3.3
3
Inductive Proximity Sensors
E57PS Performance Short Body Sensors
Contents
Description
3
Page
Product Selection
E57PS Performance Short Body Sensors . .
Compatible Connector Cables . . . . . . . . . . .
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . .
Technical Data and Specifications . . . . . . . . . .
Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . .
3
3
3
3
V8-T3-25
V8-T3-25
V8-T3-26
V8-T3-26
V8-T3-27
V8-T3-27
3
3
3
3
3
3
Product Description
Features
For demanding sensing
applications in areas too small
for standard length units, the
Body series is an ideal
solution as it incorporates
the premium features of the
E57P series but in a shorter
body length. With its
stainless steel tubular
body, IP69K rating, wide
temperature range (down to
–40 °C), fast switching speed
and laser-etched markings,
the E57PS series provides
value at a low price point.
3
3
3
3
3
3
3
360° LED indicator
Stainless steel tube
10–48 Vdc operating
voltage
Short-circuit protection
–40 to 70 °C temperature
range
IP69K environmental
rating
Durable laser-engraved
label
Available in cable and
micro-connector styles
Standards and Certifications
cULus Listed
CE
3
3
DANGER
THIS SENSOR IS NOT A
SAFETY DEVICE AND IS NOT
INTENDED TO BE USED AS A
SAFETY DEVICE. This sensor
is designed only to detect
and read certain data in an
electronic manner and
perform no use apart from
that, specifically no safetyrelated use. This sensor
product does not include
self-checking redundant
circuitry, and the failure of
this sensor product could
cause either an energized
or de-energized output
condition, which could result
in death, serious bodily
injury, or property damage.
3
3
3
3
3
3
3
3
3
For the most current information
on this product, visit our Web site:
www.eaton.com
V8-T3-24
For Customer Service in the U.S. call 1-877-ETN CARE (386-2273),
in Canada call 1-800-268-3578.
For Application Assistance in the U.S. and Canada
call 1-800-426-9184.
Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com
3.3
Product Selection
3
3
Three-Wire Sensors
Operating
Voltage
12 mm
NO Output
Catalog Number
NC Output
Catalog Number
2 mm
Shielded
(standard range) (PNP)
2-meter cable
E57PS-12SNN2-C2
E57PS-12SNC2-C2
4-pin micro DC connector
E57PS-12SNN2-Q
E57PS-12SNC2-Q
Shielded
(NPN)
2-meter cable
E57PS-12SPN2-C2
E57PS-12SPC2-C2
E57PS-12SPN2-Q
E57PS-12SPC2-Q
4 mm
Unshielded
2-meter cable
E57PS-12UNN4-C2
E57PS-12UNC4-C2
E57PS-12UNN4-Q
E57PS-12UNC4-Q
Unshielded
(NPN)
2-meter cable
E57PS-12UPN4-C2
E57PS-12UPC4-C2
E57PS-12UPN4-Q
E57PS-12UPC4-Q
5 mm
Shielded
2-meter cable
E57PS-18SNN2-C2
E57PS-18SNC2-C2
E57PS-18SNN2-Q
E57PS-18SNC2-Q
Shielded
(NPN)
2-meter cable
E57PS-18SPN2-C2
E57PS-18SPC2-C2
E57PS-18SPN2-Q
E57PS-18SPC2-Q
8 mm
Unshielded
2-meter cable
E57PS-18UNN4-C2
E57PS-18UNC4-C2
E57PS-18UNN4-Q
E57PS-18UNC4-Q
Unshielded
(NPN)
2-meter cable
E57PS-18UPN4-C2
E57PS-18UPC4-C2
E57PS-18UPN4-Q
E57PS-18UPC4-Q
3
10 mm
Shielded
2-meter cable
E57PS-30SNN2-C2
E57PS-30SNC2-C2
3
E57PS-30SNN2-Q
E57PS-30SNC2-Q
Shielded
(NPN)
2-meter cable
E57PS-30SPN2-C2
E57PS-30SPC2-C2
3
3
3
3
3
3
18 mm Diameter
10–48 Vdc
30 mm
3
Connection Type 1
Shielding
12 mm Diameter
10–48 Vdc
18 mm
Sensing
Range (Sn)
3
3
3
3
30 mm Diameter
10–48 Vdc
E57PS-30SPN2-Q
E57PS-30SPC2-Q
15 mm
Unshielded
2-meter cable
E57PS-30UNN4-C2
E57PS-30UNC4-C2
E57PS-30UNN4-Q
E57PS-30UNC4-Q
Unshielded
(NPN)
2-meter cable
E57PS-30UPN4-C2
E57PS-30UPC4-C2
E57PS-30UPN4-Q
E57PS-30UPC4-Q
3
3
3
3
3
3
Standard Cables 2
Voltage
Style
Micro-Style
Straight Female
Number
of Pins
Gauge
Length
22 AWG
6.0 ft (2m)
Pin Configuration/Wire Colors
(Face View Female Shown)
PVC Jacket
Catalog Number
PUR Jacket
Catalog Number
1-Brown
2-White
3-Blue
4-Black
CSDS4A4CY2202
CSDS4A4RY2202
Micro-Style, Straight Female
DC
4-pin,
4-wire
3
3
3
3
Notes
See listing of compatible connector cables above.
