CCP2R-3-100CF
CCP2R-3-100CF
    EATON(伊顿)
    EATON BUSSMANN SERIES - CCP2R-3-100CF - FUSED SWITCH, 3P, 100A, 600V, SCREW - Contact Configuration:...
CCP2R-3-100CF 数据手册
BUSSMANN Technical Data 10801 SERIES Effective August 2018 Compact Circuit Protector UL 98 Class CF disconnect switches up to 100 A (cat. no. CCP2) Contents Page Description and specifications. . . . . . . . . . . . . . . . . 2-3 2011/65/EU Catalog numbers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Conductor information and available fuses. . . . . . . . . 5 Dimensions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-7 Accessories Selector and pistol handles, and shafts. . . . . . . . . . . . 8 Multi-wire lug kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Auxiliary contacts . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 PLC fuse monitor . . . . . . . . . . . . . . . . . . . . . . . . . 11-12 How to order 30-60 A switches. . . . . . . . . . . . . . . . . . . . . . . . . . 13-16 100 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . 17-20 Motor fuse sizing table. . . . . . . . . . . . . . . . . . . . . . . 21 CCP2 switch CCP2 right front rotary switch CCP2 left front rotary switch CCP2 right side rotary switch CCP2 left side rotary switch Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 Catalog symbols for 30, 60 and 100 A switches Symbol CCP2-(pole)-(30/60/100)CF Description Switch only CCP2R-(pole)-(30/60/100)CF Right front rotary, clockwise operated switch CCP2RL-(pole)-(30/60/100)CF Left front rotary, clockwise operated switch Right side rotary, clockwise operated switch Left side rotary, counterclockwise operated switch CCP2S-(pole)-(30/60/100)CF CCP2SL-(pole)-(30/60/100)CF Description The revolutionary, next generation Bussmann™ series Compact Circuit Protector (CCP2) is a fused UL® 98 branch circuit disconnect switch utilizing the UL Class CF time-delay or fast-acting CUBEFuse™. With 2/3 the footprint of a traditional fusible solution, these switches provide a high 200 kA SCCR to help improve panel and assembly SCCR. Conductors/terminals • 75°C Cu, see conductor tables for size, type and torque information • Box lug, single/dual conductor • Fork terminal suitable for line, load or accessory connection, max. 30 A suitable for use with: • 10-24 screw for 30 and 60 A switches • • 1/4-28 screw for 100 A switches Multi-wire lug kit — see accessories for details Storage and operating temperature • - 20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions 1/4” lock, direct use on switches without rotary mechanisms requires a lock with a straight shank of sufficient length to engage all poles The switch-only versions of the 30, 60 and 100 A disconnects are direct, drop-in replacements for the earlier models (noted by a catalog number starting “CCP-”). The auxiliary contacts and PLC remote fuse indicator are backwards compatible. The multi-wire lug kits and terminal shrouds are not. • The 35 mm DIN-Rail mount CCP2 is available in a variety of 30, 60 and 100 amp configurations to meet many application needs including rotary operation. • 30 and 60 A switch 10”x 8”x 6”(254 x 203 x 152 mm) • 100 A switch, 14” x 12” x 6” (356 x 305 x 152 mm) Application flexibility is extended with an optional multi-wire lug kit, featuring finger-safe shrouds, that provides three (30 and 60 A switches) and six (100 A switches) additional wire ports on each pole for power distribution applications. Other accessories include a PLC fuse monitor for open fuse indication and NO/NC auxiliary contacts that easily integrated into many monitoring systems. Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Ratings • Volts • • • • • 347 Vac (1-pole switches) 600 Vac (2- and 3-pole switches) 125 Vdc* 30 A • 60 A • 100 A SCCR • 200 kA RMS Sym. • 100 kA DC 1-, 2- and 3-poles catalog number dependent * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. Agency information • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, Guide WHTY7, File 302370 • RoHS compliant • CE 2 • 35 mm DIN-Rail Local open fuse indication minimum voltage** • 90 Vac for AC switches • 12 Vdc for DC switches ** Open fuse indication requires an open fuse to be in the CCP2 and the switch in the ON position. Accessories • Multi-wire lug kit with terminal shrouds • Selector and pistol handles for use with rotary operated switches • 8 mm shafts for use with selector and pistol handles • Auxiliary contacts • PLC remote fuse indicator Item 30 and 60 amp switches Switch only Poles • Mounting Carton quantity and shipping weight Amps • Minimum enclosure size Eaton.com/bussmannseries Switches Poles — 2-pole Switch with side rotary mechanism 3-pole 2-pole Switch with front rotary mechanism 3-pole 100 amp switches Switch only — 2-pole Switch with side rotary mechanism 3-pole 2-pole Switch with front rotary mechanism 3-pole Weight lbs (kg) 12 — — — — 3.8 (1.7) 1.3 (0.6) 1.6 (0.7) 1.3 (0.6) 1.6 (0.7) 6 — — — — 3.1 (1.4) 1.7 (0.8) 2.3 (1.0) 1.7 (0.8) 2.3 (1.0) Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 Features • Uses UL Class CF time-delay or fast-acting CUBEFuse with Class J electrical performance • Extremely compact design at 25.4 mm (1 inch) wide per pole • Amp rating rejecting disconnects will not accept a CUBEFuse amp rating greater than switch rating • High 200 kA short-circuit current rating • Disconnect rated to provide means for load isolation • Full voltage rated at 347 Vac (1-pole switches) and 600 Vac (2- and 3-pole switches) • 125 Vdc* rated to meet specialized applications • UL 98 Listed and suitable for branch circuit disconnect and branch circuit protection • 1-, 2- and 3-pole versions are horsepower rated • Open fuse indication: • Local fuse indication light on each pole standard • Optional PLC fuse monitor for wired remote open fuse indication by signaling a PLC and open a contactor to de-energize all phases, if required • Additional open fuse indication can be provided by the time-delay CUBEFuse (6 to 100 A) • IP20 finger-safe construction with 10 AWG (6 mm2) wire or larger • Built-in switch interlock prohibits removing the fuse under load • Padlockable for lockout/tagout procedures with a 1/4” lock • Rotary operated versions provide for through-the-door and through-the-side operation flexibility and enhanced safety with: • Right front switch operation • Left front switch operation • Right side switch operation • Left side switch operation Right front rotary operated CCP2 switch with PLC fuse monitor. Rotary operating switch versions • Optional selector and pistol handles available for use with rotary operated versions • Multi-wire lug kit with terminal shrouds allows for power distribution to multiple loads. Each lug has three (30 and 60 A switches) or six (100 A switches) ports rated for single and dual wires. (See lug kit in accessories for conductor and torque details.) * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. Switch handle (ganged on 2- and 3-pole versions) Open fuse indicating light Left front rotary switch Right front rotary switch Clockwise operating handles Clockwise operating handles Fuse holder Fork terminal 1/4” Lockout/ tagout provision Box lug terminal Left side rotary switch Right side rotary switch Counterclockwise operating handles Clockwise operating handles Eaton.com/bussmannseries 3 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 30, 60 and 100 A switch catalog numbers Max Hp rating (Vac) Catalog no. Poles Description Volts SCCR 120 240 480 600 30 amp switches CCP2-1-30CF 1 CCP2-2-30CF 2 347 Vac/125 Vdc 1.5 — — — 600 Vac/125 Vdc — 3 — CCP2-3-30CF — 3 600 Vac — 5 15 10 CCP2R-2-30CF 2 600 Vac/125 Vdc — 3 — — CCP2R-3-30CF 3 600 Vac — 5 15 10 CCP2RL-2-30CF 2 — 3 — — CCP2RL-3-30CF 3 — 5 15 10 CCP2S-2-30CF 2 600 Vac/125 Vdc — 3 — — CCP2S-3-30CF 3 600 Vac — 5 15 10 CCP2SL-2-30CF 2 600 Vac/125 Vdc — 3 — — CCP2SL-3-30CF 3 600 Vac — 5 15 10 347 Vac/125 Vdc* 3 — — — 600 Vac/125 Vdc* — 7.5 — — Switch only Right front rotary, clockwise operated switch Left front rotary, clockwise operated switch