HFDE322521
HFDE322521
    EATON(伊顿)
    EATON CUTLER HAMMER - HFDE322521 - ELECTRONIC CIRCUIT BREAKER, 3 POLE, 225A
HFDE322521 数据手册
2.3 2 Molded Case Circuit Breakers Series C Contents Molded Case Circuit Breaker Product Family Description 2 2 2 2 2 2 2 2 Learn Online 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Page Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes). . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes). . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes). . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 Drawings Online Product Overview Eaton’s molded case circuit breakers are designed to provide circuit protection for low voltage distribution systems. They are described by NEMA as, “... a device for closing and interrupting a circuit between separable contacts under both normal and abnormal conditions,” and furthermore as, “... a breaker assembled as an integral unit in a supporting and enclosing housing of insulating material.” The National Electrical Code (NEC) describes them as, “A device designed to open and close a circuit by nonautomatic means, and to open the circuit automatically on a predetermined overload of current, without injury to itself when properly applied within its rating.” So designed, Eaton circuit breakers protect conductors against overloads and conductors and connected apparatus, such as motors and motor starters, against short circuits. In low voltage distribution systems, there are many varied applications of molded case circuit breakers. Eaton offers the most comprehensive family of molded case circuit breakers in the industry. This section of circuit breakers includes: ● ● ● ● ● ● Thermal-magnetic trip breakers Electronic rms trip breakers Molded case switches Motor circuit protectors Current limiting breakers Special application breakers Modified Breakers Eaton breakers can be ordered with internal accessories installed. These modified breakers will be subject to an addition charge. Special Calibration Special non-UL-listed calibrations are available for certain ambient temperatures other than 40 °C and for frequencies other than 50/60 Hz or DC. Reduced interrupting ratings will apply for 400 Hz applications. 50 °C Calibration Add suffix V to catalog Number for complete breaker, listed above, when ordering listed ampere ratings for breakers to be used in 50 °C ambients. (No price adder.) (No UL label.) Moisture-Fungus Treatment All circuit breaker cases are molded from glass-polyester which does not support the growth of fungus. Any parts which are susceptible to the growth of fungus will require special treatment. Freeze-Tested Circuit Breakers The circuit breakers may be ordered with freeze testing. This option uses special lubrication and mechanical operation is verified at –40 °C. Marine Applications E- to R-Framed circuit breakers can be supplied to meet the following marine specifications: ● U.S. Coast Guard CFR 46; ABS—American Bureau of Shipping; IEEE 45; DNV; Lloyds; and ABS/NVR 2 2 These specifications generally require molded case circuit breakers to be supplied with 50 °C ambient, and plug-in adapter kits. When plug-in adapter kits are used, no terminals need be supplied (switchboard applications). Circuit breakers can also be supplied to meet UL 489 Supplement SA (Marine use) and UL 489 Supplement SB (Naval Use). UL 489 Supplement SA applies to vessels over 65 feet (19.8 m) in length. Requirements include 40 °C ambient calibration, special labeling, and no use of aluminum conductors or terminals. (No 50 °C.) ● Or you can choose to add 50 °C ambient but then there is no “UL” mark. ● Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Suffix VH08 UL 489 Supplement SB requires partial 50 °C ambient calibration, vibration testing, special nameplating and no use of aluminum conductors or terminals. Eaton chooses to always fully calibrate to 50 °C ambient. (“Naval” labeled per UL, and UL now allows 50 °C label here.) ● V4-T2-116 Suffix H08 Suffix VH09 Molded Case Circuit Breakers Series C 2.3 Standards and Certifications Certified Test Reports Eaton breakers can be ordered with certified test reports at the time of order entry. Test report documents the thermal and magnetic or electronic tripping characteristics of the individual breaker. Breaker and test report must be ordered together. Add suffix 12 to breaker catalog number and enter separate line item on order for certified test report. Molded case circuit breakers are designed to conform with the following standards: ● ● ● ● ● ● Underwriters Laboratories Inc., Standard UL 489, molded case circuit breakers and circuit breaker enclosures National Electrical Manufacturers Association (NEMA) Standards Publication No. AB1-1993, molded case circuit breakers Australian Standard AS 2184, molded case circuit breakers British Standards Institution Standard BS 4752: Part 1, switchgear and control gear Part 1: circuit breakers Canadian Standards Association (CSA) Standard C22.2 No. 5, service entrance and branch circuit breakers International Electrotechnical Commission Recommendations IEC 60947-2, circuit breakers ● ● ● ● ● Japanese T-Mark Standard molded case circuit breakers South African Bureau of Standards, Standard SABS 156, Standard Specification for molded case circuit breakers Swiss Electro-Technical Association Standard SEV 157-1, safety regulations for circuit breakers Union Technique de l’Electricite Standard NF C 63-120, low voltage switchgear and control gear circuit breaker requirements Verband Deutscher Elektrotechniker (Association of German Electrical Engineers) Standard VDE 0660, low voltage switchgear and control gear, circuit breakers Conformance with these standards satisfies most local and international codes, assuming user acceptability and simplified application. Molded case circuit breakers equal or exceed Federal Specification Classification W-C-375b requirements for the particular class associated with the circuit breaker frame being considered. Open breakers do not have service entrance ratings. Service entrance rating is part of the enclosure. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-117 2.3 2 2 2 Molded Case Circuit Breakers Series C Quick Reference Industrial Circuit Breakers G-Frame UL Listed Interrupting Ratings (rms Symmetrical Amperes) Circuit Breaker Type Continuous Ampere Rating at 40 °C No. of Poles AC GHB 15–100 1 2 GHB 15–100 2, 3 2 GHB 15–100 GHB 15–100 2 HGHB 15–30 1 277 125 N.I.T.U. 12c, 13a, 13b 65 — — 25 — — GHBS 15–30 1, 2 480Y/277 — — — 65 65 — 14 — — 2 GBHS 15–20 1, 2 600Y/347 — N.I.T.U. — — — — — — 10 GDB 15–50 2 480 125/250 N.I.T.U. — — — — — 14 2 GDB 15–100 3 480 250 N.I.T.U. — — — — — 14 2 GD 15–50 2 480 125/250 N.I.T.U. 13b — — 65 — GD 15–100 3 480 250 N.I.T.U. 13b — — 65 2 GHC 15–100 1 120 125 N.I.T.U. 12c, 13a 65 — — GHC 15–100 2, 3 240 125/250 N.I.T.U. 13b — — 65 2 GHC 15–100 1 277 125 N.I.T.U. 12c, 13a — — — 14 2 GHC 15–100 2, 3 480Y/277 125/250 N.I.T.U. 13b — — — HGHC 15–30 1 277 125 N.I.T.U. — 65 — — 2 2 2 2 Volts AC (kA) DC Type of Trip 1 Federal Specification W-C-375b 120 120/240 240 120 125 N.I.T.U. 11a 65 — — — — — 240 125/250 N.I.T.U. 11a10b, 11b — — 65 — — — 1 277 125 N.I.T.U. 12b, 14b — — — 14 — — 2, 3 480Y/277 125/250 N.I.T.U. 15b — — — 14 14 — DC (kA) 2 Notes 1 N.I.T.U. is non-interchangeable trip unit and I.T.U. is interchangeable trip unit. 2 Two-pole circuit breaker, or two poles of three-pole circuit breaker at 250 Vdc. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-118 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 250 Page Number 14 — V4-T2-126 — 14 V4-T2-126 14 — V4-T2-126 — 14 V4-T2-126 14 — V4-T2-126 — — V4-T1-34 — — V4-T1-34 — — 10 V4-T2-124 — — 10 V4-T2-124 14 — — 10 V4-T2-123 — 22 — — 10 V4-T2-123 — — — 14 — V4-T2-131 — — — 1 V4-T2-131 — — 14 — V4-T2-131 14 14 — — 14 V4-T2-131 25 — — 14 — V4-T2-131 277 480 600 125 2.3 Molded Case Circuit Breakers Series C F-Frame 2 UL Listed Interrupting Ratings (rms Symmetrical Amperes) Circuit Breaker Type Continuous Ampere Rating at 40 °C No. of Poles AC DC EDB 100–225 2, 3 240 EDS 100–225 2, 3 240 ED 15–225 2, 3 240 EDH 100–225 2, 3 240 125 EDC 100–225 2, 3 240 125 EHD 15–100 1 277 125 N.I.T.U. 13a — — — 14 — — EHD 15–100 2, 3 480 250 N.I.T.U. 13b — — 18 — 14 — FDB 15–150 2, 3 600 250 N.I.T.U. 18a — — 18 — 14 14 — — 18 — 14 — — — 35 — Volts Type of Trip 1 Federal Specification W-C-375b AC (kA) 120 120/240 240 277 480 600 125 250 Page Number 125 N.I.T.U. — — — 22 — — — 10 — V4-T2-135 125 N.I.T.U. — — — 42 — — — 10 — V4-T2-135 125 N.I.T.U. 12b — — 65 — — — 10 — V4-T2-135 N.I.T.U. 14b — — 100 — — — 10 — V4-T2-135 N.I.T.U. 1 — — 200 — — — 10 — V4-T2-135 10 — V4-T2-135 — 10 V4-T2-135 — 10 V4-T2-135 14 — 10 V4-T2-135 — 10 — V4-T2-135 FDB 15–150 4 600 250 N.I.T.U. 3 FD 15–150 1 277 125 N.I.T.U. 13a DC (kA) 2 FD 15–225 2, 3 600 250 N.I.T.U. 22a — — 65 — 35 18 — 10 V4-T2-135 FD 15–225 4 600 250 N.I.T.U. 3 — — 65 — 35 18 — 10 V4-T2-135 FDE 15–225 3 600 — N.I.T.U. — — — 65 — 35 18 — — V4-T2-135 HFD 15–150 1 277 125 N.I.T.U. 13a — — — 65 — — 10 — V4-T2-135 HFD 15–225 2,3 600 250 N.I.T.U. 22a — — 100 — 65 25 — 22 V4-T2-135 HFD 15–225 4 600 250 N.I.T.U. 3 — — 100 — 65 25 — 22 V4-T2-135 — — — 100 — 65 25 — — V4-T2-135 HFDE 15–225 3 600 — N.I.T.U. 4 15–225 2, 3 600 250 N.I.T.U. 24a — — 200 — 100 35 — 22 V4-T2-135 FDC 4 15–225 4 600 250 N.I.T.U. 3 — — 200 — 100 35 — 22 V4-T2-135 FDCE 45 15–225 3 600 — N.I.T.U. — — — 200 — 100 25 — — V4-T2-135 FDC 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 N.I.T.U. is non-interchangeable trip unit and I.T.U. is interchangeable trip unit. 2 Two-pole circuit breaker, or two poles of three-pole circuit breaker at 250 Vdc. 3 Not defined in W-C-375b. 4 Current limiting. 5 Check with Eaton for availability. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-119 2.3 Molded Case Circuit Breakers Series C 2 J-Frame 2 Circuit Breaker Type Continuous Ampere Rating at 40 °C 2 JDB 70–250 2, 3 2 JD 70–250 2, 3, 4 HJD 70–250 2, 3, 4 2 JDC 3 70–250 2, 3, 4 2 2 UL Listed Interrupting Ratings (rms Symmetrical Amperes) Volts No. of Poles Federal Specification W-C-375b DC Type of Trip 1 600 250 N.I.T.U. 22a — 600 250 I.T.U. 22a — 600 250 I.T.U. 22a — 600 250 I.T.U. 22a — Federal Specification W-C-375b AC (kA) 120 120/240 240 277 480 600 125 250 Page Number AC DC (kA) 2 AC (kA) 120 240 277 480 600 125 250 Page Number — 65 — 35 18 — 10 V4-T2-156 — 65 — 35 18 — 10 V4-T2-155 — 100 — 65 25 — 22 V4-T2-155 — 200 — 100 35 — 22 V4-T2-155 120/240 K-Frame Circuit Breaker Type Continuous Ampere Rating at 40 °C No. of Poles AC DC Type of Trip 1 2 DK 250–400 2, 3 240 250 N.I.T.U. 14b — — 65 — — — — 10 V4-T2-167 KDB 100–400 2, 3 600 250 N.I.T.U. 23a — — 65 — 35 25 — 10 V4-T2-167 2 KD 100–400 2, 3, 4 600 250 I.T.U. 23a — — 65 — 35 25 — 10 V4-T2-164, V4-T2-165, V4-T2-169, V4-T2-172 2 CKD 100–400 2, 3, 4 600 250 I.T.U. 23a — — 65 — 35 25 — — V4-T2-166, V4-T2-175, V4-T2-177 2 HKD 100–400 2, 3, 4 600 250 I.T.U. 23a — — 100 — 65 35 — 22 V4-T2-164, V4-T2-165, V4-T2-169, V4-T2-172 2 CHKD 100–400 2, 3, 4 600 250 I.T.U. 23a — — 100 — 65 35 — — V4-T2-166, V4-T2-175, V4-T2-177 KDC 3 100–400 2, 3, 4 600 250 I.T.U. 23a — — 200 — 100 65 — 22 V4-T2-164, V4-T2-165, V4-T2-169, V4-T2-172 Federal Specification W-C-375b AC (kA) DC Type of Trip 1 2 2 2 2 2 2 2 2 UL Listed Interrupting Ratings (rms Symmetrical Amperes) Volts DC (kA) 2 L-Frame UL Listed Interrupting Ratings (rms Symmetrical Amperes) Circuit Breaker Type Continuous Ampere Rating at 40 °C LDB 300–600 2, 3 600 250 N.I.T.U. 23a — — 65 — 35 25 — 22 V4-T2-190 LD 300–600 2, 3, 4 600 250 I.T.U. 23a — — 65 — 35 25 — 22 V4-T2-188, V4-T2-189, V4-T2-194 Volts No. of Poles AC 120 DC (kA) 2 120/240 240 277 480 600 125 250 Page Number CLD 300–600 2, 3, 4 600 250 I.T.U. 23a — — 65 — 35 25 — — V4-T2-190, V4-T2-200 HLD 300–600 2, 3, 4 600 250 I.T.U. 23a — — 100 — 65 35 — 25 V4-T2-188, V4-T2-189, V4-T2-194 2 CHLD 300–600 2, 3, 4 600 250 I.T.U. 23a — — 100 — 65 35 — — V4-T2-190, V4-T2-200 LDC 3 300–600 2, 3, 4 600 250 I.T.U. 23a — — 200 — 100 50 — 30 2 V4-T2-188, V4-T2-189, V4-T2-196 CLDC 3 300–600 2, 3, 4 600 250 I.T.U. 23a — — 200 — 100 50 — 30 V4-T2-190, V4-T2-202 Federal Specification W-C-375b AC (kA) 120 120/240 240 277 480 600 125 250 Page Number 23a — — 65 — 50 25 — 22 V4-T2-213, V4-T2-215 2 2 M-Frame 2 Circuit Breaker Type Continuous Ampere Rating at 40 °C No. of Poles AC DC Type of Trip 1 MDL 300–800 2, 3 600 250 I.T.U. 2 2 2 2 2 UL Listed Interrupting Ratings (rms Symmetrical Amperes) Volts DC (kA) 2 CMDL 300–800 2, 3 600 250 I.T.U. 23a — — 65 — 50 25 — — V4-T2-215 HMDL 300–800 2, 3 600 250 I.T.U. 23a — — 100 — 65 35 — 25 V4-T2-213, V4-T2-215 CHMDL 300–800 2, 3 600 250 I.T.U. 23a — — 100 — 65 35 — — V4-T2-215 Notes 1 N.I.T.U. is non-interchangeable trip unit and I.T.U. is interchangeable trip unit. 2 Two-pole circuit breaker, or two poles of three-pole circuit breaker at 250 Vdc. 3 Current limiting. V4-T2-120 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C Molded Case Circuit Breaker Product Family 2.3 Contents Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-122 V4-T2-122 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 G-Frame (15–100 Amperes) 2 Product Description 2 ● ● ● ● All two- and three-pole circuit breakers are of the common trip type. On all three-phase delta (240 V) Grounded B phase applications, refer to Eaton Single-pole circuit breakers, 15 and 20 amperes. Switching duty rated (SWD) for fluorescent lighting applications All G-Frame circuit breakers are suitable for reverse feed use HACR rated 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-121 2.3 2 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. Circuit Breaker/Frame GD 3 100 K 2 2 Circuit Breaker Type GD HGHB GDB HGHC GHB GHBGFEP GHC GHCGFEP GHQ 2 2 2 2 2 2 Suffix Number of Poles 1 = 1 pole 2 = 2 poles 3 = 3 poles Trip Amperes 035 040 045 050 060 015 020 024 030 K D C V 070 080 090 100 = Molded case switch = Ring type terminals = Steel collars = 122 °F (50 °C) J01= Fungus proofed R01= Shock tested F01= Freeze tester HID= High intensity discharge 1 Technical Data and Specifications UL 489 Interrupting Capacity Ratings Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 120 240 277 480 480Y/277 125 250 23 GDB 2, 3 — — — 14 — — 10 2 GD 2 — 65 — 14 — — 10 GD 3 — 65 — 22 — — 10 2 GHQ — 65 — 14 — — — — 2 GHB 1 65 — 14 — — 14 — GHB 2, 3 — 65 — — 14 14 — 2 HGHB 1 65 — 25 — — 14 — GHC 1 65 — 14 — — 14 — GHC 2, 3 — 65 — — 14 14 — HGHC 1 65 — 25 — — 14 — 2 2 2 2 Volts DC Terminal Types For line and load-side. Terminals are UL listed as suitable for wire type and size given below. 2 Terminal Types 2 Standard Circuit Breaker Amperes Terminal Type Material Screw Head Type Wire Type AWG Wire Range Metric Wire Range (mm2) 4 2 15–20 Clamp (plated steel) Slotted Cu/Al 14–10 2.5–4 25–100 Pressure (aluminum body) Slotted Cu/Al 10–1/0 4–50 2 Optional—GD Only Pressure (steel body) Slotted Cu 14–3 — 2 2 2 15–100 Notes 1 HID suffix only applies to the GHB and GHC single-pole, 15–20 A circuit breakers. 2 Time constant is 8 milliseconds minimum. 3 Two poles of three-pole circuit breaker. 4 Not UL listed sizes. 2 2 2 2 V4-T2-122 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Contents Typical G-Frame Circuit Breaker Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference. . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 Type GD Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units (15–100 Amperes) 2 Product Description 2 ● ● Standards and Certifications Cable in, cable out Includes mounting hardware and BMHE ● UL/CSA 2 2 2 Product Selection 2 Type GD Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 480 Vac Maximum, 250 Vdc Includes Line and Load Terminals Includes Binding Head Screws and Clamps 10–32 x 0.312 Two-Pole Three-Pole Three-Pole Catalog Number Catalog Number Catalog Number 15 GD2015 GD3015 GD3015D 20 GD2020 GD3020 GD3020D 25 GD2025 GD3025 GD3025D 30 GD2030 GD3030 GD3030D 35 GD2035 GD3035 GD3035D 40 GD2040 GD3040 GD3040D 45 GD2045 GD3045 GD3045D 50 GD2050 GD3050 GD3050D 60 — GD3060 GD3060D 70 — GD3070 GD3070D 80 — GD3080 GD3080D 90 — GD3090 GD3090D 100 — GD3100 GD3100D 14 kAIC at 480 Vac Maximum Continuous Ampere Rating at 40 °C 22 kAIC at 480 Vac 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-123 2.3 2 2 2 Molded Case Circuit Breakers Series C Type GDB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 480 Vac Maximum, 250 Vdc 14 kAIC at 480 Vac Includes Line and Load Terminals Maximum Continuous Ampere Rating at 40 °C Two-Pole Three-Pole Catalog Number Catalog Number 15 GDB2015 GDB3015 20 GDB2020 GDB3020 25 GDB2025 GDB3025 30 GDB2030 GDB3030 2 35 GDB2035 GDB3035 40 GDB2040 GDB3040 2 45 GDB2045 GDB3045 50 GDB2050 GDB3050 2 60 — GDB3060 2 70 — GDB3070 80 — GDB3080 90 — GDB3090 100 — GDB3100 2 2 2 2 2 Type GD Molded Case Switches 2 Type GD Molded Case Switches—Three-Pole 2 2 2 2 480 Vac Maximum, 250 Vdc Maximum Continuous Ampere Rating at 40 °C Catalog Number (Includes Line and Load Terminals) 60 GD3060K 60 GD3060KC 1 100 GD3100K 100 GD3100KD 2 2 Notes 1 Includes line and load steel terminals. 2 Includes binding head screws and clamps 10–32 x 0.312. 2 Molded case switches may open above 1300 amperes. 2 2 2 2 2 2 2 2 2 2 2 V4-T2-124 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Dimensions 2 Approximate Dimensions in Inches (mm) 2 GD-Frame, Three-Pole Front View 2 Side View 2 2 2 2 2 4.88 (123.8) 2 Off 2 2 2 3.00 (76.2) 2 2.63 (66.7) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-125 2.3 2 Molded Case Circuit Breakers Series C Contents Typical GHB Description 2 Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes). . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes). . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes). . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes). . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . 2 2 2 2 2 2 2 2 2 Types GHB and HGHB Bolt-On Panelboard Circuit Breakers (15–100 Amperes) 2 Standards and Certifications 2 2 2 These breakers meet the requirements of Federal Specification W-C-375b as follows: ● Type GHB, 120 and 240 V: ● Single-pole: Class 11a ● Two-, three-pole: Classes 10b, 11b, 12b, 14b, 15b ● UL/CSA ● Type GHB, 277 and 480Y/277V: ● Single-pole: Classes 12c, 13a ● Two-, three-pole: Class 13b ● Type HGHB 277V ● Type GHQ 277V 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-126 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 Molded Case Circuit Breakers Series C 2.3 Product Selection Typical GHB 2 2 Type GHB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 1 277/480 Vac Maximum, 125 Vdc Maximum 2 277/480 Vac Maximum, 125/250 Vdc Maximum 2 277/480 Vac Maximum, 125/250 Vdc Maximum 3 Continuous Ampere Rating at 40 °C Single-Pole Two-Pole Three-Pole Catalog Number Catalog Number Catalog Number 15 GHB1015 45 GHB2015 4 GHB3015 4 20 GHB1020 45 GHB2020 4 GHB3020 4 25 GHB1025 GHB2025 GHB3025 30 GHB1030 GHB2030 GHB3030 35 GHB1035 GHB2035 GHB3035 40 GHB1040 GHB2040 GHB3040 45 GHB1045 GHB2045 GHB3045 50 GHB1050 GHB2050 GHB3050 60 GHB1060 GHB2060 GHB3060 70 GHB1070 GHB2070 GHB3070 80 GHB1080 GHB2080 GHB3080 90 GHB1090 GHB2090 GHB3090 100 GHB1100 GHB2100 GHB3100 2 2 2 2 2 2 2 2 2 2 2 Type HGHB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 2 277 Vac Maximum, 125 Vdc Maximum Continuous Ampere Rating at 40 °C Single-Pole 15 HGHB1015 6 20 HGHB1020 6 25 HGHB1025 30 HGHB1030 2 Catalog Number 2 2 2 Notes 1 480Y/277 V, circuit breakers (Type GHB) not suitable for three-phase delta (480 V). 2 15 through 70 ampere circuit breakers only. 3 Use two outside poles. 4 Uses 0.190 (4.83) –32 screw type clamp terminals. 5 Add suffix HID for High Intensity Discharge (HID) applications. 15 and 20 ampere, single-pole are SWD rated. 6 15 and 20 ampere, single-pole are SWD rated. 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-127 2.3 2 2 2 Molded Case Circuit Breakers Series C Dimensions Approximate Dimensions in Inches (mm) GDB-Frame, Three-Pole Front View 2 Side View 2 2 2 2 4.00 (101.6) 2 2 2 2 3.00 (76.2) Max. 2 2.63 (66.7) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-128 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Contents Single-Phase (requires two poles) Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference. . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 Type GHBGFEP Bolt-On Panelboard 30 mA Industrial Ground Fault Circuit Protectors (15–100 Amperes) 2 Product Description 2 ● ● Standards and Certifications 15–60 amperes, 277 V, 50/60 Hz Operational voltage 240 V to 305 V These circuit breakers meet the requirements of UL 489 and UL 1053. 2 2 2 2 Product Selection 2 Type GHBGFEP Bolt-On Panelboard 30 mA Industrial Ground Fault Circuit Protectors with Non-Interchangeable Trip Units 2 Single-Phase (Requires Two Poles) 277 Vac, 30 mA Continuous Ampere Rating at 40 °C 2 Catalog Number 15 GHBGFEP1015 20 GHBGFEP1020 30 GHBGFEP1030 40 GHBGFEP1040 50 GHBGFEP1050 60 GHBGFEP1060 2 2 2 2 2 Technical Data and Specifications 2 Interrupting Capacity Ratings Circuit Breaker Type Number of Poles Interrupting Capacity (Symmetrical Amperes) GHBGFEP 1 14,000 2 277 Vac (50/60 Hz) 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-129 2.3 2 2 2 Molded Case Circuit Breakers Series C Dimensions Approximate Dimensions in Inches (mm) GHB-Frame, Three-Pole Front View 2 Side View 2 2 2 2 4.00 (101.6) 2 2 2 2 3.00 (76.2) 2.63 (66.7) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-130 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Contents Typical GHC Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference. . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 Types GHC and HGHC Circuit Breakers (15–100 Amperes) 2 Product Description 2 ● ● ● ● ● 15–100 amperes 120, 240, 277, 480Y/277V, 50/60 Hz, 125, 125/250 Vdc Single-, two- and three-pole Cable in, cable out Does not include mounting hardware Standards and Certifications These breakers meet the requirements of Federal Specification W-C-37b as follows: ● 2 2 Type GHC, 277 and 480Y/ 277V: ● Single-pole: Classes 12c, 13a ● Two-, three-pole: Class 13b ● UL/CSA 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-131 2.3 2 2 2 2 Molded Case Circuit Breakers Series C Product Selection Type GHC Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 277 Vac Maximum, 125 Vdc Maximum 1 480Y/277 Vac Maximum, 125/250 Vdc Maximum 480Y/277 Vac Maximum, 125/250 Vdc Maximum 2 Continuous Ampere Rating at 40 °C Single-Pole Two-Pole Three-Pole Catalog Number Catalog Number Catalog Number 2 15 GHC1015 34 GHC2015 3 GHC3015 3 20 GHC1020 34 GHC2020 3 GHC3020 3 2 25 GHC1025 GHC2025 GHC3025 30 GHC1030 GHC2030 GHC3030 2 35 GHC1035 GHC2035 GHC3035 2 40 GHC1040 GHC2040 GHC3040 45 GHC1045 GHC2045 GHC3045 2 50 GHC1050 GHC2050 GHC3050 60 GHC1060 GHC2060 GHC3060 2 70 GHC1070 GHC2070 GHC3070 80 GHC1080 GHC2080 GHC3080 90 GHC1090 GHC2090 GHC3090 100 GHC1100 GHC2100 GHC3100 2 2 2 2 2 Type HGHC Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 277 Vac Maximum, 125 Vdc Maximum 2 Continuous Ampere Rating at 40 °C Single-Pole 2 15 HGHC1015 5 2 20 HGHC1020 5 25 HGHC1025 2 30 HGHC1030 2 2 2 Catalog Number Notes 1 15 through 70 ampere circuit breakers only. 2 Use two outside poles. 3 Uses 0.190–32 screw type clamp terminals. 4 Add suffix HID for High Intensity Discharge (HID) applications. 15 and 20 ampere, single-pole are SWD rated. 5 15 and 20 ampere, single-pole are SWD rated. 2 2 2 2 2 2 2 2 V4-T2-132 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Contents Single-Phase (requires two-pole spaces) Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference. . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 Type GHCGFEP Cable-In/Cable-Out 30 mA Industrial Ground Fault Circuit Protectors (15–100 Amperes) 2 Product Description 2 ● ● Standards and Certifications 15–60 amperes, 277 V, 50/60 Hz Operational voltage 240–305 V These circuit breakers meet the requirements of UL 489 and UL 1053. 2 2 2 Product Selection 2 Type GHCGFEP 30 mA Industrial Ground Fault Circuit Protectors with Non-Interchangeable Trip Units 2 2 Single-Phase (Requires Two Poles) 277V, 30 mA Continuous Ampere Rating at 40 °C Catalog Number 2 15 GHCGFEP1015 20 GHCGFEP1020 2 30 GHCGFEP1030 40 GHCGFEP1040 50 GHCGFEP1050 60 GHCGFEP1060 2 2 2 Technical Data and Specifications 2 Interrupting Capacity Ratings 2 Circuit Breaker Type Number of Poles GHCGFEP 1 Interrupting Capacity (Symmetrical Amperes) 2 277 Vac (50/60 Hz) 2 14,000 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-133 2.3 2 Molded Case Circuit Breakers Series C Contents Special Purpose Circuit Breakers Description 2 2 2 2 2 2 2 2 2 2 Special Purpose GHC Circuit Breakers (15–100 Amperes) 2 Product Description 2 2 2 Page Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes). . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes). . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Eaton’s Type GHC circuit breakers have binding head screw-type terminals on line and load side. These circuit breakers with screw-type terminals (0.190–32) will be marked “Special purpose breaker not for general use.” To order this special breaker, use the catalog number from the tables on this page. Product Selection Type GHC Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 277 Vac Maximum, 125 Vdc Maximum 480Y/277 Vac Maximum, 125/250 Vdc Maximum 480Y/277 Vac Maximum, 125/250 Vdc Maximum 1 Continuous Ampere Rating at 40 °C Single-Pole Two-Pole Three-Pole Catalog Number Catalog Number Catalog Number 25 GHC1025D GHC2025D GHC3025D 30 GHC1030D GHC2030D GHC3030D 35 GHC1035D GHC2035D GHC3035D 40 GHC1040D GHC2040D GHC3040D 2 45 GHC1045D GHC2045D GHC3045D 50 GHC1050D GHC2050D GHC3050D 2 60 GHC1060D GHC2060D GHC3060D 70 GHC1070D GHC2070D GHC3070D 2 80 GHC1080D GHC2080D GHC3080D 2 90 GHC1090D GHC2090D GHC3090D 100 GHC1100D GHC2100D GHC3100D 2 2 2 2 V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 Type GHB and GHC Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units for HID Lighting Applications 2 277 Vac Maximum 2 2 Type Cable-in 2 Bolt-on 2 2 Continuous Ampere Rating at 40 °C Single-Pole 15 GHC1015HID 20 GHC1020HID 15 GHB1015HID 20 GHB1020HID Note 1 Use two outside poles. 2 V4-T2-134 Catalog Number Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C Typical F-Frame Breaker F-Frame Breaker with Electronic Trip Unit 2.3 Contents Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-136 V4-T2-138 V4-T2-149 V4-T2-150 V4-T2-152 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 F-Frame (10–225 Amperes) 2 Product Description 2 ● ● ● All Eaton’s F-Frame circuit breakers are HACR rated All circuit breakers 10 through 30 amperes are suitable for HID (high intensity discharge) use All F-Frame circuit breakers are suitable for reverse feed use 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-135 2.3 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. 2 FD-Frame Circuit Breakers with Thermal-Magnetic Trip Unit Technology 2 FDC 3 100 L 2 Circuit Breaker Type EHD FDB FD HFD FDC 2 2 2 2 2 2 2 2 Number of Poles 1 = 1 pole 2 = 2 poles 3 = 3 poles 4 = 4 poles Trip Amperes 010 015 020 025 030 035 040 045 050 060 070 080 090 100 110 125 150 175 (FD, HFD, FDC, two-, three-, four-pole only) 200 (FD, HFD, FDC, two-, three-, four-pole only) 225 (FD, HFD, FDC, two-, three-, four-pole only) 2 Suffix E = 100% protected (four-pole only) neutral pole EH = 50% protected (four-pole only) K = High magnetic molded case switch L = Line and load terminals S = Stainless steel terminals V = 50 °C calibration W = Without terminals Y = Line terminals only Z = Aluminum terminals (≤100 amperes) EDC 3 200 L 2 2 Circuit Breaker Type EDB EDS ED EDH EDC 2 2 2 Number of Poles 2 = 2 poles 3 = 3 poles Trip Amperes 100 125 150 175 200 225 2 2 2 2 2 2 2 2 2 2 2 V4-T2-136 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Suffix L = Line and load terminals W = Without terminals Y = Line terminals only Z = Aluminum terminals (100 amperes) Molded Case Circuit Breakers Series C 2.3 This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. 2 FD-Frame Circuit Breakers with 210+ Electronic Trip Unit Technology 2 2 HFDE 3 225 22 L Performance at 480 Vac FDE = 35 kAIC HFDE = 65 kAIC FDCE = 100 kAIC Number of Poles 3 = 3 poles Trip Units 100 150 225 Trip Unit 21 = 210+ LI 22 = 210+ LSI 2 Features W = Without terminals L = Line and load terminals Blank = Load side terminals only 2 2 2 2 FD-Frame Circuit Breakers with 310+ Electronic Trip Unit Technology HFDE 3 225 32 ZG W Performance at 480 Vac FDE = 35 kAIC HFDE = 65 kAIC FDCE = 100 kAIC Number of Poles 3 = 3 poles Trip Units 080 160 225 Trip Unit 32 = 310+ LSI 33 = 310+ LS 35 = 310+ LSG 36 = 310+ LSIG Trip Unit Features ZG = Zone selective interlocking Blank = No option 2 2 Features W = Without terminals L = Line and load terminals Blank = Load side terminals only 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-137 2.3 2 2 2 Molded Case Circuit Breakers Series C Product Selection Type ED Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units Suitable for Reverse Feed 240 Vac Maximum, 125 Vdc (Includes Terminals on Load End Only) 2 65 kAIC at 240 Vac Two-Pole Three-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number 15 ED2015 ED3015 2 20 ED2020 ED3020 25 ED2025 ED3025 2 30 ED2030 ED3030 35 ED2035 ED3035 2 40 ED2040 ED3040 2 50 ED2050 ED3050 60 ED2060 ED3060 2 100 ED2100 ED3100 125 ED2125 ED3125 2 150 ED2150 ED3150 175 ED2175 ED3175 2 200 ED2200 ED3200 225 ED2225 ED3225 2 2 2 2 2 Type EDH Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units Suitable for Reverse Feed 240 Vac Maximum, 125 Vdc (Includes Terminals on Load End Only) 2 100 kAIC at 240 Vac Two-Pole Three-Pole 2 Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number 2 15 — — 2 20 — — 25 — — 2 30 — — 35 — — 2 40 — — 50 — — 2 60 — — 2 100 EDH2100 EDH3100 125 EDH2125 EDH3125 2 150 EDH2150 EDH3150 175 EDH2175 EDH3175 2 200 EDH2200 EDH3200 225 EDH2225 EDH3225 2 2 2 2 V4-T2-138 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Type EDC Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units Suitable for Reverse Feed 2 240 Vac Maximum, 125 Vdc (Includes Terminals on Load End Only) 2 200 kAIC at 240 Vac Two-Pole Three-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number 15 — — 20 — — 25 — — 30 — — 35 — — 40 — — 50 — — 60 — — 100 EDC2100 EDC3100 125 EDC2125 EDC3125 150 EDC2150 EDC3150 175 EDC2175 EDC3175 200 EDC2200 EDC3200 225 EDC2225 EDC3225 2 2 2 2 2 2 2 2 2 2 2 Type EDB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units Suitable for Reverse Feed 2 240 Vac Maximum, 125 Vdc (Includes Terminals on Load End Only) 2 22 kAIC at 240 Vac Two-Pole Three-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number 100 EDB2100 EDB3100 110 EDB2110 EDB3110 125 EDB2125 EDB3125 150 EDB2150 EDB3150 175 EDB2175 EDB3175 200 EDB2200 EDB3200 225 EDB2225 EDB3225 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-139 2.3 2 Molded Case Circuit Breakers Series C Type EDS Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units Suitable for Reverse Feed 2 240 Vac Maximum, 125 Vdc (Includes Terminals on Load End Only) 2 42 kAIC at 240 Vac Two-Pole Three-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number 100 EDS2100 EDS3100 110 EDS2110 EDS3110 2 125 EDS2125 EDS3125 150 EDS2150 EDS3150 2 175 EDS2175 EDS3175 2 200 EDS2200 EDS3200 225 EDS2225 EDS3225 2 2 2 2 Type EHD Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units (Includes Terminals on Load End Only) 277 Vac Maximum, 125 Vdc 2 480 Vac Maximum, 250 Vdc 14 kAIC at 277 Vac 14 kAIC at 480 Vac Single-Pole Two-Pole Three-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number Catalog Number 2 10 1 EHD1010 EHD2010 EHD3010 2 15 EHD1015 2 EHD2015 EHD3015 20 EHD1020 2 EHD2020 EHD3020 2 25 EHD1025 EHD2025 EHD3025 30 EHD1030 EHD2030 EHD3030 2 35 EHD1035 EHD2035 EHD3035 2 40 EHD1040 EHD2040 EHD3040 45 EHD1045 EHD2045 EHD3045 2 50 EHD1050 EHD2050 EHD3050 60 EHD1060 EHD2060 EHD3060 2 70 EHD1070 EHD2070 EHD3070 80 EHD1080 EHD2080 EHD3080 90 EHD1090 EHD2090 EHD3090 100 EHD1100 EHD2100 EHD3100 2 2 2 2 Notes 1 Not UL listed. 5 kAIC interrupting rating. 2 UL listed for SWD applications, see NEC Article 240.83(d). 2 2 2 2 2 2 2 2 V4-T2-140 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Type FDB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units (Includes Terminals on Load End Only) 2 600 Vac Maximum, 250 Vdc 2 14 kAIC at 600 Vac Two-Pole Three-Pole Four-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number Catalog Number 10 1 FDB2010 FDB3010 FDB4010 15 FDB2015 FDB3015 FDB4015 20 FDB2020 FDB3020 FDB4020 25 FDB2025 FDB3025 FDB4025 30 FDB2030 FDB3030 FDB4030 35 FDB2035 FDB3035 FDB4035 40 FDB2040 FDB3040 FDB4040 45 FDB2045 FDB3045 FDB4045 50 FDB2050 FDB3050 FDB4050 60 FDB2060 FDB3060 FDB4060 70 FDB2070 FDB3070 FDB4070 80 FDB2080 FDB3080 FDB4080 90 FDB2090 FDB3090 FDB4090 100 FDB2100 FDB3100 FDB4100 110 FDB2110 FDB3110 FDB4110 125 FDB2125 FDB3125 FDB4125 150 FDB2150 FDB3150 FDB4150 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Not UL listed. 5 kAIC interrupting rating. 2 UL listed for SWD applications, see NEC Article 240.83(d). 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-141 2.3 2 Molded Case Circuit Breakers Series C Type FD Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units (Includes Terminals on Load End Only) 2 277 Vac Maximum, 125 Vdc 600 Vac Maximum, 250 Vdc 35 kAIC at 277 Vac 35 kAIC at 480 Vac Single-Pole Two-Pole Three-Pole Four-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number Catalog Number Catalog Number 10 1 FD1010 — — — 15 FD1015 2 FD2015 FD3015 FD4015 20 FD1020 2 FD2020 FD3020 FD4020 2 25 FD1025 FD2025 FD3025 FD4025 2 30 FD1030 FD2030 FD3030 FD4030 35 FD1035 FD2035 FD3035 FD4035 2 40 FD1040 FD2040 FD3040 FD4040 45 FD1045 FD2045 FD3045 FD4045 2 50 FD1050 FD2050 FD3050 FD4050 60 FD1060 FD2060 FD3060 FD4060 2 70 FD1070 FD2070 FD3070 FD4070 2 80 FD1080 FD2080 FD3080 FD4080 90 FD1090 FD2090 FD3090 FD4090 2 100 FD1100 FD2100 FD3100 FD4100 110 FD1110 FD2110 FD3110 FD4110 2 125 FD1125 FD2125 FD3125 FD4125 2 150 FD1150 FD2150 FD3150 FD4150 175 — FD2175 FD3175 FD4175 2 200 — FD2200 FD3200 FD4200 225 — FD2225 FD3225 FD4225 2 Notes 1 Not UL listed. 5 kAIC interrupting rating. 2 UL listed for SWD applications, see NEC Article 240.83(d). 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-142 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Type HFD Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units (Includes Terminals on Load End Only) 277 Vac Maximum, 125 Vdc 600 Vac Maximum, 250 Vdc 65 kAIC at 277 Vac 65 kAIC at 480 Vac Single-Pole Two-Pole Three-Pole Four-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number Catalog Number Catalog Number 15 HFD1015 1 HFD2015 HFD3015 HFD4015 20 HFD1020 1 HFD2020 HFD3020 HFD4020 25 HFD1025 HFD2025 HFD3025 HFD4025 30 HFD1030 HFD2030 HFD3030 HFD4030 35 HFD1035 HFD2035 HFD3035 HFD4035 40 HFD1040 HFD2040 HFD3040 HFD4040 45 HFD1045 HFD2045 HFD3045 HFD4045 50 HFD1050 HFD2050 HFD3050 HFD4050 60 HFD1060 HFD2060 HFD3060 HFD4060 70 HFD1070 HFD2070 HFD3070 HFD4070 80 HFD1080 HFD2080 HFD3080 HFD4080 90 HFD1090 HFD2090 HFD3090 HFD4090 100 HFD1100 HFD2100 HFD3100 HFD4100 110 HFD1110 HFD2110 HFD3110 HFD4110 125 HFD1125 HFD2125 HFD3125 HFD4125 150 HFD1150 HFD2150 HFD3150 HFD4150 175 — HFD2175 HFD3175 HFD4175 200 — HFD2200 HFD3200 HFD4200 225 — HFD2225 HFD3225 HFD4225 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Note 1 UL listed for SWD applications, see NEC Article 240.83(d). 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-143 2.3 2 Molded Case Circuit Breakers Series C Type FDC Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units (Includes Terminals on Load End Only) 2 600 Vac Maximum, 250 Vdc 100 kAIC at 480 Vac Two-Pole Three-Pole Four-Pole Maximum Continuous Ampere Rating at 40 °C Catalog Number Catalog Number Catalog Number 15 FDC2015 FDC3015 FDC4015 20 FDC2020 FDC3020 FDC4020 25 FDC2025 FDC3025 FDC4025 2 30 FDC2030 FDC3030 FDC4030 2 35 FDC2035 FDC3035 FDC4035 40 FDC2040 FDC3040 FDC4040 2 45 FDC2045 FDC3045 FDC4045 50 FDC2050 FDC3050 FDC4050 2 60 FDC2060 FDC3060 FDC4060 70 FDC2070 FDC3070 FDC4070 2 80 FDC2080 FDC3080 FDC4080 2 90 FDC2090 FDC3090 FDC4090 100 FDC2100 FDC3100 FDC4100 2 110 FDC2110 FDC3110 FDC4110 125 FDC2125 FDC3125 FDC4125 2 150 FDC215 FDC3150 FDC4150 2 175 FDC2175 FDC3175 FDC4175 200 FDC2200 FDC3200 FDC4200 225 FDC2225 FDC3225 FDC4225 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-144 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Types FDE, HFDE and FDCE 310+ Electronic Circuit Breakers with Non-Interchangeable Trip Units See 310+ adjustability specifications on Page V4-T2-151. 2 2 Digitrip RMS 310+ Trip Unit Only Maximum Ampere Rating Standard LS Optional LSI LSG LSIG Adjustable Short Time Pickup with I2t Short Delay Ramp Independently Adjustable Short Time Pickup and Delay Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Ground Fault Protection Catalog Number 2 Neutral CT for LSG and LSIG 2 Catalog Number 2 35 kAIC at 480 Vac / 18 kAIC at 600 Vac 2 80 FDE308033 FDE308032 FDE308035 FDE308036 CTF080 160 FDE316033 FDE316032 FDE316035 FDE316036 CTF160 225 FDE322533 FDE322532 FDE322535 FDE322536 CTF225 2 2 65 kAIC at 480 Vac / 25 kAIC at 600 Vac 80 HFDE308033 HFDE308032 HFDE308035 HFDE308036 CTF080 160 HFDE316033 HFDE316032 HFDE316035 HFDE316036 CTF160 225 HFDE322533 HFDE322532 HFDE322535 HFDE322536 CTF225 2 2 100 kAIC at 480 Vac / 25 kAIC at 600 Vac 80 FDCE308033 FDCE308032 FDCE308035 FDCE308036 CTF080 160 FDCE316033 FDCE316032 FDCE316035 FDCE316036 CTF160 225 FDCE322533 FDCE322532 FDCE322535 FDCE322536 CTF225 Types FDE, HFDE, and FDCE 210+ Electronic Circuit Breakers with Non-Interchangeable Trip Units Digitrip RMS 210+ Trip Unit Only Maximum Ampere Rating 100 2 FDE 310+ Electronic Breaker with Zone Selective Interlocking Ampere Rating LSI w/ZSI LSIG w/ZSI Catalog Number Catalog Number Standard Optional LI Adjustable Instantaneous LSI Adjustable Short Time Pickup and Delay 35 kAIC at 480 Vac / 18 kAIC at 600 Vac 80 FDE308032ZG FDE308036ZG Catalog Number Catalog Number 160 FDE316032ZG FDE316036ZG 225 FDE322532ZG FDE322536ZG 35 kAIC at 480 Vac / 18 kAIC at 600 Vac 2 2 2 2 2 2 65 kAIC at 480 Vac / 25 kAIC at 600 Vac FDE310021 FDE310022 150 FDE315021 1 225 FDE322521 FDE322522 65 kAIC at 480 Vac / 25 kAIC at 600 Vac 80 HFDE308032ZG HFDE308036ZG 160 HFDE316032ZG HFDE316036ZG 225 HFDE322532ZG HFDE322536ZG 2 2 100 kAIC at 480 Vac / 25 kAIC at 600 Vac 100 HFDE310021 HFDE310022 150 HFDE315021 1 225 HFDE322521 HFDE322522 80 FDCE308032ZG FDCE308036ZG 160 FDCE316032ZG FDCE316036ZG 225 FDCE322532ZG FDCE322536ZG 2 2 100 kAIC at 480 Vac / 25 kAIC at 600 Vac 2 Digitrip 310+ Electronic Trip Units Amperage Settings 2 Circuit Breaker Type Frame Ratings 2 210+ Trip Electronic Trip Units Amperage Settings FDE, HFDE, FDCE 225 100, 110, 125, 150, 160, 175, 200, 225 Circuit Breaker Type FDE, HFDE, FDCE 160 60, 70, 80, 90, 100, 125, 150, 160 FDE, HFDE, FDCE 80 15, 20, 30, 40, 50, 60, 70, 80 Frame Ratings FDE, HFDE, FDCE 225 100, 110, 125, 150, 175, 200, 225 FDE, HFDE, FDCE 150 70, 80, 90, 100, 110, 125, 150 FDE, HFDE, FDCE 100 40, 50, 60, 70, 80, 90, 100 100 FDCE310021 FDCE310022 150 FDCE315021 1 225 FDCE322521 FDCE322522 2 2 Notes 1 For 210+ trip unit, 150 A not available with LSI trip unit; entire range is covered by 100 A and 225 A frames. 2 Contact the product line for availability. 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-145 2.3 2 2 2 2 2 2 Series C Molded Case Switches Eaton’s molded case switches are used as compact switches in applications requiring high current switching capabilities. Molded case switches are constructed of circuit breaker components and are of the high instantaneous automatic type. Molded case switches are listed in accordance with Underwriters Laboratories Standard UL 489. Molded Case Switches 2 2 Molded Case Circuit Breakers Complete Circuit Breaker with Load Side Terminals Only Maximum Continuous Ampere Rating at 40 °C 480 Vac Maximum, 250 Vdc 600 Vac Maximum, 250 Vdc Catalog Number Catalog Number Catalog Number Two-Pole 2 100 EHD2100K FD2100K HFD2100K 2 150 — FD2150K HFD2150K 225 — FD2225K HFD2225K 2 Three-Pole 100 EHD3100K FD3100K HFD3100K 2 150 — FD3150K HFD3150K 225 — FD3225K HFD3225K HFD4100K 2 Four-Pole 2 100 — FD4100K 150 — FD4150K HFD4150K 225 — FD4225K HFD4225K 2 2 Note Molded case switches will open above 1800 amperes. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-146 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Accessories Selection Guide and Ordering Information 2 Line and Load Terminals Line and load terminals provide wire connecting capabilities for specific ranges of continuous current ratings and wire types. Except as noted, terminals comply with Underwriters Laboratories Standards UL 486A and UL 486B. Unless otherwise specified, F-Frame circuit breakers are factory equipped with load terminals only. 2 Ordering Information F-Frame circuit breakers and molded case switches have load terminals only as standard equipment. When standard line-end terminals (same as standard load-end terminals) are required, add Suffix L to the circuit breaker catalog number. When nonstandard or optional line and/ or load terminals are required, order by style number. Specify if factory installation is required. 2 2 2 2 2 2 2 Line and Load Terminals Maximum Breaker Amperes Package of Three Terminals 2 Wire Type AWG Wire Range Metric Wire Range mm2 Catalog Number 2 Steel Cu/AI 14–10 2.5–4 3T20FB 2 2 100 Steel Cu/AI 14–1/0 2.5–50 3T100FB 225 Aluminum Cu/AI 4–4/0 25–95 3TA225FD Cu/AI 14–4 2.5–25 3TA50FB 2 Terminal Body Material Standard Pressure Type Terminals 20 (EHD) 2 2 Optional Pressure Terminals 50 Aluminum 100 Aluminum Cu/AI 14–1/0 2.5–50 3TA100FD 200 Stainless steel Cu 4–4/0 25–95 3T150FB 225 Copper Cu 4–4/0 25–95 3T225FD 225 Aluminum Cu/AI 6–300 kcmil 16–150 3TA225FDK 3 2 2 2 Notes 1 Use on FDE, HFDE and FDCE electronic trip only. 2 Not for use with ED, EDH, EDC breakers. 