FWC-10A10F
FWC-10A10F
    EATON(伊顿)
    5AG,10.00 x 38.10mm
    FUSE CARTRIDGE 10A 600VAC/700VDC
FWC-10A10F 数据手册
Bussmann ® Ferrule 6-32A FWC 600V Size ® Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 600V Ordering Information Watts Loss Part Number 6 4 30 1.5 8 6 50 2.0 10 9 70 2.5 10 ≈ 38mm 12 15 120 3.0 (⁄‹Ω£™∑) 16 25 150 3.5 20 34 260 4.8 25 60 390 6.0 32 95 600 7.5 n Interrupting rating 200kA RMS Symmetrical. n Watts loss provided at rated current. n (400 Vdc/Interrupting rating 50kA) U.L. Recognition: 32A n (700 Vdc/Interrupting rating 50kA) U.L. Recognition: 6 - 25A FWC-6A10F FWC-8A10F FWC-10A10F FWC-12A10F FWC-16A10F FWC-20A10F FWC-25A10F FWC-32A10F Carton Qty. 10 Dimensions Curves Carton Weight (kg) Figure Number BIF # 0.100 Fig. 1 35785306 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 6-32 Amp Range 38.1 (1.500") 10.3 (0.406") 9.5 (0.375") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K , given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 2.0 1.5 K 1.6 1.0 0.5 0.3 0.2 0.15 100 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.0 Kp 0.8 UL 1.2 0.6 0.5 103 0.4 800 0.3 600 500 0.2 400 Eg 250 400 500 600 300 200 Eg 300 400 500 600 0.1 30 40 50 Ib 60 70 80 90 100% The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 7-18-01 SB01191 Form No. Page 1 of 1 BIF Doc #720011
FWC-10A10F 价格&库存
很抱歉,暂时无法提供与“FWC-10A10F”相匹配的价格&库存,您可以联系我们找货