Right side rotary, clockwise operated switch Left side rotary, counterclockwise operated switch 600 Vac/125 Vdc 600 Vac 200 kA AC 100 kA DC 60 amp switches CCP2-1-60CF 1 CCP2-2-60CF 2 CCP2-3-60CF 3 600 Vac — 7.5 20 10 CCP2R-2-60CF 2 600 Vac/125 Vdc* — 7.5 — — CCP2R-3-60CF 3 600 Vac — 7.5 20 10 CCP2RL-2-60CF 2 — 7.5 — — CCP2RL-3-60CF 3 — 7.5 20 10 CCP2S-2-60CF 2 600 Vac/125 Vdc* — 7.5 — — CCP2S-3-60CF 3 600 Vac — 7.5 20 10 CCP2SL-2-60CF 2 600 Vac/125 Vdc* — 7.5 — — CCP2SL-3-60CF 3 600 Vac — 7.5 20 10 347 Vac/125 Vdc** 5 — — — Switch only Right front rotary, clockwise operated switch Left front rotary, clockwise operated switch Right side rotary, clockwise operated switch Left side rotary, counterclockwise operated switch 600 Vac/125 Vdc* 600 Vac 200 kA AC 100 kA DC 100 amp switches CCP2-1-100CF 1 CCP2-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2-3-100CF 3 600 Vac — 20 50 40 CCP2R-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2R-3-100CF 3 600 Vac — 20 50 40 CCP2RL-2-100CF 2 — 10 — — CCP2RL-3-100CF 3 — 20 50 40 CCP2S-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2S-3-100CF 3 600 Vac — 20 50 40 CCP2SL-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2SL-3-100CF 3 600 Vac — 20 50 40 Switch only Right front rotary, clockwise operated switch Left front rotary, clockwise operated switch Right side rotary, clockwise operated switch Left side rotary, counterclockwise operated switch 600 Vac/125 Vdc** 600 Vac * 125 Vdc for installed fuse amp ratings up to 40 A. 24 Vdc for installed fuse amp ratings from 45 to 60 A. ** 125 Vdc for installed fuse amp ratings up to 80 A, 24 Vdc for installed fuse amp ratings from 90 to 100 A. 4 Eaton.com/bussmannseries 200 kA AC 100 kA DC Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Box lug terminal conductor data Wire type AWG range Class Technical Data 10801 Effective August 2018 Dimensions – mm (in) Quantity Torque N•m (lb-in) Switch (shown with optional terminal shrouds) 30 and 60 A switches 4-6 8-18 6-8 75°C Cu Stranded, Class B to K Single Stranded, Class B/C Stranded, Class K Dual Stranded, Class B to K 10-18 Solid Single/dual 4-18 Stranded, UL ferrule, Class B/C Single Stranded, UL ferrule, Class K Single 4-18 6-18 2.26 (20) 3.39 (30) 10-18 6-18 3.95 (35) Twin† Twin† 114 4.5 206 8.1 2.26 (20) 2.26 (20) 76 3.0 50 2.0 3.39 (30) 25 1.0 2.82 (25) 83 3.3 75 3.0 30A Fuse 100 A switches 12-18 2.26 (20) 10 2.82 (25) 8 4-6 Stranded, Class B/C Single Dual 12-18 75°C Cu 10-18 Stranded, UL ferrule, Class B/C Solid Class K 3-10 30 and 60 amp switches Class K, UL ferrule 6-18 3.95 (35) 4.52 (40) Single/Dual Single Dual 8-18 1-7 Single Twin† 8-18 1-7 5.08 (45) 2.26 (20) 6-9 10-18 60A Fuse 6.21 (55) 4-12 1-8 4.52 (40 89 3.5 5.08 (45) 1-3 10 75 3.0 Single Twin 2.26 (20) 2.82 (25) 2.26 (20) 2.26 (20) 3.39 (30) 75 3.0 50 2.0 25 1.0 5.08 (45) 148 5.8 240 9.5 2.26 (20) 3.39 (30) 100 3.9 2.26 (20) † Two stranded conductors placed in one UL Listed twin ferrule. Lineside and loadside fork terminal • Fork terminal suitable for line, load or accessory connection, max. 30 A suitable for use with: • 10-24 screw for 30 and 60 A switches • 100 amp switches 1/4-28 screw for 100 A switches Available Bussmann series fuses UL fuse class Type/description Indicating time-delay, LowPeak™ CUBEFuse (6-100 A) Non-indicating time-delay, CF Low-Peak CUBEFuse (1-100 A) Non-indicating fast-acting CUBEFuse (1-100 A) Volts 600 Vac/ 300 Vdc Data sheet no. 9000 600 Vac/dc 2147 Eaton.com/bussmannseries 5 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 Left front rotary switches (shown with optional terminal shrouds) 114 4.5 114 4.5 206 8.1 99 3.9 101 4.0 76 3.0 Right front rotary switches (shown with optional terminal shrouds) 83 3.3 76 3.0 30 A Fuse 99 3.9 101 4.0 99 3.9 30 A Fuse 60 A Fuse 30 and 60 amp switches 101 4.0 148 5.8 101 4.0 76 3.0 240 9.5 100 106 3.9 4.2 100 amp switches 6 Eaton.com/bussmannseries 89 3.5 60 A Fuse 30 and 60 amp switches 76 3.0 83 3.3 99 3.9 89 3.5 206 8.1 148 5.8 240 9.5 100 106 3.9 4.2 100 amp