3 Includes terminal shield kit. Adds approximately 3 inches (76.2) to breaker height. Available for use on three-pole breaker only. 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-147 2.3 2 Molded Case Circuit Breakers Series C Line and Load Terminals 2 Collar 2 Collar Nut Screw 2 2 2 2 Clip Conductor Washer Conductor Conductor Screw Wire Clamp Extrusion 3T20FB 3T100FB, 3T150FB 3TA225FD Assemble wire clamp to bottom of conductor as shown. Insert collar enclosing conductor as shown. Locate nut on top of conductor and tighten securely with screw and washer. Caution: Collar must surround conductor. Insert collar enclosing conductor and center on extrusion on collar. Install clip with legs on top of conductor and snap end around bottom of collar. 2 2 2 Collar 2 Conductor Collar 2 2 2 2 Washer Conductor Screw Washer Screw 3TA50FB 3TA100FD 3TA225FDK (Up to 150 mm2) Assemble collar on top of conductor as shown. Tighten securely with screw and washer. Collar slides onto conductor and is held in position by a screw and lockwasher. Assemble collar on top of conductor as shown. Tighten securely with screw and washer. Terminal shield must be used with this collar. Note: For 185 mm2, use 3TA225FDK1. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-148 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Accessories 2 Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 Allowable Accessory Combinations 2 FD Frame Accessories Description Reference Page Single-Pole Two-Pole Three-Pole Center Left Left Right 1 Center Four-Pole Right Left Center Right Neutral 2 Internal Accessories (Only one internal accessory per pole) ■ Alarm lockout switch (make only) V4-T2-275 Alarm lockout (Make/Break) V4-T2-275 ■ ❏ ❏ ■ Alarm lockout (2Make/2Break) V4-T2-275 ■ ❏ ❏ ■ Auxiliary switch (1A, 1B) V4-T2-277 ■ ■ ■ ■ ■ Auxiliary switch (2A, 2B) V4-T2-277 ■ ■ ■ ■ ■ Auxiliary switch and alarm switch combination V4-T2-279 ■ ❏ ❏ ■ Shunt trip—standard V4-T2-281 ■ ■ ■ ■ Shunt trip—low energy V4-T2-285 ■ ■ ■ ■ Undervoltage release mechanism V4-T2-287 ■ ■ ■ ■ ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● 2 ■ V4-T2-308 Keeper nut V4-T2-308 ● 2 2 2 2 External Accessories End cap kit 2 2 Control wire terminal kit V4-T2-309 ● ● ● ● ● ● ● ● ● Multiwire connectors V4-T2-310 ● ● ● ● ● ● ● ● ● ● Rear fed terminals V4-T2-310 ● ● ● ● ● ● ● ● ● ● Base mounting hardware V4-T2-310 ● ● ● ● ● ● ● ● ● ● Terminal shields V4-T2-312 ● ● ● ● ● ● ● ● ● ● Terminal end covers V4-T2-313 ● ● ● 2 ● ● ● ● ● ● 2 ● ● Interphase barriers V4-T2-313 Non-padlockable handle block V4-T2-314 ■ ■ Snap-on padlockable handle lock hasp V4-T2-314 ■ ■ Padlockable handle lock hasp V4-T2-315 Cylinder lock V4-T2-315 Key interlock kit V4-T2-316 Sliding bar interlock—requires two breakers V4-T2-317 ● ● ● Walking beam interlock—requires two breakers V4-T2-317 ● ● ● Electrical (solenoid and motor) operators V4-T2-318 Plug-in adapters V4-T2-319 ● ■ ■ ■ ■ ❏ ■ ❏ ❏ ❏ ❏ ❏ ❏ 2 ■ ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Rear connecting studs V4-T2-321 ● ● ● ● ● ● ● ● ● ● Panelboard connecting straps V4-T2-322 ● ● ● ● ● ● ● ● ● ● Handle mechanisms V4-T2-430 ● ● ● LFD current limiter V4-T2-324 ● ● ● ● ● ● ● ● 2 2 ■ ❏ 2 2 2 2 2 2 IQ Energy Sentinel V4-T2-324 Cause of trip display V4-T2-325 ● ● Remote mount cause of trip display V4-T2-325 ● ● Cause of trip LED V4-T2-325 ● ● 2 2 Modifications (Refer to Eaton) Special calibration — ● ● ● ● ● ● ● ● ● ● Moisture fungus treatment V4-T2-116 ● ● ● ● ● ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● ● ● ● ● ● Marine/naval application — ● ● ● ● ● ● ● ● ● ● Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available 2 2 2 2 2 Note Internal accessories are listed with Underwriters Laboratories (UL) for factory installation. They are not listed with UL for field installation. 1 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2 V4-T2-149 2.3 Molded Case Circuit Breakers Series C 2 Technical Data and Specifications 2 UL 489 Interrupting Capacity Ratings Interrupting Capacity (kA Symmetrical Amperes) 2 Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 277 480 600 125 250 23 2 EDB 2, 3 22 — — — 10 — EDS 2, 3 42 — — — 10 — 2 ED 2, 3 65 — — — 10 — EDH 2, 3 100 — — — 10 — 2 EDC 2, 3 200 — — — 10 — 2 EHD Volts DC 1 1 — 4 — — 10 — 2, 3 18 — 14 — — 10 FDB 2, 3, 4 18 — 14 14 — 10 2 FD 1 — 35 — — 10 — 2, 3, 4 65 — 35 18 — 10 2 FDE 4 3 65 — 35 18 — — HFD 1 — 65 — — 10 — 2 2 2 2 2 2 2 2, 3, 4 100 — 65 25 — 22 HFDE 4 3 100 — 65 25 — — FDC 5 2, 3, 4 200 — 100 35 — 22 FDCE 456 3 200 — 100 25 — — IEC 157-1 (P1) Interrupting Capacity Ratings (P1) Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Volts DC 1 Volts AC (50/60 Hz) Number of Poles 220, 240 380, 415 440 500 125 250 23 EDB 2, 3 22 — — — 10 — EDS 2, 3 42 — — — 10 — ED 2, 3 65 — — — 10 — EDH 2, 3 100 — — — 10 — EDC 2, 3 200 — — — 10 — 2 EHD 2 FDB 2, 3, 4 18 14 14 14 — 10 FD 1 35 — — — 10 — 1 — 14 — — 10 — 2, 3 18 — 14 — — 10 2 2, 3, 4 65 35 35 18 — 10 HFD 1 65 — — — 10 — 2 2, 3, 4 100 65 65 25 — 22 FDC 2, 3, 4 200 100 100 35 — 22 2 210+ and 310+ Electronic Trip Unit Accessories 2 Description 210+ 310+ Catalog number Electronic portable test kit ■ ■ MTST230V Trip unit tamper protection wire seal ■ ■ 5108A03H01 2 External neutral sensor (80 A) 7 ■ CTF080 2 External neutral sensor (160 A) 7 ■ CTF160 External neutral sensor (225 A) 7 ■ CTF225 2 2 Compact external neutral sensor (80 ■ CTFD080 Compact external neutral sensor (160 A) 7 ■ CTFD160 2 Compact external neutral sensor (225 A) 7 ■ CTFD225 Breaker-mount cause-of-trip indication ■ TRIP-LED Breaker-mount ammeter module ■ DIGIVIEW Remote-mount ammeter module ■ DIGIVIEWR06 2 2 A) 7 Notes 1 DC ratings apply to substantially non-inductive circuits. 2 Two-pole circuit breaker, or two poles of three-pole circuit breaker. 3 Time constant is 3 milliseconds minimum at 10 kA and 8 milliseconds minimum at 22 kA. 4 Electronics available on three-pole only, no DC rating for FDE, HFDE, FDCE. 5 Current limiting. 6 Check with Eaton for availability. 7 Neutral sensor required for four-wire systems if neutral protection is desired; sold separately. 2 V4-T2-150 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C FDE 210+ and 310+ Specifications Description FDE 310+ Adjustability Specifications Digitrip RMS 210+ Digitrip RMS 310+ Frame designation FD FD Frames available 100 A, 150 A, 225 A 80 A, 160 A, 225 A Continuous current range (A) 40–225 A 15–225 A Ground fault pickup (A) N/A 16–225 A Interrupting capacities at 480 Vac (kAIC) 35, 65, 100 35, 65, 100 Breaker type 310+ Settings 80 A 160 A 225 A Ir = continuous current or long delay pickup (amperes) Ir (All 310+) A 15 60 100 B 20 70 110 C 30 80 125 Protection Ordering options LI, LSI LS, LSI, LSG, LSIG Arcflash Reduction Maintenance System™ (or Maintenance Mode) No No Interchangeable trip unit No No High load alarm (suffix B20) No No No No Ground fault alarm, no trip (suffix B22) No No Zone selective interlocking (suffix ZG) No LSI, LSIG Cause of trip indication No Yes Thru-cover accessories No No Test kit available Yes 100 A Ir = continuous current or long delay pickup (amperes) (all 210+) Ii (x In)= Instantaneous pickup (210+ LI version) “Isd (x Ir) / tsd = SD profile (210+ LSI version) 225 A A 40 70 100 B 50 80 110 C 60 90 125 D 70 100 150 E 80 110 175 F 90 125 200 G (= In) 100 150 225 Ii 100 150 225 J–2x 200 300 450 K–2.5x 250 375 565 L–3x 300 450 675 M–3.5x 350 525 790 N–4x 400 600 900 O–5x 500 750 1125 P–6x 600 900 1350 Q–8x 800 1200 1800 R–10x 1000 1500 2250 S–12x 1 1200 1800 2400 2400 2400 2400 150 100 160 F 60 125 175 G 70 150 200 160 225 2 2 2 Position 2 4 4 4 Position 3 7 7 7 Position 4 10 10 10 Position 5 12 12 12 Position 6 15 15 15 Position 7 20 20 20 Position 8 24 24 24 Position 1 2x 2x 2x Position 2 3x 3x 3x Position 3 4x 4x 4x Position 4 5x 5x 5x Position 5 6x 6x 6x Position 6 7x 7x 7x Position 7 8x 8x 8x Position 8 10x 10x 10x Position 9 12x 12x 12x tsd (LS, LSG) Fixed 67 at10x 67 at10x 67 at10x tsd = short delay time flat (milliseconds) (LSI, LSIG) Position 1 Inst Inst Inst Position 2 120 120 120 Position 3 300 300 300 Position 1 16 32 45 Position 2 24 48 67 Position 3 32 64 90 Position 4 48 96 135 Position 5 64 128 180 Isd (x Ir) = short delay pickup (All 310+) Ir Fixed instantaneous override (all 210+) 2 150 A 90 50 80 Yes FD Frame 40 E H (= In) FDE 210+ Adjustability Specifications 210+ settings D Position 1 tr = long delay time (seconds) (All 310+) Ground fault alarm with trip (suffix B21) = short delay time I2t (milliseconds) Ig = gound fault pickup (amperes) (LSG, LSIG) tg = ground fault delay time (milliseconds) (LSG, LSIG) Position 6 80 160 225 Position 1 Inst Inst Inst Position 2 120 120 120 Position 3 300 300 300 Isd / tsd 100 150 225 J 2x / 150 N/A 2x / 150 K 2x / 300 N/A 2x / 300 L 2x / I2t N/A 2x / I2t Independently Adjustable Instantaneous (Ii) setting 1 M 4x / Inst N/A 4x / Inst Maintenance Mode pickup (2.5 x In) (amperes) 2 N 4x / 150 N/A 4x / 150 O 4x / I2t N/A 4x / I2t P 6x / Inst N/A 6x / Inst Q 6x / 300 N/A 6x / 300 R 10x / 150 N/A 10x / 150 S 10x / 300 N/A 10x / 300 2 FD Frame 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Not available for FD. Independently adjustable I setting available in LG, NG and i RG ALSI and ALSIG trip units. 2 Maintenance Mode not available for FD frames. It is available for KD, LD, MDL, LG, NG and RG. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-151 2.3 2 2 Molded Case Circuit Breakers Series C Dimensions and Weights Approximate Dimensions in Inches (mm) FD Frame 2 Number of Poles Width Height Depth 2 1 1.38 (35.1) 6.00 (152.4) 3.38 (86.0) 2 2.75 (70.0) 6.00 (152.4) 3.38 (86.0) 3 4.13 (105.0) 6.00 (152.4) 3.38 (86.0) 4 5.50 (139.7) 6.00 (152.4) 3.38 (86.0) 2 2 2 FD Frame, Three-Pole Side View Front View 2 2 2 On Off 2 2 6.00 (152.4) 2 2 2 2 3.38 (85.7) 4.13 (104.9) 2 2 Approximate Shipping Weight Lbs (kg) 2 FD Frame 2 Breaker Type 1 2 3 4 2 ED, EDB, EDS, EDH, EDC — 3 (1.4) 4.5 (2.0) — 2 EHD, FDB, FD, HFD, FDC 2 (0.9) 3 (1.4) 4.5 (2.0) 6 (2.7) FDE, HFDE, FDCE — — 4.5 (2.0) — Number of Poles 2 2 2 2 2 2 2 2 V4-T2-152 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C Typical J-Frame Breaker 2.3 Contents Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-154 V4-T2-155 V4-T2-158 V4-T2-159 V4-T2-160 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 J-Frame (70–250 Amperes) 2 Product Description 2 ● ● ● All Eaton’s J-Frame circuit breakers are HACR rated J-Frame circuit breakers are available as individual components (frame, trip unit, terminals), or factory assembled complete breakers J-Frame circuit breakers with non-interchangeable trip units are suitable for reverse feed use 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-153 2.3 2 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. Circuit Breaker/Frame 2 JD 3 250 F 2 Circuit Breaker/ Frame Type JDB JD HJD JDC 2 2 Number of Poles 2 = 2 poles 3 = 3 poles 4 = 4 poles 2 2 Circuit Breaker/Frame Ampere Rating 070 090 100 125 150 175 200 225 250 Suffix C = Non-aluminum terminals F = Frame only K = High magnetic molded case switch V = 50 °C calibration W = Without terminals X = Load side terminals only Y = Line side terminals only 2 2 Trip Unit JT 3 250 T 2 2 Trip Unit Type JT = Thermal-magnetic 2 2 2 2 Number of Poles 2 = 2 poles 3 = 3 poles 4 = 4 poles Trip Unit Rating/ Plug Ampere Rating 070 090 100 125 150 175 200 225 250 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-154 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Suffix T = Trip unit thermal-magnetic fixed thermal adj. magnetic V = 50 °C calibration (thermal-magnetic trip units only) Molded Case Circuit Breakers Series C 2.3 Product Selection 2 2 Types JD, HJD and JDC Thermal-Magnetic Circuit Breakers with Interchangeable Trip Units Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals 1 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals 1 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals 1 For Use with Standard or High or Ultra High Interrupting Frames See Page V4-T2-157 for Optional Terminals Catalog Number Catalog Number Catalog Number Catalog Number Catalog Number 70 JD2070 HJD2070 JDC2070 JT2070T TA250KB 2 90 JD2090 HJD2090 JDC2090 JT2090T 100 JD2100 HJD2100 JDC2100 JT2100T 125 JD2125 HJD2125 JDC2125 JT2125T 150 JD2150 HJD2150 JDC2150 JT2150T 175 JD2175 HJD2175 JDC2175 JT2175T 200 JD2200 HJD2200 JDC2200 JT2200T 225 JD2225 HJD2225 JDC2225 JT2225T 250 JD2250 HJD2250 JDC2250 JT2250T 70 JD3070 HJD3070 JDC3070 JT3070T 90 JD3090 HJD3090 JDC3090 JT3090T 100 JD3100 HJD3100 JDC3100 JT3100T 125 JD3125 HJD3125 JDC3125 JT3125T 150 JD3150 HJD3150 JDC3150 JT3150T 175 JD3175 HJD3175 JDC3175 JT3175T 200 JD3200 HJD3200 JDC3200 JT3200T 225 JD3225 HJD3225 JDC3225 JT3225T 250 JD3250 HJD3250 JDC3250 JT3250T 125 JD4125 HJD4125 JDC4125 JT3125T 150 JD4150 HJD4150 JDC4150 JT3150T 175 JD4175 HJD4175 JDC4175 JT3175T 200 JD4200 HJD4200 JDC4200 JT3200T 225 JD4225 HJD4225 JDC4225 JT3225T 250 JD4250 HJD4250 JDC4250 JT3250T Maximum Continuous Ampere Rating at 40 °C Thermal-Magnetic Trip Unit Only 1 Standard Terminals Only 2 2 2 2 Two-Pole 2 2 2 2 2 2 Three-Pole TA250KB 2 2 2 2 2 2 2 Four-Pole 34 TA250KB 2 2 2 2 2 Notes 1 Magnetic trip adjustable 5–10 times continuous ampere rating. 2 Individually packed. 3 Fully rated neutral pole with no protection. 4 Neutral is in right pole. 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-155 2.3 Molded Case Circuit Breakers Series C 2 Types JD, HJD and JDC Thermal-Magnetic Circuit Breakers— Frame Only 2 Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Catalog Number Catalog Number Catalog Number HJD2250F JDC2250F 2 2 JD2250F 2 JD3250F Molded Case Switches Three-Pole HJD3250F 2 2 2 Four-Pole JD4250F HJD4250F JDC4250F Type JDB Thermal-Magnetic Circuit Breakers with NonInterchangeable Thermal-Magnetic Trip Units Suitable for Reverse Feed Application Maximum Continuous Ampere Rating at 40 °C Complete Circuit Breaker Maximum Continuous Ampere Rating at 40 °C Without Line and Load Terminals With Standard Line and Load Terminals Only Catalog Number Catalog Number Two-Pole 2 70 JDB2070W JDB2070 90 JDB2090W JDB2090 250 100 JDB2100W JDB2100 125 JDB2125W JDB2125 2 150 JDB2150W JDB2150 2 175 JDB2175W JDB2175 200 JDB2200W JDB2200 2 225 JDB2225W JDB2225 250 JDB2250W JDB2250 2 Three-Pole 70 JDB3070W JDB3070 2 90 JDB3090W JDB3090 2 100 JDB3100W JDB3100 125 JDB3125W JDB3125 2 150 JDB3150W JDB3150 175 JDB3175W JDB3175 2 200 JDB3200W JDB3200 225 JDB3225W JDB3225 250 JDB3250W JDB3250 Suitable for Reverse Feed Use See PageV4-T2-157 for Optional Terminals Catalog Number Catalog Number Catalog Number JD2250KW JDB2250KW TA250KB 1 HJD2250KW HJDB2250KW — 250 JD3250KW JDB3250KW TA250KB 1 HJD3250KW HJDB3250KW — JD4250KW JDB4250KW TA250KB 1 HJD4250KW HJDB4250KW — Four-Pole Notes 1 Individually packed. Molded case switches may open above 2500 amperes. 2 2 2 2 2 2 V4-T2-156 Standard Terminals Only Three-Pole 250 2 Complete Circuit Breaker Only Without Line and Load Terminals Two-Pole 600 Vac Rated, 250 Vdc 2 2 600 Vac Maximum, 250 Vdc JDC3250F 2 2 components and are of the high instantaneous automatic type. Molded case switches are listed in accordance with Underwriters Laboratories Standard UL 489. Two-Pole 2 2 Molded Case Switches Eaton’s molded case switches are used as compact switches in applications requiring high current switching capabilities. Molded case switches are constructed of circuit breaker Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Accessories Selection Guide and Ordering Information Line and Load Terminals Eaton’s line and load terminals provide wire connecting capabilities for specific ranges of continuous current ratings and wire types. All terminals comply with Underwriters Laboratories Standards UL 486A and UL 486B and CSA Standard C22.2 No. 65, or Electrical Bulletin 1165. Unless otherwise specified, JFrame circuit breaker line and load terminals are shipped separately for field installation. The bottom of the standard TA250KB terminal contains a recess that is positioned over the J-Frame circuit breaker terminal conductor. 2 Ordering Information J-Frame circuit breakers use Cu/AI terminals as standard. When optional copper-only terminals are required, order by catalog number. Specify if factory installation is required. 2 2 2 2 2 2 2 Collar 2 Collar 2 Nut Slotted Screw T250KB Terminal 2 Slotted Screw 2 TA250KB Terminal (Standard) 2 Line and Load Terminals Maximum Breaker Amperes Terminal Body Material 2 Wire Type AWG Wire Range/ No. Conductors Metric Wire Range mm2 Catalog Number Cu/AI 4–350 kcmil 25–185 TA250KB 2 Cu 4–350 kcmil 25–185 T250KB 2 2 Standard Cu/AI Pressure Terminals 250 Aluminum Optional Cu Pressure Terminals 250 Stainless Steel 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-157 2.3 Molded Case Circuit Breakers Series C 2 Accessories 2 Allowable Accessory Combinations Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 2 JD Frame Accessories 2 Description Reference Page Two-, Three-Pole Alarm lockout (Make/Break) V4-T2-275 2 Auxiliary switch (1A, 1B) V4-T2-277 2 Auxiliary switch (2A, 2B) Left ❏ ❏ ❏ ❏ ■ ■ ■ ■ V4-T2-277 ■ ■ ■ ■ Auxiliary switch and alarm switch combination V4-T2-279 ❏ ❏ ❏ ❏ Shunt trip—standard V4-T2-282 ■ ■ ■ ■ Shunt trip—low energy V4-T2-285 ■ ■ ■ ■ 2 Undervoltage release mechanism V4-T2-289 ■ ■ ■ ■ 2 End cap kit V4-T2-308 ● ● ● ● ● ● ● Plug nut V4-T2-309 ● ● ● ● ● ● ● Control wire terminal kit V4-T2-309 ● ● ● ● ● ● ● 2 Multiwire connectors V4-T2-310 ● ● ● ● ● ● ● 2 Base mounting hardware V4-T2-311 ● ● ● ● ● ● ● Terminal shields V4-T2-312 ● ● ● ● ● ● ● Interphase barriers V4-T2-313 ● ● ● ● ● ● ● Non-padlockable handle block V4-T2-314 ■ ■ 2 Padlockable handle block V4-T2-314 ■ ■ 2 Padlockable handle lock hasp V4-T2-315 ❏ ❏ Cylinder lock V4-T2-315 ❏ ❏ Key interlock kit V4-T2-316 ❏ Sliding bar interlock—requires two breakers V4-T2-317 ● ● ● 2 Electrical (solenoid) operator V4-T2-319 ● ● ● ● ● ● ● 2 Plug-in adapters V4-T2-319 ● ● ● ● ● ● ● Rear connecting studs V4-T2-321 ● ● ● ● ● ● ● Panelboard connecting straps V4-T2-322 ● ● ● ● ● ● ● Handle mechanisms V4-T2-430 ● ● ● ● ● ● ● Handle extension V4-T2-445 ● ● ● ● ● ● ● 2 IQ Energy Sentinel V4-T2-324 ● ● ● 2 Special calibration — ● ● ● ● ● ● ● Moisture fungus treatment V4-T2-116 ● ● ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● ● ● Marine/naval application — ● ● ● ● ● ● ● 2 2 2 2 2 2 2 2 2 2 Center Four-Pole Right 2 Left Center Right Neutral Internal Accessories (Only One Internal Accessory Per Pole) External Accessories ❏ ❏ ❏ ❏ ❏ Modifications (Refer to Eaton) Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available 2 2 V4-T2-158 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Technical Data and Specifications 2 UL 489 Interrupting Capacity Ratings 2 Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 480 600 125 250 12 JDB 2, 3 65 35 18 — 10 JD 2, 3, 4 65 35 18 — 10 HJD 2, 3, 4 100 65 25 — 22 JDC 3 2, 3, 4 200 100 35 — 22 2 Volts DC 2 2 2 2 IEC 157-1 (P1) Interrupting Capacity Ratings 2 Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 380 415 600 125 250 12 JD 2, 3, 4 65 35 35 — — 10 Volts DC HJD 2, 3, 4 100 65 65 — — 22 JDC 2, 3, 4 200 100 100 — — 22 2 2 2 Notes 1 Two-pole circuit breaker or two outside poles of three-pole circuit breaker. 2 Time constant is 3 milliseconds minimum at 10 kA and 8 milliseconds minimum at 22 kA. 3 Current limiting. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-159 2.3 2 2 Molded Case Circuit Breakers Series C Dimensions and Weights Approximate Dimensions in Inches (mm) JD Frame Number of Poles Width Height Depth 2, 3 4.13 (105.0) 10.00 (254.0) 4.06 (104.1) 2 4 5.50 (139.7) 10.00 (254.0) 4.06 (104.1) 2 JD-Frame, Three-Pole 2 2 Front View Front View Cutout 2 1.56 (39.7) 0.34 R (8.7 R) 2 2 3.94 (100.0) 2 2 0.72 (18.2) 0.50 (12.7) Diameter 3 Megger Holes if Required 0.19 R (4.8) R Side View 4.13 (104.8) 0.78 (19.8) 2.92 (74.2) CL Breaker 2 2 CL Handle 2 0.88 (22.2) 3.33 (84.5) ON 10.00 (254.0) OFF 2.75 (69.9) 1.38 (34.9) 3.50 (88.9) 1.75 (44.5) 2 4.06 (103.2) 2 2 Approximate Shipping Weight in Lbs (kg) 2 JD Frame 2 Breaker Type Complete Breaker Two-Pole Three-Pole Four-Pole Two-Pole Three-Pole Four-Pole Two-Pole Three-Pole Four-Pole 2 JDB 11.25 (5.1) 12.50 (5.7) — — — — — — — JD 11.25 (5.1) 12.50 (5.7) 13.25 (6.0) 9.00 (4.1) 10.00 (4.5) 10.50 (4.8) 2.00 (0.9) 2.00 (0.9) 2.25 (1.0) 2 HJD 11.25 (5.1) 12.50 (5.7) 13.25 (6.0) 9.00 (4.1) 10.00 (4.5) 10.50 (4.8) 2.00 (0.9) 2.00 (0.9) 2.25 (1.0) JDC 12.25 (5.6) 13.50 (6.1) 14.25 (6.5) 10.00 (4.5) 11.00 (5.0) 11.50 (5.2) 2.00 (0.9) 2.00 (0.9) 2.25 (1.0) Frame Only Trip Unit 2 2 2 2 2 2 2 2 2 V4-T2-160 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C Typical K-Frame Circuit Breaker 2.3 Contents Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-162 V4-T2-164 V4-T2-180 V4-T2-181 V4-T2-184 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 K-Frame (70–400 Amperes) 2 Product Description 2 ● ● ● All Eaton K-Frame circuit breakers are HACR rated K-Frame circuit breakers are available as individual components (frame, trip unit, terminals), or factory assembled complete breakers K-Frame circuit breakers with non-interchangeable trip units are suitable for reverse feed use 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-161 2.3 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. 2 K-Frame with Thermal-Magnetic Trip Unit Technology 2 Thermal-Magnetic Breakers and Frames 1 KD 3 400 F 2 2 Circuit Breaker/ Frame Type DK KD KDB HKD KDC 2 2 Number of Poles 2 = Two-pole 3 = Three-pole 4 = Four-pole 2 2 2 2 KT 3 400 F 2 Trip Unit Type KT = Thermal-magnetic 2 2 2 2 2 2 Suffix = Copper terminals = 50% protected neutral pole (four-pole electronic trip unit circuit breaker only) F = Frame only (400 A only) K = High-magnetic molded-case switch V = 50 ° calibration (thermal-magnetic trip units only) W = Without terminals X = Load terminals only Y = Line side terminals only Blank = Standard load and line side terminals C E Thermal-Magnetic Trip Unit 1 2 2 Circuit Breaker/ Frame Ampere Rating 100 125 150 175 200 225 250 300 350 400 Number of Poles 2 = Two-pole 3 = Three-pole 4 = Four-pole Circuit Breaker/ Frame Ampere Rating 100 125 150 175 200 225 250 300 350 400 Notes 1 Frames are the same for thermal-magnetic or 310+ electronic trip units, e.g., KD3400F or HKD3400F. Ampere rating available with electronic trip unit only. 2 2 2 2 2 2 2 2 2 V4-T2-162 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Suffix T = Trip unit only Molded Case Circuit Breakers Series C 2.3 K-Frame with 310+ Electronic Trip Unit Technology 1 2 2 310+ Circuit Breakers 2 KDB 3 400 F T36 ZG W Performance at 480 Vac KDB = 35 kAIC HKDB = 65 kAIC CKDB = 35 kAIC 100% rated CHKDB = 65 kAIC 100% rated Number of Poles 3 = Three-pole Ampere Rating 125 250 400 T33 T32 T35 T36 T38 T39 = = = = = = Frame Designation F 2 Feature Blank = No feature B20 = High load alarm B21 = Ground fault alarm, with trip B22 = Ground fault alarm, no trip ZG = Zone selective interlocking 2 Terminals W = No terminals L = Line and load 2 2 2 Trip Unit 310+ Electronic LS 310+ Electronic LSI 310+ Electronic LSG 310+ Electronic LSIG 310+ Electronic ALSI with Maintenance Mode 310+ Electronic ALSIG with Maintenance Mode 2 2 2 310+ Electronic Trip Units 3 2 KES 3 400 LSIG ZG Trip Unit Type KES Number of Poles 3 = Three-pole 4 = Four-pole Ampere Rating 125 250 400 2 Trip Unit LS = 310+ Electronic LS LSI = 310+ Electronic LSI LSG= 310+ Electronic LSG 2 LSIG= 310+ Electronic LSIG 2 ALSI= 310+ Electronic LSI with Maintenance Mode ALSIG= 310+ Electronic LSIG with Maintenance Mode 2 Feature Blank = No feature B20 = High load alarm B21 = Ground fault alarm, with trip 2 B22 = Ground fault alarm, no trip 2 ZG = Zone selective interlocking 2 2 2 2 2 2 K-Frame with OPTIM Trip Unit Technology 2 2 OPTIM Circuit Breakers KD 3 125 T5 7 W Circuit Breaker/ Frame Type KD HKD KDC CKD CHKD Number of Poles 3 = Three-pole Circuit Breaker/Frame Ampere Rating 125 250 400 Trip Model T5 = Model 550 T10 = Model 1050 2 Trip Type 2 = LSI 6 = LSIG 7 = LSIA 2 Suffix W = Without terminals 2 2 2 2 Notes 1 Cannot combine ‘B2X’ suffixes with ‘B2X’ suffixes. 2 Not available in four-pole configurations. 3 Frames are the same for thermal-magnetic or 310+ electronic trip units, e.g., KD3400F, HKD3400F, etc. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-163 2.3 2 2 Types KD, HKD and KDC Thermal-Magnetic Circuit Breakers with Interchangeable Trip Units 2 2 2 Series C Product Selection 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Thermal-Magnetic Trip Unit Only 1 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals 1 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals 1 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals 1 For Use with Standard or High or Ultra High Interrupting Frames See Page V4-T2-179 for Optional Terminals Catalog Number Catalog Number Catalog Number Catalog Number Catalog Number Standard Terminals Only Two-Pole 100 KD2100 HKD2100 KDC2100 KT2100T TA300K 2 125 KD2125 HKD2125 KDC2125 KT2125T TA300K 2 150 KD2150 HKD2150 KDC2150 KT2150T TA300K 2 175 KD2175 HKD2175 KDC2175 KT2175T TA300K 2 2 200 KD2200 HKD2200 KDC2200 KT2200T TA300K 2 2 225 KD2225 HKD2225 KDC2225 KT2225T TA300K 2 250 KD2250 HKD2250 KDC2250 KT2250T TA350K 2 2 300 KD2300 HKD2300 KDC2300 KT2300T TA350K 2 350 KD2350 HKD2350 KDC2350 KT2350T TA350K 2 2 400 KD2400 HKD2400 KDC2400 KT2400T 2TA400K 3 2 2 Three-Pole 2 100 KD3100 HKD3100 KDC3100 KT3100T TA300K 2 2 125 KD3125 HKD3125 KDC3125 KT3125T TA300K 2 150 KD3150 HKD3150 KDC3150 KT3150T TA300K 2 2 175 KD3175 HKD3175 KDC3175 KT3175T TA300K 2 200 KD3200 HKD3200 KDC3200 KT3200T TA300K 2 2 225 KD3225 HKD3225 KDC3225 KT3225T TA300K 2 250 KD3250 HKD3250 KDC3250 KT3250T TA350K 2 2 300 KD3300 HKD3300 KDC3300 KT3300T TA350K 2 2 350 KD3350 HKD3350 KDC3350 KT3350T TA350K 2 400 KD3400 HKD3400 KDC3400 KT3400T 3TA400K 3 2 Four-Pole 100 KD4100 HKD4100 KDC4100 KT3100T TA300K 2 2 125 KD4125 HKD4125 KDC4125 KT3125T TA300K 2 2 175 KD4175 HKD4175 KDC4175 KT3175T TA300K 2 200 KD4200 HKD4200 KDC4200 KT3200T TA300K 2 2 225 KD4225 HKD4225 KDC4225 KT3225T TA300K 2 250 KD4250 HKD4250 KDC4250 KT3250T TA350K 2 2 300 KD4300 HKD4300 KDC4300 KT3300T TA350K 2 350 KD4350 HKD4350 KDC4350 KT3350T TA350K 2 400 KD4400 HKD4400 KDC4400 KT3400T 4TA400K 3 2 2 2 Notes 1 Magnetic trip adjustable 5–10 times continuous ampere rating. 2 Individually packed. 3 2TA400K, 3TA400K and 4TA400K terminal kits contain one terminal for each pole and one terminal cover. 2 2 2 V4-T2-164 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Types KD, HKD and KDC Thermal-Magnetic Circuit Breakers—Frame Only 2 Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Catalog Number Catalog Number Catalog Number HKD2400F KDC2400F HKD3400F KDC3400F 2 HKD4400F KDC4400F 2 2 2 2 Two-Pole KD2400F 2 Three-Pole KD3400F Four-Pole KD4400F Types KD, HKD and KDC Electronic Circuit Breakers with Interchangeable 310+ Trip Units Order as individual components: breaker frame, trip unit and terminals. See 310+ adjustability specifications on Page V4-T2-182. Types KD, HKD and KDC Electronic Circuit Breakers with Interchangeable 310+ Trip Units—Three-Pole Max. Cont. Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Standard Options LS LSI LSG LSIG Adjustable Short Time Pickup with I2t Short Delay Ramp Independently Adjustable Short Time Pickup and Delay Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Delay and Ground Fault Protection Catalog Number 2 2 Neutral CT for LSG and LSIG 23 Terminal Catalog Number Information 125 KD3400F HKD3400F KDC3400F KES3125LS KES3125LSI KES3125LSG KES3125LSIG LGFCT125 250 KD3400F HKD3400F KDC3400F KES3250LS KES3250LSI KES3250LSG KES3250LSIG LGFCT250 400 KD3400F HKD3400F KDC3400F KES3400LS KES3400LSI KES3400LSG KES3400LSIG LGFCT400 See Page V4-T2-179 Max. Cont. Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 2 2 2 2 Digitrip RMS 310+ Trip Unit Only 1 Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 2 2 Types KD, HKD and KDC Electronic Circuit Breakers with Interchangeable 310+ Trip Units—Four-Pole 45 Circuit Breaker Frame Only 2 2 Digitrip RMS 310+ Trip Unit Only 1 Circuit Breaker Frame Only 2 Standard Options LS LSI LSG LSIG Adjustable Short Time Pickup with I2t Short Delay Ramp Independently Adjustable Short Time Pickup and Delay Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Delay and Ground Fault Protection Catalog Number 2 2 Neutral CT for LSG and LSIG 23 Terminal Catalog Number Information 125 KD4400F HKD4400F KDC4400F KES4125LS KES4125LSI — — — 250 KD4400F HKD4400F KDC4400F KES4250LS KES4250LSI — — — 400 KD4400F HKD4400F KDC4400F KES4400LS KES4400LSI — — — See Page V4-T2-179 2 2 2 2 Notes 1 For AC use only. 2 Required for four-wire systems if neutral protection is desired. 3 Included with LSG and LSIG trip units. 4 Trip unit includes protected neutral pole. Use corresponding three-pole trip unit if protected neutral pole is not required. 5 Fully rated neutral pole protection is standard. For 50% rated protection on neutral pole, add Suffix E to four-pole trip unit catalog number. 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-165 2.3 2 Molded Case Circuit Breakers Series C Type KDB with Digitrip 310+ Non-Interchangeable Trip Unit Suitable for Reverse Feed See 310+ adjustability specifications on Page V4-T2-182. 2 2 Factory Assembled Circuit Breaker Consisting of Frame and Trip Unit Less Terminals 1 Standard LS Optional LSI Adjustable Short Time Pickup with I2t Short Delay Ramp Adjustable Short Time Independently Adjustable Pickup with I2t Short Delay and Ground Fault Short Time Pickup and Protection Delay LSG LSIG Maximum Continuous Ampere Rating at 40 °C Number of Poles 2 125 3 KDB3125FT33W KDB3125FT32W KDB3125FT35W KDB3125FT36W LGFCT125 250 3 KDB3250FT33W KDB3250FT32W KDB3250FT35W KDB3250FT36W LGFCT250 2 400 3 KDB3400FT33W KDB3400FT32W KDB3400FT35W KDB3400FT36W LGFCT400 2 2 2 2 2 2 2 Catalog Number Catalog Number Terminal Information See Page V4-T2-180 Type HKDB with Digitrip 310+ Non-Interchangeable Trip Unit Suitable for Reverse Feed See 310+ adjustability specifications on Page V4-T2-182. Factory Assembled Circuit Breaker Consisting of Frame and Trip Unit Less Terminals 1 2 2 Independently Adjustable Short Time Pickup and Neutral CT for Ground Fault Protection LSG and LSIG 23 Standard LS Optional LSI Adjustable Short Time Pickup with I2t Short Delay Ramp Adjustable Short Time Independently Adjustable Pickup with I2t Short Delay and Ground Fault Short Time Pickup and Protection Delay LSG LSIG Maximum Continuous Ampere Rating at 40 °C Number of Poles 125 3 HKDB3125FT33W HKDB3125FT32W HKDB3125FT35W HKDB3125FT36W LGFCT125 250 3 HKDB3250FT33W HKDB3250FT32W HKDB3250FT35W HKDB3250FT36W LGFCT250 400 3 HKDB3400FT33W HKDB3400FT32W HKDB3400FT35W HKDB3400FT36W LGFCT400 Independently Adjustable Neutral CT for Short Time Pickup and LSG and LSIG 23 Ground Fault Protection Catalog Number Catalog Number Terminal Information See Page V4-T2-180 2 2 2 2 100% Rated Types CKD and CHKD Electronic Circuit Breakers The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at the 75 °C ampacity. All 100% rated circuit breakers have electronic trip units. 100% Rated Types CKD and CHKD Electronic Circuit Breakers—Three-Pole See 310+ adjustability specifications on Page V4-T2-182. 2 Circuit Breaker Frame Only Standard 2 2 2 2 2 2 2 2 Digitrip RMS 310+ Trip Unit Only Maximum Continuous Ampere Rating at 40 °C Standard Interrupting Capacity High Interrupting Capacity 35 kAIC at 480 Vac 65 kAIC at 480 Vac Adjustable Short Time Pickup with I2t Short Delay Ramp Options Independently Adjustable Short Time Pickup and Delay Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Delay and Ground Fault Protection Catalog Number Neutral CT for LSG and LSIG 23 Catalog Number 125 CKD3400F CHKD3400F KES3125LS KES3125LSI KES3125LSG KES3125LSIG LGFCT125 250 CKD3400F CHKD3400F KES3250LS KES3250LSI KES3250LSG KES3250LSIG LGFCT250 400 CKD3400F CHKD3400F KES3400LS KES3400LSI KES3400LSG KES3400LSIG LGFCT400 Notes 1 For AC use only. 2 Required for four-wire systems if neutral protection is desired. 3 Included with LSG and LSIG trip units. 2 2 2 V4-T2-166 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Terminal Information See Page V4-T2-179 2.3 Molded Case Circuit Breakers Series C Types DK and KDB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units Suitable for reverse feed application. 2 2 Types DK and KDB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 240 Vac Rated, 250 Vdc Maximum Continuous Ampere Rating at 40 °C 2 600 Vac Rated, 250 Vdc Complete Circuit Breaker Complete Circuit Breaker 2 Without Line and Load Terminals With Line Terminals Only With Standard Line and Load Terminals Only Without Line and Load Terminals With Standard Line and Load Terminals Catalog Number Catalog Number Catalog Number Catalog Number Catalog Number 100 — — — KDB2100W KDB2100 125 — — — KDB2125W KDB2125 150 — — — KDB2150W KDB2150 175 — — — KDB2175W KDB2175 200 — — — KDB2200W KDB2200 225 — — — KDB2225W KDB2225 250 DK2250W DK2250Y DK2250 KDB2250W KDB2250 300 DK2300W DK2300Y DK2300 KDB2300W KDB2300 350 DK2350W DK2350Y DK2350 KDB2350W KDB2350 400 DK2400W DK2400Y DK2400 KDB2400W KDB2400 2 100 — — — KDB3100W KDB3100 2 125 — — — KDB3125W KDB3125 150 — — — KDB3150W KDB3150 175 — — — KDB3175W KDB3175 200 — — — KDB3200W KDB3200 225 — — — KDB3225W KDB3225 250 DK3250W DK3250Y DK3250 KDB3250W KDB3250 300 DK3300W DK3300Y DK3300 KDB3300W KDB3300 350 DK3350W DK3350Y DK3350 KDB3350W KDB3350 400 DK3400W DK3400Y DK3400 KDB3400W KDB3400 2 2 Two-Pole 2 2 2 2 2 Three-Pole 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-167 2.3 2 2 2 2 2 2 2 2 2 Maximum Continuous Ampere Rating at 40 °C Three-Pole 2 240 Vac Maximum, 250 Vdc 600 Vac Maximum, 250 Vdc 600 Vac Maximum, 250 Vdc Complete Circuit Breaker with Standard Line and Load Terminals Complete Circuit Breaker with Standard Line and Load Terminals Complete Circuit Breaker with Standard Line and Load Terminals. Suitable for Reverse Feed Use Catalog Number Catalog Number Catalog Number DK2400K KD2400K KDB2400K — HKD2400K HKDB2400K DK3400K KD3400K KDB3400K — HKD3400K HKDB3400K — KD4400K KDB4400K — HKD4400K HKDB4400K Two-Pole 2 2 components and are of the high instantaneous automatic type. Molded case switches are listed in accordance with Underwriters Laboratories Standard UL 489. Molded Case Switches 400 2 Series C Molded Case Switches Eaton’s molded case switches are used as compact switches in applications requiring high current switching capabilities. Molded case switches are constructed of circuit breaker 2 2 Molded Case Circuit Breakers 400 Four-Pole 400 Note Molded case switches may open above 4000 amperes. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-168 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug Order as individual components: breaker frame (which includes trip unit), rating plug, terminals. 2 2 Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) ➀ – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) 2 L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number KD3125T57W 70 ORPK125A70 90 ORPK125A90 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 250 ORPK40A250 300 ORPK40A300 350 ORPK40A350 400 ORPK40A400 Fixed Rating Plug 250 400 KD3125T52W KD3250T52W KD3400T52W KD3125T56W KD3250T56W KD3400T56W KD3250T57W KD3400T57W 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-169 2.3 2 Series C Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only L – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 S – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number HKD3125T57W 70 ORPK125A70 2 90 ORPK125A90 2 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 2 250 ORPK40A250 300 ORPK40A300 2 350 ORPK40A350 400 ORPK40A400 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 HKD3125T52W HKD3250T52W HKD3125T56W HKD3250T56W HKD3250T57W 2 2 2 2 2 2 Fixed Rating Plug 400 HKD3400T52W HKD3400T56W HKD3400T57W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-170 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPK125A70 90 ORPK125A90 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 250 ORPK40A250 300 ORPK40A300 350 ORPK40A350 400 ORPK40A400 2 Three-Pole Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 125 250 400 KDC3125T52W KDC3250T52W KDC3400T52W KDC3125T56W KDC3250T56W KDC3400T56W KDC3125T57W KDC3250T57W KDC3400T57W 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-171 2.3 2 Molded Case Circuit Breakers Series C Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug Order as individual components: breaker frame (which includes trip unit), rating plug, terminals. 2 2 Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug Circuit Breaker Frame Only 2 L S I G A 2 2 2 Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 2 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPK125A70 2 90 ORPK125A90 2 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 2 200 ORPK025A200 2 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A22 250 ORPK40A250 300 ORPK40A300 350 ORPK40A350 400 ORPK40A400 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 250 KD3125T106W KD3250T106W KD3125T107W KD3250T107W 2 2 400 KD3400T106W KD3400T107W 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 V4-T2-172 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 2 OPTIM 1050 2 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPK125A70 90 ORPK125A90 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 250 ORPK40A250 300 ORPK40A300 350 ORPK40A350 400 ORPK40A400 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 400 HKD3125T106W HKD3250T106W HKD3400T106W HKD3125T107W HKD3250T107W HKD3400T107W 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-173 2.3 2 Circuit Breaker Frame Only L S I G A 2 2 Series C Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug, continued 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 2 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPK125A70 2 90 ORPK125A90 2 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 2 250 ORPK40A250 300 ORPK40A300 2 350 ORPK40A350 400 ORPK40A400 2 2 Three-Pole Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 125 250 KDC3125T106W KDC3250T106W KDC3125T107W KDC3250T107W 2 2 2 2 2 2 400 KDC3400T106W KDC3400T107W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-174 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C 100% Rated Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug Order as individual components: breaker frame (which includes trip unit), rating plug, terminals. 2 2 100% Rated Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) 2 L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number CKD3125T57W 70 ORPK125A70 90 ORPK125A90 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 Fixed Rating Plug 250 400 CKD3125T52W CKD3250T52W CKD3400T52W CKD3125T56W CKD3250T56W CKD3400T56W CKD3250T57W CKD3400T57W 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 2 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 250 ORPK40A250 300 ORPK40A300 350 ORPK40A350 400 ORPK40A400 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number (refer to Page V4-T2-293). 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-175 2.3 2 Series C 100% Rated Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 L S I G A 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number CHKD3125T57W 70 ORPK125A70 2 90 ORPK125A90 2 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 2 250 ORPK40A250 300 ORPK40A300 2 350 ORPK40A350 400 ORPK40A400 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 CHKD3125T52W CHKD3250T52W CHKD3125T56W CHKD3250T56W CHKD3250T57W 2 2 2 2 2 2 Fixed Rating Plug 400 CHKD3400T52W CHKD3400T56W CHKD3400T57W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-176 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C 100% Rated Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug Order as individual components: breaker frame (which includes trip unit), rating plug, terminals. 2 2 100% Rated Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) 2 L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 OPTIM 1050 2 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 250 400 CKD3125T106W CKD3250T106W CKD3400T106W CKD3125T107W 70 ORPK125A70 90 ORPK125A90 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 CKD3250T107W 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 CKD3400T107W 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 250 ORPK40A250 300 ORPK40A300 350 ORPK40A350 400 ORPK40A400 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-177 2.3 2 Circuit Breaker Frame Only L S I G A 2 2 Series C 100% Rated Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plug, continued 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 2 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPK125A70 2 90 ORPK125A90 2 100 ORPK125A100 110 ORPK125A110 125 ORPK125A125 125 ORPK025A125 150 ORPK025A150 175 ORPK025A175 200 ORPK025A200 225 ORPK025A225 250 ORPK025A250 200 ORPK40A200 225 ORPK40A225 2 250 ORPK40A250 300 ORPK40A300 2 350 ORPK40A350 400 ORPK40A400 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 CHKD3125T106W CHKD3250T106W CHKD3125T107W CHKD3250T107W 2 2 2 2 2 2 400 CHKD3400T106W CHKD3400T107W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-178 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Accessories Selection Guide and Ordering Guide Line and Load Terminals Eaton’s line and load terminals provide wire connecting capabilities for specific ranges of continuous current ratings and wire types. All terminals comply with Underwriters Laboratories Standards 2 UL 486A and UL 486B and CSA Standard C22.2 No. 65, or Electrical Bulletin 1165. Unless otherwise specified, K-Frame circuit breaker line and load terminals are shipped separately for field installation. Ordering Information K-Frame circuit breakers use Cu/AI terminals as standard. When optional copper or Cu/ AI terminals are required, order by catalog number. Specify if factory installation is required. 