250NHG1B
250NHG1B
    EATON(伊顿)
    Rectangular,Blade
    FUSE SQUARE 250A 500VAC/250VDC
250NHG1B 数据手册
BUSSMANN Technical Data 720109 Effective September 2015 Supersedes February 2015 SERIES Bussmann series 690 Volts gG/gL NH Fuse links Product description Eaton’s Bussmann series 690 V a.c. NH square bodied industrial fuse links are suitable for a wide variety of applications. Standard features • Reliable dual indicator system • Low temperature rise • Globally compliant • Compatible with Bussmann series PV NH base range (see data sheet 10163) Technical Data 720109 Bussmann series 690 Volts gG/gL NH Fuse links Effective September 2015 Catalogue symbol: Fuse holders (ordered separately) (amp)NHG(size)B-690 with conducting metal gripping lugs • • Fuse size: • • 000 to 4* • Fuse bases 1 pole: • DIN-Rail mounting SD(size)-D Screw mounting SD(size)-S Fuse bases 3 pole • DIN-Rail mounting TD(size)-D Technical data: • Volts: 690 V a.c. • Amps: 2 to 800 A • Breaking capacity: 120 kA AC • Operating frequency: 45-62 Hz • Class of operation: gG/gL Standards/Approvals: • IEC 60269 • VDE 0636 • DIN 43620 Microswitches: • 170H0236 • BVL50 Packaging: • Sizes 000 to 3: 3 per carton • Size 4: 1 per carton Size - mm Table 1. NH Sizes Size a1 a2 (max) a3 a4 b c1 c2 d e1 (max) e2 (max) e3 (max) e4 f (max) 000 78.5 ± 1.5 54 45±1.5 49±1.5 15 35 10 2±0.5 41 21 16 6 8 00 78.5 ± 1.5 54 45±1.5 49±1.5 15 35 11 2±0.5 48 30 25 6 15 1 135±2.5 75 62±2.5 68±2.5 20 40 11 2.5±0.5 53 40 25 6 15 2 150±2.5 75 62±2.5 68±2.5 25 48 11 2.5±0.5 61 53 25 6 15 3 150±2.5 75 62±2.5 68±2.5 32 60 11 3±0.5 75 70 25 6 18 4* 200±3 84 62±2.5 90±3 50 85 10 3±0.5 102 87 25 8 30 * Single indication slotted tags 2 EATON www.eaton.com Bussmann series 690 Volts gG/gL NH Fuse links Technical Data 720109 Effective September 2015 Table 2. Part numbers Size 000 00 1 2 3 4 Rated current (Amps) 2 4 6 10 16 20 25 32 35 40 50 63 50 63 80 100 125 160 50 63 80 100 125 160 200 224 250 200 224 250 315 250 315 355 400 425 500 630 800 Rated voltage (V a.c.) 690 660 690 gG/gL dual indicator Voltage conducting metal gripping lugs 2NHG000B-690 4NHG000B-690 6NHG000B-690 10NHG000B-690 16NHG000B-690 20NHG000B-690 25NHG000B-690 32NHG000B-690 35NHG000B-690 40NHG000B-690 50NHG000B-690 63NHG000B-690 50NHG00B-690 63NHG00B-690 80NHG00B-690 100NHG00B-690 125NHG00B-690 160NHG00B-660 50NHG1B-690 63NHG1B-690 80NHG1B-690 100NHG1B-690 125NHG1B-690 160NHG1B-690 200NHG1B-690 224NHG1B-690 250NHG1B-690 200NHG2B-690 224NHG2B-690 250NHG2B-690 315NHG2B-690 250NHG3B-690 315NHG3B-690 355NHG3B-690 400NHG3B-690 425NHG3B-690 500NHG3B-690 630NHG4B-690 800NHG4B-690 Pack quantity 3 1 * Available upon request EATON www.eaton.com 3 Bussmann series 690 Volts gG/gL NH Fuse links Technical Data 720109 Effective September 2015 Time in seconds (s) Time-current curves - NH Size 000 Current in Amps (A) Technical data - NH size 000 I2t (Amps2 Seconds) Part numbers with metal gripping lugs 2NHG000B-690 4NHG000B-690 6NHG000B-690 10NHG000B-690 16NHG000B-690 20NHG000B-690 25NHG000B-690 32NHG000B-690 35NHG000B-690 40NHG000B-690 50NHG000B-690 63NHG000B-690 Fuse link size 000 Rated current (Amps) 2 4 6 10 16 20 25 32 35 40 50 63 Rated voltage (V a.c.) 690 Minimum pre-arcing 3.5 6 14 60 240 500 920 1800 2800 3300 6100 6500 *I1 120kA at 690 V a.c. 8 16 25 400 1200 2500 4400 9600 15,000 15,000 26,500 30,500 Watts loss 4 2 2 1.5 2.5 2.5 3.5 3.5 4 4 5.5 5.5 Net weight per fuse (kg) 0.118 *I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements EATON www.eaton.com 4 Technical Data 720109 Bussmann series 690 Volts gG/gL NH Fuse links Effective September 2015 Time in seconds (s) Time-current curves - NH Size 00 Current in Amps (A) Technical data - NH size 00 I2t (Amps2 Seconds) Part numbers