switches Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 Left side rotary switches (shown with optional terminal shrouds) 114 4.5 114 4.5 206 8.1 206 8.1 83 3.3 75 3.0 101 4.0 Right side rotary switches (shown with optional terminal shrouds) 101 4.0 76 3.0 30 A Fuse 89 3.5 75 3.0 30 A Fuse 75 3.0 60 A Fuse 76 3.0 89 3.5 60 A Fuse 30 and 60 amp switches 101 4.0 83 3.3 75 3.0 30 and 60 amp switches 101 4.0 148 5.8 76 3.0 240 9.5 148 5.8 240 9.5 100 3.9 100 3.9 100 amp switches 100 amp switches Eaton.com/bussmannseries 7 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 Selector and pistol handles Agency information Catalog symbol • UL Listed, Guide DIHS/DIHS7, File E140305 • NEMA 4X rating • RoHS compliant • CE • CCP2-H4X-_ Description Selector and pistol handles for use with any 2- and 3-pole CCP2 rotary operated switch. Both selector and pistol handles are available in black/grey and red/yellow colors and clockwise/counterclockwise operating modes. The application of clockwise and counterclockwise operation is dependent upon the CCP2 rotary switch configuration. Installation requires an 8 mm shaft (ordered separately). Each handle is rated NEMA 4X and capable of accepting up to three (3) 1/4” locks for lockout/tagout in the OFF position. They can also be field configured for lock-on. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Packaging • Each handle is packaged individually as a kit Selector handles Pistol handles In application, only the clockwise operating handles in combination with either the left front or right front rotary switches provide a door interlock means to ensure the enclosure door remains shut during lockout/tagout or lock-on. Both clockwise and counterclockwise operating handles when mounted on the enclosure’s left or right side do NOT provide a door interlock means. See the catalog number table below for applicable rotary switch, handle and shaft combinations. Carton quantity and shipping weight Handle style Qty. All selector handles 1 All pistol handles Clockwise • CCP2-H4X-B1 • CCP2-H4X-R1 Weight lbs (kg) Counterclockwise 1.1 (0.5) • CCP2-H4X-B1L 1.3 (0.59) • CCP2-H4X-R1L Handle shafts Clockwise • CCP2-H4X-B2 • CCP2-H4X-R2 Counterclockwise • CCP2-H4X-B2L • CCP2-H4X-R2L Catalog symbol • CCP2-SH1-_ Handle shafts Description Eight millimeter square shafts available in 290 and 490 millimeter (11.5 and 19.3 inch) lengths. Shafts are indexed to ensure handle/ switch orientation for correct operation. Shafts are to be cut to length when installed. Packaging • Each shaft is packaged separately For these switch catalog numbers CCP2R-(pole)-30CF CCP2R-(pole)-60CF CCP2R-(pole)-100CF CCP2RL-(pole)-30CF CCP2RL-(pole)-60CF CCP2RL-(pole)-100CF CCP2S-(pole)-30CF CCP2S-(pole)-60CF CCP2S-(pole)-100CF Description/operation • CCP2-H4X-B1 (selector, black/grey) Left front rotary, clockwise • CCP2-H4X-R1(selector, red/yellow) • CCP2-H4X-B2 (pistol, black/grey) • CCP2-H4X-R2 (pistol, red/yellow) Right side rotary, clockwise Left side rotary, counterclockwise Eaton.com/bussmannseries • CCP2-SH1-290 (11.5”/290 mm) • CCP2-SH1-490 (19.3”/490 mm) • CCP2-H4X-B1L (selector, black/grey) CCP2SL-(pole)-100CF 8 Order either shaft catalog number Right front rotary, clockwise CCP2SL-(pole)-30CF CCP2SL-(pole)-60CF Order these handle catalog numbers (description) • CCP2-H4X-R1L (selector, red/yellow) • CCP2-H4X-B2L (pistol, black/grey) • CCP2-H4X-R2L (pistol, red/yellow) Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Multi-wire lug kits Technical Data 10801 Effective August 2018 Installed on CCP2-3-xx Catalog numbers • CCP2-MW1-3 (for 30 and 60 A switches only) • CCP2-MW-1-6 (for 100 A switches only) Description The multi-wire lug kit permits expanding each box lug terminal on the switch into a three-port (30 and 60 A switches) or six-port (100 A switches) terminal for power distribution applications. Each multi-wire lug kit comes with three lugs and three terminal shrouds. Shrouds provide finger-safe protection when properly installed. Lugs