ED315
ED315
    EATON(伊顿)
    Cylindrical,Blade Terminal(Bolt)
    FUSE CRTRDGE 315A 415VAC CYLINDR
ED315 数据手册
Bussmann® Industrial HRC Fuse Link ED 31 x 112mm, BS88, IEC 269-1 Center Bolted Tags 250 315 355 400 & 315M400 400M500 Time-Current Characteristic Curve (Full Size Curves Available) CURRENT RATING 10,000 1,000 CATALOG SYMBOL: ED INDUSTRIAL HRC FUSE CENTER BOLTED TAGS PACKAGE QUANTITY: 1 80kA INTERRUPTING RATING MOUNTS ON BH-1131 MODULAR FUSEBLOCK TIME IN SECONDS 100 Dimensional Data: A B H G C 10 D F E 1 J 0,000 100 1,000 .01 0,000 .1 Electrical Characteristics Catalog Number Ampere Rating I2T (Amp2 Seconds) PreTotal At Arcing 240V Total At 415V Nom Watts Loss ED250 ED315 ED315M400 ED355 ED400 ED400M500 250 315 315M400 355 400 400M500 200,000 265,000 475,000 360,000 475,000 1,200,000 480,000 635,000 1,150,000 865,000 1,150,000 2,700,000 18 22 21 24 29 38 340,000 450,000 810,000 610,000 810,000 — Dimensions (Inches/mm) Rated Voltage 415AC 550AC A B C D E F G H J 136.0 111.0 47.0 9.0 12.5 19.0 3.2 22.5 31.0 136.0 110.0 50.0 9.0 12.5 25.4 4.7 31.0 38.0 136.0 110.0 50.0 9.0 12.5 25.4 4.7 31.0 38.0 135.5 114.0 75.0 9.5 12.5 25.4 4.7 31.5 59.0 The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-17-98 SB98107 Rev. A Form No. ED Page 1 of 1 BIF Doc #4119
ED315 价格&库存
很抱歉,暂时无法提供与“ED315”相匹配的价格&库存,您可以联系我们找货
ED315
  • 1+254.78494
  • 25+244.58979
  • 100+234.40506
库存:199