with metal Fuse link gripping lugs size 50NHG00B-690 00 63NHG00B-690 80NHG00B-690 100NHG00B-690 125NHG00B-690 160NHG00B-660 Rated current (Amps) 50 63 80 100 125 160 Rated voltage (V a.c.) 690 660 Minimum pre-arcing 5800 5800 11,000 19,000 27,500 40,500 *I1 120kA at 690 V a.c. 35,000 43,000 54,500 92,000 105,000 135,000 Watts loss 5 5 7 7.5 9.5 13 *I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements 5 EATON www.eaton.com Net weight per fuse (kg) 0.182 Bussmann series 690 Volts gG/gL NH Fuse links Technical Data 720109 Effective September 2015 Time in seconds (s) Time-current curves - NH Size 1 Current in Amps (A) Technical data - NH size 1 I2t (Amps2 Seconds) Part numbers with metal gripping lugs 50NHG1B-690 63NHG1B-690 80NHG1B-690 100NHG1B-690 125NHG1B-690 160NHG1B-690 200NHG1B-690 224NHG1B-690 250NHG1B-690 Fuse link size 1 Rated current (Amps) 50 63 80 100 125 160 200 224 250 Rated voltage (V a.c.) 690 Minimum pre-arcing 6350 6800 10,500 *I1 120kA at 690 V a.c. 26,500 36,000 47,500 Watts loss 6.4 5.6 7.7 22,000 29,000 71,000 105,000 120,000 150,000 105,000 120,000 240,000 350,000 430,000 520,000 8.2 13 13 17 19 22 Net weight per fuse (kg) 0.38 *I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements EATON www.eaton.com 6 Technical Data 720109 Bussmann series 690 Volts gG/gL NH Fuse links Effective September 2015 Time in seconds (s) Time-current curves - NH Size 2 Current in Amps (A) Technical data - NH size 2 I2t (Amps2 Seconds) Part numbers with metal gripping lugs 200NHG2B-690 224NHG2B-690 250NHG2B-690 315NHG2B-690 Fuse link size 2 Rated current (Amps) 200 224 250 315 Rated voltage (V a.c.) 690 Minimum pre-arcing 99,000 130,000 170,000 *I1 120kA at 690 V a.c. 385,000 485,000 625,000 Watts loss 18 20 23 295,000 760,000 32 *I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements 7 EATON www.eaton.com Net weight per fuse (kg) 0.62 Bussmann series 690 Volts gG/gL NH Fuse links Technical Data 720109 Effective September 2015 Time in seconds (s) Time-current curves - NH Size 3 Current in Amps (A) Technical data - NH size 3 I2t (Amps2 Seconds) Part numbers with metal gripping lugs 250NHG3B-690 315NHG3B-690 355NHG3B-690 400NHG3B-690 425NHG3B-690 500NHG3B-690 Fuse link size 3 Rated current (Amps) 250 315 355 400 425 500 Rated voltage (V a.c.) 690 Minimum pre-arcing 160,000 375,000 400,000 *I1 120kA at 690 V a.c. 715,000 1,400,000 1,650,000 Watts loss 21 22 25 475,000 630,000 856,000 1,600,000 1,700,000 2,480,000 37 35 43 Net weight per fuse (kg) 0.38 *I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements EATON www.eaton.com 8 Technical Data 720109 Bussmann series 690 Volts gG/gL NH Fuse links Effective September 2015 Time in seconds (s) Time-current curves - NH Size 4 Single indication slotted tags Current in Amps (A) Technical data - NH size 4 I2t (Amps2 Seconds) Part numbers with metal gripping lugs 630NHG4B-690 800NHG4B-690 Fuse link size 4 Rated current (Amps) 630 800 Rated voltage (V a.c.) 690 Minimum pre-arcing 1,730,000 3,330,000 *I1 120kA at 690 V a.c. 6,550,000 11,000,000 Watts loss 44 61 Net weight per fuse (kg) 2.5 *I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton Industries Manufacturing GmbH Electrical Sector EMEA Route de la Longeraie 71110 Morges, Switzerland Eaton.eu © 2015 Eaton All Rights Reserved Publication No. 720109 September 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
250NHG1B 价格&库存
很抱歉,暂时无法提供与“250NHG1B”相匹配的价格&库存,您可以联系我们找货
250NHG1B
  • 1+65.99249
  • 100+65.87794
  • 500+65.75297
库存:5
250NHG1B
  • 1+82.509141+10.72370
  • 45+75.7275745+9.84230
  • 60+73.6409360+9.57110
  • 75+71.8151275+9.33380
  • 90+70.1632090+9.11910
  • 120+67.38102120+8.75750
  • 150+66.16381150+8.59930
  • 225+64.59883225+8.39590
库存:3