2 2 2 2 2 2 2 2 2 Tab is 1/4 x.032 TA401K TA400K, T400K TA350K, T350K TA300K, T300K T400KCW, TA400KCW, TA401KCW TA402K, T402K 2 Line and Load Terminals Maximum Breaker Amperes Terminal Body Material Terminal Wire Type AWG Wire Range/No. Conductors Terminals with Control Wire Termination Metric Wire Range mm2 Catalog Number Catalog Number 2 225 Aluminum Cu/AI 3–350 (1) 35–185 TA300K 1 — 400 Aluminum Cu/AI 250–500 (1) 120–240 TA350K 1 — 400 Aluminum Cu/AI 3/0–250 (2) 95–120 2TA400K 23 2TA400KCW 23 400 Aluminum Cu/AI 3/0–250 (2) 95–120 3TA400K 24 3TA400KCW 24 400 Aluminum Cu/AI 3/0–250 (2) 95–120 4TA400K 56 4TA400KCW 56 Optional Copper and Cu/AI Pressure Type Terminals Copper Cu 3–350 (1) 35–185 T300K1 — 400 Copper Cu 250–500 (1) 120–240 T350K 1 — 400 400 400 Copper Aluminum Aluminum Cu Cu/AI Cu/AI 3/0–250 (2) 2/0–250 (2) or 2/0–500 (1) 500–750 (1) 95–120 2T400K 3 Copper Cu 500–750 (1) 3T400KCW 24 4T400K 5 4T400KCW 56 70–120 2TA401K 23 2TA401KCW 23 70–240 3TA401K 24 3TA401KCW 24 70–240 4TA401K 56 4TA401KCW 56 300–400 2TA402K 23 — 24 — 4TA402K 56 — 2T402K 23 — 3T402K 24 — 4T402K 56 — — 2 2 2 2 23 3T400K 4 3TA402K 400 2T400KCW 2 2 Standard Cu/AI Pressure Terminals 225 2 2 2 2 2 2 2 2 2 Notes 1 Individually packed. 2 Terminal kits contain one terminal for each pole and one terminal cover. 3 Two-pole kit. 4 Three-pole kit. 5 Four-pole kit. 6 Terminal kits contain one terminal for each pole and three interphase barriers. 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-179 2.3 Molded Case Circuit Breakers Series C 2 Accessories 2 Allowable Accessory Combinations Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 2 2 KD Frame Accessories Reference Page Description Alarm lockout (Make/Break) V4-T2-276 Alarm lockout (2Make/2Break) V4-T2-276 2 Auxiliary switch (1A, 1B) V4-T2-278 Auxiliary switch (2A, 2B) V4-T2-278 Auxiliary switch (3A, 3B) V4-T2-278 Auxiliary switch and alarm switch combination V4-T2-279 Shunt trip—standard 2 V4-T2-282 Shunt trip—low energy 2 V4-T2-285 2 2 Three-Pole Left Right Left ■ ■ ❏ ❏ ■ ■ ■ ❏ ■ ■ ■ ● ● ● ● ● ● ● ● ● ● Center Four-Pole Right Left ❏ ❏ ■ ■ ■ ❏ ■ ■ ■ ■ ■ ■ ■ ■ ■ ❏ ■ ■ ■ ● ● ● ● ● ● ● ● ● ● Center Right Neutral Internal Accessories (Only One Internal Accessory Per Pole) 2 2 Two-Pole 1 Undervoltage release mechanism 2 V4-T2-290 PowerNet or zone interlock kit (OPTIM 550) V4-T2-293 ■ ■ ■ ■ ■ ❏ ■ 2 External Accessories End cap kit V4-T2-308 2 Keeper nut V4-T2-308 Control wire terminal kit V4-T2-309 2 Terminal adapter V4-T2-309 Multiwire connectors V4-T2-310 ● ● ● ● ● 2 Rear fed terminals V4-T2-310 ● ● ● ● ● ● ● ● ● Base mounting hardware V4-T2-311 2 Terminal shields V4-T2-313 Interphase barriers V4-T2-313 ● ● ● ● ● ● ● ● ● ● ● ● V4-T2-314 ● ● ● ■ ● ● ● 2 Padlockable handle block V4-T2-314 ● ● ● ■ ■ ● ● ● Non-padlockable handle block ● ● ● ■ 2 Padlockable handle lock hasp V4-T2-315 2 Key Interlock kit V4-T2-316 ❏ V4-T2-317 2 Walking beam interlock—requires two breakers V4-T2-317 Electrical (solenoid) operator V4-T2-318 2 Plug-in adapters V4-T2-319 Rear connecting studs V4-T2-321 2 Panelboard connecting straps V4-T2-322 Handle mechanisms V4-T2-430 2 Handle extension V4-T2-445 IQ Energy Sentinel V4-T2-324 2 Solid-state (electronic) portable test kit V4-T2-324 ❏ ❏ ❏ ● ● ● ● ● ● ● ● ● ● ❏ Sliding bar interlock—requires two breakers ❏ ❏ ❏ ● ● ● ● ● ● ● ● ● ● ❏ V4-T2-315 ■ ❏ ❏ ❏ Cylinder lock 2 Breaker interface module (BIM) V4-T2-325 Digitrip OPTIMizer V4-T2-325 2 Auxiliary power module V4-T2-325 2 2 2 2 ❏ ■ ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● OPTIM System Components Three Poles Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available Notes Two-pole breaker supplied in three-pole frame. Current carrying parts omitted from center pole. 2 Shunt trip and UVR cannot be mounted in right poles on KES or OPTIM trip units. Standard internal accessories cannot be mounted in right pole on any K-Frame OPTIM trip unites. Special OPTIM ground fault and zone interlock accessories are available for field installation in the right pole of K-Frame 550 OPTIM trip units. Factory installed 2a/2b and bell/aux are available for factory installation. K-Frame breakers equipped with OPTIM 1050 trip units include aux-bell alarm in the right pole. 1 2 V4-T2-180 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C KD Frame Accessories, continued Reference Page Description 2 Two-Pole 1 Three-Pole Left Right Left Center Right Left Center Right Neutral 2 2 Four-Pole Modifications (Refer to Eaton) Special calibration — ● ● ● ● ● ● ● ● ● Moisture fungus treatment V4-T2-116 ● ● ● ● ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● ● ● ● ● Marine/naval application — ● ● ● ● ● ● ● ● ● Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both 2 2 2 ● Accessory available/modification available 2 310+ Electronic Trip Unit Accessories Description 2 Catalog Number 2 2 Electronic portable test kit MTST230V Trip unit tamper protection wire seal 5108A03H01 External neutral sensor, 400 A LGFCT400 3 External neutral sensor, 250 A LGFCT250 3 External neutral sensor, 125 A LGFCT125 3 Breaker-mount cause-of-trip indication TRIP-LED Breaker-mount ammeter module DIGIVIEW Remote-mount ammeter module DIGIVIEWR06 4 2 2 2 2 Technical Data and Specifications 2 NEMA/UL 489/CSA Interrupting Capacity Ratings 2 Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 277 480 600 250 56 DK 2, 3 65 — — — 10 KDB 2, 3, 4 65 — 35 25 10 2 Volts DC KD 2, 3, 4 65 — 35 25 10 HKD, HKDB 2, 3, 4 100 — 65 35 22 KDC 7 2, 3, 4 200 — 100 65 22 CKD 3 65 — 35 25 — CHKD 3 100 — 65 35 — 2 2 2 2 2 IEC 157-1 (P1) Interrupting Capacity Ratings 2 Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 380 415 440 500 600 250 56 DK 2, 3 65 — — — — — 10 KDB 2, 3, 4 65 40 40 — — — 10 KD 2, 3, 4 65 40 40 — — — 10 Volts DC HKD, HKDB 2, 3, 4 100 65 65 — — — 22 KDC 2, 3, 4 200 100 100 — — — 22 2 2 2 2 Notes 1 Two-pole breaker supplied in three-pole frame. Current carrying parts omitted from center pole. 2 MTST230V applies to 100–230 Vac. 3 Included with all LD LSG and LSIG trip units and breakers. 4 Includes 6 ft cable for remote mounting; NEMA 3R rated. 5 Two-pole circuit breaker or two outside poles of three-pole circuit breaker. 6 Time constant is 3 milliseconds minimum at 10 kA and 8 milliseconds minimum at 22 kA. 7 Current limiting. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-181 2.3 2 Molded Case Circuit Breakers Series C 310+ Specifications Trip Unit Type 310+ Adjustability Specifications Digitrip RMS 310+ 2 Breaker Type 2 Frame K Frames available 125 A, 250 A, 400 A 2 Continuous current range (A) 55–400 A Ground fault pickup (A) 2 2 K-Frame 310+ Settings 125A 250 A 400 A A (=Ir) 55 100 160 B (=Ir) 60 125 200 50–400 A C (=Ir) 70 150 225 Interrupting capacities at 480 Vac (kAIC) 35, 65, 100 D (=Ir) 80 160 250 100% rated Yes E (=Ir) 90 175 300 F (=Ir) 100 200 315 G (=Ir) 110 225 350 Ir = continuous current or long delay pickup (amperes) (All 310+) Protection 2 Ordering options LS, LSI, LSG, LSIG, ALSI, ALSIG Arcflash Reduction Maintenance System Remote enabled on ALSI, ALSIG 2 Interchangeable trip unit Yes High load alarm, trip (suffix B20) 1 Yes 2 Ground fault alarm with trip (suffix B21) 1 LSG, LSIG, ALSIG 2 Ground fault alarm, no trip (suffix B22) Ir \ In H (=Ir=In) 125 250 400 2 2 2 2 4 4 4 4 7 7 7 7 LSG, LSIG, ALSIG 10 10 10 10 Zone selective interlock (suffix ZG) 1 LSI, LSIG, ALSI, ALSIG 12 12 12 12 Cause of trip indication Yes (via TRIP-LED or DIGIVIEW) 15 15 15 15 Thru-cover accessories No 20 20 20 20 24 24 24 24 Position 1 2 2x 2x Position 2 3 3x 3x Position 3 4 4x 4x Position 4 5 5x 5x 2 Position 5 6 6x 6x Position 6 7 7x 7x 2 Position 7 8 8x 8x 2 Position 8 10 10x 10x Position 9 12 12x 12x tsd = short delay time I2t (milliseconds) (LS and LSG) Fixed 67 @10x tsd = short delay time flat (milliseconds) (LSI, LSIG, ALSI, ALSIG) Position 1 Inst Position 2 120 2 2 tr = long delay time (seconds) (All 310+) Isd (x Ir) = short delay pickup (amperes) (All 310+) 2 2 2 2 2 Ig (x In) = ground fault pickup (amperes) (LSG, LSIG, ALSIG) 2 2 2 2 tg = ground fault delay time (milliseconds) (LSG, LSIG, ALSIG) 2 2 2 Position 3 300 Position 1 25 50 80 Position 2 37.5 75 120 Position 3 50 100 160 Position 4 75 150 240 Position 5 100 200 320 Position 6 125 250 400 Position 1 Inst Position 2 120 Position 3 300 625 1000 Independently adjustable Instantaneous (Ii) setting 2 Maintenance Mode pickup (2.5 x In) (amperes) (310+ with Maintenance Mode—ALSI and ALSIG) Fixed 312 Notes 1 B2x suffixes cannot be combined with B2x suffixes. 2 Not available for KD. Independently adjustable I setting available in LG, NG and RG ALSI and i ALSIG trip units. 2 2 2 V4-T2-182 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Specifications 2 Trip Unit Type Digitrip OPTIM 550 Digitrip OPTIM 1050 rms sensing Yes Yes 2 Frame K K Ampere range 125–400 A 125–400 A 2 Interrupting rating at 480 volts 35, 65, 100 (kA) 35, 65, 100 (kA) 2 Ordering options LSI, LSI(A), LSIG LSI(A), LSIG Fixed rated plug (In) Yes Yes 2 Overtemperature trip Yes Yes 2 2 Breaker Type Protection Long Delay Protection (L) Adjustable rating plug (In) No No Long delay pickup 0.4–1.0 x (In) 0.4–1.0 x (In) Long delay time I2t 2–24 seconds 2–24 seconds Long delay time I4t 1–5 seconds 1–5 seconds 2 Long delay thermal memory Yes Yes High load alarm 0.5–1.0 x Ir 0.5–1.0 x Ir 2 Short delay pickup 150–800% x (Ir) 150–800% x (Ir) 2 Short delay time I2t 100–500 ms 100–500 ms Short delay time flat 100–500 ms 100–500 ms Short Delay Protection (S) Short delay time zone selective interlocking Yes 1 2 Yes 2 2 Instantaneous Protection (I) Instantaneous pickup 200–800% x (In) 200–800% x (In) Discriminator Yes Yes Instantaneous override Yes Yes 2 Ground fault alarm 20–100% x (Is) 20–100% x (Is) Ground fault pickup 20–100% x (Is) 20–100% x (Is) 2 Ground fault delay I2t 100–500 ms 100–500 ms Ground fault delay flat 100–500 ms 100–500 ms Ground Fault Protection (G) Ground fault zone selective interlocking Yes Ground fault thermal memory Yes 1 2 Yes 2 2 Yes System Diagnostics Status LEDs Yes Yes Cause of trip LEDs Yes Yes Magnitude of trip information Yes 2 Yes 1 Remote signal contact—ground alarm Yes Local auxiliary and bell alarm contact Optional Included 2 Digital display Yes 2 Yes 2 2 Current Yes Yes Power and energy No Yes Power quality—harmonics No Yes Power factor No Yes 2 Yes 3 Yes 2 OPTIMizer, BIM, PowerNet OPTIMizer, BIM, PowerNet 2 Yes System Monitoring 2 Communications PowerNet Testing Testing method 2 Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting 2 2 Notes Zone interlock kit. 2 By OPTIMizer/BIM. 3 Eaton’s PowerNet kit. 1 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-183 2.3 2 2 Molded Case Circuit Breakers Series C Dimensions and Weights Approximate Dimensions in Inches (mm) KD Frame 2 Number of Poles Width Height Depth 2 2, 3 5.50 (149.7) 10.13 (257.3) 4.10 (104.1) 4 7.22 (183.4) 10.13 (257.3) 4.10 (104.1) 2 KD-Frame, Two- and Three-Pole 2 2 4.31 (109.6) 5.49 (139.4) Front Cover Cutout 2 0.34 R (8.7 R) 2 3.75 (95.3) 2 2 Side View Front View CL Handle 0.83 (21.0) 0.19 R (4.8 R) 2 1.64 (41.7) ON 1.25 (31.8) 10.13 (257.2) 1.31 (33.3) 2 OFF 2.63 (66.7) 2.39 (60.7) 4.78 (121.5) 2 2 2 2 2 2 Approximate Shipping Weight, Lbs (kg) KD Frame Complete Breaker Trip Unit 1 Frame Only Breaker Type Two-Pole Three-Pole Two-Pole Three-Pole Two-Pole Three-Pole DK 10.0 (4.5) 11.5 (5.2) — — — — 2 KDB 10.0 (4.5) 11.5 (5.2) — — — — KD 10.0 (4.5) 11.5 (5.2) 7.5 (3.4) 8.5 (3.9) 1.5 (0.7) 1.5 (0.7) 2 HKD, HKDB 10.0 (4.5) 11.5 (5.2) 7.5 (3.4) 8.5 (3.9) 1.5 (0.7) 1.5 (0.7) KDC 10.0 (4.5) 11.5 (5.2) 7.5 (3.4) 8.5 (3.9) 1.5 (0.7) 1.5 (0.7) 2 2 2 Note 1 Weights shown are for thermal-magnetic trip units. Three-pole electronic trip units weigh 2.5 lbs (1.1 kg). 2 2 2 2 2 2 V4-T2-184 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Contents Typical L-Frame Circuit Breaker Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-186 V4-T2-188 V4-T2-204 V4-T2-206 V4-T2-210 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 2 L-Frame (125–600 Amperes) Product Description ● ● ● All Eaton L-Frame circuit breakers are HACR rated L-Frame circuit breakers are available as individual components (frame, trip unit, terminals), or factory assembled complete breakers L-Frame circuit breakers with non-interchangeable trip units are suitable for reverse feed use 2 Standards and Certifications ● CE marked 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-185 2.3 2 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. LD-Frame with Thermal-Magnetic Trip Unit Technology Thermal-Magnetic Breakers and Frame 1 2 LD 3 600 F 2 Circuit Breaker/ Frame Type LDB LD HLD LDC CLD CHLD CLDC 2 2 2 2 2 Number of Poles 2 = Two-pole 3 = Three-pole 4 = Four-pole LT 3 400 T 2 Trip Unit Type LT = Thermal-magnetic 2 2 2 2 Suffix C = Copper terminals F = Frame only (600 A only) K = High magnetic molded case switch V = 50 °C (thermal-magnetic trip units only) W = Without terminals X = Load side terminals only Y = Line side terminals only Thermal-Magnetic Trip Unit 1 2 2 Circuit Breaker/ Frame Ampere Rating 300 350 400 450 500 600 Number of Poles 2 = Two-pole 3 = Three-pole 4 = Four-pole Trip Unit Rating/Plug Ampere Rating 300 350 400 450 500 600 Suffix T = Trip unit thermal-magnetic fixed thermal adjustable magnetic V = 50 °C calibration (thermal-magnetic trip units only) Note 1 Frames are the same for thermal-magnetic or 310+ electronic trip units, e.g., LD3600F, HLD3600F, etc. 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-186 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C LD-Frame with 310+ Electronic Trip Unit Technology 2 310+ Circuit Breakers 2 LDB 3 600 F T36 B22ZG W Performance at 480 Vac LDB = 35 kAIC HLDB = 65 kAIC LDCB = 100 kAIC CLDB = 35 kAIC, 100% rated CHLDB = 65 kAIC, 100% rated CLDCB = 100 kAIC, 100% rated 2 Number of Poles 3 = Three-pole 4 = Four-pole Terminals W = No terminals Amperes 600 Designation T33 T32 T35 T36 T38 T39 = = = = = = Trip Unit 310+ Electronic LS 310+ Electronic LSI 310+ Electronic LSG 1 310+ Electronic LSIG 1 310+ Electronic LSI with Maintenance Mode 310+ Electronic LSIG with Maintenance Mode 1 Blank = B20 = B21 = B22 = ZG = Features No feature High load alarm Ground fault alarm, with trip 1 Ground fault alarm, no trip 1 Zone selective interlocking F 2 2 2 2 2 2 310+ Electronic Trip Units 2 2 LES 3 600 LSIG B22ZG 2 Trip Unit Type LES Number of Poles 3 = Three-pole 4 = Four-pole Amperes 600 LS = LSI = LSG = LSIG = ALSI = ALSIG = Trip Unit 310+ Electronic LS 310+ Electronic LSI 310+ Electronic LSG 1 310+ Electronic LSIG 1 310+ Electronic LSI with Maintenance Mode 310+ Electronic LSIG with Maintenance Mode 1 Blank = B20 = B21 = B22 = ZG = Features No feature High load alarm Ground fault alarm, with trip 1 Ground fault alarm, no trip 1 Zone selective interlocking 2 2 OPTIM Circuit Breakers 2 LD 3 125 T5 7 W Number of Poles 3 = Three-pole 2 2 LD-Frame with OPTIM Electronic Trip Unit Technology Circuit Breaker/ Frame Type LD HLD LDC CLD CHLD CLDC 2 Circuit Breaker/ Frame Ampere Rating 125 (Available on Model 1050 only) 250 (Available on Model 1050 only) 400 600 2 Trip Type 2 = LSI (550 only) 6 = LSIG 7 = LSIA 2 Suffix W = Without terminals 2 2 Trip Model T5 = Model 550 T10 = Model 1050 2 2 Notes 1 Not available in four-pole configurations. 2 Frames are the same for thermal-magnetic or 310+ electronic trip units, e.g., LD3600F, HLD3600F, etc. 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-187 2.3 Molded Case Circuit Breakers Series C 2 Product Selection 2 Types LD, HLD and LDC Thermal-Magnetic Circuit Breakers with Interchangeable Trip Units Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Factory Assembled Factory Assembled Circuit Circuit Consisting of Frame, Consisting of Frame, Trip Unit and Terminals Trip Unit and Terminals For Use with Standard or High or Ultra High Interrupting Frames See Page V4-T2-203 for Optional Terminals Catalog Number Catalog Number Catalog Number Catalog Number Catalog Number 300 LD2300 HLD2300 LDC2300 LT2300T TA602LD 2 2 350 LD2350 HLD2350 LDC2350 LT2350T TA602LD 2 400 LD2400 HLD2400 LDC2400 LT2400T TA602LD 2 2 450 LD2450 HLD2450 LDC2450 LT2450T TA602LD 2 500 LD2500 HLD2500 LDC2500 LT2500T TA602LD 2 2 600 LD2600 HLD2600 LDC2600 LT2600T 2TA603LDK 3 2 300 LD3300 HLD3300 LDC3300 LT3300T TA602LD 2 2 350 LD3350 HLD3350 LDC3350 LT3350T TA602LD 2 400 LD3400 HLD3400 LDC3400 LT3400T TA602LD 2 2 450 LD3450 HLD3450 LDC3450 LT3450T TA602LD 2 500 LD3500 HLD3500 LDC3500 LT3500T TA602LD 2 2 600 LD3600 HLD3600 LDC3600 LT3600T 3TA603LDK 3 2 300 LD4300 HLD4300 LDC4300 LT4300T TA602LD 2 2 350 LD4350 HLD4350 LDC4350 LT4350T TA602LD 2 400 LD4400 HLD4400 LDC4400 LT4400T TA602LD 2 2 450 LD4450 HLD4450 LDC4450 LT4450T TA602LD 2 500 LD4500 HLD4500 LDC4500 LT4500T TA602LD 2 600 LD4600 HLD4600 LDC4600 LT4600T 4TA603LDK 3 2 2 2 2 2 2 2 2 Maximum Continuous Ampere Rating at 40 °C 1 Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Standard Terminals Only Two-Pole Three-Pole Four-Pole 4 Types LD, HLD and LDC Thermal-Magnetic Circuit Breakers—Frame Only Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 2 Catalog Number Catalog Number Catalog Number 2 Two-Pole HLD2600F LDC2600F 2 Three-Pole HLD3600F LDC3600F HLD4600F LDC4600F 2 2 2 2 2 Thermal-Magnetic Trip Unit Only LD2600F LD3600F Four-Pole LD4600F Notes 1 Magnetic trip range 5–10 times continuous ampere rating. 2 Individually packed. 3 Terminal kits contain one terminal for each pole and one terminal cover. 4 Neutral is in right pole. 2 2 V4-T2-188 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Types LD, HLD and LDC Electronic Circuit Breakers with Interchangeable Trip Units Order as individual components: breaker frame, trip unit and terminals. See 310+ adjustability specifications on Page V4-T2-182. 2 Types LD, HLD and LDC Electronic Circuit Breakers with Interchangeable 310+ Trip Units 2 Digitrip RMS 310+ Trip Unit Only 1 Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac Catalog Number Standard LS Optional LSI LSG LSIG Adjustable Short Time Pickup with I2t Short Delay Ramp Independently Adjustable Short Time Pickup and Delay Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Ground Fault Protection LES3600LSI LES3600LSG LES3600LSIG Catalog Number 2 2 Neutral CT for LSG and LSIG 23 Terminal Catalog Number Information Three-Pole 600 LD3600F HLD3600F LDC3600F LES3600LS LGFCT600 See Page V4-T2-180 Four-Pole 4 600 LD4600F HLD4600F LDC4600F LES4600LS LES4600LSI — — — See Page V4-T2-180 Adjustable Short Time Pickup with I2t Short Delay Ramp Adjustable Short Time Independently Adjustable Pickup with I2t Short Delay and Ground Fault Short Time Pickup and Protection Delay Maximum Continuous Ampere Rating at 40 °C Number of Poles 600 3 LDB3600FT33W LDB3600FT32W LDB3600FT35W LDB3600FT36W 600 3 HLDB3600FT33W HLDB3600FT32W HLDB3600FT35W HLDB3600FT36W 600 3 LDCB3600FT33W LDCB3600FT32W LDCB3600FT35W LDCB3600FT36W Independently Adjustable Short Time Pickup and Neutral CT for Ground Fault Protection LSG and LSIG 23 Terminal Catalog Number Information LGFCT600 See Page V4-T2-180 100% Rated Types CLD, CHLD and CLDC Electronic Circuit Breakers with Interchangeable Trip Units The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at the 75 °C ampacity. All 100% rated circuit breakers have electronic trip units. Order as individual components: breaker frame, trip unit and terminals. See 310+ adjustability specifications on Page V4-T2-182. 100% Rated Types CLD, CHLD and CLDC Electronic Circuit Breakers with 310+ Interchangeable Trip Units Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac Optional LSI LSG LSIG Ultra High Interrupting High Interrupting Capacity Current Capacity 600 Vac Limiting 600 Vac Rated 65 kAIC at Rated 100 kAIC 480 Vac at 480 Vac Adjustable Short Time Pickup with Adjustable Short Independently Time Pickup with Adjustable Short I2t Short Delay 2 Time Pickup and and Ground Fault I t Short Delay Protection Ramp Delay Independently Adjustable Short Time Pickup and Ground Fault Neutral CT for Protection LSG and LSIG 23 Terminal Catalog Number Information CHLD3600F LES3600LS LES3600LSIG Catalog Number Three-Pole 600 CLD3600F CLDC3600F LES3600LSI LES3600LSG LGFCT600 2 2 2 2 2 2 2 2 Digitrip RMS 310+ Trip Unit Only Standard LS 2 2 LSIG Catalog Number 2 2 Factory Assembled Circuit Breaker Consisting of Frame and Trip Unit Less Terminals 1 LSG 2 2 Circuit Breaker Frame Including Digitrip RMS 310+ Electronic Trip Unit Less Terminals Types LDB, HLDB and LDCB with Digitrip 310+ Non-Interchangeable Trip Units Optional LSI 2 2 Types LDB, HLDB and LDCB Electronic Circuit Breakers with Non-Interchangeable 310+ Electronic Trip Units Suitable for Reverse Feed See 310+ adjustability specifications on Page V4-T2-182. Standard LS 2 See Page V4-T2-180 2 2 2 2 2 2 Notes 1 For AC use only. 2 Required for four-wire systems if neutral protection is desired. 3 Included with LSG and LSIG trip units. 4 Neutral is in right pole. 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-189 2.3 2 Molded Case Circuit Breakers Series C Type LDB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units 1 2 600 Vac Rated, 250 Vdc Complete Circuit Breaker Without Line and Load Terminals With Standard Line and Load Terminals Only Catalog Number Catalog Number 300 LDB2300W LDB2300 2 350 LDB2350W LDB2350 400 LDB2400W LDB2400 2 450 LDB2450W LDB2450 2 500 LDB2500W LDB2500 600 LDB2600W LDB2600 2 2 2 Maximum Continuous Ampere Rating Molded Case Switches Eaton’s molded case switches are used as compact switches in applications requiring high current switching capabilities. Molded case switches are constructed of circuit breaker components and are of the high instantaneous automatic type. Molded case switches are listed in accordance with Underwriters Laboratories Standard UL 489. Two-Pole Molded Case Switches Maximum Continuous Ampere Rating at 40 °C 600 Vac Maximum, 250 Vdc Standard Terminals Only Circuit Breaker Only without Line and Load Terminals See Page V4-T2-203 for Optional Terminals Catalog Number Catalog Number 2 Three-Pole 300 LDB3300W LDB3300 600 LD2600WK 2TA603LDK 2 350 LDB3350W LDB3350 600 LDB2600WK 1 2TA603LDK 400 LDB3400W LDB3400 600 HLD2600WK 2TA603LDK 2 450 LDB3450W LDB3450 Three-Pole 2 500 LDB3500W LDB3500 600 LD3600WK 3TA603LDK 600 LDB3600W LDB3600 600 LDB3600WK 1 3TA603LDK 2 600 HLD3600WK 3TA603LDK 2 600 LD4600WK 4TA603LDK 2 600 LDB4600WK 1 4TA603LDK 600 HLD4600WK 4TA603LDK 2 Notes 1 Factory sealed—suitable for reverse feed application. 2 Molded case switch will trip above 6000 amperes. Two-Pole Four-Pole 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-190 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM Electronic Circuit Breaker with Interchangeable Rating Plug Order as individual components: Breaker Frame (which includes Trip Unit), Rating Plug, Terminals. 2 Digitrip OPTIM 550 Electronic Circuit Breaker with Interchangeable Rating Plug 2 Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only 2 L – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 S – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number LD3125T57W — ORPL125A070 — ORPL125A090 — ORPL125A100 — ORPL125A110 — ORPL125A125 — ORPL025A125 — ORPL025A150 — ORPL025A175 — ORPL025A200 — ORPL025A225 — ORPL025A250 200 ORPL40A200 225 ORPL40A225 250 ORPL40A250 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 Fixed Rating Plug 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 250 400 600 LD3125T52W LD3250T52W LD3400T52W LD3600T52W LD3125T56W LD3250T56W LD3400T56W LD3600T56W LD3250T57W LD3400T57W LD3600T57W 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-191 2.3 2 Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only L – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 S – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) 2 2 Series C Digitrip OPTIM 550 Electronic Circuit Breaker with Interchangeable Rating Plug, continued 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 70 ORPL125A070 2 90 ORPL125A090 2 100 ORPL125A100 110 ORPL125A110 2 125 250 HLD3125T52W HLD3250T52W HLD3125T56W HLD3250T56W HLD3125T57W HLD3250T57W 2 2 2 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 2 250 ORPL40A250 300 ORPL40A300 2 350 ORPL40A350 2 2 400 600 HLD3400T52W HLD3600T52W HLD3400T56W HLD3600T56W HLD3400T57W HLD3600T57W 2 2 2 2 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 V4-T2-192 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM 550 Electronic Circuit Breaker with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number — ORPL125A070 — ORPL125A090 — ORPL125A100 — ORPL125A110 — ORPL125A125 — ORPL025A125 — ORPL025A150 — ORPL025A175 — ORPL025A200 — ORPL025A225 — ORPL025A250 200 ORPL40A200 225 ORPL40A225 250 ORPL40A250 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 Three-Pole Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 125 250 400 600 LDC3125T52W LDC3250T52W LDC3400T52W LDC3600T52W LDC3125T56W LDC3250T56W LDC3400T56W LDC3600T56W LDC3125T57W LDC3250T57W LDC3400T57W LDC3600T57W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-193 2.3 Molded Case Circuit Breakers Series C 2 Digitrip OPTIM Electronic Circuit Breaker with Interchangeable Rating Plug Order as individual components: Breaker Frame (which includes Trip Unit), Rating Plug, Terminals. 2 Digitrip OPTIM 1050 Electronic Circuit Breaker with Interchangeable Rating Plug Circuit Breaker Frame Only 2 L S I G A 2 2 2 Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 90 ORPL125A090 2 100 ORPL125A100 2 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 2 225 ORPL40A225 250 ORPL40A250 2 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 2 400 ORPL60A400 500 ORPL60A500 2 600 ORPL60A600 2 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 250 LD3125T106W LD3250T106W LD3125T107W LD3250T107W 2 2 2 2 2 2 2 400 600 LD3400T106W LD3600T106W LD3400T107W LD3600T107W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 V4-T2-194 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM 1050 Electronic Circuit Breaker with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 2 OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 90 ORPL125A090 100 ORPL125A100 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 250 ORPL40A250 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 400 600 HLD3125T106W HLD3250T106W HLD3400T106W HLD3600T106W HLD3125T107W HLD3250T107W HLD3400T107W HLD3600T107W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-195 2.3 2 Circuit Breaker Frame Only L S I G A 2 2 Series C Digitrip OPTIM 1050 Electronic Circuit Breaker with Interchangeable Rating Plug, continued 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 2 90 ORPL125A090 2 100 ORPL125A100 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 2 250 ORPL40A250 300 ORPL40A300 2 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 2 Three-Pole Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 125 250 LDC3125T106W LDC3250T106W LDC3125T107W LDC3250T107W 2 2 2 2 2 400 600 LDC3400T106W LDC3600T106W LDC3400T107W LDC3600T107W 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 2 V4-T2-196 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C 100% Rated Digitrip OPTIM Circuit Breakers with Interchangeable Rating Plug Order as individual components: Breaker Frame (which includes Trip Unit), Rating Plug, Terminals. 2 2 100% Rated Digitrip OPTIM 550 Circuit Breakers with Interchangeable Rating Plug Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) 2 L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number CLD3125T57W 70 ORPL125A070 90 ORPL125A090 100 ORPL125A100 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 250 ORPL40A250 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 Fixed Rating Plug 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 250 400 600 CLD3125T52W CLD3250T52W CLD3400T52W CLD3600T52W CLD3125T56W CLD3250T56W CLD3400T56W CLD3600T56W CLD3250T57W CLD3400T57W CLD3600T57W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-197 2.3 2 Series C 100% Rated Digitrip OPTIM 550 Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 L S I G A 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number CHLD3125T57W 70 ORPL125A070 2 90 ORPL125A090 2 100 ORPL125A100 110 ORPL125A125 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 2 250 ORPL40A250 350 ORPL40A350 2 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 CHLD3125T52W CHLD3250T52W CHLD3125T56W CHLD3250T56W CHLD3250T57W 2 2 2 2 2 400 600 CHLD3400T52W CHLD3600T52W CHLD3400T56W CHLD3600T56W CHLD3400T57W CHLD3600T57W 2 2 2 2 Fixed Rating Plug Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 V4-T2-198 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C 100% Rated Digitrip OPTIM 550 Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only 2 Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 90 ORPL125A090 100 ORPL125A100 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 250 ORPL40A250 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 Three-Pole Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 125 250 400 600 CLDC3125T52W CLDC3250T52W CLDC3400T52W CLDC3600T52W CLDC3125T56W CLDC3250T56W CLDC3400T56W CLDC3600T56W CLDC3125T57W CLDC3250T57W CLDC3400T57W CLDC3600T57W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-199 2.3 2 Circuit Breaker Frame Only L S I G A 2 2 Series C 100% Rated Digitrip OPTIM 1050 Circuit Breakers with Interchangeable Rating Plug 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 2 90 ORPL125A090 2 100 ORPL125A100 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 2 250 ORPL40A250 300 ORPL40A300 2 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 35 kAIC at 480 Vac 125 250 CLD3125T106W CLD3250T106W CLD3125T107W CLD3250T107W 2 2 2 2 2 400 600 CLD3400T106W CLD3600T106W CLD3400T107W CLD3600T107W 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 2 V4-T2-200 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C 100% Rated Digitrip OPTIM 1050 Circuit Breakers with Interchangeable Rating Plug, continued Circuit Breaker Frame Only L S I G A Maximum Continuous Ampere Rating at 40 °C 2 Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) 2 2 OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 90 ORPL125A090 100 ORPL125A100 110 ORPL125A110 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 250 ORPL40A250 300 ORPL40A300 350 ORPL40A350 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 125 250 400 600 CHLD3125T106W CHLD3250T106W CHLD3400T106W CHLD3600T106W CHLD3125T107W CHLD3250T107W CHLD3400T107W CHLD3600T107W 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-201 2.3 2 Circuit Breaker Frame Only L S I G A 2 2 Series C 100% Rated Digitrip OPTIM 1050 Electronic Circuit Breaker with Interchangeable Rating Plug, continued 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time (I2t or Flat Response) OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 70 ORPL125A070 2 90 ORPL125A090 2 100 ORPL125A100 110 ORPL125A110 2 2 Three-Pole Ultra High Interrupting Capacity Current Limiting 600 Vac Rated 100 kAIC at 480 Vac 125 250 CLDC3125T106W CLDC3250T106W CLDC3125T107W CLDC3250T107W 2 2 2 125 ORPL125A125 125 ORPL025A125 150 ORPL025A150 175 ORPL025A175 200 ORPL025A200 225 ORPL025A225 250 ORPL025A250 200 ORPL40A200 225 ORPL40A225 2 250 ORPL40A250 300 ORPL40A300 2 350 ORPL40A350 2 2 400 600 CLDC3400T106W CLDC3600T106W CLDC3400T107W CLDC3600T107W 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 2 V4-T2-202 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 400 ORPL40A400 300 ORPL60A300 350 ORPL60A350 400 ORPL60A400 500 ORPL60A500 600 ORPL60A600 2.3 Molded Case Circuit Breakers Series C Accessories Selection Guide and Ordering Information Line and Load Terminals Eaton’s line and load terminals provide wire connecting capabilities for specific ranges of continuous current ratings and wire types. All terminals comply with Underwriters Laboratories Standards UL 486A and UL 486B and CSA Standard C22.2 No. 65M. Unless otherwise specified, 2 L-Frame circuit breaker line and load terminals are shipped separately for field installation. The wire connecting terminal is secured with two panhead, slotted screws and lockwashers that can be checked for the correct torque loading or retightened from the front of the circuit breaker before installation of the conductors. (Applies to all styles.) The circuit breaker line/load terminal conductors are positioned in the conducting holes in the wire connecting terminal and are secured with recessed socket screws that are tightened to the correct torque loading from the front of the circuit breaker. Ordering Information L-Frame circuit breakers use Cu/AI terminals as standard. When optional copper terminals are required, order by catalog Number. Specify if factory installation is required. 2 2 2 2 2 2 Terminals 2 TA401LD or TA603LD Terminal (Step-Type Terminal Requires Terminal Cover and Warning Label. See Inset.) Pan-Head Screws and Lockwashers TA450LD or TA602LD or T602LD Terminal 2 Pan-Head Screws and Lockwashers (Installed before Cable Clamping Screws) 2 2 Terminal Cover 2 2 2 2 Warning Label 2 Retainer 2 Screws Circuit Breaker Line Terminal Cover 2 2 Line and Load Terminals Maximum Breaker Amperes Terminal Body Material Wire Type Terminals with Control Wire Termination Terminal AWG Wire Range/Number of Conductors Metric Wire Range mm2 Poles Catalog Number Catalog Number 2 2 2 Standard Cu/AI Pressure Terminals 2 400 Aluminum Cu/AI 4/0–600 (1) 120–300 Two-pole kit 1 2TA401LDK — 400 Aluminum Cu/AI 4/0–600 (1) 120–300 Three-pole kit 1 3TA401LDK — 400 Aluminum Cu/AI 4/0–600 (1) 120–300 Four-pole kit 1 4TA401LDK — 450 Aluminum Cu/AI 4–4/0 (2) 25–95 2 TA450LD — 500 Aluminum Cu/AI 3/0–350 (2) 95–150 2 TA602LD TA602LDCW 600 Aluminum Cu/AI 400–500 (2) 185–240 Two-pole kit 1 2TA603LDK 2TA603LDKCW 600 Aluminum Cu/AI 400–500 (2) 185–240 Three-pole kit 1 3TA603LDK 3TA603LDKCW 600 Aluminum Cu/AI 400–500 (2) 185–240 Four-pole kit 1 4TA603LDK 4TA603LDKCW 2 120–250 2 T602LD T602LDCW 2 2 2 2 Optional Copper and Cu/AI Pressure Type Terminals 600 Copper Cu 250–350 (2) 2 Notes 1 Terminal kits contain one terminal for each pole and one terminal cover. 2 Individually packed. 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-203 2.3 Molded Case Circuit Breakers Series C 2 Accessories 2 Allowable Accessory Combinations Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 2 LD Frame Accessories Reference Page Two-Pole 1, Three-Pole Four-Pole Left Right Left Alarm lockout (Make/Break) V4-T2-276 ■ ■ ■ ■ Alarm lockout (2Make/2Break) V4-T2-276 ■ ■ ■ ■ Auxiliary switch (1A, 1B) V4-T2-278 ■ ■ ■ ■ Auxiliary switch (2A, 2B) V4-T2-278 ■ ■ ■ ■ Auxiliary switch (3A, 3B) V4-T2-278 ■ ■ ■ ■ 2 Auxiliary switch (1A, 1B) and alarm switch combination V4-T2-280 ■ ■ ■ ■ 2 Auxiliary switch (2A, 2B) and alarm switch combination V4-T2-280 ■ ■ ■ ■ Shunt trip—standard 4 V4-T2-282 ■ ■ ■ ■ Shunt trip—low energy 4 V4-T2-285 ■ ■ ■ ■ Undervoltage release mechanism 4 V4-T2-291 ■ ■ ■ ■ 2 Eaton PowerNet communications kit (OPTIM 550) V4-T2-293 2 End cap kit V4-T2-308 ● ● ● ● ● ● ● Control wire terminal kit V4-T2-309 ● ● ● ● ● ● ● Base mounting hardware V4-T2-311 ● ● ● ● ● ● ● 2 Terminal shields V4-T2-313 ● ● ● ● ● ● ● 2 Interphase barriers V4-T2-313 ● ● ● ● ● ● ● Non-padlockable handle block V4-T2-314 Padlockable handle lock hasp V4-T2-315 ❏ Key interlock kit V4-T2-316 ❏ 2 Sliding bar interlock—requires two breakers V4-T2-317 ● ● ● 2 Walking beam interlock—requires two breakers V4-T2-317 ● ● ● ● ● ● ● Electrical (motor) operator V4-T2-318 ● ● ● ● ● ● ● Plug-in adapters V4-T2-320 ● ● ● ● ● ● ● Rear connecting studs V4-T2-321 ● ● ● ● ● ● ● 2 Panelboard connecting straps V4-T2-322 ● ● ● ● ● ● ● 2 Handle mechanisms V4-T2-430 ● ● ● ● ● ● ● Handle extension V4-T2-445 ● ● ● ● ● ● ● Solid-state (electronic) portable test kit V4-T2-324 ● ● ● ● ● ● ● 2 2 2 2 2 2 2 2 2 2 2 2 2 Description Internal Accessories (Only One Internal Accessory Per Pole) Center Center Right Neutral 2 3 ■ External Accessories ■ ■ ❏ ❏ ❏ ❏ ❏ ❏ Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available Notes Two-pole breaker supplied in three-pole frame. Current carrying parts omitted from center pole. 2 Refer to Eaton for appropriate neutral pole accessory combinations. 3 OPTIM model 1050 is factory sealed and does not have the right pole space available for accessories. 4 Shunt trip and UVR cannot be mounted in right poles on LES or OPTIM trip units. Standard non-tripping internal accessories can be mounted in the left or right poles of LES and 550 OPTIM trip units. 1 2 2 2 V4-T2-204 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C LD Frame Accessories, continued Description Reference Page Two-Pole 1, Three-Pole Left Center Right 2 Four-Pole Left Center Right Neutral 2 OPTIM System Components Three Poles Ground fault alarm unit V4-T2-324 Potential transformer module V4-T2-324 Breaker interface module (BIM) V4-T2-325 Digitrip OPTIMizer V4-T2-325 Auxiliary power module V4-T2-325 2 2 2 2 Modifications (Refer to Eaton) Special calibration — ● ● ● ● ● ● ● Moisture fungus treatment V4-T2-116 ● ● ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● ● ● Marine/naval application — ● ● ● ● ● ● ● 2 2 2 2 Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available 2 2 310+ Electronic Trip Unit Accessories Description Catalog Number Electronic portable test kit MTST230V 3 Trip unit tamper protection wire seal 5108A03H01 External neutral sensor LGFCT600 4 Breaker-mount cause-of-trip indication TRIP-LED Breaker-mount ammeter module DIGIVIEW Remote-mount ammeter module DIGIVIEWR06 2 2 2 2 2 5 Notes 1 Two-pole breaker supplied in three-pole frame. Current carrying parts omitted from center pole. 2 Refer to Eaton for appropriate neutral pole accessory combinations. 3 MTST230V applies to 100–230 Vac. 4 Included with all LD LSG and LSIG trip units and breakers. 5 Includes 6 ft cable for remote mounting; NEMA 3R rated. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-205 2.3 Molded Case Circuit Breakers Series C 2 Technical Data and Specifications 2 UL 489 Interrupting Capacity Ratings 1 2 Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 277 480 600 125 250 23 2 Interrupting Capacity (kA rms Symmetrical Amperes) Volts DC LDB 2, 3 65 — 35 25 — 22 LD 2, 3, 4 65 — 35 25 — 22 CLD 4 2, 3, 4 65 — 35 25 — — 2 HLD, HLDB 2, 3, 4 100 — 65 35 — 25 CHLD 4 2, 3, 4 100 — 65 35 — — 2 LDC, LDCB 5 2, 3, 4 200 — 100 50 — 30 CLDC 45 2, 3, 4 200 — 100 50 — — 2 2 2 2 IEC 947-2 Interrupting Capacity Ratings 1 Interrupting Capacity (kA Symmetrical Amperes) Volts AC (50/60 Hz) Volts DC Circuit Breaker Type Number of Poles 240 Icu Ics Icu Ics Icu Ics Icu Ics LDB 2, 3 85 85 45 45 20 10 20 10 2 LD 2, 3, 4 85 85 45 45 20 10 20 10 4 2, 3, 4 85 85 45 45 20 10 — — 2 HLD, HLDB 2, 3, 4 100 100 70 70 25 13 20 10 2 CHLD 4 2, 3, 4 100 100 70 70 25 13 — — LDC, LDCB 2, 3, 4 200 100 100 75 35 18 20 10 CLDC 4 2, 3, 4 200 100 100 75 35 18 — — 2 2 2 2 2 CLD 415 250 23 690 Notes 1 Utilization Category A circuit breakers. 2 L/R = 8 milliseconds minimum. 3 Two-pole circuit breaker or two poles of three-pole circuit breaker. Incorporating thermal-magnetic trip unit only. 4 100% rated breakers. 5 Current limiting. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-206 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C 310+ Specifications Description Trip Unit Type 310+ Adjustability Specifications Digitrip RMS 310+ Breaker Type Frame designation LD Frame Specification 310+ settings 600 A Ir = continuous current or long delay pickup (amperes) (All 310+) LD Frames available 600 A Continuous current range (A) 250–600 A Ground fault pickup (A) 120–600 A Interrupting capacities at 480 Vac (kAIC) 35, 65, 100 100% rated Description Specification Yes Protection Ordering options LS, LSI, LSG, LSIG, ALSI, ALSIG 250 B 300 C 315 D 350 E 400 F 450 G 500 H (= In) 600 2 2 4 4 2 2 Ir A 2 2 2 2 2 Arcflash Reduction Maintenance System (or Maintenance Mode) Remote enabled on ALSI, ALSIG Interchangeable trip unit Yes High load alarm (suffix B20) 1 Yes 7 7 Ground fault alarm with trip (suffix B21) 1 LSG, LSIG, ALSIG 10 10 Ground fault alarm, no trip (suffix B22) 1 LSG, LSIG, ALSIG 12 12 Zone selective interlocking (suffix ZG) LSI, LSIG, ALSI, ALSIG 15 15 Cause of trip indication Yes (via TRIP-LED or DIGIVIEW) 20 20 Thru-cover accessories No 24 24 Position 1 2x Position 2 3x Position 3 4x Position 4 5x Position 5 6x Position 6 7x Position 7 8x Position 8 8x Position 9 8x tsd (LS and LSG) Fixed 67 @10x 2 tsd = short delay time flat (milliseconds) (LSI, LSIG, ALSI, ALSIG) Position 1 Inst Position 2 120 2 tr = long delay time (seconds) (All 310+) Isd (x Ir) = short delay pickup (All 310+) = short delay time I2t (milliseconds) 2 2 2 2 2 2 2 2 2 2 2 Position 3 300 Position 1 120 Position 2 180 Position 3 240 Position 4 360 Position 5 480 Position 6 600 tg = ground fault delay time (milliseconds) (LSG, LSIG, ALSIG) Position 1 Inst Position 2 120 Position 3 300 2 Independently adjustable Instantaneous (Ii) setting 2 Maintenance Mode pickup (2.5 x In) (amperes) (310+ with Maintenance Mode—ALSI and ALSIG) Fixed 1500 2 Ig (x In) = ground fault pickup (amperes) (LSG, LSIG, ALSIG) 2 2 2 2 Notes 1 B2x suffixes cannot be combined with B2x suffixes. 2 Not available for LD. Independently adjustable Ii setting available in LG, NG, and RG ALSI and ALSIG trip units. