Limit Switches
E47 Precision Switch
2.0
Introduction
Technical Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Product Selection Guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.1
E47 Precision Switches
Product Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Product Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.2
2.5
V8-T2-49
V8-T2-50
E50 Heavy-Duty Plug-In Switches
2.7
V8-T2-43
V8-T2-44
E49 Compact Metal Switches
2.6
V8-T2-21
V8-T2-23
E49 Mini Metal Switches
LS-Titan Miniature DIN Switch
V8-T2-15
V8-T2-16
LS-Titan Miniature DIN Switches
2.4
V8-T2-6
V8-T2-7
Compact Prewired Switches
2.3
V8-T2-2
V8-T2-3
V8-T2-54
V8-T2-55
E50 Heavy-Duty Factory Sealed 6P+ Switches
V8-T2-68
V8-T2-69
2.8
Operators
2.9
Non Plug-In Switches
2.10
V8-T2-89
V8-T2-90
Hazardous Location Limit Switches
6P+ Switch
2.11
V8-T2-80
V8-T2-81
V8-T2-92
V8-T2-93
Special Purpose Limit Switches
V8-T2-96
V8-T2-97
Unless otherwise noted, the products contained in this section should not
be used for functional safety applications. These products were not designed
or tested to IEC 60947-5-3 or recommended for functional safety.
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Learn
Online
2
For Customer Service in the U.S. call 1-877-ETN CARE (386-2273),
in Canada call 1-800-268-3578.
For Application Assistance in the U.S. and Canada
call 1-800-426-9184.
Volume 8—Sensing Solutions CA08100010E—August 2015 www.eaton.com
V8-T2-1
2
2
2.0
2
2
Limit Switches
Introduction
Technical Reference
Limit Switches
2
2
2
2
2
2
2
2
2
2
2
Mechanical Limit Switches
are contact sensors widely
used for detecting the
presence or position of
objects in industrial
applications.
2
2
2
2
2
Limit Switches offer high
precision in terms of accuracy
and repeatability. This is
primarily due to the fact that
they make direct contact
with the target. When an
object contacts the limit
switch lever (or plunger)
the lever moves a pre-travel
distance to the operating
point where the contacts are
tripped. Movement of the
lever beyond this point is
called the over-travel.
Limit switches contain the
following major components.
These may be modular or part
of a single-piece switch.
Limit Switch Components
Actuator/
Operating
Head
Pre-travel
Operating
Point Over-travel
Initial Position
2
Receptacle/
Terminals
Reset Point
2
Switch
Body
2
Differential
2
2
Initial Position
Pre-travel
Differential
2
Over-travel
Reset Point
Operating Point
Final Position
2
2
2
Actuator/
Operating
Head
Lever Type Actuator
2
2
Switch
Body
Actuator
Terminals
This is the part of the switch
that contacts the target.
Typical actuators are levers
and plungers. Several styles
are available, see Sensor
Learning Course, Page
V8-T12-4, for more
information.
The terminals are the point of
connection for the wiring.
These terminals may be on
the body itself, or housed in a
removable receptacle. The
limit switch may also come
equipped with a factory
installed cable or pinconnector.
Switch Body
Refer to Sensor Learning Course, Page V8-T12-4, for a
complete description of limit switch terminology.
2
V8-T2-2
This part contains the
electrical contact mechanism.
For complete information on
electrical outputs, see Sensor
V8-T12-4.
Limit Switches
Introduction
2.0
2
Compact Prewired
Switches
LS-Titan Miniature
DIN Switches
2
2
2
2
2
Page V8-T2-6
Page V8-T2-15
Page V8-T2-21
Page V8-T2-43
2
Overview
Overview
Overview
Overview
2
Specified when accurate repeatability,
choice of operating forces and travel
characteristics and tightly controlled
action of cam or target in space restricted
areas are of prime importance. Cost
effective and compact.
Designed to be a versatile, slim device for
hard to fit applications where sealing
integrity is required.
Safety position switches with
insulated plastic or rugged metal
enclosures. Approved for worldwide
safety application.
Suitable for OEMs who require a small,
cost-effective solution but cannot sacrifice
durability and mechanical life as they would
if they chose a plastic IEC style switch.
Applications
Applications
Applications
Applications
Overhead, folding and elevator doors,
sliding gates, automated guided vehicles
and commercial instrumentation
Machine tool, food processing and
packaging
Automatic vending machines, electronic
assembly machines, elevators and lifts,
injection molding, packaging and safety
applications
Product Features
Product Features
Product Features
Product Features
Self-contained switches or with an enclosed
cast housing for increased durability and
conduit connection
(1/2 in NPT)
Rugged aluminum alloy die cast housing
Modular plug-in head and body components
Sealed construction with enclosure ratings
of NEMA 4, 6 and 13
Positive opening NC contacts for safety
applications
Pre-wired units with custom cable lengths
available for high volume customers
Prewired with 3m of 18 AWG, AWM 2517,
300V cable
Operating heads can be rotated 90 degrees
to suit specific direction of operation
High current capacity for power load
switching and motor handling capability
Screw and solder terminations
Stackable ridge for ganged operation
2
2
2
2
2
2
“Fingerproof” terminals protect against
accidental shock
Double-spring mechanism for contact
reliability
Grounding terminal included
2
2
2
Booted enclosed version shields actuators
from debris
Captive screws on enclosure cover make
wiring hassle-free
Mounting centers—1.0 in (25.4 mm),
#8 screw size
2
SPDT double break
2
Technical Data and Specifications
Mechanical life: 3,000,000 operations min.
Mechanical life: 10,000,000 operations
min.
Mechanical life: 8,000,000 operations
Contact ratings—
5A at 250 Vac
5A at 30 Vdc
Contact ratings—
NEMA B300
Contact ratings—
AC-15, 6A at 24V, 6A at 230/240V,
4A at 400/415V;
DC-13, 3A at 24V, 800 mA at 110V,
300 mA at 220V
Enclosure ratings—
NEMA 4, 6 and 13; IP67, IP69K
Enclosure ratings—
IP66, IP67 (by model)
Construction—
Aluminum alloy die cast
Construction—
Plastic or metal (by model)
Approvals
Approvals
Approvals
Approvals
UL® Recognized
CSA® Certified
CE
cULus
Safety function, IEC/EN 60947-5-1
TÜV-Rheinland certified (LSE models)
CSA certified
UL listed
CE
CCC
UL Recognized
CE
Electrical life: 500,000 operations min.
Contact ratings—
NEMA A600, R300, AC-15, DC-13
15A/20A, 125 or 250 Vac
Enclosure ratings—
Enclosed: NEMA 1
Construction—
Basic: Phenolic
Enclosed: Aluminum die cast
Electrical life: 200,000 operations
30 operations min.
2
2
Enclosure ratings—
IP65
2
Construction—
Zinc alloy
2
2
2
2
2
2
2
2
V8-T2-3
2.0
Limit Switches
Introduction
E49 Compact Metal
Switches
Switches
Sealed 6P+ Switches
Operators
2
Page V8-T2-49
Page V8-T2-54
Page V8-T2-68
Page V8-T2-80
2
Overview
Overview
Overview
Overview
Designed with high mechanical strength for
robust environments. The rugged Aluminum
die cast construction provides reliable, oiltight, waterproof and dustproof sealing for
a variety of applications. Snap action 1NO1NC contacts provide flexibility in design.
Versatile in design. High reliability. Low
maintenance costs with installation ease.
BEST CHOICE for Heavy-Duty Limit Switch
applications. Withstands physical and
chemical abuse of harsh industrial
environments.
Designed specifically to withstand the
penetrating properties of new cutting fluids
(coolants), acid or caustic washes, salt
spray, severe vibration, shock and
temperature fluctuations, grit and debris.
Wide variety of operator types for rotary and
wobble style limit switches.
