851 SERIES
MIL-DTL-26482 Connectors
Overview
851 Series | Introduction
Typical applications............................................ 06
Features & Benefits ........................................... 07
Receptacle range overview ............................... 08
Plug range overview .......................................... 10
Ordering information......................................... 12
Layouts .............................................................. 14
General technical characteristics ....................... 16
Crimp contacts .................................................. 56
Caps / Ordering information.............................. 57
Plastic protective caps........................................ 59
Filler plugs.......................................................... 59
Dummy receptacle............................................. 60
Gasket................................................................ 60
Connector
Technical Information
Environmental connectors.................................. 20
Hermetic connectors.......................................... 43
PC Tail connectors.............................................. 45
Panel cut out...................................................... 46
Backshells / Ordering information...................... 47
Push-pull locking plug........................................ 49
8F51 filter connectors......................................... 51
SNC specific connectors..................................... 52
Tooling................................................................ 64
Stripping instruction........................................... 66
Crimping instruction........................................... 66
Crimp contact insertion...................................... 67
Crimp contact extraction.................................... 67
Cross reference list............................................. 68
Drilling pattern .................................................. 70
Discrimination / Keying methods....................... 76
Contacts & Accessories
Overview
Connector
Contents
3
851 SERIES
© 2016 SOURIAU - SOURIAU is a registered trademark
851 Series
Overview
Typical applications .......................................................................................................... 06
Features & Benefits .......................................................................................................... 07
Range overview ................................................................................................................ 08
Ordering information ....................................................................................................... 12
Layouts ............................................................................................................................. 14
General technical characteristics ...................................................................................... 16
5
851 Series | Overview
Robotics - Machine Tools
Aircraft
© curraheeshutter / Shutterstock
Water Measurement
Oil & Gaz Industries
6
Telecom Military
© dell / Fotolia
© krungchingpixs / Fotolia
Off-Road - Pavers
© JPS / Fotolia
© SOURIAU
© Rainer Plendl / Fotolia
Features & Benefits
MIL-DTL-26482H
Overview
qualified
Fully in accordance with the MIL spec requirements with solder type.
500 Mating Cycles
ROBUSTNESS
Equipped with a coupling ring made from high strength
aluminum. The plug provides a minimum of 500 mating
unmating cycles. The receptacle is equipped with rugged
stainless steel bayonet pins.
Salt Spray 500 Hours
OUTDOOR
USING
Designed to withstand climate ingress and exposure to salt spray or
corrosive atmospheres while still maintaining mechanical, electrical
functionality and RoHS compliance.
1/3 Bayonet Coupling
quick
mating
With only 1/3 twist of the bayonet coupling system, connectors are
mated with audible "click" and tactile feel to confirm proper mating.
These mating features eliminate uncertainty connection and reduce
time and labor during installation.
Arrangements from 2 to 61 contacts
FLEXIBILITY
Power supply and signal transmission can be combined in a
unique interconnect solution to reduce system complexity and
minimize component/installation costs.
7
Receptacle range
Square flange receptacle type 00
with straight adaptor
Square flange receptacle with straight
cable clamp without grommet
Front view
00A/RA
00AC
Page 20
Page 20
sealing gland backshell
sealing gland and cable clamp
Square flange receptacle with removable
straight backshell for heatshrink sleeving
00J
00JC
00M/RM
Page 22
Page 22
Page 23
Cable in line receptacle
Cable in line receptacle with
straight cable clamp without grommet
01A/RA
01AC
Cable in line receptacle type 01
Front view
Page 25
Page 25
Cable in line receptacle with straight
Cable in line receptacle with removable
01J
01JC
01M/RM
Page 27
Page 27
Page 28
Square flange receptacle type 02
Jam nut receptacle type 07
Jam nut receptacle not
accepting backshell
Front view
Front view
07A/07H
not accepting backshell
Jam nut receptacle with removable
straight backshell for screen
termination and heatshrink sleeving
Jam nut receptacle with straight
backshell for potting
02E/02R/02H
07G/RG
07P/RP
Page 32
Page 32
Pages 30, 43 & 45
H: Hermetic version
8
Pages 30, 43 & 45
with backnut
with straight cable clamp
removable straight backshell for screen
00E/R
00EC/RC
00G/RG
Page 21
Page 20
Page 21
straight backshell for potting
removablebackshell and heatshrink sleeving
00P/RP
00T/RT
00T/RT..38/42
Page 23
Page 24
Page 24
with backnut
01E/R
01EC/RC
01G/RG
Page 26
Page 25
Page 26
01P/RP
01T/RT
01T/RT..38/42
Page 28
Page 29
Page 29
Jam nut receptacle with backnut
Solder fixing receptacle for
hermetic version type IH
07AC
07E/R
07EC/RC
Front view
Page 31
Page 31
Page 31
Solder fixing receptacle not
accepting backshell
07T/RT
07T/RT..38/42
IH
Page 33
Page 33
Overview
overview
Page 44
9
Plug range
Plug type 06
Plug with straight adaptor
Plug with straight cable
Front view
06A/RA
06AC
Page 34
Page 34
Plug with straight sealing gland and
cable clamp
Plug with Long Metallic Adaptor
and Plastic Cable Gland
Plug with removable straight
06JC
06L*
06M/RM
Page 36
Page 37
Plug with Short Metallic Adaptor
Plug with straight
Plug with straight for electrical
pitch access
06S*
06T/RT
06Z/RZ
Page 39
Page 39
Page 40
Shielded plug with
straight adaptor
Shielded plug with removable straight
backshell for screen termination and
heatshrink sleeving
heatshrink sleeving
36A/RA
36G/RG
36T/RT..38/42
Page 41
Page 42
Page 42
Page 36
* Available only from size 8 to 16
10
Plug with
backnut
Plug with straight
cable clamp
backshell
06E/R
06EC/RC
06J
Page 35
Page 34
Page 35
Plug with short metallic adaptor
and plastic cable gland with
spiral protector
Plug with long metallic adaptor
spiral protector
Plug with straight backshell
for potting
06NS*
06NL*
06P/RP
Page 37
Page 38
Page 38
Plug with elbow cable
clamp backshell
Plug with elbow backshell
for potting
08EC/RC
08P/RP
Page 40
Page 41
Overview
overview
Plug overmolded
Consult us
11
Environmental connectors / Ordering information
Basic Series
851
00
E
8
3A
P
50
Shell type:
00 square flange receptacle accepting backshells
01 in line receptacle
02 square flange receptacle not accepting backshells
07 jam nut receptacle accepting backshells
06 plug for use with straight backshells
08 plug for use with 90° backshells
36 shielded plug for use with straight backshells
Backshell type:
Solder Crimp
A
RA
straight adaptor
EC
RC
straight cable clamp for solder contacts
EC
RC
90° cable clamp
AC
E
R backnut
G
RG
straight removable backshell for screen termination and heatshrink sleeving
J
straight backshell with sealing gland
JC
straight backshell with sealing gland and cable clamp
L
long metallic adaptor and plastic cable gland - Shell size 08 to 16
M
RM
NL long metallic adaptor and plastic cable gland with spiral protector - Shell size 08 to 16
NS short metallic adaptor and plastic cable gland with spiral protector - Shell size 08 to 16
P
RP
P
RP
90° backshell for potting
S
short metallic adaptor and plastic cable gland - Shell size 08 to 16
T
RT
U
RU
short backshell for screen termination and heatshrink sleeving
Z
RZ
straight adaptor for electrical pich access
Shell size:
8 - 10 - 12 - 14 - 16 - 18 - 20 - 22 - 24
Contacts layout:
see pages 14 & 15
Contact type:
P male
S female
Orientation:
Normal (not included in part number). For others note: W, X, Y, Z - see table page 76
Obligatory suffix
B crimp version without clip for layouts 8-2, 8-3, 8-4, & 12-14, gold plated all over the contact
