DATASHEET - DILM65(230V50/60HZ)
Contactor, 3 pole, 380 V 400 V 30 kW, 230 V 50/60 Hz, AC operation, Screw
terminals
Part no.
Catalog No.
Alternate Catalog
No.
Delivery program
DILM65(230V50/60HZ)
277902
XTCE065D00G2
Product range
Contactors
Application
Contactors for Motors
Subrange
Contactors up to 170 A, 3 pole
Utilization category
AC-1: Non-inductive or slightly inductive loads, resistance furnaces
NAC-3: Normal AC induction motors: starting, switch off during running
AC-4: Normal AC induction motors: starting, plugging, reversing, inching
Notes
Also suitable for motors with efficiency class IE3.
IE3-ready devices are identified by the logo on their packaging.
Connection technique
Screw terminals
Number of poles
3 pole
Rated operational current
AC-3
Notes
At maximum permissible ambient temperature (open.)
380 V 400 V
Ie
A
65
Ith =Ie
A
98
Ith
A
72
open
Ith
A
200
enclosed
Ith
A
180
220 V 230 V
P
kW
380 V 400 V
P
kW
30
660 V 690 V
P
kW
35
220 V 230 V
P
kW
7
380 V 400 V
P
kW
12
660 V 690 V
P
kW
17
Contact sequence
Instructions
Contacts to EN 50 012.
Can be combined with auxiliary contact
DILM150-XHI(V)..
DILM1000-XHI(V)..
Actuating voltage
230 V 50/60 Hz
Voltage AC/DC
AC operation
Connection to SmartWire-DT
no
07/10/2020
Eaton 277902 ED2020 V70.0 EN
AC-1
Conventional free air thermal current, 3 pole, 50 - 60 Hz
Open
at 40 °C
enclosed
Conventional free air thermal current, 1 pole
Max. rating for three-phase motors, 50 - 60 Hz
AC-3
AC-4
1 / 14
Technical data
General
Standards
IEC/EN 60947, VDE 0660, UL, CSA
Lifespan, mechanical
Operations
x 10
AC operated
Operating frequency, mechanical
AC operated
6
10
Operations/h
5000
Climatic proofing
Damp heat, constant, to IEC 60068-2-78
Damp heat, cyclic, to IEC 60068-2-30
Ambient temperature
Open
°C
-25 - +60
Enclosed
°C
- 25 - 40
Storage
- 40 - 80
°C
Mounting position
Mechanical shock resistance (IEC/EN 60068-2-27)
Half-sinusoidal shock, 10 ms
Main contacts
N/O contact
g
10
Auxiliary contacts
N/O contact
g
7
N/C contact
g
5
Mechanical shock resistance (IEC/EN 60068-2-27) when tabletop-mounted
Main contacts
N/O contact
g
10
Auxiliary contacts
N/O contact
g
7
N/C contact
g
5
Degree of Protection
IP00
Protection against direct contact when actuated from front (EN 50274)
Finger and back-of-hand proof
Altitude
m
Max. 2000
Weight
kg
0.872
AC operated
Screw connector terminals
Terminal capacity main cable
Solid
mm
Flexible with ferrule
mm
Stranded
Solid or stranded
Flat conductor
Lamellenzahl mm
x Breite x
Dicke
2 x (6 x 9 x 0.8)
Stripping length
mm
14
Terminal screw
M6
Tightening torque
Nm
3.3
Tool
1 x (0.75 - 16)
2 x (0.75 - 16)
2
1 x (0.75 - 35)
2 x (0.75 - 25)
mm
2
1 x (16 - 50)
2 x (16 - 35)
AWG
single 14 - 1, double 14 - 2
Pozidriv screwdriver
Size
2
Standard screwdriver
mm
0.8 x 5.5
1x6
Terminal capacity control circuit cables
07/10/2020
2
2 / 14
Solid
mm
2
1 x (0.75 - 4)
2 x (0.75 - 2.5)
mm
2
1 x (0.75 - 2.5)
2 x (0.75 - 2.5)
Solid or stranded
Stripping length
AWG
18 - 14
mm
10
Terminal screw
M3.5
Tightening torque
Nm
1.2
Tool
Size
2
mm
0.8 x 5.5
1x6
Rated impulse withstand voltage
Uimp