Applications
Applications
Applications
Applications
Packaging, material handling conveyors,
end-of-travel and guarding operations,
baler/compactor, industrial door lifts
Punch presses, waste water treatment,
machine tool, automotive, retrieval
systems, industrial truck, car wash lines
Automotive, pulp and paper, food
processing, waste management, primary
metals, machine tool (cutting, forming,
bending)
Used with E50, E50 6P+ and 10316
limit switches
Product Features
Product Features
Product Features
Product Features
Rigid die cast switch housing
Modular operating heads, switch bodies
and receptacles are interchangeable
without field adjustment
Tamperproof, one-piece switch body
assembly, epoxy filled
Rollers and rods available in metal
and nonmetal contact surfaces
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Set position indicator plate for easy
maintenance
High mechanical strength
Oiltight, waterproof and dustproof
construction
2
2
2
2
90 degree total travel, 5 degree pre-travel
characteristics are standard features
Viton® gasket, boot, and seal material
offers exceptional chemical resistance
2
2
Order as complete assemblies or
components for stocking and
manufacturing flexibility
Rotary head operating mode from CW,
CCW or CW and CCW is easily changed
without tools
Factory sealed. 6P submersible. Pre-wired
with cable, pigtail or pin connector options.
All with ground connection
Utilizes E50 modular operating heads
Special V-seal on switch body/head
connection provides hermetic barrier
against fluid ingress
LED indicating light, 24V–120 Vac/dc
neon version too
Peel off see-through painting mask over
nameplate
Mechanical life: 15,000,000 operations
min.
Mechanical life: 13,000,000 operations
min.
Mechanical life: 35,000,000 operations min.
Varies by model
min. at full load
Electrical life: 1,000,000 operations
min. at full load (single-pole)
Contact ratings—
NEMA A600, R300; AC-15, DC-13
min. at full load
Contact ratings—
NEMA A600, R300
Lighted versions A150, R150
6A, 120 Vac; 10A continuous
2
Enclosure ratings—
NEMA 4, 4X, 6, 6P, 12, 13; IP65, IP67
Contact ratings—
NEMA A600, R300
2
Construction—
Aluminum die cast
Enclosure ratings—
NEMA 1, 3, 3S, 4, 4X, 6, 6P, 13; IP67
Enclosure ratings—
NEMA 1, 2, 3, 3S, 4, 4X, 6, 6P, 13; IP67,
IP69K
2
Construction—Zinc die cast
Approvals
Approvals
Approvals
Approvals
2
cULus
IP67
UL Listed
CSA Certified
IEC 947-5-1
TUV
CE (some models)
UL Listed
CSA Certified
IEC 947-5-1
TUV
CE (some models)
Varies by model
2
2
2
2
V8-T2-4
Limit Switches
Introduction
Hazardous Location
Switches
2.0
2
Special Purpose Switches
2
2
2
2
Page V8-T2-89
Page V8-T2-92
Page V8-T2-96
2
Overview
Overview
Overview
2
The Industrial standard for Non Plug-In
Heavy-Duty Limit Switches. Sold as
complete assembled units only.
Designed for severe environmental service
in locations where there exists a danger of
an internal or external explosion of
flammable gases, vapors, metal alloy or
grain dust.
Variety of special function limit switch
products.
2
Applications
Applications
Applications
2
Serving MRO and USER replacement
requirements with broad
d market coverage
Mining, metal cutting, grain storage, forest
products, petrochemical, waste and sewage
management, pharmaceutical
requirements with broad market coverage
2
Product Features
Product Features
Product Features
Side and top rotary, side and top push or
wobble operation
Sealed and unsealed versions available
Special function switch lines include:
One-way gasket on sealed version keeps
liquids out, yet allows a harmless release of
gases in the event of an internal explosion
Cabinet door interlocks — when plunger
is pulled out, red band indicator visually
shows that interlock is defeated
Silicon bronze housing provides excellent
corrosion resistant properties in extreme
NEMA 4X applications
Precision switches—1NO-1NC,
2NO-2NC, or operator only. Variety of
mounting brackets available
Temperature build-up on limit switch
surface is dissipated by housing design and
materials used
Pneumatic time delay—ON delay and OFF
delay. Timing range—0.05 to 60 seconds
CW, CCW or CW and CCW operating modes
are field convertible
Double break-make snap action contacts,
same polarity each pole
Captive saddle clamp terminals accept up
to #12 wire
Head can be mounted in any of four discrete
positions, intervals of 90 degrees
2
2
2
2
2
2
2
Rotating cam shaft switches
2
Utilizes the operating heads and internal
switch mechanisms of the 10316
Non Plug-In line
2
min.
NEMA 7, Div. 1, Class I, BCD
See Page V8-T2-99 for more information
NEMA 9, Div. 1, Class II, EFG
Electrical life: 500,000 operations at
full load
Contact ratings—NEMA B600
3A, 120 Vac; 5A continuous
Enclosure ratings—
NEMA 1 or NEMA 4 versions
2
Contact ratings—NEMA A600, R300
Enclosure ratings—LX: NEMA 7, 9
CX: NEMA 1, 4, 7, 9
CB: NEMA 1, 4, 4X, 13
CBX: NEMA 1, 4, 4X, 7, 9, 13
Construction—
Zinc die cast
PS: Phenolic
2
Enclosure ratings—NEMA 1, 4, 13
Construction—
Zinc die cast
2
2
2
Construction—LX, CX: Aluminum die cast
CB, CBX: Silicon bronze
Approvals
Approvals
Approvals
2
UL Listed
CSA Certified
cUL® Listed
UL Listed
CSA Certified (PS and J only)
2
2
2
2
2
V8-T2-5
2.1
2
Limit Switches
Contents
Description
2
Page
Product Selection
Basic Switches . . . . . . . . . . . . . . . . . . . . . .
Enclosed Switches. . . . . . . . . . . . . . . . . . . .
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . .
Technical Data and Specifications . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . .
2
2
2
2
V8-T2-7
V8-T2-9
V8-T2-10
V8-T2-10
V8-T2-12
Drawings
Online
2
2
2
2
2
2
Product Description
Features
E47 Precision Switches from
Eaton’s electrical sector
provide high accuracy
switching at an affordable
price. A variety of standard
features, such as current
capacity, operating force,
travel characteristics and
actuators, lets you custom
fit the switch to your
application.
2
2
2
2
2
2
2
The switches are available
in their compact basic form,
or enclosed in a rugged,
metal housing.
2
Compact housings are
ideal for use where space
is restricted
Precision, snap-action
operators provide accurate
repeatability of electrical
and mechanical operating
characteristics
(up to 20A) allows power
load switching and motor
handling capability
Enclosed booted versions
shield actuators from
debris
Operating Characteristics
Definitions
UL Recognized
CSA Certified
CE
RoHS
DANGER
2
2
Standards and Certifications
OF—Operating Force
RF—Return Force
PT—Pre-Travel
OT—Over-Travel
MD—Movement
Differential
FP—Free Position
OP—Operating Position
2
2
2
2
THIS SENSOR IS NOT A
SAFETY DEVICE AND IS NOT
INTENDED TO BE USED AS A
SAFETY DEVICE. This sensor
is designed only to detect
and read certain data in an
electronic manner and
perform no use apart from
that, specifically no safetyrelated use. This sensor
product does not include
self-checking redundant
circuitry, and the failure of
this sensor product could
cause either an energized
or de-energized output
condition, which could result
in death, serious bodily
injury, or property damage.
2
2
2
2
For the most current information
on this product, visit our Web site:
www.eaton.com
V8-T2-6
Limit Switches
2.1
Product Selection
2
Basic Switches
2
E47 Precision Switches—Basic
Type
Pin Plunger
Solder terminal
Solder terminal
Solder terminal
Solder terminal
Spade terminal
Solder terminal
E47CML01 2
OF max.—12.3 oz (350g)
RF max.—4.02 oz (114g)
PT max.—0.016 in (0.4 mm)
OT max.—0.063 in (1.6 mm)
MD max.—0.002 in (0.05 mm)
OP—1.11 in (28.2 mm)
E47BMS03
E47BML03
OP—0.846 in (21.5 mm)
E47BMS02
E47CMS02
E47BML02
E47CML02
OF max.—5.29 oz (150g)
RF max.—0.49 oz (14g)
PT max.—0.16 in (4 mm)
MD max.—0.051 in (1.3 mm)
FP max.—0.81 in (20.6 mm)
OP—0.685 in (17.4 mm)
E47BMS21
2
E47BML21
2
E47BMT21
2
2
2
2
2
2
2
2
2
2
2
OF max.—2.47 oz (70g)
RF min.—0.49 oz (14g)
PT max.—0.394 in (10 mm)
OT max.—0.220 in (5.6 mm)
FP max.—1.11 in (28.2 mm)
OP—0.748 in (19 mm)
E47BMS22
E47CMS22
E47BML22
OF max.—3.53 oz (100g)
RF min.—0.99 oz (28g)
PT max.—0.197 in (5.0 mm)
OT max.—0.079 in (2.0 mm)
MD max.—0.039 in (1.0 mm)
FP max.—0.976 in (24.8 mm)
OP—0.748 in (19 mm)
E47BMS20
E47BML20
OT max.—0.217 in (5.5 mm)
OP—0.858 in (21.8 mm)
E47BMS04
E47CMS04
2
E47BMT04
2
E47BML04
E47CML04
2
2
2
Standard Lever
Screw terminal
Solder terminal
Extended Straight
Plunger
E47BML01
2
Straight Lever
Screw terminal
Standard Lever
E47CMS01
Reversed Lever
Screw terminal
Straight Lever
E47BMS01
Straight Plunger
Screw terminal
Reversed Lever
OT max.—0.005 in (0.13 mm)
OP—0.626 in (15.9 mm)
2
Extended Plunger
Screw terminal
Straight Plunger
20A
Catalog Number
Pin Plunger
Screw terminal
Extended Plunger
2
15A
Catalog Number
Specifications 1
2
2
2
2
Extended Straight Plunger
Screw terminal
Screw terminal (with space lugs)
Solder terminal
2
Notes
1 OF = Operating Force; RF = Return Force; PT = Pre-Travel; OT = Over-Travel; MD = Movement Differential;
FP = Free Position; OP = Operating Position.