50 Crimp type contact: Gold plated, all sizes
Solder type contact:
- Size 20, gold plated active area, tin plated termination area, except for layouts 8-2, 8-3, 8-4, & 12-14
- Size 16 and mix layouts (size 20 &16), gold plated all over the contact.
51 solder type contact (only size 20, gold plated all over the contact)
54 black zinc nickel plating (contacts as per suffix 50)
57 black zinc nickel plating (contacts as per suffix 51)
Specification (without specification: olive green cadmium plating)
29 black anodized plating (solder type contacts)
031 black anodized plating (crimp type contacts)
44 nickel plating
66 crimp version: delivered without backshell and conical ring
solder version: delivered without backshell, conical ring and grommet
12
Cadmium
plating
without
specification
Hermetic connectors / Ordering information
Basic Series
851
02H
8
3A
P
50
Shell type:
02H square flange receptacle not accepting backshells
07H jam nut receptacle not accepting backshells
IH solder fixing receptacle not accepting backshells
Shell size:
Overview
Contacts layout:
see pages 14 & 15
Contact type:
P male
Orientation:
Obligatory suffix
50 Gold plating for contacts #20 & #16
Specification (without specification: 02H and 07H yellow cadmium plating, IH nickel plating)
44 02H and 07H nickel plating
PC Tail connectors / Ordering information
Basic Series
851
02E
8
3A
P
5016
Shell type:
02E square flange receptacle not accepting backshells
07A jam nut receptacle not accepting backshells
Shell size:
Contacts layout:
see pages 14 & 15
Contact type:
P male
S female
Orientation:
Specification
5016 olive drab cadmium plating, shouldered PC tail type contact*
5116 olive drab cadmium plating, shouldered PC tail type contact (only size 20, gold plated all over the contact)
5416 black zinc nickel plating*
5716 black zinc nickel plating (only size 20, gold plated all over the contact)
5045 nickel plating, shouldered PC tail type contact*
5145 nickel plating, shouldered PC tail type contact (only size 20, gold plated all over the contact)
50F9 black anodized plating, shouldered PC tail type contact*
51F9 black anodized plating, shouldered PC tail type contact (only size 20, gold plated all over the contact)
50A7 olive drab cadmium plating, not shouldered PC tail type contact (gold plated all over the contact)
50G9 nickel plating, not shouldered PC tail type contact (gold plated all over the contact)
*- Size 20, gold plated active area, tin plated termination area, except for layouts 8-2, 8-3, 8-4, & 12-14 gold plated all over the contact
- Size 16, gold plated all over the contact, same for mix layouts (size 20 &16)
13
Layouts
Shell size
Contact #16 (Ø 1.6 mm)
Contact #20 (Ø 1.0 mm)
8-2
2 contacts
B
AB
AB
8
8-3
8-3A/8-98
3xØ1.0 (#20)
3xØ1.0 (#20)
3 contacts
2xØ1.0 (#20)
8-33
B
C
A
A
B
A
C B A
B
A
FC
D
BC E
BB
A
FB
B EC
D
8-4
■ A
FB
B ▲F G
C A B C ●A D
EC
C B E
D
A
D
C
C
AA
4xØ1.0 (#20)
A
FBG
B
D A D D
EC
EC B C C
FBG
A
C
CCC A
AAA
C A
B
BBB
B
B
AB
C
A
10
AC
B
A
B
B
A
AF
B
B B AA
C B
C
A
E
C
D
B
A
F
E
A
FB
D
EC
12-2
C
B
B
A
AA AA
A
A
A
B
A
E
D
B
A
C
C
A
BA
A
BB BB
B
B
A
A
H
C
E
C A
AJ
A
KB
G
L
L
B
CC CC
C
H
A
DD DD
DP CA P
A
E
K
14
J
H
F
D
B
C
C
K
M
B
M
S J
S N
R
RP
G
H
F
D
E
G E
E
B
B
C
CF
B
A
A
EEA
C
CD A
B
C B A D
BC
DC
C
C CC
C BB BB
B
G C AG B A
12-10
C
C AA BB
D
D
6 contacts
A
A
6xØ1.0 (#20)
C
BC
BC
C B
A▲
AAC
BA
EE
FF
BB
B
D
DC
C
G
A
B
E
A
A
C
A
A G
H
F
D
B
BC
C
F
B
E
C
D
D
A G
H
F
B
EC
D
A
D
A
H
H
BG
C
K
F
HB
GJ
E
A
HB
KC GJ
FD
E
A
KC
B
J
FD E
D
A B
C
CA
B
A
A
D
A
C
D E
J
N
B
B
A C
F
H
D E
D
L M
K J
K
N R
P
F
CA
12-14
10 contacts
A A
EEFEE
E
C
C CC
CB
D
D DD
D
EA H BA ACG FB A
A
D
H
B
GA K GGJ KFC JG
C
B
14 contacts
H
F
H
B E
A
A
C N
E
H
H
G
G K
J
C
FF FFF EE EE
ED
D DD
D
B
B
A
14-18
H
L BM
D E K
JJ JJJ KK KK
C
M
M MM
M YYN YY
Y
SS SS
S CCB CC
R
XX XX
X YZZ ZZZ TT STTTDD DC
LL LLLM
D
D
VV VV
V
A
XW
P
L
T
A
A
BA
Z
W
W
W
W
UU UU
UEE EE
ED
KK KK
K
N
A
A
GVGG
G
HH HH
HG
15 contacts
8xØ1.0 (#20)
4xØ1.6 (#16)
19xØ1.0 (#20)
16-26
14-15
12 contacts
19 contacts
18xØ1.0 (#20)
8 contacts
C
D
RR RR
R
NN NN
Naa Aaaa
14-12
14-19
18 contacts
PP PP
P DD DD
L D
LA
A
K
A
LB
R
P
MD M
M
HG
G GG
G
EEKEE
E
B
BB
KK
FF FFF S
N N M N
W
X NW CX A
G J
E
FJ
S
M
JJ
C NB CC
Y
VR a V P Ya P
H
DP L P A
W
R
L
C
R Z
H
HHZ E
D P DD
G U
RK
RM
U X
FT
SS
V SG T
K
E D
HH HH
H
B
D P
F
A
16-8
■ Solder contact layouts (QPL)
□ Solder contact layouts
+ Solder contact layouts without grommet
▲ Crimp contact layouts
● Hermetic version contact layouts
CC CC
C
JJ JJJ
♦ PC tail contact
layouts
S
N
CA
J
AL
A
L
L
F
A
7xØ1.6 (#16)
D
H
K
B
A
D C
AA
B
B
G
FF G
BB
D
D
C
C
CA B
DC A EEB
12-8
14-7
J
B
BBC
C
B
D C
10-98
AC
7xØ1.0 (#20)
B
B A
A
CA B
C
8 contacts
6 contacts
+ground
H
G
F
A
8xØ1.6 (#16)
C
DE
16
GHH HH
H
FEE EE
E
B
H
F
F
BB
D C
14xØ1.0 (#20)
1xØ1.6 (#16)
16-23
D
UT
U UU
UDDCDD
S
cc cccb
D
U
VV VV
V
EE EE
E
c
A
XX XX
X
A
B
Y
Y
W
WW
W
W
LLMLL
LY ZYY
FF VFFF E
A
N
N
B
B
AA
CB
C
AH
C
A
JJ AJJJHHXH
BRJ
H
J
E
DG R
A
JJK JJJ W
A
AA
FFSU
FFFb E
RT S b T PT AA
KL
K KK
K
G
G GG
GS Fb T
PP
AA
SB A
T
A
S
A
Y
W
AA
BB
C S
C
C
M
M
Y M
YS
Y
SN
B
A U DR
C BS
R
aG N
a
N
U SD UR D BBH
J N Ha
G
B
NN
BB B
HH
S b T
AA
CC
J H
F
G
G A U BB
B
B
G
U
SS bb TT
c
c L
RR d
K K
F
CK
T LR
T
C
A
P AL d
P
C
CC
MR cd
SV
V
X L ZX
X
d Ce
L
L
T Z D T
T Ye D
D
a
CC
N
M
D
Z
U
L
LYY c
A RB A RB A
ANN RBaa A RB U
A
AL M
A
ASS
H
V E
V E
V Ec
M Z M Z
M Z
U DDB
UB
U
R
B
R
H
H
K
K
K
V
V
V
c
B
B
F
C
P
D
P
D
N
D
N
D
f
f
X
XX
X
E GW D
e
W
W
cc
FF
CC
cM
CA
C
Me
M
M
W K
j
U
g
E LU
E
K
K Y WL Y LW UcF E Wj Z Fg TG D
LLM XX
T
T
D
D
Y
WZ MF b
P
P
P
C
C
V
Z
Z
LA
L
M
E
A
L
b B
BK
B V
K
K
A
Vh P
MP
B V E Ah A
JHJ M AA X A
G
GE
P X M
S ZZXC P
S XC VV S EE C
P
A
J H H GJ F H
J
a
Sa
Sa
S
MW
E
D
B
XE E B
J H
J HF
F
N
N VV g N Af
S GJ Y A
SN Jg WC fN
SN
E
TTW AA
bW G N U
bCEE N
XX
DDC X
KJ
KNGK
KJ
N SS AAN
N
D
D
D
L
N
N
N
D
D
FT W C
X BBW
X
WaX
N
B
G
B
UU
SS
EE W
KK W
F
D
D
RR
BB LL YY
A a
C
W
W A
a
S
A
F
F
G
B
b
Z
a GZ R F
H
P
J
H
Z
TbZ
S b YT
A
BT b
HH
R
bZ
BB
F
F
T
UU J
Y FY
J C JL HH CGG YFF C
M J M
F
M
F RR J
HH TY
E
S M EC Y
G
Y
KKKL N
ddW
TT Y WCC KKTYJJW
PP
C
D
S
N E GG
ee
V Y C
XR U a
ZY
X
a VV
aC V JY
a
R
RaZ
AM
C E
H
M
M
M
E B
E
P J DH
U Ddd V
H
P
P BG
M
M
E
KP G
H
J
H
H K P HD c P GN
cc
L K
LD K
d
c
F
CF
G
b UU ZDDb M
ZY b R Z
Y
Y c d US Y b c Td U
c G
C
X
L
T
C
PP
NN
Z
ff
J
ee
W DDZ
XD
H
H
L
TG D
cc
a
G
Z W
Z J
N
Z
a FS
V
M Z CC
U D
D
H
D
HD
F
L
L aVV
L a F
V E H j j hh gg H
M ZEE
V
G LL
GE
R
L
L
L
F
U
U R
U RF
V
XG E
cF
E
D
C MM bb
E
E
W
V
V
U
V
U
U
X
E
D
X
X
V
X
V
V
X
U
F
F
F
L
K
T
D
W F Y
Z
bb
L Y
T
SXX TEE S T
S
U
E
KE W
gg
ff
W NNF
WM Z W
W
V E
L
JJ JJJ AA AA
G
H
F
F
D
D
A
a
a
W
W
J
H
V
E
G
E
G
K
K
G KX
G
K
K
G K
G
G
aa G ZZ
G SS SSSAA AAA
J
F
J
H
TT TTTAA AA
A
EE
D
K
G
LL
FF J K H W J H U
J H
F
F YY FF
F
F
M
K
YY
G M
E
SS SS
S
BB BB
B
J HL YJ H
J H
W
RR RR
R
BB E
BEB
B
F
ZZ
XXJ H
J
ABB BB
HH
HH HH
H
KK JJ
G
B
H
K
K
J
G
G
U
U
U
U
U
H
T
A
S
A
L
L
GG
KK KK
K
J
RR RR
R e Seee
C
PP PP
P dd ddd TT TTT CC CC
C
F
K
G
VV VV
V CC
B CC
dd ded
d
R
B
JJ
HH
H
cc ccc
B
UU UU
U C
U
K
PP PP
P R d eff f ff
DD CDD
D
NN NN
NP
DD DD
D
V WW
eed eee T
W
W
cc ccc jj j jgjg ggg W
G
G GG
G
CC CC
C
LL LLL
bb bbb c
VV U
VV
V
hh hhfh
P
N
J C A
M
M MM
M
EE ED
E
E
e
W
XEE ED
G
NN NN
N bb cbbb
E
EA S
j
g XX XTX
T
A
T
A
S
A
A
S
A
g
g
g
g
g
f
f
f
f
f
L DD SDD
FF FFF
D
aa abaa
W
W WW
WV
S
B
B
R BB
B
R
B
aa aaaZZh ZZZS R X
J
MLL
A
LL L
FF FFF E
H
M
MN
MM
M
YY YY
YFF FFF E
b
BU
EE EE
ER
JJ
AA
YYgYY
Y
U
TC T A
A
d
T
C V
C
R P e dUP VT Sd C
P f
CS
TT
AA
SS AA
F
e RK d eL
V
BC L
d D
H
A
AKK KKKZaZ ZZZ XX XXXGG GW
R
B
KJJ aJJJHHdZHH
G
G F
SS
BB
LL LKK
LL KK
G
G cGY
G
G F c LU
BB
L
H
M
B
E
U d AH
Y c
U AU
WRR A
L
A
W A B
A
A BB
P
P K
D WB D
P N
Nf eR d W
DC
U
HX
R RR A
B U
R D TH B C KK
R
B
V PP
VC
f
f K
e e D D KV
e P
W
dd B RTT
BJJ JJZJ NHH HH
CC
CC B
G c
C
K
V
K
G
j cg
j M
VV
J c H Gj
g
g
dd ee
L
M
cV
M
U
C
U
Lh
b
b
VM
V
X U
h
hPK
P
C
C
cX
c P
JM bH
UU
D
N
D
B
B
f
K
j
Y
j
Y
M
M
E
E
E
e
W
U
X
X
X
c
Gb
P
N
E
EC
N
b N
b
P X ANGGS
CA
P ff X A W
SW DD
C
ee a D A D
SD
N
A PaN
T T i NNA T B A
T
cc AS N
g
f Wg j Ef Jg N S
N g NfAN
N CC
SD
N
Z
i
j j gg
W
T
L NJ
B
B
b
V
C
C
A
Ja
F
a
a
W
W
a
W
D
N
D
h
i
N
D
D
X
J
Z a
Z
Z
a
LX
k m Z
A
bb kN
VV
S
A LE
hhP
T
LN Y
FA EB
L
sT
B
B
P
P
MYM W B
M Fg Y
M
ME
Y
F Y
F
M L
Yb YF FS T X
A
T
AM
S
A
T
M
M
M
B
B
B
S
S
S
M
M
E
E
Z
T
Z
T
b
b
R
b
R
R
X
X
C
C
C
b
b
f
RJ P W T
B R
S
S Sh Ba
Y
NN
EET
bb W
U
ZJ
X
S
BLL Z P AA X a P
C
h
D
r
r
B
g U ff a E U
h S
H
HX Z
J
Z G URC
KHF J H P
A
a
FF
DD
Y
K
K
G P
W
W
J M
Vgm
V
V E
ML
M
E
P
HB
L K H JL R
L KBK
T
G
tU S n A
V Ga GRa d H
F E CY
ZZ E
aa
P
LL
T d
rf
A
A
E G DK
R BB d R LL aad
M
MR
YR dV