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-207 2.3 2 Molded Case Circuit Breakers Series C Digitrip OPTIM Specifications Trip Unit Type Digitrip OPTIM 550 Digitrip OPTIM 1050 2 rms sensing Yes Yes 2 Frame L L 2 Ampere range 200–600 A 200–600 A Interrupting rating at 480 volts 35, 65, 100 (kA) 35, 65, 100 (kA) 2 Protection LSI, LSI(A), LSIG LSI(A), LSIG 2 Breaker Type Ordering options Fixed rated plug (In) Yes Yes 2 Overtemperature trip Yes Yes 2 Adjustable rating plug (In) No No Long delay pickup 0.4–1.0 x (In) 0.4–1.0 x (In) 2 Long delay time I2t 2–24 seconds 2–24 seconds 2 Long delay time I4t 1–5 seconds 1–5 seconds Long delay thermal memory Yes Yes High load alarm 0.5–1.0 x Ir 0.5–1.0 x Ir Long Delay Protection (L) 2 Short Delay Protection (S) 2 Short delay pickup 150–800% x (Ir) 150–800% x (Ir) Short delay time I2t 100–500 ms 100–500 ms Short delay time flat 100–500 ms 100–500 ms Short delay time zone selective interlocking Yes 1 Yes 200–800% x (In) 200–800% x (In) 2 2 2 2 Instantaneous Protection (I) Instantaneous pickup Discriminator Yes Yes Instantaneous override Yes Yes Ground Fault Protection (G) 2 Ground fault alarm 20–100% x (Is) 20–100% x (Is) 2 Ground fault pickup 20–100% x (Is) 20–100% x (Is) Ground fault delay I2t 100–500 ms 100–500 ms 2 Ground fault delay flat 100–500 ms 100–500 ms Ground fault zone selective interlocking Yes 1 Yes 2 Ground fault thermal memory Yes Yes 2 Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting 2 2 Note Zone interlock kit. 1 2 2 2 2 2 2 2 V4-T2-208 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Digitrip OPTIM Specifications, continued Trip Unit Type Digitrip OPTIM 550 Digitrip OPTIM 1050 Status LEDs Yes Yes Cause of trip LEDs Yes Yes Magnitude of trip information Yes Yes Remote signal contact—ground alarm Yes 1 Yes Local auxiliary and bell alarm contact Optional Included Digital display Yes 2 Yes 2 Current Yes Yes 2 2 System Diagnostics 2 2 2 System Monitoring Power and energy No Yes Power quality—harmonics No Yes Power factor No Yes Yes 3 Yes OPTIMizer, BIM, PowerNet OPTIMizer, BIM, PowerNet 2 2 2 2 Communications PowerNet 2 Testing Testing method 2 Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting 2 2 Notes 1 Zone interlock kit. 2 By OPTIMizer/BIM. 3 Eaton’s PowerNet kit. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-209 2.3 2 2 Molded Case Circuit Breakers Series C Dimensions and Weights Dimensions in Inches (mm) LD Frame 2 Number of Poles Width Height Depth 2, 3 8.25 (209.6) 10.75 (273.1) 4.06 (103.1) 2 4 11.00 (279.4) 10.75 (273.1) 4.06 (103.1) 2 LD-Frame, Two- and Three-Pole 2 Side View 2 3.81 (96.8) CL Handle 2 CL Breaker 3.44 (87.3) 1.72 (43.7) 2 2 Front View Front Cover Cutout 2 3.28 (83.3) 0.25 (6.4) R 2 1.33 (33.7)2.29 (58.2) 10.75 (273.1) 1.50 (38.1) 3.64 (92.5) 2 8.21 (208.6) 0.19 R (4.8) R 7.28 (184.9) 2 2 8.25 (209.6) 2 2 Approximate Shipping Weight, Lbs (kg) 2 LD Frame 2 Breaker Type 2 LD, HLD, LDC 18 (8.2) 20 (9.1) 25 (11.3) 14 (6.4) 15 (6.8) 20 (9.1) 3 (1.4) 4 (1.8) 5 (2.3) LDB 18 (8.2) 20 (9.1) 25 (11.3) — — — — — — 2 Complete Breaker Two-Pole Three-Pole Frame Only Four-Pole Two-Pole Trip Unit Three-Pole 2 2 2 2 2 2 2 2 2 V4-T2-210 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Four-Pole Two-Pole Three-Pole Four-Pole Molded Case Circuit Breakers Series C 2.3 Contents Typical M-Frame Circuit Breaker Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-212 V4-T2-213 V4-T2-218 V4-T2-219 V4-T2-221 V4-T2-256 V4-T2-222 V4-T2-237 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 2 M-Frame (300–800 Amperes) Product Description ● ● ● All Eaton M-Frame circuit breakers are HACR rated MDL-Frame circuit breakers are available as individual components (frame, trip unit, terminals), or factory assembled complete breakers MDLB, HMDLB-Frame circuit breakers with noninterchangeable trip units are suitable for reverse feed use 2 Standards and Certifications ● CE marked 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-211 2.3 2 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. MDL Frame with Thermal-Magnetic Trip Unit Technology Thermal-Magnetic Breakers and Frame 1 2 MDL 3 800 F 2 Circuit Breaker/ Frame Type MDL, MDLB HMDL, HMDLB 2 2 Number of Poles 2 = Two-pole 3 = Three-pole 2 2 Trip Unit Type MT Number of Poles 2 = Two-pole 3 = Three-pole 2 2 2 2 Suffix Frame only (800 A only) High magnetic molded case switch 50 °C (thermal-magnetic trip units only) Without terminals Load side terminals only Line side terminals only Trip Unit Rating/ Plug Ampere Rating 500 300 1 600 350 1 700 400 800 450 T V Suffix = Thermal-magnetic = 50 °C (thermal-magnetic trip units only) MDL Frame with 310+ Electronic Trip Unit Technology 310+ Circuit Breaker 2 2 = = = = = = MT 3 800 T 2 2 F K V W X Y Thermal-Magnetic Trip Unit 1 2 2 Circuit Breaker/ Frame Ampere Rating 500 300 1 600 350 1 700 400 800 450 MDLB 3 800 F T36 B21 W Performance at 480 Vac MDLB = 50 kAIC HMDLB = 65 kAIC CMDLB = 50 kAIC, 100% rated CHMDLB = 65 kAIC, 100% rated Number of Poles 3 = Three-pole Terminals W = No terminals Amperes 800 2 2 Designation F T33 T32 T35 T36 T38 T39 = = = = = = Trip Unit 310+ Electronic LS 310+ Electronic LSI 310+ Electronic LSG 310+ Electronic LSIG 310+ Electronic LSI with Maintenance Mode 310+ Electronic LSIG with Maintenance Mode Blank = B20 = B21 = B22 = ZG = Features No feature High load alarm Ground fault alarm, with trip Ground fault alarm, no trip Zone selective interlocking Blank = B20 = B21 = B22 = ZG = Features No feature High load alarm Ground fault alarm, with trip Ground fault alarm, no trip Zone selective interlocking 2 2 310+ Electronic Trip Unit 1 MES 3 800 ALSIG B21 2 2 2 Trip Unit Type MES 2 2 2 2 Number of Poles 3 = Three-pole Amperes 800 LS = LSI = LSG = LSIG = ALSI = ALSIG = Trip Unit 310+ Electronic LS 310+ Electronic LSI 310+ Electronic LSG 310+ Electronic LSIG 310+ Electronic LSI with Maintenance Mode 310+ Electronic LSIG with Maintenance Mode Note 1 Frames are the same for thermal-magnetic or 310+ electronic trip units, e.g., MDL3800F, HMDL3800F, etc. V4-T2-212 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Product Selection 2 Types MDL and HMDL Thermal-Magnetic Circuit Breakers with Interchangeable Trip Units—Two-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 2 Thermal-Magnetic Trip Unit Only For Use with Standard or High or Ultra High Interrupting Frames 2 2 Standard Terminals Only 1 2 Frame Only Magnetic Trip Range is 5–10 Up Through 600 A; 4–8 on 700 and 800 A x Continuous Ampere Rating See Page V4-T2-217 for Optional Terminals Catalog Number Catalog Number Catalog Number Catalog Number 2 HMDL2300 HMDL2800F MT2300T TA700MA1 HMDL2350 MT2350T TA700MA1 2 MDL2400 HMDL2400 MT2400T TA700MA1 MDL2450 HMDL2450 MT2450T TA700MA1 500 MDL2500 HMDL2500 MT2500T TA700MA1 600 MDL2600 HMDL2600 MT2600T TA700MA1 700 MDL2700 HMDL2700 MT2700T TA700MA1 800 MDL2800 HMDL2800 MT2800T TA800MA2 Maximum Continuous Ampere Rating at 40 °C Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Frame Only Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Catalog Number Catalog Number 300 MDL2300 MDL2800F 350 MDL2350 400 450 2 2 2 2 2 Types MDL and HMDL Thermal-Magnetic Circuit Breakers with Interchangeable Trip Units—Three-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 2 Thermal-Magnetic Trip Unit Only For Use with Standard or High or Ultra High Interrupting Frames 2 Frame Only Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Frame Only Catalog Number Catalog Number Catalog Number Catalog Number Catalog Number MDL3800F HMDL3300 HMDL3800F MT3300T TA700MA1 HMDL3350 MT3400T TA700MA1 HMDL3400 MT3400T TA700MA1 MDL3450 HMDL3450 MT3450T TA700MA1 500 MDL3500 HMDL3500 MT3500T TA700MA1 600 MDL3600 HMDL3600 MT3600T TA700MA1 700 MDL3700 HMDL3700 MT3700T TA700MA1 800 MDL3800 HMDL3800 MT3800T TA800MA2 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Catalog Number 300 MDL3300 350 MDL3350 400 MDL3400 450 2 Standard Terminals Only 1 Magnetic Trip Range is 5–10 Up Through 600 A; 4–8 on 700 and 800 A x Continuous Ampere Rating Maximum Continuous Ampere Rating at 40 °C 2 See Page V4-T2-217 for Optional Terminals 2 2 2 2 2 2 2 2 Note 1 Two terminals are required per pole. 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-213 2.3 2 Molded Case Circuit Breakers Series C Types MDLB and HMDLB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units—Two-Pole 1 Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Standard Terminals Only 2 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals See Page V4-T2-217 for Optional Terminals Catalog Number Catalog Number Catalog Number 300 MDLB2300 HMDLB2300 TA700MA1 2 350 MDLB2350 HMDLB2350 TA700MA1 400 MDLB2400 HMDLB2400 TA700MA1 2 450 MDLB2450 HMDLB2450 TA700MA1 500 MDLB2500 HMDLB2500 TA700MA1 2 600 MDLB2600 HMDLB2600 TA700MA1 2 700 MDLB2700 HMDLB2700 TA700MA1 800 MDLB2800 HMDLB2800 TA800MA2 2 2 2 2 2 2 2 Maximum Continuous Ampere Rating at 40 °C Types MDLB and HMDLB Thermal-Magnetic Circuit Breakers with Non-Interchangeable Trip Units—Three-Pole 1 Maximum Continuous Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Standard Terminals Only 2 Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals Factory Assembled Circuit Consisting of Frame, Trip Unit and Terminals See Page V4-T2-217 for Optional Terminals Catalog Number Catalog Number Catalog Number 2 300 MDLB3300 HMDLB3300 TA700MA1 2 350 MDLB3350 HMDLB3350 TA700MA1 400 MDLB3400 HMDLB3400 TA700MA1 2 450 MDLB3450 HMDLB3450 TA700MA1 500 MDLB3500 HMDLB3500 TA700MA1 2 600 MDLB3600 HMDLB3600 TA700MA1 700 MDLB3700 HMDLB3700 TA700MA1 2 800 MDLB3800 HMDLB3800 TA800MA2 2 Notes 1 Factory sealed for reverse feed application. 2 Two terminals are required per pole. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-214 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Types MDL and HMDL Electronic Circuit Breakers with Interchangeable Trip Units Order as Individual Components: breaker frame, trip unit and terminals. See 310+ adjustability specifications on Page V4-T2-220. 2 2 Types MDL and HMDL Electronic Circuit Breakers with Interchangeable 310+ Trip Units—Three-Pole Circuit Breaker Frame Only 2 Digitrip RMS 310+ Trip Unit Only 1 Standard LS Maximum Continuous Ampere Rating at 40 °C Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac High Interrupting Capacity 600 Vac Adjustable Short Rated 65 kAIC at Time Pickup with I2t Short Delay Ramp 480 Vac Catalog Number Catalog Number Catalog Number 800 MDL3800F HMDL3800F MES3800LS Optional LSI LSG LSIG Independently Adjustable Short Time Pickup and Delay Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Ground Fault Protection 2 2 Neutral CT for LSG and LSIG 23 Catalog Number MES3800LSI MES3800LSG MES3800LSIG Types MDLB and HMDLB Electronic Circuit Breakers with Non-Interchangeable 310+ Trip Units LGFCT600 Terminal Information See Page V4-T2-218 LS LSI LSG Adjustable Short Time Pickup Independently Adjustable Short Time Pickup and Delay with I2t Short Delay Ramp Adjustable Short Time Pickup Independently Adjustable with I2t Short Delay and Short Time Pickup and Ground Neutral CT for Ground Fault Protection Fault Protection LSG and LSIG 23 Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac MDLB3800FT33W MDLB3800FT32W HMDLB3800FT33W HMDLB3800FT32W LGFCT600 2 HMDLB3800FT35W HMDLB3800FT36W LGFCT600 2 100% Rated Types CMDL and CHMDL Electronic Circuit Breakers with Interchangeable 310+ Trip Units—Three-Pole Maximum Continuous Ampere Rating at 40 °C 800 Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac Options LSI Independently Adjustable Short Adjustable Short 2 Time Pickup with I t Time Pickup and Short Delay Ramp Delay LSG LSIG Adjustable Short Time Pickup with I2t Short Delay and Ground Fault Protection Independently Adjustable Short Time Pickup and Ground Fault Protection Catalog Number CMDL3800F CHMDL3800F MES3800LS MES3800LSI MES3800LSG MES3800LSIG 2 2 2 2 Digitrip RMS 310+ Trip Unit Only 1 Standard LS 2 MDLB3800FT36W 100% Rated Types CMDL and CHMDL Electronic Circuit Breakers with Interchangeable Trip Units The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at the 75 °C ampacity. All 100% rated circuit breakers have electronic trip units. Order as individual components: breaker frame, trip unit and terminals. See 310+ adjustability specifications on Page V4-T2-220. Circuit Breaker Frame Only 2 MDLB3800FT35W Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 800 2 2 LSIG Catalog Number 800 2 2 4 Factory-Assembled Circuit Breaker Consisting of Frame and Trip Unit Less Terminals Maximum Continuous Ampere Rating at 40 °C 2 2 2 Neutral CT for LSG and LSIG 23 Catalog Number Terminal Information LGFCT600 See Page V4-T2-218 2 2 2 Notes 1 For AC use only. 2 Required for four-wire systems if neutral protection is desired. 3 Included with LSG and LSIG trip units or breakers. 4 Factory sealed, suitable for reverse feed application. CMDLB and CHMDLB are also available. 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-215 2.3 2 2 2 2 2 2 2 2 2 2 2 2 Series C Molded Case Switches Eaton’s molded case switches are used as compact switches in applications requiring high current switching capabilities. Molded case switches are constructed of circuit breaker components and are of the high instantaneous automatic type. Molded case switches are listed in accordance with Underwriters Laboratories Standard UL 489. Molded Case Switches 600 Vac Maximum, 250 Vdc Maximum Continuous Ampere Rating at 40 °C Circuit Breaker Only without Line and Load Terminals Catalog Number Two-Pole 800 2 2 Molded Case Circuit Breakers MDL2800WK MDLB2800WK 1 HMDL2800WK Three-Pole 800 MDL3800WK MDLB3800WK 1 HMDL3800WK Notes 1 MDLB and HMDLB are suitable for reverse feed applications. Molded case switch may trip above 6000 amperes. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-216 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Accessories Selection Guide and Ordering Information 2 Line and Load Terminals M-Frame circuit breakers use Cu/AI terminals as standard. When optional copper or Cu/ AI terminals are required, order by catalog number. Specify if factory installation is required. 2 2 2 2 2 2 2 2 TA700MA1 TA800MA2 TA801MA 2 2 Line and Load Terminals Maximum Breaker Amperes Terminal Body Material Wire Type AWG Wire Range/No. Conductors Terminal Terminals with Control Wire Termination Catalog Number Catalog Number TA700MA1CWT 2 2 Standard Cu/AI Pressure Terminals 700 Aluminum Cu/AI 1–500 kcmil (2) TA700MA1 800 std. Aluminum Cu/AI 3/0–400 kcmil (3) TA800MA2 TA800MA2CWT 800 Aluminum Cu/AI 500–750 kcmil (2) TA801MA TA801MACWT 2 2 2 Optional Copper and Cu/AI Pressure Type Terminals 600 Copper Cu 2/0–500 kcmil (2) T600MA1 — 800 Copper Cu 3/0–300 kcmil (3) T800MA1 — 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-217 2.3 Molded Case Circuit Breakers Series C 2 Accessories 2 Allowable Accessory Combinations Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 2 MD Frame Accessories Two-Pole 1 Three-Pole Reference Page Left Right Left Alarm lockout (Make/Break) V4-T2-276 ■ ■ ■ ■ Alarm lockout (2Make/2Break) V4-T2-276 ■ ■ ■ ■ 2 Auxiliary switch (1A, 1B) V4-T2-278 ■ ■ ■ ■ 2 Auxiliary switch (2A, 2B) V4-T2-278 ■ ■ ■ ■ Auxiliary switch (3A, 3B) V4-T2-278 ■ ■ ■ ■ Auxiliary switch (1A, 1B) and alarm switch combination V4-T2-280 ■ ■ ■ ■ Auxiliary switch (2A, 2B) and alarm switch combination V4-T2-280 ■ ■ ■ ■ 2 Shunt trip—standard 2 V4-T2-283 ■ ■ ■ ■ 2 Shunt trip—low energy 2 V4-T2-285 ■ ■ ■ ■ Undervoltage release mechanism 2 V4-T2-291 ■ ■ ■ ■ Rear fed terminals V4-T2-310 ● ● ● 2 Base mounting hardware V4-T2-311 ● 2 Terminal shields V4-T2-313 ● Interphase barriers V4-T2-313 ● Non-padlockable handle block V4-T2-314 Padlockable handle lock hasp V4-T2-315 ❏ ❏ 2 Key interlock kit V4-T2-316 ❏ ❏ 2 Sliding bar interlock—requires two breakers V4-T2-317 ● ● ● ● ● Walking beam interlock—requires two breakers V4-T2-317 ● ● ● ● ● Electrical (motor) operator V4-T2-318 ● ● ● ● ● Plug-in adapters V4-T2-320 ● ● ● ● ● 2 Rear connecting studs V4-T2-321 ● ● ● ● ● 2 Panelboard connecting straps V4-T2-322 ● ● ● ● ● Handle mechanisms V4-T2-430 ● ● ● ● ● Handle extension V4-T2-445 ● ● ● ● ● Solid-state (electronic) portable test kit V4-T2-324 ● ● ● ● ● 2 2 2 2 2 2 2 Description Center Right Internal Accessories (Only One Internal Accessory Per Pole) External Accessories ● ● ■ ❏ ❏ 2 Modifications (Refer to Eaton) 2 Special calibration — ● ● ● ● ● Moisture fungus treatment V4-T2-116 ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● Marine/naval application — ● ● ● ● ● 2 2 2 2 2 Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available Notes Two-pole breaker supplied in three-pole frame. Current carrying parts omitted from center pole. 2 Shunt trip and UVR cannot be mounted in right poles on MES trip units. 1 2 2 V4-T2-218 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 310+ Electronic Trip Unit Accessories Description Catalog Number Electronic portable test kit MTST230V 1 Trip unit tamper protection wire seal 5108A03H01 External neutral sensor LGFCT600 2 Breaker-mount cause-of-trip indication TRIP-LED Breaker-mount ammeter module DIGIVIEW Remote-mount ammeter module DIGIVIEWR06 3 2 2 2 2 2 2 2 Technical Data and Specifications UL 489/CSA Interrupting Capacity Ratings 4 2 Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles 240 480 600 250 MDL, MDLB 2, 3 65 50 25 22 CMDL 2, 3 65 50 25 — 2 Volts DC 56 Volts AC (50/60 Hz) HMDL, HMDLB 2, 3 100 65 35 25 CHMDL 2, 3 100 65 35 — 2 2 2 IEC 947-2 Interrupting Capacity Ratings 4 2 Interrupting Capacity rms (kA Symmetrical Amperes) I CU ≠ I CS Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 415 690 MDL, MDLB 2, 3 65/65 50/50 20/10 20/10 CMDL 2, 3 65/65 50/50 20/10 — HMDL, HMDLB 2, 3 100/100 70/50 25/13 20/10 CHMDL 2, 3 100/100 70/50 25/13 — Volts DC 56 2 250 2 2 2 Notes 1 MTST230V applies to 100–230 Vac. 2 Included with all LD LSG and LSIG trip units and breakers. 3 Includes 6 ft cable for remote mounting; NEMA 3R rated. 4 Utilization Category A circuit breakers. 5 Two-pole or two poles of three-pole circuit breaker. Thermal-magnetic trip units only, MDL, HMDL breakers with electronic trip unit are not DC rated. 6 Time constant is 3 milliseconds minimum at 10 kA and 8 milliseconds at 22 kA. 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-219 2.3 2 2 2 2 2 2 Molded Case Circuit Breakers Series C 310+ Specifications Description 310+ Adjustability Specifications MDL Frame Specification Specification Trip Unit Type Digitrip RMS 310+ Description 310+ settings Breaker Type Frame designation MDL Frames available 800 A Continuous current range (A) Ground fault pickup (A) Ir = continuous current or long delay pickup (amperes) (All 310+) 320–800 A 160–800 A Interrupting capacities at 480 Vac (kAIC) 100% rated 50, 65 Yes 800 A Ir A 320 B 400 C 450 D 500 E 600 F 630 2 Protection 2 Arcflash Reduction Maintenance System (or Maintenance Mode) Remote enabled on ALSI, ALSIG 2 Interchangeable trip unit Yes High load alarm (suffix B20) 1 Yes 7 7 2 Ground fault alarm with trip (suffix B21) 1 LSG, LSIG, ALSIG 10 10 Ground fault alarm, no trip (suffix B22) 1 LSG, LSIG, ALSIG 12 12 Zone selective interlocking (suffix ZG) LSI, LSIG, ALSI, ALSIG 15 15 Cause of trip indication Yes (via TRIP-LED or DIGIVIEW) 20 20 Thru-cover accessories No 24 24 Position 1 2x Position 2 3x 2 Position 3 4x 2 Position 4 5x Position 5 6x 2 Position 6 7x Position 7 8x 2 Position 8 8x 2 2 Ordering options 2 LS, LSI, LSG, LSIG, ALSI, ALSIG tr = long delay time (seconds) (All 310+) Isd (x Ir) = short delay pickup (All 310+) G 700 H (= In) 800 2 2 4 4 Position 9 8x 2 tsd = short delay time I2t (milliseconds) (LS and LSG) Fixed 67 @10x 2 tsd = short delay time flat (milliseconds) (LSI, LSIG, ALSI, ALSIG) Position 1 Inst Position 2 120 Position 3 300 Position 1 160 Position 2 240 Position 3 320 Position 4 480 Position 5 640 2 Ig (x In) = ground fault pickup (amperes) (310+ w/ ground fault) 2 2 2 2 2 2 2 Position 6 800 tg = ground fault delay time (milliseconds) (LSG, LSIG, ALSIG) Position 1 Inst Position 2 120 Position 3 300 Independently adjustable Instantaneous (Ii) setting 2 Maintenance Mode pickup (2.5 x In) (amperes) (310+ with Maintenance Mode—ALSI and ALSIG) Fixed 2000 Notes 1 B2x suffixes cannot be combined with B2x suffixes. 2 Not available for MDL. Independently adjustable Ii setting available in LG, NG, and RG ALSI and ALSIG trip units. 2 2 2 V4-T2-220 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Dimensions and Weights 2 Dimensions in Inches (mm) 2 MD Frame Number of Poles Width Height Depth 2, 3 8.25 (209.6) 16.00 (406.4) 4.06 (103.1) 2 2 MDL-Frame, Two- and Three-Pole Drilling Plan Front View 2 Side View 2 3.44 (87.3) 1.72 (43.7) 2 2 R 0.25 (6.4) CL Breaker 2 R 0.19 (4.8) CL Handle 1.33 (33.7) 1.50 (38.1) 2 16.00 (406.4) 3.28 (83.3) 2 2 0.97 (24.6) 2 3.64 (92.5) 7.28 (184.9) 2 4.06 (103.2) 8.25 (209.6) 2 2 Approximate Shipping Weight, Lbs (kg) 2 MD Frame 2 Trip Unit 1 Complete Breaker Frame Only Breaker Type Two-Pole Three-Pole Two-Pole MDL, HMDL (T/M T.U.) 26.5 (12.0) 29.0 (13.2) 24.5 (11.1) 26.0 (11.8) 2.5 (1.1) 3.0 (1.4) MDL, HMDL (Elec. T.U.) — 30.0 (13.6) — 26.0 (11.8) — 4.0 (1.8) Three-Pole Two-Pole Three-Pole 2 2 Note 1 Thermal-magnetic only. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-221 2.3 2 Molded Case Circuit Breakers Series C Typical N-Frame Breaker Contents Description 2 Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes). . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes). . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) Catalog Number Selection. . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . 2 2 2 2 2 2 2 2 2 2 2 2 N-Frame (400–1200 Amperes) 2 Product Description ● 2 2 ● All Eaton N-Frame circuit breakers are suitable for reverse feed use All N-Frame circuit breakers are HACR rated 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-222 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-223 V4-T2-224 V4-T2-232 V4-T2-233 V4-T2-236 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 Molded Case Circuit Breakers Series C 2.3 Catalog Number Selection 2 This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. 2 2 Circuit Breaker/Frame ND 3 12 T3 2 W Circuit Breaker/ Frame Type ND HND NDC NDU CND CHND CNDC Number of Poles 2 = Two-pole 3 = Three-pole 4 = Four-pole Circuit Breaker/Frame Ampere Rating 800 = 800 amperes 12 = 1200 amperes T3 T5 T7 T10 Trip Model = Model 310 = Model 550 = Model 750 = Model 1050 2 Trip Type 2 = LSI 3 = LS 5 = LSG 6 = LSIG 7 = LSIA E EH K W X Y = = = = = = 2 Suffix 100% R.P. protected (four-pole) 50% R.P. protected (four-pole) High magnetic molded case switch Without terminals Load only terminals Line only terminals 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-223 2.3 Molded Case Circuit Breakers Series C 2 Product Selection 2 Digitrip OPTIM Electronic Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit), rating plug, terminals. 2 2 Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only L S I G A 2 2 2 Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) OPTIM 550 2 Fixed Rating Plug LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number ND3800T57W 400 ORPN80A400 450 ORPN80A450 500 ORPN80A500 2 550 ORPN80A550 2 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 2 700 ORPN12A700 800 ORPN12A800 2 1000 ORPN12A100 1200 ORPN12A120 400 ORPN80A400 450 ORPN80A450 2 500 ORPN80A500 2 550 ORPN80A550 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 2 800 ORPN12A800 2 1000 ORPN12A100 1200 ORPN12A120 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac 800 ND3800T52W ND3800T56W 2 2 2 2 1200 ND312T52W ND312T56W ND312T57W Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 800 HND3800T52W HND3800T56W HND3800T57W 2 2 2 2 1200 HND312T52W HND312T56W HND312T57W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 V4-T2-224 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Digitrip OPTIM 550 Electronic Circuit Breakers with Interchangeable Rating Plugs, continued Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 Fixed Rating Plug 2 Ampere Rating Catalog Number 2 400 ORPN80A400 450 ORPN80A450 500 ORPN80A500 550 ORPN80A550 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number NDC3800T57W Three-Pole Ultra High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 800 1200 NDC3800T52W NDC312T52W NDC3800T56W NDC312T56W NDC312T57W 2 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-225 2.3 2 Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only L– Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 S– Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) I– Adjustable Instantaneous Pickup G– Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) A– Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) 2 2 Series C Digitrip OPTIM 1050 Electronic Circuit Breakers with Interchangeable Rating Plugs 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 400 ORPN80A400 2 450 ORPN80A450 2 500 ORPN80A500 550 ORPN80A550 2 600 ORPN80A600 700 ORPN80A700 2 800 ORPN80A800 600 ORPN12A600 2 700 ORPN12A700 2 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 400 ORPN80A400 450 ORPN80A450 500 ORPN80A500 2 550 ORPN80A550 600 ORPN80A600 2 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 400 ORPN80A400 2 450 ORPN80A450 2 500 ORPN80A500 550 ORPN80A550 2 600 ORPN80A600 700 ORPN80A700 2 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 2 800 ORPN12A800 1000 ORPN12A100 2 1200 ORPN12A120 2 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac 800 1200 ND3800T106W ND312T106W ND3800T107W ND312T107W Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 800 HND3800T106W HND3800T107W 2 2 1200 HND312T106W HND312T107W 2 2 2 Three-Pole Ultra High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 800 1200 NDC3800T106W NDC312T106W NDC3800T107W NDC312T107W 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch and one Form C bell (trip) alarm switch supplied with breaker as standard. 3 Factory sealed. V4-T2-226 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 100% Rated Digitrip OPTIM Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit), rating plug, terminals. 2 2 100% Rated Digitrip OPTIM 550 Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) 2 L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 Fixed Rating Plug 2 Ampere Rating Catalog Number 2 400 ORPN80A400 450 ORPN80A450 500 ORPN80A500 550 ORPN80A550 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 2 400 ORPN80A400 450 ORPN80A450 2 500 ORPN80A500 550 ORPN80A550 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 OPTIM 550 2 LSI LSIG LSIA Catalog Number Catalog Number Catalog Number CND3800T57W Three-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac 800 1200 3 CND3800T52W CND312T52W CND3800T56W CND312T56W CND312T57W Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 800 1200 3 CHND3800T52W CHND312T52W CHND3800T56W CHND312T56W CHND3800T57W CHND312T57W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 3 Includes conductor extension kit, which increases breaker length 3.75 on each end. Terminal ordered separate. 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-227 2.3 2 Series C 100% Rated Digitrip OPTIM 550 Circuit Breakers with Interchangeable Rating Plugs, continued Circuit Breaker Frame Only 2 L S I G A 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) OPTIM 550 2 Fixed Rating Plug LSI LSIG LSIA Catalog Number Catalog Number Catalog Number Ampere Rating Catalog Number CNDC3800T57W 400 ORPN80A400 2 450 ORPN80A450 2 500 ORPN80A500 550 ORPN80A550 2 600 ORPN80A600 700 ORPN80A700 2 800 ORPN80A800 600 ORPN12A600 2 700 ORPN12A700 2 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 2 2 2 2 2 Three-Pole Ultra High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 800 1200 3 CNDC3800T52W CNDC312T52W CNDC3800T56W CNDC312T56W CNDC312T57W Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 Zone interlocking, PowerNet, or both features can be added at the factory by adding suffixes ZG, PN or ZGP respectively to above catalog number. 3 Includes conductor extension kit, which increases breaker length 3.75 on each end. Terminal ordered separate. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-228 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 100% Rated Digitrip OPTIM 1050 Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Digitrip OPTIM Rating Plug Only L S I – Adjustable Instantaneous Pickup G – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) A – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) Maximum Continuous Ampere Rating at 40 °C 2 Fixed Rating Plug 2 Ampere Rating Catalog Number 2 400 ORPN80A400 450 ORPN80A450 500 ORPN80A500 550 ORPN80A550 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 2 400 ORPN80A400 450 ORPN80A450 2 550 ORPN80A550 600 ORPN80A600 700 ORPN80A700 800 ORPN80A800 600 ORPN12A600 700 ORPN12A700 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 50 kAIC at 480 Vac 800 1200 CND3800T106W CND312T106W CND3800T107W CND312T107W Three-Pole High Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 800 1200 CHND3800T106W CHND312T106W CHND3800T107W CHND312T107W 2 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch one Form C bell (trip) alarm switch supplied with breaker as standard. 3 Factory sealed. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-229 2.3 2 Circuit Breaker Frame Only L S I G A 2 2 Series C 100% Rated Digitrip OPTIM 1050 Circuit Breakers with Interchangeable Rating Plugs, continued 2 2 Molded Case Circuit Breakers Maximum Continuous Ampere Rating at 40 °C Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time (I2t or I4t Response) 1 – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) OPTIM 1050 23 LSIG LSIA Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 400 ORPN80A400 2 450 ORPN80A450 2 500 ORPN80A500 550 ORPN80A550 2 600 ORPN80A600 700 ORPN80A700 2 800 ORPN80A800 600 ORPN12A600 2 700 ORPN12A700 2 800 ORPN12A800 1000 ORPN12A100 1200 ORPN12A120 2 2 2 2 Three-Pole Ultra High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 800 1200 CNDC3800T106W CNDC3800T107W CNDC312T106W 4 CNDC312T107W Type ND Molded Case Switches Type ND High Instantaneous (K) Continuous Ampere Rating at 40 °C Three-Pole Four-Pole 5 Catalog Number Catalog Number 2 800 ND3800WK ND4800WK 2 1200 2 2 HND3800WK HND4800WK ND312WK ND412WK HND312WK HND412WK 2 Notes 1 Long delay I4t response selection limits short delay time to flat response. 2 One Form C auxiliary switch one Form C bell (trip) alarm switch supplied with breaker as standard. 3 Factory sealed. 4 Includes conductor extension kit, which increases breaker length 3.75 on each end. Terminal ordered separate. 5 Neutral is in right pole. 2 Molded case switch will trip above 14,000 amperes. For UL listed, series tested molded case switch application data, refer to Eaton. 2 2 2 2 2 2 2 2 2 V4-T2-230 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Accessories Selection Guide and Ordering Information 2 Line and Load Terminals—Ordering Information N-Frame circuit breakers use Cu/AI terminals as standard. When optional copper or Cu/AI terminals are required, order by catalog number. Specify if factory installation is required. 2 2 2 2 2 2 2 TA700NB1 TA1000NB1 TA1200NB1 TA1201NB1 T700NB1 2 T1000NB1 2 Line and Load Terminals Maximum Breaker Amperes Terminal Body Material Wire Type AWG Wire Range/ No. Conductors Metric Wire Range mm2 Catalog Number 2 2 Standard Cu/AI Pressure Terminals 700 Aluminum Cu/AI 1–500 kcmil (2) 50–240 TA700NB1 1000 Aluminum Cu/AI 3/0–400 kcmil (3) 95–185 TA1000NB1 1 2 2 1 1200 Aluminum Cu/AI 4/0–500 kcmil (4) 120–240 TA1200NB1 1200 Aluminum Cu/AI 500–750 kcmil (3) 300–400 TA1201NB1 2 2 Optional Copper and Cu/AI Pressure Type Terminals 700 Copper Cu 2/0–500 kcmil (2) 70–240 T700NB1 1000 Copper Cu 3/0–500 kcmil (3) 95–240 T1000NB1 1200 Copper Cu 3/0–400 kcmil (4) 95–185 T1200NB3 2 2 Notes 1 Terminal rating is AL9CU. 2 Terminal rating is AL7CU. 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-231 2.3 Molded Case Circuit Breakers Series C 2 Accessories 2 Allowable Accessory Combinations Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 2 ND Frame Accessories 2 Description Reference Page Internal Accessories (Only One Internal Accessory Per Pole) 1 2 Alarm lockout (Make/Break) V4-T2-276 Alarm lockout (2Make/2Break) V4-T2-276 2 Auxiliary switch (1A, 1B) 2 Three-Pole Left Four-Pole Center Right Left Center Right ■ ■ ■ ■ ■ ■ ■ ■ V4-T2-278 ■ ■ ■ ■ Auxiliary switch (2A, 2B) V4-T2-278 ■ ■ ■ ■ Auxiliary switch (3A, 3B) V4-T2-278 ■ ■ ■ ■ 2 Auxiliary switch (1A, 1B) and alarm switch combination V4-T2-280 ■ ■ ■ ■ Auxiliary switch (2A, 2B) and alarm switch combination V4-T2-280 ■ ■ ■ ■ 2 Shunt trip—standard V4-T2-284 ■ ■ Shunt trip—low energy V4-T2-285 ■ ■ 2 Undervoltage release mechanism V4-T2-292 ■ Eaton PowerNet communications kit (OPTIM 550) V4-T2-293 Neutral ■ ■ 2 External Accessories 2 Base mounting hardware V4-T2-311 ● ● ● ● ● ● ● Interphase barriers V4-T2-313 ● ● ● ● ● ● ● 2 Terminal shield V4-T2-313 ■ ■ ■ Non-padlockable handle block V4-T2-314 2 Padlockable handle lock hasp V4-T2-315 ❏ ❏ ❏ ❏ Key interlock kit V4-T2-316 ❏ ❏ ❏ ❏ 2 Sliding bar interlock—requires two breakers V4-T2-317 ● ● ● 2 Walking beam interlock—requires two breakers V4-T2-317 ● ● ● ● ● ● ● Electrical (motor) operator V4-T2-319 ● ● ● ● ● ● ● 2 Plug-in adapters V4-T2-320 ● ● ● ● ● ● ● Rear connecting studs V4-T2-321 ● ● ● ● ● ● ● 2 Panelboard connecting straps V4-T2-322 ● ● ● ● ● ● ● Handle mechanisms V4-T2-430 ● ● ● ● ● ● ● 2 Handle extension V4-T2-445 ● ● ● ● ● ● ● 2 Solid-state (electronic) portable test kit V4-T2-325 ● ● ● ● ● ● ● OPTIM System Components Three Poles ■ ■ 2 Ground fault alarm unit V4-T2-324 Potential transformer module V4-T2-324 2 Breaker interface module (BIM) V4-T2-325 Digitrip OPTIMizer V4-T2-325 2 Auxiliary power module V4-T2-325 2 Special calibration — ● ● ● ● ● ● ● 2 Moisture fungus treatment V4-T2-116 ● ● ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● ● ● Marine/naval application — ● ● ● ● ● ● ● 2 2 2 2 Modifications (Refer to Eaton) Legend ■ Applicable in indicated pole position ❏ May be mounted on left or right pole—not both ● Accessory available/modification available Note OPTIM 550 and 1050 are factory sealed and do not have the right pole available for accessories. 1 V4-T2-232 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Technical Data and Specifications 2 2 UL 489 Interrupting Capacity Ratings 1 Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 277 480 600 ND 2, 3, 4 65 — 50 25 CND 2 2, 3, 4 65 — 50 25 HND 2, 3, 4 100 — 65 35 CHND 2 2, 3, 4 100 — 65 35 NDC 2, 3, 4 200 — 100 65 2, 3, 4 200 — 100 65 CNDC 2 NDU 3 2 Interrupting Capacity (kA Symmetrical Amperes) 3 300 4 — 150 75 2 2 2 2 2 5 2 IEC 947-2 Interrupting Capacity Ratings 1 Circuit Breaker Type 2 Interrupting Capacity (kA Symmetrical Amperes) Number of Poles Volts AC (50/60 Hz) 240 415 690 2 Icu 2, 3, 4 85 50 20 2 Ics 2, 3, 4 85 50 10 2 Icu 2, 3, 4 85 50 20 Ics 2, 3, 4 85 50 10 2 2, 3, 4 100 70 25 2, 3, 4 100 50 13 2 Icu 2, 3, 4 100 70 25 2 Ics 2, 3, 4 100 50 13 2 Icu 2, 3, 4 200 100 35 2 Ics 2, 3, 4 100 50 18 2 Icu 2, 3, 4 200 100 35 Ics 2, 3, 4 100 50 18 2 ND CND 2 2 HND Icu Ics CHND 2 NDC CNDC 2 2 Notes 1 Utilization Category A circuit breakers. 2 100% rated breakers. 3 800 amperes maximum rating. 4 Successfully tested at 300 kAIC, although UL recognizes maximum of 200 kAIC at 240 Vac. 5 Successfully tested at 75 kAIC, although UL recognizes maximum of 65 kAIC at 600 Vac. 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-233 2.3 2 Molded Case Circuit Breakers Series C N-Frame Digitrip Trip Unit Type Digitrip OPTIM 550 Digitrip OPTIM 1050 2 rms sensing Yes Yes 2 Frame N N 2 Ampere range 400–1200 A 400–1200 A Interrupting rating at 480 volts 50, 65, 100 (kA) 50, 65, 100 (kA) 2 Protection LSI, LSIG, LSI(A) LSI(A), LISG 2 Breaker Type Ordering options Fixed rated plug (In) Yes Yes 2 Overtemperature trip Yes Yes 2 Adjustable rating plug (In) No No Long delay pickup 0.4–1.0 x (In) 0.4–1.0 x (In) 2 Long delay time I2t 2–24 seconds 2–24 seconds Long delay time I4t 1–5 seconds 1–5 seconds Long delay thermal memory Yes Yes 2 High load alarm No 0.5–1.0 x Ir 2 Short delay pickup 150–800% x (Ir) 150–800% x (Ir) Short delay time I2t 100–500 ms 100–500 ms 2 Short delay time flat 100–500 ms 100–500 ms 2 Short delay time zone selective interlocking Yes Yes Instantaneous Protection (I) 200–800% x (In) 200–800% x (In) 2 2 2 Long Delay Protection (L) Short Delay Protection (S) Instantaneous pickup Discriminator Yes Yes Instantaneous override Yes Yes Ground Fault Protection (G) 2 Ground fault alarm 20–100% x (Is) 20–100% x (Is) 2 Ground fault pickup 20–100% x (Is) 20–100% x (Is) Ground fault delay I2t 100–500 ms 100–500 ms 2 Ground fault delay flat 100–500 ms 100–500 ms Ground fault zone selective interlocking Yes 1 Yes 2 Ground fault thermal memory Yes Yes 2 Status LEDs Yes Yes 2 Cause of trip LEDs Yes Yes Magnitude of trip information Yes Yes 2 Remote signal contact—ground alarm Yes 1 Yes Local auxiliary and bell alarm contact Optional Included 2 2 2 2 System Diagnostics Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting Note Zone interlock kit. 1 2 2 2 V4-T2-234 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 N-Frame Digitrip, continued Trip Unit Type Digitrip OPTIM 550 Digitrip OPTIM 1050 Yes 1 Yes 1 2 2 System Monitoring Digital display Current Yes Yes Power and energy No Yes Power quality—harmonics No Yes Power factor No Yes No 2 Yes OPTIMizer, BIM, PowerNet OPTIMizer, BIM, PowerNet 2 2 2 Communications Eaton PowerNet 2 Testing Testing method 2 2 Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting 2 2 Notes 1 By OPTIMizer/BIM. 2 Eaton’s PowerNet kit. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-235 2.3 2 Molded Case Circuit Breakers Series C Dimensions and Weights Approximate Dimensions in Inches (mm) 2 2 2 2 2 ND Frame Number of Poles Width Height Depth 2, 3 4 8.25 (209.6) 16.00 (406.4) 5.50 (139.7) 11.13 (282.6) 16.00 (406.4) 5.50 (139.7) ND-Frame, Two- and Three-Pole Front View 2 2 3.44 (87.3) 2 2 2 2 2 1.72 (43.6) 1.91 (48.4) 0.25 R (6.4 R) CL Handle 2 CL Handle 16.00 (406.4) 0.19 R (4.8 R) 3.68 (93.2) OFF/O 3.19 (80.9) 6.38 (161.9) 8.25 (209.6) 2 2 2 2 ON/I 1.50 (38.1) 2 2 Side View Front Cover Cutout Approximate Shipping Weight in Lbs (kg) ND Frame Complete Breaker Breaker Type Two-Pole Three-Pole Four-Pole ND, HND, NDC, NDU 37 (16.8) 45 (20.4) 58 (26.3) 2 2 2 2 2 2 2 2 2 2 V4-T2-236 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 5.50 (139.7) Molded Case Circuit Breakers Series C Typical R-Frame Breaker 2.3 Contents Description Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) Catalog Number Selection . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-238 V4-T2-239 V4-T2-251 V4-T2-252 V4-T2-255 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 R-Frame (800–2500 Amperes) 2 Product Description 2 ● ● Eaton R-Frame circuit breakers are available as frame (which includes trip unit), rating plug and terminals All R-Frame circuit breakers are suitable for reverse feed use 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-237 2.3 2 2 2 Molded Case Circuit Breakers Series C Catalog Number Selection This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. Circuit Breaker/Frame 2 2 2 2 RD 3 16 T53 W Circuit Breaker/ Frame Type RD RDC CRD 2 CRDC 2 2 2 2 Number of Poles 3 = Three-pole 4 = Four-pole Circuit Breaker/Frame Ampere Rating 16 = 1600 amperes 20 = 2000 amperes 25 = 2500 amperes T53 T65 T86 T96 T106 T107 Trip Type 1 = Digitrip RMS 510 LS = Digitrip RMS 610 LSG = Digitrip RMS 810 LSIG = Digitrip RMS 910 LSIG = Digitrip OPTIM 1050 LSIG = Digitrip OPTIM 1050 LSIA Notes 1 For complete list of available trip types, refer to Pages V4-T2-239 to V4-T2-248. 2 No four-pole for CRD and CRDC. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-238 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com W P R K = = = = Suffix Without terminals 100% protected neutral pole Ground fault remote (310 only) Molded case switch Molded Case Circuit Breakers Series C 2.3 Product Selection 2 Digitrip RMS 510 Electronic Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit) and rating plug. 2 2 Digitrip RMS 510 Electronic Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) LI LS LSI LIG LSG 2 LSIG Catalog Number Rated Current (In) Fixed Rating Plug 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 2000 2500 RD316T51W RD320T51W RD325T51W RD316T53W RD320T53W RD325T53W RD316T52W RD320T52W RD325T52W RD316T54W RD320T54W RD325T54W RD316T55W RD320T55W RD325T55W RD316T56W RD320T56W RD325T56W Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 2000 2500 RDC316T51W RDC320T51W RDC325T51W RDC316T53W RDC320T53W RDC325T53W RDC316T52W RDC320T52W RDC325T52W RDC316T54W RDC320T54W RDC325T54W RDC316T55W RDC320T55W RDC325T55W 2 RDC316T56W RDC320T56W RDC325T56W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-239 2.3 2 2 2 Series C 100% Rated Digitrip RMS 510 Circuit Breakers The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at 75 °C ampacity. Order as individual components: breaker frame (which includes trip unit) and rating plug. 100% Rated Digitrip RMS 510 Circuit Breakers 2 2 Molded Case Circuit Breakers Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I 2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) Rated Current (In) Fixed Rating Plug 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 2 1200 RP6R20A120 1600 RP6R20A160 2 2000 RP6R20A200 2 2 2 LI LS LSI LIG LSG LSIG Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 CRD316T51W CRD316T53W CRD316T52W CRD316T54W CRD316T55W CRD316T56W 2 2 2000 1 CRD320T51W CRD320T53W CRD320T52W CRD320T54W CRD320T55W CRD320T56W 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 — CRDC316T53W CRDC316T52W CRDC316T54W CRDC316T55W CRDC316T56W 2 2 2 Catalog Number 2000 1 CRDC320T51W CRDC320T53W CRDC320T52W CRDC320T54W CRDC320T55W Note 1 Includes B2016RDL rear connectors. