Technical Data 4430
Effective September 2020
Supersedes June 2015
HCM0503
High current power inductors
Applications
Product features
High current carrying capacity
Low core losses
Magnetically shielded, low EMI
Frequency range up to 1 MHz
Inductance range from 0.2 μH to 22 μH
Current range from 1.9 A to 22 A
5.5 mm x 5.3 mm footprint surface mount
package in a 3.0 mm height
Iron powder core material
Voltage Regulator Module (VRM)
Multi-phase regulators
Point-of-Load modules
Desktop and server VRMs and EVRDs
Base station equipment
Notebook and laptop regulators
Battery power systems
Graphics cards
Data networking and storage systems
Environmental compliance and general
specifications
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient + self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
HCM0503
Technical Data 4430
Product Specifications
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical @
+20 °C
DCR (mΩ)
maximum @ +20 °C
K-factor5
HCM0503-R20-R
0.20
0.13
22.2
21.0
2.1
2.31
1764
HCM0503-R35-R
0.35
0.22
16.6
14.9
3.9
4.29
1259
HCM0503-R47-R
0.47
0.30
12.0
11.5
6.5
7.15
820
HCM0503-R75-R
0.75
0.48
11.3
9.7
8.5
9.35
801
HCM0503-1R0-R
1.0
0.64
10.1
8.5
10.4
11.44
588
HCM0503-1R5-R
1.5
0.96
7.5
7.0
17.1
18.5
393
HCM0503-2R2-R
2.2
1.4
6.8
6.5
22.5
25
325
HCM0503- 3R3-R
3.3
2.1
5.5
6.0
36.4
40.4
273
HCM0503-4R7-R
4.7
3.0
4.5
5.5
54
60.0
226
HCM0503-5R6-R
5.6
3.6
4.3
3.5
63
70.6
206
HCM0503-100-R
10
6.4
2.8
2.3
122.1
131.9
158
HCM0503-150-R
15
9.6
2.4
2.1
138.4
166.2
127
HCM0503-220-R
22
14
1.9
1.9
260
270
106
Part Number
6
1. Open circuit inductance (OCL) test parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, @ +25 °C
2. Full load inductance (FLL) test parameters: 100 kHz, 0.25 Vrms, @ Isat, @ +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L:
(Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM0503-xxx-R
HCM0503 = Product code and size
xxx= inductance value in μH, R= decimal point ,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Recommended Pad Layout
3.0
max
5.15
±0.35
1.0
±0.3
3.15
typ.
2.2
1
5.10
±0.2
a
2
XXX
wly
R
1
1
1.5
±0.30
2
2.05
2
b
www.eaton.com/electronics
1
2.2
Part marking: xxx=inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros.
wly=date code, R=revision level
All soldering surfaces to be coplanar within 0.1 millimeters
Tolerances are ±0.2 millimeters unless stated otherwise
DCR measured from point “a” to point “b”
Color: Grey
Traces or vias underneath the inductor is not recommended
2
Schematic
2
HCM0503
Technical Data 4430
Packaging information (mm)
Supplied in tape and reel packaging, 2,000 parts per 13” diameter reel (EIA-481 compliant)
4.0
1.5 dia
2.0
A
1.5 dia
1.75
1
7.5
5.7
16.0
±-0.3
5.2
2
2.0
2.9
3.2
5.4
A
8.0
SECTION A – A
User direction of feed
Temperature rise vs. total loss
50
Temperature Rise (°C)
40
30
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1.0
Total Loss (W)
3
HCM0503
Technical Data 4430
Core loss vs. Bp-p
10000.0
500kHz
300kHz
200kHz
100kHz
50kHz
Core Loss (mW)
1000.0
100.0
25kHz
10.0
1.0
0.1
100
1000
10000
B p-p (Gauss)
Inductance characteristics
110%
110%
100%
100%
90%
90%
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
4
6
8 10 12 14 16 18 20 22 24 26 28 30
I DC (Amps)
4
HCM0503-R35-R
% of OCL
% of OCL
HCM0503-R20-R
4
6
8
I DC (Amps)
HCM0503
Technical Data 4430
HCM0503-R47-R
HCM0503-R75-R
110%
100%
100%
90%
90%
% of OCL
% of OCL
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
4
6
8
10
12
14
16
18
40%
24
4
6
I DC (Amps)
100%
100%
90%
90%
% of OCL
% of OCL
110%
80%
70%
50%
50%
40%
40%
8
I DC (Amps)
10
12
14
16
4
18
8
10
12
I DC (Amps)
HCM0503-2R2-R
HCM0503-3R3-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
16
70%
60%
6
14
80%
60%
4
12
HCM0503-1R5-R
110%
2
10
I DC (Amps)
HCM0503-1R0-R
80%
70%
60%
80%
70%
60%
50%
50%
40%
2
3
4
5
6
7
I DC (Amps)
8
9
10
11
12
40%
2
3
4
5
6
I DC (Amps)
7
8
9
10
11
5
HCM0503
Technical Data 4430
HCM0503-5R6-R
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
HCM0503-4R7-R
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
2
3
4
5
6
7
8
9
10
2
3
I DC (Amps)
110%
110%
100%
100%
90%
90%
% of OCL
% of OCL
6
7
8
9
4.0
4.5
5.0
HCM0503-150-R
80%
70%
80%
70%
60%
60%
50%
50%
40%
40%
0.0
0.5
1.0
1.5
2.0
2.5
3.0
I DC (Amps)
3.5
4.0
4.5
0.0
5.0
110%
100%
90%
80%
70%
60%
50%
40%
0.0
0.5
1.0
1.5
2.0
I DC (Amps)
2.5
3.0
0.5
1.0
1.5
2.0
2.5
3.0
I DC (Amps)
HCM0503-220-R
% of OCL
5
I DC (Amps)
HCM0503-100-R
6
4
3.5
3.5
HCM0503
Technical Data 4430
Solder reflow profile
TP
TC -5 °C
tP
Max. ramp up rate = 3 °C/s
Max. ramp down rate = 6 °C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM0503-220-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.066321+0.91414
- 10+5.8441310+0.75603
- 100+4.80115100+0.62111
- 1000+3.948981000+0.51086
- 国内价格 香港价格
- 2000+5.354532000+0.69269
- 国内价格 香港价格
- 2000+3.759682000+0.48638
- 4000+3.545644000+0.45869
- 6000+3.426276000+0.44324
- 10000+3.2817410000+0.42455
- 14000+3.1899914000+0.41268
- 20000+3.1116320000+0.40254