e YP FV R C e D UL V
K
T
WCLJ
RL
D RR AA S BBR
dA B FFc D U
Z CREE P C d
Z FF C
f R
RR AA
J
R
Yc L dM
hM
S acCc hSUb c CYY S
YY D
KK
H JK
H
HW
d
BB ZbCW
L C a Lh a
RR g V
R g
H
c X
eq SZZnYe
Xb
X Fe
g
bq
U c
K N
J
q
p
Z
M
M
H
a H G
M
M
G
U
D
D
k
c P
c RKK Pkf e W
c U kf VGGW C f
WPP
R
fD
H L P Zc
D
F
e
K HHa GG B
ge d
T
LL KK JJj T
P
ZD g Z
NF
G
f
J
G
E
X
W DX L
Rj G g P Wc E
R e KK
L j BB gd Z j T
F E aa
c E
U
H XUU
dp LJJ
eCCf mP
E
G C
C
m
gdV V F d UT
PP XX
SS PCC f
j
h
cf W
S
S
V
g
P
P
P
L
H
H
X
X
V
b
V
G
F
F
P
V
V
S
V
S
S
h
N
N
S
S
c
N
N
W
W
i
i
i
L
T
S
C D
bS DE
JK
J
K
K CM
DT
H
NN
h
P NDD e L d
W D
X
K V YEXX K Y K K YU
DgG NN
j DDPe c gj d KX f H gj W W
E
b E
N
GN
Gf M
E
n Ne
X
K
K GU D
G
UC GD
g
N
E
b
N
X F
X ZF
j
Z
TdT N
gF
bb
F
D
g JJf
W
W
YY b TN
T Mb N Jb
f
eCC f J H
e f Le
F
Z
a
l b d K Nlj J Md
F
D
J H
H
W aa
U
T U L TJa U
T F W a
N
Z
hE L K h h J H
hX
M
Y
F a
MNM
RR F J PP
E
JE
EY X L E F
M
M
E
X V
V
F X YY
PPX V
E M
M
E
HH J Y
DD
Y VV
Z
Y
ab M G a
Y
fY
A
LL LLL AA AA
M ZZ a MN
bb
GY M
GYY AAddAAA cc UUc EE a k c g
H
Z
X
J
JW
J WE F WE
D E
K
GK
J
H AA AA
L K
Z
a
G L K
AA aA
A
A
GAA AA
W
W
W
W
W
LL LLL
J
A
W
W
W
W
W
B
B
B
B
B
A
AA AA
A
Z
Z
M
M
M
a
H
H
F
H
F
F
G
L
Z
Z
Z
M
Y
F
E
R
R RR
R
H
H
RR RR
R
BBGBB
BEE
V
JG
FF L
BB BB
Y
LLVV VV
H
KK KK
K
B
LB
H L
H
H
ABB BB
L
G
G
G
J
CC CC
C
VVLLVV
V
HBB BBBRR DDH F
H F
F
Fb
F
H UU
a Z bZ X
M
M MM
M
A BVV
VV
UC
U CC
M MM
M A
UU UU
U
CK
X
K L
LM
G
G
W
XXWXX
X A C
JL KK J J KH G J
AFF B
XX
X XX
X
PP PP
P R TT A SS B
CCGCC
C
LD
G
BB BB
B
R
KK KK
K
jj Vj jj YY YY
Y B
W
W YY
YY
Y DDC D
D
UU UU
U Vjj j jj
K
B
J
PP PP
PXX XX
X SS SS
SCC CC
C
G SS SS
aa aG
aa
SEE
KK
G
G K
GDD
TT TTT U KK
DDG
D
K
H H
M NN NN
N
SS SS
S
N
MNN NN
FF FFF
GB
12-4
A
G
C B A
C
A
FF
A
B
B
CD
C
E
A
R RR
R
N
NN
N
LN
L
AR
A
A
B
L A
KP PP
AL FA A E CHD
A
H
A
MA A
BA
M
A
B
CK AB A BB
M
B
K JM P
K
N P B RF
N
PC A
P
A
BA
B
KA
F B F
G
G
AA
A A BB PN A
G
G H
E
BA
B
HH AA BB
A
G NK
J NC B N
M
MA
FAB
B
B
B
B
C
A
C AN
C
C J
PB
B
HF
G
B
E
E
L
N
P
C
J
T A
T
C
U
P
A
B BRE N
AA ECL H L RH
AA
D
D
S
HB
R b NT CLSC
RC
RU DP E C
b T SP b CT
J
J C
L
J
J
H
H
M
M
M
C
C
C
M
M
M
M
K
M
K
Y
Y
Y
P
P
S
S
S
G KL J
C
F
B
C
C
B
BB
B
B
a UH
a
N
N
LF
E
EC C C B
E
G
GK KKU JJV CCR D
B
E F DHE
D HC
F
E
D
R
R B
H
D Ea
S
K NU D V U R D D U D HFF S
H
D K
D
K
K
D
C
D
C
L Mc
J
c
c
F
C HJ
C J
D
D
DC F
AA X
RLZF XF T LEZD X CDT Z D
LL
CF
B FC
B
AA
NC FF ND LR
LE
L AAV E
C
C Z B DJVBM
B ETZ S
BBG V F ETNHHD AA M J RH
D
C
D
CE
V E
Z KM
EE F ECC
G
F
F J EET DDS E
G
A
A
A
V
V
D
B
E
D
E
D
M
M
F
F
B
B
K
K
P
P
P
N
N
G
G
E
E
G
A
A
H W
B GG H A BBB
E
DE
DE
D
R XH
K
BB
DD
FK X
H
F
N
W
AXL YW
U
U
E
E
K
K UW EK
A
B
A
C
L Y
EE A
BB
FL CY
MW F
GWA F M
G
A
B
A
C
A
BBH
G
G
G
EE H
G
JJ TT UU PP CC
J PH F J
J RR
H
H NN C
JJ
F
J FH G JK FH J
JH
J
K
KG
KG
G
CFGM
F
B F J H
M
PP
J
C
B
A CCH
B LKL KKA
C
A RR DD
D E
HH SS
HKK
L DM E
D
D
CC
L M
C
B
B
F
E
C
H
H
D
D
C
B
B
F
E
D FF F
C
K
E CCD
CCE
J
F
F
D DD
G
G
E
E
K
FF FFF AA AA
A
J
EE DD
R
LL D
LLL
G
G FF EE R
AA AA
A
N
LL LLLAA AA
A
C
B
N B
E
HH HH
HAA AA
A
M
M MM
MAA AA
ABB BB
B
AA AA
A
ML
MM
MNN NN
BB
B
KK KK
KM
P
NBB
F
A
D
P
KK KK
K L B
B BB
B
A
G
G
G
G
G
B
B
B
B
B
A
EE EE
E
B
H
A
M
M MM
M
A BB BB
BB BB
B
EE EE
E
LL LLLNNMNN
N PPAPP
PCCBCC
C
JJ JJJTTKTTTUUMUU
C
UPPNPP
PCCB CC
RNN NN
N BC
K RR
JJ JJJ
GMM
JJ JJJ RR
M
M
M KK KK
K B
E
B
PP PM
P
P CC CC
LL LLL
B
E
RDDPDD
S RRURR
KK KK
KUULUU
UVVNVV
VRRPRR
RDDCDD
D
HHJ HH
HSSTSS
D C
R
N
J
DD DD
D CC CC
C
J
C
K CC
P DD DD
HH HH
H L
F
AF
A
F
A
FF FFF M L CC
C
L
L
A DL AA
A
L A LH A A
DD DD
D CCHCC
C A H
JJKJJJ TTUTTT SSVSS
SEEREE
E D
G
GHGG
GFFSFFFEEREE
E D
D
C
A
EE EE
EDD DD
D A
FG
FMFE
FF
A
M
AKM BM A N B B
A
B
A
G
G
EKE
E MDB N
B
K
NE
HAGG
F
A
F
HH HH
H FF FFFM
A
K
KG B C
B B
K
A
B
B
P
P BA L
A
A
DG
CG
A
B
AAL
BA
LL
J G
E
F
G
E FF
E
B
GTGG
G S
H
A
M
M
LL AA
F TE PANJUMC P A C B
MAA A
B
A
B
B
B N
KC M
N CB
B RE ND R JN
E
E
E J
L
N J L PT N CU PA P
LF N
P HH C
TAG J U
C
H
A JBJ
C
AA
R
N KC
B
M NN
J
KK M
G
B
G
B
T
A
T
A
T
A
S
A
S
A
S
A
G
J
J
C
C
J
S
T
S
T
R
KK
BB
b
M
KM
K
MP
K
E
B
PEE R
G
G
BB R B
MCBB
S
S B
S Bb
B
RG
B
C P
L
LE
L
M
M
Y
Y
B S
S
M
M
L R D
NB
P
C
J
T
C
U
P
R
R
R
S
S
S
K
U
K
V
U
R
V
D
R
D
K
U
V
R
HH
H
HUEE
a
N
N Ua D
H
D
B
JN
BKH D D BK JD R
B
U
D
C
UB
JJ
TT UU
H
H
C R
RR NN
K
d P JJT d P
R
RC Ve
C VU
C
P
C T d C T
C
P
J
J
C
C
H
HF D
DC C M L K
H
D
d e
d Ve
d
c
c
F
C
F
F
F
C
C
M
KK
PP
X
L
LGE XF
R
T
D
D
KM LLE
U
HE S
D
CD
C
D
C
D
Z A T
Z
c
c U V cR U D
J
T
J
S
T
E
S
J
T
S
F
F
G
G
E
E
U
D
C
RR
A
A
F
S
S
H
H
V EG F ED
E
D E
D
M Z
D
G FF EG AEF ED F
N eD
D
D
CC
f ZD
eD
Wf DL V W E A
LD PA PPc H AAPj f FLcgH AMPW
V
LNAA H A NF e
G
G
C
CV H
C
j F cg
j
H C GAX
E
D
E
D
HH
DD
FF
DK
C
AV B
A
Jb T VCCMS
E
AL
W
F g WM
G X hK
E F N
L KH W
B KAA M b BB G
U
U
b
VM
G h
G
E
DD Lh Y CC
A
B
A
E GL
D Y L
B
G
G FF
N CM
G FEK E NN
F FE A
BW F
M
E
E
CBEE D
K BB b NXB Eb J X H E
D
X
HM
G
G
G
G FF EE
G
G
H
EAA
bR N
E
B E
J BBH G
SS bb TT
MN
R
g
f
gL
fN g P f C
JD H B D F
B E J
F B
H
A
M
K
K
G
G
G
F
F
D
F
J
T
C
U
P
a
a
W
a
W
W
C
C
A
M
M
Y
Y
R
N
B
S R Z Na
Z
Z
J
a
E
L
P
C
J
T L U UUP LDDC
N
J
C J aSM
J E
L YF
FN
M HHE K
YM C
F
Y
F
Y
FN aa
G
B
E
P M
Y
YF
B
P
L
Z
X Z
X Z
cc
FF
CC M L K
R
VG R
H E HS
DH
BXK DGU
HD
HK
K
D
C
LL XX
T
S K R
V
R
D
JT L D
D KE K G UK
LZZ K
J
G J L
G J
G
D
C
VV
H
DVV H
M
M ZZ
F
C F
M
K
J EE H J
J
D
C
L
D
C
J HT
S HE J
F
XX F
EEE
G
E
D
C
AA AA
A
T
S
E
W
DDD
D
CLL YY G
UU
GKK F W
EE
E
W
W E FF
E
D
F
A
A
A
A
A
G
H
F
E
PP PP
PAA AA
A
F
C
AA AA
A
BB BB
B
H
F
GG
JJ
HH
G
JJ HH
D
C
A
FF
KK
GG
G
NN NN
N
BB BB
B
AA AA
A
C
E
D
A TTT CC CC
G
G GG
G
BB BB
B
SS S
S bTb
Tb
AbS
B
RRPRR
R A
b
A
5xØ1.6 (#16)
A
A
B
3 contacts
+ground
14-5
14
C
AA
F
CA B
D
D C
AA
10-7
A
A
F E CB AF EB B F
C
C BB AA
7 contacts
AC
C
AB
6xØ1.0 (#20)G A
5 contacts
E
A
A
F G
B
F
B
A
ACD A DD C CAA BC A B AE F D B
BCC
B BC BC
E
CB
E
A
D
C
A
D D C BC
B
B
3 contacts
2xØ1.6 (#16)
BB BB
B
B
A
12-3
2 contacts
12
A
10-6
AAAB
C
CCA
C
BBB
CB A BAB
6 contacts
A
C B A
BC
B
A
A AA
A
A
A AA
A
G
G AB
A
FF FG
F
FGG
B BB
B
G
F
F
F
F
F
B
B
B
B
B
E
E
E
E
E
FD
DDD
D B
F
A F
AF
A
BL
AL
AL
A
G
A
G
AB
E
E EE
E
C
CCC
C
L A
B
H A
B
H L A A BL A
ED
H
A
H
A
A
D
B KN MB N
B
A H A C
A K M KNC M
DDD
C
D
CFCC
C B
A
A
C
A A
C A A A
A
K
KB
KB
B
G
G
B
EA
C
H
H BF G B
A A
A
F
E
E B
E B
B
M
M
M
B
D C
G
C B
G R
K NJ RC N R N
F
B E
F J
E
E K BJ
J
JU TPH JUC TP UC P
T
C
JB
JH
G
E
E
D
D
J
J
C
J
C
C
A
A
F
B
M
KM
KM
P
P
P
L LMA
L M
A
AK
AA
L
L
A
A
R
R
R
C
B
C
B
B
B
S
S
S
H
H
H
D
D
D K
EC D
CC
E
C
D
C D
FE BF D B F G
F
B
E
F
E
D G
F
E
D
BE
B
K
H D
H D
D J
JFD CK F C
BB
D F
F
BBD
FFC G
BB F
G
GC AA H
R
RE
E
C
CD
CD
A
A
H
H
B
B
N
N
F
F
F
G
G
G
E
E
F
B
E
D
AA
G F E G F E G F E
D
BB
EE FF
AA
BB
AA
C
C
AA E D E PD E
D C D C
D C
CC
P
D
D
HH
C
E
C
FF
EE
C
C
EE
C
C
G
G KK JJ CC
FF
BB
D 8xØ1.0
C A
D 3xØ1.6
HH
A
D
DC
C
(#16)A
(#20) A
10xØ1.0
(#20)
14xØ1.0 (#20)
DD EE
D
D
A
A
LL M
M
G
C
C
BB
BB
EE
CC A
F
B
F4xØ1.6
B (#16)
FF EE DD A
F
B
F G
B
K
K
JJ
A
DD
R
R
F
B
E
N
N
F
B
D
E
B
F G
B
BB BB
B F
D
G
G GG
G AA AA
A
E
C
E
C
P
P
A BB BB
H
H HH
HAA AA
B
C
AA AA
A
F
B
E
AE D C
C
CDCC
C AA AA
AA AA
AE
D HH
CHHH A
C CC
C
B C
D
G
D▲
C
FF FFF E
H A
B
C▲
E
C
A
G
G GG
GKK KK
K JJ JJJ C
C CC
C
FF FFF
BB BB
B
A
C
A
CD
H
H
HH
H
D C
E
E EE
E F
D
D DD
D
H
LL LL
LM MM
M
M
A
A AA
A
FF FF
F AB
B BB
B
F
B
E
E EE
E
C
CCC
C
D
D
D
D
D
B
EA
C
A A
DG
G
F
F BF
B B
F
D
D
E
EC E C C
D
E
B
D
C
A
AAA
D
DDD
B
BB
C
C
BCC
A
D
BC
C
CCCB
A
AAA
BBB
C B A
●E
AA
BB
B
BBB A
AAA
B A
●AD AD CD A BC A BC A B
A
B AC B AC B A B C♦ B C B C
4 contacts
3xØ1.0 (#20)
A
3 contacts
A
AC A C A C ▲
B
B
B C
3 contacts
A
Mixed power
A
B
a
N
M
M MM
M
ZZ ZZZ
26 contacts
23 contacts
26xØ1.0 (#20)
22xØ1.0 (#20)
1xØ1.6 (#16)
Other layouts, please consult us
ii i ii
ZZ ZZZ C
W
WW
W
WXX XX
J
X HHZZ ZZZ
NN NN
N
DD DD
D
ii i ii
FF
NN NN
N P
DDCDD
D
X
kjk JkJkX
k HHY
B
K
Y
TT TTT U ss sjkssk kJJkkm
EEDEE
E
m mm
m
ZZ ZZZ abb bbb S
TT TTT
DE
SS SS
ShhT hhh rri r rr m
W
WW
W
WP YYXYY
Y S TT TCTT D
N
JJ JJJ
W
C
aaZaaa
N
maa ZaaaEE EE
hh hhh i
N
D
X Y CC CC
k
km mm
M
M MM
M
EE EE
E
VV VV
V aa aaa YY YY
A
SS SS
ST
FF FE
FFB
PP PP
P
rr r rr tst t tt nn nm
nn
M
M MM
M
E EE
E A W
Z
TE
A
WWa AA
L
W
B A B
S
E BW
Wbb bbb YZZ ZZZR R
TA AB R B A
J
YY YY
Ydd ddd cbc cccR
UU UV
U
UAW BV
h
B
RC A RB A
B
Vm
a
B
B
r
R
R
R
R
R
g
g
g
g
g
b
b
b
b
b
F
F
F
F
F
h
C
C
C
g
g
g
g
g
b
b
b
b
b
a
V
V
V
q
q
q
q
q
nn nnn
qqr qqqpp t ppp n
ZZ ZZZ Y DD DP
M
aa aaa
SR
M
UE
U
C
C
CW
RR R
R
HH HH
HV
D
D
FF FP
FFE
A
LL LLL
L
G
GX GG
GF W A B
XA
X
AC LL B C AA LL M
A
d P cU U
P
b
Z
R
LLL Y
FF j FFFX R
LL Y B
UU UU
U
B
R
pp ppp cc cjcc jbU X
K RR RR
AA
Yj C
Y VjY X R
Y
F
D Y BAA D BB
D RR
VV VV
V
UX a S
XX XX
X
VV VV
Va
V
PS X C S
C
CS
ffg f ff qU cpc cjcc b