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-240 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com CRDC320T56W 2.3 Molded Case Circuit Breakers Series C Digitrip RMS 610 Electronic Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit) and rating plug. 2 2 Digitrip RMS 610 Electronic Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) LI LS 2 Digitrip Rating Plug Only LSI LIG LSG LSIG Catalog Number 2 Rated Current (In) Fixed Rating Plug Catalog Number 2 800 RP6R16A080 2 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 2 800 RP6R16A080 2 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 2000 2500 RD316T61W RD320T61W RD325T61W RD316T63W RD320T63W RD325T63W RD316T62W RD320T62W RD325T62W RD316T64W RD320T64W RD325T64W RD316T65W RD320T65W RD325T65W RD316T66W RD320T66W RD325T66W 2 2 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 2000 2500 RDC316T61W RDC320T61W RDC325T61W RDC316T63W RDC320T63W RDC325T63W RDC316T62W RDC320T62W RDC325T62W RDC316T64W RDC320T64W RDC325T64W RDC316T65W RDC320T65W RDC325T65W RDC316T66W RDC320T66W RDC325T66W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-241 2.3 2 2 2 Series C 100% Rated Digitrip RMS 610 Circuit Breakers The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at 75 °C ampacity. Order as individual components: breaker frame (which includes trip unit) and rating plug. 100% Rated Digitrip RMS 610 Circuit Breakers 2 2 Molded Case Circuit Breakers Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) Rated Current (In) Fixed Rating Plug 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 2 1200 RP6R20A120 1600 RP6R20A160 2 2000 RP6R20A200 2 2 2 LI LS LSI LIG LSG LSIG Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 CRD316T61W CRD316T63W CRD316T62W CRD316T64W CRD316T65W CRD316T66W 2 2 2000 1 CRD320T61W CRD320T63W CRD320T62W CRD320T64W CRD320T65W CRD320T66W 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 CRDC316T61W CRDC316T63W CRDC316T62W CRDC316T64W CRDC316T65W CRDC316T66W 2 2 2 Catalog Number 2000 1 CRDC320T61W CRDC320T63W CRDC320T62W CRDC320T64W CRDC320T65W Note 1 Includes B2016RDL rear connectors. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-242 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com CRDC320T66W Molded Case Circuit Breakers Series C 2.3 Digitrip RMS 810 Electronic Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit) and rating plug. 2 2 Digitrip RMS 810 Electronic Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I 2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) LI LS LSI LIG LSG LSIG Catalog Number 2000 2500 RD316T81W RD320T81W RD325T81W RD316T83W RD320T83W RD325T83W RD316T82W RD320T82W RD325T82W RD316T84W RD320T84W RD325T84W RD316T85W RD320T85W RD325T85W RD316T86W RD320T86W RD325T86W Fixed Rating Plug Catalog Number 2 800 RP6R16A080 2 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 2 800 RP6R16A080 2 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 2000 2500 RDC316T81W RDC320T81W RDC325T81W RDC316T83W RDC320T83W RDC325T83W RDC316T82W RDC320T82W RDC325T82W RDC316T84W RDC320T84W RDC325T84W RDC316T85W RDC320T85W RDC325T85W RDC316T86W RDC320T86W RDC325T86W 2 Rated Current (In) Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-243 2.3 2 2 2 2 2 2 Series C 100% Rated Digitrip RMS 810 Circuit Breakers The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at 75 °C ampacity. Order as individual components: breaker frame (which includes trip unit) and rating plug. 100% Rated Digitrip RMS 810 Circuit Breakers 2 2 Molded Case Circuit Breakers Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) LI LS LSI LIG LSG LSIG Catalog Number 1600 CRD316T81W CRD316T83W CRD316T82W CRD316T84W CRD316T85W CRD316T86W 2000 1 CRD320T81W CRD320T83W CRD320T82W CRD320T84W CRD320T85W CRD320T86W 2 2 2 Fixed Rating Plug 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 2 2 Rated Current (In) 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 CRDC316T81W CRDC316T83W CRDC316T82W CRDC316T84W CRDC316T85W CRDC316T86W 2 1600 RP6R16A160 1000 RP6R20A100 2 1200 RP6R20A120 1600 RP6R20A160 2 2000 RP6R20A200 2 2 2000 1 CRDC320T81W CRDC320T83W CRDC320T82W CRDC320T84W CRDC320T85W Note 1 Includes B2016RDL rear connectors. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-244 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com CRDC320T86W Molded Case Circuit Breakers Series C 2.3 Digitrip RMS 910 Electronic Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit) and rating plug. 2 2 Digitrip RMS 910 Electronic Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I 2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) LI LS LSI LIG LSG LSIG Catalog Number Fixed Rating Plug 2000 2500 RD316T91W RD320T91W RD325T91W RD316T93W RD320T93W RD325T93W RD316T92W RD320T92W RD325T92W RD316T94W RD320T94W RD325T94W RD316T95W RD320T95W RD325T95W RD316T96W RD320T96W RD325T96W Catalog Number 2 800 RP6R16A080 2 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 2500 RDC316T91W RDC320T91W RDC325T91W RDC316T93W RDC320T93W RDC325T93W RDC316T92W RDC320T92W RDC325T92W RDC316T94W RDC320T94W RDC325T94W RDC316T95W RDC320T95W RDC325T95W RDC316T96W RDC320T96W RDC325T96W 2 2 2 2 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 2 800 RP6R16A080 2 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 2 Rated Current (In) Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 2 2000 RP6R20A200 1600 RP6R25A160 2000 RP6R25A200 2500 RP6R25A250 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-245 2.3 2 2 2 Series C 100% Rated Digitrip RMS 910 Circuit Breakers The NEC allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 °C wire is applied at 75 °C ampacity. Order as individual components: breaker frame (which includes trip unit) and rating plug. 100% Rated Digitrip RMS 910 Circuit Breakers 2 2 Molded Case Circuit Breakers Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G Digitrip Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I 2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) Rated Current (In) Fixed Rating Plug 800 RP6R16A080 1000 RP6R16A100 1200 RP6R16A120 1600 RP6R16A160 1000 RP6R20A100 1200 RP6R20A120 1600 RP6R20A160 2000 RP6R20A200 800 RP6R16A080 1000 RP6R16A100 1000 RP6R16A100 1200 RP6R16A120 1000 RP6R20A100 2 1200 RP6R20A120 1600 RP6R20A160 2 2000 RP6R20A200 2 2 2 LI LS LSI LIG LSG LSIG Catalog Number Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 CRD316T91W CRD316T93W CRD316T92W CRD316T94W CRD316T95W CRD316T96W 2 2 2000 1 CRD320T91W CRD320T93W CRD320T92W CRD320T94W CRD320T95W CRD320T96W 2 2 2 Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 CRDC316T91W CRDC316T93W CRDC316T92W CRDC316T94W CRDC316T95W CRDC316T96W 2 2 2 Catalog Number 2000 1 CRDC320T91W CRDC320T93W CRDC320T92W CRDC320T94W CRDC320T95W Note 1 Includes B2016RDL rear connectors. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-246 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com CRDC320T96W 2.3 Molded Case Circuit Breakers Series C Digitrip OPTIM Electronic Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit) and rating plug. 2 2 Digitrip OPTIM Electronic Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only Maximum Continuous Ampere Rating at 40 °C L S I G A Digitrip OPTIM Rating Plug Only 2 – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) LSIA 1050 LSIG 1050 Catalog Number Catalog Number 2 Fixed Rating Plug 2 Ampere Rating Catalog Number 800 ORPR16A080 1000 ORPR16A100 1200 ORPR16A120 1600 ORPR16A160 1000 ORPR20A100 1200 ORPR20A120 1600 ORPR20A160 2000 ORPR20A200 1600 ORPR25A160 2000 ORPR25A200 2500 ORPR25A250 2 800 ORPR16A080 1000 ORPR16A100 2 1200 ORPR16A120 1600 ORPR16A160 1000 ORPR20A100 1200 ORPR20A120 1600 ORPR20A160 2000 ORPR20A200 1600 ORPR25A160 2000 ORPR25A200 2500 ORPR25A250 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 2000 2500 RD316T107W RD320T107W RD325T107W RD316T106W RD320T106W RD325T106W Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 2000 2500 RDC316T107W RDC320T107W RDC325T107W RDC316T106W RDC320T106W RDC325T106W 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-247 2.3 2 Molded Case Circuit Breakers Series C 100% Rated 600 Volts AC Digitrip OPTIM Circuit Breakers with Interchangeable Rating Plugs Order as individual components: breaker frame (which includes trip unit) and rating plug. 2 2 100% Rated 600 Volts AC Digitrip OPTIM Circuit Breakers with Interchangeable Rating Plugs Circuit Breaker Frame Only 2 2 2 Maximum Continuous Ampere Rating at 40 °C L S I G A Digitrip OPTIM Rating Plug Only – Adjustable Long Delay Pickup (Ir) with Adjustable Long Delay Time – Adjustable Short Delay Pickup with Adjustable Short Delay Time (I2t or Flat Response) – Adjustable Instantaneous Pickup – Adjustable Ground Fault Pickup with Adjustable Ground Fault Time Delay (I2t or Flat Response) – Adjustable Ground Fault Alarm with Adjustable Ground Fault Time Delay (I2t or Flat Response) LSIA 1050 LSIG 1050 Catalog Number Catalog Number Fixed Rating Plug Ampere Rating Catalog Number 800 ORPR16A080 1000 ORPR16A100 1200 ORPR16A120 1600 ORPR16A160 1000 ORPR20A100 2 1200 ORPR20A120 1600 ORPR20A160 2 2000 ORPR20A200 800 ORPR16A080 2 1000 ORPR16A100 1200 ORPR16A120 2 1600 ORPR16A160 1000 ORPR20A100 2 1200 ORPR20A120 2 1600 ORPR20A160 2000 ORPR20A200 2 2 Three-Pole Standard Interrupting Capacity 600 Vac Rated 65 kAIC at 480 Vac 1600 CRD316T107W CRD316T106W 2 2 2 2 2000 1 CRD320T107W Three-Pole High Interrupting Capacity 600 Vac Rated 100 kAIC at 480 Vac 1600 2000 1 CRDC316T107W 2 2 Type RD—High Instantaneous (K) 2 2 2 2 Continuous Ampere Rating at 40 °C CRDC316T106W CRDC320T107W Molded Case Switches Refer to Eaton for UL listed, series tested Molded Case Switch application data. 2 CRD320T106W CRDC320T106W Complete without Terminals Three-Pole Four-Pole Catalog Number Catalog Number 1600 RD316WK RD416WK 2000 RD320WK RD420WK Notes 1 Includes B2016RDL rear connectors. Molded case switch may trip above 17,500 amperes. 2 2 2 2 2 V4-T2-248 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Accessories Selection Guide and Ordering Information 2 Line and Load Terminals Line and load terminals provide wire connecting capabilities for specific ranges of continuous current ratings and wire types. All terminals comply with Underwriters Laboratories Standards UL 486A and UL 486B and CSA C22.2 No. 65M. Unless otherwise specified, R-Frame circuit breaker line load terminals are shipped separately for field installation. 2 Ordering Information R-Frame circuit breakers have Cu/AI terminals as standard and Cu only terminals as an option. Specify if factory installation is required. 2 2 2 2 2 2 2 Line and Load Terminals Maximum Breaker Amperes Terminal Body Material Wire Type Hardware AWG/kcmil Wire Range/ No. Conductors Metric Wire Range mm2 Catalog Number 2 2 Wire Terminals 2 1600 Aluminum Cu/AI English 500–1000 (4) 300–500 TA1600RD 1600 Copper Cu English 1–600 (4) 50–300 T1600RD 2000 Aluminum Cu/AI English 2–600 (6) 35–300 TA2000RD 1 2 — English — — B2016RD 2 Rear Connectors 2000 Copper 2 2000 Copper — English — — B2016RDL 2500 Copper — English — — B2500RD 3 2 2 Notes 1 Catalog Number includes bus connection, terminals and hardware for either line side or load side of three-pole breaker. 2 For use with 100% rated 1600 A and 2000 A frame. Do not order separately unless for replacement purposes. Included in breaker carton when 100% rated device is ordered. 3 For use with 2500 A frame. Do not order separately unless for replacement purposes. Included in breaker carton when 2500 A breaker is ordered. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-249 2.3 2 2 Molded Case Circuit Breakers Series C Mounting Hardware Breaker Line/Load Conductors 2 2 2 2 2 2 2 2 2 TA2000RD 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-250 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Accessories 2 Allowable Accessory Combinations Different combinations of accessories can be supplied, depending on the types of accessories and the number of poles in the circuit breaker. 2 RD Frame Accessories 2 Description Reference Page Three-Pole Left 2 Four-Pole Center Right Left Center Right Neu. Alarm lockout (Make/Break) V4-T2-276 ■ ■ Alarm lockout (2Make/2Break) V4-T2-276 ■ ■ Auxiliary switch (2A, 2B) V4-T2-276 ■ ■ Auxiliary switch (4A, 4B) V4-T2-276 ■ ■ Shunt trip—standard V4-T2-284 ■ ■ Shunt trip—low energy V4-T2-285 ■ ■ Undervoltage release mechanism V4-T2-292 ■ ■ Accessory terminal block 2 V4-T2-293 ■ 2 2 2 ■ External Accessories Base mounting hardware V4-T2-311 Padlockable handle lock hasp V4-T2-314 Key interlock kit V4-T2-316 Walking beam interlock V4-T2-317 Electrical (motor) operator ● 2 2 Internal Accessories 1 2 2 2 ● ■ ■ ■ ■ 2 V4-T2-319 ■ ■ ■ ■ 2 Handle mechanisms V4-T2-430 ■ ■ ■ ■ Handle extension 3 V4-T2-445 ■ 2 ■ 2 OPTIM System Components Breaker interface module (BIM) V4-T2-325 ● ● ● Digitrip OPTIMizer V4-T2-325 ● ● ● Auxiliary power module V4-T2-325 ● ● ● Special calibration — ● ● ● ● ● ● ● Moisture fungus treatment V4-T2-116 ● ● ● ● ● ● ● Freeze-tested circuit breakers — ● ● ● ● ● ● ● Marine/naval application — ● ● ● ● ● ● ● 2 2 Modifications (Refer to Eaton) Legend ■ Applicable in indicated pole position ● Accessory available/modification available 2 2 2 2 2 Notes All accessories mount in the RH cavity which will accept one each shunt trip, UVR, auxiliary switch and alarm switch. 2 Mounts outside breaker. 3 Included with breaker. 1 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-251 2.3 2 2 2 2 2 2 Molded Case Circuit Breakers Series C Technical Data and Specifications UL 489/CSA Interrupting Capacity Ratings 1 Interrupting Capacity (kA Symmetrical Amperes) Circuit Breaker Type Number of Poles Volts AC (50/60 Hz) 240 277 480 600 RD 3, 4 125 — 65 50 50 CRD 2 3 125 — 65 RDC 3, 4 200 — 100 65 CRDC 2 3 200 — 100 65 2 2 2 2 2 IEC 947-2 Interrupting Capacity Ratings Circuit Breaker Type 1 Interrupting Capacity (kA Symmetrical Amperes) Number of Poles Volts AC (50/60 Hz) 240 415 690 Icu 3, 4 135 70 25 Ics 3, 4 100 50 13 RD 2 RDC Icu 3, 4 200 100 35 2 Ics 3, 4 100 50 18 2 2 Notes 1 Utilization Category A circuit breakers. 2 100% rated breakers. See Page V4-T2-253 for Trip Unit Specifications. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-252 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Specifications 2 2 R-Frame Digitrip Trip Unit Type Digitrip RMS 510 Digitrip RMS 610 Digitrip RMS 810 Digitrip RMS 910 Digitrip OPTIM 1050 2 rms sensing Yes Yes Yes Yes Yes 2 Frame R R R R R Ampere range 800–2500 A 800–2500 A 800–2500 A 800–2500 A 800–2500 A 2 Interrupting rating at 480 volts 65, 100 (kA) 65, 100 (kA) 65, 100 (kA) 65, 100 (kA) 65, 100 (kA) LI, LS, LSI, LIG, LSG, LSIG LI, LS, LSI, LIG, LSG, LSIG LI, LS, LSI, LIG, LSG, LSIG LI, LS, LSI, LIG, LSG, LSIG LSI(A), LISG 2 2 Breaker Type 2 Protection Ordering options Fixed rated plug (In) Yes Yes Yes Yes Yes Overtemperature trip Yes Yes Yes Yes Yes 2 Adjustable rating plug (In) No No No No No Long delay pickup 0.5–1.0 x (In) 0.5–1.0 x (In) 0.5–1.0 x (In) 0.5 –1.0 x (In) 0.4–1.0 x (In) 2 Long delay time I2t 2–24 seconds 2–24 seconds 2–24 seconds 2–24 seconds 2–24 seconds Long delay time I4t No No No No 1–5 Seconds Long Delay Protection (L) 2 2 Long delay thermal memory Yes Yes Yes Yes Yes High load alarm No 0.85 x Ir 0.85 x Ir 0.85 x Ir 0.5-1.0 x Ir Short delay pickup 200–600% S1 and S2 x (Ir) 200–600% S1 and S2 x (Ir) 200–600% S1 and S2 x (Ir) 200–600% S1 and S2 x (Ir) 150-800% x (Ir) 12 2 Short delay time I2t 100–500 ms 100–500 ms 100–500 ms 100–500 ms 100–500 ms Short delay time flat 100–500 ms 100–500 ms 100–500 ms 100–500 ms 100–500 ms 2 Short delay time zone selective interlocking Yes Yes Yes Yes Yes 200–600% M1and M2 x (In) 200–600% M1and M2 x (In) 200–600% M1and M2 x (In) 200–600% M1and M2 x (In) 200–800% x (In) 2 2 2 2 Short Delay Protection (S) 2 Instantaneous Protection (I) Instantaneous pickup Discriminator Yes 3 Yes 3 Yes 3 Yes 3 Yes Instantaneous override Yes Yes Yes Yes Yes 2 2 Ground Fault Protection (G) Ground fault alarm 4 No No No No 25–100% x (In) Ground fault pickup 4 25–100% x (Is) 25-100% x (Is) 25–100% x (Is) 25–100% x (Is) 25–100% x (In) Ground fault delay I2t 100–500 ms 100–500 ms 100–500 ms 100–500 ms 100–500 ms Ground fault delay flat 100–500 ms 100–500 ms 100 –500 ms 100–500 ms 100–500 ms Ground fault zone selective interlocking Yes Yes Yes Yes Yes Ground fault thermal memory Yes Yes Yes Yes Yes 2 2 2 Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting x In 2 2 2 Notes 1 Except 2500 ampere frame is 200–600%. 2 Varies by frame. 3 LS/LSG only. 4 Not to exceed 1200 amperes. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-253 2.3 Molded Case Circuit Breakers Series C 2 R-Frame Digitrip, continued 2 Trip Unit Type 2 Digitrip RMS 510 Digitrip RMS 610 Digitrip RMS 810 Digitrip RMS 910 Digitrip OPTIM 1050 Yes System Diagnostics Status LEDs Yes Yes Yes Yes Cause of trip LEDs Yes Yes Yes Yes Yes Magnitude of trip information No Yes Yes Yes Yes 2 Remote signal contacts No Yes Yes Yes Yes 2 Digital display No Yes Yes Yes Yes 1 2 System Monitoring Current No Yes Yes Yes Yes 2 Voltage No No No Yes No 2 Power and energy No No Yes Yes Yes Power quality—harmonics No No No Yes Yes 2 Power factor No No Yes (over Eaton PowerNet only) Yes Yes 2 Communications No No Yes Yes Yes 2 Testing Integral Integral Integral Integral OPTIMizer, BIM, PowerNet 2 Eaton PowerNet Testing method 2 Legend BIM = Breaker Interface Module (A) = GF Alarm Is = Sensor Rating In = Rating Plug Ir = Long Delay Pickup Setting x In 2 Note 1 By OPTIMizer/BIM. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-254 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Dimensions and Weights 2 Dimensions in Inches (mm) 2 RD Frame Number of Poles Width Height Depth 3 15.50 (393.7) 16.00 (406.4) 9.75 (247.7) 4 20.00 (508.0) 16.00 (406.4) 9.75 (247.7) 2 2 2 RD-Frame, Three-Pole, 1600 and 2000 Amperes 2 Front View 7.25 (184.2) 14.50 (368.3) 11.13 (0.4) Dia. (4 Holes) Use 4, 0.38 (Mil) Dia. Bolts for Mounting Breaker 15.50 (393.7) 2 Side View 2 9.00 (228.6) 2 C L Breaker 5.09 (129.4) 9.69 (246.1) 7.75 (196.9) 2 C L Handle 16.00 (406.4) 15.00 (381.0) 2 Push To Trip 6.65 (166.7) 12.91 (327.8) 2 0.16 (4.0) R Typ. 2 2 Approximate Shipping Weight in Lbs (kg) 2 RD Frame 2 Complete Breaker Breaker Type Three-Pole Four-Pole 102 (46.3) 135 (61.2) 2 2 2 1600 Amperes RD, CRD 1, RDC, CRDC 1 2000 Amperes RD, RDC 102 (46.3) 135 (61.2) CRD, CRDC 130 (59.0) 175 (79.4) 135 (61.2) 182 (82.6) 2 2500 Amperes RD, RDC 2 2 Note 1 No four-pole for CRD and CRDC. 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-255 2.3 2 Molded Case Circuit Breakers Series C Contents Motor Circuit Protectors Description 2 Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes). . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes). . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) Catalog Number Selection. . . . . . . . . . . . . . . . . . Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . 2 2 2 2 2 2 2 2 2 2 2 2 Motor Circuit Protectors (MCP) 2 Product Description Standards and Certifications Designated as Eaton’s Types GMCP and HMCP, the instantaneous-only motor circuit protector (MCP) is available in ratings from 3 A to 1200 A for motor starter sizes 0 through 8. The MCP is designed to comply with the applicable requirements of Underwriters Laboratories Standard UL 489, Canadian Standards Association Standard C22.2 No. 5.1, and International Electrotechnical Commission Recommendations IEC 157-1. 2 2 2 2 2 2 2 An innovative design of internal components allows higher MCP-starter combination interrupting ratings. The MCP is marked to permit proper electrical application within the assigned equipment ratings. 2 2 2 2 The MCP is a recognized component (UL File E7819) and complies with the applicable requirements of Underwriters Laboratories Standard UL 489. It is also designed to comply with the applicable requirements of Canadian Standards Association Standard C22.2 No. 5.1, International Electrotechnical Commission Recommendations IEC 157-1, and nameplates bear the CE marking. 2 2 Note: Interrupting ratings are dependent on starter it is used with. 2 2 V4-T2-256 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-257 V4-T2-258 V4-T2-259 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 Molded Case Circuit Breakers Series C 2.3 Catalog Number Selection 2 This information is presented only as an aid to understanding catalog numbers. It is not to be used to build catalog numbers for circuit breakers or trip units. 2 2 Motor Circuit Protector HMCP 003 A0 C Motor Circuit Protective Type HMCP = Three-pole HM2P = Two-pole 1 HMCPS = Three-pole Continuous Ampere Rating 003 007 015 025 030 050 A0 = C0 = E0 = D0 = H1 = G2 = K2 = J2 = M2 = L3 = R3 = T4 = U4 = A5 = C5 = D5 = F5 = G5 = J5 = K5 = L5 = W5 = N5 = R5 = X5 = Y5 = L6 = X6 = Y6 = X7 = Y8 = 070 100 150 250 400 600 800 1200 Magnetic Trip Range/ NEMA Starter Size 9–30/0 21–70/0 45–150/0 40–60/0 90–300/1 80–120/2 50–500/2 115–170/2 210–700/2 160–240/3 300–1000/3 450–1500/4 750–2500/4 350–700/5 450–900/5 500–1000/5 625–1250/5 750–1500/5 875–1750/5 1000–2000/5 1125–2250/5 1250–2500/5 1500–3000/5 1750–3500/5 2000–4000/5 2250–4500/5 1800–6000/6 (electronic) 500–2500/6 (electronic) 1000–4000/6 (electronic) 1600–6400/7 (electronic) 2400–9600/8 (electronic) 2 2 Suffix Non-aluminum terminals Without terminals Load terminals only Line terminals only Stainless steel terminals (150A frame only) No Suffix: Standard terminals on line and load C = W= X = Y = S = 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Motor Circuit Protector GMCP 003 A0 C Motor Circuit Protective Device GMCP = Three-pole Continuous Ampere Rating 003 007 015 030 050 060 063 Magnetic Trip Range/NEMA Starter Size A0 = 15–30/0 C0 = 35–70/0 E0 = 75–150/0 H1 = 150–300/1 K2 = 250–500/2 J2 = 300–600/2 M2 = 320–630/2 2 2 Suffix C = Non-aluminum terminals 2 2 2 2 Note 1 On J- and K-Frame HMCPs only. 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-257 2.3 Molded Case Circuit Breakers Series C 2 Product Selection 2 G-Frame 2 480 Vac Maximum, 600Y/347 Vac NEMA Starter Size Continuous Amperes Cam Setting Motor Full Load Current Amperes (FLA) 1 MCP Trip Setting MCP Catalog Number 0 3 A 1.1–1.2 15 GMCP003A0C B 1.3–1.5 18 C 1.6–1.7 21 2 D 1.8–1.9 24 2 E 2.0–2.2 27 F 2.3–2.5 30 A 2.6–3.1 35 B 3.2–3.6 42 C 3.7–3.9 49 D 4.3–4.7 56 E 4.8–5.2 63 F 5.3–5.7 70 A 5.7–6.8 75 2 B 6.9–7.9 90 C 8.0–9.1 105 2 D 9.2–10.3 120 E 10.4–11.4 135 2 F 11.5–12.6 150 A 11.5–13.7 150 B 13.8–16.0 180 C 16.1–18.3 210 D 18.4–20.6 240 E 20.7–22.9 270 2 2 2 0 7 2 2 2 2 0 1 15 30 2 2 F 23.0–25.2 300 A 19.3–22.9 250 2 B 23.0–26.8 300 C 26.9–30.6 350 2 D 30.7–34.5 400 E 34.6–38.3 450 F 38.4–42.1 500 A 23.1–27.5 300 B 27.7–32.2 360 2 C 32.3–36.7 420 D 36.9–41.4 480 2 E 41.5–46.0 540 F 46.2–50.5 600 A 24.2–32.1 320 2 B 29.1–34.8 380 D 38.8–46.4 500 2 E 43.6–48.9 570 F 48.5–53.7 630 2 2 2 2 2 2 2 2 3 3 50 60 63 GMCP007C0C GMCP015E0C GMCP030H1C GMCP050K2C GMCP060J2C GMCP063M2C Notes 1 Motor FLA ranges are typical. The corresponding trip setting is at 13 x the minimum FLA value shown. Where a 13 x setting is required for an intermediate FLA value, alternate Cam settings and/or MCP ratings should be used. All GMCP 3–63A come with line and load steel body terminals for Cu only wire. Refer to Page V4-T2-122 under Optional Terminal Types. UL recognized and CSA approved. V4-T2-258 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Accessories 2 Modifications for GMCP Internal accessories must be factory installed. 2 2 Internal Accessories 1 Electrical Ratings Type Accessory Volts Frequency Amperes Contact Arrangement Shunt trip 2 120 50/60 Hz 1.1 — S5 Shunt trip 2 240 50/60 Hz 2.1 — S6 1373D62G19 Auxiliary switch 3 240 50/60 Hz 6.0 1A/1B A3 1288C74G03 Auxiliary switch 3 240 50/60 Hz 6.0 2A/2B A6 1288C73G03 Alarm switch 3 Auxiliary switch/alarm switch combination 3 Factory Suffix Style Number 2 1373D62G18 2 240 50/60 Hz 6.0 Make/Break B3 1288C75G03 240 50/60 Hz 6.0 1A/1B Make/Break B13 1288C76G09 Number Units in Package Style Number 2 Lock dog (non-padlockable) 1 1294C01H01 Mounting hardware 1 624B375G23 DIN rail adapter 4 10 1225C79G02 2 2 2 Modifications for HMCP See Internal Accessories starting on Page V4-T2-273. 2 Handle Mechanisms for Series C Frames 2 Kits Only (Kit Includes Shaft, Mechanism and Handle)—GMCP-Frame Rating Type S01 Blue Handle S01 Red Handle 2 2 External Mounted Accessories Description 2 GMCP-Frame 2 Description NEMA IP Catalog Number S01 blue handle, 12-inch shaft 1/3R/12 54 GMHMVD12B / 68C6039G05 4/4X 65 GMHMVD12BX / 68C6039G07 2 S01 red handle, 12-inch shaft 1/3R/12 54 GMHMVD12R / 68C6039G06 4/4X 65 GMHMVD12RX / 68C6039G08 2 2 2 Direct (Close-Coupled) Handle Mechanisms 2 G Direct 5 Black Handle 2 Yellow Handle With Shroud Without Shroud With Shroud Without Shroud Frame Catalog Number Catalog Number Catalog Number Catalog Number 2 GMCP HRGMC1S HRGMC10 HRGMC3S HRGMC30 2 Notes 1 Only one accessory may be installed in GMCP. 2 LH only. 3 RH only. 4 For use with standard 35 mm DIN rail such as, 35 x 7.5 or 15 mm per DIN EN50022. 5 Suitable for use on two- or three-pole G-Frame. 2 2 2 No UVR available on GMCP. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-259 2.3 Molded Case Circuit Breakers Series C 2 F-Frame 2 600 Vac Maximum, 250 Vdc Maximum NEMA Starter Size Cont. Amps Cam Setting Motor Full Load Current Amperes (FLA) 1 0 3 A 2 B 2 2 MCP Trip Setting 600 Vac Maximum, 250 Vdc Maximum, continued Motor Full Load Current Amperes (FLA) 1 MCP Trip Setting 2 MCP Catalog Number HMCP070M2C 2 MCP Catalog Number NEMA Starter Size Cont. Amps 0.69–0.91 9 HMCP003A0C 2 70 A 16.1–21.4 210 0.92–1.0 12 B 21.5 –26.8 280 C 1.1–1.2 15 C 26.9 –32.2 350 D 1.3–1.5 18 D 32.3–37.5 420 2 E 1.6–1.7 21 E 37.6–42.9 490 F 1.8–1.9 24 F 43.0–48.3 560 2 G 2.0–2.2 27 G 48.4–53.7 630 H 2.3–2.5 30 H 53.8–59.1 700 A 1.5–2.0 21 A 23.0–30.6 300 2 B 2.1–2.5 28 B 30.7–38.3 400 C 2.6–3.1 35 C 38.4–46.0 500 2 D 3.2–3.6 42 D 46.1–53.7 600 E 3.7–3.9 49 E 53.8 –61.4 700 2 F 4.3–4.7 56 F 61.5 –69.1 800 2 G 4.8–5.2 63 G 69.2–76.8 900 H 5.3–5.7 70 H 76.9–84.5 1000 A 3.4–4.5 45 A 34.6–46.0 450 B 4.6–5.6 60 B 46.1–57.5 600 C 5.7–6.8 75 C 57.6–69.1 750 D 6.9–7.9 90 D 69.2–80.6 900 2 E 8.0–9.1 105 D 69.2–80.6 900 2 F 9.2–10.3 120 E 80.7–92.2 1050 G 10.4–11.4 135 F 92.3–103.7 1200 H 11.5 –12.6 150 G 103.8–115.2 1350 A 6.9–9.1 90 2 B 9.2–11.4 120 C 11.5–13.7 2 D 2 E 2 2 2 2 0 0 7 15 2 2 4 100 150 H 115.3–126.7 1500 57.0 –75.0 750 150 B 76.0–95.0 1000 13.8–16.0 180 C 96.0–114.0 1250 16.1–18.3 210 D 115.0–130.7 1500 F 18.4–20.6 240 E 3 1750 G 20.7–22.9 270 F 3 2000 H 23.0–25.2 300 G 3 2250 A 11.5–15.2 150 H 3 2500 B 15.3–19.1 200 C 19.2–22.9 250 2 D 23.0–26.8 300 E 26.9–30.6 350 2 F 30.7–4.5 400 G 34.6–38.3 450 H 38.4–42.1 500 2 2 2 30 HMCP015E0C 3 A 2 1 HMCP007C0C 50 HMCP030H1C Cam Setting 4 150 HMCP050K2C HMCP150T4C HMCP150U4C Notes 1 Motor FLA ranges are typical. The corresponding trip setting is at 13 x the minimum FLA value shown. Where a 13 x setting is required for an intermediate FLA value, alternate Cam settings and/or MCP ratings should be used. 2 For DC applications, actual trip levels are approximately 40% higher than values shown. 3 Settings above 130 amperes are for special applications. NEC Article 430.110(a) requires the ampere rating of the disconnecting means to be not less than 115% of the motor full load ampere rating. HMCP 3–100 A come with line and load steel body terminals, 3T100FB. HMCP 150A come with line and load steel body terminals, 3T150FB. 2 2 2 V4-T2-260 HMCP100R3C Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Special Low Magnetic Protection Application MCP 2 600 Vac Maximum, 250 Vdc Maximum 2 Cont. Amps Cam Setting MCP Trip Setting 1 MCP Catalog Number 25 A 40 HMCP025D0C B 43 D 49 E 52 F 55 G 58 H 60 A 80 B 87 C 93 D 98 E 103 F 109 G 115 H 120 A 115 B 122 C 130 D 139 E 145 F 153 G 160 H 170 50 70 100 A 160 B 174 C 185 D 196 E 207 F 218 G 229 H 240 2 2 2 2 2 HMCP050G2C 2 2 2 2 2 HMCP070J2C 2 2 2 2 2 HMCP100L3C 2 2 2 2 Notes 1 For DC applications, actual trip levels are approximately 40% higher than values shown. 2 HMCP 25–100 A come with line and load steel body terminals, 3T100FB. 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-261 2.3 Molded Case Circuit Breakers Series C 2 MCPs for Application with Motor Starters Equipped with Electronic Overload Relays 2 600 Vac Maximum, 250 Vdc Maximum 2 NEMA Starter Size Cont. Amps 2 0 3 600 Vac Maximum, 250 Vdc Maximum, continued Cam Setting Motor Full Load Current Amperes (FLA) 1 MCP Trip Setting 2 MCP Catalog Number A 23.0–30.6 300 HMCPS100R3C B 30.7–38.3 400 15 C 38.4–46.0 500 18 D 46.1–53.7 600 1.6–1.7 21 E 53.8–61.4 700 2 F 1.8–1.9 24 F 61.5–69.1 800 2 G 2.0–2.2 27 G 69.2–76.8 900 H 2.3–2.5 30 H 76.9–84.5 1000 A 1.5–2.0 21 A 34.6–46.0 450 B 2.1–2.5 28 B 46.1–57.5 600 C 2.6–3.1 35 C 57.6–69.1 750 D 3.2–3.6 42 D 69.2–80.6 900 2 E 3.7–3.9 49 E 80.7–92.2 1050 2 F 4.3–4.7 56 F 92.3–103.7 1200 G 4.8–5.2 63 G 103.8–115.2 1350 H 5.3–5.7 70 H 115.3–126.7 1500 A 3.4–4.5 45 A 57.0–75.0 750 2 B 4.6–5.6 60 B 76.0–95.0 1000 C 5.7–6.8 75 C 96.0–114.0 1250 2 D 6.9–7.9 90 D 115.0–130.7 1500 2 E 8.0–9.1 105 E 3 1750 F 9.2–10.3 120 F 3 2000 2 G 10.4–11.4 135 G 3 2250 H 11.5–12.6 150 H 3 2500 A 6.9–9.1 90 B 9.2–11.4 120 C 11.5–13.7 150 2 D 13.8–16.0 180 E 16.1–18.3 210 2 F 18.4–20.6 240 G 20.7–22.9 270 H 23.0–25.2 300 A 11.5–15.2 150 B 15.3–19.1 200 2 C 19.2–22.9 250 D 23.0–26.8 300 2 E 26.9–30.6 350 F 30.7–34.5 400 G 34.6–38.3 450 H 38.4–42.1 500 Cam Setting Motor Full Load Current Amperes (FLA) 1 MCP Trip Setting A 2 B 2 2 0 7 2 2 2 0 1 15 30 2 2 2 2 50 2 2 2 MCP Catalog Number NEMA Starter Size Cont. Amps 0.69–0.91 9 HMCPS003A0C 3 100 0.92–1.0 12 C 1.1–1.2 D 1.3–1.5 E HMCPS007C0C HMCPS015E0C HMCPS030H1C 4 4 150 150 HMCPS150U4C Notes 1 Motor FLA ranges are typical. The corresponding trip setting is at 13 x the minimum FLA value shown. Where a 13 x setting is required for an intermediate FLA value, alternate cam settings and/or MCP ratings should be used. 2 For DC applications, actual trip levels are approximately 40% higher than values shown. 3 Settings above 130A are for special applications. NEC Article 430.110(a) requires the ampere rating of the disconnecting means to be not less than 115% of the motor full load ampere rating. HMCP 25–100 A come with line and load steel body terminals, 3T100FB. HMCPS 3–100 A come with line and load steel body terminals, 3T100FB. HMCPS 150A come with line and load steel body terminals, 3T150FB. HMCPS050K2C 2 2 2 V4-T2-262 HMCPS150T4C Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C J-Frame 2 600 Vac Maximum, 250 Vdc Maximum 2 MCP Catalog Number 3 NEMA Starter Size Cont. Amps Cam Setting Motor Full Load Current Amperes (FLA) 1 27.0–30.7 350 HMCP250A5C 5 250 A 67.4–75.3 B 30.8–33.8 400 B 75.4–83.8 980 C 33.9–36.9 440 C 83.9–92.3 1090 D 37.0–40.3 480 D 92.4–100.7 1200 E 40.4–43.8 525 E 100.8–109.2 1310 F 43.9–46.9 570 F 109.3–117.6 1420 G 47.0–50.7 610 G 117.7–126.1 1530 H 47.0–50.7 660 H 126.2–134.6 1640 NEMA Starter Size Cont. Amps Cam Setting Motor Full Load Current Amperes (FLA) 1 4 250 A 5 5 5 5 5 250 250 250 250 250 600 Vac Maximum, 250 Vdc Maximum, continued MCP Trip Setting I 47.0–50.7 700 A 34.7–38.8 450 B 38.9–43.4 C 43.5–47.6 D 2 MCP Catalog Number 3 875 HMCP250J5C I 134.7–142.8 1750 A 77.0–86.6 1000 505 B 86.6–96.1 1125 565 C 96.2–105.7 1250 47.7–52.2 620 D 105.8–115.3 1375 E 52.3–56.5 680 E 115.4–124.9 1500 F 56.6–60.7 735 F 125.0–134.6 1625 G 60.8–64.9 790 G 134.7–144.2 1750 H 65.0–69.2 845 H 144.3–153.8 1875 I 69.3–73.5 900 I 153.9–163.3 2000 A 38.5–43.4 500 A 86.6–97.3 1125 B 43.5–48.0 565 B 97.4–108.4 1265 C 48.1–53.0 625 C 108.5–118.8 1410 D 53.1–57.6 690 D 118.9–129.9 1545 E 57.7–62.3 750 E 130.0–140.7 1690 F 62.4–67.3 810 F 140.8–151.5 1830 G 67.4–71.9 875 G 151.6–162.3 1970 H 72.0–76.9 935 H 162.4–173.0 2110 I 77.0–81.6 1000 I 173.1–183.6 2250 A 48.1–53.8 625 A 96.2–108.0 1250 B 53.9–59.9 700 B 108.1–119.9 1405 C 60.0–66.1 780 C 120.0–132.3 1560 D 66.2–72.3 860 D 132.4–144.2 1720 E 72.4–78.4 940 E 144.3–156.1 1875 HMCP250C5C HMCP250D5C HMCP250F5C 5 5 5 250 250 250 F 78.5–83.8 1020 F 156.2–168.0 2030 G 83.9–89.9 1090 G 168.1–179.9 2185 H 90.0–96.1 1170 H 180.0–192.3 2340 I 96.2–102.0 1250 I 192.4–204.0 2500 A 57.7–64.6 750 B 64.7–71.9 840 C 72.0–79.2 935 D 79.3–86.5 1030 E 86.6–93.8 1125 F 93.9–101.1 1220 G 101.2–108.4 1315 H 108.5–115.3 1410 I 115.4–122.4 1500 HMCP250G5C 2 MCP Trip Setting 2 2 2 2 2 2 HMCP250K5C 2 2 2 2 2 2 HMCP250L5C 2 2 2 2 2 HMCP250W5C 2 2 2 2 2 Notes 1 Motor FLA ranges are typical. The corresponding trip setting is at 13 times the minimum FLA value shown. Where a 13 times setting is required for an intermediate FLA value, alternate cam settings and/or MCP ratings should be used. 2 For DC applications, actual trip levels are approximately 40% higher than values shown. 3 Three-pole catalog numbers shown. Two-pole catalog numbers begin with HM2P in place of HMCP. All HMCP and HM2P 250A come with line and load steel body terminals, T250KB. (With suffix “C,” without “C” comes with TA250KB.) 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-263 2.3 Molded Case Circuit Breakers Series C 2 K-Frame 2 600 Vac Maximum, 250 Vdc Maximum 2 2 2 MCP Catalog Number 3 NEMA Starter Size Cont. Amps Cam Setting 27.0–30.7 350 HMCP400A5C 5 400 A 30.8–33.8 400 B NEMA Starter Size Cont. Amps Cam Setting 4 400 A B 2 600 Vac Maximum, 250 Vdc Maximum, continued Motor Full Load Current Amperes (FLA) 1 Motor Full Load Current Amperes (FLA) 1 MCP Trip Setting MCP Trip Setting 2 MCP Catalog Number 3 77.0–86.5 1000 HMCP400K5C 86.6–96.1 1125 C 33.9–36.9 440 D 37.0–40.3 480 2 E 40.4–43.8 525 E 115.4–124.9 1500 F 43.9–46.9 570 F 125.0–134.6 1625 2 G 47.0–50.7 610 G 134.7–144.2 1750 H 50.8–53.8 660 H 144.3–153.8 1875 2 I 53.9–57.2 700 I 153.9–163.3 2000 A 38.5–43.4 500 A 86.6–97.3 1125 B 43.5–48.0 565 B 97.4–108.4 1265 C 48.1–53.0 626 C 108.5–118.8 1410 D 53.1–57.6 690 D 118.9–129.9 1545 2 E 57.7–62.3 750 E 130.0–140.7 1690 2 F 62.4–67.3 810 F 140.8–151.5 1830 G 67.4–71.9 875 G 151.6–162.3 1970 H 72.0–76.9 935 H 162.4–173.0 2110 I 77.0–81.6 1000 I 173.1–183.6 2250 A 48.1–53.8 625 A 96.2–108.0 1250 B 53.9–59.9 700 B 108.1–119.9 1405 2 C 60.0–66.1 780 C 120.0–132.3 1560 2 D 66.2–72.3 860 D 132.4–144.2 1720 E 72.4–78.4 940 E 144.3–156.1 1875 2 F 78.5–83.8 1020 F 156.2–168.0 2030 G 83.9–89.9 1090 G 168.1–179.9 2185 2 H 90.0–96.1 1170 H 180.0–192.3 2340 I 96.2–102.0 1250 I 192.4–204.0 2500 A 57.7–64.6 750 A 115.4–129.9 1500 2 B 64.7–71.9 840 B 130.0–144.2 1690 C 72.0–79.2 935 C 144.3–158.4 1875 2 D 79.3–86.5 1030 D 158.5–173.0 2060 E 86.6–93.8 1125 E 173.1–187.6 2250 2 F 93.9–101.1 1220 F 187.7–201.9 2440 2 G 101.2–108.4 1315 G 202.0–216.1 2625 H 108.5–115.3 1410 H 216.2–230.7 2810 I 115.4–122.4 1500 I 230.8–244.9 3000 A 67.4–75.3 875 B 75.4–83.8 980 C 83.9–92.3 1090 2 D 92.4–100.7 1200 2 E 100.8–109.2 1310 F 109.3–117.6 1420 2 G 117.7–126.1 1530 H 126.2–134.6 1640 2 I 134.7–142.8 1750 2 2 5 5 400 400 2 2 2 2 2 5 5 5 400 400 400 2 V4-T2-264 HMCP400A5C HMCP400D5C HMCP400F5C HMCP400G5C HMCP400J5C 5 5 5 400 400 400 C 96.2–105.7 1250 D 105.8–115.3 1375 HMCP400L5C HMCP400W5C HMCP400N5C Notes 1 Motor FLA ranges are typical. The corresponding trip setting is at 13 x the minimum FLA value shown. Where a 13 x setting is required for an intermediate FLA value, alternate cam settings and/or MCP ratings should be used. 2 For DC applications, actual trip levels are approximately 40% higher than values shown. 3 Three-pole catalog numbers shown. Two-pole catalog numbers begin with HM2P in place of HMCP. All HMCP and HM2P 400 A come with aluminum body terminals, 3TA400K. Catalog numbers with suffix “C” as shown above come with copper body terminals 3T400K. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C L-Frame 600 Vac Maximum, 250 Vdc Maximum, continued NEMA Starter Size Cont. Amps Cam Setting Motor Full Load Current Amperes (FLA) 1 5 400 A 5 5 400 400 2 600 Vac Maximum 4 2 2 MCP Catalog Number 3 NEMA Starter Size Cont. Amps Cam Setting Motor Full Load Current Amperes (FLA) 1 134.7–151.5 1750 HMCP400R5C 6 600 A 138.5–184.5 1800 B 151.6–168.4 1970 B 184.6–230.7 2400 C 168.5–185.3 2190 C 230.8–276.8 3000 D 185.4–201.9 2410 D 276.9–323.0 3600 E 202.0–218.8 2625 E 323.1–369.1 4200 F 218.9–235.7 2845 F 369.2–415.3 4800 G 235.8–252.6 3065 G 415.4–461.4 5400 H 252.7–269.2 3285 H 461.5–507.7 6000 A 38.5–46.1 500 B 46.2–61.4 600 MCP Trip Setting MCP Trip Setting MCP Catalog Number HMCP600L6W I 269.3–285.7 3500 A 153.9–173.0 2000 B 173.1–192.3 2250 C 61.5–76.8 800 C 192.4–211.5 2500 D 76.9–96.1 1000 D 211.6–230.7 2750 E 96.2–115.3 1250 E 230.8–249.9 3000 F 115.4–153.7 1500 F 250.0–269.2 3250 G 153.8–192.2 2000 G 269.3–288.4 3500 H 288.5–307.6 3750 I 307.7–326.9 4000 A 173.1–194.5 2250 B 194.6–216.1 2530 C 216.2–237.6 2810 D 237.7–259.5 3090 E 259.6–281.1 F 6 600 HMCP400X5C H 192.3–230.7 2500 A 76.9–96.1 1000 B 96.2–115.3 1250 C 115.4–153.7 1500 D 153.8–192.2 2000 E 192.3–230.7 2500 F 230.8–269.1 3000 3375 G 269.2–307.6 3500 281.2–302.6 3655 H 307.7–346.1 4000 G 302.7–324.1 3935 H 324.2–346.1 4215 I 346.2–368.1 4500 6 HMCP400Y5C 600 2 2 2 2 2 2 HMCP600X6W 2 2 2 2 2 HMCP600Y6W 2 2 2 2 Notes 1 Motor FLA ranges are typical. The corresponding trip setting is at 13 x the minimum FLA value shown. Where a 13 x setting is required for an intermediate FLA value, alternate cam settings and/or MCP ratings should be used. 2 For DC applications, actual trip levels are approximately 40% higher than values shown. 3 Three-pole catalog numbers shown. Two-pole catalog numbers begin with HM2P in place of HMCP. 4 Equipped with electronic trip device. All HMCP and HM2P 400 A come with aluminum body terminals, 3TA400K. Catalog numbers with suffix “C” as shown above come with copper body terminals 3T400K. All HMCP 600 A come without terminals. For terminals, see Page V4-T2-217. 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-265 2.3 Molded Case Circuit Breakers Series C 2 N-Frame 2 600 Vac Maximum 2 NEMA Starter Size Cont. Amps 7 800 1 Cam Setting Motor Full Load Current Amperes (FLA) 2 MCP Trip Setting MCP Catalog Number HMCP800X7W A 123.1–184.5 1600 B 184.6–246.1 2400 C 246.2–307.6 3200 D 307.7–369.1 4000 2 E 369.2–430.7 4800 2 F 430.8–492.2 5600 G 492.3–553.7 6400 A 184.6–276.8 2400 B 276.9–369.1 3600 2 C 369.2–461.4 4800 2 D 461.5–553.7 6000 E 553.8–646.1 7200 F 646.2–738.4 8400 G 738.5–830.7 9600 2 2 2 8 1200 2 2 2 2 2 HMCP12Y8W Notes 1 Equipped with electronic trip device. 2 Motor FLA ranges are typical. The corresponding trip setting is at 13X the minimum FLA value shown. Where a 13X setting is required for an intermediate FLA value, alternate cam settings and/or MCP ratings should be used. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-266 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Contents Motor Protection Circuit Breakers Description Page Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories. . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-268 V4-T2-268 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Motor Protection Circuit Breakers (MPCB) Product Description Motor protection circuit breakers (MPCBs) provide UL 489 branch circuit protection, UL 508 and CSA C22.2 No. 14 motor protection, and meet IEC 60947-2 and 50947-4 requirements. Typical branch motor loads are protected by three-component starters, consisting of breaker, contactor and overload relay, or fuse, contactor and overload relay. The MPCB application-specific protection eliminates the need for motor overload relay found in the traditional three-component starter assembly. The branch motor load protection is simplified to an MPCB and contactor, reducing both space requirements and heat generation in customer panels. Protection is provided by application-specific electronic trip units. The electronic trip unit provides typical motor overload relay functionality and short-circuit protection against potential phase-tophase or phase-to-ground faults. ● ● ● ● Disconnecting means Branch circuit short-circuit protection Overload protection ● Class 5, 10, 15 and 20 Phase unbalance protection ● FDMP breaker trips when there is a 40% difference between any phase compared to the calculated three-phase average ● ● Phase loss protection ● Active when the maximum phase current is greater than 50% of FLA setting ● Breaker will trip when minimum phase current is 25% or less than the maximum phase current ● Time delay of 1 or 2 seconds before breaker trips Thermal memory to prevent immediate restart after overload trip to allow motor to cool down The MPCB is based on the Series C F-Frame. Accessories for standard Series C breakers apply to the MPCB. Unlike Motor Circuit Protectors (MCPs), MPCBs are UL 489 listed with 35 kA and 65 kA interruption ratings. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-267 2.3 Molded Case Circuit Breakers Series C 2 Product Selection 2 FDMP and HFDMP 2 2 2 2 2 Continuous Amperes 35 kA Without Phase Unbalance, Class 10 Motor Protection Only 35 kA With Phase Unbalance and Adjustable Motor Class Protection 65 kA Without Phase Unbalance, Class 10 Motor Protection Only 65 kA With Phase Unbalance and Adjustable Motor Class Protection 80 FDMP3080L FDMP3080JL HFDMP3080L HFDMP3080JL 100 FDMP3100L FDMP3100JL HFDMP3100L HFDMP3100JL 160 FDMP3160L FDMP3160JL HFDMP3160L HFDMP3160JL 205 FDMP3205L FDMP3205JL HFDMP3205L HFDMP3205JL FLA le Dial Setting Continuous Amperes A B C D E F G H 2 80 40 50 60 70 80 — — — 100 80 — 90 — 100 — — — 2 160 100 115 130 145 160 — — — 205 160 170 180 195 205 — — — 2 2 Technical Data and Specifications 2 Specifications 2 2 Feature FDMP HFDMP Interruption rating at 240 V 65 kA 100 kA Interruption rating at 480 V 35 kA 65 kA Interruption rating at 600 V 18 kA 25 kA Icu/Ics at 240 V 65 kA/33 kA 1 100 kA/50 kA 1 Icu/Ics at 415 V 35 kA/18 kA 1 65 kA/33 kA 1 100% rated No No 2 FLA range (A) 40–205 40–205 Motor class protection 5, 10, 15, 20 5, 10, 15, 20 2 Phase unbalance protection (current)—active for phase current >0.5 FLA setting t40% delta (single-phase): (three-phase avg.) for 5 seconds t40% delta (single-phase): (three-phase avg.) for 5 seconds 2 Phase loss protection (current)—active for phase current >0.5 FLA setting Min. phase d0.25 max. phase for 1 second Min. phase d0.25 max. phase for 1 second 2 Thermal memory protection Yes Yes High load indicator — — 2 Pre-detection relays — — Factory installed Factory installed Aux. alarm, shunt trip, UVR Aux. alarm, shunt trip, UVR 2 2 2 Internal accessories 2 Notes 1 IEC ratings available only on FWMP and HFWMP. 2 For additional breaker solutions, see Page V4-T2-89. 