BK/ETF 1A
BK/ETF 1A
    EATON(伊顿)
    EATON BUSSMANN - BK/ETF 1A - Fuse, PCB Leaded, 1 A, 250 VAC, Time Delay, Radial Leaded
BK/ETF 1A 数据手册
Bussmann Table of Contents Fuse Holder Selection Chart 2 Surface Mount Fuses 3 Axial and Radial Leaded Fuses 8 5 x 15mm Fuses 12 5 x 20mm Fuses 18 6.3 x 32mm Fuses 36 Automotive Fuses 46 Miscellaneous Fuses 47 Fuse Clips for 5mm dia. Fuses 51 Fuse Clips for 6.3mm dia. Fuses 53 Fuse Clips Miscellaneous Sizes 55 Fuse Clips Automotive 56 Fuse Holders 57 Fuse Holders In-Line 63 Fuse Holders In-Line Automotive 64 Fuse Blocks 65 Fuse Technology and Glossary of Terms 67 Parts Index 68 ® Useful Telephone Numbers UK Sales Phone: Fax: 01509 882606 01509 882788 Export Sales Phone: Fax: +44 1509 882700 +44 1509 882789 Application Engineers Phone: Fax: +44 (0)1509 882766 +44 (0)1509 882760 +44 (0)1509 882786 Catalogue Requests Phone: Fax: e-mail: +44 (0)1509 882715 +44 (0)1509 882794 micht@bussmann.co.uk Sales on e-mail: sales@bussmann.co.uk World Wide Web Site www.bussmann.com Our World Wide Web site has information on all Bussmann products, together with catalogues and Data Sheets and useful application information. www.bussmann.com e-mail: sales@bussmann.co.uk Sales Fax: +44 (0)1509 882788 1 Bussmann Fuse Holder Selection Chart P a n el Mo u n t F u se Ty pe an d Holders S ize S crewdriver S lot Carrier P a n el Mo u n t Holders F in gergrip S crew or Bay on et Carrier P C Board Holders en closed ® P C Board Holders o p en F u se Blocks In -lin e F u se Holders F u se Clips 5 x 20mm S500 to S508 GDA, GDB and GDC GMA, GMC and GMD C640 and C641 HTB3*M HTB5*M HTB9*M HTC35M HTC40M HTC55M HTC70M HTB2*M Series HTB4*M Series HTB6*M Series HBV-M HBW-M HBH-M HTC15M HTC15MS HTC200M HTC210M HTC220M 1A3399 1A5108 1A5601 1A5602 HTC10M HTC200M HTC210M HTC220M 1A3399 1A5108 1A5601 1A5602 5 x 15mm C519 C520 6.3 x 32mm TDC10 TDA304 TDC455 ABC AGC MDQ GBB TDC11 TDC436 TDC459 MDL MDA 6.3 x 32mm GBA and GLD 6.3 x 25.4mm AGX TDC180 2 HTB3*I HTB5*I HTB9*I HTB2*I HTB4*I HTB6*I HTB8*I HKP Series HK L HM R HBV-I HBW-I HBH-I S8000 Series 2499 4574 4405 4406 HFB HHB HFA 1A3398 1A4533 1A1907 1A4534 1A1119 1A1120 5681 5682 S8000 Series HLD HJL HJM HM S 2499 4574 4405 4406 4520 4393 3828 1A3398 1A4533 1A1907 1A4534 1A1119 1A1120 5681 5682 HHB HRK 1A3398 1A4533 1A1907 1A4534 1A1119 1A1120 5681 5682 Application Engineers +44 (0)1509 882766 or 882760 Bussmann Surface Mount Fuses ® 1608FF Agency Approvals: ▲ General Description: Bussmann SMT Chip Fuses utilise thick and thin metal film technologies for superior fusing action and enhanced reliability. The fuse element is bonded to a ceramic substrate and encapsulated with glass, providing excellent short circuit performance and environmental integrity. Predicted reliability of the 1608FF chip fuse is 30 times greater than that of the typical chip capacitor (consult Bussmann for details). Substrate and coating thermal expansion coefficients are closely matched to that of FR-4 epoxy glass circuit board for superior solder joint reliability. The end terminations are over-plated with nickel and