G GG
GU
PPRPP
Pff g f ff qT Ui n G
a KK S
BB
aUUPUU
D R
S
S W P DNX N
i T PS i
ZD D M
Z CD
eLeedLdLLddid HH HH
A D
A ee eee dd ddd i
H
PPR PA
P
P ee L
H TT TTT SSZ S
F
W
WW
W
WT
L
NM D AN B D A
N B AK
X
D TD M
i Z ZX Y Z C
Z
M
M
k G
k
T NN NN
LK KK
N f B Tp
cH
G
GU
GG
G
EEN EE
ER X K
K XN
G
G GG
G Fk
HH H
KK KK
K V N N G
G GG
GN
THks G k msj k m
E
E U NN NN
U
Bf T
B
JJ JcsJJ U m j PP E Y
P X
S
C
N
Z V Sb
TaKK
SE
FF FT
FF
T
SHH
E B
S
S W
B
Y
W
H
M MM
M
XX Z a
SS DT CC
JJ dJhJJr
J
A P M
i a PPE
eAKKLhKK
M W bCYTXMP N TR B
JJ JH
JH
J HW
H
H Z YN bZ T STb SS M T b DNN P C R BJJ JJJHHW
SN
H
eKK
PT M
h
h
aW
aT N
hK
M MM
M
K
d
a
a k aa
C
r
r
m
m
m
L
L
L
L
L
K
K
i
h
N
D
C
W
k
U
U
V
a
C
C
N
JJ
G
K
G
K M M
G
P E
B
B r J Tt
SXXT
M
E
t rNNn t
V E M Y
SrH
FS
FE n SDD WNUS
P
n
n NNs F m
Md ZW cd YE dcE T E V
M
d
V S
bE
F
d
cZ U
U
S
H
M
b
Z
b
Z
b
J
J
J
J
H
Y
Y
U
U
Y
ZZ
R
R
C
h
M
K
A
L
R
R g Rq g
bR nF Af b F
h
W
YYb aA m RTT p f
JJq
VC e C R LgK D g q
C
C
gn p rbq W
bFp m
b
a a L ha LYcW P SA C
aAe hE c D S
n
X Vg D Cq
W
L
L
C
q
p
Z
R
M
a
a
t Wn
V
A
a
a
S
W
L
A
Y
Y
r
A
A
R
B
M
E
B
VG
R
HL
D
F
F
F RRR
L
L
M
M
P
dVV
k G B AA V EE q g R B
Y
kFZ
M
M VG dd
f BWR f
Y
W
L V
L UP bHHc
FPf
LB
D
DR
cF
c U Acg PPk R
KB
BU
p Lc P
p g fc qc U
b ZZ F e
Z RV Ug Z j U M
bc
V
XT
gc
X
XAV Z a ZVA
X f P pVf
j
f
G bn
e m G
PN
P
E fR A
A
qYY p
z U C BBm X r
g
dE T
M
M
PP G
C
A
h W
h CW
T
SH
E e DR d
N WA
eB L HLd Pj aXa HAYP
eA
D
W
NN BZ AA LZ W
V Rd D
CP e TT ePd
UH Rj
d eHH
d ZZ
i
L d B
L
KK
D
KBS
Y P
P X iS FC
FFj
L
F PDD
E
A
FB
D
EC
A
B
C
D
F G
B
BD
E
C
D C
F
E
F
E
CC
AB
C
A
CC BB AA
A
AC
Layouts
C
B
B
A
A
A
B
E
B
FF
C
C
D
G
FF
EE
Shell size
AA
BB
FC
C
DD
A
E
D
G
E
B
B
D
F
H
F
E
D
E
A
B
B
C
F
C
J
L
M
G
M
C
C
S
H
T
Z
V
E
W
J H
K
B
B
R
Y
FX
L
A
C
D
U
G
D
E
EE
DD
BB
BB
EE
DD
C
R
P
G
d
c
b
F
M
AA
GG
BB
HH
FF
X
DZ
H
J
E
Y
F
G
LL
KK
C
S
J
D
H
HH
aP
G
BB
B
T
Z
E
Y
D
S
F
XX
WW
J J HH
CC
TT
ZZ
VV
DD
L
K
P
R
J
V
D
H
E
TT
SS
RR
NN
MM
C
D
T
cc
jj
bb
AA
UU
dd ee
A
CC
XX
W
22
A
w
k
L
g
z
h
K
E
f
y
i
X
J
W
D
e
x
j
C
d
KK
B
Y
B
c
AA
S Bb
G
A
A
P H
F
BB
C
C
C
T
C
AT
P
a
N
F
DA
H
M
A
B
B E
J
B
H
KK
JJ
a
u
b
GG v
c
B
d
P
D X
C
BB
E
C
F
G
AA
EE
D
D
J
E
G F E
B
C
C
T G
HS FAE E
H
F
G
B
G
J
M
K
L
BB
EE
GG
T
S
AA
R
HH
d
D
J
A
U
e
P
BB
BC
C
V
D
D
A
C
C
BB H
HH AA
RA
B
P
D
AA
H
H
FF
A
C
N A
B
G
G
EE
B
A
H
G BB K
A
K
H
H
G
G
M
M
U
BB K
BF
H
M G
N
C
P
R
J
R
R
A
E
F
20-24
B
K
C
AAL
AA
BB
AA F
CC
D
SS bb TT
E
aa
D
UU D
A
cc
B
VV EE
MM ZZ
XX
R LL YCY
WW FF
J J HH
KK
GG
GNN
MM
Z
Y
t
a
u
GG v
A
b
LL
c
B
cc
aa
gg
RR
EE
HH
GG
KK
aa
ZZ
s
XX
HH
ee
GG
SS
dd
WW
EEC D
D
J
N
T
B
M
M
PP
H
L M
H
L M
D E
R
R
K
PJ
N
K
P
R
P
K
R
P
C
C
FF
A
JJ A KK
N
N
H
H
LL M
M
B
R
R
Mixed power
A
S b
a
N
M
L
D
U
V
X
Y
W
E
F
18-30
J
K
F
C
P
TP
c
Z
A
E
BB
D
D EE
H
G
30 contacts
B
29xØ1.0 (#20)
1xØ1.6 (#16)
N
N
R
U
U
e N
C
e
V
b
Mf
W D
j
g
g
f
B
h a
X Y E
C TC RNACS b A LB
Z
X
a
U
U
KZ
C Y
F
e P D Md D T
J
H
H
K
V c V
UJ
N BE
D G
ELe
f
W b W
V
E
F
YM F
g
f
X
W
G a G
L
F
Y
H
Z
X
K
G
J
H
P
B
A
d
W
d
P
D
V
c
F
C
HW
X
E
F
G
EH
J
D
VA
f
FY
Z
K
B
G
g
a
L
C
U
e
b
M
A
T
c
N
E
G
K
C
D
25xØ1.0 (#20)
F
N
DD
EE
M
h
b
X
Z
a
NNE
Y
hh
bb
b
20-27
XX
ZZ
aa
FM
M
M
EE
YY
HH
G
G
L
FF
V
g
a
f
Y
AZ
bb
M
E
M
W
VV
gg
aa
F LL
N
A
L K
H
J
N LL KKA JJ
TK
X
27 contacts
G
ff
YY
ZZ
N
W
W
XX
A
27xØ1.0 (#20)
UU
VV
ff
ZZ
KK
YY
JJ
C
WW
XX
DD
G
G
FF
EE
EE
H
Z
U
G
FF
T
S
F
D
H
H
Y
X
t
TT
G
G
FF
SS
R
R
D
D
20-41
EE
FF
41 contacts
a
L
V
EE
K
22-32
b
c
GG v
B
J
HK
L
a
Y
aa
LLF
G
VV
32 contacts
P
JJ HH
KK
GG
WW
VV
FF
TT
CC
UU DD
EE
A
ZZ
AA
S PP f f N
C
GG
ee
dd
NN
HH
MP
M LLKK JJ
R
D
J
GG
H
22-36
G
E
F
a
u
GG v
b
c
B
R
AAP
a AZ
U
T
L K
U
UN
M
ff h
EE
w
W
W
N
Y
L
F
Y
Z
a
gg
L
22-55
H
T
F
A
U
B
V
BB
CR
R
G
55 contacts
C JJ
MMP KK
Z
U
T
S
F
c
R
Y
Z
J
nn
cc
pp
G
G
ee
dd
H
H
M
M LL KK JJ
SS
RR
PP ee mm
NN
MM
dd
ll
cc
LL
AA
TT
ff
UU
gg
nn
kk
VV
UU
TT
▲N
M
CC
hh WW DD
jj
XX
YY
bb
aa
ZZ
KK
JJ
HH
EE
FF
A
P
W
L
R
mm
zz
yy
ii
MM h h
xx
gg
LL
D
T
kk
jj
NN
C
S
U
J
PP
B
X
V
K
GG
SS
RR
E
nn
pp
AA
AA
GG
GG
FF
FF
ww
BB
BB
HH
HH
EE
EE
vv
BB
WW
qq
CC
CC
DD
DD
uu
CC
XX
rr
ss
tt
DD
YY
EE
M
ZZ
aa
bb
cc
HH
dd
ff
JJ
KK e e
L
GG
FF
Z
K
SS
H
m
m
ll
bb
KK
U
U
gg
nn
kk
D
A
U
AA
TT
ff
T
BB
VV
jj
aa
ZZ
JJ
N
H
H
S
C
C
hh W
W
M
XX
R
D
D
P
EE
N
A
YY R
FF
G
GP
X
W
M h
C L
Y
T
Z
a
V
n
A
●b P R B
a♦ h
c
S
X
j
H
f
d
e
W
G
AA
z
BB
GG
HH
FF
x
EE
w
g
D
f
UU AA
BB
TT
C
VV
SS
nn
W
W
m
X RR
pp
X
D m
q
qq
Y kk
AA
AA
rP
zz
BB
BB
P
E
CC
CC
CC
Zj j
GG
GG
y
y
s
s
HH
HH
NN
F
ai i
FF
FF
DD
DD
DD
xx
t
t
EE
EE
u
ww
uuR
bM
M Ghh
vvP
gg
c
c
H
d
dd a
LL
ff
N
J
JJ
K
K ee
B
v
K e
Z
E
M
T
U
V
F
E
S
C
D
R
A
T
c
N
b
i
j
h
a
M
L
D
f
W
g
X
Y
Z
K
C
V
e
k
P
B
U
d
J
E
F
G
H
61xØ1.0 (#20)
A
Z
24
Y
X
W
V
U
T
t
s
FF
r
a
u
b
GG v
NN
PP
c
w
HH
JJ
B
C
d
x
y
D
e
f
E
EE
MM
F
KK
g
LL
DD
z
G
CC
AA
h
BB
S
H
n
i
m
j
R
J
M k
P
K
N
L
q
p
15
d
X
K
G
H
Y
L
61 contacts
tt
e L
M
W
p
F
U
J
m
y
i
B
V
K
k
j
S
b
L
E
g
f
N
G
▲N
Y
J
F
G
AA
VV
P
F
55xØ1.0 (#20)
BB
q
R
E
W
X
ff
N
N
D
V
f
GPP
H
C
U
e
g
a
c
B
J
E
b
NNY
a
V
A d
L KT
d
D
hh
J
n
p
e
S
M
b
K
GC
G
g CC
g
c
ee
EE v
h W
PP D
H
d
YY
DD
f
n
XX FFK e
i Ji d
d
kk mm ZZj E
TT N
EX dE
N
N
ss l
YY
G
G SLS hh rArc t t knn aa Y
cc
FF
M
M
MF
ZZ
M
H
H
gg
b
qqbB ppa bZ
K
RR
GG
JJ
L
G
LL
W
cc
f fN
X
K
H
ee LL ddJ
HH
PP
ii
f
NR
P
M
t
u
P
G
G
E
s
DD
FF
VV
H
H
D
■R S Af A
WW
VV
XX
P e m
UU♦ j j
HH
FF
D
D
x
W
W
JJ
X
r
CC
XX
KK
W
X
q
BB
GG
yC
C
iV
V
ee
W
p
AA
z
B
H
VJ
m
k
B
jB
g
h
LF
L
AA
TT aa bbBB
YY
BB
SS
cc CC CC
UUvv
XX C uu GG
GG
VV dd
t
RdR tt dd
DD DD
W
W
w W
ww
D
eeHH
HH
HH
s
sse
ee
kk
f f WW
xx
Px cc FF
FF NN
FF
NN
V
VV
JJ P
JJ
JJ
EE EE
E NN
r
rr f
i PP
iPP
ff
PP
gg XXyy
y bEE j j
U
EE
MM
MM
F MM
KKUUNN bEE
KK
KK
FF FF
gg
q
qq g DD
LL
LL
DD
DD hhLL
z
z
z
T
TT MM
YAA
Y
GaaCC
GG GG
CC
AA
CC
AA
p
h pp
hh
BB
BB
ZZBB
S
SS LHL
HH
HHii
n
nn
i
Km
K
JJ jj
m
j
m
R
J RR
JJ
M k
M
M kk
P
PP
K
KK
N
NN
L
LL
X
M
f
j
b
34xØ1.0 (#20)
S
n
VV
JJ HH
c
N
34 contacts
XX
X
V
TW A
KS
BG
J UH
C
V
d e
R
22-34
B
32xØ1.0 (#20)
UU
L
G
G
JJ H
H
C
b
FF
U
U
KK
B
A
Z
G
C
d
UA
J
H
A
a
u
ZZ
U
U
Z
GG
HH
R
E
AA
aa bb
BB
uu
cc
CC
GG
GGv v
dd
ww
DD
HH
HH
ee
xx
FF
FF NN
NN
VV
JJJJ
EE
rr
ff
PP
PP
yy
UU
EE
EE MM
MM
FF
KK
KK
gg
qq DD
LL
LL
DD
z
z
TT
GG
CC
CC
AA
AA
pp
hh
BB
BB
SS
H
H
nn
ii
mm
jj
RR
JJ
MM k k
PP
KK
NN LL
ss
C
D
41xØ1.0 (#20)
YY
XX
E
37xØ1.0 (#20)
2xØ1.6 (#16)
24-61
WW
B
J
39 contacts
A
W
A
H
ZZ
A
H
G
B
20-39
A
LL
FF
22-21
Y
RR BB
cc
ff
B
FF
A b
S
21xØ1.6 (#16)
AA
jj
gg
YY
JJ
FF
hh
A
A
D A
P
JJ
C
C
D E
AA
C
F
25 contacts
24xØ1.0 (#20)
NN
PKP
21 contacts
d
Z
LL
JK
N
N
W A B
A
B
V
R
B
B
R
B
C
V
M
M
U
C
M
X
X
L
A
A P B
A
C
CC
B
j
Y
BP
j
Y
K
R
D
UC
R
K
B
P X
S
C
P X
S
CT
a
S
a
S
T
N
KK U
U VV RM
R DDW
N N
i
Z D
HJH SSS RR DD N N C
W
M
F
A
D
i
Z
N
D
D
X
N
P
X
k
B
E L
K
L A TT D s k m
HH
DD
Z
T
H
A
P
X
S
C
Z
a
b
b
S
E
A
A
L
L
W
Y
T
WN
Y
T h
J
MS N
C
aN
JJJ TT S SS JAEE N
C
W
aN K
GG FF EE
r
C Y
m
D
K
B h
A
XA
a
Y
GG FF
A
A
A
G
B
W
W
W
L
L
L
A
A
W
R
A
A
A
A
A
A
M
E
M
E
P
t
V EE a
V
P
HHE RFF
nB
B
MP
E
Er
Bb
R
B
B W V MY
B
V
V
BT
B FZV
H
D
K
K
d M cS U
B
B
B
b
b
Z
Z R g R
Y R Ed R cB U B
B R
A
L
Y
J
C
J
T
U
b
F
G
G
R
R
N
M
M
J
M
Ma M
U
Ug
UqX p X C
b
C E
C
n
Z
Z
R A
W jA X
M
P
P M F Pq K
C
C A j BX JY
VP Aa LB Y
P
RC
P Ca
H
D
B LHFB
D
K
K
j
j Y
Y
M VG
UY
R
B
d
L
BG B
E LK
R K
b L Z
P X H SU CD
C
F
R L P XP SX CS
S U
A
a
SV
pa S c S R
T
DS P
cZU DZ H
N
S
V W NU N N
N
U N P Nf a
iD
Z D VT
iFTf i
X
V
W
D
C
X
G
F
M
C
C
CMW
J T BS S N
D
N
N
D
D
i
RJ
Z
X
a
N
D
D
X
X
X K
S
k
k CH
e kL d k
H
e
W
WF
d P L
H
D
D P
B EG T
T j
F N
sY
G
GT
Z b C b T HS
Ta
E
KJ
G
KU
G hS
G Z
d
CP TXUZ S bC K R T
P
CE
TJ amiL E ha GXE F
WK W Y D Y TG
JS
J
NFY
C
CW W
C
h V rS
N rh
N
mD GJa FHEES
F
FT
E MD
D J H
J
J H N
S
N
a
aV J aHY
YC P
k
M r Km
R
R P J P
W
E M
M
E
ET
c H
VD
V
S
PY M P X
E M
M d LK
E K bE
DN
H U
D
K r
T
G
dc
D
b
Z
b
bZ
ZM
S
YYG Fd
U
Y
Y
UcZR Ug
W
TEc
e
J
C
hb
b F R g R gq
m
q
qn
n Fr bg F Jq
J H n
a
Y aP
Z
Z V
a Ma
RH
E
PZ D
b JJ
V
R
D
H
H
D
D
F
F
F
L
L
L
M
E
H
A
A
d
c
G
G
E
R
R
R S
F
L
L
F
M
EE
Z
c
U
pU
p Rp c g c
YV F
TU A
TT
AA U
A
SS AA
U
V
V U
U Lb
V
X
X V
G
G q Gf n
F
F
P f
P fP f
g
f
ZV
T
ST
S R
aX
S
BS
SS
BBT
e L
e
e
ed
P
B D
RR
BB
a
W
W
W
W
d
d
FG
L G
N
N
G E
E
G
G E H EU
G
K
K
GN
H f H p
K T R
G
K
K
G K
LG
F H
BB F
LHH
U
UU
KKY
d
dd
TT
V
U
N
R
C RR
P
CC
X
V
VV F CC F
M LM
Z
X
JP
d e F FV
dd ee
J H
J HJ H
J H J H
T
S J HC PP
M
WM L K J
K L
K J e
d
K
G
c G
cc
N
EU
UU
K
G
K
G
P
P
D
P
D
D
N
D
N
N
D
D
f
f
f
J
e
e
e
W
W
W
F
H
M LK J
c
cc
G
G
CC
J H
J H
j
jj gg
g
Eee
bbF
VV
KK
PP
J
D
BC
B
BBA
KK
s
NN
G
G
SS
EE
MM bb
E
20-25
24 contacts
P
JG
P
N
N
R
AA
H
H
C
E
KK
JJ
36xØ1.0 (#20)
AAr
R
LL D CAA
A
B
M
M
AA BB
M
M N
B
KK M
N
N BB M
BB K
P
C
LL N
N
PP C
C
J
T
TT
C JJ
C N
U
P
U
U PP LC
C
C
R
R
R K
S
V
R
D KK U
U
VV R
R D
D
H
H
H SS
D