2 2 2 2 2 2 V4-T2-268 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Contents Type ELC Current Limiter Attachment Description Page V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications. . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes). . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB). . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . V4-T2-270 V4-T2-273 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Type ELC Current Limiter Attachment (Size 0–4) Product Description Eaton’s Type ELC current limiter attachment for the MCP is designed to provide increased interrupting capacity. The combination may be used for the application up to 200,000 A symmetrical at 600 Vac, making the MCP suitable for use in network distribution systems or other applications where unusually high fault currents are available. The current limiter connects to the load end of the MCP and is provided with terminals suitable for copper or aluminum conductors. (See table at right.) Product Selection Limiters are coordinated with the MCP so that normal fault currents are interrupted automatically by the MCP without any damage to the limiter. Only the rare very high fault is opened by the limiter. Faults that are interrupted by the limiter also magnetically trip the MCP, opening all three poles, preventing singlephase operation. Each of the three poles of the Type ELC limiter is equipped with an indicator that extends when a fault is interrupted by the limiter. Type ELC Current Limiter Attachment 2 ELC Current Limiter Attachment MCP Rating (Amperes) Catalog Number 3 ELC3003R 7 ELC3007R 15 ELC3015R 30 ELC3030R 50 ELC3050R 100 ELC3100R 150 ELC3150R 2 2 2 2 2 2 Technical Data and Specifications 2 Type ELC Current Limiter Terminal Wire Sizes 1 Wire Range AWG Metric (mm2) 2 50 14–2 2.5–35 2 100 1–4/0 50–95 150 1–4/0 50–95 50 14–2 2 2.5–35 100 — — 150 — — Type ELC Current Limiter Maximum Amperes Standard Aluminum Terminals Non-Standard Terminals (Steel) Notes 1 Terminal wire connectors are UL listed for standard stranded wire sizes as defined in UL 486A or UL 486B. 2 Optional on special order for copper cable only. All HMCP 800 A and 1200 A come without terminals. For terminals, see Page V4-T2-217. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-269 2 2 2 2 2 2 2.3 2 Molded Case Circuit Breakers Series C Contents Current Limiting Circuit Breaker Module Description 2 Page Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes). . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes). . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Dimensions and Weights . . . . . . . . . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . 2 2 2 2 2 2 2 2 V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-271 V4-T2-272 V4-T2-273 V4-T2-304 2 2 2 2 Current Limiting Circuit Breaker Module 2 Product Overview Product Description Features and Benefits Standards and Certifications Power demand continues to grow in new and existing facilities. To meet increased demand, larger utility supplies, spot networks and large facility transformers are installed. The increased capacity of the electrical source results in increased fault currents in excess of 100 kA short-circuit protection. Eaton manufactures non-fused current limiting modules with interrupting capacities up to 200 kA at 600 Vac. Unlike fused current limiters with a one-time use, a current limiter module provides an automatic reset of the module after a short-circuit event. Resetting the moldedcase circuit breaker is the only action required to restore critical power to the system; there is no time wasted with sourcing the correct replacement fuses or module to bring the system back online. The current limiting breaker modules use a unique contact design to enhance the system protection similar to that of the circuit breaker. When high short-circuit current is flowing through the contacts of these modules, the design results in very high interrupting capacities and improved current limiting characteristics. Superior system protection: ● 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-270 ● ● ● Application Description High-performance breakers are most commonly applied when very high fault levels are available and with applications where the current limiting capability is used upstream of the final load to limit current. Typical loads include lighting, power distribution, and motor control applications. ● ● ● Auto reset improves system uptime and eliminates the need for finding replacement parts No fuses to replace, reducing the overall cost of ownership and the waste created by fuses Overloads, by using inverse time current tripping characteristics of the molded-case circuit breaker Low-level short circuits, by using instantaneous and/or short-time delay tripping characteristics of the molded-case circuit breaker High-level short circuits, by using ultra-high-speed, blow-apart contacts of the current limiting module in series with the circuit breaker contacts Let-through currents, by improved opening speed of the contacts, the resultant rapid rise of arc voltage introduces impedance into the system Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com ● UL 489 CSA C22.2 2.3 Molded Case Circuit Breakers Series C Product Selection 2 2 Series C High Performance Ratings Type Product Amperes 480 Vac (UL) 600 Vac (UL) FDC 3P thermal-magnetic Breaker only 15–225 100 35 With limiter 40–200 200 200 2 2 2 FD Frame FD IC Rating—200 kAIC at 600 Vac 1 Ampere Rating Breaker with Line Side Mounted Current Limiter 2 2 Breaker with Load Side Mounted Current Limiter 3 2 Thermal-Magnetic 40 FDC3040Q01 FDC3040Q02 45 FDC3045Q01 FDC3045Q02 50 FDC3050Q01 FDC3050Q02 60 FDC3060Q01 FDC3060Q02 70 FDC3070Q01 FDC3070Q02 80 FDC3080Q01 FDC3080Q02 90 FDC3090Q01 FDC3090Q02 100 FDC3100Q01 FDC3100Q02 110 FDC3110Q01 FDC3110Q02 125 FDC3125Q01 FDC3125Q02 150 FDC3150Q01 FDC3150Q02 175 FDC3175Q01 FDC3175Q02 200 FDC3200Q01 FDC3200Q02 2 2 2 2 2 2 2 2 2 Limiter Terminals Maximum Breaker Amperes Terminal Body Material Wire Type Metric Wire Range mm2 AWG Wire Range/ Number of Conductors Catalog Number Cu/Al 10–185 #8–350 (1) TA250FJ 4 2 2 Standard Pressure Type Terminals 250 Aluminum 2 Breaker Load Terminals (For Line Mounted Limiters Only) Maximum Breaker Amperes Terminal Body Material Wire Type AWG Wire Range Metric Wire Range mm2 Package of Three Terminals Catalog Number 2 2 2 Standard Pressure Type Terminals 100 Steel Cu/AI 14–1/0 2.5–50 3T100FB 225 Aluminum Cu/AI 4–4/0 25–95 3TA225FD 2 2 Notes 1 Line and load terminal included. 2 Two interphase barriers provided, mounted on line end of limiter, catalog number FJ1PBK. 3 Four interphase barriers provided, (2) line end of breaker, (2) load end of limiter. 4 Load side breaker terminations included for units configured with line mounted limiters. 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-271 2.3 2 2 2 Molded Case Circuit Breakers Series C Dimensions and Weights Approximate Dimensions in Inches (mm) Assembled Breaker and Current Limiting Module Frame Height Width Depth Weight in lbs (kg) FD + limiter 12.06 (306.3) 4.13 (104.9) 3.39 (86.1) 8.50 (3.86) 2 2 FD-Frame With Current Limiter Module 2 2 4.13 (104.9) 4.12 (104.6) 2 2 2 2 12.06 (306.3) 2 2 2 3.34 (84.8) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-272 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 3.96 (100.5) 3.39 (86.1) Molded Case Circuit Breakers Series C 2.3 Contents Series C Internal Accessories Description Page Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes) . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes) . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes). . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module. . . . . . . . . . . Internal Accessories Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications. . . . . . . . . . . . External Accessories . . . . . . . . . . . . . . . . . . . . . . . . V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-275 V4-T2-294 V4-T2-304 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Internal Accessories 2 Product Overview Alarm Switch For remote indication of automatic trip operation. Does not function with manual switching; however, it will operate when either a shunt trip or undervoltage release is operated. A “make” contact closes and a “break” contact opens when the alarm/lockout switch operates. The switch automatically resets when the circuit breaker is reset. Auxiliary Switch The auxiliary switch provides circuit breaker contact status information by monitoring the position of the molded cross bar that contains the moving contact arms. The auxiliary switch is used for remote indication and interlock system verification, and consists of one or two SPDT switches housed in a plug-in module. Each SPDT switch has one “a” and one “b” contact. When the circuit breaker contacts are open, the “a” contact is open and the “b” contact is closed. Auxiliary Switch and Alarm Switch Combination Each catalog number listed in tables on Pages V4-T2-278 and V4-T2-279 includes one auxiliary switch and one alarm switch. In an auxiliary switch ASL switch combination, the auxiliary switch is always mounted on the side of the plug-in module next to the center pole of the circuit breaker. Shunt Trip The shunt trip provides remote controlled tripping of the circuit breaker. The shunt trip consists of an intermittent rated solenoid with a tripping plunger and a cutoff switch assembled to a plug-in module. When required for ground fault protection applications, certain AC rated shunt trips, as noted in the electrical rating table, are suitable for operation at 55 percent of rated voltage. Select shunt trip catalog number for the voltage within the indicated voltage range. Shunt trip coils are designed to be applied at specific AC or DC voltages within the voltage range shown. Electrical ratings are also shown on applicable circuit breaker accessory nameplates. Low Energy Shunt Trip Low energy shunt trip devices are designed to operate from low energy output signals from dedicated current sensors typically applied in ground fault protection schemes. However, with a proper control voltage source, they may be applied in place of conventional trip devices for special applications. Flux paths surrounding permanent magnets used in the shunt trip assembly hold a charged spring poised in readiness to operate the circuit breaker trip mechanism. When a 100 microfarad capacitor charged to 28 Vdc is discharged through the shunt trip coil, the resultant flux opposes the permanent magnet flux field, which releases the stored energy in the spring to trip the circuit breaker. As the circuit breaker resets, the shunt trip reset arm is actuated by the circuit breaker handle, resetting the shunt trip. The plug-in module is mounted in retaining slots in the top of the trip unit. Coil is intermittent-rated only. Cutoff provisions required in control circuit. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-273 2.3 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Molded Case Circuit Breakers Series C Undervoltage Release Mechanism The undervoltage release mechanism monitors a voltage (typically a line voltage) and trips the circuit breaker when the voltage falls to between 70 and 35 percent of the solenoid coil rating. The undervoltage release mechanism consists of a continuous rated solenoid with a plunger and tripping lever mounted in a plug-in module. The tab on the tripping lever resets the undervoltage release mechanism when normal voltage has been restored and the circuit breaker handle is moved to the reset (or OFF) position. With less than pickup voltage applied to the undervoltage release mechanism, the circuit breaker contacts will not touch when a closing operation is attempted. Accessory Terminal Block (R-Frame) (For fixed-mounted configuration.) Internal accessory wiring leads are normally supplied with pigtail leads (18 AWG) that exit from the right side of the circuit breaker. Where specified, fixed-mounted accessory terminal blocks are available. A maximum of one 24-point terminal block can be installed on the right side of the circuit breaker for the internal accessories. PowerNet and Zone Interlock Kits (OPTIM 550 only) K-, L- and N-Frames Eaton’s PowerNet Communications Kit can be ordered to add PowerNet communications to an existing OPTIM 550 breaker in the field. An 18-inch (457.2 mm) wiring pigtail is routed to the rear of the breaker: two wires for PowerNet and two wires for 24 Vdc (45 mA load). It is recommended that the power supply be an “isolated high quality” unit. For convenience in determining the appropriate number of terminal block points required, refer to Page V4-T2-274. Note: Undervoltage release mechanism accessories are not designed for, and should not be used as, circuit interlocks. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-274 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Product Selection 2 Alarm Switch Alarm Switch Electrical Ratings Make 2 G-Frame Alarm Switch (RH Only) 1 Volts Frequency 2 Amperes Contact Arrangement Factory Suffix Catalog Number 234 6 1 Make/1 Break B3 1288C75G03 2 B13 1288C76G09 2 2 Alarm Switch Break 240 50/60 Hz Alarm Switch Auxiliary Switches Combination 240 50/60 Hz 6 1 Make/1 Break and 1A/1B 2 F-Frame Alarm Switch 1 Factory Installation Kit 5 Factory Mounted 2 Connection Type and Location 18-Inch (457.2 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block 2 Number of Contacts (Make and Break) Mounting Location (Pole) Same Side Rear 6 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 2 1 Left 7 B01 B02 B03 B04 A1L1LPK A1L1LTK Right B05 B06 B07 B08 A1L1RPK A1L1RTK 2 2 1 (Make only) 7 B09 B10 — B11 A2L1LPK A2L1LTK Right B12 B13 — B14 A2L1RPK A2L1RTK Single-pole B15 8 — — — — — Left 2 2 2 F-Frame HMCP Alarm Switch 1 Factory Installation Kit 5 Factory Mounted 2 Connection Type and Location 18-Inch (457.2 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block 2 Number of Contacts (Make and Break) Mounting Location (Pole) Same Side Rear 6 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 2 1 Left 7 B01 B02 B03 B04 MA1L1LPK MA1L1LTK Right B05 B06 B07 B08 MA1L1RPK MA1L1RTK 2 B09 B10 — B11 MA2L1LPK MA2L1LTK B12 B13 — B14 MA2L1RPK MA2L1RTK 2 Left 7 Right 2 J-Frame and HMCP (J) Alarm Switch Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 9 18-Inch (457.2 mm) Pigtail Leads Number of Contacts (Make and Break) Mounting Location (Pole) 1 2 Terminal Block Pigtail Leads 2 Terminal Block Same Side Rear 7 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number Left j B01 B02 B03 B04 A1L2LPK A1L2LTK Right B05 B06 B07 B08 A1L2RPK A1L2RTK 6 Notes 1 F-Frame circuit breakers are factory sealed. Underwriters Laboratories requires that internal accessories be installed at the factory. Internal accessories are UL listed for factory installation under E7819. Where local codes and standards permit and UL listing is not required, internal accessories can be field installed; however, this is not recommended for FDE breakers. Accessory installation should be done before the circuit breaker is mounted and connected. 2 Includes 24-inch (609.6 mm) external pigtail leads,18 AWG (16–0.010). 3 A maximum of two internal accessories may be mounted in a three-pole circuit breaker. 4 Suitable for mounting in right pole only of two- or three-pole breaker. 5 Not listed with Underwriters Laboratories; for field installation. 6 Standard pigtail lead exit location. 7 Standard mounting location. 8 Factory installation only. Leads exit load end of circuit breaker. 9 Listed with Underwriters Laboratories; for field installation on interchangeable trip unit breakers under E64983. j Standard mounting location—leads exit rear of breaker. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-275 2 2 2 2 2 2 2 2 2 2.3 2 2 2 2 2 Series C K-Frame and HMCP (K) Alarm Switch Catalog Number Catalog Number B03 B04 A1L3LPK A1L3LTK B07 B08 A1L3RPK A1L3RTK B10 — B11 A2L3LPK A2L3LTK B13 — B14 A2L3RPK A2L3RTK Suffix Number Suffix Number Suffix Number 1 Left 3 B01 B02 Right 4 B05 B06 Left 3 B09 Right 4 B12 2 L-, HMCP (L) and (M) Frames and Alarm Switch Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 1 18-Inch (457.2 mm) Pigtail Leads 2 Terminal Block Pigtail Leads Terminal Block Suffix Number Catalog Number Catalog Number B03 B04 A1L4LPK A1L4LTK B07 B08 A1L4RPK A1L4RTK B10 — B11 A2L4LPK A2L4LTK B13 — B14 A2L4RPK A2L4RTK Same Side Rear 2 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Left 3 B01 B02 Right B05 B06 Left 3 B09 Right B12 N-Frame and HMCP (N) Alarm Switch 2 Number of Sets of Contacts (1M and 1B) 2 1 2 2 2 Suffix Number Same Side 2 2 Terminal Block Opposite Side 1 2 Pigtail Leads Rear 2 2 2 Terminal Block Same Side Mounting Location (Pole) 2 Field Installation Kits 1 18-Inch (457.2 mm) Pigtail Leads Number of Sets of Contacts (1M and 1B) 2 Field Mounted Connection Type and Location Mounting Location (Pole) 2 2 Factory Mounted Number of Sets of Contacts (1M and 1B) 2 2 Molded Case Circuit Breakers Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 5 18-Inch (457.2 mm) Pigtail Leads Mounting Location (Pole) Terminal Block Catalog Number Suffix Number Suffix Number Suffix Number Left B01 B02 B03 B04 A1L5LPK A1L5LTK B05 B06 B07 B08 A1L5RPK A1L5RTK Left B09 B10 — B11 A2L5LPK A2L5LTK B12 B13 — B14 A2L5RPK A2L5RTK 3 R-Frame Alarm Switch (RH Only) Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 5 2 18-Inch (457.2 mm) Pigtail Leads Pigtail Leads Catalog Number 6 2 1 B05 A1L6RPK 2 B12 A2L6RPK 2 Catalog Number Same Side Suffix Number 6 2 Suffix Number Opposite Side Number of Contacts (Make and Break) 2 Terminal Block Rear 2 Right 3 Right 2 2 Pigtail Leads Same Side Notes 1 Listed with Underwriters Laboratories; for field installation on interchangeable trip unit breakers under E64983. 2 Standard mounting location. 3 Standard mounting location—leads exit rear of breaker. 4 Breakers with K-Frame OPTIM 550 can only accept accessories in left pole. 5 Listed with Underwriters Laboratories for field installation under E64983. 6 A maximum of three ASL plug-in modules may be installed in a circuit breaker. 2 2 2 V4-T2-276 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Auxiliary Switch Auxiliary Switch 2 G-Frame Auxiliary Switch (RH Only) Electrical Ratings a b Volts Frequency Amperes Contact Arrangement Factory Suffix Catalog Number 12 240 50/60 Hz 6 1a/1b A3 1288C74G03 240 50/60 Hz 6 2a/2b A6 1288C73G03 2 2 2 2 F-Frame and HMCP (F) Auxiliary Switch Factory Installation Kit 4 Factory Mounted Connection Type and Location 18-Inch (457.2 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block Number of Contacts A and B Mounting Location (Pole) Same Side Suffix Number Rear 3 Suffix Number Opposite Side Suffix Number Same Side Suffix Number Catalog Number Catalog Number 1 Left 5 A01 A02 A03 A04 A1X1PK A1X1LTK A15 7 A16 7 A17 7 — E1X1PK — A05 A06 A07 A08 A1X1PK A1X1RTK 8 A18 7 A19 7 A20 7 — — — A09 A10 — A11 A2X1LPK A2X1LTK Left 5 A21 7 A22 7 — — E2X1LPK — Right or Neutral 6 A12 A13 — A14 A2X1RPK A2X1RTK 8 Right or Neutral 6 A23 7 A24 7 — — E2X1RPK — Left 5 Right or Neutral 6 Right or Neutral 6 2 Left 5 Factory Mounted Right Terminal Block Pigtail Leads Terminal Block Same Side Suffix Number 2 Catalog Number Catalog Number 2 A30 A31 A32 — — — 2 A33 A34 A35 — — — Factory Mounted Field Mounted Connection Type and Location Factory Installation Kit j 18-Inch (457.2 mm) Pigtail Leads 1 2 2 Opposite Side Suffix Number 2 2 J-Frame and HMCP (J) Auxiliary Switch Number of Contacts A and B 2 Rear Suffix Number Trip Unit Type 210+ 1 2 2 Trip Unit Type 310+ Right 2 Same Side Suffix Number 18-Inch (457.2 mm) Pigtail Leads 1 2 Factory Installation Kit 4 Connection Type and Location Mounting Location (Pole) 2 2 F-Frame with Electronic Trip Unit Auxiliary Switch 9 Number of Contacts A and B 2 Mounting Location (Pole) Same Side Suffix Number Rear 3 Suffix Number Opposite Side Suffix Number 2 Terminal Block Pigtail Leads Terminal Block Same Side Suffix Number 2 Catalog Number Catalog Number 2 2 Left A01 A02 A03 A04 A1X2PK A1X2LTK Right k A05 A06 A07 A08 A1X2PK A1X2RTK 4 Left A09 A10 — A11 A2X2PK A2X2LTK Right k A12 A13 — A14 A2X2PK A2X2RTK 4 Notes 1 Includes 24-inch external pigtail leads, 18 AWG (16–0.010). 2 A maximum of two internal accessories may be mounted in a three-pole circuit breaker. Suitable for mounting in right pole only of two- or three-pole breaker. 3 Standard pigtail lead exit location. 4 Not listed with Underwriters Laboratories; for field installation. 5 Pigtail wire size: 18 AWG (0.82 mm2). 6 Not for use on F-Frame with electronic trip unit. 7 125 volts (max.), 50/60 Hz switch for use in electronic circuit of 100 micro amperes and 15 Vdc minimum. 8 Not for use on four-pole circuit breakers. 9 Only for use on three-pole F-Frame breakers with electronic trip unit. Installation auxiliary switch for FD electronic breakers on right pole must be performed at breaker factory. j Listed with Underwriters Laboratories for field installation or interchangeable trip unit breakers under E64983. k Standard mounting location—leads exit rear of breaker. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-277 2 2 2 2 2 2 2 2.3 2 Molded Case Circuit Breakers Series C K-Frame and HMCP (K) Auxiliary Switch 2 2 2 2 18-Inch (457.2 mm) Pigtail Leads Same Side Suffix Number 2 2 2 2 2 2 2 2 Terminal Block Pigtail Leads Terminal Block Same Side Suffix Number Catalog Number Catalog Number A01 A02 A03 A04 A1X3PK A1X3LTK Right 23 A05 A06 A07 A08 A1X3PK A1X3RTK 4 Left A09 A10 — A11 A2X3PK A2X3LTK Right 23 A12 A13 — A14 A2X3PK A2X3RTK 4 — 2 3 Right A21 A22 — — 1482D28G10 67 Left A18 — — A15 A3X3LPK A3X3LTK Right 3 A17 — — A16 A3X3RPK A3X3RTK 4 L-, HMCP (L) and (M) Frames and Auxiliary Switch Factory Mounted Field Mounted Connection Type and Location Factory Installation Kit 1 18-Inch (457.2 mm) Pigtail Leads Number of Contacts A and B 1 2 3 Same Side Suffix Number Mounting Location (Pole) Terminal Block Pigtail Leads Terminal Block Rear 2 Suffix Number Opposite Side Suffix Number Same Side Suffix Number Catalog Number Catalog Number A1X4LTK Left A01 A02 A03 A04 A1X4PK Right 2 A05 A06 A07 A08 A1X4PK A1X4RTK 4 Left A09 A10 — A11 A2X4PK A2X4LTK Right 2 A12 A13 — A14 A2X4PK A2X4RTK 4 Left A18 — — A15 A3X4PK A3X4LTK Right 2 A17 — — A16 A3X4PK A3X4RTK 4 N-Frame and HMCP (N) Auxiliary Switch 2 2 Opposite Side Suffix Number Left 2 2 Rear 2 Suffix Number 1 2 2 Factory Installation Kit 1 Mounting Location (Pole) 2 2 Field Mounted Connection Type and Location Number of Contacts A and B 2 2 Factory Mounted Factory Mounted Field Mounted Connection Type and Location Factory Installation Kit 1 18-Inch (457.2 mm) Pigtail Leads Number of Contacts A and B 1 2 3 Terminal Block Pigtail Leads Terminal Block Mounting Location (Pole) Same Side Suffix Number Rear 2 Suffix Number Opposite Side Suffix Number Same Side Suffix Number Catalog Number Catalog Number Left A01 A02 A03 A04 A1X5PK A1X5LTK Right 2 A05 A06 A07 A08 A1X5PK A1X5RTK 4 Left A09 A10 — A11 A2X5PK A2X5LTK Right 2 A12 A13 — A14 A2X5PK A2X5RTK 4 Left A18 — — A15 A3X5LPK A3X5LTK Right 2 A17 — — A16 A3X5RPK A3X5RTK 4 R-Frame Auxiliary Switch (RH Only) 2 Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 1 2 Number of Contacts A and B 18-Inch (457.2 mm) Pigtail Leads Pigtail Leads Suffix Number 5 Catalog Number 5 2 A12 A2X6RPK 4 A19 A4X6RPK 2 2 2 2 2 Notes 1 Listed with Underwriters Laboratories for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 Breakers with K-Frame OPTIM 550 can only accept accessories in left pole. 4 Not for use on four-pole circuit breakers. 5 A maximum of two auxiliary switches (any combination of 2a/2b or 4a/4b plug-in modules may be installed in a circuit breaker. 6 This option is not field installable. 7 Available on the OPTIM 550 only. Communications are not available with this option. V4-T2-278 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Auxiliary Switch and Alarm Switch Combination Auxiliary Switch and Alarm Switch Combination a b 2 F-Frame Auxiliary Switch and Alarm Switch Combination 1 Factory Mounted Factory Installation Kit 2 2 Pigtail Leads Terminal Block 2 Connection Type and Location 18-Inch (457 mm) Pigtail Leads Terminal Block Same Side Rear 3 Same Side Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number Left 3 C01 C02 C03 AAL1LPK AAL1LTK Right C04 C05 C06 AAL1RPK AAL1RTK 4 Mounting Location (Pole) 2 2 2 Factory Installation Kit 2 2 Pigtail Leads Terminal Block 2 F-Frame HMCP Auxiliary Switch and Alarm Switch Combination Factory Mounted Connection Type and Location 18-Inch (457 mm) Pigtail Leads Terminal Block 3 2 Same Side Mounting Location (Pole) Same Side Rear Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number Left 4 C01 C02 C03 MAAL1LPK MAAL1LTK Right C04 C05 C06 MAAL1RPK MAAL1RPK 2 2 2 J-Frame and HMCP (J) Auxiliary Switch and Alarm Switch Combination Factory Mounted Field Mounted Field Installation Kits 5 Connection Type and Location Number of Sets of Contacts (1A and 1B) (1M–1B) Mounting Location (Pole) Same Side Rear 6 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 1 Left C01 C02 — C03 AAL2LPK AAL2LTK Right 4 C04 C05 — C06 AAL2RPK AAL2RTK 4 18-Inch (457 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block Field Mounted Mounting Location (Pole) Same Side Rear 6 Opposite Side Same Side Suffix Number Suffix Number Suffix Number 1 Left C01 C02 Right 67 C04 C05 18-Inch (457 mm) Pigtail Leads Right C07 C08 Terminal Block 2 2 2 Field Installation Kits 5 Connection Type and Location Number of Sets of Contacts (1A and 1B) (1M–1B) 2 2 K-Frame and HMCP (K) Auxiliary Switch and Alarm Switch Combination Factory Mounted 2 Pigtail Leads Terminal Block 2 Suffix Number Catalog Number Catalog Number 2 — C03 AAL3LPK AAL3LTK — C06 AAL3RPK 8 2 — — 1482D28G09 AAL3RTK 9j — Notes 1 Auxiliary switch and alarm switch combination options (Cxx) are not available on FDE 310+ with LSG or LSIG trip units due to exit wire limitations. To obtain both features, order a left mounting alarm switch (B01-B04 or B09-B11), and right mounting auxiliary switch (A30-A32). 2 Not listed with Underwriters Laboratories for field installation. 3 Standard mounting location. 4 Not for use on four-pole circuit breakers 5 Listed with Underwriters Laboratories for field installation of interchangeable trip unit breakers under E64983. 6 Standard mounting location—leads exit rear of breaker. 7 Breakers with K-Frame OPTIM 550 can only accept accessories in left pole. 8 Will not install on OPTIM Trip (RH). 9 Available on the OPTIM 550 only. Communications are not available with this option. j This option is not field installable. 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-279 2.3 2 Molded Case Circuit Breakers Series C L-, HMCP (L) and (M) Frames and Auxiliary Switch and Alarm Switch Combination 2 2 2 2 2 2 2 Field Mounted Connection Type and Location Field Installation Kits 1 18-Inch (457 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block Catalog Number Catalog Number C03 AA114LPK AA114LTK C06 AA114RPK AA114RTK 3 C12 AA214LPK AA214LTK — C13 AA214RPK AA214RTK 3 — — — AA314LPK — — — — AA314RPK — Same Side Rear 2 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number Number of Sets of Contacts Mounting Location (Pole) 1A, 1B and 1 Make/1 Break Left C01 C02 — Right 2 C04 C05 — 2A, 2B and 1 Make/1 Break Left C07 C08 — Right 2 C10 C11 3A, 3B and 1 Make/1 Break Left C14 Right 2 C15 N-Frame and HMCP (N) Auxiliary Switch and Alarm Switch Combination 2 2 Factory Mounted Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 1 18-Inch (457 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block Suffix Number Catalog Number Catalog Number Number of Sets of Contacts Mounting Location (Pole) Same Side Rear 2 Opposite Side Same Side Suffix Number Suffix Number Suffix Number 2 1A, 1B and 1 Make/1 Break Left 2 2A, 2B and 1 Make/1 Break 2 2 2 2 C01 C02 — C03 AA115LPK AA115LTK 2 C04 C05 — C06 AA115RPK AA115RTK 3 Left C07 C08 — C12 AA215LPK AA215LTK Right 2 C10 C11 — C13 AA215RPK AA215RTK 3 Right Notes 1 Listed with Underwriters Laboratories for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 Not for use on four-pole circuit breaker. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-280 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Shunt Trip Shunt Trip 2 2 G-Frame Shunt Trip (LH Three-Pole Only) Electrical Ratings ST a Catalog Number 2 2 Volts Frequency Amperes Suffix Number 120 50/60 Hz 1.1 S1 1373D62G01 240 50/60 Hz 2.1 S2 1373D62G02 12 DC 2.8 S3 1373D62G15 24 DC 5.7 S4 1373D62G16 24 60 Hz — S7 1373D62G20 2 2 2 F-Frame and HMCP (F) Shunt Trip 2 Factory Installation Kit 1 Factory Mounted Connection Type and Location 18-Inch (457.2 mm) Pigtail Leads 2 Terminal Block Pigtail Leads Terminal Block Same Side Rear 3 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 12–24 Vac or Vdc S01 S02 S03 S04 SNT1LP03K SNT1LT03K 48–127 Vac or 48–60 Vdc 4 S05 S06 S07 S08 SNT1LP08K SNT1LT08K 208–380 Vac or 110–127 Vdc S09 S10 S11 S12 SNT1LP12K SNT1LT12K 415–600 Vac or 220–250 Vdc S13 S14 S15 S16 SNT1LP18K SNT1LT18K S18 S19 S20 SNT1RP03K SNT1RT03K 6 Voltage Rating (AC Frequency = 50/60 Hz) 2 2 Left-Pole Mounting AC/DC Ratings Right- or Neutral-Pole Mounting AC/DC Ratings 5 12–24 Vac or Vdc S17 2 48–127 Vac or 48–60 Vdc 4 S21 S22 S23 S24 SNT1RP08K SNT1RT08K 6 208–380 Vac or 110–127 Vdc S25 S26 S27 S28 SNT1RP12K SNT1RT12K 6 415–600 Vac or 220–250 Vdc S29 S30 S31 S32 SNT1RP18K SNT1RT18K 6 2 2 2 2 2 2 Notes 1 Not listed with Underwriters Laboratories, for field installation. 2 Pigtail wire size: 18 AWG (0.82 mm2). 3 Standard pigtail lead exit location. 4 120 Vac marked suitable for ground fault protection devices. 5 Standard mounting location. 6 Not for use on four-pole circuit breakers. 2 2 2 G-Frame circuit breakers are factory sealed. Underwriters Laboratories requires that internal accessories be installed at the factory. Internal accessories are UL listed for factory installation under E7819. Where local codes and standards permit and UL listing is not required, internal accessories can be field installed. Accessory installation should be done before the circuit breaker is mounted and connected. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-281 2.3 2 Molded Case Circuit Breakers Series C J-Frame and HMCP (J) Shunt Trip Factory Mounted Field Mounted 2 Connection Type and Location Field Installation Kits 1 2 Same Side Rear 2 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number 2 18-Inch (457.2 mm) Pigtail Leads Voltage Rating (AC Frequency = 50/60 Hz) Terminal Block Pigtail Leads Terminal Block Catalog Number Catalog Number Left-Pole Mounting AC/DC Ratings 2 2 12–24 Vac or Vdc S41 S42 S43 S44 SNT2P04K SNT2T04K 2 48–60 Vac or Vdc S49 S50 S51 S52 SNT2P06K SNT2T06K 110–240 Vac or 110–125 Vdc 3 S09 S10 S11 S12 SNT2P11K SNT2T11K 2 380–440 Vac or 220–250 Vdc S13 S14 S15 S16 SNT2P14K SNT2T14K 480–600 Vac S17 S18 S19 S20 SNT2P18K SNT2T18K 2 Right- or Neutral-Pole Mounting AC/DC Ratings 12–24 Vac or Vdc S45 S46 S47 S48 SNT2P04K SNT2T04K 4 2 48–60 Vac or Vdc S53 S54 S55 S56 SNT2P06K SNT2T06K 4 2 S29 S30 S31 S32 SNT2P11K SNT2T11K 4 380–440 Vac or 220–250 Vdc S33 S34 S35 S36 SNT2P14K SNT2T14K 4 480–600 Vac S37 S38 S39 S40 SNT2P18K SNT2T18K 4 2 2 110–240 Vac or 110–125 Vdc 3 K-Frame and HMCP (K) Shunt Trip 2 Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 1 2 18-Inch (457.2 mm) Pigtail Leads Terminal Block Pigtail Leads Terminal Block Suffix Number Catalog Number Catalog Number S43 S44 SNT3P04K SNT3T04K S51 S52 SNT3P06K SNT3T06K S10 S11 S12 SNT3P11K SNT3T11K S13 S14 S15 S16 SNT3P14K SNT3T14K S17 S18 S19 S20 SNT3P18K SNT3T18K S45 S46 S47 S48 SNT3P04K SNT3T04K 4 48–60 Vac or Vdc S53 S54 S55 S56 SNT3P06K SNT3T06K 4 2 110–240 Vac or 110–125 Vdc 3 S29 S30 S31 S32 SNT3P11K SNT3T11K 4 2 380–440 Vac or 220–250 Vdc S33 S34 S35 S36 SNT3P14K SNT3T14K 4 480–600 Vac S37 S38 S39 S40 SNT3P18K SNT3T18K 4 Same Side Rear 2 Opposite Side Same Side Suffix Number Suffix Number Suffix Number 12–24 Vac or Vdc S41 S42 2 48–60 Vac or Vdc S49 S50 2 110–240 Vac or 110–125 Vdc 3 S09 380–440 Vac or 220–250 Vdc 2 480–600 Vac 2 12–24 Vac or Vdc 2 2 2 2 2 Voltage Rating (AC Frequency = 50/60 Hz) Left-Pole Mounting AC/DC Ratings 2 Right- or Neutral-Pole Mounting AC/DC Ratings 56 Notes 1 Listed with Underwriters Laboratories for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 Suitable for use with Class 1 ground fault sensing element. 4 Not for use on four-pole circuit breakers. 5 For use with KT (thermal-magnetic) trip units only. 6 Breakers with K-Frame OPTIM 550 can only accept accessories in left pole. 2 2 2 2 2 V4-T2-282 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C L-, HMCP (L) and (M) Frames and Shunt Trip Factory Mounted 2 Field Mounted Connection Type and Location Field Installation Kits 18-Inch (457.2 mm) Pigtail Leads 2 1 Terminal Block Same Side Rear 2 Opposite Side Same Side Pigtail Leads Terminal Block Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 12–24 Vac or Vdc S01 S02 S03 S04 SNT4LP03K SNT4LT03K 48–60 Vac S05 S06 S07 S08 SNT4LP05K SNT4LT05K 48–60 Vdc S85 S86 S87 — SNT4LP23K SNT4LT23K 110–240 Vac S09 S10 S11 S12 SNT4LP11K SNT4LT11K 110–125 Vdc S41 S42 S43 S44 SNT4LP26K SNT4LT26K 380–440 Vac or 220–250 Vdc S13 S14 S15 S16 SNT4LP14K SNT4LT14K 480–600 Vac S17 S18 S19 S20 SNT4LP18K SNT4LT18K 12–24 Vac or Vdc S21 S22 S23 S24 SNT4RP03K SNT4RT03K 48–60 Vac S25 S26 S27 S28 SNT4RP05K SNT4RT05K 48–60 Vdc S88 S89 S90 — SNT4RP23K SNT4RT23K 110–240 Vac S29 S30 S31 S32 SNT4RP11K SNT4RT11K 110–125 Vdc S45 S46 S47 S48 SNT4RP26K SNT4RT26K 380–440 Vac or 220–250 Vdc S33 S34 S35 S36 SNT4RP14K SNT4RT14K 480–600 Vac S37 S38 S39 S40 SNT4RP18K SNT4RT18K Voltage Rating (AC Frequency = 50/60 Hz) 2 2 Left-Pole Mounting AC/DC Ratings 2 Right-Pole Mounting AC/DC Ratings 3 Notes 1 Listed with Underwriters Laboratories, for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 For use with LT (thermal-magnetic) three-pole trip units only. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-283 2.3 2 Molded Case Circuit Breakers Series C N-Frame and HMCP (N) Shunt Trip Factory Mounted Field Mounted 2 Connection Type and Location Field Installation Kits 1 2 Same Side Rear 2 Opposite Side Same Side Pigtail Leads Terminal Block Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 9–24 Vac or Vdc S01 S02 S03 S04 SNT5LP03K SNT5LT03K 48–60 Vac S05 S06 S07 S08 SNT5LP05K SNT5LT05K 2 2 2 18-Inch (457.2 mm) Pigtail Leads Voltage Rating (AC Frequency = 50/60 Hz) Terminal Block Left-Pole Mounting AC/DC Ratings 2 3 S09 S10 S11 S12 SNT5LP11K SNT5LT11K 2 110–125 Vdc S41 S42 S43 S44 SNT5LP26K SNT5LT26K 380–440 Vac or 220–250 Vdc S13 S14 S15 S16 SNT5LP14K SNT5LT14K 2 480–600 Vac S17 S18 S19 S20 SNT5LP18K SNT5LT18K 48–60 Vdc S21 S22 S23 S24 SNT5LP23K SNT5LT23K 110–240 Vac 2 2 R-Frame Shunt Trip (RH Only) 2 Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 1 18-Inch (457.2 mm) Pigtail Leads Pigtail Leads 2 Voltage Rating (AC Frequency = 50/60 Hz) Suffix Number 4 Catalog Number 4 2 24 Vac or Vdc S21 SNT6P03K 48–60 Vac S25 SNT6P05K 2 110–240 Vac S29 SNT6P11K 2 380–440 Vac or 220–250 Vdc S33 SNT6P14K 480–600 Vac S37 SNT6P18K 2 48–60 Vdc S88 SNT6P23K 110–125 Vdc S45 SNT6P26K 2 2 2 Notes 1 Listed with Underwriters Laboratories for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 Supply voltages suitable for use with Class 1 GFP devices. Marking label included with accessory kits. 4 A maximum of two shunt trip plug-in modules may be installed in a circuit breaker. 2 2 2 2 2 2 2 2 2 2 2 V4-T2-284 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Low Energy Shunt Trip Ordering Information 2 Select shunt trip catalog number for the voltage within the indicated voltage range. Shunt trip coils are designed to be applied at specific AC or DC voltages within the voltage range shown. Electrical ratings are also shown on applicable circuit breaker accessory nameplates. 2 Low Energy Shunt Trip 2 2 2 2 2 F-, J-, K-, L-, M-, N- and R-Frames and HMCPs Low Energy Shunt Trip 1 Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 2 18-Inch (457.2 mm) Pigtail Leads UV Mounting Positions (Pole) Same Side Rear Suffix Number 3 Suffix Number 2 2 Terminal Block Opposite Side Same Side Pigtail Leads Terminal Block Suffix Number Suffix Number Catalog Number Catalog Number 2 2 F-Frame 4 LST1LTK 2 4 Left NO1 NO2 NO3 NO4 LST1LPK Right 3 NO5 NO6 NO7 NO8 LST1RPK 4 LST1RTK 4 Left NO1 NO2 NO3 — LST2LPK — Right 3 NO5 NO6 NO7 — LST2RPK — 2 NO1 NO2 NO3 — LST3LPK — 2 NO5 NO6 NO7 — LST3RPK — 2 2 2 J-Frame K-Frame Left 3 Right 56 L- and M-Frames Left NO1 NO2 NO3 — LST4LPK — Right NO5 NO6 NO7 — LST4RPK — 2 NO1 NO2 NO3 — LST5LPK — 2 NO1 — — — LST6RPK — N-Frame Left 3 R-Frame Right 2 Notes 1 Cutoff provisions required in control circuit. 2 Listed with Underwriters Laboratories for field installation under E64983. 3 Standard mounting location—leads exit rear of breaker. 4 For F-Frame HMCP, add an “M” to beginning of catalog number. Field Installation Kit referenced for factory use only, not UL listed for field installation. 5 For use with thermal-magnetic trip units only. 6 Breakers with K-Frame OPTIM 550 can only accept accessories in left pole. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-285 2.3 2 2 2 2 2 2 2 2 2 Molded Case Circuit Breakers Series C Undervoltage Release Mechanism Ordering Information Select handle reset undervoltage release mechanism catalog number for the voltage within the indicated voltage range. Undervoltage release mechanism coils are designed to be applied at specific AC or DC voltages within the voltage range shown on applicable circuit breaker accessory nameplates. Undervoltage Release Mechanism G-Frame Undervoltage Release Mechanism (LH Three-Pole Only) Electrical Ratings Volts (AC Only) Frequency (Hz) Amperes Style Numbers 123 Factory Suffix 120 50/60 0.05 1373D62G03 T1 2 24 50/60 0.22 1373D62G04 T2 48 50/60 0.11 1373D62G05 T3 2 60 50/60 0.10 1373D62G06 T4 110 50 0.049 1373D62G07 T5 2 208 60 0.026 1373D62G08 T6 2 220 50 0.025 1373D62G09 T7 240 50/60 0.024 1373D62G10 T8 2 380 50 0.015 1373D62G11 T9 415 50 0.013 1373D62G12 T10 2 440 50 0.012 1373D62G13 T11 480 60 0.01 1373D62G14 T12 2 UV 2 Notes 1 Includes 24-inch (609.6 mm) external pigtail leads, 18 AWG (16–0.010). 2 A maximum of two internal accessories may be mounted in a three-pole circuit breaker. 3 Suitable for mounting in left pole only of three-pole breaker. 2 2 G-Frame circuit breakers are factory sealed. Underwriters Laboratories requires that internal accessories be installed at the factory. Internal accessories are UL listed for factory installation under E7819. Where local codes and standards permit and UL listing is not required, internal accessories can be field installed. Accessory installation should be done before the circuit breaker is mounted and connected. 2 2 2 2 2 2 2 2 2 2 2 V4-T2-286 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 F-Frame Factory Mounted (For F-Frame Breaker and F-Frame HMCP) Undervoltage Release Mechanism 2 Connection Type and Location 18-Inch Pigtail Leads Rear 1 Opposite Side Same Side Suffix Number Suffix Number Suffix Number Suffix Number 12 Vac U01 U02 U03 U04 24 Vac U05 U06 U07 U08 48 Vac U37 U38 U39 U40 60 Vac U97 U98 U99 U100 110–127 Vac U13 U14 U15 U16 208–240 Vac U17 U18 U19 U20 380–480 Vac U21 U22 U23 U24 525–600 Vac U25 U26 U27 U28 Voltage Rating (AC Freq. = 50/60 Hz) 2 Terminal Block Same Side 2 2 Left-Pole Mounting AC Ratings 2 2 2 2 2 Right-Pole Mounting AC Ratings 23 12 Vac U49 U50 U51 U52 24 Vac U53 U54 U55 U56 48 Vac U85 U86 U87 U88 60 Vac U101 U102 U103 U104 110–127 Vac U61 U62 U63 U64 208–240 Vac U65 U66 U67 U68 380–480 Vac U69 U70 U71 U72 525–600 Vac U73 U74 U75 U76 12 Vdc U29 U30 U31 U32 24 Vdc U33 U34 U35 U36 48 Vdc U37 U38 U39 U40 60 Vdc U97 U98 U99 U100 110–127 Vdc U41 U42 U43 U44 220–250 Vdc U45 U46 U47 U48 2 2 2 2 2 Left-Pole Mounting DC Ratings 2 2 2 2 Right-Pole Mounting DC Ratings 23 12 Vdc U77 U78 U79 U80 24 Vdc U81 U82 U83 U84 48 Vdc U85 U86 U87 U88 60 Vdc U101 U102 U103 U104 110–127 Vdc U89 U90 U91 U92 220–250 Vdc U93 U94 U95 U96 2 2 2 2 Notes 1 Standard pigtail lead exit location. 2 Standard mounting location. 3 Not for use on right pole of four-pole circuit breaker. 2 F-Frame circuit breakers are factory sealed. Underwriters Laboratories requires that internal accessories be installed at the factory. Internal accessories are UL listed for factory installation under E7819. Where local codes and standards permit and UL listing is not required, internal accessories can be field installed. Accessory installation should be done before the circuit breaker is mounted and connected. 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-287 2.3 2 Molded Case Circuit Breakers Series C F-Frame Field Mounted Undervoltage Release Mechanism F-Frame Breaker 2 2 Voltage Rating (AC Freq. = 50/60 Hz) 2 Left-Pole Mounting AC Ratings 2 2 2 2 2 F-Frame Breaker HMCP Factory Installation Kits 1 Pigtail Leads Terminal Block Pigtail Leads Terminal Block Catalog Number Catalog Number Catalog Number Catalog Number MUVH1LT02K 12 Vac UVH1LP02K UVH1LT02K MUVH1LP02K 24 Vac UVH1LP03K UVH1LT03K MUVH1LP03K MUVH1LT03K 48 Vac UVH1LP22K UVH1LT22K MUVH1LP22K MUVH1LT22K MUVH1LT24K 60 Vac UVH1LP24K UVH1LT24K MUVH1LP24K 110–127 Vac UVH1LP08K UVH1LT08K MUVH1LP08K MUVH1LT08K 208–240 Vac UVH1LP11K UVH1LT11K MUVH1LP11K MUVH1LT11K 380–480 Vac UVH1LP15K UVH1LT15K MUVH1LP15K MUVH1LT15K 525–600 Vac UVH1LP18K UVH1LT18K MUVH1LP18K MUVH1LT18K Right-Pole Mounting AC Ratings 23 12 Vac UVH1RP02K UVH1RT02K MUVH1RP02K MUVH1RT02K 24 Vac UVH1RP03K UVH1RT03K MUVH1RP03K MUVH1RT03K 2 48 Vac UVH1RP22K UVH1RT22K MUVH1RP22K MUVH1RT22K 60 Vac UVH1RP24K UVH1RT24K MUVH1RP24K MUVH1RT24K 2 110–127 Vac UVH1RP08K UVH1RT08K MUVH1RP08K MUVH1RT08K 2 208–240 Vac UVH1RP11K UVH1RT11K MUVH1RP11K MUVH1RT11K 380–480 Vac UVH1RP15K UVH1RT15K MUVH1RP15K MUVH1RT15K 525–600 Vac UVH1RP18K UVH1RT18K MUVH1RP18K MUVH1RT18K 2 2 2 2 2 2 2 Left-Pole Mounting DC Ratings 12 Vdc UVH1LP20K UVH1LT20K MUVH1LP20K MUVH1LT20K 24 Vdc UVH1LP21K UVH1LT21K MUVH1LP21K MUVH1LT21K 48 Vdc UVH1LP22K UVH1LT22K MUVH1LP22K MUVH1LT22K 60 Vdc UVH1LP24K UVH1LT24K MUVH1LP24K MUVH1LT24K 110–127 Vdc UVH1LP26K UVH1LT26K MUVH1LP26K MUVH1LT26K 220–250 Vdc UVH1LP28K UVH1LT28K MUVH1LP28K MUVH1LT28K MUVH1RT20K Right-Pole Mounting DC Ratings 23 12 Vdc UVH1RP20K UVH1RT20K MUVH1RP20K 24 Vdc UVH1RP21K UVH1RT21K MUVH1RP21K MUVH1RT21K 2 48 Vdc UVH1RP22K UVH1RT22K MUVH1RP22K MUVH1RT22K 2 60 Vdc UVH1RP22K UVH1RT22K MUVH1RP22K MUVH1RT22K 110–127 Vdc UVH1RP26K UVH1RT26K MUVH1RP26K MUVH1RT26K 220–250 Vdc UVH1RP28K UVH1RT28K MUVH1RP28K MUVH1RT28K 2 2 2 Notes 1 Not listed with Underwriters Laboratories, for field installation. 