Fusetron™ advanced protection time-delay fuses
BUSSMANN
SERIES
23% more energy efficient than the
next leading brand
Product description:
Bussmann series
Fusetron fuses
provide advanced
fuse.
Eaton’s Bussmann™ series
Fusetron™fuses are, on
average, 23% more energy
efficient than the next
leading brand, saving
users money*. The energy
efficient RK5 fuses utilize a
separate overload element to
provide the best time-delay
performance for sizing as
close as 125% of motor Full
Load Amps (FLA).
Fusetron, 225-600 amp
fuses enhance safety with
insulated end caps to reduce
exposure to live parts and
extend air gap distance
between blades of adjacent
mounted fuse or to housing.
* Test results are based on weighted
sales volume of Fusetron and
Ferraz Shawmut (Mersen) fuses by
selected amp and volt rating
combination. Next leading brand
refers to Ferraz Shawmut based
on third-party fuse market share
data for a twenty-seven month
period (July 2008 through
September 2010).
Features and benefits:
Dual-element feature
provides the best
time-delay performance,
allowing closer sizing
and superior protection
of motors and
transformers.
Closer sizing allows for
smaller fuses and less
costly switches.
200kA interrupting rating
allows use in a broad
range of applications.
Most common fuses
are in stock and ready
to ship within 24 hours
with QuikShip Everyday
Service.
Time-delay Fusetron fuses are ideally
suited for protecting motor and
transformer loads.
Fuses Made Simple™ is the easiest and fastest way to select and specify fuses
Four fuse familes in three tiers of protection offer distinct levels of performance benefits to help speed specification and selection:
Ultimate protection
The best worry-free protection in virtually any application. Low-Peak™ (yellow) fuses 50%*
higher interrupting rating than any other similar fuse. Unique dual-element construction delivers
a powerful combination of all performance options in one fuse - fast short-circuit protection,
current limitation, and time-delay performance with up to 300kA interrupting ratings.
Advanced protection
Application specific protection for sensitive devices and critical components or motors and
transformers.
Limitron™ (black) fuses offer 10X better current limitation than basic circuit breakers or fuses**.
Fusetron™ (green) fuses are 23% more energy efficient*** and the best time-delay
performance.
Based on the application, you can choose between fast short-circuit, current limiting performance
of Limitron fuses or energy efficient, current limiting, time-delay performance of Fustron fuses
and still get a 200kA interrupting rating.
Basic protection
General purpose (grey) delivers basic single-element fuse protection for service, feeder and
branch circuit applications. Featuring up to 50kA interrupting ratings.
*50% higher IR (300 kA) than any other UL and CSA Class J, L and R fuses.
**Does not include current limiting circuit breakers or current limiting fuses. Protection determined by comparing published let–through values for Class CC, J, R, and T fuses versus a RMS symmetrical waveform at 200kA.
*** Test results are based on weighted sales volume of Fusetron and Ferraz Shawmut (Mersen) fuses by selected amp and volt rating combination. Next leading brand refers to Ferraz Shawmut based on third-party fuse market
share data for a twenty-seven month period (July 2008 through September 2010).
250V FRN-R Class RK5 dual-element, time-delay fuses
Ratings
Volts
• 250 Vac
• 125 Vdc (1⁄10-60 A, 110-200 A)
• 250 Vdc (225-600 A)
Amps
• 1⁄10 to 600 A
IR
200kA AC
20kA DC
Agency information
UL® Listed, Std. 248-12, Class RK5, Guide JDDZ,
File E4273, CSA® Certified, Class 1422-01, File 53787,
CE
Catalog numbers (amps)
FRN-R-1/10 FRN-R-1-1/2
FRN-R-1/8
FRN-R-1-6/10
FRN-R-15/100 FRN-R-1-8/10
FRN-R-2/10 FRS-R-2
FRN-R-1/4
FRN-R-2-1/4
FRN-R-6
FRN-R-6-1/4
FRN-R-7
FRN-R-7-1/2
FRN-R-8
FRN-R-40
FRN-R-45
FRN-R-50
FRN-R-60
FRN-R-70
FRN-R-200
FRN-R-225
FRN-R-250
FRN-R-300
FRN-R-350
FRN-R-3/10
FRN-R-4/10
FRN-R-1/2
FRN-R-6/10
FRN-R-8/10
FRN-R-1
FRN-R-2-1/2
FRN-R-2-8/10
FRN-R-3
FRN-R-3-2/10
FRN-R-3-1/2
FRN-R-4
FRN-R-9
FRS-R-10
FRN-R-12
FRN-R-15
FRN-R-17-1/2
FRN-R-20
FRN-R-75
FRN-R-80
FRN-R-85
FRN-R-90
FRS-R-100
FRN-R-110
FRN-R-1-1/8
FRN-R-1-1/4
FRN-R-4-1/2
FRN-R-5
FRN-R-25
FRN-R-30
FRN-R-125
FRN-R-150
FRN-R-400
FRN-R-450
FRN-R-500
FRN-R-600
FRN-R-1-4/10 FRN-R-5-6/10
FRN-R-35
FRN-R-175
FRS-R-1/10
FRS-R-1-1/2
FRS-R-1/8
FRS-R-1-6/10
FRS-R-6
FRS-R-6-1/4
FRS-R-40
FRS-R-45
FRS-R-15/100 FRS-R-1-8/10
FRS-R-2/10
FRS-R-2
FRS-R-1/4
FRS-R-2-1/4
FRS-R-7
FRS-R-7-1/2
FRS-R-8
FRS-R-50
FRS-R-60
FRS-R-65
FRS-R-3/10
FRS-R-4/10
FRS-R-1/2
FRS-R-6/10
FRS-R-8/10
FRS-R-1
FRS-R-2-1/2
FRS-R-2-8/10
FRS-R-3
FRS-R-3-2/10
FRS-R-3-1/2
FRS-R-4
FRS-R-9
FRS-R-10
FRS-R-12
FRS-R-15
FRS-R-17-1/2
FRS-R-20
FRS-R-1-1/8
FRS-R-1-1/4
FRS-R-4-1/2
FRS-R-5
FRS-R-25
FRS-R-30
FRS-R-70
FRS-R-75
FRS-R-80
FRS-R-90
FRS-R-100
FRS-R-110
FRS-R-125
Data sheet
No. 1019 (Up to 60 A)
No. 1020 (70-600 A)
600V FRS-R Class RK5 dual-element, time-delay fuses
Ratings
Volts
• 600 Vac
• 300 Vdc (1/10-30 A, 65-600 A)
• 250 Vdc (35-60 A)
Amps
1⁄10 to 600 A
IR
200 kA AC, 20 kA DC
Agency information
UL Listed, Std. 248-12, Class RK5, Guide JDDZ,
File E4273, CSA Certified, Class 1422-02s, File 53787,
CE
FRS-R-1-4/10 FRS-R-5-6/10
FRS-R-35
FRS-R-150
FRS-R-175
FRS-R-200
FRS-R-225
FRS-R-250
FRS-R-300
FRS-R-350
FRS-R-400
FRS-R-450
FRS-R-500
FRS-R-600
Data sheet
• No. 1017 (Up to 60 A)
• No. 1018 (65-600 A)
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
Eaton.com/bussmannseries
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 10117
May 2017
Eaton, Bussmann, Fuses Made Simple,
Fusetron, Limitron and Low-Peak are
valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“FRS-R-20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+636.325272+82.20827
- 5+416.518375+53.81093
- 10+398.1373810+51.43625
