FWP-150A
FWP-150A
    EATON(伊顿)
    Cylindrical,Blade Terminal(Bolt)
    FUSE CARTRIDGE 150A 700VAC/VDC
FWP-150A 数据手册
Bussmann ® FWP 700V Type 5-1200A R ® Electrical Characteristics Ordering Information I2t (A2 Sec) Rated Current Clearing Watts Part Carton RMS-Amps Pre-arc at 700V Loss Number Qty. 5 1.6 10 1.5 FWP-5B __________________________________________________________________________ 10 3.6 20 4 FWP-10B __________________________________________________________________________ 15 10 75 5.5 FWP-15B __________________________________________________________________________ 20 26 180 6 FWP-20B __________________________________________________________________________ 25 44 340 7 FWP-25B __________________________________________________________________________ 10 Dimensions Carton Weight (lbs) Figure Number 2.25 Curves BIF # 35785316 30 58 450 9 FWP-30B ______________________________________________________________________________________ ____________ 35 34 160 12 FWP-35B __________________________________________________________________________ 40 76 320 12 FWP-40B __________________________________________________________________________ 50 135 600 12 FWP-50B __________________________________________________________________________ 5 1.21 60 210 950 15.5 FWP-60B _________________________________________________________________________________________________ 35785308 70 305 2000 18 FWP-70B __________________________________________________________________________ 80 360 2400 21 FWP-80B __________________________________________________________________________ 0.24 90 415 2700 25 FWP-90B __________________________________________________________________________ 100 540 3500 27 FWP-100B __________________________________________________________________________ ____________ 125 1800 7300 28 FWP-125A __________________________________________________________________________ FWP 150 2900 11700 32 FWP-150A __________________________________________________________________________ Fig. 1 0.65 700V __________________________________________________________________________ 175 4200 16700 35 FWP-175A 200 5500 22000 43 FWP-200A __________________________________________________________________________ ____________ 225 7700 31300 45 FWP-225A __________________________________________________________________________ 361 250 10500 42500 48 FWP-250A __________________________________________________________________________ 300 17600 71200 58 FWP-300A __________________________________________________________________________ 1 1.17 350 23700 95600 65 FWP-350A __________________________________________________________________________ 400 31000 125000 78 FWP-400A __________________________________________________________________________ ____________ 450 36400 137000 94 FWP-450A __________________________________________________________________________ 500 45200 170000 107 FWP-500A __________________________________________________________________________ 2.39 600 66700 250000 122 FWP-600A __________________________________________________________________________ ____________ 700 54000 300000 125 FWP-700A __________________________________________________________________________ 800 78000 450000 140 FWP-800A __________________________________________________________________________ 1.21 _______________________ 900 91500 530000 150 FWP-900A __________________________________________________________________________ 1000 120000 600000 170 FWP-1000A __________________________________________________________________________ 1200 n n n n 195000 1100000 190 FWP-1200A 6.60 Fig. 2 Fig. 3 Interrupting rating 200kA RMS Symmetrical. 1 kg = 2.2 lbs Watts loss provided at rated current. (700 Vdc/Interrupting rating 50kA) U.L. Recognition & CSA Component Acceptance on 5 through 100 & 700 through 800 amperes. (700 Vdc/Interrupting rating 10kA) U.L. Recognition & CSA Component Acceptance on 125 through 600 amperes. 3-6-02 A02008 35785308 ___________ 1 lb = 0.45 kg Form No. FWP 700 Page 1 of 2 Data Sheet: 720012 Bussmann ® 5-1200A FWP 700V R ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K , given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 2 1.5 1.0 Kp 0.8 UL K 1.6 1.4 1.2 103 1.0 2) 0.5 0.6 0.5 1) 0.4 2) 8 0.3 0.2 0.3 6 5 1) 3) Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 4 0.15 316 Eg 460 604 Eg 3 300 700 1) 35-100 Amp Range 2) 125-600 Amp Range 3) 700-1200 Amp Range 400 500 600 Ib 0.1 30 40 50 700 60 70 80 90 100% 1) 125-600 Amp Range 2) 35-100 & 700-1200 Amp Range Dimensions Fig. 1: 5-800 Amp Range Fig. 2: 900-1000 Amp Range Fig. 3: 1200 Amp Range 3.500 1.375 J 0.125 0.500 5.966 7.594 A D E C 9.590 6.840 3.844 3.844 10.844 5.154 1.031 0.625 1.625 1.750 0.625 2.750 0.750 0.500 4.250 F 3.500 G H B Order # Fig. A B C D E F G H J FWP-5B-30B 1 2.870 0.563 1.855 2.477 2.477 0.250 0.405 0.063 0.250 FWP-35B-60B 1 4.375 0.813 2.750 3.708 3.312 0.344 0.725 0.125 0.542 FWP-70B-100B 1 4.406 0.947 2.594 3.625 3.563 0.344 0.750 0.125 0.375 FWP-125A-200A 1 5.090 1.500 2.840 4.190 3.500 0.410 1.000 0.250 0.750 FWP-225A-400A 1 5.090 2.000 2.840 4.280 3.530 0.410 1.500 0.250 0.780 FWP-450A-600A 1 7.090 2.500 2.840 5.720 4.190 0.530 2.000 0.380 1.300 FWP-700A-800A 1 6.630 2.000 2.844 5.562 5.062 0.625 1.500 0.250 0.875 FWP-900A-1000A 2 See Drawing FWP-1200A 3 See Drawing Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 3-6-02 A02008 Form No. FWP 700 Page 2 of 2 Data Sheet: 720012
FWP-150A 价格&库存
很抱歉,暂时无法提供与“FWP-150A”相匹配的价格&库存,您可以联系我们找货