may be mounted on either the loadside or lineside to meet various application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Multi-wire lugs mount in switch box lug terminals to provide three or six additional wire ports per pole. Lugs can be mounted on the switch lineside or loadside. Each multi-wire lug kit comes with three lugs and three shrouds. Ratings • Volts 600 V • Amps • 60 A max (CCP2-MW1-3) • 100 A max (CCP2-MW1-6) • Wire insulation strip lengths 1/8” Allen head screw 1/8” Allen head screw SCCR 200 kA Agency information • UL Recognized 1 = 11/16” • RoHS compliant 2 = 1-1/8” Storage and operating temperature • 1 = 11/16” 2 = 1-1/8” 3 = 1-9/16” 3 = 1-9/16” - 20°C to 75°C (-4°F to 167°F) Multi-wire lug conductor information Strip back wire insulation to the lengths as indicated in the illustration above and the table below. • 75°C Cu/AL • AWG size and quantity per port - see table below Type Cu/Al Cu AWG range 4-6 Class Quantity Lug port Torque N•m (lb-in) 3.95 (35) Stranded, Class B/C Single 10-14 Stranded, Class B/C Single/dual* 2.26 (20) 10-14 Solid Single 2.26 (20) UL ferrule, Class B to K Single/twin† 8 8 10-14 2.82 (25) Strip wire insulation back (inch) 1 11/16 2 1-1/8 3 1-9/16 2.82 (25) 2.26 (20) * Dual wire to be same size and type. † Two stranded conductors placed in one UL Listed twin ferrule. CCP2 box lug torque for multi-wire lugs • 60 A lug, 4.52 N•m (40 lb-in) • 100 A lug, 5.09 N•m (45 lb-in) Carton quantity and shipping weight Catalog no. Description/application Qty. CCP2-MW1-3 Lug kit, 30/60 A switches CCP2-MW-1-6 Lug kit, 100 A switches 3 lugs and 3 shrouds CCP2-TS1-3 Shrouds, 30/60 A switches CCP2-TS1-6 Shrouds, 100 A switches 3 shrouds Weight lbs (kg) 0.36 (0.16) 0.49 (0.22) 0.17 (0.077) Wiring versatility is provided by single/dual rated box lug terminals on the switch, or by the three-port or six-port multi-wire lug kits that are also single/dual wire rated. 0.2 (0.09) Eaton.com/bussmannseries 9 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 Auxiliary contacts Installed on a CCP2-3-xx Catalog numbers Note: CCP2-AUX and CCP2-AUX-100 CANNOT be mounted on the left front and left side rotary operated versions. • CCP2-AUX (30 and 60 A switches) • CCP2-AUX-100 (100 A switches) Description NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on any 1-, 2- or 3-pole CUBEFuse CCP2 switch and the right front/right side rotary operated switches. Ratings • Amps up to 5 A • Volts up to 240 Vac • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Catalog no. Switch Description CCP2-AUX 30/60 A only Auxiliary contacts NO+NC for switch status CCP2-AUX-100 100 A only Max per CCP2* 1 per CCP2 (1-, 2- or 3-pole) Signal output Dimensions — in 5 A / 240 Vac 1.8 * The CCP2-AUX CANNOT be mounted on the left front and left side rotary operated versions. De-energize all circuits and follow all prescribed safety procedures before installing or removing the auxiliary contact device. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • IEC 60947-5-1 AC-15 (catalog no. CCP2-AUX)) • IP20 finger-safe in installed state • RoHS compliant • CE 2.6 STRIP 33 NO 34 NO 41 NC 42 NC 1.9 .190 3.7 0.3 CCP2-AUX Wiring • 20-16 AWG (0.5 to 1.5 mm2) wire • Torque 0.56 N•m (5 lb-in) • Use only 75°C Cu wire 1.8 Packaging • CCP2-AUX and CCP2-AUX-100 are packaged individually Installation technique • Mounts on the CCP2’s right side ONLY and mechanically interlocks with the CCP2 switch handle with provided hardware. The CCP2-AUX and CCP2-AUX-100 CANNOT be mounted on the left front and left side rotary operated versions. 