DATASHEET - FAZ6-D63/3
Miniature circuit breaker (MCB), 63 A, 3p, characteristic: D, 6 kA
Similar to illustration
Part no.
Catalog No.
Alternate Catalog
No.
FAZ6-D63/3
168087
FAZ6-D63/3
Delivery program
Number of poles
Design verification as per IEC/EN 61439
Technical data for design verification
3 pole
Rated operational current for specified heat dissipation
In
A
63
Equipment heat dissipation, current-dependent
Pvid
W
20.4
Static heat dissipation, non-current-dependent
Pvs
W
Heat dissipation capacity
Pdiss
W
Operating ambient temperature min.
°C
-40
Operating ambient temperature max.
°C
70
linear, per +1 °C, results in a 0.5% reduction of current carrying capacity
Technical data ETIM 7.0
Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042)
Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB)
(ecl@ss10.0.1-27-14-19-01 [AAB905014])
Release characteristic
D
Number of poles (total)
3
Number of protected poles
3
Rated current
A
63
Rated voltage
V
230
Rated insulation voltage Ui
V
440
Rated impulse withstand voltage Uimp
kV
4
Rated short-circuit breaking capacity Icn EN 60898 at 230 V
kA
6
Rated short-circuit breaking capacity Icn EN 60898 at 400 V
kA
6
Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V
kA
10
Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V
kA
10
Voltage type
AC
Frequency
Hz
50 - 60
Current limiting class
3
Suitable for flush-mounted installation
No
Concurrently switching N-neutral
No
Over voltage category
3
Pollution degree
2
Additional equipment possible
Yes
Width in number of modular spacings
3
Built-in depth
mm
70.5
Degree of protection (IP)
IP20
Ambient temperature during operating
°C
-25 - 75
Connectable conductor cross section multi-wired
mm²
1 - 25
Connectable conductor cross section solid-core
mm²
1 - 25
Additional product information (links)
Temperature dependency, derating
https://www.eaton.com/content/dam/eaton/technicaldocumentation/technical-data-tables/Derating table
FAZ6.pdf
05/30/2020
Eaton 168087 ED2020 V68.0 EN
1/2
05/30/2020
Eaton Industries GmbH
http://www.eaton.eu
© 05/2020 by Eaton Industries GmbH
2/2
很抱歉,暂时无法提供与“FAZ6-D63/3”相匹配的价格&库存,您可以联系我们找货