2 Contact Eaton’s Sensor Applications Department at 1-800-426-9184 for approval status.
2
2
V8-T2-7
2.1
Limit Switches
2
E47 Precision Switches—Basic, continued
2
Type
Roller Plunger
2
2
2
2
Solder terminal
Cross Roller Plunger
2
2
2
Solder terminal
Reversed Roller Lever
Solder terminal
2
2
Extended Roller Lever
2
2
Solder terminal
Roller Lever
Screw terminal
2
Solder terminal
2
Spade terminal
One-Way Roller
2
Solder terminal
2
2
Integral Leaf
Solder terminal
2
2
OT max.—0.14 in (3.6 mm)
OP—1.315 in (33.4 mm)
E47BMS11
E47CMS11
E47BML11
FP max.—1.252 in (31.8 mm)
OP—1.126 in (28.6 mm)
E47BMS41
E47BML41
OF max.—5.64 oz (160g)
RF min.—0.78 oz (22g)
PT max.—0.28 in (7.1 mm)
OT max.—0.16 in (4 mm)
MD max.—0.04 in (1.02 mm)
FP max.—1.437 in (36.5 mm)
OP—1.189 in (30.2 mm)
E47BMS42
E47CMS42
E47BML42
RF min.—1.48 oz (42g)
PT max.—0.106 in (2.7 mm)
OT max.—0.094 in (2.4 mm)
MD max.—0.02 in (0.5 mm)
FP max.—1.28 in (32.5 mm)
E47BMS30
E47CMS30
E47BML30
E47BMT30
E47CMT30
FP—1.717 in (43.6 mm)
OP—1.697 in (43.1 mm)
E47BMS31
E47BML31
OF max.—0.35 oz (10g)
RF min.—0.106 oz (3.0g)
PT max.—0.787 in (20.0 mm)
OT max.—0.22 in (5.6 mm)
MD max.—0.118 in (3.0 mm)
OP—0.748 in (19.0 mm)
E47BMS23
E47CMS23
E47BML23
Integral Leaf
Screw terminal
2
One-Way Roller
Screw terminal
2
E47BML10
Roller Lever
2
2
E47CMS10
Screw terminal
2
E47BMS10
Screw terminal
2
Screw terminal
2
20A
Catalog Number
Roller Plunger
Screw terminal
2
15A
Catalog Number
Specifications 1
Note
2
2
V8-T2-8
Limit Switches
2.1
Type
Adjustable Roller
20A
Catalog Number
OF max.—17.64 oz (500g)
RF min.—6.0 oz (170g)
OT max.—0.5 in (12.7 mm)
MD max.—0.087 in (2.2 mm)
FP max.—1.752 in (44.5 mm)
OP—1.591 in (40.4 mm)
E47BMS40
E47BML40
OF max.—21.16 oz (600g)
RF min.—10.58 oz (300g)
PT max.—0.118 in (3.0 mm)
OT max.—0.236 in (6.0 mm)
MD max.—0.079 in (2.0 mm)
FP max.—1.614 in (41 mm)
E47BMS43
E47BML43
2
2
Adjustable Roller
Screw terminal
Solder terminal
Extended
Adjustable Roller
15A
Catalog Number
Specifications 1
2
2
2
2
Extended Adjustable Roller
Screw terminal
Solder terminal
2
2
2
2
2
Enclosed Switches
2
E47 Precision Switches—Enclosed
Specifications 1
Plunger Actuator
Booted Plunger
E47BLS05
2
E47BLS33
2
Booted Roller Lever
OF max.—22.57 oz (640g)
RF min.—8.11 oz (230g)
MD max.—0.016 in (0.4 mm)
E47CLS05 23
Catalog Number
2
2
2
Booted Plunger
OF max.—28.22 oz (800g)
RF min.—8.46 oz (240g)
PT max.—0.079 in (2.0 mm)
OT max.—0.197 in (5.0 mm)
MD max.—0.004 in (0.1 mm)
OP—1.803 in (45.8 mm)
Roller Lever
Booted Roller Lever
Plunger Actuator
OF max.—8.82–12.3 oz (250–350g)
RF min.—4.02 oz (114g)
OP—1.504 in (38.2 mm)
Specifications 1
Catalog Number
E47BLS06
Roller Plunger
Roller Plunger
PT max.—0.02 in (0.5 mm)
OT max.—0.142 in (3.6 mm)
OP—1.957 in (49.7 mm)
E47CLS06 23
2
E47BLS07
E47BLS11 4
Roller Lever
OF max.—20.1 oz (570g)
PT max.—0.157 in (4.0 mm)
E47BLS32
E47CLS32 23
Booted Roller Plunger
2
2
RF min.—3.53 oz (100g)
PT max.—0.039 in (1.0 mm)
OT max.—0.138 in (3.5 mm)
MD max.—0.005 in (0.12 mm)
2
2
E47BLS08
E47BLS12 4
2
2
2
Notes
3 20 ampere version.
4 Cross roller unit.
2
2
2
2
2
V8-T2-9
2.1
Limit Switches
2
Enclosed, continued
2
Specifications 1
One-Way Roller
Enclosed, continued
One-Way Roller
2
2
Specifications 1
Catalog Number
Booted Wobble
E47BLS34
Catalog Number
Booted Wobble
OF max.—2.11 oz (60g)
RF min.—0.88 oz (25g)
PT max.—0.520 in (13.2 mm)
OT max.—0.315 in (8.0 mm)
E47BLS14
Description
Catalog Number
Terminal wire cover with
90° conduit interface
E47PA2
2
2
2
Booted One-Way
Roller
Booted One-Way Roller
2
2
E47BLS35
2
2
2
Accessories
2
Terminal Wire Covers for Basic Switches
2
2
45°
Description
Catalog Number
45° conduit interface
E47PA1
90°
2
2
2
2
2
Description
Specification
2
Operating speed
0.01m/second to 1m/second
Operating Frequency
2
Mechanical
120 operations/minute
2
Electrical
Mechanical life
3,000,000 operations minimum
2
Electrical life
500,000 operations minimum
Contact resistance
15M ohms maximum, initial
2
Insulation resistance
100M ohms minimum at 500 Vdc
2
2
2
Dielectric Strength
Between non-current carrying parts
1000 Vac, 50/60 Hz for 1 minute
Between current carrying parts and ground
2000 Vac, 50/60 Hz for 1 minute
Notes
MD = Movement Differential; FP = Free Position; OP = Operating Position.
2 Cross roller unit.
2
2
V8-T2-10
Limit Switches
2.1
E47 Precision Switches, continued
Description
Specification
2
–13° to 176°F (–25° to 80°C)
2
Ambient Operating Temperature
Basic
Enclosed
2
5° to 176°F (–15° to 80°C)
Environmental rating enclosed, booted
NEMA 1
Mounting centers
1.0 in (25.4 mm), #8 screw size
2
Terminal screws
Bottom facing M4 x 0.7 (8–32)
Screws with cup washers will accept 22–12 AWG (2.5 sq. mm maximum)
Maximum torque: 10 in-lbs.
