Tilt Wall Mount for 37" to 70" TVs and Monitors
Highlights
Fits most flat-panel displays
from 37 to 70 in.
Hangs out of sight for a sleek,
professional appearance
-10° to 0° tilt capability for
comfortable viewing
Supports up to 200 lbs (90.7
kgs)
MODEL NUMBER: DWT3770X
Package Includes
Low-profile mount hangs a flat-panel television, monitor or other display on the wall. Ideal for home
theaters, classrooms, boardrooms, hotels, bars and restaurants. Tilts to provide optimal viewing angles.
Description
The VESA-compliant DWT3770X Tilt Wall Mount allows you to mount your flat-panel television, monitor or
other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants,
it fits most flat-panel displays from 37 to 70 inches. A -10° to 0° tilt capability minimizes glare and provides
comfortable viewing from multiple angles.
Low-profile mount is concealed behind the display to give a sleek, professional appearance. Frame is
open for easy wall access. Mounting rails adjust horizontally to compensate for off-center wall studs. Builtin bubble level allows accurate display leveling. Durable all-metal frame with scratch-resistant powdercoated finish supports up to 200 lbs (90.7 kgs). Mounting hardware included. Conforms to VESAcompliant displays with any of the following mounting hole patterns: 200 x 200 mm, 200 x 300 mm, 200 x
400 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400 mm,
500 x 300 mm, 500 x 400 mm, 600 x 300 mm, 600 x 400 mm, 800 x 300 mm and 800 x 400 mm
Features
Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from
37 to 70 in.Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurantsMounts out of
sight behind display for sleek, professional appearanceMounting hardware included
Convenient One-Touch Adjustment-10° to 0° tilt capability provides comfortable viewing from multiple
anglesImproves viewing angles in applications where audience is below the display
Durable Metal ConstructionSupports up to 200 lbs (90.7 kgs)Open frame allows easy wall
accessAdjustable mounting rails compensate for off-center wall studsBuilt-in bubble level for accurate
display levelingScratch-resistant powder-coated finish
VESA ComplianceSupports the following VESA mounting hole patterns: 200 x 200 mm, 200 x 300 mm,
200 x 400 mm, 300 x 200 mm, 300 x 300 mm, 300 x 400 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400
mm, 500 x 300 mm, 500 x 400 mm, 600 x 300 mm, 600 x 400 mm, 800 x 300 mm and 800 x 400 mm
Specifications
OVERVIEW
UPC Code
037332183613
1/3
DWT3770X Tilt Wall Mount for
32" to 70" TVs and Monitors
(4) M5 x 14 screws
(4) M6 x 14 screws
(4) M6 x 30 screws
(4) M8 x 20 screws
(4) M8 x 30 screws
(4) Washers
(8) Small spacers
(4) Big spacers
(6) Anchor bolts
(6) Concrete anchors
(6) D6 washers
Owner’s manual
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
Material of Construction
Steel
VESA Pattern (mm)
200x200; 200x300; 200x400; 300x200; 300x300; 300x400; 400x200; 400x300; 400x400; 500x300; 500x400;
600x300; 600x400; 800x300; 800x400
Motion
Tilt
Mounting Location
Wall
Degrees of Motion
-10/+0 Tilt
Distance from Wall (in.)
1.77
Distance from Wall (cm)
5
Distance from Wall (mm)
45
Minimum Screen Size (in.)
37
Minimum Screen Size (cm)
93.98
Maximum Screen Size (in.)
70
Maximum Screen Size (cm)
177.8
Maximum Weight Capacity (lbs.)
200
Maximum Weight Capacity (kg)
91
Number of Displays
1
Shipping Dimensions (hwd / in.)
8.40 x 2.60 x 35.00
Shipping Dimensions (hwd / cm)
21.34 x 6.60 x 88.90
Shipping Weight (lbs.)
7.18
Shipping Weight (kg)
3.26
Unit Dimensions (hwd / in.)
17.320 x 34.020 x 1.800
Unit Dimensions (hwd / cm)
44 x 86 x 4.77
Unit Weight (lbs.)
7.26
Unit Weight (kg)
3.29
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
No
Tools Necessary
Yes
Security Lock
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
2/3
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
1000 Eaton Boulevard
© 2024 Eaton. All Rights Reserved.
Cleveland, OH 44122
Eaton is a registered trademark. All other trademarks
United States
are the property of their respective owners.
https://tripplite.eaton.com
3/3
