Soft�starter,�3p,�32A,�200-480VAC,�us=24VAC/DC
Part�no.
Article�no.
Catalog�No.
DS7-340SX032N0-N
134914
DS7-340SX032N0-N
Delivery�programme
Description
With internal bypass contacts
Function
Soft starters for three-phase loads
Mains supply voltage (50/60 Hz)
ULN
V AC
200 - 480
Supply voltage
Us
24 V AC/DC
Control voltage
UC
24 V AC
24 V DC
Assigned�motor�rating�(Standard�connection,�In-Line)
at 400 V, 50 Hz
P
kW
15
at 460 V, 60 Hz
P
HP
25
Rated�operational�current
AC-53
Ie
A
32
Startup class
CLASS 10 (star-delta replacement)
CLASS 20 (heavy starting duty 3 x Ie for 45 s)
Rated operational voltage
Ue
200 V
230 V
400 V
480 V
Connection to SmartWire-DT
no
Standards
IEC/EN 60947-4-2
UL 508
CSA22.2-14
Approvals
CE
Approvals
UL
CSA
C-Tick
UkrSEPRO
Climatic proofing
Damp heat, constant, to IEC 60068-2-3
Damp heat, cyclic, to IEC 60068-2-10
Ambient temperature
Technical�data
General
Operation
ϑ
°C
-5 - +40
up to 60 at 2% derating per Kelvin temperature rise
Storage
ϑ
°C
-25 - +60
Altitude
m
0 - 1000 m, above that 1 % derating per 100 m , up to 2000 m
Mounting position
Vertical
Degree of protection
IP20
Protection against direct contact
Finger- and back-of-hand proof
Overvoltage category/pollution degree
II/2
Shock resistance
8 g/11 ms
Vibration resistance to EN 60721-3-2
2M2
Radio interference level (IEC/EN 55011)
B
Static heat dissipation, non-current-dependent
Pvs
W
1.5
Weight
kg
0.4
Rated operating voltage
Ue
V AC
200 - 480
03/18/2016
134914 - HPL-ED2016 V20.0 EN
Degree of Protection
Main�conducting�paths
1/5
Supply frequency
fLN
Hz
50/60
Rated operational current
Ie
A
Ie
A
32
AC-53
Assigned motor rating (Standard connection, In-Line)
at 230 V, 50 Hz
P
kW
7.5
at 400 V, 50 Hz
P
kW
15
at 200 V, 60 Hz
P
HP
10
at 230 V, 60 Hz
P
HP
10
at 460 V, 60 Hz
P
HP
25
AC-53a
32 A: AC-53a: 3 - 5: 75 - 10
Internal bypass contacts
Overload cycle to IEC/EN 60947-4-2
Short-circuit rating
Type “1” coordination
PKM0-32 (+ CL-PKZ0)
Type „2“ coordination (additional with the fuses for coordination type „1“)
3 x 170M1366
Fuse base (number x part no.)
3 x 170H1007
Cable lengths
Solid
mm
Flexible with ferrule
mm
Stranded
Solid or stranded
Tightening torque
Screwdriver (PZ: Pozidriv)
Terminal�capacities
Control cables
2
1 x (0.75 - 16)
2 x (0.75 - 10)
2
1 x (0.75 - 16)
2 x (0.75 - 10)
mm
2
1 x 16
AWG
18 - 6
Nm
3.2
mm
PZ2; 1 x 6 mm
Solid
2
mm
1 x (0.5 - 2.5)
2 x (0.5 - 1.0)
mm
2
1 x (0.5 - 1.5)
2 x (0.5 - 0.75)
Stranded
mm
2
1 x (0.5 - 1.5)
2 x (0.5 - 1.0)
Solid or stranded
AWG
1 x (21 - 14)
2 x (21 - 18)
Tightening torque
Nm
1.2
Screwdriver
mm
0,6 x 3,5
DC-operated
V DC
24 V DC +10 %/- 15 %
AC operated
V AC
24 V AC +10 %/- 15 %
mA
mA
1.6
x Us
DC-operated
V DC
17.3 - 27
AC operated
V AC
17.3 - 27
x Us
DC operated
V DC
0-3
AC operated
V AC
0-3
DC operated
ms
250
AC operated
ms
250
Control�circuit
Digital inputs
Control voltage
Current consumption 24 V
External 24 V
Pick-up voltage
Drop-out voltage
Pick-up time
Drop-out time
ms
350
Regulator supply
DC operated
03/18/2016
2/5
Voltage
Us
V
24 V AC/DC +10 %/- 15 %
Current consumption
Ie
mA
50
Notes
External supply voltage
Relay outputs
Number
2 (TOR, Ready)
Voltage range
V AC
250
AC-11 current range
A
1 A, AC-11
Soft�start�function
Ramp times
Acceleration
s
1 - 30
Deceleration
s
0 - 30
Start voltage (= turn-off voltage)
30 100
Start pedestal
30 - 100
Fields of application
Soft starting of three-phase asynchronous motors
1-phase motors
3-phase motors
Fast switching (semiconductor contactor)
Soft start function
Reversing starter
Suppression of closing transients
Suppression of DC components for motors
Potential isolation between power and control sections
Rated operational current for specified heat dissipation
In
A
32
Heat dissipation per pole, current-dependent
Pvid
W
Equipment heat dissipation, current-dependent
Pvid
W
1.5
Pvs
W
1.5
Heat dissipation capacity
Pdiss
W
Operating ambient temperature min.