2
Threaded bushing
15/32 in
Material of construction
Mineral filled phenolic
Enclosure rating
Aluminum die casting (ADC-3/A380); Seal boot: nitrile, butyl rubber (NBR)
Conduit fitting on enclosed type
1/2 in NPT
2
2
2
2
Maximum Ampere Ratings 1 2
Non-Inductive Load (A)
Inductive Load (A)
Lamp Load
Inductive Load
Motor Load
Inrush Current (A)
Model
Rated
Voltage
Resistive Load
NC and NO
NC
NO
NC and NO
NC
NO
NC
NO
15A
125 Vac
15
3
1.5
15
5
2.5
30 max.
15 max.
20A
250 Vac
15
2.5
1.25
15
3
1.5
500 Vac
3
1.5
0.75
2.5
1.5
0.75
8 Vdc
15
3
1.5
15
5
2.5
14 Vdc
15
3
1.5
10
5
2.5
30 Vdc
6 (2)
3
1.5
5
5
2.5
125 Vdc
0.4
0.4
0.4
0.05
0.05
0.05
250 Vdc
0.2
0.2
0.2
0.03
0.03
0.03
125 Vac
7.5
12.5
250 Vac
7.5
8.3
500 Vac
6
4
4
5
2
2
8 Vdc
1.5
12.5
14 Vdc
1.5
15
12.5
12.5
30 Vdc
6
3
1.5
5
5
5
125 Vdc
0.5
0.5
0.5
0.05
0.05
0.05
250 Vdc
0.25
0.25
0.25
0.03
0.03
0.03
2
2
2
2
2
2
60 max.
2
30 max.
2
2
2
2
2
Terminal Configurations
Screw Type
2
Solder Type
2
2
2
Contact Configuration—
Form C Precision Snap Action
2
2
(Spade type not shown, available on some models)
2
Notes
1 Inductive load has a power factor of 0.04 minimum (AC) and a time constant of 7 m/second (DC).
2 Lamp load has an inrush current of six times steady-state current.
2
2
V8-T2-11
2.1
2
Limit Switches
Dimensions
Approximate Dimensions in Inches [mm]
2
Basic Switches
2
Pin Plunger
Standard Lever
Extended Plunger
Straight Plunger
Roller Plunger
Reversed Lever
Straight Lever
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
V8-T2-12
Limit Switches
2.1
2
Integral Leaf
2
2
2
2
Roller Lever
2
Adjustable Roller
2
2
2
2
2
One-Way Roller
2
2
2
2
2
2
Enclosed Switches
Plunger Actuator
2
Roller Lever
2
2
2
2
2
2
Booted Plunger
Booted Roller Lever
2
2
2
2
2
2
V8-T2-13
2.1
Limit Switches
2
2
Roller Plunger
Booted Wobble
2
2
2
2
2
2
2
0.25 [6.5]
Dia.
2
0.37
[9.5]
2
5.91
[150]
0.67
[17]
2-M4.0 x 45
3.37
[85.5]
0.08
[2.1]
1.00
[25.5]
0.96 [24.5]
0.91
[23]
2
2
PT
1.00 [25.4]
1.00 [25.4]
One-Way Roller
2
2
2
2
2
2
53
25.4
21
14
2
2-ø4.2
2-ø4.2
39
46
18
12
14
25
2
53
25.4
21
21
2
2
Terminal Wire Cover with 90° Conduit Interface
7
Terminal Wire Cover with 45° Conduit Interface
21
2
Approximate Dimensions in mm
14
2
Accessories
7
2
12
14
2
2
2
2
V8-T2-14
A
B
A
B
12
Limit Switches
2.2
Contents
Description
Page
Wiring Diagram . . . . . . . . . . . . . . . . . . . . . . . .
V8-T2-16
V8-T2-18
V8-T2-18
V8-T2-19
2
2
2
2
2
Drawings
Online
2
2
2
2
2
2
Product Description
Features
The E47 Compact Prewired
Limit Switch by Eaton’s
electrical sector is designed
for hard to fit applications
where sealing integrity is
required. The rugged die
cast aluminum alloy housing,
cable connection and switch
mechanism are encapsulated
for protection against extreme
temperature (–10° to 70°C
[14° to 158°F]), contaminants,
moisture, shock and
vibration. This factory wired
(3m) device has NEMA®
enclosure ratings of 4, 6
and 13, making it suitable
for applications such as
machine tool, food
processing and packaging.
cast housing
enclosure ratings of NEMA
4, 6 and 13
Prewired with 3m of
18 AWG, AWM 2517,
300V cable, or microconnector version also
available
operation
cULus (cable versions only)
UL (cable versions only)
NEMA 4, 6 and 13
IEC IP67, IP69K
RoHS
2
DANGER
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
www.eaton.com
V8-T2-15
2
2
2.2
2
Limit Switches
Product Selection
2
2
Actuator Type
Operating Force
(Maximum)
Pin Plunger
Pin Plunger
2
42.3 oz
(1.2 kg)
2
Pre-Travel
Movement
Differential
(Maximum)
Operating
Position
Standard Version
Catalog Number
Connector Version
Catalog Number
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
0.62 ± 0.04 in
(15.7 ± 1 mm)
E47BCC05
E47BCC05P4
15.9 oz
(450g)
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
0.99 ± 0.04 in
(24.9 ± 1 mm)
E47BCC06
E47BCC06P4
15.9 oz
(450g)
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
1.12 ± 0.04 in
(28.5 ± 1 mm)
E47BCC07
E47BCC07P4
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
1.35 ± 0.04 in
(34.3 ± 1 mm)
E47BCC08
E47BCC08P4
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
1.12 ± 0.04 in
(28.5 ± 1 mm)
E47BCC11
E47BCC11P4
15.9 oz
(450g)
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
1.35 ± 0.04 in
(34.3 ± 1 mm)
E47BCC12
E47BCC12P4
15.9 oz
(450g)
0.118 in
(3 mm)
0.07 in
(1.8 mm)
0.008 in
(0.2 mm)
1.12 ± 0.04 in
(28.5 ± 1 mm)
E47BCC13
E47BCC13P4
Reset Force
(Minimum)
Over-Travel
(Maximum)
15.9 oz
(450g)
2
2
Sealed Plunger
Sealed Plunger
63.5 oz
(1.8 kg)
2
2
2
Roller Plunger
2
Roller Plunger
42.3 oz
(1.2 kg)
2
2
2
Sealed Roller Plunger
63.5 oz
(1.8 kg)
2
15.9 oz
(450g)
2
2
2
42.3 oz
(1.2 kg)
15.9 oz
(450g)
2
2
2
Sealed Cross Roller
Plunger
Sealed Cross Roller Plunger
Bevel Plunger
Bevel Plunger
2
63.5 oz
(1.8 kg)
2
2
2
42.3 oz
(1.2 kg)
2
2
2
2
2
V8-T2-16
Limit Switches
2.2
Compact Prewired Switches, continued
Actuator Type
Operating Force
(Maximum)
Roller Lever
Roller Lever
20.5 oz
(580g)
Reset Force
(Minimum)
Over-Travel
(Maximum)
5.3 oz
(150g)
40°
2
Pre-Travel
Movement
Differential
(Maximum)
Operating
Position
Standard Version
Catalog Number
Connector Version
Catalog Number
25° max.
3°
E47BCC15
E47BCC15P4
2
2
2
2
2
Wobble Stick
Wobble Stick
5.3 oz
(150g)
15° max.
E47BCC20
E47BCC20P4
2
2
2
2
Rod Lever
2
Rod Lever
20.5 oz
(580g)
5.3 oz
(150g)
40°
25° max.
3°
E47BCC21P4
2
2
2
2
Adjustable Level Arm
20.5 oz
(580g)
5.3 oz
(150g)
40°
25° max.
3°
E47BCC22
E47BCC22P4
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
V8-T2-17
2.2
Limit Switches
2
2
Description
Specification
2
Contacts
1-SPDT (Form C)
Mechanical life
2
Electrical life
200,000 operations, 30 operation/min. at rated load
2
Operating speed
30 operations per minute maximum
Operating temperature range
–10° to 70°C (14° to 158°F)
2
Storage temperature range
Humidity
95% maximum non-condensing
2
Vibration
Malfunction durability, 10 to 55 Hz 1.5 mm double amplitude
2
Shock
Malfunction durability, approximately 50G
Enclosure ratings
NEMA 4, 6 and 13; IEC IP67
2
2
Inductive Load (A)
2
Rated
Voltage
Resistive Load
Inductive Load
Motor Load
NC
NO
NC
NO
NC
NO
NC
NO
2
125 Vac
5
5
3
3
2.5
1.3
20 max.