2.9 33 NO STRIP 34 NO 2.2 42 NC 41 NC Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) .190 Carton quantity and shipping weight Catalog no. Application CCP2-AUX For 30 and 60 A switches only CCP2-AUX-100 For 100 A switches only 10 Eaton.com/bussmannseries 3.7 Qty. Weight lbs (kg) 1 0.14 (0.063) CCP2-AUX-100 0.3 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 PLC fuse monitor Agency information Catalog numbers • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • CCP2-PLC-IND (30/60 A switches) • CCP2-PLC-100 (100 A switches) Local indication • Description A resettable three-phase fuse monitor that integrates with the I/O card in a Programmable Logic Controller (PLC). A single unit can be mounted on any 1-, 2- or 3-pole 30 and 60 amp CUBEFuse CCP2 switch and the left front/ left side rotary operated switches. A single unit monitors up to three phases. When used on 1- and 2-pole switches unused conductor(s) are removed after installation. The CCP2-PLC-IND CANNOT be mounted on the right front/right side rotary operated versions or if the multi-wire lug kit is installed. Ratings • • Wiring • Packaging Catalog no.* Application CCP2-PLC-IND 30 and 60 A switches only CCP2-PLC-100 100 A switches only • 24 Vdc High – fuse has opened • IEC 60947-1: Voltage Switchgear and Control Gear • IEC 61000-6-2: Electromagnetic Compatibility (EMC) • IEC 61000-4-2: Electrostatic Discharge Immunity - Test at level 3 (6 kV-Contact Discharge) and level 2 (4 kV-Air Discharge) • IEC 61000-4-3: Electromagnetic Compatibility - Radiated, Radiofrequency, Electromagnetic Field Immunity test at level x (20 V/m) • IEC 61000-4-4: Electromagnetic Compatibility - Testing and Measurement Techniques at level 3 (± 2kV - Power Port and ±1 kV - I/O Ports) • IEC 61000-4-5: Electromagnetic Compatibility - Surge Immunity test at level 4 (±4 kV) • IEC 61000-4-6: Immunity to Conducted Disturbances at level 3 (10 V) CCP2-PLC-100 30/60 A Wired per remote fuse 1 only CCP2 indication (1, 2- or for PLC 100 A 3-pole) applications only Mounts on the left side ONLY of the CCP2 and mechanically interlocks with the CCP2 switch handle with hardware provided. The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the right front/right side rotary operated versions or if the multiwire lug kit is installed. Storage and operating temperature • • • CCP2-PLC-IND 0.17 (0.077) -20°C to 75°C (-4°F to 167°F) PLC programming Emissions and immunity testing Catalog no. 1 Weight lbs (kg) IP20 rating — yes * When the fuse opens, the output signal is sent high and will remain high until the unit is reset. Max per Switch Description CCP2** Qty. * Includes 0.110” (2.8 mm) quick connects for power, signal and ground connections. Output signals • Digital 0 Vdc (low), 24 Vdc max (high) 0 Vdc Low – fuse is good For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25 mm2) 300 V rated wire Installation technique Signal output to PLC* • +24 Vdc, 10 mA max • Two distinct LEDs indicate unit power (green) and open fuse (red). Open fuse LED is resettable upon fuse replacement and the actuating the reset switch Signal output to PLC Min. circuit volts 24 Vdc/ 10 mA 100 Vac The CCP2-PLC-IND or CCP2-PLC-100 signal line is designed to provide a digital input to a PLC I/O card. In this case, a Programmable Logic Control program must be written to properly interpret the input signal to the PLC. The PLC program should check for consecutive high signals before taking action on a critical process. ** The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the right front/ right side rotary operated versions or if the multi-wire lug kit is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the CCP2-PLC-IND or CCP2-PLC-100. Eaton.com/bussmannseries 11 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 Installed on a CCP2-3-xx PLC wiring schematic PLC power supply CCP2-PLC-IND +24 Vdc +24 Vdc 0 Vdc/Gnd 0 Vdc/Gnd Signal 10 mA max. The CCP2-PLC-IND needs to be powered by the same +24 Vdc and ground (0 Vdc/Gnd return) terminals that feed the PLC input card. If it is not, it may improperly signal. +24 Vdc 0 Vdc/Gnd PLC input card CCP2-PLC-IND mounted on a 3-pole switch and using the fork terminals. When mounted on a 2- or 1-pole switch, remove unused leads. If feeding multiple CCP2-PLC-INDs from different power supplies, there must be multiple input cards being powered by those same power supplies as well. Note: the CCP2-PLC-IND CANNOT be mounted on the