°C
-5
Operating ambient temperature max.
°C
40
10.2 Strength of materials and parts
10.2.2 Corrosion resistance
Meets the product standard's requirements.
10.2.3.1 Verification of thermal stability of enclosures
10.2.3.2 Verification of resistance of insulating materials to normal heat
10.2.3.3 Verification of resistance of insulating materials to abnormal heat
and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
Does not apply, since the entire switchgear needs to be evaluated.
10.2.6 Mechanical impact
10.2.7 Inscriptions
Functions
- (minimum ramp time 1s)
External solution required
Notes
Rated impulse withstand voltage:
• 1.2 µs/50 µs (rise time/fall time of the pulse to IEC/EN 60947‐2 or ‐3)
• Applies for control circuit/power section/enclosure
Design�verification�as�per�IEC/EN�61439
Technical data for design verification
IEC/EN 61439 design verification
10.3 Degree of protection of ASSEMBLIES
10.4 Clearances and creepage distances
10.5 Protection against electric shock
10.6 Incorporation of switching devices and components
03/18/2016
3/5
10.7 Internal electrical circuits and connections
Is the panel builder's responsibility.
10.8 Connections for external conductors
10.9 Insulation properties
10.9.2 Power-frequency electric strength
10.9.3 Impulse withstand voltage
10.9.4 Testing of enclosures made of insulating material
10.10 Temperature rise
The panel builder is responsible for the temperature rise calculation. Eaton will
provide heat dissipation data for the devices.
10.11 Short-circuit rating
Is the panel builder's responsibility. The specifications for the switchgear must be
observed.
10.12 Electromagnetic compatibility
observed.
10.13 Mechanical function
The device meets the requirements, provided the information in the instruction
leaflet (IL) is observed.
Technical�data�ETIM�6.0
Low-voltage industrial components (EG000017) / Soft starter (EC000640)
Electric engineering, automation, process control engineering / Low-voltage switch technology / Load breakout, motor breakout / Semiconductor motor controller or soft starter
(ecl@ss8.1-27-37-09-07 [ACO300008])
Rated operation current Ie at 40 °C Tu
A
32
Rated operating voltage Ue
V
230 - 460
Rated power three-phase motor, inline, at 230 V
kW
7.5
Rated power three-phase motor, inline, at 400 V
kW
15
Rated power three-phase motor, inside delta, at 230 V
kW
Rated power three-phase motor, inside delta, at 400 V
kW
Internal bypass
Yes
With display
No
Torque control
No
Rated surrounding temperature without derating
°C
40
Rated control supply voltage Us at AC 50HZ
V
24 - 24
Rated control supply voltage Us at AC 60HZ
V
24 - 24
Rated control supply voltage Us at DC
V
24 - 24
Voltage type for actuating
AC/DC
Integrated motor overload protection
No
IEC/EN 60947-4-2; GB 14048.6; UL 508; CSA-C22.2 No 0-M91; CSA-C22.2 No 14-05 CE
marking
E251034
2511305
321106
No
Branch circuits
No
480 V
IP20; UL/CSA Type 1
03/18/2016
Approvals
4/5
Dimensions
Additional�product�information�(links)
IL03902004Z�Instructions�for�DS7�Soft�Starter
IL03902004Z Instructions for DS7 Soft Starter
ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL03902004Z2012_07.pdf
MN03901001Z�Manual�DS7�soft�starters
MN03901001Z Handbuch Softstarter DS7 Deutsch
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN03901001Z_DE.pdf
MN03901001Z Manual DS7 soft starters English
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN03901001Z_EN.pdf
CA04020001Z_EN-INT Product range catalog:
Efficient Engineering for starting and
controlling motors.
http://www.eaton.eu/ecm/groups/public/@pub/@europe/@electrical/documents/content/pct_1095238.pdf
03/18/2016
Eaton Industries GmbH
http://www.eaton.eu
© 03/2016 by Eaton Industries GmbH
5/5
很抱歉,暂时无法提供与“DS7-340SX032N0-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3445.455771+447.89810
