14004-3
14004-3
    EATON(伊顿)
    接线端子 间距P=9.53mm
14004-3 数据手册
Barrier & Dead Front Terminal Blocks Series 14002 & 14004 Barrier Terminal Blocks Inches (Millimeters) Series 14002 A SPECIFICATIONS Ratings: 115A, 600V; UL/CSA Poles: 2 to 6 poles Wire sizes: #2 – #14 CU/#8 AL Operating temperature: 150°C Marking: Marking strip optional, consult factory. Options: CP = Pressure plate, rated 60A, 600V Q = Quick-Connect, rated 50A, 600V To order options, enter letter code in front of Part No.: ie; CP14002-2 Agency approvals: UL E62622; CSA LR15364; CE Pending .87 (22.09) 1.25 (31.75) B .75 (19.05) 1.50 (38.10) .96 (24.38) .37 (9.39) .62 (15.74) .39 (9.90) A* .17 (4.31) dia. holes with .34 (8.63) dia. x .75 (19.05) deep c'bore Part Number A B 14002-2 14002-3 14002-4 14002-5 14002-6 1.75 2.37 3.34 3.96 4.59 – – 1.59 2.21 2.84 Note: “A” dimension for 14002-2 & 14002-3 only. (14002-2 & 14002-3 have only two mounting holes.) 14002-2 Dead Front Terminal Blocks Inches (Millimeters) Series 14004 SPECIFICATIONS Ratings: 90A, 600V; UL/CSA Poles: 2 to 12 poles Wire sizes: #4 – #14 CU/#8AL Operating temperature: 75°C Marking: Marking strip optional, consult factory. Agency approvals: UL E62622; CSA LR15364 .50 (12.70) .65 (16.51) .21 (5.33) dia. holes 1.50 (38.10) .50 (12.70) .18 (4.57) .75 (19.05) B 1.12 (28.44) A 14004-4 Part Number A B 14004-2 14004-3 14004-4 14004-5 14004-6 14004-7 14004-8 14004-9 14004-10 14004-11 14004-12 1.81 2.31 2.81 3.31 3.81 4.31 4.81 5.31 5.81 6.31 6.81 1.43 1.93 2.43 2.93 3.43 3.93 4.93 4.93 5.43 5.93 6.43 BIF document: 1429 25 For complete specification data, call Bussmann Information Fax ~ 314.527.1450
14004-3 价格&库存
很抱歉,暂时无法提供与“14004-3”相匹配的价格&库存,您可以联系我们找货
