DILER-40-G(24VDC)
DILER-40-G(24VDC)
    EATON(伊顿)
DILER-40-G(24VDC) 数据手册
Contactor�relay,�4N/O,�DC�current Part�no.  Article�no.  Catalog�No.  Delivery�programme DILER-40-G(24VDC) 010223 XTRM10A40TD Product range     DILER Mini-contactors Application     Contactor relays Description     with interlocked opposing contacts Connection technique     Screw terminals Rated�operational�current                   Ith =Ie A 10 Conventional free air thermal current, 3 pole, 50 - 60 Hz Open at 50 °C AC-15       220 V 230 V 240 V Ie A 6 380 V 400 V 415 V Ie A 3           4 N/O Contact sequence     Code�number�and�version�of�combination       Contacts N/O = Normally open     40 E For use with Distinctive number     …DILE Actuating voltage     24 V DC Voltage AC/DC     DC operation Instructions     Contact numbers to EN 50011 Coil terminal markings to EN 50005 Integrated diode-resistor combination Coil rating 2.6 W Standards     IEC/EN 60947, VDE 0660, UL, CSA Lifespan, mechanical     Technical�data General DC operated Operations x 10   6 20 Maximum operating frequency Operations/h   9000 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature       Open   °C -25 - +50 Enclosed   °C - 25 - 40       Mounting position     As required, except vertical with terminals A1/A2 at the bottom Mounting position     Mounting position 12/21/2015 010223 - HPL-ED2015 V18.0 EN 1/7 Mechanical shock resistance (IEC/EN 60068-2-27)               g   N/O contact   g 10 N/C contact Half-sinusoidal shock, 10 ms Basic unit with auxiliary contact module   g 8 Degree of Protection     IP20 Protection against direct contact when actuated from front (EN 50274)     Finger and back-of-hand proof Weight       DC operated   kg Terminal capacities   mm   Screw terminals       0.2 2 Solid   2 mm 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) Flexible with ferrule   mm 2 1 x (0.75 - 1.5) 2 x (0.75 - 1.5) Solid or stranded   AWG 18 - 14 Terminal screw     M3.5 Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6 Max. tightening torque   Nm 1.2 Positive operating contacts to EN 60947-5-1 appendix L, including auxiliary contact   module   Yes Rated impulse withstand voltage Uimp V AC 6000 Overvoltage category/pollution degree     III/3 Rated insulation voltage Ui V AC 690 Rated operational voltage Ue V AC 600 Safe isolation to EN 61140       between coil and auxiliary contacts   V AC 300 between the auxiliary contacts   V AC 300   A               Ith =Ie A 10 Contacts Rated operational current Conventional free air thermal current, 3 pole, 50 - 60 Hz Open at 50 °C AC-15       220 V 230 V 240 V Ie A 6 380 V 400 V 415 V Ie A 3 500 V Ie A 1.5       Notes     Switch-on and switch-off conditions based on DC-13, time constant as specified. DC-13 L/R - 15 ms       DC current Contacts in series:   A   1 24 V A 2.5 2 60 V A 2.5 3 110 V A 1.5 3 220 V A 0.5 Control circuit reliability Failure rate λ
DILER-40-G(24VDC) 价格&库存
很抱歉,暂时无法提供与“DILER-40-G(24VDC)”相匹配的价格&库存,您可以联系我们找货
