DWM1742MN
DWM1742MN
    EATON(伊顿)
    EATON TRIPP LITE - DWM1742MN - SWIVEL/TILT WALL MOUNT, 52KG, 17"-42"
DWM1742MN 数据手册
Swivel/Tilt Wall Mount for 17" to 42" TVs and Monitors, 80° Swivel, -15° to +15° Tilt, -4° to +4° Screen Adjustment MODEL NUMBER: DWM1742MN Highlights ● Fits most flat-panel displays from 17 to 42 in. ● One-touch adjustment for comfortable viewing ● 80° swivel, -15° to +15° tilt and 4° to +4° screen adjustment ● Supports up to 115 lbs (52.2 kgs) Package Includes Hangs a flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants. Swivels and tilts to provide optimal viewing angles. Description The VESA-compliant DWM1742MN Swivel/Tilt Wall Mount allows you to mount your flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants, it fits most flat-panel displays from 17 to 42 inches. Adjust the display angle to fit your environment and comfort level. An 80° swivel, -15° to +15° tilt and -4° to +4° screen level adjustment capability minimizes glare and provides comfortable viewing from multiple angles. ● Durable all-metal frame with scratch-resistant powder-coated finish supports up to 115 lbs (52.2 kgs). Comes fully assembled for quick mounting to the wall with included hardware. Conforms to VESAcompliant displays with any of the following mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 75 x 200 mm, 100 x 100 mm, 200 x 100 mm and 200 x 200 mm Features Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from 17 to 42 in.Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurantsDisplay angle adjusts to fit your environment and comfort levelMounting hardware included Convenient One-Touch Adjustment80° swivel, -15° to +15° tilt and -4° to +4° screen level adjustment capability provides comfortable viewing from multiple angles Durable Metal ConstructionSupports up to 115 lbs (52.2 kgs)Scratch-resistant powder-coated finishFully assembled for immediate installation VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 75 x 200 mm, 100 x 100 mm, 200 x 100 mm and 200 x 200 mm Specifications OVERVIEW 1/3 ● DWM1742MN Swivel/Tilt Wall Mount for 17" to 42" TVs and Monitors ● (4) M4 x 14 screws ● (4) M5 x 14 screws ● (4) M6 x 14 screws ● (4) M8 x 20 screws ● (4) D5 washers ● (4) D8 washers ● (8) Small spacers ● (3) Anchor bolts ● (3) Concrete anchors ● (3) D6 washers ● Hex key, 4 mm ● Owner’s manual UPC Code 037332183552 Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 200x100; 200x200; 75x100; 75x200; 75x75 Motion Full Mounting Location Wall Degrees of Motion -15/+15 Tilt; 80 Swivel; -4/+4 Level Adjustment Minimum Screen Size (in.) 17 Minimum Screen Size (cm) 43.18 Maximum Screen Size (in.) 42 Maximum Screen Size (cm) 106.68 Maximum Weight Capacity (lbs.) 115 Maximum Weight Capacity (kg) 52 Min/Max Arm Extension (in.) 1.30 min to 2.20 max Min/Max Arm Extension (cm) 3.30 min to 5.89 max Number of Displays 1 Shipping Dimensions (hwd / in.) 3.60 x 9.10 x 9.30 Shipping Dimensions (hwd / cm) 9.14 x 23.11 x 23.62 Shipping Weight (lbs.) 3.60 Shipping Weight (kg) 1.63 Unit Dimensions (hwd / in.) 7.870 x 2.200 x 1.280 Unit Dimensions (hwd / cm) 15.5 x 8.9 x 3.3 Unit Weight (lbs.) 3.63 Unit Weight (kg) 1.65 FEATURES & SPECIFICATIONS Antimicrobial No Cord Management No Tools Necessary Yes Security Lock No STANDARDS & COMPLIANCE Product Compliance RoHS; RoHS3; REACH 2/3 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 1000 Eaton Boulevard © 2024 Eaton. All Rights Reserved. Cleveland, OH 44122 Eaton is a registered trademark. All other trademarks United States are the property of their respective owners. https://tripplite.eaton.com 3/3
DWM1742MN 价格&库存
很抱歉,暂时无法提供与“DWM1742MN”相匹配的价格&库存,您可以联系我们找货