right front/ right side rotary operated versions or if the multi-wire lug kit is installed. Dimensions — in Pin interlocks with CCP2 switch handle SIG GND +24vDC +24vDC RESET STATUS 2 4T 1.9 6T 5L 3 3 2.6 3L 2 2T 1L 1 1 ON 1.8 3.7 CCP2-PLC-IND 0.3 Pin interlocks with CCP2 switch handle 4T 2 2.2 6T 3 5L 3 2.9 3L 2 2T 1L 1 SIG GND +24vDC +24vDC RESET STATUS 1 ON 2.0 3.7 CCP2-PLC-100 12 Eaton.com/bussmannseries 0.3 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 30 and 60 A CCP2 Switches For a complete assembly, select from the following required and optional components and accessories. Catalog no. Switches Amps Poles Required Switch (used alone or with flange cable or flange rod handles) CCP2-1-30CF CCP2-2-30CF 1 2 30 CCP2-3-30CF 3 CCP2-1-60CF CCP2-2-60CF 1 60 2 CCP2-3-60CF 3 Optional And Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shields, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — mounts on right side, cannot be used with flange rod handle CCP2-AUX NO + NC, 5 A / 240 V PLC fuse monitor Description — mounts on left side, cannot be used with flange rod handle CCP2-PLC-IND Signal output 24 Vdc / 10 mA Accessories And Eaton.com/bussmannseries 13 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 30 and 60 A CCP2 Clockwise rotary switches For a complete assembly, select from the following required and optional components and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-30CF CCP2R-3-30CF 2 30 3 CCP2R-2-60CF CCP2R-3-60CF 2 60 3 Left front rotary CCP2RL-2-30CF CCP2RL-3-30CF CCP2RL-2-60CF CCP2RL-3-60CF 2 30 3 2 60 3 Right side rotary Required CCP2S-2-30CF CCP2S-3-30CF CCP2S-2-60CF CCP2S-3-60CF 2 30 3 2 60 3 And Rotary handles Description NEMA rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow 4X CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm Optional And 14 Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shields, pack of 3 Eaton.com/bussmannseries Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 Accessories And Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — use with CCP2RL-(poles)-30/60CF switches CCP2-AUX NO + NC, 5 A / 240 V PLC fuse monitor Description — use with CCP2R-(poles)-30/60CF and CCP2S-(poles)-30/60CF switches CCP2-PLC-IND Signal output 24 Vdc / 10 mA Eaton.com/bussmannseries 15 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 30 and 60 A CCP2 Counterclockwise switches For a complete assembly, select from the following required and optional components and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-30CF CCP2SL-3-30CF CCP2SL-2-60CF CCP2SL-2-60CF 2 30 3 2 60 2 Required And Rotary handles Description NEMA rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow 4X CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm Optional And Lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 14-6, includes terminal shields, pack of 3 Accessories And 16 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — mounts on right side CCP2-AUX NO + NC, 5 A / 240 V Eaton.com/bussmannseries Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 100 A CCP2 Switches For a complete assembly, select from the following required and optional components and accessories. Catalog no. Switches Amps Poles Required Switch (used alone or with flange cable or flange rod handles) CCP2-1-100CF CCP2-2-100CF 1 100 2 CCP2-3-100CF 3 Optional And Lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shields, pack of 3 Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — mounts on right side, cannot be used with flange rod handle CCP2-AUX-100 NO + NC, 5 A / 240 V PLC fuse monitor Description — mounts on left side, cannot be used with flange rod handle CCP2-PLC-100 Signal output 24 Vdc / 10 mA Accessories And Eaton.com/bussmannseries 17 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 100 A CCP2 Clockwise rotary switches For a complete assembly, select from the following required and optional components and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-100CF 2 100 CCP2R-3-100CF 3 Left front