Effective February 2016
Supersedes April 2014
Technical Data 1012
FNQ 13⁄32˝ x 1-1⁄2˝ 500Vac time-delay
supplemental fuses
Catalog symbol / color code:
Dimensions - in (mm)
FNQ - Orange (500Vac maximum voltage)
Description:
Bussmann® series time-delay FNQ supplemental
fuses. For superior protection, upgrade to FNQ-R
Class CC fuses. See data sheet no. 1014.
Specifications:
Ratings
Fuse
Amp
Range
500Vac
UL
CSA
10kA
X
X
Features
Color coded for 500Vac maximum voltage rating
Fiber tube construction
Nickel-plated brass endcaps
Motor control transformers
Circuits with in-rush currents.
Recommended fuse blocks/fuse holders
Agency information
500Vac
1/10 to 30A
1.5"
(38.1)
Typical applications
Interrupting Rating Agency
at Rated Voltage
Information
1/10 to 30
0.41"
(10.3)
Catalog symbol
UL® Listed, Std. 248-14, Guide JDYX,
File E19180
CSA® Certified: C22.2 No. 248.14,
Class 1422-01, File 53787, HRC-MISC
CE
RoHS compliant*
Description
Data sheet no.#
Blocks
1-, 2- and 3-pole modular
BMM blocks with optional
covers
10235
BM 1-, 2- and 3-pole blocks
1104
DIN-rail holders / switches
CCP-_-30M 1-, 2- and 3-pole switch
1157
CHM 1-, 2- and 3-pole
3185
* FNQ-1/8 not RoHS compliant.
Optima NG 3-Pole protection module
Catalog numbers (amps)
FNQ-1/10
FNQ-8/10
FNQ-3-2/10
FNQ-9
FNQ-1/8
FNQ-1
FNQ-3-1/2
FNQ-10
FNQ-15/100
FNQ-1-1/8
FNQ-4
FNQ-12
FNQ-3/16
FNQ-1-1/4
FNQ-4-1/2
FNQ-14
FNQ-2/10
FNQ-1-1/2
FNQ-5
FNQ-15
FNQ-1/4
FNQ-1-6/10
FNQ-5-6/10
FNQ-20
FNQ-3/10
FNQ-2
FNQ-6
FNQ-25
FNQ-4/10
FNQ-2-1/4
FNQ-6-1/4
FNQ-30
FNQ-1/2
FNQ-2-1/2
FNQ-7
FNQ-6/10
FNQ-3
FNQ-8
1109
Optima 3-Pole holder
1102
Optima 3-Pole holder + switch
1103
Panel mount holders
HPM and HPM-D 1-Pole holder
2112
HPC-D 1-Pole holder
2109
HPS2 2-Pole holder
2140
HPF, HPF-C and
1-Pole holder
HPF-WT
2114
HPS 1-Pole holder
2113
HPG and HPD 1-Pole holder
2108
In-line holders
Carton quantity
HEB 1-Pole holder
2127
HEX 2-Pole holder
2126
Amps
Qty.
Fuseclips
1/10 to 30
10
1A3400, 5956 and
PCB fuseclips
5960
2132
Fuse covers
SAMI-7 Finger-safe fuse cover
1204
FNQ Series
500Vac Time-Delay Supplemental Fuses
Technical Data 1012
15
30
4
5
6
7
10
3-2/10
Amp Rating
100
Amp Rating
1/2
300
1-6/10
2
1
Time-current characteristic curves – average melt
100
10
Time in Seconds
Time in Seconds
10
1
0.1
1
0.1
600
Current in Amps
200
100
0.01
6
Current in Amps
200
100
1
0.6
0.01
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document
are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the
end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue
or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this
bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2016 Eaton
All Rights Reserved
Printed in USA
Publication No. 1012 — BU-SB14286
February 2016
Eaton and Bussmann are valuable trademarks
of Eaton in the U.S. and other countries. You
are not permitted to use the Eaton trademarks
without prior written consent of Eaton.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
CSA is a registered trademark of the Canadian
Standards Group.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“FNQ-4”相匹配的价格&库存,您可以联系我们找货
