Technical Data 720038
Effective December, 2015
Supersedes August, 2003
BUSSMANN
SERIES
FWH
6x32mm high speed ferrule fuses
Agency information
CE
RoHS compliant
UL® Recognized JFHR2, E91958, 0.25-7A
UL Recognized JDYX2, E19180, 10-30A
CSA® Component Acceptance file Class
1422-30, 1422-90 (53787) 0.25-7A
Opening times:
Catalog symbols:
FWH-(amp)A6F
FWH-(amp)A6FR (RoHS compliant)
FWH5-(amp)A6F
FWH5-(amp)A6FR (RoHS compliant)
Amp range
150%
200%
300%
0.25-7A
> 30 min.
> 30 min.
≤ 10 sec.
10-30A
> 30 min.
> 30 min.
≤ 10 sec.
Dimensions:
31.8
(1.25)
6.4
(0.25)
Description:
Eaton’s Bussmann® series of FWH 6x32mm
ferrule high speed fuses are for the protection
of DC common bus, DC drives, power
converters/rectifiers and reduced rated voltage
starters.
Specification:
Ratings
Volts
Features:
Low watts loss in a compact size
Excellent cycling capability and DC
performance
Low arc voltage and low energy let-through
(I2t)
500Vac (0.25-1A and 3.15-30A)
1000Vac (2A)
Typical applications:
600Vdc (1-5A)
DC common bus
DC drives
Power converters/rectifiers
Reduced voltage starters
Amps
3.2
(0.125)
0.25-30A
Interrupting rating
50kA AC (0.25-1A and 3.15-20A)
30kA AC (2A)
20kA AC (25-30A)
50kA DC (1-5A)
FWH 6x32mm high speed ferrule fuses
Effective December 2015
Catalog numbers:
Amps
0.25
0.5
1
2
3.15
4
5
6.3
7
10
12.5
15
16
30
Rated voltage
Vac
500
500
500
1000
500
500
500
500
500
500
500
500
500
500
500
500
I2t (A2s)
Vdc
600
600
600
600
600
Pre-arcing
0.01
0.05
0.4
1.3
3.1
15
36
50
9.9
48
75
126
145
Clearing @ 500Vac
0.05
0.25
2
3.5
7.7
40
90
125
139
60
146
177
259
345
430
Watts loss (W)
2.7
1.2
1.7
3.2
2.9
2.1
2.3
2.5
2.86
3.53
3.08
4.48
4.26
Catalog numbers
Standard
FWH-250A6F
FWH-500A6F
FWH-001A6F
FWH-002A6F
FWH-3.15A6F
FWH-004A6F
FWH-005A6F
FWH-6.30A6F
FWH-007A6F
FWH5-010A6F
FWH5-12-5A6F
FWH5-015A6F
FWH5-016A6F
FWH5-020A6F
FWH-025A6F
FWH-030A6F
RoHS compliant
FWH-250A6F
FWH-500A6F
FWH-001A6F
FWH-002A6F
FWH-3.15A6F
FWH-004A6F
FWH-005A6F
FWH-6.30A6F
FWH-007A6F
FWH5-010A6FR
FWH5-12-5A6FR
FWH5-015A6FR
FWH5-016A6FR
FWH5-020A6FR
FWH-025A6FR
FWH-030A6FR
0.25-7A 300% minimum opening current at rated voltage.
10-30A 200% minimum opening current at rated voltage.
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 720038 — BU-SB15288
December 2015
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton and Bussmann are valuable
trademarks of Eaton in the US and other
countries. You are not permitted to use the
Eaton trademarks without prior written
consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“FWH-001A6F”相匹配的价格&库存,您可以联系我们找货