D
D U
H
H
D
D
S
A
J
T
S
E
JJ
TT
SS EE
F
R
BG
G
G FF EE
E
G
G FF EE
T PA
S
A
H
F
H
H
FF
d
T
C
S
B
R
B
G
G
G
c
D J T (#20)
32xØ1.0
S
E
AA
JJ
KK
LL
M
S
B
B
J
C
CF
D
D
36 contacts
PP
F
M
F
K
W GGD
f
C
w
D
HH
e
x
FF NN
JJ
E
f
PP
y
BB MM
EE
F
KK
g
q
LL
DD
z
T RR
WW
G
CCCC
AA
p
h
BB
H
XX S
n
i
VV
SSR DDm
j
J
M k
P
K
N
L
UU TT
V
NN
MM
F
LG
L
t
D
P
T
U
cC
Z
E
A
Z
JJ
L
A
CA
K
N
TT
GG
FF
D
E
K
A
A
U
KK
G
G
G
T
B
B
B
T
J
JJ P HH R B
P
M
B
A
M
H CA
T
M b
S
A
T
S
R B
A
C
A
A
N
U
AM b
V
U
T C
P
P
BN
A
B S
P
S
B
A
B
S
n
d
V
d
V
U
U
B
P
R
M
R
N
M
B
B
SW X
W
R
W
R
Cf
A D
C
f
Vb
C
V
R
C
C
G P DL B a
a
h
c
S
h
c
S
p
U DR
L
C L
C
SRb T m
R
e
e
V
k
qd
C
Y
M
k
Y
fW W
k
c
AAD
f N Wa
c
R
gA S
g
P
Z
T
R
P
D
Z
T
X
U
X
j
A
A
L
C
j
e
a
h
c
S
E
e
r e P E
EP
N
A
N
NA
A
m
z
H
C
BB
N
N gN A
Um A
U
A
Ad
h W D
P T
TC g
T L B hB W D
B d
V
S
V
S
cj
F
i
i
D
K
D
B
k
f
CC
c
W
Z
GG
K Y
D b
T
T
T
DS L S X
P A
Z
Z CgT CDj A d bT T j A
g NBXX KS
B
B
B
P
M
M
M
g M XZ
T y VTA
M NbM b P
nU
R B
b j P
R BR
n
U M
C
E
Y
U
E
A
N
C
s
N
U
U
V
V
HH
A
d
F
X
d
T
P
P
P
X
F
B A B FNS X S
B
B
S
eV
j
A N Ad B dl K VV j V
U A TA
Df
W W
L
U
T
A WB A K h V E
ES B
AR f A e B
Si aN
SE
S n
n l
W
UD hW
U
U
i
DD
R
J
R
BE
V
V
R
R K W
BM b
B
P DRd B
E
M RVC
A gm X
X
V DV R
W
R
Wf FF
YS U D E R
V EEbS
VC jTt C
L
C L RLJW X WB R
C a J hB c
RYC Rf
S
cC YC
S
mp
YC L G
pF k
X
x FN
UDe Mf U C a V V
LEP
C L ULa M ha X ach S
C J
D
R
R
Rm
G
c eCH ke G
W
B
c
W
f
M
U
e
C
E
Y
Y
J
H
X
X
X
U
T
P
C
P
CY J
V Ug
kAA
q
u
bh kM
Y
k E
U
f
f Fd W F
j
c
WUj P j Y
cPM kc YJ k DfR W
AA
j
Y K D M h Gg w g
H P X BSF C
F k
Hj
F
Z T HP
X
V
Z
Z
T
Z
Z
T
W
R
D
G
P
X
S
C
X
X
X
a
S
a
S
j
j
f
L
V
L
C
C
e
e
e
L
b
R
E
E
E
c
SH C T
T
bG
HP
rZ
Z PWe
m E
z BB
g
dG
g L d Z adD h
H
F
gm h MvWh a
BB a
i g
iF
Z D
W
WcP D Yz
a
P E P z
P m
D
N X GN
DV
S
V
ik
ih W
N
N
k Lm i Z JiE c
k KD
GS D S
K
DN K
KV
D DD
J
J k Dm Z
Hg
j
j GG
E L
d
f TW K
CC
ZG
F j T i Gg T
LGG
K
s
Zj
g kGX
Z U HEDU j D
Z
T K XY
ZS YK b Y
T
n E s
n f n ee L mJ
bT
U D
S
W
Y C
T
bN jab EKj aPg
X
H
yH
h
h X r hFN
hy H
W KHH
AAY
L
LLW
dF F l
Pj K Xj
rf
m
X N dNa ld
X
h j
N F N y
D J sH
ef m ea g N G b d
V
Sf
l W
JhF HA F
Y
U AT
U
U
T
TE
De
N Gi
EKN E
Ma
t
t En
hD
a
A
S
F
P
W
W AA DD
LE
i J
i
i FF A
W
FF
r
nh
A
J E
EKKM
J M b JY dZ K c E
j
g S XRR AAr
X A
V MLL Y d AA X c X U K E
V
V
BB
b
Z
R g AA
BB M
VxV
BB t
U E
K
B
BB
Y
R J g J q W n W Yb ER F f E Me B a U
RR
k gF
kV
k dY Bl Y n
xE
Mapb Fab NYR b YG BG c
Vx
EE
G
X
c
c
W
J
E
g
b
q
n
Y
q
q
p
j
Z
M
M
M
T
aD
M
M
C b
N X
XE u C
wX
R
h M hw X
FH
L
L
P
G
Mh C PP R
MG U
F CCM
F C FM UUh
F
H aH
FJ F KF U F M
EB
M
Z
Z
Z
X
V
B
B
KK L
j
Y
j
j
Y
Y
j
G
R
U
L
F
c
c
U
p
p
L
L
L
b
b
b
H
H
H
fH VH
aS
Y
Za cZ
C
G N
GU G V
kT ii g Y
v
H N
F W
FJ P G
F X WS
c
a
aa Zf SS
M
g
g v
V
U
V
f
aG
Gc
T
T
D
E PPJ P XX f SSeP CC
NW
S
SS
N
NX
ia
Z D
ZZ c D
W
W XXXP N
T
S
CJJ
C
CW
J
eG L d D
D
DL dK N KJH
e G d NG
KNN
J
de D
D LH
X F G
H
d
L
Li
L k
k
L
G
Mk G
HG
f kF
ZT L NND HZZ P
T
N
N
G K
E
K
K
G
H
H
G
K
G
SS AA
sf
Lb
TT
G
J Z
J S Kh K H
FT
bb
N TT
N
Y
W
W
YYM
F
H
H b aSS a Ehh Z rr K e m
K
CJJ
C
RR
BB
HMC
J W H
J H
J H J H J
m J aa EE
h
J r J Lm
M
K
G
K
J K J
L K MJ EE K
a
aa
Y
YYJ PP L K M
G
R
R
R
M
M E
PP
t
V
VV
S
P
r
M
M
ME
EE
dPd
T
PP
H
DT H
H CC
D
D
d
c
cc U
b
Z
bb
ZZ
Y
U
YY dd
U
K
H
R g
b
R
R
F
g
g
b
b
F
F
J
g
q
qq
YY FF
HH
GG
JJ
EF
J
N
18-32
B
L
EE
ZZ
N
A
b B P
R B
FF
P
G A
J
F
H
B
B
L
K
A B
C
32 contacts
JJ
WW DD
gg
hh
aa
LL KK
BB
VV
ff
F
C
D
L
A
A
L A
HB A
M
A
B
M
A
B
M
B
K
N
FN
A
K
B
L
A
G
B
L A
M
H
A
L
N
P
C
LK NM PN C
U
P J C
J
TK U
P B C
J GR P N
CB
M
K
M
B
R
K
U
V
R JD
H ES
S R RN D
DL
KJ UT VU RP
H
D
DC
C
J
C
L A
A
A
M L
KD
P
H
D
H
L A
L C
A L LA
F
H
AH
A
D
T
S K E LMK N
M BA
B
J H TS SR E
F
G
EE
FM EA
G
M MBN AB B
B J
DC
C K
A
K DK K B M B N
G F E G
G F E
L
A
B
G
B
B B
H
D
H
H
F
FF
C
L A
M
M
H
A
D
C MJ
A
B
G GF
E
L F NLE P
N CP M
C
B
K
TJ DUT LPU NC
C B GJ
C CN
P PM
RJ NR T CN UKC P
E
J J J R GN
G
C
J
B
M
MK
KP
P
P
M
L
L
B
RR D N
S
SH KR
S UDJR VT
UK VU RV DLR N
D
P
C
H
H
D RU DP
C K
J
C
B F
P
H C
H
H
D JD
C
F
C M DL K
J
TJ
ST EKS U
E
V
R
D
H SS E R
A
D
F
FG JEF TE
G
G
E
EC DE GD F E
G F GE F E H
H
F
H
HF
F
D
F
F
C C A
C
T
S
E
GG
G
G J
F
E
B AH
E
D
G F E
D E
H
F
L M
CA B
A
D
G
C
A
A
A
A
B
P E
E
b
EF C E C D
D
D
E
Fu
Dc
W
C
w
X
D
AA
N HH Aw T e AD
A
Z
ZA
GG EvU A
HH
s
e
T
BZ
B
t
x
Bd
x
WT
V
JJ
M
A T HH w
E
T V A FF NN
M
MFF bNN P JJS R B
S
D
E
Z C Ar
s
a Cb
eC
U
V
r
ba
bB S B
P
B
B
S
fU
Y
Y
Ya
f
PP
PP
B
V
d
V U U EE
y
USFF NN n JJ W x
V
U
R KK dy X
EE
E
u
uR
uv
c
c
c
WL
R
D
D
MM
MM
F
C
C
C
F
X
X
v
v
KK
f
f
V
V
L
C
C
C
R
a
h
c
S
a
h
c
S gC
m
X f
a
C
Lq
D
GG
GG GG
r R
b q
e
eRY
g
PP p
B
t
t
t
LL
DD
LL
Y
k w d wuf d WTg c DD
W w d WD W
c
z
U
gEE k MM AA KK q y
T
Pj c zWk T G f
P
T
Z
F
C
D v DE
G
XZ
X
j
ee m
e
E
r
m
z
g
d
g
d
CC
AA
HH
HH
HH
GG
BB
s
s
s
A
CC
AA
e
e
h
h
W
W
P
P
P
g
q
Np d A D
N
AA
p
h i N
N
N
V
S
hN
A
AA
LL D
itx
T CC
TT
B E
K
D
x
x
BB
BB
jDD
z
Z
GG
S
S
K Y
D
K
D
FF
FF
FF
T
NN
NN
NN
V
V
V
W
H
JJ
JJ
JJ
j
g
j
g
H
E
E X n E w Pn
G
D
U
Yn
PP
M
M
bBB
M i bb
N eb i U
X FB M
SS
CC
AA
y S
bF
R
Rd BB N np
s d f M HH
s
emR B M
C
HH
r
r
rN
X
X
F
h
f
e
f
f
f
U
PP
PP
PP
m
j
j
l
l
j
j
P
P
P
U
T
N
BB dE DD
R
E k
J h
R x
J
M k
y U
y
M
S
i
FF
V N h yFF NN
U
UEE
H aV R
E
EE
X
V
V
E
MM R KK
MM
MM
n R
F k JJ F
R D dd
PX
KK
i
AA J
LL
P
KL a EEW Y
K
WqF
R
R
x Y
t
EE j
LLC g W
C
Cr LL KKcLY
c C
W
ag G h
c fA
hh cc
SS
J
E
J
N WM
g
L
qE DD
q M DDLL a
NASLL L C aa
Y
m
C kR
PP
A
A
LLG
W
W
L
L
e
DD
A
A
A
A
J
k
M
y
w
u
b
h
zZ
z
MEE
M
F
F
RR F F BB
RR z
B
U
M P
Z
TB G T
KK
BB H
W cc kk
GP
MM
KK Zj
LFT
LCC
Pg N cUU LVvkV K c f BB
P
T ZZ
TTb
bZG
H agG
Z
G
X H AA
X CC
H
F
H
CC
AAq AA
jj
MM
a
MM
CC E
gd
gg
dd
p
pX
p
h
h
h
XX
G
G
SSBBT D
KBB DD
BB S K
BB
KK
j jd i H
YY
L
LJ H LLH PP z aGa GKKSS D CC
L
Gf
S
K SK V n J
D VV S
D
PP XX K
D
n
n
g ZZN
i SS HCC
i K CC
i Y
SS
NN CC
U YY DD
U
U KD
WW XX NN
J
bb jj
N TTb Ki i ej
N
X DDF
JJ
K JNNAAf H eh
H
DD m
mN
j
m j kp Jj
J
kk
ff
ee
R UN
J
J BB
MT k
U
UR TTR M k M
S
Hbb
h
ZZ
TTX
A
L
n
J
E
J
J
E
E
P
P
P
S
S
EE
i
W
W
Y
Y
T
T
K
K
K
X
V
X
V
V
JJ
CC
m
Ym aaM
aa
N
L
LN RL
m
M hh a r r
M
G
YY PP
W
W
RR
J M MM
EJJ
EE
MM N
EE
PP DD
k j W J
VV aa
K
HH
cc UU EE
H
Fbb
H
FF
ZZH
P
ZB
YY
K dd
R
R
g
g
b
b
F
FLL
M
L
H
N HL
qq
G
G
G
nn
F
H
H
FF
ZZ
aa
HH
DD
FF
LL
G
K pp J cc
KK
GG
EE
RR
LL G
FF G
UU
B
S
A
AF A
L
K
M
B
E
EE RFF
N B
J
D
A
C
C P A
B
S
Z
V
NN
N
UU EE
GG
FF
C
PP
N
R
Y
X
16xØ1.6 (#16)
C
CC
FF
EE PDD
R
D
X
A
JJ
KK
LLN
BB
SS
B
N
C
DD
EE
AA
RR
YY
A
CC
LL
FF
M
N
X
W
G H U
F
AA
KK
GG
M
J
RV
E
JJ
K
eP
K
A
L
K
B
PP
NN
DD
L
D
B
T G AS
A E
FB
J
R
B
U d
C
V TC
d
c
U
P
D H
f
e W D
c N
j
g
b h
V
M
E
X
N
E
b
g
f
W
Z
aa
L
F H
M
F
YY
Z H X
K
K J
G
L
G
J
H
G
R
D
C W
g
h
a
D
F
F EEA D
S
C
MM
A
P
B
V
MM
S
CC
B
CC
EE
N
f
j
L
E
L K
A
U
K
e
N
D
A
E
A
K
H
H
B
T
B
H
C
LF A H
A
K
B
G
DB
M E
R
N
J
J
P M LC K
AA
J
S
B
L M
F
E
R
K
N
16 contacts
AA
CC
J
A
R
J
A
20-16
F
FF
AA
BB
E
B
D
S
AC
A
FF
C
CH T
S
B
R
B
A G F E
EE D
DJ
BE d D BBT
U
C
R
C
V
AA
d e
CC
c
H
B
FF U D
K
P
f
e
W D
KK JJ CC
FF
c
G
C
c
G
C
j
j
g
g
HH
E
E
D
D
L
L
b
V
J
J
J
A
A
A
h
h
L M
M
EM G
T
A
T
AT LA
S N A b
AS
X
X
CC
BB
N
E
b
C
E S
EE
CC
B
S g S f
B
B R
FF JSEE DD
R
R
F
D
L B a
KK
F
D a JJ
W
A
H
H
aH Z
Z
D
BD
B
B
U
U
U FC P TC dA
LR
K
K
d
T
C E
M
YK F R d e
YP F Pd
E
N dY eX V RR
V
eR
VS
B MBT ADC
d N
Z
H
H
c
c
UK
PP G ND c DU F
K
B
J
J
L K
L
G HP
G
AA
A
K
D
P
P
D
N
N
R
C
f
f
f
P
E
e
W
W d W
A
B
A
BG
e
Ve
cC
c J cj H
G
C
G
C
j
g
g j
g
L
L
L
BC
b
V
b
b
h
h
h
AN
A
C
P X MEX
E
M
M
S Rb T
S b T
fE
X
W D
N
E
N
N
b
b
b
c
G
C
j
gg
f
g
fg
C
M
S
F
F
D
D
La
a h
W
a
a
aY
N
N Da
Z
Za
Z
a
U D
U FD
L
L
L
M
Y
F
M
M
FY
F
E
E
E
NY
E F
Y X
Y
b
c
c
Z
X
Z
ZX
X
L
T
D
F
Z
HJ
H
Z
Ka
K
K
G
A
AA E
J D H G
V E
V
L K
L K LJ K
M Z
M Z
G
M AG
Y
F
VX
AA
P
PP
AE
AA
J
JH
X
A
B J
AA
BB
H
W
UW EF
H
KL Y
K
W F
L Y
JC
N
NN
B
BB
L
GAA
A
CC
G
B
G
G
BB
GH
J
H
S b T
SS bb TT
R
RR
J K HJ
F
K
G
G
C M
CC
M
M
Y
YY
S
SS
a
N
U D NN aa
UU DD
H
H
H
c
cc
F
C
FF
C
C
X
L
T
TT DD
D LL XX
Z
ZZ
V EM
VV EE
M Z
M ZZ
LL
AA VV
V
X
XX
E
D
EELL AAD
D
HH A AA
L
A UU EE
W
W
U
EK M
K
KK
M
M FAA LB
M LW
W
W
W FF
K
N
N BB
L Y
LB YY
KK
LBB
A JB H
A
A
GG
BB
G
G
G
JJL HH
R
R
J H
K
B
K JJ HH
MM
F
FF
B
LPP CKC
K
KA
G
G
G
L
L
N
N
J
J
T
T
C
C
U
U
P
P
M
BB
A
G
H
11xØ1.6 (#16)
G
C
C
L
A
11 contacts
H
AA
CC
P
FF
C
R
C
M
Y
S
NN
a
D
U D
G
B
R
C
M
Y
Sc
X
L
T
D
Z
VP E
H
V E
M Z
A
A
A
A
A
V C
A
A
A B
B
FB
XT
X
L
D
W
Z
A
U
E
K
N
NW F B A B
B
EA
KC W
W F
L Y N
AU
C
C A
L Y
G
G
B
B
S
T
S
S
T
T
P
A
V
R
R
R
G
b
b
b
A
B
J
H
J
H
E J HD G F
J H
F
C
CS
M
M
Y
Y GY S
KM
S
W
K
G
U
E
K
Na C
B
a
a
N
N
N
C
U D
U AD U D
G
B
H
H
S b T
R
G
c
c
c
F
FL
J H
A
F
C
LC XA C Z
S
X L LXZ
LA
L
T
D
ZT M DT Y D
a
N
U D
M K A M B NM BZ
V E
H
M KN
B
K
A M M Z M A ZXB XV E V E c A