10 max.
Inrush Current (A)
250 Vac
5
5
2
2
1.5
0.8
2
8 Vdc
5
5
5
4
1.5
1.5
2
14 Vdc
5
5
4
4
1.5
1.5
30 Vdc
4
4
3
3
1.5
1.5
125 Vdc
0.4
0.4
0.4
0.4
0.05
0.05
250 Vdc
0.2
0.2
0.2
0.2
0.03
0.03
2
2
2
2
Wiring Diagram
Micro-Connector Switches
Contacts Rated
1.0A at 124 Vac
1.0A at 30 Vdc
NC (Red)
2
2
2
1
2 NC
2
2
2
COM 1
NO (Blue)
Common
(Black)
Ground
(Green)
3
4 NO
4
3
Face View of Male Connector
Note
1 Inductive load ratings are tested at a power factor 0.4 min. for AC power and a time constant of 7 ms max. for DC power. Inrush current for
motor load is six times the steady state current.
2
2
2
2
2
2
2
V8-T2-18
2.2
Limit Switches
Dimensions
2
Approximate Dimensions in mm [in]
E47BCC05
2 x Ø10.2
[0.402]
Depth: 6
[0.236]
40.0 [1.575]
25.0
[0.984]
PT
2 x Ø5.1 [Ø0.201]
Ø10 [0.397]
Stainless
Steel Plunger
OP
7.5 [0.295]
8.0 [0.315]
54.2
[2.134]
Max 49.0
[1.929]
23.0
2.0
[0.079] [0.906]
2.0 [0.079]
1.4
[0.055]
34.0 [1.339]
PT
2.8
[0.110]
Correct
Setting
Postion
1.5
[0.059]
PT
OP
63.5
[2.5] 49.0
Max. [1.929]
67.0
[2.638]
Max
51.5
[2.028]
2 x Ø5.1 [Ø0.201]
8.0 [0.315]
16.0
[0.630]
Max
2.0 [0.079]
34.0 [1.339]
2
2.8
[0.110]
Correct
Setting
Position
2
2
2
1.5
[0.059]
1.4
[0.055]
2
2
1.4
[0.055]
34.0 [1.339]
40.0 [1.575]
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
Ø12.7 [0.500] x
4.0
3.8 [0.150]
[0.157]
Stainless Steel
Roller
7.5 [0.295]
8.0 [0.315]
OP
Rubber
Cap
73.0
[2.874]
Max.
49.0
[1.929]
2
Rubber
Cap
2
2
23.0
2.0 [0.906]
[0.079]
2.0
[0.079]
1.5
[0.059]
2
16.0
[0.630]
Max
2 x Ø5.1 [Ø0.201]
PT
23.0
2.0 [0.906]
[0.079]
2
1.5
[0.059]
1.4
[0.055]
34.0 [1.339]
2
2
E47BCC13
40.0 [1.575]
Max
PT
OP
67.0
[2.638]
Max
2 x Ø5.1 [Ø0.201]
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
7.0 Ø12.7 [0.500] x
[0.276] 3.8 [0.150]
Stainless Steel
Roller
7.5 [0.295]
8.0 [0.315]
16.0
[0.630]
Max
2.0 [0.079]
34.0 [1.339]
1.4
[0.055]
40.0 [1.575]
25.0
[0.984]
PT
2.8
[0.110]
Correct
Setting
Position
OP
16.0
[0.630]
2 x Ø5.1 [Ø0.201]
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
7.0
Ø10 [0.397]
[0.276]
Stainless
Steel PLU
8.0 [0.315]
23.0
2.0 [0.906]
[0.079]
2.0 [0.079]
34.0 [1.339]
1.5
[0.059]
E47BCC08
2
2
2.8
[0.110]
Correct
Setting
Position
7.5 [0.295]
67.0
[2.638]
Max
51.5
[2.028]
23.0
2.0 [0.906]
[0.079]
51.5
[2.028]
2
2
2
1.5
[0.059]
1.4
[0.055]
2
2
E47BCC15
40.0 [1.575]
Max
2 x Ø5.1 [Ø0.201]
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
4.0
[0.157]
Ø12.7 [0.500] x
3.8 [0.150]
Stainless Steel
Roller
7.5 [0.295]
PT
OP
73.0
[2.874]
Max. 49.0
[1.929]
8.0 [0.315]
Ø17.0 [0.669]
x 7.0 [0.276]
Stainless
Sintered Roller
16.0
[0.630]
Max
2 x Ø5.1
[Ø0.201]
Rubber
Cap
2x
Ø10.2 [0.402]
Depth: 6 [0.236]
23.0
2.0
[0.079] [0.906]
23.0 [0.906]
2.0
[0.079]
2
23.0
2.0 [0.906]
[0.079]
25.0
[0.984]
E47BCC07
25.0
[0.984]
2 x Ø5.1 [Ø0.201]
E47BCC12
40.0 [1.575]
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
Ø10 [0.397]
4.0
Stainless
[0.157]
Steel Plunger
7.5 [0.295]
25.0
[0.984]
16.0
[0.630]
Max
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
Ø12.7 [0.500]
7.0
x 3.8 [0.150]
[0.276]
Stainless
Steel Roller
7.5 [0.295]
8.0 [0.315]
OP
E47BCC06
2.0
[0.079]
40.0 [1.575]
Max
25.0
[0.984]
16.0
[0.630]
Max
4.5 [0.177]
25.0
[0.984]
2
E47BCC11
34.0 [1.339]
1.4
[0.055]
1.5
[0.059]
44.0
[1.732]
25.0
[0.984]
16.0 [0.630]
Max
7.0 [0.276]
11.4 [0.45]
7.5 [0.30]
2.0 [0.079]
34.0 [1.339]
40.0 [1.575]
102.7
[4.043]
Max
1.4 [0.055]
2
2
31.5
[1.240]
R38
[1.496]
8.0
2.0
[0.079] [0.31]
50.0 [1.969]
Max.
2
2
65.0
[2.559]
Max
2
2
1.5 [0.059]
2
V8-T2-19
2.2
2
2
E47BCC20
E47BCC22
Ø1.2
50.7
2 x Ø5.1 [Ø0.201]
4.0
[0.157]
2
8.0 [0.315]
49.0
[1.929]
2.0
[0.079]
25.0
[0.984]
2
1.4
[0.055]
E47BCC21
Ø3.0
[0.117]
159.0
[6.257]
2
2
2
16.0
[0.630]
25.9 25.0
[1.020] [0.984]
23.0
[0.906]
2
2
2
8.0
[0.315]
2.0
[0.079]
2.0 [0.079]
34.0 [1.339]
40.0 [1.575]
18 AWG/4
UL, SJT (0)
Ø8.5 [0.335]
1.3
[0.051]
1.5
[0.059]
18 AWG/4
UL, SJT (0)
Ø8.5 [0.335]
2
2
2
2
2
2
2
2
2
V8-T2-20
2.0
[0.079]
1.3
[0.051]
40.0 [1.575]
18 AWG/4
UL, SJT (0)
Ø 8.5 [0.335]
2
8.0
[0.315]
2.0 [0.079]
34.0 [1.339]
1.5
[0.059]
40.0 [1.575]
2
2
25.0
[0.984]
23.0
[0.906]
23.0
2.0 [0.906]
[0.079]
34.0 [1.339]
2
2
Rubber
Cap
7.5 [0.295]
2
2
16.0
[0.630]
2 x Ø10.2 [0.402]
Depth: 6 [0.236]
2
2
R 25.0–89.0
[0.984–3.600]
5.7
103.7
[2.5]
51.2 [2.017]
7.0 [0.280]
Ø17.5
[0.69]
16.0
[0.630]
Max
2
2
Limit Switches
18 AWG/4
UL, SJT (0)
Ø 8.5 [0.335]
1.5
[0.059]
Limit Switches
2.3
Contents
Description
Page
Product Identification . . . . . . . . . . . . . . . . . . . .
LS-Titan Plastic Safety Switches . . . . . . . . .
LS-Titan Plastic Electronic
Safety Position Switches . . . . . . . . . . . . .
LS-Titan Metal Safety Switches . . . . . . . . .
Understanding LS-Titan Electronic
Operating Point Adjustment . . . . . . . . . . . .
