EN1511N4LATCH
EN1511N4LATCH
    EATON(伊顿)
    EATON TRIPP LITE - EN1511N4LATCH - ENCLOSURE W/HASP, NETWORK BOX, PC, WHITE
EN1511N4LATCH 数据手册
Wireless Access Point Enclosure with Hasp NEMA 4, Surface-Mount, PC Construction, 15 x 11 in. Highlights ● Designed for Cisco WAPs, but accommodates equipment from most vendors MODEL NUMBER: EN1511N4LATCH ● NEMA 4 rating ensures protection against water, dust, rain, sleet, snow and ice ● Rugged polycarbonate cover with hasp accepts optional padlock for extra security ● Transparent to wireless signals, ensuring an optimum Wi-Fi signal in all directions ● Comes fully assembled and ready for wall- or ceilingmounting using included hardware Protects your indoor or outdoor Wi-Fi access point against water, dust, rain, sleet, snow and ice, as well as theft, damage or tampering. Applications Features ● Wall-Mount Enclosure Secures and Organizes Your Router/Modem or Wireless Access Point Protect your indoor or outdoor router/modem or Wi-Fi access point by installing it inside this SmartRack® NEMA 4 Wireless Access Point Enclosure made from impact-resistant UL 94 V-1 Classified PC plastic. It’s ideal for offices, dorms, hotels, classrooms, retail locations and other indoor/outdoor areas where you need to keep Wi-Fi equipment secure, organized and out of the way. Carries a NEMA 4 Rating for Protection Against Harsh Elements The NEMA 4-rated enclosure supports indoor or outdoor use. It protects its contents against the ingress of water (including rain, sleet, snow, splashing water and hose-directed water), solid foreign objects (including falling dirt and windblown dust) and even ice forming on the outside of the enclosure. Accommodates a Wide Range of Equipment, Including Cisco WAPs, up to 627.5 in.³ Though the EN1511N4LATCH is designed specifically to protect Cisco Wi-Fi access points, it will also house most other equipment up to 627.5 cubic inches (10,283 cubic centimeters). While rugged enough to keep your equipment safe inside, it’s also transparent to wireless signals, ensuring strong Wi-Fi coverage. Latches Securely to Help Prevent Theft, Damage or Tampering The hinged polycarbonate plastic cover latches tightly to the enclosure to protect the contents. Attach a padlock or tamper seal (both sold separately) to the hasp on the latch for an extra level of security. Supports Wall- or Ceiling-Mounting to Best Fit Your Application The EN1511N4LATCH comes fully assembled and ready for horizontal or vertical mounting on a wall or ceiling with user-provided hardware. It is designed for Cisco WAPs, but the included universal T-bar bracket will accommodate a wide variety of equipment from other brands. 1/2 Protect a router/modem or wireless access point inside a classroom, office, hotel, store, dorm or other indoor space from damage, theft or tampering ● Protect outdoor equipment against water, dust, rain, sleet, snow and ice Package Includes ● NEMA 4 wireless access point enclosure, 15 x 11 in. ● (2) M4 screws ● (2) M6 screws, 1 in. ● (4) M6 trusshead screws, 0.25 in. ● Cable tie ● (2) Nylon spacers ● T-bar bracket ● (4) Mounting feet ● Installation guide Specifications OVERVIEW UPC Code 037332217844 Rack Type Enclosure PHYSICAL Color White Maximum Device Depth (cm) 9.65 Maximum Device Depth (in.) 3.8 Maximum Device Depth (mm) 97 Rack Height 0U Shipping Dimensions (hwd / cm) 15.56 x 34.29 x 42.54 Shipping Dimensions (hwd / in.) 6.12 x 13.50 x 16.75 Shipping Weight (kg) 3.63 Unit Dimensions (cm) 38.6 x 28.2 x 10.16 Unit Dimensions (hwd / cm) 38.6 x 28.2 x 10.16 Unit Dimensions (hwd / in.) 15.1 x 11.2 x 4.0 Unit Dimensions (in.) 15.1 x 11.2 Unit Weight (kg) 2.86 Unit Weight (lbs.) 6.3 SPECIAL FEATURES Built-in Cable Management No WARRANTY Product Warranty Period (Worldwide) 5-year limited warranty © 2020 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
EN1511N4LATCH 价格&库存
很抱歉,暂时无法提供与“EN1511N4LATCH”相匹配的价格&库存,您可以联系我们找货
