AGC-4-R
AGC-4-R
    EATON(伊顿)
    D6.35xL31.75mm
    一次性保险丝(熔断) 4A 250V
AGC-4-R 数据手册
Fast-Acting 1/4” x 1 1⁄4” Glass Tube Fuses AGC Series Dimensions - in Description • • • • • Fast-acting Optional axial leads available 1 ⁄4” x 1 1⁄4” (6.3 x 32mm) physical size Glass tube, nickel-plated brass endcap construction UL Listed product meets standard 248-14 Agency Information • • • • UL Listed Card: AGC 1⁄20-10 UL Recognition Card: AGC 11-40 CSA Component Acceptance Card (Class No. 1422 30) CSA Certification Card (Class No. 1422 01) Environmental Data • Shock: 1⁄20 - 3⁄4A – MIL-STD-202, Method 213, Test Condition I; 1 - 30A – MIL-STD-202, Method 207, (HI Shock) • Vibration: 1⁄20 - 30A – MIL-STD-202,Method 204, Test Condition A (Except 5g, 500Hz) Ordering • Specify packaging code prefix, part number and option code suffix (if applicable) Specifications • See page 2 1116 Page 1 of 3 Data Sheet 2543 Part Number AGC-1⁄20-R AGC-1⁄10-R AGC-1⁄8-R AGC-3⁄16-R AGC-2⁄10-R AGC-1⁄4-R AGC-3⁄10-R AGC-3⁄8-R AGC-1⁄2-R AGC-3⁄4-R AGC-1-R AGC-1-1⁄4-R AGC-1-1⁄2-R AGC-2-R AGC-2-1⁄4-R AGC-2-1⁄2-R AGC-3-R AGC-4-R AGC-5-R AGC-6-R AGC-7-R AGC-7-1⁄2-R AGC-8-R AGC-9-R AGC-10-R AGC-12-R AGC-14-R AGC-15-R AGC-20-R AGC-25-R AGC-30-R AGC-35-R AGC-40-R AC Voltage Rating 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 32 32 32 32 32 32 32 32 SPECIFICATIONS AC Interrupting Rating (amps) 250 125 32 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 35 10,000 — 100 10,000 — 100 10,000 — 100 10,000 — 100 10,000 — 100 10,000 — 100 10,000 — 200 10,000 — 200 10,000 — 200 10,000 — 200 10,000 — 200 10,000 — 200 10,000 — 200 10,000 — 200 10,000 — — — 1000 — — 1000 — — 1000 — — 1000 — — 1000 — — 1000 — — 70 — — 80 Typical DC Cold Resistance* (Ω) 4.500 12.565 6.800 4.900 3.360 2.300 1.670 1.203 0.615 0.312 0.190 0.145 0.115 0.078 0.067 0.057 0.045 0.030 0.024 0.020 0.017 0.0146 0.014 0.012 0.008 0.0070 0.0062 0.006 0.004 0.003 0.002 0.0014 0.0019 Typical Melting I2t† AC 0.00773 0.000787 0.00131 0.00637 0.00435 0.0148 0.0208 0.0321 0.269 0.815 1.615 0.018 0.0149 0.00509 0.00588 0.00879 0.0167 0.0305 0.045 0.071 0.105 — 0.152 0.21 0.492 — — 0.566 1.438 2.109 3.807 — — * DC Cold Resistance (Measured at ≤10% of rated current) † Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage.) ‡ Typical Voltage Drop (Voltage drop was measured at 25°C ambient temperature at rated current) 1116 Page 2 of 3 Data Sheet 2543 Typical Voltage Drop‡ 0.67 6.00 4.67 4.12 4.51 0.89 2.88 4.59 0.59 0.37 0.31 0.35 0.27 0.28 0.26 0.31 0.25 0.22 0.23 0.23 0.23 — 0.19 0.18 0.20 — — 0.14 0.12 0.11 0.12 — — Time-Current Curves CURRENT IN AMPERES 1-1/2 2 2-1/2 3 4 3/4 1 2/10 1/4 3/10 3/8 1/2 CURRENT IN AMPERES TIME IN SECONDS 1/10 1/8 1/16 TIME IN SECONDS Packaging Code Prefix Code BK BK1 Description 100 pieces of fuses packed into a cardboard carton with flaps folded 1000 pieces of fuses packed into a cardboard carton with flaps folded Code B V -R Description Board Washable - Hermetically sealed to withstand aqueous cleaning Axial leads - copper tinned wire with nickel-plated brass overcaps RoHS Compliant Option Code Suffix The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2013 Cooper Bussmann www.cooperbussmann.com 1116 Page 2 of 3 Data Sheet 2543
AGC-4-R 价格&库存
很抱歉,暂时无法提供与“AGC-4-R”相匹配的价格&库存,您可以联系我们找货
