Technical Data 10132
Effective January 2021
Supersedes December 2019
S505SC
5 mm x 20 mm Time-delay, axial lead ceramic tube fuses
HALOGEN
Pb HF
FREE
Applications
Primary circuit protection:
Power supplies
LED lighting
LED/LCD televisions
Appliances and white goods
Printers
Agency information
Product features
Time-delay, high breaking capacity
Designed to IEC 60127-2
Nickel-plated brass end cap construction
5 mm x 20 mm physical size
cURus Recognition file number: E19180, Guide
JDYX2/JDYX8
SEMKO: File 1219335, 1310139
VDE: File 40024252, 40037710 (1 A - 8 A)
BSI: File KM55676
IMQ: File CA03.00529
PSE/JET: JET1641-31003-1010, JET1641-310032002, JET7042-31003-2001
CCC self declaration: 2020970207000210
KC-Mark: File SU05011-12003, SU05011-12004,
SU05011-12005A; SU05030-13003A, SU0503013004, SU05030-13005
TUV: J50233218
Ordering
The ordering code is the part number replacing
the “.” with a “-” plus adding the packaging
prefix (i.e. S505SC-1.25-R; BK-S505SC1-25-R)
Packaging prefixes
BK- (20 parts in a carrier, 5 carriers in a box)
TR2- (1500 parts per reel, tape width 52 mm)
TR3- (1500 parts per reel, tape width 54 mm)
S505SC
Electrical characteristics
ln
1.5ln
min
minute
2.1ln
max
minute
2.75ln
min
ms
max
s
4ln
min
ms
max
s
10ln
min
ms
max
ms
1 A-3.15 A
60
30
750
80
95
5
10
150
4 A-6.3 A
60
30
750
80
150
5
10
150
8 A-10 A
30
30
750
80
150
5
10
150
Product specifications
Part number5
Current
rating (A)
Voltage
rating
(Vac)
Interrupting
rating at rated
voltage (50
Hz) (A)
Typical
DC cold
resistance
(Ω)2
Typical
pre-arcing l2t
(A2s)3
Typical
voltage
drop
(mV)4
IMQ
VDE
SEMKO
cURus
PSE/
JET
CCC
KC
BSI
TUV
S505SC-1-R
1.0
250
1500
0.169
1.38
180
x
x
x
x
x
x
x
x
x
S505SC-1.25-R
1.25
250
1500
0.108
2.14
151
x
x
x
x
x
x
x
x
x
S505SC-1.6-R
1.6
250
1500
0.070
7.35
130
x
x
x
x
x
x
x
x
x
S505SC-2-R
2.0
250
1500
0.055
9.83
123.5
x
x
x
x
x
x
x
x
x
S505SC-2.5-R
2.5
250
1500
0.040
19.9
119
x
x
x
x
x
x
x
x
x
S505SC-3.15-R
3.15
250
1500
0.031
40.4
110
x
x
x
x
x
x
x
x
x
S505SC-4-R
4.0
250
1500
0.018
41.0
89.8
x
x
x
x
x
x
x
x
x
S505SC-5-R
5.0
250
1500
0.013
71.2
88
x
x
x
x
x
x
x
x
x
S505SC-6.3-R
6.3
250
1500
0.010
152
72.5
x
x
x
x
x
x
x
x
x
S505SC-8-R
8.0
250
1500
0.007
237
82.5
x
x
x
x
x
x
x
x
x
S505SC-10-R
10
250
1500
0.005
353
70
x
x
x
x
x
x
x
x
1 Interrupting ratings 1 A to 10 A were measured at 70% to 80% PF on AC.
2 Typical DC cold resistance measured at
很抱歉,暂时无法提供与“BK-S505SC-6-3-R”相匹配的价格&库存,您可以联系我们找货
