DATASHEET - FAZ6-D16/3
Miniature circuit breaker (MCB), 16 A, 3p, characteristic: D, 6 kA
Similar to illustration
Part no.
Catalog No.
Alternate Catalog
No.
FAZ6-D16/3
168081
FAZ6-D16/3
Design verification as per IEC/EN 61439
Technical data for design verification
Rated operational current for specified heat dissipation
In
A
16
Equipment heat dissipation, current-dependent
Pvid
W
6.9
10.2 Strength of materials and parts
10.2.2 Corrosion resistance
Meets the product standard's requirements.
10.2.3.1 Verification of thermal stability of enclosures
10.2.3.2 Verification of resistance of insulating materials to normal heat
10.2.3.3 Verification of resistance of insulating materials to abnormal heat
and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
Does not apply, since the entire switchgear needs to be evaluated.
10.2.6 Mechanical impact
10.2.7 Inscriptions
IEC/EN 61439 design verification
10.3 Degree of protection of ASSEMBLIES
10.4 Clearances and creepage distances
10.5 Protection against electric shock
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
Is the panel builder's responsibility.
10.8 Connections for external conductors
10.9 Insulation properties
10.9.2 Power-frequency electric strength
10.9.3 Impulse withstand voltage
10.9.4 Testing of enclosures made of insulating material
10.10 Temperature rise
The panel builder is responsible for the temperature rise calculation. Eaton will
provide heat dissipation data for the devices.
10.11 Short-circuit rating
Is the panel builder's responsibility. The specifications for the switchgear must be
observed.
10.12 Electromagnetic compatibility
observed.
10.13 Mechanical function
The device meets the requirements, provided the information in the instruction
leaflet (IL) is observed.
Technical data ETIM 7.0
Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042)
Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB)
(ecl@ss10.0.1-27-14-19-01 [AAB905014])
Release characteristic
D
Number of poles (total)
3
Number of protected poles
3
Rated current
A
16
Rated voltage
V
230
Rated insulation voltage Ui
V
440
Rated impulse withstand voltage Uimp
kV
4
Rated short-circuit breaking capacity Icn EN 60898 at 230 V
kA
6
Rated short-circuit breaking capacity Icn EN 60898 at 400 V
kA
6
Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V
kA
10
05/30/2020
Eaton 168081 ED2020 V68.0 EN
1/2
Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V
kA
10
Voltage type
AC
Frequency
Hz
50 - 60
Current limiting class
3
Suitable for flush-mounted installation
No
Concurrently switching N-neutral
No
Over voltage category
3
Pollution degree
2
Additional equipment possible
Yes
Width in number of modular spacings
3
Built-in depth
mm
70.5
Degree of protection (IP)
IP20
Ambient temperature during operating
°C
-25 - 75
Connectable conductor cross section multi-wired
mm²
1 - 25
Connectable conductor cross section solid-core
mm²
1 - 25
Additional product information (links)
Temperature dependency, derating
05/30/2020
https://www.eaton.com/content/dam/eaton/technicaldocumentation/technical-data-tables/Derating table
FAZ6.pdf
Eaton Industries GmbH
http://www.eaton.eu
© 05/2020 by Eaton Industries GmbH
2/2
很抱歉,暂时无法提供与“FAZ6-D16/3”相匹配的价格&库存,您可以联系我们找货
