ACE1V2012-102-R
ACE1V2012-102-R
    EATON(伊顿)
    水平式,4 PC 板
    2 线路共模扼流圈 表面贴装型 1 kOhms @ 100 MHz 190mA DCR 1.5 欧姆
ACE1V2012-102-R 数据手册
Technical Data 10984 Effective November 2019 ACE1V2012 Automotive grade common-mode chip inductor Applications Product features • Controller area network (CAN) • Ethernet architectures • Automotive signal line filter • Advanced driver assistance systems (ADAS) • Infotainment, safety cameras, sensors, xEV, Powertrain • AEC-Q200 qualified Engine control unit (ECU) • • 0805 (2012 metric) package Electric power steering system (EPS) • • Impedance range from 90 ohms to 2200 ohms Battery management systems (BMS) • • Moisture sensitivity level (MSL): 1 Environmental compliance and general specifications • Operating temperature range: -40 °C to +105 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ACE1V2012 Automotive grade common-mode chip inductor  Technical Data 10984 Effective November 2019 Product specifications Part number Common-mode impedance Z (Ω) at 100 MHz DCR (Ω) @ +25 °C maximum Idc (mA) maximum Rated voltage (Vdc) typical Insulation resistance (MΩ) minimum Withstanding voltage (Vdc) typical ACE1V2012-900-R 90 ±25% 0.3 400 50 10 125 ACE1V2012-121-R 120 ±25% 0.3 370 50 10 125 ACE1V2012-201-R 200 ±25% 0.35 330 50 10 125 ACE1V2012-361-R 360 ±25% 0.4 280 50 10 125 ACE1V2012-681-R 680 ±25% 0.8 220 50 10 125 ACE1V2012-102-R 1000 ±25% 1.5 190 50 10 125 ACE1V2012-222-R 2200 ±25% 2.0 150 50 10 125 1. Part Number Definition: ACE1V2012-xxn-R ACE1V2012 = Product code and size xx= inductance value in ohms, n= multiplication factor: 10^n (i.e. 900 = 90 * 10^0 = 90 ohms) -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout B A Epoxy C D Terminations Wires E E F F Equivalent circuit 1 4 2 3 No polarity Part Number A B C D E F ACE1V2012-xxn-R 2.0 ±0.2 1.2 ±0.2 1.2 ±0.2 0.2 ±0.1 0.40 typ 0.45 typ All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics Technical Data 10984 ACE1V2012  Automotive grade common-mode chip inductor Effective November 2019  Packaging information (mm) Supplied in tape and reel packaging, 2000 parts per 7” diameter reel Ao 1.50±0.10 Bo 2.35±0.10 Ko 1.45±0.10 W 8.00±0.20 E 1.75±0.10 F 3.50±0.05 Po 4.0±0.05 P1 4.0±0.10 Do 1.0±0.1 www.eaton.com/electronics 3 ACE1V2012 Automotive grade common-mode chip inductor  Technical Data 10984 Effective November 2019 Performance curves ACE1V2012-121-R Impedance (Ω) Impedance (Ω) ACE1V2012-900-R Frequency (MHz) Frequency (MHz) ACE1V2012-201-R Impedance (Ω) Impedance (Ω) ACE1V2012-361-R Frequency (MHz) Frequency (MHz) Frequency (MHz) 4 ACE1V2012-102-R Impedance (Ω) Impedance (Ω) ACE1V2012-681-R www.eaton.com/electronics Frequency (MHz) ACE1V2012  Automotive grade common-mode chip inductor Technical Data 10984 Effective November 2019  Performance curves Impedance (Ω) ACE1V2012-222-R Frequency (MHz) Common mode measurement method: Differential mode measurement method: www.eaton.com/electronics 5 Technical Data 10984 ACE1V2012 Automotive grade common-mode chip inductor  Effective November 2019 Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
ACE1V2012-102-R 价格&库存
很抱歉,暂时无法提供与“ACE1V2012-102-R”相匹配的价格&库存,您可以联系我们找货
ACE1V2012-102-R
    ACE1V2012-102-R
    • 1+4.918361+0.63619
    • 10+4.1146510+0.53223
    • 25+3.7040625+0.47912
    • 50+3.4157750+0.44183
    • 100+3.12749100+0.40454
    • 250+2.76931250+0.35821
    • 500+2.52470500+0.32657
    • 1000+2.437341000+0.31527
    库存:1884
    ACE1V2012-102-R
    • 1+5.738251+0.74225
    • 10+4.6833910+0.60580
    • 25+4.3295025+0.56002
    • 50+4.0829050+0.52813
    • 100+3.84975100+0.49797
    • 250+3.56087250+0.46060
    • 500+3.35756500+0.43430
    • 1000+3.165731000+0.40949
    库存:6252
