Chip™ Fuses
3216FF Series, Fast Acting
Description
• RoHS Compliant
• Surface mount fuse, fast acting
• Rapid interruption of excessive current
• Compatible with reflow and wave solder
• Excellent environmental integrity
• Ampere rating marked and oriented facing up in carrier
• Solder-free design provides excellent temperature
cycling characteristics
• Heat and shock tolerant
ELECTRICAL CHARACTERISTICS
Ampere Rating % of Amp Rating
Opening Time
250mA - 7A
100%
4 Hours Minimum
1.25A - 3A
200%
60 Seconds Maximum
250mA - 3A
250%
5 Second Maximum
4A - 7A
350%
1 Second Maximum
Dimensions
mm
⁄(inches)
Drawing Not to Scale
Agency Information
• UL Recognition Guide & File numbers:
JDYX2 & E19180.
• CSA Component Acceptance: 053787 C 000 &
Class No: 1422 30.
Environmental Data
• Thermal Shock: MIL-STD-202, Method 107,
Test Condition B
• Vibration: MIL-STD-202, Method 204, Test Condition C
• Moisture Resistance: MIL-STD-202, Method 106,
10 day cycle
• Solderability: ANSI/J-STD-002, Test B
Ordering
• Specify packaging code and product code
(i.e. TR/3216FF250-R)
Land Pattern
Soldering Method
• Wave Immersion: 260°C, 10 sec max.
• Infrared Reflow: 260°C, 30 sec max.
SPECIFICATIONS
Product Code
Current
Rating
3216FF250-R
3216FF375-R
3216FF500-R
3216FF750-R
3216FF1-R
3216FF1.5-R
3216FF2-R
3216FF2.5-R
3216FF3-R
3216FF4-R
3216FF4.5-R
3216FF5-R
3216FF6.5-R
3216FF7-R
250mA
375mA
500mA
750mA
1A
1.5A
2A
2.5A
3A
4A
4.5A
5A
6.5A
7A
Voltage
Rating
AC
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
32 V
DC
63 V
63 V
63 V
63 V
63 V
63 V
63 V
63 V
63 V
32 V
32 V
32 V
32 V
32 V
Interrupting
Rating*
AC/DC
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
50 A
Resistance
(ohms)**
Typ.
3.50
1.75
0.98
0.75
0.219
0.119
0.066
0.046
0.036
0.018
0.016
0.014
0.0085
0.0085
Typical
Melt I2t†
DC
0.000084
0.0002
0.0019
0.00095
0.007
0.029
0.049
0.112
0.165
0.189
0.328
0.619
3.21
3.53
Typical
Voltage
Drop (V)‡
1.4
0.73
0.66
0.63
0.20
0.18
0.16
0.14
0.13
0.11
0.10
0.09
0.076
0.078
* AC Interrupting Rating (Measured at rated voltage with a unity power factor); DC Interrupting Rating (Measured at rated voltage, time constant of less than 50
microseconds, battery source)
** DC Cold Resistance (Measured at 10% of rated current)
† Typical Melting I2t (Measured with a battery bank at rated DC voltage, 10x-rated current, not to exceed IR, time constant of calibrated circuit less than 50
microseconds) (6.5A & 7A measured at interrupting rating)
‡ Typical Voltage Drop (Measured at rated current after temperature stabilizes)
It is recommended that fuses be mounted with ceramic (white) side facing up.
Device designed to carry rated current for four hours minimum. An operating current of 80% or less of rated current is recommended, with further derating required at
elevated ambient temperatures.
Chip™ Fuses
TIME CURRENT CURVE
PACKAGING CODE
Packaging Code
TR
Visit us on the web at:
www.CooperET.com
OC-2540 Rev. A 7/05
© Cooper Electronic
Technologies 2005
Description
3,000 pieces of fuses on 8mm tape-and-reel on a 7 inch (178mm) reel per EIA Standard 481
North America
Cooper Bussmann
Cooper Electronic Technologies
P.O. Box 14460
3601 Quantum Boulevard
St. Louis, MO 63178-4460
Boynton Beach, FL 33426-8638
Tel: 1-636-394-2877
Tel: 1-561-752-5000
Fax: 1-800-544-2570
Fax: 1-561-742-0134
Toll Free: 1-888-414-2645
Europe
Cooper (UK) Limited
Burton-on-the-Wolds
Leicestershire • LE12 5TH UK
Tel: +44 (0) 1509 882 737
Fax: +44 (0) 1509 882 786
Asia Pacific
1 Jalan Kilang Timor
#06-01 Pacific Tech Centre
Singapore 159303
Tel: +65 278 6151
Fax: +65 270 4160
很抱歉,暂时无法提供与“3216FF4-R”相匹配的价格&库存,您可以联系我们找货