V
V
B V
F
C
X
E
ED
D
WK
W U L L
G
U
E
EUXY E Z
KM W
K
WTFF D
L NY L PY CW M F W
B
VB E
Z FF
L
N
P
C
L
J
J
T
T
C
U RP NC H
U
P
V
G
G
G
J
J
H
HJ
H
J
X
J HJ H F
PJ E C D F
K
K
G
GY
UG E
K FKW
W
D F
L
R
S
K
U H V S R RD D
K
H
D
G
J
CU V R D
E
C L
H
J H
F H A
FF
AA
FE
D
K LL AA G
A
L A
M
C
18-11
B
P
N
D
J
AA
N
B
D
E
D
18
BB
H
DD CC
K
C
D
A
A C
Contact
#16 (Ø 1.6 mm)
AA
EE
A
A
A
A
A
B
D
D E
B
B
B
E
FF GG
BB
DD
EE
CC
A
E
F
B
BF G
B
E
A
AA
A
HG A
FG
B
BA
GF
B
E
B
E BF
D
JD
M
E
C
E
E
C
CE
C
E
E L KC
C
D
C
D
D
D
D
F
A
F
FCAD C
A
F
C
H
A
D
C
A
A
A
E
D
F
G
E
B
E
E
B
B
B A
B
B
E
E
E
J
M
K
E
B
L
CCAA BB
AA
DD
E
D
C
D
DC
C
BCCA
B
GB
G
A
H A
B
HD A DCB FC
D
C D A C
A
E
D
C
H
H
F
D
G K
JF C
G K H J
C
F
B
B
AA
BB
F
F
B
C
D
B
D C
A
A
E
BB AA
E
B
A
A
Overview
F G
A
Environmental versions
Technical features
Materials
• Shell:
Environmental version : aluminium alloy
- Plating :
- olive green cadmium
- black anodised
- black zinc nickel
- nickel
• Backshells: Aluminum alloy
• Cable glands: Thermoplastic
• Coupling ring: Aluminum alloy
• Spring washer: Spring stainless steel
• Insert: Elastomeric soft neoprene
• RoHS compliant & conforms to the Chinese
standard SJ/T1166-2006
(Chinese RoHS equivalent)
- At reduced pressure 10 mbar:
connectors mated and unmated
- 200 Vrms between size 20 contacts
(service 1)
- 300 Vrms between size 16 contacts
(service 2)
• Insulation resistance
≥ 5000 MΩ under 500 Vcc
• Current rating per contact
- Standard version:
Size 20 = 7.5 A / Size 16 = 13 A
- Hermetic version:
Size 20 = 5 A / Size 16 = 10 A
• Contact resistance
- Environmental version:
Size 20 ≤ 4 mΩ / Size 16 ≤ 3 mΩ
- Hermetic version:
Size 20 ≤ 30 mΩ / Size 16 ≤ 14 mΩ
• Shielding effectiveness:
70 dB to 5 MHz - 40 dB to 100 MHz
• Fluid resistance:
- to MIL-DTL-26482G series 1 and
NFC 93422 - HE 301 B code A
- Hydraulic fluids
- Lubricating oil
Mechanical
• Durability:
500 matings and unmatings per
MIL-DTL-26482H
COMPLIANT
Electrical
Environmental
• Dielectric withstanding voltage:
- At standard pressure: mated and unmated
connectors
- 1500 Vrms between size 20 contacts
(service 1)
- 2300 Vrms between size 16 contacts
(service 2)
- 1500 Vrms between mixed size 20 and 16
contacts (service 1)
• Operating temperature:
from -55°C to +125°C
• Flammability rating:
UL94 HB
• Dynamic salt spray:
per EIA-364-26
- 48 h nickel, zinc cobalt, zinc nickel
- 500 h black anodized version
- 500 h black zinc nickel version
16
• Sealing:
- Globally IP65 (unmated conditions)
- With J or JC backshell IP67 (mated conditions)
- With cable gland IP68 (mated conditions)
Under 10 meter of water during 48 hours
- Crimp contact version, 1 bar differential
pressure, leakage ≤ 8 cm3/hr
- Solder contact version, 2 bar differential
pressure, leakage ≤ 16 cm3/hr
• Vibration resistance:
10-2000 Hz, acceleration 15 g test procedure
per EIA-364-28
• Thermal shock:
5 cycles, 30 min. from -55°C to 125°C
per EIA-364-32
• Mechanical shock:
50 g, 11 ms period per EIA-364-27
Overview
Hermetic versions
Technical features
Materials
Electrical
Environmental
• Shell:
Steel
• Max current rating per contact:
-55°C to +125°C
• Plating:
Iridescent yellow cadmium
Nickel
• Contact:
Gold plated ferrous alloy
• Seal:
Fluorocarbon elastomer
Contact size
Rating (A)
5
10
Service
I
II
Standard
pressure
1 500 Vrms
2 300 Vrms
• Contact resistance:
Size 20 ≤ 30 mΩ
Size 16 ≤ 14 mΩ
10 mbar
pressure
200 Vrms
300 Vrms
• Hermeticity:
1 bar differential pressure,
leakage ≤ 2.8 mm3/hr
• Salt spray:
48 hours min
• Chemical resistance:
To MIL-DTL-26482G Series I
• Damp heat: 21 days
• Shielding:
70 dB to 5 MHz
40 dB to 100 MHz
17
851 SERIES
851 Series
Connector
Environmental connectors .................................................................................................20
Hermetic connectors .........................................................................................................43
PC Tail connectors .............................................................................................................45
Panel cut out .....................................................................................................................46
Backshells ..........................................................................................................................47
Push-pull locking plug .......................................................................................................49
8F51 filter connectors ........................................................................................................51
SNC specifique connectors ...............................................................................................52
19
851 Series | Connector
Square flange receptacle with straight adaptor
E
L
F
D
HE 301 B 00 RA
ØK
00 RA
ØA
HE 301 B 00 A
ØG
Cross reference
00 A
ØJ
Shell
size
Part numbers
solder contacts
8
851 00 A 8..
10
12
L max
crimp contacts
. 50..
851 00 RA 8..
851 00 A 10..
P
S
. 50..
851 00 A 12..
P
S
. 50..
14
851 00 A 14..
P
S
16
851 00 A 16..
P
S
18
solder
crimp
A
B
max
C
max
D
max
F
max
G
max
J
E
K
threading
UNEF 2A
. 50 ..
41.00
12.03 11.70
1.32
14.50 15.09 20.99
9.10
3.13
1/2 18
851 00 RA 10..
P
S
. 50..
41.00
15.01 11.70
1.32
18.70 18.26 24.19 12.08
3.13
5/8 24
851 00 RA 12..
P
S
. 50..
41.00
19.07 11.70
1.32
21.70 20.62 26.54 15.25
3.13
3/4 20
. 50..
851 00 RA 14..
P
S
. 50..
41.00
22.25 11.70
1.32
25.10 23.00 28.89 18.15
3.13
7/8 20
. 50..
851 00 RA 16..
P
S
. 50..
41.00
25.42 11.70
1.32
28.13 24.61 31.29 21.32
3.13
1-20
851 00 A 18..
P
S
. 50..
851 00 RA 18..
P
S
. 50..
41.00
28.60 11.70
1.32
31.38 26.97 33.69 24.32
3.13
1-3/16 18
851 00 A 20..
P
S
. 50..
851 00 RA 20..
P
S
. 50..
44.00
31.77 14.35
2.15
34.30 29.36 36.89 26.73
3.13
1-3/16 18
22
851 00 A 22..
P
S
. 50..
851 00 RA 22..
P
S
. 50..
44.00
34.95 14.35
2.15
37.60 31.75 39.99 30.67
3.13
1-7/16 18
24
851 00 A 24..
P
S
. 50..
851 00 RA 24..
P
S
. 50..
44.00
38.12 15.20
2.15
40.70 34.92 43.15 33.08
3.81
1-7/16 18
P
S
P
S
Square flange receptacle with straight cable clamp
Cross reference
HE 301 B 00 EC
00 EC
HE 301 B 00 RC
00 RC
F
MS 3120 F
VG 95328 B
B
Part numbers
solder contacts
8
851 00 EC
AC 8..
10
851 00
EC
AC
10..
P
S
12
851 00
EC
AC
12..
P
S
14
851 00 EC
AC 14..
P
S
16
851 00
16..
P
S
18
851 00 EC
AC 18..
P
S
20..
P
S
22
851 00 EC
AC 22..
P
S
24
851 00
P
S
EC
AC
EC
AC
EC
AC
24..
Note: all dimensions are in mm
D
ØA
HE 301 B 00 AC
ØG
MS 3110 F
00 AC
Shell
size
E
L
P
S
ØJ
C
L max
crimp contacts
solder
crimp
A
B
max
C
max
D
max
E
F
max
J
. 50..
851 00 RC 8..
. 50 ..
48.00
47.30
12.03
11.70
1.32
13.50
15.09
20.99
3.13
. 50..
851 00 RC 10..
P
S
. 50..
48.00
47.30
15.01
11.70
1.32
16.70
18.26
24.19
3.13
. 50..
851 00 RC 12..
P
S
. 50..
48.00
47.30
19.07
11.70
1.32
19.90
20.62
26.54
3.13
. 50..
851 00 RC 14..
P
S
. 50..
48.00
47.30
22.25
11.70
1.32
23.40
23.00
28.89
3.13
. 50..
851 00 RC 16..
P
S
. 50..
51.00
50.50
25.42
11.70
1.32
26.60
24.61
31.29
3.13
. 50..
851 00 RC 18..
P
S
. 50..
51.00
50.50
28.60
11.70
1.32
29.50
26.97
33.69
3.13
. 50..
851 00 RC 20..
P
S
. 50..
53.00
51.50
31.77
14.35
2.15
32.70
29.36
36.89
3.13
. 50..
851 00 RC 22..
P
S
. 50..
53.00
51.50
34.95
14.35
2.15
36.00
31.75
39.99
3.13
851 00 RC 24..
P
S
. 50..
53.00
51.50
38.12
15.20
2.15
39.10
34.92
43.15
3.81
. 50..
P
S
Square flange receptacle with backnut
HE 301 B 00 E
MS 3110 E
ØA
F
HE 301 B 00 R
00 R
D
MS 3120 E
VG 95328 A
B
Shell
size
Part numbers
solder contacts
8
851 00 E 8..
10
12
L max
crimp contacts
. 50..
P
S
ØJ
C
crimp
A
B
max
C
max
D
max
E
F
max
J
. 50..
32.70
32.00
12.03
11.70
1.32
13.50
15.09
20.99
3.13
851 00 R 10..
P
S
. 50..
32.70
32.00
15.01
11.70
1.32
16.70
18.26
24.19
3.13
851 00 R 12..
P
S
. 50..
32.70
32.00
19.07
11.70
1.32
19.90
20.62
26.54
3.13
. 50..
851 00 R 14..
P
S
. 50..
32.70
32.00
22.25
11.70
1.32
23.40
23.00
28.89
3.13
. 50..
851 00 R 16..
P
S
. 50..
32.70
32.00
25.42
11.70
1.32
26.60
24.61
31.29
3.13
. 50..
851 00 R 18..
P
S
. 50..
32.70
32.00
28.60
11.70
1.32
29.50
26.97
33.69
3.13
. 50..
851 00 R 20..
P
S
. 50..
34.50
33.40
31.77
14.35
2.15
32.70
29.36
36.89
3.13
. 50..
851 00 R 22..
P
S
. 50..
34.50
33.40
34.95
14.35
2.15
36.00
31.75
39.99
3.13
. 50..
851 00 R 24..
P
S
. 50..
34.50
33.40
38.12
15.20
2.15
39.10
34.92
43.15
3.81
851 00 E 10..
P
S
. 50..
851 00 E 12..
P
S
. 50..
14
851 00 E 14..
P
S
16
851 00 E 16..
P
S
18
851 00 E 18..
P
S
851 00 E 20..
P
S
22
851 00 E 22..
P
S
24
851 00 E 24..
P
S
851 00 R 8..
solder
P
S
Connector
00 E
E
L
Cross reference
Square flange receptacle with removable straight backshell for
E
L
B
Shell
size
Part numbers
solder contacts
8
851 00 G 8..