Contact Travel Diagrams . . . . . . . . . . . . . . . . . .
V8-T2-22
V8-T2-23
V8-T2-23
V8-T2-26
V8-T2-30
V8-T2-32
V8-T2-32
V8-T2-33
V8-T2-34
V8-T2-37
V8-T2-40
2
2
2
2
2
2
2
2
2
2
2
Product Description
Features
Eaton’s LS-Titan™ limit
switch line is a complete
offering of safety position
switches designed for
worldwide application.
Economical insulated
enclosures and modular,
plug-in operating heads
and bodies make LS-Titan a
flexible switching solution.
A highlight of the LS-Titan
switch line is the world’s
first electronic position
switch (LSE models). These
switches feature freely
programmable operating
points that can be set
individually at any time.
Additional LSE models
provide analog outputs
proportional to the
actuator position.
Modular, plug-in
system (head and
body components)
Positive opening NC
contacts for safety
applications
Wide variety of economical
plastic and rugged metal
versions available
Operating heads can
of operation
Unique electronic safety
position switches (LSE
models) provide analog
(0–10 Vdc or 4–20 mA)
outputs proportional to the
actuator position and allow
for easy configuration of
a custom trip point
Can be ordered as
separate components
(head and body) or as
completely assembled
switches
Screw and Cage Clamp®
(standard on LSE models
and optionally available
on mechanical models)
connections provide larger
wiring areas for easier
installation
application
Safety function by positive
opening contacts per
IEC/EN 60947-5-1 up to
Category 4 per EN 954-1
TÜV-Rheinland Certified
for Functional-Safety
(LSE models)
CSA certified
UL listed
CE
CCC
2
2
2
2
2
2
2
2
Note: Cage Clamp is a
registered trademark of
Wago Kontakttechnik,
32423 Minden, Germany.
2
2
2
2
LS-Titan switches are suitable
for use in safety applications
designed to protect persons
or processes.
2
2
2
2
2
www.eaton.com
V8-T2-21
2
2
2.3
2
Limit Switches
2
1
2
2
2
2
2
2
2
3
2
4
5
6
2
7
2
8
9
j
2
2
2
2
2
2
2
2
2
k
Notes
1 Basic device
(see Pages V8-T2-23 to V8-T2-31)
According to EN 50047
With screw-on cover
Contacts: 1NO-1NC, 2NO, 2NC
Cage Clamp, screw terminal
As snap-action or standard-action switch
As electronic snap-action switch
(individually adjustable)
As 4–20 mA analog signal encoder
As 0–10 Vdc analog signal encoder
2
2
3
4
Fixing adapter (see Page V8-T2-33)
Allows mounting of M22 pushbuttons
Roller lever
(see Pages V8-T2-23 and V8-T2-26)
For one-sided operation with higher
operating speed
Angled roller lever
(see Pages V8-T2-23, V8-T2-26 and
V8-T2-30)
For actuation along the unit axis
5
6
7
Rotary lever (see Pages V8-T2-23,
V8-T2-27 and V8-T2-30)
For actuation from the side, for
pendulum movements
Roller plunger (see Pages V8-T2-23,
V8-T2-26 and V8-T2-30)
For actuation from the side with low
actuating force
Adjustable roller lever
(see Pages V8-T2-24, V8-T2-27,
V8-T2-28 and V8-T2-30)
For length adjustment as required
8
Actuating rod (see Pages V8-T2-25,
V8-T2-29 and V8-T2-31)
On conveyor belts for lightweight goods
9 Spring-rod (see Pages V8-T2-25,
For flexible actuation from all sides
j Actuating rod (see Pages V8-T2-25,
Withdrawable mechanism from front
k Pushbuttons from the M22 family; see
M22 catalog (CA04716001E) or
www.eaton.com/m22
by 90 degrees.
2
2
2
2
2
2
2
2
2
V8-T2-22
2.3
Limit Switches
Product Selection
2
Plastic Safety
Switch Body
2
LS-S02
LS-S20A
LS-S11S
Output Function
2NC with positive
opening contacts
2NO with slow
make/break
1NO and 1NC with
positive opening contact
2
Terminal Connection
Screw terminal 1
Screw terminal 1
Screw terminal 1
2
Contact Sequence
11 21
12 22
13 23
13
14 24
14 22
Contact Travel
Assembled Switch
2
Switch Body Catalog Number
2
2
Snap-action contact
= contact closed
= contact open
21
3.0
11–12
21–22
3.0
Zw = 4.5 mm
6.1
NC
NC
13–14
23–24
2.1
ZW = 4.5 mm
6.1
NO
NO
6.1
21–22
13–14
21–22
13–14
2
2
1.6
Zw = 5.5 mm
2
Operating Head Type 2
Top Push Roller
Plunger
Head Only
Catalog Number
Assembled Switch
Catalog Number
LS-XP
LS-S02-P
LS-S20A-P
2
LS-S11S-P
2
2
Long Roller Lever
LS-XL
LS-S02-L
LS-S20A-L
2
LS-S11S-L
2
Short Roller Lever
LS-XLS
LS-S02-LS
LS-S20A-LS
2
LS-S11S-LS
2
2
Large Roller Lever
LS-XLB
LS-S02-LB
LS-S20A-LB
2
LS-S11S-LB
2
2
2
Angled Roller
LS-XLA
LS-S02-LA
LS-S20A-LA
2
LS-S11S-LA
2
2
Rotary Lever
LS-XRL
LS-S02-RL
LS-S20A-RL
2
LS-S11S-RL
2
2
2
Notes
1 Cage Clamp versions available. Contact Application Engineering.
2 For operating head dimensions, see Page V8-T2-40.
2
V8-T2-23
2.3
2
Plastic Safety
Switch Body
Limit Switches
Plastic Safety Switches, continued
LS-S02
LS-S20A
LS-S11S
2
Output Function
2NC with positive
opening contacts
2NO with slow
make/break
1NO and 1NC with
2
Terminal Connection
Screw terminal 1
Screw terminal 1
Screw terminal 1
Contact Sequence
2
2
12 22
13 23
13
14 24
14 22
Contact Travel
Assembled Switch
2
= contact open
3.0
11–12
21–22
3.0
Zw = 4.5 mm
2
21
Snap-action contact
= contact closed
2
6.1
NC
NC
13–14
23–24
2.1
ZW = 4.5 mm
6.1
NO
NO
21–22
13–14
21–22
13–14
1.6
Zw = 5.5 mm
Head Only
Catalog Number
Assembled Switch
Catalog Number
Adjustable
Roller Lever
(with 18 mm Roller)
LS-XRLA
LS-S02-RLA
LS-S20A-RLA
LS-S11S-RLA
Adjustable
Roller Lever
(with 30 mm Roller)
LS-XRLA30
LS-S02-RLA30
LS-S20A-RLA30
LS-S11S-RLA30
Adjustable
Roller Lever
(with 40 mm Roller)
LS-XRLA40
LS-S02-RLA40
LS-S20A-RLA40
LS-S11S-RLA40
Adjustable Roller
Lever (with 40 mm
Rubber Roller)
LS-XRLA40R
LS-S02-RLA40R
LS-S20A-RLA40R
LS-S11S-RLA40R
2
2
11 21
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Notes
2
2
2
V8-T2-24
6.1
2.3
Limit Switches
Plastic Safety
Switch Body
LS-S02
LS-S20A
LS-S11S
Output Function
2NC with positive
opening contacts
2NO with slow
make/break
1NO and 1NC with
Terminal Connection
Screw terminal
Contact Sequence
1
Screw terminal
11 21
12 22
1
Screw terminal
13 23
13
14 24
14 22
Contact Travel
Assembled Switch
2
2
21
2
2
Snap-action contact
= contact closed
= contact open
2
1
3.0
11–12
21–22
3.0
Zw = 4.5 mm
6.1
NC
NC
13–14
23–24
2.1
ZW = 4.5 mm
6.1
NO
NO
6.1
21–22
13–14
21–22
13–14
2
2
1.6
Zw = 5.5 mm
2
Plastic Rod Lever
Head Only
Catalog Number
Assembled Switch
Catalog Number
LS-XRR
LS-S02-RR
LS-S20A-RR
2
LS-S11S-RR
2
2
2
2
Metal Rod
LS-XRRM
LS-S02-RRM
LS-S20A-RRM
LS-S11S-RRM
2
2
2
2
2
Spring Rod (Wobble) 3 LS-XS
LS-S02-S
LS-S20A-S
2
LS-S11S-S
2
2
2
Actuating Rod
LS-XOR
LS-S02-OR
LS-S20A-OR
2
LS-S11S-OR
2
2
2
Notes
3 Not to be used as a safety position switch. Use only in conjunction with snap-action contact.
2
2
2
2
V8-T2-25
2.3
Limit Switches
2
LS-Titan Plastic Electronic Safety Position Switches
2
Plastic Electronic
Safety Position
Switch Body
2
2
2
Switch Body
Catalog Number
LSE-11
LSE-02
LSE-AI
Output Function
1NO and 1 NC
2NC
Analog 4–20 mA
Analog 0–10V
Terminal Connections
Cage Clamp 1
Cage Clamp 1
Cage Clamp 1
Cage Clamp 1
Safety Functions
and Approvals
These models may be used in safety-oriented circuits. Visual status
LED indication is comparable to positive opening contacts. Certified
by TÜV as a “Functional-Safety” device. Suitable for protection of
people or processes.