V AC
8000
Overvoltage category/pollution degree
III/3
Rated insulation voltage
Ui
V AC
690
Rated operational voltage
Ue
V AC
690
Safe isolation to EN 61140
Main conducting paths
between coil and contacts
V AC
440
between the contacts
V AC
440
Up to 690 V
A
910
Breaking capacity
220 V 230 V
A
650
380 V 400 V
A
650
500 V
A
650
660 V 690 V
A
370
Short-circuit rating
Making capacity (p.f. to IEC/EN 60947)
Short-circuit protection maximum fuse
Type “2” coordination
400 V
gG/gL 500 V
A
125
690 V
gG/gL 690 V
A
80
Type “1” coordination
AC
400 V
gG/gL 500 V
A
250
690 V
gG/gL 690 V
A
100
AC-1
Open
at 40 °C
Ith =Ie
A
98
at 50 °C
Ith =Ie
A
88
at 55 °C
Ith =Ie
A
83
at 60 °C
Ith =Ie
A
80
Ith
A
72
enclosed
open
Ith
A
200
enclosed
Ith
A
180
Notes
220 V 230 V
Ie
A
65
240 V
Ie
A
65
380 V 400 V
Ie
A
65
415 V
Ie
A
65
AC-3
Open, 3-pole: 50 – 60 Hz
07/10/2020
3 / 14
440V
Ie
A
65
500 V
Ie
A
65
660 V 690 V
Ie
A
37
380 V 400 V
Ie
A
65
Motor rating
P
kWh
220 V 230 V
P
kW
240V
P
kW
22
380 V 400 V
P
kW
30
415 V
P
kW
39
440 V
P
kW
41
500 V
P
kW
47
660 V 690 V
P
kW
35
220 V 230 V
Ie
A
25
240 V
Ie
A
25
380 V 400 V
Ie
A
25
415 V
Ie
A
25
440 V
Ie
A
25
500 V
Ie
A
25
660 V 690 V
Ie
A
AC-4
Motor rating
DC
P
kWh
220 V 230 V
P
kW
7
240 V
P
kW
7.5
380 V 400 V
P
kW
12
415 V
P
kW
13
440 V
P
kW
14
500 V
P
kW
16
660 V 690 V
P
kW
17
Rated operational current, open
DC-1
60 V
Ie
A
72
110 V
Ie
A
72
220 V
Ie
A
65
3 pole, at Ith (60°)
W
25.9
Current heat loss at Ie to AC-3/400 V
W
17.1
Impedance per pole
mΩ
1.9
Voltage tolerance
Current heat loss
Magnet systems
AC operated
Pick-up
x Uc
0.8 - 1.1
Drop-out voltage AC operated
Drop-out
x Uc
0.3 - 0.6
50/60 Hz
Pick-up
VA
168
154
50/60 Hz
Sealing
VA
22
14
50/60 Hz
Sealing
W
4.1
Duty factor
% DF
100
Changeover time at 100 % US (recommended value)
Power consumption of the coil in a cold state and 1.0 x US
Main contacts
AC operated
07/10/2020
Closing delay
ms
12 - 18
Opening delay
ms
8 - 13
4 / 14
Arcing time
ms
x 10
Emitted interference
to EN 60947-1
Interference immunity
to EN 60947-1
Switching capacity
Lifespan, mechanical; Coil 50/60 Hz
Electromagnetic compatibility (EMC)
Rating data for approved types
Maximum motor rating
10
6
Mechanical lifespan at 50 Hz approx. 30% lower than under → Technical data
general
Three-phase
200 V
208 V
HP
230 V
240 V
HP
25
460 V
480 V
HP
50
575 V
600 V
HP
60
Single-phase
115 V
120 V
HP
5
230 V
240 V
HP
15
General use
A
88
SCCR
Basic Rating
SCCR
kA
10
max. Fuse
A
250
Short Circuit Current Rating
max. CB
A
250
480 V High Fault
SCCR (fuse)
kA
30/100
max. Fuse
A
250/150 Class J
SCCR (CB)
kA
65
max. CB
A
100
600 V High Fault
SCCR (fuse)
kA
30/100
max. Fuse
A
250/150 Class J
SCCR (CB)
kA
30
max. CB
A
250
Special Purpose Ratings
Electrical Discharge Lamps (Ballast)
480V 60Hz 3phase, 277V 60Hz 1phase
A
88
600V 60Hz 3phase, 347V 60Hz 1phase
A
88
A
88
A
88
A
88
A
88
Incandescent Lamps (Tungsten)
Resistance Air Heating
Definite Purpose Ratings (100,000 cycles acc. to UL 1995)
LRA 480V 60Hz 3phase
A
390
FLA 480V 60Hz 3phase
A
65
Elevator Control
200V 60Hz 3phase
HP
10
200V 60Hz 3phase
A
32.2
240V 60Hz 3phase
HP
15