2 Standard mounting location. 3 Not for use on right pole of four-pole circuit breaker. 2 2 2 2 2 2 V4-T2-288 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 J-Frame and HMCP (J) Undervoltage Release Mechanism Factory Mounted Connection Type and Location Field Installation Kits 2 2 Terminal Block 1 18-Inch (457.2 mm) Pigtail Leads Voltage Rating (AC Freq. = 50/60 Hz) 2 Field Mounted Same Side Rear 2 Opposite Side Same Side Pigtail Leads Terminal Block 3 Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 2 2 Left-Pole Mounting AC Ratings 4 12 Vac U05 U06 U07 U08 UVH2LP02K UVH2LT02K 24 Vac U09 U10 U11 U12 UVH2LP03K UVH2LT03K 48–60 Vac U13 U14 U15 U16 UVH2LP05K UVH2LT05K 110–127 Vac U17 U18 U19 U20 UVH2LP08K UVH2LT08K 208–240 Vac U21 U22 U23 U24 UVH2LP11K UVH2LT11K 380–480 Vac U25 U26 U27 U28 UVH2LP15K UVH2LT15K U39 U40 UVH2RP02K UVH2RT02K 2 2 2 2 Right-Pole Mounting AC Ratings 3 2 12 Vac U37 U38 24 Vac U41 U42 U43 U44 UVH2RP03K UVH2RT03K 48–60 Vac U45 U46 U47 U48 UVH2RP05K UVH2RT05K 110–127 Vac U49 U50 U51 U52 UVH2RP08K UVH2RT08K 208–240 Vac U53 U54 U55 U56 UVH2RP11K UVH2RT11K 380–480 Vac U57 U58 U59 U60 UVH2RP15K UVH2RT15K 2 2 2 2 Left-Pole Mounting DC Ratings 4 12 Vdc T01 T02 T03 T04 UVH2LP20K UVH2LT20K 24 Vdc T05 T06 T07 T08 UVH2LP21K UVH2LT21K 48–60 Vdc T09 T10 T11 T12 UVH2LP23K UVH2LT23K 110–127 Vdc T13 T14 T15 T16 UVH2LP26K UVH2LT26K 220–250 Vdc T17 T18 T19 T20 UVH2LP28K UVH2LT28K 2 2 2 2 Right-Pole Mounting DC Ratings 3 12 Vdc T21 T22 T23 T24 UVH2RP20K UVH2RT20K 24 Vdc T25 T26 T27 T28 UVH2RP21K UVH2RT21K 48–60 Vdc T29 T30 T31 T32 UVH2RP23K UVH2RT23K 110–127 Vdc T33 T34 T35 T36 UVH2RP26K UVH2RT26K 220–250 Vdc T37 T38 T39 T40 UVH2RP28K UVH2RT28K 2 2 2 Notes 1 For electrical rating data for manual, automatic and electrical reset undervoltage release mechanisms, refer to Eaton. 2 Listed with Underwriters Laboratories for field installation under E64983. 3 Not for use on right pole of four-pole circuit breakers. 4 Standard mounting location—leads exit rear of breaker. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-289 2.3 2 Molded Case Circuit Breakers Series C K-Frame and HMCP (K) Undervoltage Release Mechanism Factory Mounted Field Mounted 2 Connection Type and Location Field Installation Kits 1 2 18-Inch (457.2 mm) Pigtail Leads Terminal Block Same Side Rear 2 Opposite Side Same Side Pigtail Leads Terminal Block Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 2 Voltage Rating (AC Freq. = 50/60 Hz) 2 Left-Pole Mounting AC Ratings 2 12 Vac U05 U06 U07 U08 UVH3LP02K UVH3LT02K 2 24 Vac U09 U10 U11 U12 UVH3LP03K UVH3LT03K 48–60 Vac U13 U14 U15 U16 UVH3LP05K UVH3LT05K 2 110–127 Vac U17 U18 U19 U20 UVH3LP08K UVH3LT08K 2 208–240 Vac U21 U22 U23 U24 UVH3LP11K UVH3LT11K 380–480 Vac U25 U26 U27 U28 UVH3LP15K UVH3LT15K UVH3RT02K 2 Right-Pole Mounting AC Ratings 345 12 Vac U37 U38 U39 U40 UVH3RP02K 2 24 Vac U41 U42 U43 U44 UVH3RP03K UVH3RT03K 48–60 Vac U45 U46 U47 U48 UVH3RP05K UVH3RT05K 110–127 Vac U49 U50 U51 U52 UVH3RP08K UVH3RT08K 2 208–240 Vac U53 U54 U55 U56 UVH3RP11K UVH3RT11K 380–480 Vac U57 U58 U59 U60 UVH3RP15K UVH3RT15K 2 Left-Pole Mounting DC Ratings 2 12 Vdc T01 T02 T03 T04 UVH3LP20K UVH3LT20K 2 24 Vdc T05 T06 T07 T08 UVH3LP21K UVH3LT21K 2 48–60 Vdc T09 T10 T11 T12 UVH3LP23K UVH3LT23K 110–127 Vdc T13 T14 T15 T16 UVH3LP26K UVH3LT26K 2 220–250 Vdc T17 T18 T19 T20 UVH3LP28K UVH3LT28K 2 12 Vdc T21 T22 T23 T24 UVH3RP20K UVH3RT20K 24 Vdc T25 T26 T27 T28 UVH3RP21K UVH3RT21K 2 48–60 Vdc T29 T30 T31 T32 UVH3RP23K UVH3RT23K 2 110–127 Vdc T33 T34 T35 T36 UVH3RP26K UVH3RT26K 220–250 Vdc T37 T38 T39 T40 UVH3RP28K UVH3RT28K 2 2 2 2 Right-Pole Mounting DC Ratings 345 Notes 1 Listed with Underwriters Laboratories, for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 For use with KT (thermal-magnetic) trip units only. 4 Not for use on right pole of four-pole circuit breaker. 5 Breakers with K-Frame OPTIM 550 can only accept accessories in left pole. 2 2 2 2 2 2 2 2 V4-T2-290 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 L-, HMCP (L) and (M)-Frames and Undervoltage Release Mechanism Factory Mounted Connection Type and Location Field Installation Kits 2 1 Terminal Block 18-Inch (457.2 mm) Pigtail Leads Voltage Rating (AC Freq. = 50/60 Hz) 2 Field Mounted Same Side Rear 2 Opposite Side Same Side Pigtail Leads Terminal Block Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number 2 2 Left-Pole Mounting AC Ratings 2 12 Vac U05 U06 U07 U08 UVH4LP02K UVH4LT02K 24 Vac U09 U10 U11 U12 UVH4LP03K UVH4LT03K 48–60 Vac U13 U14 U15 U16 UVH4LP05K UVH4LT05K 110–127 Vac U17 U18 U19 U20 UVH4LP08K UVH4LT08K 208–240 Vac U21 U22 U23 U24 UVH4LP11K UVH4LT11K 380–480 Vac U25 U26 U27 U28 UVH4LP15K UVH4LT15K 2 2 2 2 Right-Pole Mounting AC Ratings 34 2 12 Vac U37 U38 U39 U40 UVH4RP02K UVH4RT02K 24 Vac U41 U42 U43 U44 UVH4RP03K UVH4RT03K 48–60 Vac U45 U46 U47 U48 UVH4RP05K UVH4RT05K 110–127 Vac U49 U50 U51 U52 UVH4RP08K UVH4RT08K 208–240 Vac U53 U54 U55 U56 UVH4RP11K UVH4RT11K 380–480 Vac U57 U58 U59 U60 UVH4RP15K UVH4RT15K 2 2 2 2 Left-Pole Mounting DC Ratings 2 12 Vdc T01 T02 T03 T04 UVH4LP20K UVH4LT20K 24 Vdc T05 T06 T07 T08 UVH4LP21K UVH4LT21K 48–60 Vdc T09 T10 T11 T12 UVH4LP23K UVH4LT23K 110–127 Vdc T13 T14 T15 T16 UVH4LP26K UVH4LT26K 220–250 Vdc T17 T18 T19 T20 UVH4LP28K UVH4LT28K 2 2 2 2 Right-Pole Mounting DC Ratings 34 12 Vdc T21 T22 T23 T24 UVH4RP20K UVH4RT20K 24 Vdc T25 T26 T27 T28 UVH4RP21K UVH4RT21K 48–60 Vdc T29 T30 T31 T32 UVH4RP23K UVH4RT23K 110–127 Vdc T33 T34 T35 T36 UVH4RP26K UVH4RT26K 220–250 Vdc T37 T38 T39 T40 UVH4RP28K UVH4RT28K 2 2 2 Notes 1 Listed with Underwriters Laboratories for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 For use with LT (thermal-magnetic) trip units only. 4 Not for use on right pole of four-pole circuit breaker. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-291 2.3 2 Molded Case Circuit Breakers Series C N-Frame and HMCP (N) Undervoltage Release Mechanism 2 2 2 2 Factory Mounted Field Mounted Connection Type and Location Field Installation Kits 1 18-Inch (457.2 mm) Pigtail Leads Voltage Rating (AC Freq. = 50/60 Hz) Terminal Block Same Side Rear 2 Opposite Side Same Side Pigtail Leads Terminal Block Suffix Number Suffix Number Suffix Number Suffix Number Catalog Number Catalog Number Left-Pole Mounting AC Ratings 2 12 Vac U05 U06 U07 U08 UVH5LP02K UVH5LT02K 24 Vac U09 U10 U11 U12 UVH5LP03K UVH5LT03K 2 48–60 Vac U13 U14 U15 U16 UVH5LP05K UVH5LT05K 2 110–127 Vac U17 U18 U19 U20 UVH5LP08K UVH5LT08K 208–240 Vac U21 U22 U23 U24 UVH5LP11K UVH5LT11K 2 380–480 Vac U25 U26 U27 U28 UVH5LP29K UVH5LT29K 2 12 Vdc T01 T02 T03 T04 UVH5LP20K UVH5LT20K 24 Vdc T05 T06 T07 T08 UVH5LP21K UVH5LT21K 2 48–60 Vdc T09 T10 T11 T12 UVH5LP23K UVH5LT23K 2 110–127 Vdc T13 T14 T15 T16 UVH5LP26K UVH5LT26K 220–250 Vdc T17 T18 T19 T20 UVH5LP28K UVH5LT28K 2 2 Left-Pole Mounting DC Ratings 2 R-Frame Undervoltage Release Mechanism (RH only) Factory Mounted 2 Field Mounted Connection Type and Location Field Installation Kits 3 18-Inch (457.2 mm) Pigtail Leads Pigtail Leads 2 Voltage Rating (AC Frequency = 50/60 Hz) Suffix Number 4 Catalog Number 4 2 12 Vac U37 UVH6RP02K 24 Vac U41 UVH6RP03K 2 48–60 Vac U45 UVH6RP05K 110–127 Vac U49 UVH6RP08K 2 208–240 Vac U53 UVH6RP11K 2 380–500 Vac U57 UVH6RP29K 12 Vdc T21 UVH6RP20K 2 24 Vdc T25 UVH6RP21K 48–60 Vdc T29 UVH6RP23K 2 110–125 Vdc T33 UVH6RP26K 220–250 Vdc T37 UVH6RP28K 2 2 2 Notes 1 Listed with Underwriters Laboratories for field installation under E64983. 2 Standard mounting location—leads exit rear of breaker. 3 Endurance: 500 electrical operations plus 2500 mechanical operations. 4 Pigtail wire size: 18 AWG (0.82 mm2). Leads are orange and brown. 2 2 2 2 2 2 V4-T2-292 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Accessory Terminal Block (R-Frame) Accessory Terminal Block (R-Frame) 2 R-Frame Accessory Terminal Block 1 Factory Installed Field Mounted 2 Suffix Number Catalog Number 2 Q01 TBRDK 2 2 2 Number of Control Wires for Each Internally Mounted Accessory Number of Contacts per Single Accessory Required Number of Wires 2 Auxiliary switch 2a/2b 4a/4b 6 12 2 Alarm (Signal)/ Lockout switch 1m/1b 2m/2b 6 12 Shunt trip N/A 2 2 Low energy shunt N/A 2 Undervoltage release mechanism N/A 2 Type of Accessory 2 2 2 PowerNet and Zone Interlock Kits (OPTIM 550 Only) K-, L- and N-Frames PowerNet and Zone Interlock Kits 2 PowerNet Interlock Kit 2 Circuit Breaker Factory Install Suffix Catalog Number 2 K-Frame PN ICK550K L-Frame PN ICK550L 2 N-Frame PN ICK550N 2 2 2 Zone Interlock/Ground Kit 23 Circuit Breaker Factory Install Suffix Catalog Number 2 K-Frame ZG ZGK550K L-Frame ZG ZGK550L 2 N-Frame ZG ZGK550N 2 2 PowerNet and Zone Interlock/Ground Kit 23 Circuit Breaker Factory Install Suffix Catalog Number K-Frame ZGP ZGPK550K L-Frame ZGP ZGPK550L N-Frame ZGP ZGPK550N 2 2 2 2 Notes 1 One 24-point accessory terminal block provided with circuit breaker when ordered factory installed or shipped from warehouse as separate item when ordered for field installation. See Digitrip RMS master connection diagram (IL 29C714). 2 Installation of these kits restrict any other attachments from being installed in the RH pole. 3 Includes a ground fault alarm signal that can drive the ground fault alarm unit (catalog number GFAU). 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-293 2.3 Molded Case Circuit Breakers Series C 2 Technical Data and Specifications 2 Alarm Switch 2 2 F-Frame Electrical Rating Data 12 Maximum Voltage Frequency L- and M-Frames Electrical Rating Data 67 Maximum Current Amperes Dielectric Withstand Voltage Multi-Pole Circuit Breakers Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2500 600 50/60 Hz 6 2500 125 DC 0.50 3 2500 125 DC 0.50 3 2500 250 DC 0.25 3 2500 2 250 DC 0.25 3 2500 2 125/250 50/60 Hz 63 2000 28 DC 33 2000 28 DC 54 2000 2 2 N-Frame Electrical Rating Data Single-Pole Circuit Breakers 2 2 2 2 2 2 2 2 2 J-Frame Electrical Rating Data Frequency 600 50/60 Hz 125 DC 250 DC 0.25 3 2500 Maximum Current Amperes Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2500 125 DC 0.50 3 2500 250 DC 0.25 3 2500 Dielectric Withstand Voltage R-Frame Electrical Rating Data 9j 6 2500 Maximum Voltage 0.50 3 2500 K-Frame Electrical Rating Data 67 Maximum Voltage Frequency 600 50/60 Hz 6 2500 125 DC 0.50 3 2500 250 DC 0.25 3 2500 Maximum Current Amperes Dielectric Withstand Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2500 125 DC 0.50 3 2500 250 DC 0.25 3 2500 Notes 1 Endurance: 6000 electrical operations plus 4000 mechanical operations. 2 Endurance: 6000 electrical operations plus 2000 mechanical operations. 3 Non-inductive load. 4 Inductive (L/R = 0.026). 5 Endurance: 6000 electrical operations plus 2000 mechanical operations. 6 Pigtail wire size: 18 AWG (0.82 mm2). 7 Endurance: 5000 electrical operations plus 1000 mechanical operations. 8 Endurance: 3000 electrical operations plus 1000 mechanical operations. i Endurance: 500 electrical operations plus 2500 mechanical operations. j Pigtail wire size: 18 AWG (0.82 mm2). Leads are red, black and blue. 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-294 Frequency 56 Maximum Voltage 2 Maximum Voltage 8 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Auxiliary Switch 2 L- and M-Frames Electrical Rating Data 2 F-Frame Electrical Rating Data 12 Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 125 3 50/60 Hz 1 2500 600 50/60 Hz 6 2500 4 2500 2500 600 50/60 Hz 6 2500 125 DC 0.50 125 DC 0.50 4 2500 250 DC 0.25 4 250 DC 0.25 4 2500 Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2 Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2500 2500 125 DC 0.50 4 2500 4 2500 250 DC 0.25 4 2500 2500 125 DC 0.50 250 DC 0.25 4 K-Frame Electrical Rating Data 25 Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2500 2 2 Frequency 2 600 50/60 Hz 6 125 DC 0.50 4 2 DC 0.25 4 250 Notes 1 Endurance: 6000 electrical operations plus 4000 mechanical operations. 2 Pigtail wire size: 18 AWG (0.82 mm2). 3 For use in electronic circuit of 100 micro amperes and 15 Vdc minimum. 4 Non-inductive load. 5 Endurance: 5000 electrical operations plus 1000 mechanical operations. 6 Endurance: 3000 electrical operations plus 1000 mechanical operations. 7 Endurance: 500 electrical operations plus 2500 mechanical operations. 8 Pigtail wire size: 18 AWG (0.82 mm2). Leads are red, black and blue. 0.25 4 2 Maximum Current Amperes 2500 0.50 DC 2 Maximum Voltage 2500 DC 250 2 R-Frame Electrical Rating Data 78 4 125 2 2 N-Frame Electrical Rating Data 26 J-Frame Electrical Rating Data 12 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-295 2.3 Molded Case Circuit Breakers Series C 2 Auxiliary Switch and Alarm Switch Combination 2 F-Frame Electrical Rating Data 12 2 2 Maximum Voltage Frequency Maximum Current Amperes L- and M-Frames Electrical Rating Data 25 Dielectric Withstand Voltage Maximum Voltage Frequency Maximum Current Amperes Dielectric Withstand Voltage 600 50/60 Hz 6 2500 600 50/60 Hz 6 2500 125 DC 0.50 3 2200 125 DC 0.50 3 2500 250 DC 0.25 3 2200 250 DC 0.25 3 2500 2 2 2 2 2 J-Frame Electrical Rating Data 24 Maximum Voltage Maximum Current Amperes Frequency 600 50/60 Hz 125 DC 250 DC 0.25 3 N-Frame Electrical Rating Data 26 Dielectric Withstand Voltage Maximum Voltage 6 2500 600 50/60 Hz 6 2500 0.50 3 2500 125 DC 0.50 3 2500 2500 250 DC 0.25 3 2500 2 K-Frame Electrical Rating Data 25 2 Maximum Voltage Frequency 2 600 50/60 Hz 6 2500 125 DC 0.50 3 2500 250 DC 0.25 3 2500 2 Maximum Current Amperes Dielectric Withstand Voltage Maximum Current Amperes Dielectric Withstand Voltage Notes 1 Endurance: 6000 electrical operations plus 4000 mechanical operations. 2 Pigtail wire size: 18 AWG (0.82 mm2). 3 Non-inductive load. 4 Endurance: 6000 electrical operations plus 2000 mechanical operations. 5 Endurance: 5000 electrical operations plus 1000 mechanical operations. 6 Endurance: 3000 electrical operations plus 1000 mechanical operations. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-296 Frequency Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Shunt Trip 2 K-Frame Electrical Rating Data 678 F-Frame Electrical Rating Data 123 50/60 Hz DC Supply Voltage Minimum Operating Voltage 12 6.75 24 50/60 Hz VA Supply Voltage Minimum Operating Voltage 75 12 9 6.75 300 24 48 36 92 60 36 140 110 156 120 2 DC VA Supply Voltage Minimum Operating Voltage VA Supply Voltage Minimum Operating Voltage 100 12 9 VA 45 12 8.4 35 9 400 24 9 200 24 8.4 170 48 36 100 60 36 160 48 — 830 48 — 710 60 — 1280 60 — 1105 480 110 77 55 110 5 156 570 120 77 60 100 110 77 110 66 120 5 60 120 120 77 130 127 156 640 125 77 71 127 5 208 156 180 60 140 125 77 140 — — — 208 5 60 420 — — — 220 156 200 — — — 220 5 60 470 — — — 240 156 240 — — — 240 5 60 550 — — — 380 300 610 127 — 72 380 285 95 220 154 41 415 300 130 220 — 110 400 285 108 250 154 54 440 300 330 250 — 140 415 285 120 — 154 — 480 300 380 — — — 440 285 136 — 154 — 525 300 450 — — — 480 360 40 — — — 550 300 530 — — — 525 360 50 — — — 600 300 590 — — — J-Frame Electrical Rating Data 124 50/60 Hz DC Supply Voltage Minimum Operating Voltage VA Supply Voltage Minimum Operating Voltage VA 12 9 31 12 8.4 50 24 9 173 24 8.4 247 48 36 686 48 33.6 1094 60 36 1014 60 33.6 1698 5 60.5 66 110 77 112 120 5 60.5 84 120 77 138 127 5 60.5 102 125 77 150 208 5 60.5 354 — 77 — 220 5 60.5 396 — — — 110 5 60.5 432 — — — 380 285 180 110 154 40 400 285 200 120 154 58 415 285 240 125 154 — 440 285 610 127 154 — 480 360 34 — — — 525 360 42 — — — 550 360 50 — — — 600 360 60 — — — 240 550 360 50 — — — 600 360 70 — — — Notes 1 Average unlatching time: 6 milliseconds. 2 Average circuit breaker contact total opening time: 18 milliseconds. 3 Endurance: 6000 electrical operations plus 4000 mechanical operations. 4 Endurance: 6000 electrical operations plus 2000 mechanical operations. 5 Supply voltages suitable for use with Class 1 GFP devices. Marking label included with accessory kits. 6 Approximate unlatching time: 6 milliseconds. 7 Approximate total circuit breaker contact opening time: 8 milliseconds. 8 Endurance: 5000 electrical operations plus 1000 mechanical operations. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-297 2.3 Molded Case Circuit Breakers Series C 2 L- and M-Frame Electrical Rating Data 123 N-Frame Electrical Rating Data 125 50/60 Hz 50/60 Hz 2 Supply Voltage Minimum Operating Voltage 2 12 DC VA Supply Voltage Minimum Operating Voltage 9 45 12 24 9 200 2 48 34 2 60 34 110 4 4 DC VA Supply Voltage Minimum Operating Voltage VA Supply Voltage Minimum Operating Voltage VA 9 35 24 16.8 200 24 16.8 170 24 9 170 48 33.6 830 48 33.6 710 830 48 34 710 60 33.6 1280 60 33.6 1150 1280 60 34 1105 110 4 60 100 110 77 110 60 100 110 77 110 120 4 60 120 120 77 130 60 120 120 77 130 127 4 60 140 125 77 140 2 120 127 4 60 140 125 77 140 208 4 60 420 — — — 2 208 4 60 420 — 77 — 220 4 60 470 — — — 220 4 60 470 — — — 240 4 60 550 — — — 240 4 60 550 — — — 380 266 95 220 154 41 2 380 266 95 220 154 41 400 266 108 250 — 54 400 266 108 250 — 54 415 266 120 — — — 2 415 266 120 — — — 440 266 136 — — — 440 266 136 — — — 480 336 40 — — — 2 480 336 40 — — — 525 336 50 — — — 2 525 336 50 — — — 550 336 50 — — — 550 336 50 — — — 600 336 70 — — — 600 336 70 — — — Notes 1 Approximate unlatching time: 6 milliseconds. 2 Approximate total circuit breaker contact opening time: 18 milliseconds. 3 Endurance: 5000 electrical operations plus 1000 mechanical operations. 4 Supply voltages suitable for use with Class 1 GFP devices. Marking label included with accessory kits. 5 Endurance: 3000 electrical operations plus 1000 mechanical operations. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-298 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C R-Frame Electrical Rating Data 123456 Application Ratings 2 Electrical Operating Ratings Suffix Number Voltage (V) Frequency (Hz) Supply Voltage (V) Minimum Operating Voltage (V) Ip (A) Irms at 0.250s (A) Irms at 0.033s (A) VA One Minute Dielectric Withstand Voltage (V) 2 03/03K 24 50/60 24 16.8 36.1 — 25.5 612 1050 24 DC 24 16.8 36.1 16.5 — 396 1050 2 48–60 50/60 48 34.0 13.1 — 9.2 450 1120 48–60 50/60 60 34.0 17.2 — 12.2 740 1120 05/05K 11/11K 3 14/14K 18/18K 23/23K 26/26K 110–240 50/60 110 60.5 4.2 — 3.0 330 1480 110–240 50/60 120 60.5 4.5 — 3.2 390 1480 110–240 50/60 127 60.5 4.6 — 3.3 430 1480 110–240 50/60 208 60.5 7.9 — 5.6 1170 1480 110–240 50/60 220 60.5 8.5 — 6.0 1370 1480 110–240 50/60 240 60.5 8.7 — 6.1 1470 1480 380–440 50/60 380 266.0 4.5 — 3.2 1220 1880 380–440 50/60 415 266.0 5.0 — 3.6 1500 1880 380–440 50/60 440 266.0 5.3 — 3.7 1640 1880 220–250 DC 220 154.0 — 2.4 — 530 1500 220–250 DC 250 154.0 — 2.7 — 680 1500 480–600 50/60 480 336.0 0.6 — 0.4 200 2200 480–600 50/60 525 336.0 0.7 — 0.5 270 2200 480–600 50/60 550 336.0 0.7 — 0.5 280 2200 480–600 50/60 600 336.0 0.8 — 0.6 360 2200 48–60 DC 48 34.0 — 9.8 — 470 1120 48–60 DC 60 34.0 — 11.6 — 700 1120 110–125 DC 110 77.0 — 3.3 — 370 1250 110–125 DC 120 77.0 — 3.6 — 440 1250 110–125 DC 125 77.0 — 3.8 — 480 1250 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes 1 Approximate unlatching time of 6 milliseconds. 2 Average circuit breaker contact total opening time approximately 62 milliseconds, at rated voltage. 3 Endurance: 500 electrical operations and 2500 mechanical operations. 4 Shunt trip can be operated up to a maximum of six times per minute. 5 Maximum operating voltage—110% of maximum voltage range rating. 6 Pigtail wire size: 18 AWG (0.82 mm2). Leads are yellow and white. 2 2 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-299 2.3 Molded Case Circuit Breakers Series C 2 Undervoltage Release Mechanism 2 F-Frame Electrical Rating Data 1 2 50/60 Hz DC Supply Voltage Dropout Voltage Pickup Voltage Pickup Voltage Maximum Maximum VA Supply Voltage Dropout Voltage Minimum Minimum Maximum Maximum VA 12 4.2 6.3 7.6 1.3 12 4.2 8.4 10.2 2.8 2 12 4.2 6.3 7.6 2.5 12 4.2 8.4 10.2 2.8 24 8.4 16.8 20.4 1.4 24 8.4 16.8 20.4 1.6 2 48 21.0 33.6 40.8 1.2 48 21.0 33.6 40.8 1.3 60 21.0 33.6 40.8 1.9 60 21.0 33.6 40.8 2.0 2 110 44.5 77.0 93.5 1.3 110 44.5 77.0 93.5 1.5 2 120 44.5 77.0 93.5 1.5 120 44.5 77.0 93.5 1.7 127 44.5 77.0 93.5 1.7 125 44.5 77.0 93.5 1.9 2 208 84.0 145.6 176.8 2.2 220 87.5 154.0 187.0 2.6 220 84.0 145.6 176.8 2.4 250 87.5 154.0 187.0 3.4 2 240 84.0 145.6 176.8 2.9 — — — — — 380 168.0 266.0 323.0 2.9 — — — — — 2 415 168.0 266.0 323.0 3.5 — — — — — 2 440 168.0 266.0 323.0 3.9 — — — — — 480 168.0 266.0 323.0 4.6 — — — — — 2 525 210.0 367.0 446.0 4.3 — — — — — 550 210.0 367.0 446.0 4.8 — — — — — 2 600 210.0 367.0 446.0 5.8 — — — — — 2 2 J-Frame Electrical Rating Data 23 2 50/60 Hz DC Pickup Voltage 2 Supply Voltage Dropout Voltage Minimum Maximum Maximum Dropout Voltage Pickup Voltage Minimum Maximum Maximum VA 2 12 4.2 8.4 10.2 1.9 24 8.4 16.8 20.4 3.9 12 4.2 8.4 10.2 1.6 24 8.4 16.8 20.4 2 48 21.0 33.6 40.8 2.5 3.1 48 21.0 33.6 40.8 60 21.0 33.6 40.8 2.0 3.8 60 21.0 33.6 40.8 2 110 44.5 77.0 3.1 93.5 1.8 110 44.5 77.0 93.5 1.6 2 120 44.5 127 44.5 77.0 93.5 2.1 120 44.5 77.0 93.5 1.9 77.0 93.5 2.4 125 44.5 77.0 93.5 2 208 2.2 84.0 145.6 176.8 2.7 220 87.5 154.0 187.0 3.1 220 84.0 145.6 176.8 3.1 250 87.5 154.0 187.0 4.0 2 240 84.0 145.6 176.8 3.8 — — — — — 2 380 168.0 266.0 323.0 3.4 — — — — — 415 168.0 266.0 323.0 4.0 — — — — — 440 168.0 266.0 323.0 4.6 — — — — — 480 168.0 266.0 323.0 5.4 — — — — — 2 2 2 VA Supply Voltage Notes 1 Endurance: 6000 electrical operations plus 4000 mechanical operations. 2 Endurance: 6000 electrical operations plus 2000 mechanical operations. 3 For electrical rating data for manual, automatic and electrical reset undervoltage release mechanisms, refer to Eaton. 2 2 2 V4-T2-300 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 K-Frame Electrical Rating Data 1 50/60 Hz 2 DC Supply Voltage Dropout Voltage Pickup Voltage Pickup Voltage Maximum Maximum VA Supply Voltage Dropout Voltage Minimum Minimum Maximum Maximum VA 12 4.2 8.4 10.2 1.9 12 4.2 8.4 10.2 1.6 24 8.4 16.8 20.4 3.9 24 8.4 16.8 20.4 3.1 48 21.0 33.6 40.8 2.5 48 21.0 33.6 40.8 2.0 60 21.0 33.6 40.8 3.8 60 21.0 33.6 40.8 3.1 110 44.5 77.0 93.5 1.8 110 44.5 77.0 93.5 1.6 120 44.5 77.0 93.5 2.1 120 44.5 77.0 93.5 1.9 127 44.5 77.0 93.5 2.4 125 44.5 77.0 93.5 2.2 208 84.0 145.6 176.8 2.7 220 87.5 154.0 187.0 3.1 220 84.0 145.6 176.8 3.1 250 87.5 154.0 187.0 4.0 240 84.0 145.6 176.8 3.8 — — — — — 380 168.0 266.0 323.0 3.4 — — — — — 415 168.0 266.0 323.0 4.0 — — — — — 440 168.0 266.0 323.0 4.6 — — — — — 480 168.0 266.0 323.0 5.4 — — — — — 2 2 2 2 2 2 2 2 2 2 2 L- and M-Frames Electrical Rating Data 1 50/60 Hz DC Supply Voltage Dropout Voltage Pickup Voltage Minimum Maximum Maximum VA Supply Voltage 12 4.2 8.4 10.2 1.9 24 8.4 16.8 20.4 48 21.0 33.6 40.8 60 21.0 33.6 110 44.5 77.0 120 44.5 77.0 2 Dropout Voltage Pickup Voltage Minimum Maximum Maximum VA 12 4.2 8.4 10.2 1.6 3.9 24 8.4 16.8 20.4 3.1 2.5 48 21.0 33.6 40.8 2.0 40.8 3.8 60 21.0 33.6 40.8 3.1 93.5 1.8 110 44.5 77.0 93.5 1.6 93.5 2.1 120 44.5 77.0 93.5 1.9 127 44.5 77.0 93.5 2.4 125 44.5 77.0 93.5 2.2 208 84.0 145.6 176.8 2.7 220 87.5 154.0 187.0 3.1 220 84.0 145.6 176.8 3.1 250 87.5 154.0 187.0 4.0 240 84.0 145.6 176.8 3.8 — — — — — 380 168.0 266.0 323.0 3.4 — — — — — 415 168.0 266.0 323.0 4.0 — — — — — 440 168.0 266.0 323.0 4.6 — — — — — 480 168.0 266.0 323.0 5.4 — — — — — 2 2 2 2 2 2 2 2 2 Note 1 Endurance: 5000 electrical operations plus 1000 mechanical operations. 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-301 2.3 2 2 Molded Case Circuit Breakers Series C N-Frame Electrical Rating Data 1 50/60 Hz DC Dropout Voltage Pickup Voltage Minimum Maximum Maximum VA Supply Voltage Dropout Voltage Pickup Voltage Minimum Maximum Maximum VA 12 4.2 8.4 10.2 1.9 2 24 8.4 16.8 20.4 3.9 12 4.2 8.4 10.2 1.6 24 8.4 16.8 20.4 48 21.0 33.6 40.8 3.1 2.5 48 21.0 33.6 40.8 2.0 2 60 21.0 33.6 110 44.5 77.0 40.8 3.8 60 21.0 33.6 40.8 3.1 93.5 1.8 110 44.5 77.0 93.5 2 120 44.5 1.6 77.0 93.5 2.1 120 44.5 77.0 93.5 2 127 1.9 44.5 77.0 93.5 2.4 125 44.5 77.0 93.5 2.2 208 84.0 145.6 176.8 2.7 220 87.5 154.0 187.0 3.1 2 220 84.0 145.6 176.8 3.1 220 87.5 154.0 187.0 — 240 84.0 145.6 176.8 3.8 250 — — — 4.0 2 380 175.0 266.0 323.0 3.4 — — — — — 415 175.0 266.0 323.0 4.0 — — — — — 2 480 175.0 266.0 323.0 4.6 — — — — — 500 175.0 266.0 323.0 5.4 — — — — — 2 2 2 Supply Voltage Note 1 Endurance: 3000 electrical operations plus 1000 mechanical operations. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-302 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 R-Frame AC Undervoltage Release Mechanism (Handle Reset) Ratings 12 Application Ratings Electrical Operating Ratings Catalog Suffix Voltage (V) Supply Voltage (V) Minimum 02/02K 12 12 4.2 03/03K 24 24 05/05K 48–60 48 08/08K 11/11K 29/29K 110–127 208–240 380–500 Dropout Voltage (V) 2 Approximate Operating Time (ms) Maximum Pickup Voltage (V) Max. VA Minimum UVR Response 3 Initiation Circuit Breaker Contact Separation 4 Maximum Circuit Breaker Contact Opening Dielectric Withstand Voltage (V) 5 8.4 10.2 2.3 5 46 77 1024 8.4 16.8 21.0 33.5 20.4 3.1 5 46 77 1048 40.8 3.4 5 46 77 1120 60 21.0 33.5 40.8 6.0 5 46 77 1120 110 120 44.5 77.0 93.5 3.3 5 46 77 1254 44.5 77.0 93.5 3.6 5 46 77 1254 127 44.5 77.0 93.5 3.8 5 46 77 1254 208 84.0 145.6 176.8 4.2 5 46 77 1480 220 84.0 145.6 176.8 6.6 5 46 77 1480 240 84.0 145.6 176.8 7.2 5 46 77 1480 380 168.0 266.0 323.0 3.8 5 46 77 2000 415 168.0 266.0 323.0 8.3 5 46 77 2000 440 168.0 266.0 323.0 8.8 5 46 77 2000 480 168.0 266.0 323.0 9.6 5 46 77 2000 500 168.0 266.0 323.0 10.0 5 46 77 2000 2 2 2 2 2 2 2 2 2 Application Ratings Electrical Operating Ratings Catalog Suffix Voltage (V) Supply Voltage (V) 20/20K 12 12 4.2 8.4 10.2 3.4 5 46 77 1024 21/21K 24 24 8.4 16.8 20.4 4.3 5 46 77 1048 23/23K 48–60 48 21.0 33.5 40.8 4.8 5 46 77 1120 60 21.0 33.5 40.8 7.2 5 46 77 1120 110 43.8 77.0 93.5 3.3 5 46 77 1250 120 43.8 77.0 93.5 3.6 5 46 77 1250 125 43.8 77.0 93.5 3.8 5 46 77 1250 220 87.5 154.0 187.0 6.6 5 46 77 1500 250 87.5 154.0 187.0 7.5 5 46 77 1500 26/26K 28/28K 110–127 220–250 Minimum Maximum Approximate Operating Time (ms) Pickup Voltage (V) Max. VA Minimum UVR Response 3 2 2 R-Frame DC Undervoltage Release Mechanism (Handle Reset) Ratings 12 Dropout Voltage (V) 2 Initiation Circuit Breaker Contact Separation 4 Maximum Circuit Breaker Contact Opening Dielectric Withstand Voltage (V) 5 2 2 2 2 2 2 2 2 Notes 1 Endurance: 500 electrical operations plus 2500 mechanical operations. 2 Pigtail wire size: 18 AWG (0.82 mm2). Leads are orange and brown. 3 UVR will override a momentary voltage dip up to the response time shown. 4 Unlatching occurs 1 millisecond before circuit breaker contacts begin to separate. 5 For 1 minute. 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-303 2.3 2 Molded Case Circuit Breakers Series C Contents Series C External Accessories Description 2 Page Product Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . Standards and Certifications . . . . . . . . . . . . . . . . . . . Quick Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . G-Frame (15–100 Amperes) . . . . . . . . . . . . . . . . . . . F-Frame (10–225 Amperes) . . . . . . . . . . . . . . . . . . . J-Frame (70–250 Amperes). . . . . . . . . . . . . . . . . . . . K-Frame (70–400 Amperes) . . . . . . . . . . . . . . . . . . . L-Frame (125–600 Amperes) . . . . . . . . . . . . . . . . . . M-Frame (300–800 Amperes). . . . . . . . . . . . . . . . . . N-Frame (400–1200 Amperes) . . . . . . . . . . . . . . . . . R-Frame (800–2500 Amperes) . . . . . . . . . . . . . . . . . Motor Circuit Protectors (MCP) . . . . . . . . . . . . . . . . Motor Protection Circuit Breakers (MPCB) . . . . . . . . Type ELC Current Limiter Attachment (Size 0–4) . . . . . Current Limiting Circuit Breaker Module . . . . . . . . . . . Internal Accessories . . . . . . . . . . . . . . . . . . . . . . . . . External Accessories Product Selection . . . . . . . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . . . Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 2 2 2 2 2 2 2 2 V4-T2-116 V4-T2-117 V4-T2-118 V4-T2-121 V4-T2-135 V4-T2-153 V4-T2-161 V4-T2-185 V4-T2-211 V4-T2-222 V4-T2-237 V4-T2-256 V4-T2-267 V4-T2-269 V4-T2-270 V4-T2-273 V4-T2-308 V4-T2-326 V4-T2-327 V4-T2-328 2 2 2 External Accessories 2 Product Overview 2 End Cap Kit The end cap kit slides onto the line or load conductor of the circuit breaker and acts as a threaded adapter for the conductor to accept a ring terminal or other bolt-on connector. The end cap kit is available with English and metric thread sizes. (Field installation only.) Listed per UL File E7819. J-Frame Plug Nut The plug nut is used in applications where screwconnected ring-type terminals are preferred to connect cables to circuit breaker conductors. The plug nut is press-fit into the opening in the circuit breaker terminal conductor. Screws and washers are supplied by customer. Keeper Nut The keeper nut slides onto the line or load conductor of the circuit breaker and acts as a threaded adapter for the conductor to accept a ring terminal or other bolt-on connector. The keeper nut is available with English and metric thread sizes. Screws and washers are supplied by customer. (Field installation only.) Listed per UL File E7819. Terminal Adapter 2 2 2 2 2 2 2 2 2 2 2 2 L-, M-, N-Frames 2 Not required. Terminals are threaded. Control Wire Terminal Kit The control wire terminal kit provides a means to tap off control power from a main disconnect, using the provided male end of a quick disconnect. For use with steel or stainless steel terminals only. Note: Terminal Kits contain one terminal for each pole and one terminal cover. Multiwire Connectors Eaton’s field-installed multiwire connectors for the load side (OFF) end terminals are used to distribute the load from the circuit breaker to multiple devices without the use of separate distribution terminal blocks. Multiwire lug kits include mounting hardware, insulators and tin-plated aluminum connectors to replace three mechanical load lugs. UL listed as used on the load side (OFF) end. Terminal Shields Terminal shields provide protection against accidental contact with live line side terminations. Terminal shields are fabricated from high dielectric insulating material and fasten over the front terminal access openings. Small openings in the shields provide limited access to the terminals for tightening connectors. (Field installation only.) 2 V4-T2-304 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Rear Fed Terminals. Rear fed terminals allow the cable to connect to the breaker from the back instead of the top. Terminal shields or interphase barriers are included with each rear fed terminal kit (depending on frame size). When catalog number starts with a 3, it indicates a kit with three terminals in each kit. Catalog number beginning with a TA indicates one terminal. Molded Case Circuit Breakers Series C Terminal End Covers The terminal end covers are designed for use in motor control center applications where, because of confined spaces, line side conductors are normally custom fitted. The molded end covers are made of high dielectric glasspolyester and slide over the line ends of the circuit breaker. Close fitting conductor openings are molded into the end covers. The end cover and circuit breaker case fit together to form terminal compartments that isolate discharged ionizing gases during circuit breaker tripping. Terminal end covers are available with two conductor opening diameters, 0.25-inch (6.4 mm) and 0.41inch (10.4 mm), and are listed per UL File E7819. (Field installation only.) Interphase Barriers The interphase barriers provide additional electrical clearance between circuit breaker poles for special termination applications. The barriers are high dielectric insulating plates that are installed in the molded slots between the terminals. (Field installation only.) Two per package. Base Mounting Plate Suitable for mounting six single-pole circuit breakers. DIN Rail Adapter For use with standard 35 mm DIN rail such as, 35 x 7.5 or 35 x 15 mm per DIN EN50022. Adapter mounting screws included are for use with twoand three-pole circuit breakers. Adapters for singlepole circuit breakers clip into the base molding. Key Operated Attachment Lock Dog (Non-Padlockable) Non-Padlockable Handle Block The non-padlockable handle block secures the circuit breaker handle in either the ON or OFF position. (Trip-free operation allows the circuit breaker to trip when the handle block holds the circuit breaker handle in the ON position.) The device is positioned over the circuit breaker handle and secured by a setscrew to deter accidental operation of the circuit breaker handle. Listed per UL File E7819. (Field installation only.) Padlockable Handle Padlockable Handle Lock The device is positioned in the cover opening to prevent handle movement. Will accommodate one 5/16-inch (8 mm) padlock. Snap-on Padlockable Handle Lock Hasp The snap-on padlockable handle lock allows the handle to be locked in the OFF or ON position. (Trip-free operation allows the circuit breaker to trip when the handle lock holds the circuit breaker handle in the ON position.) This device was designed for use on the single-pole circuit breaker, but may be used on one-, two-, threeand four-pole styles. The handle lock snaps onto the escutcheon area of the handle with an optional retaining screw for added secureness. The handle lock will accommodate one padlock with a 1/4-inch (6.4 mm) shackle. Listed per UL File E7819. (Field installation only.) Padlockable Handle Lock Hasp The padlockable handle lock hasp allows the handle to be locked in the ON or OFF position. (Trip-free operation allows the circuit breaker to trip when the handle lock holds the circuit breaker handle in the ON position.) The hasp mounts on the circuit breaker cover within the trimline. The cover is predrilled on both sides of the operating handle so that the hasp can be mounted on either side of the handle. The hasp will accommodate up to three padlocks with 1/4-inch (6.4 mm) shackles, one per circuit breaker. Listed per UL File E7819. (Field installation only.) Cylinder Lock The cylinder lock internally blocks the trip bar in the tripped position to prevent the circuit breaker from being switched to ON. The cylinder lock is factory installed in the left pole only of the circuit breaker cover. Other internally mounted accessories cannot be installed in the same pole as the cylinder lock. (Factory installation only.) Key Interlock Kit (Lock Not Included) The key interlock is used to externally lock the circuit breaker handle in the OFF position. When the key interlock is locked, an extended deadbolt blocks movement of the circuit breaker handle. Uniquely coded keys are removable only with the deadbolt extended. Each coded key controls a group of circuit breakers for a given specific customer installation. The key interlock assembly is Underwriters Laboratories listed for field installation under UL File E7819 and consists of a mounting kit and a purchaser supplied deadbolt lock. The mounting kit comprises a mounting plate, which is secured to the circuit breaker cover in either the left- or right-pole position, key interlock mounting screws, and a wire seal. Specific mounting kits are required for individual key interlock types. Sliding Bar Interlock The sliding bar interlock provides mechanical interlocking between two adjacent three-pole circuit breakers. It is installed on the enclosure cover between the circuit breakers. When the sliding bar interlock handle is moved from one side to the other, a bar extends to alternately block movement of the circuit breaker handles and prevents both circuit breakers from being switched to ON at the same time. Sliding bar interlocks are not UL listed. (Field installation only.) 2.3 Walking Beam Interlock The walking beam Interlock provides mechanical interlocking between two adjacent circuit breakers of the same pole configuration. The walking beam interlock mounts on a bracket behind and between the circuit breakers. A plunger on each end of the beam is inserted through an access hole in the back plate and base of each circuit breaker. The walking beam interlock prevents both circuit breakers from being switched ON at the same time. If a walking beam interlock is installed, the wiring troughs in the back of the circuit breaker case are blocked by the plungers and cannot be used for cross wiring. Factory modified circuit breakers are required for this application. UL File E38116. Electrical Operator The electrical (solenoid) operator is a single solenoid mechanism that enables local and remote circuit breaker ON, OFF, and reset switching. The electrical operator is mounted on the circuit breaker cover within the trimline of the circuit breaker. The electrical operator uses a unique bi-stable latch that allows the device to operate using one solenoid. The accessory provides high-speed switching with a maximum operating time of 5 cycles (80 mS), making it suitable for generator synchronizing applications. Means are provided for remote electrical operation and for local manual operation. A special slide includes provisions for padlocking the circuit breaker handle in the OFF position. The slide will accept three padlock shackles with a maximum diameter of 1/4-inch (6.4 mm) each. An interlock electrically disconnects the solenoid when the electrical operator cover is removed. The rating data tables provide electrical rating data for the electrical (solenoid) operator. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-305 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2.3 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Molded Case Circuit Breakers Series C The electrical (motor) operator allows the circuit’s breaker to be opened, closed or reset remotely. It also has a lock-off capability and provisions for manual operation. The electrical (motor) operator contains a reversible motor connected to a ball screw. The ball screw drives the circuit breaker handle. Limit switches and relays are used to control the motor. Plug-In Adapters Plug-in adapters simplify installation and front removal of circuit breakers. Individual line and load plug-in adapters are available for rear connection applications on two-, three-, and four-pole circuit breakers. Common mounting plates for lineand load-end adapters are available. One plug-in adapter kit is required for line-end and one for load-end. Plug-in adapters are UL approved unless otherwise noted. Rear Connecting Studs Rear connecting studs are available in several sizes to accommodate specific fixedmounted circuit breaker applications. Each rear connecting stud assembly consists of one stud and one tube. To maintain proper clearances between poles, select alternate long and short stud assemblies for circuit breakers with more than one pole. One assembly is required for line-end and one for load-end of each pole. Tubes must be ordered separately. Connecting studs are available only with English thread sizes. Panelboard Connecting Straps Panelboard connecting straps are used to connect the circuit breaker terminals to the panelboard bus. The panelboard connecting straps are available with various ratings for outside and center poles. (Field installation only.) Panelboard connecting straps are available to meet the needs of most standard panelboard applications. Style numbers for mounting brackets for CDP panelboard installations are also included. Note: Not UL listed. Refer to panelboard manufacturer for compatibility. Type LFD Current Limiter The LFD current limiter is an accessory that bolts to the load end of a standard FDB or FD thermal-magnetic circuit breaker, providing 200,000 A interrupting capacity at up to 600 Vac. LFD current limiters for thermal-magnetic and electronic circuit breakers are listed with Underwriters Laboratories under File E47239. IQ Energy Sentinel The IQ Energy Sentinel is a highly accurate, microprocessor-based, breaker-mounted device designed to monitor power and energy readings. It represents an alternative to watt meters, watt-hour meters, and watt demand meters. Key advantages include savings in space, lower installation costs, and remote monitoring capability. The IQ Energy Sentinel mounts on the load side of a Series C F-Frame (150 ampere) circuit breaker. It can be applied on threephase, four-wire systems, or single-phase, three-wire systems with voltage connected through Phases A and C. For more information, see Descriptive Bulletin 8178. Ground Fault Alarm Unit The ground fault alarm unit is a remotely mounted device with a combination indicating light/test button that will light when the breaker trips or alarms on ground fault. The ground fault alarm unit requires a separate 120 Vac power source to power the light and the internal relay, which has 1NO and 1NC contacts for remote indication. The ground fault alarm unit can be panel mounted for ordering with an optional face mounting bracket. For use on Digitrip 310 only, K- through NFrame. Note: Not UL listed. 