DATASHEET - C22-L-R-24-P5
Indicator light; red; 24v; with cable 1m and M12A plug
Delivery program
Part no.
Catalog No.
C22-L-R-24-P5
181141
Product range
RMQ compact solution
Basic function
Indicator lights
Single unit/Complete unit
Complete unit
Design
Flat
Connection type
Cable (black) with M12A plug, 4 pole
Cable Length
m
1
Colour
Lens
Red
Lens
LED
LED
Red
Rated operational voltage LED
24 V AC/DC
Degree of Protection
IP66, IP67, IP69K (front)
IP65 (on rear)
Connection to SmartWire-DT
no
Contact sequence
Standards
IEC/EN 60947-5-1
VDE 0660
Certifications
CE, UL, CSA
Plug tightening torque
N/m
1
Tightening torque Threaded ring
Nm
2
Climatic proofing
Damp heat, constant, to IEC 60068-2-78
Damp heat, cyclic, to IEC 60068-2-30
IP65 (on rear)
03/19/2018
Eaton 181141 ED2018 V42.0 EN
Technical data
General
1/4
Mounting position
As required
Mechanical shock resistance, shock duration 11 ms
g
> 30
Rated impulse withstand voltage
Uimp
V AC
800
Rated insulation voltage
Ui
V
30
Overvoltage category/pollution degree
III/3
Max. short-circuit protective device
gG/gL
A
4
Rated conditional short-circuit current
Iq
kA
1
Cable characteristics
Design
M12A
Cable Length
m
1
Material characteristic
PUR
Diameter
mm
4.7
Operating ambient temperature min.
°C
-25
Operating ambient temperature max.
°C
70
Contacts
Fuse
Switching capacity
Design verification as per IEC/EN 61439
Technical data for design verification
Technical data ETIM 6.0
Low-voltage industrial components (EG000017) / Indicator light complete (EC000272)
Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Indicator light complete (ecl@ss8.1-27-37-12-23 [AKF041011])
Number of indicator lights
1
Colour lens
Red
Type of lamp socket
LED
With lamp
Yes
Rated operating voltage Ue
V
24 - 24
Voltage type
AC/DC
Type of electric connection
Other
Construction type lens
Round
Type of lens
Flat
Hole diameter
mm
22
Width opening
mm
Height meter opening
mm
Degree of protection (IP)
Other
With front ring
Yes
Material front ring
Plastic
Colour front ring
Other
Product Standards
IEC/EN 60947-5-1; UL 508; CAN/CSA-C22.2 No. 14-05 und 94-M91; CE marking
UL File No.
E29184
UL Category Control No.
NKCR
CSA File No.
165628
CSA Class No.
321103
North America Certification
UL listed, CSA certified
1,3R,4X,12,13
03/19/2018
Approvals
2/4
Dimensions
Static: Fixed routing
Flexible use
Assets (Links)
Declaration of Conformity
00002596
Additional product information (links)
IL047016ZU RMQ compact solution
03/19/2018
3/4
03/19/2018
ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf
Eaton Industries GmbH
http://www.eaton.eu
© 03/2018 by Eaton Industries GmbH
4/4
很抱歉,暂时无法提供与“C22-L-R-24-P5”相匹配的价格&库存,您可以联系我们找货