240V 60Hz 3phase
A
42
480V 60Hz 3phase
HP
30
480V 60Hz 3phase
A
40
07/10/2020
5 / 14
600V 60Hz 3phase
HP
40
600V 60Hz 3phase
A
41
Design verification as per IEC/EN 61439
Technical data for design verification
Rated operational current for specified heat dissipation
In
A
65
Heat dissipation per pole, current-dependent
Pvid
W
5.7
Equipment heat dissipation, current-dependent
Pvid
W
17.1
Static heat dissipation, non-current-dependent
Pvs
W
4.1
Heat dissipation capacity
Pdiss
W
Operating ambient temperature min.
°C
-25
Operating ambient temperature max.
°C
60
IEC/EN 61439 design verification
10.2 Strength of materials and parts
10.2.2 Corrosion resistance
Meets the product standard's requirements.
10.2.3.1 Verification of thermal stability of enclosures
10.2.3.2 Verification of resistance of insulating materials to normal heat
10.2.3.3 Verification of resistance of insulating materials to abnormal heat
and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
Does not apply, since the entire switchgear needs to be evaluated.
10.2.6 Mechanical impact
10.2.7 Inscriptions
10.3 Degree of protection of ASSEMBLIES
10.4 Clearances and creepage distances
10.5 Protection against electric shock
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
Is the panel builder's responsibility.
10.8 Connections for external conductors
10.9 Insulation properties
10.9.2 Power-frequency electric strength
10.9.3 Impulse withstand voltage
10.9.4 Testing of enclosures made of insulating material
10.10 Temperature rise
The panel builder is responsible for the temperature rise calculation. Eaton will
provide heat dissipation data for the devices.
10.11 Short-circuit rating
Is the panel builder's responsibility. The specifications for the switchgear must be
observed.
10.12 Electromagnetic compatibility
observed.
10.13 Mechanical function
The device meets the requirements, provided the information in the instruction
leaflet (IL) is observed.
Technical data ETIM 7.0
Low-voltage industrial components (EG000017) / Power contactor, AC switching (EC000066)
Electric engineering, automation, process control engineering / Low-voltage switch technology / Contactor (LV) / Power contactor, AC switching (ecl@ss10.0.1-27-37-10-03 [AAB718015])
Rated control supply voltage Us at AC 50HZ
V
230 - 230
Rated control supply voltage Us at AC 60HZ
V
230 - 230
Rated control supply voltage Us at DC
V
0-0
Voltage type for actuating
AC
Rated operation current Ie at AC-1, 400 V
A
98
Rated operation current Ie at AC-3, 400 V
A
65
Rated operation power at AC-3, 400 V
kW
30
Rated operation current Ie at AC-4, 400 V
A
25
Rated operation power at AC-4, 400 V
kW
12
Rated operation power NEMA
kW
37
Modular version
No
Number of auxiliary contacts as normally open contact
6 / 14
Number of auxiliary contacts as normally closed contact
Type of electrical connection of main circuit
Screw connection
Number of normally closed contacts as main contact
Number of main contacts as normally open contact
3
Product Standards
IEC/EN 60947-4-1; UL 60947-4-1; CSA - C22.2 No. 60947-4-1-14; CE marking
UL File No.