3
1
3
2
Cable models are supplied as standard with a 2-meter cable. A 5-meter cable is available by adding S5 to the catalog number.
Example: E57SAL12T110 becomes E57SAL12T110S5.
For a full selection of connector cables, see Tab 10, section 10.1.
3
3
3
V8-T3-25
3.3
3
3
Accessories
Description
Reference
3
Mounting brackets
See Tab 8,
section 8.2
3
Replacement mounting nuts and other accessories
See Tab 8,
section 8.3
3
Connector cables
See Tab 10,
section 10.1
3
3
3
3
Description
Three-Wire DC Sensors
3
Operating voltage
10–48 Vdc
Maximum load current
300 mA
Switching frequency [Hz]
12 mm—Shielded: 2000; Unshielded: 2000
18 mm—Shielded: 1200; Unshielded: 1200
30 mm—Shielded: 600; Unshielded: 500
Leakage current
100 μA maximum
3
Voltage drop
≤2.5 V
Holding current
≤10 mA
3
Yes (Auto Reset)
Switching hysteresis
2–20% of rated sensing distance
3
3
3
Repeat accuracy
1% shielded, 3% unshielded
3
Output indicator LED
360° amber LED
Operating temperature
–40 to 158 °F (–40 to 70 °C)
3
Enclosure ratings
IP67, IP69K; NEMA 4, 4X, 6, 6P
Shock
30 g sine wave, 11 ms per IEC68-2-76
3
Vibration
10 to 55 Hz, 1 mm amplitude
Material of construction
Stainless steel, polycarbonate end bells, Ryton® front cap
Cable
AWM Style 20387 (PVC)
3
3
Note
Ryton® is a registered trademark of Phillips Chemical (division of Phillips Petroleum).
3
3
3
3
3
3
3
3
3
3
V8-T3-26
3.3
Wiring Diagrams
Pin numbers are for reference, rely on pin location when wiring.
3
3
Operating
Voltage
Output
3
Micro-Connector Models
(Face View Male Shown)
Cable Models
3
Three-Wire Sensors
10–48 Vdc
NO
(NPN)
BN
BK
Load
BU
NO
(PNP)
(_)
3
Load
+V
Load
3
BN
BK
3
Load
+V
BU
NC
(PNP)
3
+V
Load
BN
BK
3
+V
BU
NC
(NPN)
3
Load
BN
BK
+V
+V
3
+V
BU
Load
Load
3
+V
3
(_)
3
Dimensions
Approximate Dimensions in Inches (mm)
3
E57PS Performance Short Body Sensors—Cable Models
3
12 mm
18 mm
A
A
A
B
B
C
3
30 mm
C
C
3
B
3
D
Size
Shielding
3
D
Sensing
Face
D
Sensing
Face
Sensing
Face
3
Overall Length
A
Threaded Length
B
Cap Height
C
Thread Size
D
M12 x 1
3
3
12 mm
Shielded
1.61 (40.9)
1.07 (27.2)
Unshielded
1.61 (40.9)
0.89 (22.7)
0.20 (5.0)
M12 x 1
18 mm
Shielded
1.77 (44.9)
1.17 (29.8)
M18 x 1
Unshielded
1.77 (44.9)
0.92 (23.3)
0.28 (7.0)
M18 x 1
30 mm
Shielded
1.84 (46.6)
1.15 (29.3)
M30 x 1.5
Unshielded
1.84 (46.6)
0.66 (16.8)
0.51 (13.0)
M30 x 1.5
3
3
3
3
3
3
3
V8-T3-27
3.3
3
3
3
3
E57PS Performance Short Body Sensors—Micro-Connector Models
12 mm
3
3
18 mm
A
A
C
C
C
D
D
D
Sensing
Face
Sensing
Face
Sensing
Face
Size
Shielding
Overall Length
A
Threaded Length
B
Cap Height
C
Thread Size
D
3
12 mm
3
3
A
B
B
B
3
3
30 mm
Shielded
1.64 (41.5)
1.07 (27.2)
M12 x 1
Unshielded
1.64 (41.5)
0.89 (22.7)
0.20 (5.0)
M12 x 1
18 mm
Shielded
1.59 (40.3)
1.17 (29.8)
M18 x 1
Unshielded
1.59 (40.3)
0.92 (23.3)
0.28 (7.0)
M18 x 1
30 mm
Shielded
1.77 (45.0)
1.15 (29.3)
M30 x 1.5
Unshielded
1.96 (49.7)
0.66 (16.8)
0.51 (13.0)
M30 x 1.5
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-28
很抱歉,暂时无法提供与“E57PS-30SPC10-C2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+779.414691+100.69430
- 5+727.459545+93.98210
- 10+675.5043910+87.26990