tin base. Breaking Capacity: Type: Time Current Characteristics: Very Fast Acting Ratings (A): 250mA to 4A Rated Voltage: 35 A @ rated voltage 100% rated current: 250% rated current: Order Code: Packing Code + 1608FF + Rating 24V dc 4 hours minimum carry. open within 5 seconds. Dimensions (mm): Packing Code Prefix: TR = 3,000 pieces on 8mm tape on a 178mm reel TR1 = 15,000 pieces on 8mm tape on a 330mm reel SP = 50 pieces on tape in a plastic box Performance Data P art Nu mber xx = P ackin g Co de xx/1608F F -250mA xx/1608F F -375mA xx/1608F F -500mA xx/1608F F -750mA xx/1608F F -1A xx/1608F F -1. 5A xx/1608F F -2A xx/1608F F -2. 5A xx/1608F F -3A xx/1608F F -3. 5A xx/1608F F -4A Cu rren t Ratin g (A) Colou r Code (Cover/S tripe) 0.25 0.375 0.5 0.75 1 1.5 2 2.5 3 3.5 4 Green Green/White Blue Blue/White Brown Brown/White Black Black/White Violet Violet/White Yellow Ty p. Resistan ce Ty p. Voltage D rop Ty p. P re-arcin g @ ≤ 10% Rated @ Rated Cu rren t I 2t @ 3 5 A Cu rren t (O h ms) (Volts) ( A 2 s ec ) 3.0 0.90 .000067 2.0 0.80 .00015 0.9 0.54 .00055 0.51 0.45 .00132 0.15 0.18 .0022 0.068 0.12 .014 0.042 0.11 .037 0.029 0.09 .070 0.022 0.087 .095 0.018 0.08 .185 0.014 0.08 .270 Ty p. O peratin g I2t @ 3 5 A ( A 2 s ec ) .000082 .00017 .00058 .00137 .0026 .015 .038 .078 .107 .190 .272 Notes: 1 AC interrupting rating, melting integral and total clearing integral measured at 32V, unity power factor. 2 DC interrupting rating, melting integral measured at 63V (250mA-3A) and 32V (4-5A) with battery source. 3 It is recommended that fuses be mounted with ceramic (white) side facing up. 4 Contact Bussmann if higher ampere ratings are needed. 5 For long term reliability, operating current of 80% or less of rated current is recommended, with further derating required at elevated ambient temperatures. www.bussmann.com e-mail: sales@bussmann.co.uk Sales Fax: +44 (0)1509 882788 3 Bussmann Surface Mount Fuses ® 3216LV/3216CP/3216FF Agency Approvals: ▲ General Description: Order Code: Packing Code + 3216LV + Rating Type: Fast Acting Ratings (A): 250mA to 1.5A Rated Voltage: 125V ac/dc Bussmann SMT Chip Fuses utilise a combination of metal film and ultrasonic wire bond technologies for superior fusing action and enhanced reliability. The fuse element is bonded to the substrate and encapsulated with coloured glass, providing excellent short circuit performance and environmental integrity. The end terminations are over-plated with nickel and tin base. Breaking Capacity: 3216FF & 3216LV - 50A @ rated voltage 3216CP - 35A @ rated voltage Time-Current Characteristics: 3216FF & 3216CP - both will carry 100% of rated current for a minimum of 4 hours and will open within 5 seconds at 250% of rated current. The 4A to 5A fuses of the 3216FF will open within 1 second at 350% of rated current. Dimensions (mm): Order Code: Packing Code + 3216CP + Rating Type: Fast Acting Ratings : 250mA to 5A Rated Voltage: 24V dc 4 Order Code: Packing Code + 3216FF + Rating Type: Fast Acting Ratings : 250mA to 6.5A Rated Voltage: 32V ac / 63V dc (250mA - 3A); 32V dc (4 - 5A) 