FAZ6-D63/4
FAZ6-D63/4
    EATON(伊顿)
    EATON MOELLER - FAZ6-D63/4 - Thermal Magnetic Circuit Breaker, 6kA, FAZ6, 63 A, 4 Pole, 230 V, DIN R...
FAZ6-D63/4 数据手册
DATASHEET - FAZ6-D63/4 Miniature circuit breaker (MCB), 63 A, 4p, characteristic: D, 6 kA Similar to illustration Part no.  Catalog No.  Alternate Catalog No.    FAZ6-D63/4 168096 FAZ6-D63/4 Delivery program Number of poles Design verification as per IEC/EN 61439 Technical data for design verification     4 pole       Rated operational current for specified heat dissipation In A 63 Equipment heat dissipation, current-dependent Pvid W 25.5 Static heat dissipation, non-current-dependent Pvs W 0 Heat dissipation capacity Pdiss W 0 Operating ambient temperature min.   °C -40 Operating ambient temperature max.   °C 70       linear, per +1 °C, results in a 0.5% reduction of current carrying capacity Technical data ETIM 7.0 Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042) Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB) (ecl@ss10.0.1-27-14-19-01 [AAB905014]) Release characteristic     D Number of poles (total)     4 Number of protected poles     4 Rated current   A 63 Rated voltage   V 230 Rated insulation voltage Ui   V 440 Rated impulse withstand voltage Uimp   kV 4 Rated short-circuit breaking capacity Icn EN 60898 at 230 V   kA 6 Rated short-circuit breaking capacity Icn EN 60898 at 400 V   kA 6 Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V   kA 10 Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V   kA 10 Voltage type     AC Frequency   Hz 50 - 60 Current limiting class     3 Suitable for flush-mounted installation     No Concurrently switching N-neutral     No Over voltage category     3 Pollution degree     2 Additional equipment possible     Yes Width in number of modular spacings     4 Built-in depth   mm 70.5 Degree of protection (IP)     IP20 Ambient temperature during operating   °C -25 - 75 Connectable conductor cross section multi-wired   mm² 1 - 25 Connectable conductor cross section solid-core   mm² 1 - 25 Additional product information (links) Temperature dependency, derating https://www.eaton.com/content/dam/eaton/technicaldocumentation/technical-data-tables/Derating table FAZ6.pdf 05/30/2020 Eaton 168096 ED2020 V68.0 EN 1/2 05/30/2020 Eaton Industries GmbH http://www.eaton.eu © 05/2020 by Eaton Industries GmbH Eaton 168096 ED2020 V68.0 EN 2/2
FAZ6-D63/4 价格&库存
很抱歉,暂时无法提供与“FAZ6-D63/4”相匹配的价格&库存,您可以联系我们找货