Additional diagnostic output that registers a 0V signal in the event
of a fault. Self-test function continuously tests both outputs for
overloads, short circuits to 0V and short circuits to +Ue. Certified by
TÜV to EN 954-1, Category 3 or 4. Suitable for protection of people
or processes.
Contact Sequence
+Ue
Analog 4–20 mA
2
2
LSE-AU
Assembled Switch
2
+Ue
electron.
2
Q1
electron.
Q2
Q1
0V
2
Contact Travel
2
Q1
= contact open
Q2
Q2
0V
0 0.5
= contact closed
Analog 0–10V
0 0.5
5.5 6.1
5.5 6.1
Q1
U [V]
I [mA]
10
Q2
default=3.0
default=3.0
4
S [%]
100
S [%]
2
2
Head Only
Catalog Number
Assembled Switch
Catalog Number
Top Push Roller
Plunger
LS-XP
LSE-11-P
LSE-02-P
LSE-AI-P
LSE-AU-P
Long Roller Lever
LS-XL
LSE-11-L
LSE-02-L
LSE-AI-L
LSE-AU-L
Short Roller Lever
LS-XLS
LSE-11-LS
LSE-02-LS
LSE-AI-LS
LSE-AU-LS
Large Roller Lever
LS-XLB
LSE-11-LB
LSE-02-LB
LSE-AI-LB
LSE-AU-LB
Angled Roller
LS-XLA
LSE-11-LA
LSE-02-LA
LSE-AI-LA
LSE-AU-LA
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Notes
1 A compatible Cage Clamp tool is available as an accessory on Page V8-T2-33.
2
2
V8-T2-26
100
2.3
Limit Switches
Plastic Electronic
Safety Position
Switch Body
Plastic Electronic Safety Position Switches, continued
Switch Body
Catalog Number
LSE-11
Output Function
1NO and 1NC
2
LSE-02
LSE-AI
2NC
1
LSE-AU
Analog 4–20 mA
1
Cage Clamp
Safety Functions
and Approvals
Cage Clamp
Cage Clamp
2
Analog 0–10V
1
Cage Clamp
1
or processes.
2
2
2
Assembled Switch
Contact Sequence
+Ue
Q1
Q2
Q1
Q1
= contact open
Q2
2
Q2
0V
0 0.5
= contact closed
2
Analog 0–10V
electron.
0V
Contact Travel
Analog 4–20 mA
+Ue
electron.
0 0.5
5.5 6.1
Q1
5.5 6.1
I [mA]
2
U [V]
10
Q2
default=3.0
default=3.0
4
S [%]
100
S [%]
Head Only
Catalog Number
Assembled Switch
Catalog Number
LS-XRL
LSE-11-RL
2
2
100
Rotary Lever
2
2
LSE-02-RL
LSE-AI-RL
2
LSE-AU-RL
2
2
Adjustable
Roller Lever
(with 18 mm Roller)
LS-XRLA
LSE-11-RLA
LSE-02-RLA
LSE-AI-RLA
2
LSE-AU-RLA
2
2
2
2
2
Adjustable
Roller Lever
(With 30 mm Roller)
LS-XRLA30
LSE-11-RLA30
LSE-02-RLA30
LSE-AI-RLA30
2
LSE-AU-RLA30
2
2
2
2
2
2
Notes
2
2
V8-T2-27
2.3
2
2
Plastic Electronic
Safety Position
Switch Body
2
2
Limit Switches
Switch Body
Catalog Number
LSE-11
LSE-02
LSE-AI
Output Function
1NO and 1NC
2NC
Analog 4–20 mA
Analog 0–10V
Cage Clamp 1
Cage Clamp 1
Cage Clamp 1
Cage Clamp 1
Safety Functions
and Approvals
or processes.
Contact Sequence
+Ue
Analog 4–20 mA
2
2
Assembled Switch
2
Q1
Contact Travel
Q1
2
Q1
= contact open
Q2
Q2
0V
0 0.5
= contact closed
0 0.5
5.5 6.1
5.5 6.1
Q1
I [mA]
U [V]
10
Q2
default=3.0
default=3.0
4
Analog 0–10V
electron.
Q2
0V
2
S [%]
100
S [%]
2
2
+Ue
electron.
2
2
LSE-AU
Head Only
Catalog Number
Assembled Switch
Catalog Number
Adjustable
Roller Lever
(With 40 mm Roller)
LS-XRLA40
LSE-11-RLA40
LSE-02-RLA40
LSE-AI-RLA40
LSE-AU-RLA40
Adjustable
Roller Lever
(With 40 mm Roller)
LS-XRLA40R
LSE-11-RLA40R
LSE-02-RLA40R
LSE-AI-RLA40R
LSE-AU-RLA40R
Plastic Rod Lever
LS-XRR
LSE-11-RR
LSE-02-RR
LSE-AI-RR
LSE-AU-RR
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Notes
2
V8-T2-28
2.3
Limit Switches
Plastic Electronic
Safety Position
Switch Body
Switch Body
Catalog Number
LSE-11
Output Function
1NO and 1NC
2
LSE-02
LSE-AI
2NC
1
LSE-AU
Analog 4–20 mA
Cage Clamp
1
Cage Clamp
Cage Clamp
Safety Functions
and Approvals
2
Analog 0–10V
1
Cage Clamp
1
by TÜV to EN 954-1, Category 3 or 4. Suitable for protection of people
or processes.
Assembled Switch
Contact Sequence
+Ue
electron.
Q1
Q1
Q2
= contact closed
= contact open
2
Q2
0 0.5
5.5 6.1
Q1
Q1
Q2
Q2
default=3.0
5.5 6.1
default=3.0
I [mA]
4
U [V]
2
10
S [%]
100
2
S [%]
2
Metal Rod
Head Only
Catalog Number
Assembled Switch
Catalog Number
LS-XRRM
LSE-11-RRM
2
2
0V
0 0.5
2
2
Analog 0–10V
electron.