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1234567 1.6 0.9 3.2 Packing Code Prefix: TR = 3,000 pieces on 8 mm tape on a 178mm reel. TR1 = 15,000 pieces on 8mm tape on a 330mm reel. SP = 50 pieces on tape in a plastic box. Application Engineers +44 (0)1509 882766 or 882760 Bussmann Surface Mount Fuses ® Performance data for the 3216 range 3216FF P art Nu mber Cu rren t xx = P ackin g Code Ratin g (A) P art Markin g Ty p. Resistan ce @ ≤ 10% Rated Cu rren t (O h ms) Ty p. Voltage D rop @ Rated Cu rren t (Volts) 1.4 I 2t Ty p. P re-arcin g @ Ty p. O peratin g I2t @ 5 0 A ( A 2 s ec ) 3 5 A ( A 2 s ec . ) ac dc ac dc xx/3216F F -250mA 250mA .25 4.5 .00016 .000084 .00017 .0001 xx/3216F F -375mA 375mA White Dot 1.8 .73 .001 .0002 .0010 .0009 xx/3216F F -500mA 500mA 0.5 1.15 .66 .0014 .0019 .0016 .0026 xx/3216F F -750mA 750mA .75 .75 .63 .0033 .00095 .0033 .0042 xx/3216F F -1A 1A 1 .168 .20 .012 .007 .014 .009 1.5A 1.5 .098 .18 .047 .029 .048 .034 2A 2 .063 .16 .116 .081 .136 .092 2.5A 2.5 .046 .14 .208 .171 .210 .198 xx/3216F F -3A 3A 3 .037 .13 .426 .359 .507 .369 xx/3216F F -4A 4A 4 .019 .11 .187 .164 .208 .168 4.5A 4.5 .014 .10 .546 .463 .550 .47 5A 5 .013 .09 .663 .619 .668 .623 6.5A 6.5 .0085 .076 xx/3216LV-250mA 250mA .25 4.50 xx/3216LV-375mA 375mA White Dot 1.80 xx/3216LV-500mA 500mA 0.5 1.15 xx/3216LV-750mA 750mA .75 1A xx/3216LV-1. 25A xx/3216LV-1. 5A xx/3216F F -1. 5A xx/3216F F -2A xx/3216F F -2. 5A xx/3216F F -4. 5A xx/3216F F -5A xx/3216F F -6. 5A 2.18 3.21 2.21 3.23 3216LV xx/3216LV-1A 1.4 .00016 .000084 .00017 .0001 .73 .001 .0002 .0010 .0009 .66 .0014 .0019 .0016 .0026 .75 .63 .0033 .00095 .0033 .0042 1 .52 .63 .020 .0084 .022 .0098 1.25A White D .40 .62 .035 .021 .038 .027 1.5A 1.5 .26 .49 .038 .024 .044 .033 3216C P xx/3216CP-250mA 250mA 4.5 xx/3216CP-375mA 375mA 1.8 .73 xx/3216CP-500mA 500mA 1.15 .66 xx/3216CP-750mA 750mA .75 .63 xx/3216CP-1A xx/3216CP-1. 5A xx/3216CP-2A xx/3216CP-2. 5A 1.4 1A .168 .20 1.5A .098 .18 2A .063 .16 2.5A .046 .14 xx/3216CP-3A 3A .037 .13 xx/3216CP-4A 4A .019 .11 4.5A .014 .10 5A .013 .09 xx/3216CP-4. 5A xx/3216CP-5A www.bussmann.com e-mail: sales@bussmann.co.uk Sales Fax: +44 (0)1509 882788 5 Bussmann Surface Mount Fuses ® 6125T Agency Approvals: Designed to comply with IEC127-4. General Description: Order Code: Packing Code + 6125T + Rating Type: Time Delay Ratings : 250mA to 5A Rated Voltage: 125V ac/dc Bussmann surge resistant time delay fuse with brazed sealed body and end plates, compatible with wave soldering. The fuse has excellent environmental integrity. Breaking Capacity: 50A ac @ rated voltage, power factor = 1.0 50A dc @ rated voltage battery source Time Current Characteristics: 125% of rating: 1 hour minimum carry. 200%: open within 2 minutes. 1000%: open within 0.01 to 0.1 seconds. Dimensions (mm): 2.5 6.1 2.5 Packing Code Prefix: TR = 1,000 pieces on 12mm tape on a 178mm reel SP = 50 pieces on 12mm tape in plastic box Performance Data P art Nu mber xx = P ackin g code xx/6125T-250mA xx/6125T-500mA xx/6125T-1A xx/6125T-1. 