CEO50
CEO50
    EATON(伊顿)
    圆柱形,扁平端子(螺栓)
    FUSE 50AMP 500V AC BS88 GG
CEO50 数据手册
Technical Data 4115 BUSSMANN Effective July 2015 Supersedes November 2014 SERIES Bussmann series CEO BS88 Offset bolted tags Product description Eaton’s Bussmann series range of British Standard A4 fuse links is specifically designed for the protection of general industrial applications e.g. power distribution, cable protection, motor protection. Standard features • Good peak let-through current limitation • 1:1:6 Selective coordination ratio between “minor” and “major” fuse • Suitable for motor protection if gM type selected • Power loss values well within the limits of IEC 60269 Technical Data 4115 Bussmann series CEO BS88 Offset bolted tags Effective July 2015 Catalogue symbol: CEO (Amps) • Technical data: • Rated voltage: 500 V a.c. (gG) / 415 V a.c. (gM) • Rated current: 32 to 100 A • Breaking capacity: 80kA • BS reference: A4 • Class of operation: gG and gM Standards/approvals: • BS88 • IEC 60269 • Suitable for use in RoHS compliant applications Fuse holder (ordered separately) RS100H (Red Spot) • Packaging: MOQ 10 • Table 1. Technical data Part number CEO32 CEO40 CEO50 CEO63 CEO80 CEO100 CEO100M125 CEO100M160 CEO100M200 Voltage 500 V a.c. 500 V a.c. 500 V a.c. 500 V a.c. 500 V a.c. 500 V a.c. 415 V a.c. 415 V a.c. 415 V a.c. Current rating (amps) 32 40 50 63 80 100 100M125 100M160 100M200 Energy integrals I2t (A2S) Watts loss Prearcing Total at 415V W 1000 1400 3000 7000 13,000 25,000 57,000 72,500 120,000 2760 3750 8350 18,800 35,200 76,500 150,000 190,000 290,000 3.5 4.7 4.9 5.6 7.2 8.5 6.5 5 3.5 Weight 75g 75g 75g 75g 75g 75g 100g 100g 195g Dimensions - mm $ % & + ' ) * ( Catalogue numbers CEO32-100 CEO100M125-160 CEO100M200 2 A 109.5 109 110 B 94 94 94 C 58.5 58 47 EATON www.eaton.com D 14.3 14.3 19 E 11 11 10 F 8.7 8.7 9 G 24.5 26.8 29.5 H 21 25.8 31 Bussmann series CEO BS88 Offset bolted tags Technical Data 4115 Effective July 2015 Time current curve - CEO32 to CEO100 A EATON www.eaton.com 3 Technical Data 4115 Bussmann series CEO BS88 Offset bolted tags Effective July 2015 Time current curve - CEO100M Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, and Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton Internet pages and Eaton order confirmations. Eaton EMEA Headquarters Route de la Longeraie 7 1110 Morges, Switzerland Eaton.eu © 2015 Eaton All Rights Reserved Publication No. 4115 July 2015 Eaton is a registered trademark. All other trademarks are property of their respective owners.
CEO50 价格&库存
很抱歉,暂时无法提供与“CEO50”相匹配的价格&库存,您可以联系我们找货