E29096
UL Category Control No.
NLDX
CSA File No.
012528
CSA Class No.
2411-03, 3211-04
North America Certification
UL listed, CSA certified
Specially designed for North America
No
Approvals
Characteristics
1: Overload relay
2: Suppressor
07/10/2020
7 / 14
3: Auxiliary contact modules
on the side: 2 x DILM1000-XHI(V)11-SI; surface mounting: 1 x DILM150-XHIA11
on the side: 2 x DILM1000-XHI(V)11-SA; surface mounting: 1 x DILM150-XHI (2 pole)
on the side: 1 x DILM1000-XHI(V)11-SI; surface mounting: 1 x DILM150-XHIA22
on the side: 1 x DILM1000-XHI(V)11-SA; surface mounting: 1 x DILM150-XHI (4 pole)
07/10/2020
8 / 14
Squirrel-cage motor
Operating characteristics
Starting:from rest
Stopping:after attaining full running speed
Electrical characteristics
Make: up to 6 x rated motor current
Break: up to 1 x rated motor current
100 % AC-3
Typical applications
Compressors
Lifts
Mixers
Pumps
Escalators
Agitators
Fans
Conveyor belts
Centrifuges
Hinged flaps
Bucket-elevators
Air conditioning system
General drives in manufacturing and processing machines
07/10/2020
9 / 14
Extreme switching duty
Squirrel-cage motor
Inching, plugging, reversing
Break: up to 6 x rated motor current
100 % AC-4
Printing presses
Wire-drawing machines
Centrifuges
Special drives for manufacturing and processing machines
07/10/2020
10 / 14
Switching conditions for non-motor consumers, 3 pole, 4 pole
Non inductive and slightly inductive loads
Switch on: 1 x rated operational current
Switch off: 1 x rated operational current
100 % AC-1
Typical examples of application
Electric heat
07/10/2020
11 / 14
Dimensions
Contactor with auxiliary contact module
07/10/2020
12 / 14
Lateral clearance to earthed parts: 6 mm
DILM40…DILM72
DILMC40…DILMC65
DILMF40…DILMF65
Additional product information (links)
IL03407033Z (AWA2100-2247) Contactor DILM, basic unit
IL03407033Z (AWA2100-2247) Contactor DILM, ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL03407033Z2018_03.pdf
basic unit
Motor starters and "Special Purpose Ratings"
for the North American market
http://www.eaton.eu/ecm/groups/public/@pub/@europe/@electrical/documents/content/pct_3258146.pdf
Switchgear of Power Factor Correction
Systems
http://www.moeller.net/binary/ver_techpapers/ver934en.pdf
X-Start - Modern Switching Installations
Efficiently Fitted and Wired Securely
http://www.moeller.net/binary/ver_techpapers/ver938en.pdf
Mirror Contacts for Highly-Reliable Information http://www.moeller.net/binary/ver_techpapers/ver944en.pdf
Relating to Safety-Related Control Functions
07/10/2020
13 / 14
Effect of the Cabel Capacitance of Long Control http://www.moeller.net/binary/ver_techpapers/ver949en.pdf
Cables on the Actuation of Contactors
Switchgear for Luminaires
http://www.moeller.net/binary/ver_techpapers/ver955en.pdf
http://www.moeller.net/binary/ver_techpapers/ver956en.pdf
Standard Compliant and Functionally Safe
Engineering Design with Mechanical Auxiliary
Contacts
The Interaction of Contactors with PLCs
http://www.moeller.net/binary/ver_techpapers/ver957en.pdf
Busbar Component Adapters for modern
Industrial control panels
http://www.moeller.net/binary/ver_techpapers/ver960en.pdf
07/10/2020
Eaton Industries GmbH
http://www.eaton.eu
© 07/2020 by Eaton Industries GmbH
14 / 14