5A xx/6125T-2A xx/6125T-3A xx/6125T-4A xx/6125T-5A 6 Cu rren t Ratin g Markin g 250mA 500mA 1A 1.5A 2A 3A 4A 5A B.25 B0.5 B1A B1.5 B2A B3A B4A B5A Ty p. Resistan ce Max. P ower Loss @ @ ≤ 10% Rated 125% of Rated Cu rren t (O h ms) Cu rren t (mW) 4.5 500 1.0 500 0.25 500 0.10 500 0.06 500 0.04 1000 0.03 1200 0.02 1200 Application Engineers +44 (0)1509 882766 or 882760 Bussmann Surface Mount Fuses ® SFT Agency Approvals: General Information: The Bussmann SMD Tron is designed to EIA-PD-100, DWG SOPM-7243. A high temperature body material is capable of surviving a 60 second exposure to a temperature of 215 degrees centigrade in a flourinert FC5311 environment. Because the SMD Tron is totally sealed, it can be subjected to cleaning by a wide variety of aggressive solvents. Dimensions (mm): Order Code: Packing Code + SFT + Rating 7.5 Type: 4.3 Fast Acting, Current Limiting Construction:Solid Matrix Ratings: 3.05 1.27 Packing Code Prefix: 63mA to 12.5A Rated Voltage: 2.3 TR/SFT - 500 pcs on a 178mm reel, 16mm tape. TR1/SFT - 2000 pcs on a 330.2mm reel, 16mm tape, (also available on a 12mm tape). 63mA to 5A -125V ac/dc 7A to 10A - 60V ac/ 90V dc Weight: 1000 = 0.54kg Time current characteristics: 63mA to 10A at 100% of rating - 4 hours minimum, 63mA to 10A at 250% of rated current - 5 seconds maximum. 12.5A - consult Bussmann. Performance Data P art Nu mber xx = P ackin g code Rated Cu rren t D xx/S F T-63mA xx/S F T-125mA xx/S F T-250mA xx/S F T-375mA xx/S F T-500mA xx/S F T-750mA xx/S F T-1A xx/S F T-1. 5A xx/S F T-2A xx/S F T-2. 5A xx/S F T-3A xx/S F T-3. 5A xx/S F T-4A xx/S F T-5A xx/S F T-7A xx/S F T-10A xx/S F T-12. 5A 63mA 125mA 250mA 375mA 500mA 750mA 1A 1.5A 2A 2.5A 3A 3.5A 4A 5A 7A 10A 12.5A Rated Voltage (V) ac (max) dc (max) 125 125 125 125 125 125 125 125 125 125 125 125 125 125 60 60 48 125 125 125 125 125 125 125 125 125 125 125 125 125 125 90 90 Ty p. P re-arcin g I2t ( A 2 s ec ) Breakin g Capacity A Ty pical O peratin g I 2 t ( A 2 s ec ) C ac dc ac dc ac dc 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 50A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A 300A TBA TBA 7.49 x 10 - 5 3.17 x 10 - 4 4.46 x 10 - 4 1.72 x 10 - 3 .01 .03 .08 .18 .34 .50 .89 1.73 TBA TBA 15 TBA TBA 5.1 x 10 - 6 2.18 x 10 - 5 3.8 x 10 - 5 2.27 x 10 - 4 .007 .020 .07 .14 .24 .38 .68 1.29 TBA TBA TBA TBA TBA 2.0 x 10 - 4 4.18 x 10 - 4 5.74 x 10 - 4 2.59 x 10 - 3 .011 .035 .089 .238 .44 .636 1.07 2.38 TBA TBA 20 TBA TBA 6.29 x 10 - 6 2.67 x 10 - 5 4.63 x 10 - 5 2.77 x 10 - 4 .008 .025 .081 .16 .27 .47 .78 1.36 TBA TBA TBA Ty pical Voltage D ropB Volts at Rated Cu rren t 0.8 0.75 0.66 0.525 0.12 0.2 0.17 0.145 0.13 0.155 0.135 0.125 0.114 0.13 0.09 A g en c y Approvals 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 Notes: A. Breaking Capacity was measured at 1.0 power factor on AC and a time constant less than 1ms on DC. B. Voltage drop was measured at 25 deg. C ± 3 deg. C ambient temperature at rated current with device mounted on a circuit trace. C. I2t measured at 50 amp, 125V AC , .95PF, random closing angle; 300 amps, 125V DC, TC
BK/ETF 1A 价格&库存
很抱歉,暂时无法提供与“BK/ETF 1A”相匹配的价格&库存,您可以联系我们找货