10
851 00 G 10..
12
C
L max
crimp contacts
solder
crimp
ØJ
M
A
B
max
F
VG 95328 R
ØD
00 RG
ØA
00 G
ØG
Cross reference
C
max
D
max
E
F
max
G
max
J
M
max
.50..
851 00 RG 8..
P
S
.50..
851 00 RG 10..
P
S
851 00 G 12..
P
S
.50..
851 00 RG 12..
P
S
.50..
54.00
19.07
11.70
1.32
22.30
20.62
26.54
13.20
3.13
3.60
14
851 00 G 14..
P
S
.50..
851 00 RG 14..
P
S
.50..
54.00
22.25
11.70
1.32
25.30
23.00
28.89
16.50
3.13
3.60
16
851 00 G 16..
P
S
.50..
851 00 RG 16..
P
S
.50..
54.00
25.42
11.70
1.32
28.30
24.61
31.29
19.35
3.13
3.60
18
851 00 G 18..
P
S
.50..
851 00 RG 18..
P
S
.50..
54.00
28.60
11.70
1.32
32.30
26.97
33.69
21.60
3.13
3.60
851 00 G 20..
P
S
.50..
851 00 RG 20..
P
S
.50..
59.30
31.77
14.35
2.15
34.30
29.36
36.89
24.80
3.13
3.60
22
851 00 G 22..
P
S
.50..
851 00 RG 22..
P
S
.50..
59.30
34.95
14.35
2.15
38.30
31.75
39.99
27.90
3.13
3.60
24
851 00 G 24..
P
S
.50..
851 00 RG 24..
P
S
.50..
59.30
38.12
15.20
2.15
41.30
34.92
43.15
31.00
3.81
3.60
P
S
P
S
.50 ..
54.00
12.03
11.70
1.32
16.30
15.09
20.99
7.45
3.13
3.60
.50..
54.00
15.01
11.70
1.32
18.30
18.26
24.19
10.30
3.13
3.60
21
Square flange receptacle with straight sealing gland backshell
E
L
B
Part numbers
Shell
size
solder contacts
solder
F
ØJ
C
L max
crimp contacts
ØD
ØA
HE 301 B 00J
ØG
Cross reference
00 J
crimp
A
B
max
C
max
D
max
E
F
max
G max
min
max
J
8
851 00 J 8..
10
851 00 J 10..
12
851 00 J 12..
P
S
. 50..
48.70
19.07
11.70
1.32
21.10
20.62
26.54
9.34
10.16
3.13
14
851 00 J 14..
P
S
. 50..
53.50
22.25
11.70
1.32
24.40
23.00
28.89
11.32
12.14
3.13
16
851 00 J 16..
P
S
. 50..
59.00
25.42
11.70
1.32
27.60
24.61
31.29
14.73
15.55
3.13
18
851 00 J 18..
P
S
. 50..
65.00
28.60
11.70
1.32
30.80
26.97
33.69
16.00
16.82
3.13
851 00 J 20..
P
S
. 50..
79.10
31.77
14.35
2.15
34.10
29.36
36.89
16.89
17.70
3.13
22
851 00 J 22..
P
S
. 50..
80.00
34.95
14.35
2.15
37.30
31.75
39.99
17.78
18.60
3.13
24
851 00 J 24..
P
S
. 50..
90.00
38.12
15.20
2.15
40.50
34.92
43.15
20.34
21.16
3.81
P
S
. 50..
47.60
12.03
11.70
1.32
14.40
15.09
20.99
5.02
5.84
3.13
. 50..
47.60
15.01
11.70
1.32
17.60
18.26
24.19
5.94
6.76
3.13
P
S
Square flange receptacle with straight sealing gland and cable clamp
E
L
B
Shell
size
Part numbers
solder contacts
8
851 00 JC 8..
.50..
crimp contacts
solder
crimp
57.68
G max
A
B
max
C
max
D
max
E
F
max
min
max
12.03
11.70
1.32
19.90
15.09
20.99
5.02
5.84
J
3.13
10
851 00 JC 10.. .50..
57.68
15.01
11.70
1.32
21.50
18.26
24.19
5.94
6.76
3.13
12
851 00 JC 12.. PS .50..
61.24
19.07
11.70
1.32
25.00
20.62
26.54
9.34
10.16
3.13
14
851 00 JC 14.. PS .50..
66.01
22.25
11.70
1.32
27.80
23.00
28.89
11.32
12.14
3.13
16
851 00 JC 16.. PS .50..
74.75
25.42
11.70
1.32
29.40
24.61
31.29
14.73
15.55
3.13
18
851 00 JC 18.. PS .50..
80.57
28.60
11.70
1.32
35.30
26.97
33.69
16.00
16.82
3.13
P
S
851 00 JC 20.. .50..
91.69
31.77
14.35
2.15
35.30
29.36
36.89
16.89
17.70
3.13
22
851 00 JC 22.. PS .50..
95.66
34.95
14.35
2.15
41.10
31.75
39.99
17.78
18.60
3.13
24
851 00 JC 24.. PS .50..
101.22
38.12
15.20
2.15
42.40
34.92
43.15
20.34
21.16
3.81
P
S
22
P
S
ØJ
C
L max
F
MS 3110 J
ØD
ØA
00 JC
ØG
Cross reference
Square flange receptacle with removable straight backshell for heatshrink sleeving
E
M
Shell
size
Part numbers
solder contacts
8
851 00 M 8..
P
S
L max
crimp contacts
. 50..
851 00 RM 8..
ØJ
C
solder
. 50 ..
P
S
crimp
50.00
A
B
max
C
max
D
max
E
F
max
G
max
J
M
max
12.03
11.70
1.32
13.55
15.09
20.99
7.05
3.13
3.50
10
851 00 M 10..
P
S
. 50..
851 00 RM 10..
P
S
12
851 00 M 12..
P
S
. 50..
851 00 RM 12..
P
S
14
851 00 M 14..
P
S
. 50..
851 00 RM 14..
P
S
. 50..
50.00
22.25
11.70
1.32
21.30
23.00
28.89
15.90
3.13
3.50
16
851 00 M 16..
P
S
. 50..
851 00 RM 16..
P
S
. 50..
50.00
25.42
11.70
1.32
24.50
24.61
31.29
18.95
3.13
3.50
18
851 00 M 18..
P
S
. 50..
851 00 RM 18..
P
S
. 50..
50.00
28.60
11.70
1.32
26.45
26.97
33.69
20.90
3.13
3.50
851 00 M 20..
P
S
. 50..
851 00 RM 20..
P
S
. 50..
53.30
31.77
14.35
2.15
30.73
29.36
36.89
23.70
3.13
3.50
22
851 00 M 22..
P
S
. 50..
851 00 RM 22..
P
S
. 50..
53.30
34.95
14.35
2.15
34.24
31.75
39.99
26.60
3.13
3.50
24
851 00 M 24..
P
S
. 50..
851 00 RM 24..
P
S
. 50..
53.30
38.12
15.20
2.15
36.47
34.92
43.15
29.30
3.81
3.50
. 50..
50.00
15.01
11.70
1.32
15.35
18.26
24.19
9.90
3.13
3.50
. 50..
50.00
19.07
11.70
1.32
19.48
20.62
26.54
12.60
3.13
3.50
Connector
B
F
ØD
ØG
ØA
L
Square flange receptacle with straight backshell for potting
E
L
Cross reference
00 RP
MS 3120 P
B
Shell
size
F
HE 301 B 00 RP
ØD
MS 3110 P
ØG
HE 301 B 00 P
ØA
00 P
Part numbers
solder contacts
8
851 00 P 8..
10
851 00 P 10..
12
L max
crimp contacts
solder
ØJ
C
crimp
A
B
max
C
max
D
max
E
F
max
G
max
J
. 50..
851 00 RP 8..
P
S
. 50..
851 00 RP 10..
P
S
851 00 P 12..
P
S
. 50..
851 00 RP 12..
P
S
. 50..
36.20
41.70
19.07
11.70
1.32
21.69
20.62
26.54
13.96
3.13
14
851 00 P 14..
P
S
. 50..
851 00 RP 14..
P
S
. 50..
36.20
41.70
22.25
11.70
1.32
23.90
23.00
28.89
17.42
3.13
16
851 00 P 16..
P
S
. 50..
851 00 RP 16..
P
S
. 50..
36.20
41.70
25.42
11.70
1.32
27.00
24.61
31.29
20.56
3.13
18
851 00 P 18..
P
S
. 50..
851 00 RP 18..
P
S
. 50..
36.91
44.46
28.60
11.70
1.32
30.50
26.97
33.69
23.66
3.13
851 00 P 20..
P
S
. 50..
851 00 RP 20..
P
S
. 50..
43.80
50.93
31.77
14.35
2.15
33.65
29.36
36.89
23.92
3.13
22
851 00 P 22..
P
S
. 50..
851 00 RP 22..
P
S
. 50..
43.80
50.93
34.95
14.35
2.15
37.10
31.75
39.99
25.52
3.13
24
851 00 P 24..
P
S
. 50..
851 00 RP 24..
P
S
. 50..
43.80
51.40
38.12
15.20
2.15
40.00
34.92
43.15
32.00
3.81
P
S
P
S
. 50 ..
36.20
41.70
12.03
11.70
1.32
15.34
15.09
20.99
10.46
3.13
. 50..
36.20
41.70
15.01
11.70
1.32
17.70
18.26
24.19
13.55
3.13
23
Square flange receptacle with straight backshell for heatshrink sleeving
E
F
ØD
ØA
ØG
L
M
B
Shell
size
Part numbers
solder contacts
8
851 00 T 8..
10
L max
crimp contacts
. 50..
ØJ
C
crimp
C
max
D
max
G max
F
max
E
Solder Crimp
M
max
. 50 ..
36.70
36.00
12.03 11.70 1.32 15.35 15.09 20.99
6.70 3.13
3.70
851 00 T 10..
. 50.. 851 00 RT 10..
P
S
. 50..
36.70
36.00
15.01 11.70 1.32 18.15 18.26 24.19 10.20 9.40 3.13
3.70
12
851 00 T 12..
P
S
. 50.. 851 00 RT 12..
P
S
. 50..
36.70
36.00
19.07 11.70 1.32 23.45 20.62 26.54 13.20 11.95 3.13
3.70
14
851 00 T 14..
P
S
. 50.. 851 00 RT 14..
P
S
. 50..
36.70
36.00
22.25 11.70 1.32 24.25 23.00 28.89 16.10 15.15 3.13
3.70
16
851 00 T 16..
P
S
. 50.. 851 00 RT 16..
P
S
. 50..
39.00
38.30
25.42 11.70 1.32 29.55 24.61 31.29 19.25 18.05 3.13
3.70
18
851 00 T 18..
P
S
. 50.. 851 00 RT 18..
P
S
. 50..
39.00
38.30
28.60 11.70 1.32 31.75 26.97 33.69 21.30 19.95 3.13
3.70
851 00 T 20..
P
S
. 50.. 851 00 RT 20..
P
S
. 50..
45.30
44.20
31.77 14.35 2.15 35.85 29.36 36.89 24.40 23.05 3.13
3.70
22
851 00 T 22..
P
S
. 50.. 851 00 RT 22..
P
S
. 50..
45.30
44.20
34.95 14.35 2.15 38.20 31.75 39.99 27.50 25.55 3.13
3.70
24
851 00 T 24..
P
S
. 50.. 851 00 RT 24..
P
S
. 50..
44.00
42.60
38.12 15.20 2.15 41.30 34.92 43.15 30.60 28.65 3.81
3.70
P
S
7.20
J
P
S
P
S
851 00 RT 8..
solder
B
max
A
Square flange receptacle with removable backshell for screen termination
and heatshrink sleeving (38 & 42 suffix)
Shell
size
8
851 00 T 8..
10
851 00 T 10..
12
38
. 50 42
P
S
. 50
38
42
851 00 T 12..
P
S
. 50 38
42
14
851 00 T 14..
P
S
. 50
38
42
16
851 00 T 16..
P
S
. 50 38
42
18
851 00 T 18..
P
S
. 50
38
42
851 00 T 20..
P
S
. 50 38
42
22
851 00 T 22..
P
S
. 50
38
42
24
851 00 T 24..
P
S
. 50 38
42
851 00 RT 8..
ØJ
L max
crimp contacts
P
S
24
M
C
Part numbers
solder contacts
P
S
F
ØA
B
ØD
E
ØG
L
solder
38
. 50 42
38
crimp
A
B
max
C
max
D
max
E
F
max
G
max
J
M
max
51.60
12.03
11.70
1.32
18.25
15.09
20.99
7.45
3.13
3.70
51.60
15.01
11.70
1.32
20.25
18.26
24.19
9.00
3.13
3.70
851 00 RT 10..
P
S
. 50 42
851 00 RT 12..
P
S
. 50 38
42
51.60
19.07
11.70
1.32
24.75
20.62
26.54
13.30
3.13
3.70
851 00 RT 14..
P
S
. 50 38
42
51.60
22.25
11.70
1.32
27.75
23.00
28.89
16.50
3.13
3.70
851 00 RT 16..
P
S
. 50 38
42
51.60
25.42
11.70
1.32
30.05
24.61
31.29
18.50
3.13
3.70
851 00 RT 18..
P
S
. 50 38
42
52.00
28.60
11.70
1.32
34.15
26.97
33.69
21.90
3.13
3.70
851 00 RT 20..
P
S
. 50 38
42
55.10
31.77
14.35
2.15
37.25
29.36
36.89
25.10
3.13
3.70
851 00 RT 22..
P
S
. 50 38
42
55.10
34.95
14.35
2.15
40.45
31.75
39.99
28.20
3.13
3.70
851 00 RT 24..
P
S
. 50 38
42
55.10
38.12
15.20
2.15
43.65
34.92
43.15
31.40
3.81
3.70
Cable in line receptacle with straight adaptor
L
P
Shell
size
Part numbers
solder contacts
8
851 01 A 8..
P
S
L max
crimp contacts
. 50..
851 01 RA 8..
solder
. 50 ..
P
S
ØD
ØF
C
B
max
C
max
D
max
F
max
G
max
UNEF 2A
P
max
12.03
10.60
2.10
14.50
24.24
9.10
1/2 28
20.99
crimp
41.00
K
A
threading
10
851 01 A 10..
P
S
. 50..
851 01 RA 10..
P
S
12
851 01 A 12..
P
S
. 50..
851 01 RA 12..
P
S
14
851 01 A 14.. PS . 50..
851 01 RA 14..
P
S
. 50..
41.00
22.25
10.60
2.10
25.10
32.10
18.15
7/8 20
28.89
16
. 50..
41.00
25.42
10.60
2.10
28.13
34.59
21.32
1-20
31.29
. 50..
41.00
15.01
10.60
2.10
18.70
27.44
12.08
5/8 24
24.19
. 50..
41.00
19.07
10.60
2.10
21.70
29.79
15.25
3/4 20
26.54
851 01 A 16..
P
S
. 50..
851 01 RA 16..
P
S
18
851 01 A 18..
P
S
. 50..
851 01 RA 18..
P
S
. 50..
41.00
28.60
10.60
2.10
31.38
36.94
24.32 1-3/16 18
33.69
851 01 A 20..