rotary CCP2RL-2-100CF 2 100 CCP2RL-3-100CF 3 Required Right side rotary CCP2S-2-100CF 2 100 CCP2S-3-100CF 3 And Rotary handles Description NEMA rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow 4X CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm Optional And 18 Lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shields, pack of 3 Eaton.com/bussmannseries Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 Accessories And Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — use with CCP2RL-(poles)-100CF switches CCP2-AUX-100 NO + NC, 5 A / 240 V PLC fuse monitor Description — use with CCP2R-(poles)-100CF and CCP2S-(poles)-100CF switches CCP2-PLC-100 Signal output 24 Vdc / 10 mA Eaton.com/bussmannseries 19 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 100 A CCP2 Counterclockwise switches For a complete assembly, select from the following required and optional components and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-100CF 2 100 CCP2SL-3-100CF 3 Required And Rotary handles Description NEMA rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm Lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shields, pack of 3 Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — mounts on right side CCP2-AUX-100 NO + NC, 5 A / 240 V 4X And Optional And Accessories And 20 Eaton.com/bussmannseries Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Technical Data 10801 Effective August 2018 Motor sizing table: Low-Peak™ TCF_ and TCF_RN time-delay Class CF fuses Voltage 115 Vac, 1-phase 230 Vac,1-phase 200 Vac, 3-phase 208 Vac, 3-phase Motor size (Hp) Motor FLA (amps) Optimal protection (amps) Code max (amps) Heavy start* (amps) 10 0.5 2.2 6 6 6 15 15 0.75 3.2 6 6 6 15 15 15 1 4.2 10 10 10 15 Motor size (Hp) Motor FLA (amps) Optimal protection (amps) Code max (amps) Heavy start* (amps) 0.167 4.4 10 10 0.25 5.8 10 0.333 7.2 Voltage 1.5 6 10 15 2 6.8 15 15 15 3 9.6 15 20 20 45 5 15.2 25 30 30 50 7.5 22 35 40 45 60 N/A 20** 54 90 100 N/A 0.5 9.8 15 20 20 0.75 13.8 25 25 30 1 16 25 30 35 1.5 20 30 35 2 24 40 45 3 34 50 5** 56 90 100 N/A 0.167 2.2 6 6 6 0.25 2.9 6 6 6 0.333 3.6 6 10 10 0.5 4.9 10 10 10 0.75 6.9 15 15 15 1 8 15 15 17.5 1.5 10 15 20 20 2 12 20 25 25 3 17 25 30 35 5 28 45 50 60 7.5 40 60 N/A N/A 10** 50 80 90 N/A 0.5 2.5 6 6 6 0.75 3.7 6 10 10 1 4.8 10 10 10 1.5 6.9 15 15 15 2 7.8 15 15 17.5 3 11 17.5 20 20 5 17.5 30 35 35 7.5 25.3 40 45 50 20** 62.1 100 N/A N/A 0.5 2.4 6 6 6 0.75 3.5 6 10 10 1 4.6 10 10 10 1.5 6.6 10 15 15 2 7.5 15 15 15 3 10.6 17.5 20 20 35 5 16.7 25 30 7.5 24.2 40 45 50 20** 59.4 90 N/A N/A 230 Vac, 3-phase 460 Vac, 3-phase 575 Vac, 3-phase 0.5 1.1 3 3 3 0.75 1.6 3 3 3 1 2.1 6 6 6 1.5 3 6 6 6 2 3.4 6 6 6 3 4.8 10 10 10 5 7.6 15 15 15 7.5 11 17.5 20 20 10 14 25 25 30 15 21 35 40 45 20 27 40 50 60 50** 65 100 N/A N/A 0.5 0.9 3 3 3 0.75 1.3 3 3 3 1 1.7 3 3 3 1.5 2.4 6 6 6 2 2.7 6 6 6 3 3.9 6 10 10 5 6.1 10 15 15 7.5 9 15 20 20 10 11 17.5 20 20 40** 41 70 80 80 Note: Use Code max column for low to moderate reverse/jog/plug applications. * Heavy Start permitted only if Code Max does not allow motor start-up. ** If equipment terminations are rated for 60°C conductors only, the 60°C conductor ampacities must be utilized and therefore larger conductor sizes or conduit sizes may be required. Eaton.com/bussmannseries 21 Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 100 A Effective August 2018 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2018 Eaton All Rights Reserved Printed in USA Publication No. 10801- BU-MC18054 August 2018 Eaton, Bussmann and CUBEFuse are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. NEC is a registered trademark of the National Fire Protection Association, Inc. UL is a registered trademark of the Underwriters Laboratories, Inc. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Follow us on social media to get the latest product and support information.
CCP2R-3-100CF 价格&库存
很抱歉,暂时无法提供与“CCP2R-3-100CF”相匹配的价格&库存,您可以联系我们找货
CCP2R-3-100CF
  • 1+7272.756631+932.87724