0V
Contact Travel
Analog 4–20 mA
+Ue
2
LSE-02-RRM
LSE-AI-RRM
2
LSE-AU-RRM
2
2
2
2
2
LSE-11-S
LSE-02-S
LSE-AI-S
2
LSE-AU-S
2
2
2
2
2
Actuating Rod
LS-XOR
LSE-11-OR
LSE-02-OR
LSE-AI-OR
LSE-AU-OR
2
2
2
2
2
Notes
2
2
V8-T2-29
2.3
Limit Switches
2
2
Metal Safety
Switch Body
LSM-02
LSM-20A
LSM-11S
2
Output Function
2NC with positive
opening contacts
2NO with slow
make/break
1NO and 1NC with
2
Terminal Connection
Cage Clamp
Cage Clamp
Cage Clamp
Contact Sequence
2
12 22
2
2
Assembled Switch
3.0
11–12
21–22
3.0
Zw = 4.5 mm
2
2
13
14 24
14 22
Snap-action contact
= contact closed
= contact open
21
13 23
Contact Travel
2
2
11 21
6.1
NC
NC
13–14
23–24
2.1
ZW = 4.5 mm
6.1
NO
NO
21–22
13–14
21–22
13–14
1.6
Zw = 5.5 mm
Operating Head Type 1
Head Only
Catalog Number
Assembled Switch
Catalog Number
Top Push Roller
Plunger
LSM-XP
LSM-02-P
LSM-20A-P
LSM-11S-P
Long Roller Lever
LSM-XL
LSM-02-L
LSM-20A-L
LSM-11S-L
Angled Roller
LSM-XLA
LSM-02-LA
LSM-20A-LA
LSM-11S-LA
Rotary Lever
LSM-XRL
LSM-02-RL
LSM-20A-RL
LSM-11S-RL
Adjustable Roller Lever
LSM-XRLA
LSM-02-RLA
LSM-20A-RLA
LSM-11S-RLA
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Note
1 For operating head dimensions, see Page V8-T2-40.
2
2
V8-T2-30
6.1
2.3
Limit Switches
Metal Safety
Switch Body
Metal Safety Switches, continued
LSM-02
LSM-20A
LSM-11S
2
Output Function
2NC with positive
opening contacts
2NO with slow
make/break
1NO and 1NC with
2
Terminal Connection
Cage Clamp
Cage Clamp
Cage Clamp
2
Contact Sequence
11 21
12 22
13 23
13
14 24
14 22
Contact Travel
= contact open
2
2
Snap-action contact
= contact closed
Assembled Switch
21
3.0
11–12
21–22
3.0
Zw = 4.5 mm
6.1
NC
NC
13–14
23–24
2.1
ZW = 4.5 mm
6.1
NO
NO
6.1
21–22
13–14
21–22
13–14
2
2
1.6
Zw = 5.5 mm
2
Plastic Rod Lever
Head Only
Catalog Number
Assembled Switch
Catalog Number
LSM-XRR
LSM-02-RR
LSM-20A-RR
2
LSM-11S-RR
2
2
2
2
2
2
Metal Rod Lever
LSM-XRRM
LSM-02-RRM
LSM-20A-RRM
LSM-11S-RRM
2
2
2
2
2
Spring Rod (Wobble)
LSM-XS
LSM-02-S
LSM-20A-S
2
LSM-11S-S
2
2
2
2
2
2
Note
2
2
2
V8-T2-31
2.3
2
2
2
2
2
2
2
Limit Switches
Understanding LS-Titan Electronic Safety Position Switches
All four LS-Titan LSE switch
bodies are safety-rated
products. The LSE-11 and
LSE-02 switch bodies both
have a freely programmable
operating point and can be
individually adjusted to suit
the application, and can be
changed as often as required.
These devices feature an
LED on the body, providing
simple indication during
programming and operation.
2
2
LSE-11
This ensures that a safe
operating state can be
monitored and evaluated at
any time. A self-test function
is also present on these
models. Outputs Q1 and Q2
are continuously tested for
The LSE-AI (4–20 mA) and
LSE-AU (0–10V) analog
position switches take
position data and convert to
an analog current or voltage
value that can then be
continuously fed into an
automation system. These
two switches also feature
a diagnostic output for
additional data processing.
LSE-02
2
adjust
fix
2
2
2
1s
LED
Set
2
fmax ≤ 2 N
Set
2
2
2
Example of LS-Titan LSE Models in a Safety-Oriented Circuit
+24V
2
LSE-11
2
S1
LSE-11
+Ue
2
2
S2
S3
+Ue
Q1
Q1
Q1
Q2
Q2
0V
R1
0V
R2
2
2
0V
2
Notes
LSE-11 and LSE-02—individual operating point adjustment.
2
LSE-11 and LSE-02 can be used in safety circuits.
S1 is connected to 24 Vdc
S2, S3 each switch with a delay of 0.7s
R1, R2, for example, series element M22-XLED60 (2820 ohms/0.5W)
2
2
2
2
V8-T2-32
LS-_
S4
Q2
0V
2
LSE-11
+Ue
K1
Like the electromechanical
position switches, LS-Titan
electronic position switches
meet Category 3 or 4 of
the EN 954-1 standard for
machine safety when
configured as a redundant
system. All devices are
thus suitable for safety
applications that are used
for the protection of persons
or processes.
2.3
Limit Switches
Accessories
2
LS-Titan Safety Switches
V1-2-M20
Description
Notes
Catalog Number
Any
M20 screw terminal in 1/2 in. For use with
American pipe thread, metal.
The screw connection must be earthed.
Not total insulation.
V1-2-M20-NA
2
Any
American pipe thread, molded material.
V1-2-M20
2
Any
M20 diaphragm bolt. With internal push-through
membrane. Will fit cable with an external diameter
of up to 13 mm. Rated IP65 with cable inserted.
EMS20
M20
2
1/2 in
EMS20
2
For Use With
2
2
LS-XTW
Any
Cage Clamp tool.
2
LS-XTW
2
M12A
LS-Titan plastic bodies (LS-_)
Plug connector, 12 mm, 4-pin male connector
M12x1 (M12x1). Rated IP65. Molded material.
Color coded to IEC/EN 60947-5-2.
1
1
1
2
2
2
3
3
3
4
4
4
2
M12A
4
2
3
1
2
2
..-11-.. ..-20-.. ..-02-..
M12A5
LS-Titan metal bodies (LSM-_)
Plug connector, 12 mm, 5-pin male connector
1
1
1
2
2
2
3
3
3
4
4
4
2
2
M12A5
4
3
1
2
2
2
M22-LS
Any
Allows mounting of M22 pushbuttons.
(See the M22 catalog, CA04716001E, for
a full selection of pushbuttons.)
2
M22-LS
2
2
2
2
2
2
2
2
2
2
2
2
2
V8-T2-33
2.3
Limit Switches
2
2
LS-Titan Miniature DIN Switches—IP66, IP67 Complete Units
2
General
2
LS, LSM
LSE-11/LSE-02
LSE-AI 1
LSE-AU 1
Standards
IEC/EN 60947
IEC/EN 60947
EN 61000-4
IEC/EN 60947
EN 61000-4
IEC/EN 60947
EN 61000-4
Climatic proofing
Damp heat, constant, to IEC
60068-2-78; damp heat,
cyclical, to IEC 60068-2-30
Units
2
2
Ambient temperature
–13° to 158°F (–25° to 70°C)
Mounting position
As required
As required
As required
As required
2
Protection type
IP66, IP67
IP66, IP67
IP66, IP67
IP66, IP67
2
2
2
2
2
2
2
°F (°C)
Terminal capacity of screw
terminal and Cage Clamp
Solid
mm2
1 x (0.5–2.5)
1 x (0.5–2.5)
1 x (0.5–2.5)
1 x (0.5–2.5)
Flexible with ferrules to DIN 46228
mm2
1 x (0.5–1.5)
1 x (0.5–1.5)
1 x (0.5–1.5)
1 x (0.5–1.5)
Ue
Vdc
N/A
12–30
24 (–15%/+20%)
24 (–15%/+20%)
12V
Ie
mA
N/A
15
N/A
N/A
24V
Ie
mA
N/A
18
28–45
24
30V
I
mA
N/A
19
N/A
N/A
N/A
N/A
N/A
Power Supply
Rated voltage
Burden current
Contacts/Switching Capacity
Rated impulse withstand voltage
Uimp
Vac
4000
Rated insulation voltage
Ui
V
400
N/A
N/A
N/A
III/3
III/3
N/A
N/A
2
Overvoltage category/
pollution degree
2
Rated Operational Current
AC–15
2
24V
Ie
A
6
N/A
N/A
N/A
230V/240V
A
6
N/A
N/A
N/A
2
Ie
400V/415V
Ie
A
4
N/A
N/A
N/A
2
DC-13
24V
Ie
A
3
0.2
N/A
N/A
2
110V
Ie
A
0.8
N/A
N/A
N/A
220V
Ie
A
0.3
N/A
N/A
N/A
2
2
Note
1 The following applies for LSE-11 and LSE-02: ensure that the power supply operates correctly when setting the operating point.
2
2
2
2
2
2
2
2
V8-T2-34
2.3
Limit Switches
LS-Titan Miniature DIN Switches—IP66, IP67 Complete Units. continued
Units
LS, LSM
LSE-11/LSE-02
LSE-AI 1
2
LSE-AU 1
2
Burden Current
Analog output Q1
Output voltage (max. 10 mA)
Vdc
N/A
N/A
Output current
mA
N/A
N/A
4–20
Fault scenario
V
N/A
N/A
0–10
2
Resolution
Steps
N/A
N/A
100
100
Step tolerance
Steps
N/A
N/A
1
1
Shunt resistor, resistive load
ohms
N/A
N/A
1000
V
N/A
N/A
Approx. Ue
Approx. Ue
mA
N/A
N/A