2 2 2 2 V4-T2-306 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Potential Transformer Module The potential transformer module is required for the Digitrip OPTIM 1050 to provide a voltage input to allow the trip unit to monitor power and energy as well as power factor. The potential transformer module is a 6 VA transformer with a primary voltage input of up to 600 volt line to line. Three 0.1 ampere fuses are provided on the primary of the transformer and can be used for isolation purposes during dielectric testing. The device is normally panel mounted and can feed up to 16 OPTIM trip units. Solid-State (Electronic) Portable Test Kit The solid-state (electronic) portable test kit provides verification of performance of all ratings of Digitrip 310 electronic trip units installed in circuit breakers while in service under varying load and/or phase imbalance. The test kit operates on 120-volt, 50/60 Hz power; it includes complete instructions and test times for testing long time, short time/instantaneous operation and optional ground fault operation of the circuit breaker. Molded Case Circuit Breakers Series C Breaker Interface Module (BIM) The Breaker Interface Module (BIM) is a panel mounted user interface device that is mounted on the front of an electrical assembly or at a remote location. The BIM is used to access, configure, test and display information for OPTIM trip units and other devices. The BIM consists of four display windows, eight function buttons, 18 LEDs, and a graphical time/current curve to provide breaker status, operational information, protection status and energy monitoring. A 24 Vdc power supply is required to provide power to the BIM. This is supplied by the switchboard builder to Eaton’s specifications. The BIM is a member of Eaton’s PowerNet family of communicating devices that connects OPTIM trip units, Digitrip RMS 810/910 trip units and energy sentinels as a subnetwork system. The BIM can also be connected to a main network via a PONI module to PowerNet software. Digitrip OPTIMizer The Digitrip OPTIMizer is a hand-held programmer that is used to access, configure, test and display information from OPTIM trip units. The OPTIMizer plugs into the front of an OPTIM trip unit via an eight-pin telephone jack and is powered by a nine-volt battery or the auxiliary power module. One highlighted feature is the “Copy” and “Download” commands. Setting up multiple OPTIM trips can be finished in minutes and with no errors. An Auxiliary Power Module connection provides a trip test when control power is not present at the breaker. The OPTIMizer is supplied as a standard package to include the programmer, the eightpin connection cord, battery and carrying case. The auxiliary power module is optional. Auxiliary Power Module The auxiliary power module is a power supply requiring 120 Vac input at 50 or 60 Hz that provides a 32 Vdc output. The auxiliary power module provides control power for testing an OPTIM trip unit when other means of control power is not available or for continuous OPTIMizer operation versus temporary with a battery. The auxiliary power module connects into the top of the Digitrip OPTIMizer via a keyed receptacle. The main application for the auxiliary power module would be for the testing of a standalone non-communicating OPTIM breaker that ordinarily would not have control power. 2.3 Cause of Trip Display/Remote Mount Cause of Trip Display The Cause of Trip Display can be field-installed on any Digitrip RMS 310+ trip unit. The device provides breaker information through an LCD screen, such as cause of trip, phrase current, ground current and low loads. The display is ideal for troubleshooting common trips such as ground fault, long delay, and instantaneous/short delay. The DIGIVIEW version will provide a local display at the breaker without additional wiring by connecting directly onto the trip unit. The DIGIVIEWR06 version has a 6 foot cable that allows users to mount the display on the outside of an enclosure door and connect to the trip unit that is contained inside the enclosure. 2 Cause of Trip LED Module The Cause of Trip LED Module can be field-installed on any Digitrip RMS 310+ trip unit. The device provides a cause of trip indication via LED. The Cause of Trip LED Module connects directly onto the trip unit. When the breaker trips, the module indicates the cause of trip (long delay, short delay, instantaneous and ground) via LED indication. The module is reset after the breaker is reset. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Note: The OPTIMizer can work off of 32 Vdc control power, although 24 Vdc is the standard on OPTIM breakers. 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-307 2.3 Molded Case Circuit Breakers Series C 2 Product Selection 2 Termination Hardware—End Cap Kit 2 End Cap Kit End Cap Kit Thread Type 2 Thread Size Catalog Number Two-Pole F-Frame (225A) 2 Imperial 10–32 KPEK12 Metric M–5 KPEKM12 2 Three-Pole F-Frame (225A) Imperial 10–32 KPEK1 2 Metric M–5 KPEKM1 2 Imperial 10–32 KPEK14 2 Metric M–5 KPEKM14 2 Imperial 0.312–18 KPEK2 Metric M–8 KPEKM2 2 Four-Pole J-Frame Imperial 0.312–18 KPEK24 2 Metric M–8 KPEKM24 2 Imperial 0.312–18 KPEK3 2 Metric M–8 KPEKM3 2 Imperial 0.312–18 KPEK34 Metric M–8 KPEKM34 Four-Pole F-Frame (225A) Three-Pole J-Frame Three-Pole K-Frame Four-Pole K-Frame 2 Three-Pole L-Frame Imperial 0.312-18 2 KPEK4 Metric M-8 KPEKM4 2 Four-Pole L-Frame Imperial 0.312–18 KPEK44 2 Metric M–8 KPEKM44 Thread Size Catalog Number Package of 12 (Priced Individually) 2 Termination Hardware—Keeper Nut 2 F-Frame Keeper Nut F-Frame Keeper Nut 2 Thread Type 2 Imperial 10–32 KPR1A Metric M–5 KPR1AM 2 Thread Type Thread Size Line/Load End Catalog Number Package of 3 2 Imperial 0.375–16 Line KPR3A Load KPR3B 2 Metric Line KPR3AM Load KPR3BM 2 2 K-Frame Keeper Nut 2 K-Frame Keeper Nut M–8 Note L-, M-, N-Frames not required. Terminals are threaded. 2 V4-T2-308 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Termination Hardware J-Frame Plug Nut Thread Type K-Frame Terminal Adapter 2 J-Frame Plug Nut Thread Size Catalog Number Package of 6 Imperial 0.250–20 PLN2 Metric M–6 PLN2M 2 2 2 2 K-Frame Terminal Adapter 1 Line/Load End Catalog Number 2 Line and load TAD3 2 2 2 F-Frame Ordering Information Terminals must be ordered separately. Priced individually. F-Frame Kit 2 F-Frame Control Wire Terminal Kit 2 Description Package of 12 control wire terminal tangs. Maximum Amperes Catalog Number 150 FCWTK 225 FCWTK225 2 2 2 2 2 J- and K-Frame Ordering Information Terminals must be ordered separately. Priced individually. J- and K-Frame Kit 2 J- and K-Frame Control Wire Terminal Kit Description Catalog Number Package of 12 control wire terminal tangs. KCWTK 2 2 2 2 L-Frame Control Wire Terminal Kit 2 AWG Wire Range/Number Conductors Metric Wire Range mm2 Catalog Number Al/Cu 3/0–350 kcmil (2) 95–150 TA602LDCW 3 2 Cu 250–350 kcmil (2) 120–250 T602LDCW 3 2 Al/Cu 400–500 kcmil (2) 185–240 2TA603LDKCW 45 2 Al/Cu 400–500 kcmil (2) 185–240 3TA603LDKCW 46 2 Al/Cu 400–500 kcmil (2) 185–240 4TA603LDKCW 47 2 2 Notes 1 K-Frame terminal adapter for use in replacing LB/DA breakers. 2 Not for use with T250KB terminals. 3 Individually packed. 4 Terminal kits contain one terminal for each pole and one terminal cover. 5 Two-pole kit. 6 Three-pole kit. 7 Four-pole kit. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2 2 2 V4-T2-309 2.3 2 Molded Case Circuit Breakers Series C Termination Hardware 2 G-Frame Control Wire Terminal 2 Description Catalog Number Catalog Number Control wire terminal (kit of 12) 5652B38G01 GCWTK 2 2 Multiwire Connectors Multiwire Connectors Ordering Information (Package of 3) Maximum Amperes 2 Wires per Terminal Wire Size Range AWG Cu Kit Catalog Number 1 3 14–2 3TA100G3K 6 14–6 3TA100G6K 3 14–2 3TA150F3K 6 14–6 3TA150F6K 3 14–2 3TA250J3K 6 14–6 3TA250J6K 3 14–2/0 3TA400K3K 6 14–3 3TA400K6K G-Frame 2 2 100 2 F-Frame 2 225 2 J-Frame 250 2 K-Frame 2 400 2 2 Rear Fed Terminals 2 Frame Maximum Amperes Wire Size Range AWG Cu Catalog Number 1 FD 150 14–4/0 TA150FDRF 150 14–4/0 3TA150FDRF 225 6–300 kcmil TA225FDRF 225 6–300 kcmil 3TA225FDRF 400 250–500 kcmil TA350KRF 400 250–500 kcmil 3TA350KRF 800 3/0 MAX (3) TA800MDLRF 800 3/0 MAX (3) 3TA800MDLRF 2 2 2 KD 2 MDL 2 2 2 2 Base Mounting Hardware Ordering Information Hardware for surface mounting of circuit breakers is supplied only on request. Hardware consists of mounting screws and lockwashers. Order hardware for circuit breaker pole configurations as required. Mounting Hardware 2 Screw Length in Inches (mm) 2 Catalog Number G-Frame 2 2 0.138–32 x 2.63 (3.5 x 66.7 mm) Std. 624B375G23 0.138–32 x 3.00 (3.5 x 76.2 mm) 8703C80G05 Notes 1 When catalog number starts with a 3, it indicates a kit with three terminals in each kit. Catalog number beginning with a TA indicates one terminal. 2 GD breakers require special tapping for multiwire lugs, as described in the IL or use with standard aluminum collars. 2 2 2 V4-T2-310 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Imperial Thread Mounting Hardware Number of Poles Description Type of Mounting Catalog Number 0.164-32 x 3.188-inch pan-head steel screws, lockwashers and clamps Individual 624B375G01 Group 1 624B375G02 F-Frame 1 2 2 2 2 2 0.164-32 x 1.5-inch pan-head steel screws and lockwashers Individual 4218B80G01 3, 4 0.164-32 x 1.5-inch pan-head steel screws and lockwashers Individual BMH1 2 0.250-20 x 2.75 inch pan-head steel screws and lockwashers Individual BMH2 2 0.250-20 x 1.5 inch pan-head steel screws and lockwashers Individual BMH3 2 0.250-20 x 1.5 inch filister-head steel screws and lockwashers and flat washers Individual BMH4 2 0.3125-18 x 1.25 inch filister-head steel screws and lockwashers and flat washers Individual BMH5 2 0.3125-18 x 1.25 inch pan-head steel screws and lockwashers Individual BMH5 2 J-Frame 2, 3, 4 K-Frame 2, 3, 4 L-Frame 2, 3, 4 M-Frame 2, 3 N-Frame 2, 3, 4 2 R-Frame Supplied by customer 2 2 Metric Thread Mounting Hardware Number of Poles Type of Mounting Description Catalog Number F-Frame 1 M4–0.7 x 80 mm pan-head steel screws, lockwashers, and clamps Individual 4218B80G09 Group 1 4218B80G10 2 2 2 2 M4–0.7 x 38 mm pan-head steel screws and lockwashers Individual 4218B80G11 3, 4 M4–0.7 x 38 mm pan-head steel screws and lockwashers Individual BMH1M 2 M6–0.7 x 70 mm pan-head steel screws and lockwashers Individual BMH2M 2 M6–0.7 x 38 mm pan-head steel screws and lockwashers Individual BMH3M 2 — Individual BMH4M 2 — Individual BMH5M 2 — Individual BMH5M 2 J-Frame 2, 3, 4 K-Frame 2, 3, 4 L-Frame 2, 3 2 M-Frame 2, 3 N-Frame 2, 3 R-Frame Supplied by customer 2 Note 1 One set of hardware for two circuit breakers. 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-311 2.3 2 Molded Case Circuit Breakers Series C Terminal Shields 2 G-Frame Terminal Shield 2 Number Units in Package Catalog Number 10 GTSK3 2 2 F-Frame 2 2 2 2 2 2 J-Frame 2 2 2 F-Frame Terminal Shield Standard (Package of 10) (Priced Individually) Special—For Use When Electrical Operator is Mounted on Circuit Breaker Number of Poles Location Catalog Number Catalog Number 1 Line 625B229G06 — 2 Line 625B229G07 — 3 Line 625B229G08 4210B95G01 4 Line 625B229G09 4210B95G02 J-Frame Terminal Shield Number of Poles Location Catalog Number (Package of 10) 2, 3 Line End 1266C07G01 4 Line End 6631C01G01 2, 3 Load End 6641C16G01 4 Load End 6641C16G02 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-312 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C K-Frame K-Frame Terminal Shield Number of Poles Location Catalog Number (Package of 10) 2, 3 Line TS33LN 4 Line TS34LN 3 Load TS33LD Interphase Barriers Ordering Information Two per package. Interphase Barrier L-Frame Terminal Shield 2 2 Interphase Barriers Frame Catalog Number F IPB1 J, K IPB3 L IPB4 M IPB4 N IPB5 2 2 2 2 Catalog Number (Package of 1) 2 314C420G05 2 2 Base Mounting Plate Base Mounting Plate M-Frame Terminal Shield Base Mounting Plate G-Frame GD/GHC 2 Number of Units in Package Catalog Number 2 1 207B513G01 Catalog Number (Package of 1) 2 208B966G01 2 DIN Rail Adapter DIN Rail Adapter DIN Rail Adapter G-Frame GD/GHC Number of Poles Number of Units in Package Catalog Number 1, 2 10 1225C79G01 3 10 1225C79G02 1 N-Frame Terminal Shield All Metal DIN Rail Adapter G-Frame GD/GHC Catalog Number (Package of 1) NTS3K Number of Poles Number of Units in Package Catalog Number 3 1 EGGDDIN Terminal End Covers Ordering Information The terminal end cover is available for three-pole circuit breakers only. Two conductor opening sizes are available. Specify quantity (one per circuit breaker) when ordering. F-Frame Terminal End Covers Conductor Opening Diameter in Inches (mm) Catalog Number 0.25 (6.35 mm) TEC1 0.41 (10.41 mm) TEC2 Key Operated Attachment 2 2 2 2 2 2 2 Key Operated Attachment F-Frame 2 Key Operated Attachment G-Frame GD/GHC 2 Number of Units in Package Catalog Number 2 10 GKOA 2 Note 1 For use on three-pole breakers only. 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-313 2.3 Molded Case Circuit Breakers Series C 2 Lock Dog (Non-Padlockable) 2 Lock Dog (NonPadlockable) Padlockable Handle Lock Lock Dog (Non-Padlockable) G-Frame GD/GHC/GHB/GMCP Padlockable Handle Lock Padlockable Handle Lock 2 Number of Units in Package Catalog Number Frame Catalog Number G GPHBOFF 2 1 1294C01H01 J, K PHB3 2 2 Handle Tie G-Frame—GHB/GHC 2 Number of Poles Number of Units in Package Catalog Number 2 2 10 HTBGD2P 3 10 HTBGD3P 2 2 2 Snap-On Padlockable Handle Lock Hasp Snap-On Padlockable Handle Lock Hasp Snap-On Padlockable Handle Lock Hasp Frame Catalog Number F PHL1 Non-Padlockable Handle Block Non-Padlockable Handle Block Non-Padlockable Handle Block Frame Catalog Number 2 F LKD1 2 J, K LKD3 L, M, N LKD4 2 2 Padlockable Handle 2 Padlockable Handle Padlockable G-Frame GD/GHC/GHB 2 Number of Units in Package Catalog Number 1 2 10 1223C77G03 10 1223C77G05 2 2 10 1223C77G06 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-314 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Notes 1 Accepts 0.285 Lock Shank. 2 Padlockable in the OFF position only. Molded Case Circuit Breakers Series C 2.3 Padlockable Handle Lock Hasp Padlockable Handle Lock Hasp 2 Padlockable Handle Lock Hasp 2 Catalog Number Description 2 F-Frame Single-pole breakers PHL1 Two-, three- and four-pole breakers PLK1 For left side mounting PLK1LOFF For right side mounting PLK1ROFF 2 2 2 J, K-Frames Two-, three- and four-pole breakers PLK3 For left side mounting PLK3LOFF 1 For right side mounting PLK3ROFF 2 2 1 L-Frame (Side Mounted) 2 Lock ON or OFF HLK4 Lock OFF only (left-hand mount) HLK4LOFF 1 2 Lock ON or OFF HLK4S Lock OFF only HLK4SOFF 1 2 L-Frame (Top Mounted) 2 M-Frame Lock ON or OFF HLK4 Lock OFF only (left-hand mount) HLK4LOFF 1 2 M-Frame (Vertical Mounting) Lock ON/OFF HLK4S Lock OFF only HLK4SOFF 2 2 N-Frame 2 Side mounted PLK5 Top mounted (ON/OFF) PLK5S Top mounted (OFF only) PLK5SOFF 1 2 Lock ON/OFF HLK6 2 Lock OFF only HLK6OFF 1 R-Frame 2 2 Cylinder Lock Cylinder Lock 2 Cylinder Lock Frame Catalog Number 2 F, J, K Order by description 2 2 Note 1 For padlockable handle lock hasp to padlock handle in OFF position only, order either catalog number. 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-315 2.3 2 2 2 2 2 Series C Key Interlock Kit Ordering Information Key interlock kits contain the necessary interface and hardware to install a trapped key interlock from one of the listed manufacturers. Key interlocks are not installed or supplied as part of the breaker, and must be obtained separately from the lock manufacturer or through the manufacturer of the equipment on which the breaker will be installed. Select the mounting kit catalog number to match the type of lock used. Key Interlock Kit photo 2 2 Molded Case Circuit Breakers Key Interlock Kit (Trapped Key Interlock) Lock Manufacturer Lock Type Bolt Projection in Withdrawn Position in Inches (mm) Kit Catalog Number KYK1 F-Frame position 2 Superior B-4003-1 0.38 (9.5) Kirk® F 0.38 (9.5) KYK1 Castell 1 K or QK 0.38 (9.5) CTK1 J, K-Frames 2 Superior B-4003-1 0.38 (9.5) KYK3 2 Kirk F 0.38 (9.5) KYK3 Castell 1 K or QK 0.38 (9.5) CTK3 KYK4 2 L-, M-, N-Frames Superior B-4003-1 0.38 (9.5) 2 Kirk F 0.38 (9.5) KYK4 Castell 1 K or QK 0.38 (9.5) CTK4 KYK6 2 R-Frame 2 Superior B-4003-1 1.0 (25.4) Kirk F 1.0 (25.4) KYK6 Castell 1 K or QK 1.0 (25.4) CTK6 Superior B-4003-1 0.38 (9.5) KYKJG Kirk F 0.38 (9.5) KYKJG 2 Castell 1 K or QK 0.38 (9.5) CTKJG 2 Superior B-4003-1 0.38 (9.5) KYKLG Kirk F 0.38 (9.5) KYKLG Castell 1 K or QK 0.38 (9.5) CTKLG 2 JG-Frame 2 LG-Frame 2 2 Note 1 When ordering Castell Interlock, it is necessary for customer to specify that the mounting bolt holes must be 10 mm in diameter 2 2 2 2 2 2 2 2 2 2 V4-T2-316 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C Sliding Bar Interlock Ordering Information The sliding bar interlock is available for mounting between two adjacent threepole circuit breakers with circuit breakers centerline Sliding Bar Interlock 2 spacing as indicated in table and enclosure front panel thickness of 1/8 or 3/16 inch (3.2 or 4.8 mm). (For field installation only.) 2 2 2 Sliding Bar Interlock Frame Centerline Spacing in Inches (mm) Catalog Number F 4.19 (106.4) SBK1 J 4.38 (111.3) SBK2 K 5.75 (146.0) SBK3 L, M 8.50 (215.9) SBK4 N 8.50 (215.9) SBK5 Walking Beam Interlock Ordering Information The walking beam interlock is available for mounting between two adjacent circuit breakers spaced 1/4-inch (6.4 mm) apart and having the same pole configuration. The two circuit breakers must be factory modified to accept the walking beam interlock assembly (suitable for use with either two-, three- or four-pole circuit breakers). Walking Beam Interlock 2.3 2 2 2 2 2 2 With properly modified circuit breakers, the walking beam interlock is suitable for field installation. Order circuit breakers specifying modification for walking beam (20% price adder) and select walking beam interlock from table below. Circuit breakers and walking beam interlock are boxed and shipped separately. 2 2 2 2 2 2 Walking Beam Interlock Frame Catalog Number 2 F WBL1 K WBL3 2 L, M WBL4A N WBL5 R1 WBL6 2 2 2 Note 1 Three-pole only. 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-317 2.3 Molded Case Circuit Breakers Series C 2 Electrical Operator 2 F-Frame Electrical (Solenoid) Operator 2 2 Terminal Block 18-Inch (457.2 mm) Pigtail Lead Catalog Number Voltage Frequency Catalog Number 120 AC EOP1T07 EOP1P07 240 AC EOP1T11 EOP1P11 2 2 F-Frame Electrical (Motor) Operator 1 18-Inch (457.2 mm) Pigtail Lead Voltage Frequency Catalog Number 2 120 50/60 Hz AC MOPFD120C 24 DC MOPFD24D 2 125 DC MOPFD120C 2 208–240 50/60 Hz MOPFD240C 220–250 DC MOPFD240C 2 2 2 2 2 2 2 2 2 2 2 2 J-Frame Electrical (Solenoid) Operator Terminal Block Operating Voltage Frequency Catalog Number 120 50/60 Hz AC EOP2T07 240 50/60 Hz AC EOP2T11 K-Frame Electrical (Solenoid) Operator Terminal Block Operating Voltage Frequency Catalog Number 120 50/60 Hz AC EOP3MT07 240 50/60 Hz AC EOP3MT11 K-Frame Electrical (Solenoid) Operator Base Mounting Kit Frame Catalog Number K BBMK3 2 2 2 L- and M-Frame Electrical (Motor) Operator (310 and OPTIM) Terminal Block 2 Operating Voltage Frequency Catalog Number 2 120 50/60 Hz EOP4MT07 208 50/60 Hz EOP4MT11 2 240 50/60 Hz EOP4MT11A 480 50/60 Hz EOP4MT15 125 DC EOP4MT26 24 DC EOP4MT21 2 2 2 Note 1 Motor operators MOP1P07, MOP1P03DC, MOP1P05DC and MOP1P07DC are replaced by MOPFD motor operators listed in table. V4-T2-318 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 N-Frame Electrical (Motor) Operator Pigtail Leads 2 Operating Voltage Frequency Catalog Number 2 120 50/60 Hz EOP5T07 208 50/60 Hz EOP5T09 2 240 50/60 Hz EOP5T11 480 50/60 Hz EOP5T15 24 DC EOP5T21 48 DC EOP5T22 125 DC EOP5T26 2 2 2 2 R-Frame Electrical (Motor) Operator Factory-Installed Terminal Block 2 Operating Voltage Frequency Catalog Number 2 120 50/60 Hz EOP6T08K 240 50/60 Hz EOP6T11K 2 48 DC EOP6T21K 2 2 Plug-In Adapters 2 F-Frame Ordering Information (Flat Bar Type) Continuous Current Rating (Amperes) Two-Pole Three-Pole Four-Pole Catalog Number Catalog Number Catalog Number 100–225 1480D13G01 1480D13G02 1480D13G07 1 Mounting plate 176C511H01 507C047H01 — 2 2 2 2 J-Frame Ordering Information (Flat Bar Type) Continuous Current Rating (Amperes) Two-Pole Three-Pole Four-Pole Terminal End Catalog Number Catalog Number Catalog Number 250 Line 1260C86G05 1260C86G06 1231C67G01 Load 1260C86G07 1260C86G08 1231C67G02 One line and one load 506C144G27 506C144G28 — — 2 PMP23 — Mounting plate 2 2 2 2 2 K-Frame Ordering Information (Flat Bar Type)—600 Vac Maximum 2 Two-Pole Three-Pole Four-Pole Continuous Current Rating (Amperes) Catalog Number Catalog Number Catalog Number 2 400 PAD32 PAD33 — Mounting plate 2 PMP33 — 2 2 Notes 1 100 ampere maximum. 2 Use three-pole mounting plate for two-pole circuit breaker. 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-319 2.3 Molded Case Circuit Breakers Series C 2 L-Frame (Threaded Stud Type) Two-Pole Three-Pole Four-Pole 2 Continuous Current Rating (Amperes) Catalog Number Catalog Number Catalog Number 2 600 (threaded stud type) 506C059G03 506C059G04 PAD44 600 (flat bar type) 1288C19G01 1288C19G02 6636C55H01 Mounting plate 504C824H01 504C824H01 — 2 2 2 2 2 M-Frame (Flat Bar Type)—600 Vac Maximum Two-Pole Three-Pole Continuous Current Rating (Amperes) Catalog Number Catalog Number 800 2614D53G05 2614D53G06 Mounting plate 1290C73H01 1290C73H01 2 2 2 2 2 N-Frame (Flat Bar Type) Two-Pole Three-Pole Continuous Current Rating (Amperes) Catalog Number Catalog Number 1200 2614D53G03 2614D53G04 Mounting plate 1290C73H01 1290C73H01 2 Plug-In Adapters 2 Frame Number of Poles Standard Certification Catalog Number 2 FD 3 IEC PAD3F 2 FD 4 IEC PAD4F JD 3 IEC PAD3JD 2 KD 3 IEC PAD3K LD 3 IEC PAD3LD 2 LD 4 IEC PAD4LD 2 2 2 2 2 2 2 2 2 2 2 V4-T2-320 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 Rear Connecting Studs 2 L-Frame Ordering Information F-Frame 1 Stud Ampere Rating Stud Catalog Number 2 Stud Catalog Number Tube Catalog Number 2 314C960G07 For 15 to 100 Ampere Circuit Breakers 2 314C960G08 100 A short 451D874G01 32B9446H20 100 A short 451D874G01 32B9446H21 100 A short 451D874G01 32B9446H22 100 A short 451D874G01 32B9446H23 M-Frame Ordering Information 1 100 A long 451D874G02 32B9446H24 100 A long 451D874G02 32B9446H25 Stud Ampere Rating Stud Catalog Number 100 A long 451D874G02 32B9446H26 225 314C960G01 100 A long 451D874G02 32B9446H27 400 314C960G04 400 314C960G05 400 314C960G06 600 314C960G07 600 314C960G08 600 314C960G09 800 314C960G10 800 314C960G11 800 314C960G12 For 110 to 225 Ampere Circuit Breakers 225A short 374D883G01 374D883H06 225A short 374D883G01 374D883H07 225A short 374D883G01 374D883H08 225A short 374D883G01 374D883H09 225A long 374D883G02 374D883H10 225A long 374D883G02 374D883H11 225A long 374D883G02 374D883H12 225A long 374D883G02 374D883H13 314C960G09 2 2 2 2 2 2 2 2 2 2 N-Frame Ordering Information 1 J-Frame 1 Stud Ampere Rating Stud Catalog Number Tube Catalog Number 250A short 5010D23G01 456D983H05 250A short 5010D23G01 456D983H06 250A short 5010D23G01 456D983H07 250A long 5010D23G02 5010D23H05 250A long 5010D23G02 5010D23H06 250A long 5010D23G02 5010D23H07 Stud Ampere Rating Stud Catalog Number 800 623B222G01 800 623B222G02 800 623B222G03 1200 373B375G04 1200 373B375G03 2 2 2 2 2 Note 1 Not UL listed. 2 2 K-Frame 1 Stud Ampere Rating Stud Catalog Number Standard Tube Catalog Number 400 A short 6642C14G02 313C909H17 400 A short 6642C14G04 313C909H18 400 A short 6642C14G06 313C909H19 400 A long 6642C14G03 313C909H20 400 A long 6642C14G05 313C909H21 400 A long 6642C14G07 313C909H22 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-321 2.3 Molded Case Circuit Breakers Series C 2 Panelboard Connecting Straps 2 F-Frame Panelboard Connecting Straps 2 Bus Spacing in Inches (mm) Continuous Current Rating (Amperes) 2.75 (69.9) 2.75 (69.9) Pole Connector Type Center Outside Catalog Number Catalog Number 50 673B142G02 673B142G09 100 673B142G02 673B142G10 2.75 (69.9) 150 673B142G04 673B142G03 2 3.50 (88.9) 50 1253C72G01 1253C72G03 2 3.50 (88.9) 100 1253C73G03 1253C73G06 3.50 (88.9) 150 1253C73G01 1253C73G05 2 2 2 2 F-Frame Mounting Bracket 2 Number of Poles Catalog Number 2 624B600H02 2 3 624B600H01 2 2 2 2 2 2 2 2 J-Frame Panelboard Connecting Straps Bus Spacing in Inches (mm) Continuous Current Rating (Amperes) 3.50 (88.9) 250 Pole Connector Type Center Outside Catalog Number Catalog Number 2600D26G01 2600D26G02 K-Frame Panelboard Connecting Straps Bus Spacing in Inches (mm) Continuous Current Rating (Amperes) 3.50 (88.9) 400 Pole Connector Type Center Outside Catalog Number Catalog Number 4212B78G02 4212B77G01 2 K-Frame Mounting Bracket 2 Number of Poles Catalog Number 2, 3 208B264H01 2 2 2 2 2 2 2 2 2 V4-T2-322 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Molded Case Circuit Breakers Series C 2.3 L-Frame Panelboard Connecting Straps Continuous Current Rating (Amperes) 600 2 Pole Connector Type Center Outside Catalog Number Catalog Number 624B609G01 506C052G01 2 2 2 L-Frame Mounting Bracket Number of Poles Catalog Number 2, 3 208B297H01 2 2 2 2 M-Frame Panelboard Connecting Straps Bus Spacing in Inches (mm) Continuous Current Rating (Amperes) 3.50 (88.9) 800 Pole Connector Type Connector Type Catalog Number Short 314C996G01 Medium 314C996G02 Long 314C996G03 2 2 2 2 2 M-Frame Mounting Bracket Catalog Number 2 315C270H01 2 2 N-Frame Panelboard Connecting Straps Bus Spacing in Inches (mm) Continuous Current Rating (Amperes) Pole Connector Type Connector Type Catalog Number 3.50 (88.9) 1200 Short 505C606G04 Medium 505C606G05 Long 505C606G06 2 2 2 2 2 N-Frame Mounting Bracket (Four Required) Catalog Number 2 315C270H01 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-323 2.3 2 2 2 2 2 Type LFD Current Limiter 2 2 2 2 2 2 2 Ground Fault Alarm Unit 2 2 2 2 2 2 2 interrupting capacity at up to 600 Vac. LFD current limiters for thermal-magnetic circuit breakers are listed with Underwriters Laboratories under File E47239. Type LFD Current Limiter Circuit Breaker Rating Amperes Catalog Number 15–70 LFD3070R 80–160 LFD3150R Ground Fault Alarm Unit The ground fault alarm unit is a remotely mounted device with a combination indicating light/test button that will light when the breaker trips or alarms on ground fault. The ground fault alarm unit requires a separate 120 Vac power source to power the 2 2 Series C Type LFD Current Limiter The LFD current limiter is an accessory that bolts to the load end of a standard FDB or FD thermal-magnetic and electronic circuit breaker, providing 200,000 A 2 2 Molded Case Circuit Breakers light and the internal relay, which has 1NO and 1NC contacts for remote indication. The ground fault alarm unit can be panel mounted for ordering with an optional face mounting bracket. For use on Digitrip 310 only, K- through N-Frame. GF Alarm Unit Description Catalog Number Ground fault alarm unit GFAU Face mounting bracket 1264C67G01 Potential Transformer Module The potential transformer module is required for the Digitrip OPTIM 1050 to provide a voltage input to allow the trip unit to monitor power and energy as well as power factor. The potential transformer module is a 6 VA transformer with a primary voltage input of up to 600 volt Potential Transformer Module Potential Transformer Module Description Catalog Number Potential transformer module DOPTMLN Solid-State (Electronic) Portable Test Kit The solid-state (electronic) 50/60 Hz power; it includes portable test kit provides complete instructions and verification of performance of test times for testing long all ratings of Digitrip 310 time, short time/ electronic trip units installed instantaneous operation in circuit breakers while in and optional ground fault service under varying load operation of the circuit and/or phase imbalance. The breaker. test kit operates on 120-volt, Portable Test Kit Description Solid-state (electronic) portable test kit IQ Energy Sentinel The IQ Energy Sentinel is a highly accurate, microprocessor-based, breaker-mounted device designed to monitor power and energy readings. It represents an alternative to watt meters, watt-hour meters, and watt demand meters. Key advantages include savings in space, lower installation costs, and remote monitoring capability. The IQ Energy Sentinel mounts on the load side of a Series C F-Frame (150 ampere) circuit breaker. It can be applied on three-phase, four-wire systems, or singlephase, three-wire systems with voltage connected through Phases A and C. For more information, see Descriptive Bulletin 8178. 2 2 2 2 2 2 2 V4-T2-324 line to line. Three 0.1 ampere fuses are provided on the primary of the transformer and can be used for isolation purposes during dielectric testing. The device is normally panel mounted and can feed up to 16 OPTIM trip units. Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com Catalog Number STK2 Molded Case Circuit Breakers Series C Breaker Interface Module (BIM) The Breaker Interface Module (BIM) is a panel mounted user interface device that is mounted on the front of an electrical assembly or at a remote location. The BIM is used to access, configure, test and display information for OPTIM trip units and other devices. The BIM consists of four display windows, eight function buttons, 18 LEDs, and a graphical time/current curve to provide breaker status, operational information, protection status and energy monitoring. A 24 Breaker Interface Module (BIM) Vdc power supply is required to provide power to the BIM. This is supplied by the switchboard builder to Eaton’s specifications. The BIM is a member of Eaton’s PowerNet family of communicating devices that connects OPTIM trip units, Digitrip RMS 810/910 trip units and energy sentinels as a subnetwork system. The BIM can also be connected to a main network via a PONI module to PowerNet software. Auxiliary Power Module power module connects into the top of the Digitrip OPTIMizer via a keyed receptacle. The main application for the auxiliary power module would be for the testing of a standalone non-communicating OPTIM breaker that ordinarily would not have control power. Catalog Number Digitrip OPTIMizer The Digitrip OPTIMizer is a hand-held programmer that is used to access, configure, test and display information from OPTIM trip units. The OPTIMizer plugs into the front of an OPTIM trip unit via an eight-pin telephone jack and is powered by a nine-volt battery or the auxiliary power module. One highlighted feature is the “Copy” and “Download” commands. Setting up multiple OPTIM trips can be finished in minutes and with no errors. An Auxiliary Power Module connection provides a trip test when control power is not present at the breaker. The OPTIMizer is supplied as a standard package to include the programmer, the eightpin connection cord, battery and carrying case. The auxiliary power module is optional. Note: 24 Vdc Power Supply A 24 Vdc power supply is required for all Digitrip OPTIM trip units that are required to communicate either on the main Eaton PowerNet network or as a subnetwork to a BIM. The breaker’s load is 45 mA of current. Typically one power supply is required per switchboard and can provide control power to a BIM and the OPTIM trip units. The 24 Vdc power supply should be an “isolated high quality” power supply with a “CE” label, and is normally provided by the switchboard manufacturer to Eaton’s recommendations. Digitrip OPTIMizer 2 2 2 2 2 2 Auxiliary Power Module 2 Catalog Number 2 PRTBAPMDV 2 Breaker Interface Module (BIM) BIMII Digitrip OPTIMizer Auxiliary Power Module The auxiliary power module is a power supply requiring 120 Vac input at 50 or 60 Hz that provides a 32 Vdc output. The auxiliary power module provides control power for testing an OPTIM trip unit when other means of control power is not available or for continuous OPTIMizer operation versus temporary with a battery. The auxiliary 2.3 Cause of Trip Display/Remote Mount Cause of Trip Display The Cause of Trip Display can The DIGIVIEW version will be field-installed on any provide a local display at the Digitrip RMS 310+ trip unit. breaker without additional The device provides breaker wiring by connecting directly information through an LCD onto the trip unit. The screen, such as cause of trip, DIGIVIEWR06 version has a phrase current, ground 6 foot cable that allows users current and low loads. The to mount the display on the display is ideal for outside of an enclosure door troubleshooting common and connect to the trip unit trips such as ground fault, that is contained inside the long delay, and enclosure. instantaneous/short delay. 2 2 2 2 2 2 2 Cause of Trip Display/Remote Mount Cause of Trip Display 2 Catalog Number 2 DIGIVIEW 2 DIGIVIEWR06 Cause of Trip LED Module The Cause of Trip LED Module can be field-installed on any Digitrip RMS 310+ trip unit. The device provides a cause of trip indication via LED. The Cause of Trip LED Module connects directly onto the trip unit. When the 2 breaker trips, the module indicates the cause of trip (long delay, short delay, instantaneous and ground) via LED indication. The module is reset after the breaker is reset. 2 2 2 2 Catalog Number Cause of Trip LED Module 2 OPTIMizer—standard package Catalog Number 2 TRIP-LED 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-325 2.3 Molded Case Circuit Breakers Series C 2 Accessories 2 Flex Shaft Accessories (F- through R-Frame) 2 NEMA 12 Safety Door Hardware for Flex Shaft and C371 1 Wire Seal The wire seal can be used to secure the cover on the trip unit to prevent adjustments after settings are confirmed. Handle Length in Inches (mm) Catalog Number 2 Wire Seal 4 (101.6) C361KJ4 6 (152.4) C361KJ6 Roller Latch 3 C361KR 2 2 2 2 2 2 2 2 Series C Rotary Accessories As an option, an auxiliary switch is offered so that the control panel builder may electrically indicate the status of the breaker. This accessory would be mounted on the mechanism and comes with 24-inch (609.6 mm) pigtail leads. Description Catalog Number Wire seal 5108A03H01 Notes 1 Customer: Consult with box manufacturer for correct door hardware and any adapters required for assembly. 2 The 1/4-inch x 1/2-inch (6.35 x 12.7 mm) standard mill rectangular locking bar is not supplied with these kits. 3 Third roller latch for use with 4- or 6-inch (101.6 or 152.4 mm) handle when 3 point latching is required. Series C Auxiliary Switch Catalog Number 5108A61G01 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 V4-T2-326 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Technical Data and Specifications 2 Electrical Operator F-Frame Electrical (Solenoid) Operator Rating Data 12 Voltage 3 Frequency Inrush Current Amperes Maximum Operating Time Fuse Amperes 4 120 50/60 Hz AC 10 5 cycles (80 ms) 240 50/60 Hz AC 5 5 cycles (80 ms) Frequency Inrush Current Amperes 120 AC 2 24 DC 5 48 DC 125 DC 168j Operating Voltage 3 Inrush Current Amperes 3 120 AC 31 2 208 AC 13 240 AC 12 125 DC 21 24 DC 50 F-Frame Electrical (Motor) Operator Rating Data 2567 Voltage 3 L- and M-Frame Electrical (Motor) Operator Rating Data 2 2 2 Frequency Fuse Amperes 2 50/60 Hz 31 6 208 50/60 Hz 21 — 2 240 50/60 Hz 19 4 3 2 120 480 50/60 Hz — — Voltage 3 Inrush Current Amperes Fuse Amperes 24 DC 50 — 120 30 6 48 DC 80 — 240 16 4 125 DC 21 — K-Frame Electrical (Solenoid) Operator Rating Data 2 2 2 R-Frame Electrical (Motor) Operator Rating Data mnop Operating Voltage 3 Inrush Current Amperes Fuse Amperes Operating Voltage q Frequency Motor Inrush Current Amperes 120 30 6 120 50/60 Hz 40 4 240 50/60 Hz 27 48 DC 53 24 DC 58 240 16 2 Inrush Current Amperes Operating Voltage 3 1689 2 2 N-Frame Electrical (Motor) Operator Rating Data 16kl J-Frame Electrical (Solenoid) Operator Rating Data 1689 2 2 2 2 2 2 Notes 1 UL listed under UL File E64983. 2 The electrical operator design is endurance tested for 8000 electrical operations. 3 Tolerance: +10%, –15% of nominal voltage. 4 Use current-limiting type fuse where required. 5 UL listed under UL File E64124. 6 Frequency: 50/60 Hz. 7 Maximum operating time: 3 seconds max. Operator is an intermittent duty device. The safe duty cycle (OFF to ON to OFF) should not exceed one per minute. 8 The electrical operator design has been endurance tested for 6000 electrical operations. 9 Maximum operating time: 5 cycles (80 mS). j Maximum operating time: 12 cycles. k The electrical operator design has been endurance tested for 2,500 electrical operations. l Maximum operating time: 12 cycles max. Operator is an intermittent duty device. The safe duty cycle (OFF to ON to OFF) should not exceed one per minute. m Operator is an intermittent duty service. The safe duty cycle (OFF to ON to OFF) should not exceed one per minute. n Electric Operating time at rated voltage; (a) To turn breaker ON–1/2 second max. (b) To turn breaker OFF–1/2 second max. o Motor operating temperature; Class “A” temperature limits apply. p A minimum 1 kVA power source is recommended for motor operation. q Applied voltage should be no less than 85% or no more than 110% of rated voltage. 2 For OPTIM trip, OPEOPCK kit required. 2 2 2 2 2 2 2 2 2 2 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-327 2.3 2 Molded Case Circuit Breakers Series C Dimensions Approximate Dimensions in Inches (mm) 2 Rear Connecting Studs 2 F-Frame 1 2 Stud Ampere Rating 2 2 2 2 Stud Catalog Number Panel Thickness Tube Length A B C Tube Catalog Number Dimensions D E F 0.31 (7.9)–18 For 15 to 100 Ampere Circuit Breakers 100 A short 451D874G01 1.00 (25.4) 1.06 (26.9) — 32B9446H20 — 3.63 (92.1) 100 A short 451D874G01 0.69–0.94 (17.5 to 23.8) 1.38 (34.9) — 32B9446H21 — 3.63 (92.1) 0.31 (7.9)–18 100 A short 451D874G01 0.38–0.63 (9.5 to 15.9) 1.69 (42.9) — 32B9446H22 — 3.63 (92.1) 0.31 (7.9)–18 100 A short 451D874G01 0.25–0.31 (6.4 to 7.9) 2.00 (50.8) — 32B9446H23 — 3.63 (92.1) 0.31 (7.9)–18 100 A long 451D874G02 1.00 (25.4) — 3.44 (87.3) 32B9446H24 6.13 (155.6) — 0.31 (7.9)–18 2 100 A long 451D874G02 0.69–0.94 (17.5 to 23.8) — 3.75 (95.2) 32B9446H25 6.13 (155.6) — 0.31 (7.9)–18 100 A long 451D874G02 0.38–0.63 (9.5 to 15.9) — 4.06 (103.1) 32B9446H26 6.13 (155.6) — 0.31 (7.9)–18 2 100 A long 451D874G02 0.25–0.31 (6.4 to 7.9) — 4.38 (111.3) 32B9446H27 6.13 (155.6) — 0.31 (7.9)–18 For 110 to 225 Ampere Circuit Breakers 2 225A short 374D883G01 1.00 (25.4) 1.06 (26.9) — 374D883H06 — 4.25 (108.0) 0.44 (11.1)–14 225A short 374D883G01 0.69–0.94 (17.5 to 23.8) 1.38 (34.9) — 374D883H07 — 4.25 (108.0) 0.44 (11.1)–14 225A short 374D883G01 0.38–0.63 (9.5 to 15.9) 1.69 (42.9) — 374D883H08 — 4.25 (108.0) 0.44 (11.1)–14 225A short 374D883G01 0.25–0.31 (6.4 to 7.9) 2.00 (50.8) — 374D883H09 — 4.25 (108.0) 0.44 (11.1)–14 2 2 2 225A long 374D883G02 1.00 (25.4) — 3.44 (87.3) 374D883H10 7.50 (190.5) — 0.44 (11.1)–14 225A long 374D883G02 0.69–0.94 (17.5 to 23.8) — 3.75 (95.2) 374D883H11 7.50 (190.5) — 0.44 (11.1)–14 225A long 374D883G02 0.38–0.63 (9.5 to 15.9) — 4.06 (103.1) 374D883H12 7.50 (190.5) — 0.44 (11.1)–14 2 225A long 374D883G02 0.25–0.31 (6.4 to 7.9) — 4.38 (111.3) 374D883H13 7.50 (190.5) — 0.44 (11.1)–14 2 F-Frame 2 2 2 2 E B Mounting Panel 2 .75 (19.1) 2 2 “F” Thread Breaker Mounting Surface .06 (1.5) A C D Note 1 Not UL listed. 2 2 2 2 2 2 2 V4-T2-328 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com 2.3 Molded Case Circuit Breakers Series C Approximate Dimensions in Inches (mm) 2 J-Frame Stud Ampere Rating Stud Catalog Number Panel Thickness Tube Length A B C Tube Catalog Number 250A short 5010D23G01 0.75–1.00 (19.1–25.4) 0.84 (21.4) — 456D983H05 250A short 5010D23G01 0.50–0.75 (12.7–19.1) 1.09 (27.7) — 456D983H06 250A short 5010D23G01 0.25–0.50 (6.4–12.7) 1.03 (26.2) — 456D983H07 250A long 5010D23G02 0.75–1.00 (19.1–25.4) — 3.88 (98.6) 5010D23H05 250A long 5010D23G02 0.50–0.75 (12.7–19.1) — 4.13 (104.9) 5010D23H06 250A long 5010D23G02 0.25–0.50 (6.4–12.7) — 4.38 (111.3) 5010D23H07 1.59 (40.4) 0.59 (15.0) 0.06 (1.5) 2 2 2 2 2 2 2 6.66 (169.2) 2 C A 0.03 (0.7) 2 0.31 (7.9) – 18 Thread 2 2 Do Not Use More Than 10 Ft Lbs Torque to Tighten Nuts 0.50 (12.7) – 13 Thread 2 Breaker 2 B Mounting Panel 3.63 (92.2) 2 2 K-Frame 1 Stud Ampere Rating Stud Catalog Number Panel Thickness Tube Length A B 400 A short 6642C14G02 0.75–1 (19.1–25.4) 400 A short 6642C14G04 0.50–0.75 (12.7–18.4) 2 C Standard Tube Catalog Number Dimensions D E F 0.84 (21.3) — 313C909H17 — 3.66 (93.0) 0.75–16 (19.1–406.4) 1.09 (27.69) — 313C909H18 — — — 400 A short 6642C14G06 0.25–0.5 (6.35–12.7) 1.03 (26.16) — 313C909H19 — — — 400 A long 6642C14G03 0.75–1 (19.1–25.4) — 3.78 (96.0) 313C909H20 — — — 400 A long 6642C14G05 0.50–0.75 (12.7–18.4) — 4.03 (102.4) 313C909H21 6.58 (167.1) — — 400 A long 6642C14G07 0.25 –0.5 (6.35–12.7) — 4.28 (108.7) 313C909H22 — — — 2 2 2 2 2 E B Mounting Panel 2 2 2 “F” Thread Breaker Mounting Surface 2 0.06 (1.5) 1.67 (42.4) 2 A C 2 D 2 Note 1 Not UL listed. 2 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com V4-T2-329 2.3 Molded Case Circuit Breakers Series C 2 Approximate Dimensions in Inches (mm) 2 L-Frame 2 Stud Length (A) Stud Catalog Number 5.47 (138.9) 314C960G07 2 7.97 (202.4) 314C960G08 10.47 (265.9) 314C960G09 2 2 .44 (11.2) A 2 Insulators Washer 2 Nut 2 2 Circuit Breaker 2 Insulating Panel Rear Connecting Stud 2 2 M-Frame Stud Ampere Rating Diameter and Thread Extension Back of Breaker Stud Catalog Number 2 225 0.50 (12.7)–13 3.66 (93.0) 314C960G01 400 0.75 (19.1)–16 5.91 (150.1) 314C960G04 2 400 0.75 (19.1)–16 8.41 (213.6) 314C960G05 400 0.75 (19.1)–16 10.91 (277.0) 314C960G06 2 600 1.00 (25.4)–12 5.91 (150.1) 314C960G07 2 600 1.00 (25.4)–12 8.41 (213.6) 314C960G08 600 1.00 (25.4)–12 10.91 (277.0) 314C960G09 2 800 1.13 (28.7)–12 5.91 (150.1) 314C960G10 800 1.13 (28.7)–12 8.41 (213.6) 314C960G11 2 800 1.13 (28.7)–12 10.91 (277.0) 314C960G12 Stud Ampere Rating Diameter and Thread Extension Back of Breaker Stud Catalog Number 800 1.13 (28.7)–12 5.5 (139.7) 623B222G01 2 800 1.13 (28.7)–12 8.0 (203.2) 623B222G02 2 800 1.13 (28.7)–12 10.5 (266.7) 623B222G03 1200 1.25 (31.8)–12 5.5 (139.7) 373B375G04 1200 1.25 (31.8)–12 10.5 (266.7) 373B375G03 2 2 2 2 2 N-Frame 2 2 2 2 V4-T2-330 Volume 4—Circuit Protection CA08100005E—October 2015 www.eaton.com
HFDE322521 价格&库存
很抱歉,暂时无法提供与“HFDE322521”相匹配的价格&库存,您可以联系我们找货