P
S
. 50..
851 01 RA 20..
P
S
. 50..
44.00
31.77
13.85
2.65
34.30
40.15
26.73 1-3/16 18
36.89
22
851 01 A 22..
P
S
. 50..
851 01 RA 22..
P
S
. 50..
44.00
34.95
13.85
2.65
37.60
42.24
30.67 1-7/16 18
40.00
24
851 01 A 24..
P
S
. 50..
851 01 RA 24..
P
S
. 50..
44.00
38.12
14.70
2.65
40.70
46.44
33.08 1-7/16 18
43.29
Connector
B
K
HE 301 B 01 A
HE 301 B 01 RA
ØA
01 A
01 RA
ØG
Cross reference
Cable in line receptacle with straight cable clamp
L
Cross reference
HE 301 B 01 EC
01 EC
HE 301 B 01 AC
D
ØA
ØG
MS 3111 F
01 AC
HE 301 B 01 RC
01 RC
Shell
size
P
MS 3121 F
B
Part numbers
solder contacts
8
851 01 EC
AC 8..
10
851 01
12
crimp contacts
. 50..
851 01 RC 8..
10..
P
S
. 50..
851 01 EC
AC 12..
P
S
. 50..
14
851 01
14..
P
S
16
851 01 EC
AC 16..
P
S
18
EC
AC
EC
AC
P
S
L max
solder
crimp
ØF
C
A
B
max
C
max
D
max
F
max
G
P
max
. 50 ..
48.00
47.30
12.03
10.60
2.10
19.90
24.24
3.50
20.99
851 01 RC 10..
P
S
. 50..
48.00
47.30
15.01
10.60
2.10
21.50
27.44
5.00
24.19
851 01 RC 12..
P
S
. 50..
48.00
47.30
19.07
10.60
2.10
25.00
29.79
8.20
26.54
. 50..
851 01 RC 14..
P
S
. 50..
48.00
47.30
22.25
10.60
2.10
27.80
32.10
10.00
28.89
. 50..
851 01 RC 16..
P
S
. 50..
51.00
50.50
25.42
10.60
2.10
29.40
34.59
13.00
31.29
P
S
851 01
EC
AC
18..
P
S
. 50..
851 01 RC 18..
P
S
. 50..
51.00
50.50
28.60
10.60
2.10
35.30
36.94
16.00
33.69
EC
AC
20..
P
S
. 50..
851 01 RC 20..
P
S
. 50..
53.00
51.50
31.77
13.85
2.65
35.30
40.14
16.00
36.89
22
851 01 EC
AC 22..
P
S
. 50..
851 01 RC 22..
P
S
. 50..
53.00
51.50
34.95
13.85
2.65
41.10
43.24
19.30
40.00
24
851 01
P
S
. 50..
851 01 RC 24..
P
S
. 50..
53.00
51.50
38.12
14.70
2.65
42.40
46.44
20.60
43.29
EC
AC
24..
25
Cable in line receptacle with backnut
L
P
Cross reference
ØA
MS 3111 E
HE 301 B 01 R
01 R
ØD
HE 301 B 01 E
01 E
MS 3121 E
B
Shell
size
Part numbers
solder contacts
8
851 01 E 8..
10
851 01 E 10..
12
ØF
C
L max
crimp contacts
solder
crimp
A
B
max
C
max
D
max
F
max
P
max
. 50..
851 01 R 8..
P
S
. 50..
851 01 R 10..
P
S
851 01 E 12..
P
S
. 50..
851 01 R 12..
P
S
. 50..
32.70
32.00
19.07
10.60
2.10
19.90
29.79
26.54
14
851 01 E 14..
P
S
. 50..
851 01 R 14..
P
S
. 50..
32.70
32.00
22.25
10.60
2.10
23.40
32.10
28.89
16
851 01 E 16..
P
S
. 50..
851 01 R 16..
P
S
. 50..
32.70
32.00
25.42
10.60
2.10
26.60
34.59
31.29
18
851 01 E 18..
P
S
. 50..
851 01 R 18..
P
S
. 50..
32.70
32.00
28.60
10.60
2.10
29.50
36.94
33.69
851 01 E 20..
P
S
. 50..
851 01 R 20..
P
S
. 50..
34.50
33.40
31.77
13.85
2.65
32.70
40.14
36.89
22
851 01 E 22..
P
S
. 50..
851 01 R 22..
P
S
. 50..
34.50
33.40
34.95
13.85
2.65
36.00
43.24
40.00
24
851 01 E 24..
P
S
. 50..
851 01 R 24..
P
S
. 50..
34.50
33.40
38.12
14.70
2.65
39.10
46.44
43.29
P
S
P
S
. 50..
32.70
32.00
12.03
10.60
2.10
13.50
24.24
20.99
. 50..
32.70
32.00
15.01
10.60
2.10
16.70
27.44
24.19
Cable in line receptacle with removable straight backshell for screen termination
L
B
Shell
size
8
851 01 G 8..
10
ØF
L max
crimp contacts
solder
crimp
A
B
max
C
max
D
max
F
max
G
max
M
max
P
max
. 50..
851 01 RG 8..
. 50 ..
54.00
12.03
10.60
2.10
16.30
24.24
7.45
3.60
20.99
851 01 G 10..
P
S
. 50..
851 01 RG 10.. PS . 50..
54.00
15.01
10.60
2.10
18.30
27.44
10.30
3.60
24.19
12
851 01 G 12..
P
S
. 50..
851 01 RG 12..
. 50..
54.00
19.07
10.60
2.10
22.30
29.79
13.20
3.60
26.54
14
851 01 G 14..
P
S
. 50..
851 01 RG 14.. PS . 50..
54.00
22.25
10.60
2.10
25.30
32.10
16.50
3.60
28.89
16
851 01 G 16..
P
S
. 50..
851 01 RG 16..
. 50..
54.00
25.42
10.60
2.10
28.30
34.59
19.35
3.60
31.29
18
851 01 G 18..
P
S
. 50..
851 01 RG 18.. PS . 50..
54.00
28.60
10.60
2.10
32.30
36.94
21.60
3.60
33.69
851 01 G 20..
P
S
. 50..
851 01 RG 20..
. 50..
59.30
31.77
13.85
2.65
34.30
40.15
24.80
3.60
36.89
22
851 01 G 22..
P
S
. 50..
851 01 RG 22.. PS . 50..
59.30
34.95
13.85
2.65
38.30
42.24
27.90
3.60
40.00
24
851 01 G 24..
P
S
. 50..
851 01 RG 24..
59.30
38.12
14.70
2.65
41.30
46.44
31.00
3.60
43.29
26
M
C
Part numbers
solder contacts
ØD
ØA
ØG
P
P
S
P
S
P
S
P
S
P
S
P
S
. 50..
Cable in line receptacle with straight sealing gland backshell
L
P
ØA
B
Part numbers
Shell
size
solder contacts
8
851 01 J 8..
10
12
ØF
C
L max
crimp contacts
solder
crimp
G max
A
B
max
C
max
D
max
F
max
min
max
P
max
5.84
20.99
. 50..
47.60
12.03
10.60
2.10
14.40
24.24
5.02
851 01 J 10..
P
S
. 50..
47.60
15.01
10.60
2.10
17.60
27.44
5.94
6.76
24.19
851 01 J 12..
P
S
. 50..
48.70
19.07
10.60
2.10
21.10
29.79
9.34
10.16
26.54
14
851 01 J 14..
P
S
. 50..
53.50
22.25
10.60
2.10
24.40
32.10
11.32
12.14
28.89
16
851 01 J 16..
P
S
. 50..
59.00
25.42
10.60
2.10
27.60
34.59
14.73
15.55
31.29
18
851 01 J 18..
P
S
. 50..
65.00
28.60
10.60
2.10
30.80
36.94
16.00
16.82
33.69
851 01 J 20..
P
S
. 50..
79.10
31.77
13.85
2.65
34.10
40.15
16.89
17.71
36.89
22
851 01 J 22..
P
S
. 50..
80.00
34.95
13.85
2.65
37.30
42.24
17.78
18.60
40.00
24
851 01 J 24..
P
S
. 50..
90.00
38.12
14.70
2.65
40.50
46.44
20.34
21.16
43.29
P
S
Connector
HE 301 B 01 J
ØD
01 J
ØG
Cross reference
Cable in line receptacle with straight sealing gland and cable clamp backshell
L
P
HE 301 B 01 J
B
Shell
size
Part numbers
solder contacts
ØD
ØA
01 JC
ØG
Cross reference
ØF
C
L max
crimp contacts
solder
crimp
G
A
B
max
C
max
D
max
F
max
min
max
P
max
8
851 01 JC 8..
.50..
57.68
12.03
10.60
2.10
19.90
24.24
5.02
5.84
20.99
10
851 01 JC 10.. PS .50..
57.68
15.01
10.60
2.10
21.50
27.44
5.94
6.76
24.19
12
14
P
S
851 01 JC 12..
P
S
.50..
61.24
19.07
10.60
2.10
25.00
29.79
9.34
10.16
26.54
851 01 JC 14..
P
S
.50..
66.01
22.25
10.60
2.10
27.80
32.10
11.32
12.14
28.89
16
851 01 JC 16.. .50..
74.75
25.42
10.60
2.10
29.40
34.59
14.73
15.50
31.29
18
851 01 JC 18.. PS .50..
80.57
28.60
10.60
2.10
35.30
36.94
16.00
16.82
33.69
851 01 JC 20.. .50..
91.69
31.77
13.85
2.65
35.30
40.15
16.89
17.71
36.89
22
851 01 JC 22.. PS .50..
95.66
34.95
13.85
2.65
41.10
42.24
17.78
18.60
40.00
24
851 01 JC 24.. .50..
101.22
38.12
14.70
2.65
42.40
46.44
20.34
21.16
43.29
P
S
P
S
P
S
27
Cable connecting receptacle with removable straight backshell for heatshrink sleeving
P
ØA
ØG
ØD
L
M
B
Shell
size
ØF
C
Part numbers
solder contacts
8
851 01 M 8..
10
12
L max
crimp contacts
.50..
851 01 RM 8..
851 01 M 10..
P
S
.50..
851 01 M 12..
P
S
.50..
14
851 01 M 14..
P
S
16
851 01 M 16..
P
S
18
solder
crimp
A
B
max
C
max
D
max
F
max
G
max
P
max
M
max
7.05
20.99
3.50
.50 ..
50.00
12.03
10.60
2.10
13.55
24.24
851 01 RM 10..
P
S
.50..
50.00
15.01
10.60
2.10
15.35
27.44
9.90
24.19
3.50
851 01 RM 12..
P
S
.50..
50.00
19.07
10.60
2.10
19.48
29.79
12.60
26.54
3.50
.50..
851 01 RM 14..
P
S
.50..
50.00
22.25
10.60
2.10
21.30
32.10
15.90
28.89
3.50
.50..
851 01 RM 16..
P
S
.50..
50.00
25.42
10.60
2.10
24.50
34.59
18.95
31.29
3.50
851 01 M 18..
P
S
.50..
851 01 RM 18..
P
S
.50..
50.00
28.60
10.60
2.10
26.45
36.94
20.90
33.69
3.50
851 01 M 20..
P
S
.50..
851 01 RM 20..
P
S
.50..
53.30
31.77
13.85
2.65
30.75
40.15
23.70
36.89
3.50
22
851 01 M 22..
P
S
.50..
851 01 RM 22..
P
S
.50..
53.30
34.95
13.85
2.65
34.24
42.24
26.60
40.00
3.50
24
851 01 M 24..
P
S
.50..
851 01 RM 24..
P
S
.50..
53.30
38.12
14.70
2.65
36.47
46.44
29.30
43.29
3.50
P
S
P
S
Cable connecting receptacle with straight backshell for potting
P
L
Cross reference
MS 3121 P
B
Part numbers
solder contacts
8
851 01 P 8..
10
851 01 P 10..
12
14
L max
crimp contacts
ØF
C
solder
crimp
A
B
max
C
max
D
max
F
max
G
max
P
max
. 50..
851 01 RP 8..
. 50 ..
36.20
41.70
12.03
10.60
2.10
15.34
24.24
10.46
20.99
P
S
. 50..
851 01 RP 10..
P
S
. 50..
36.20
41.70
15.01
10.60
2.10
17.70
27.44
13.55
24.19
851 01 P 12..
P
S
. 50..
851 01 RP 12..
P
S
. 50..
36.20
41.70
19.07
10.60
2.10
21.69
29.79
13.96
26.54
851 01 P 14..
P
S
. 50..
851 01 RP 14..
P
S
. 50..
36.20
41.70
22.25
10.60
2.10
23.90
32.10
17.42
28.89
16
851 01 P 16..
P
S
. 50..
851 01 RP 16..
P
S
. 50..
36.20
41.70
25.42
10.60
2.10
27.00
34.59
20.56
31.29
18
851 01 P 18..
P
S
. 50..
851 01 RP 18..
P
S
. 50..
36.91
44.46
28.60
10.60
2.10
30.50
36.94
23.66
33.69
851 01 P 20..
P
S
. 50..
851 01 RP 20..
P
S
. 50..
43.80
50.93
31.77
13.85
2.65
33.65
40.15
23.92
36.89
22
851 01 P 22..
P
S
. 50..
851 01 RP 22..
P
S
. 50..
43.80
50.93
34.95
13.85
2.65
37.10
42.24
25.52
40.00
24
851 01 P 24..
P
S
. 50..
851 01 RP 24..
P
S
. 50..
43.80
50.93
38.12
14.70
2.65
40.00
46.44
32.00
43.29
28
ØD
HE 301 B 01 RP
01 RP
Shell
size
ØA
MS 3111 P
ØG
HE 301 B 01 P
01 P
P
S
P
S
Cable in line receptacle with straight backshell for heatshrink sleeving
L
ØD
ØA
ØG
P
M
Shell
size
ØF
C
Part numbers
solder contacts
8
851 01 T 8..
crimp contacts
.50..
P
S
L max
851 01 RT 8..
.50..
P
S
solder
crimp
36.70
36.00
G max
A
B
max
C
max
D
max
F
max
solder
crimp
P
max
M
max
12.03
10.60
2.10
15.35
24.24
7.20
6.70
20.99 3.70
24.19 3.70
10
851 01 T 10.. .50..
851 01 RT 10.. .50..
36.70
36.00
15.01
10.60
2.10
18.15
27.44
10.20
9.40
12
851 01 T 12.. PS .50..
851 01 RT 12.. PS .50..
36.70
36.00
19.07
10.60
2.10
23.45
29.70
13.20
11.95 26.54 3.70
14
851 01 T 14.. PS .50..
851 01 RT 14.. PS .50..
36.70
36.00
22.25
10.60
2.10
24.25
32.10
16.10
15.15 28.89 3.70
16
851 01 T 16.. PS .50..
851 01 RT 16.. PS .50..
39.00
38.30
25.42
10.60
2.10
29.55
34.59
19.25
18.05 31.29 3.70
18
851 01 T 18.. PS .50..
851 01 RT 18.. PS .50..
39.00
38.30
28.60
10.60
2.10
31.75
36.94
21.30
19.95 33.69 3.70
851 01 T 20.. PS .50..
851 01 RT 20.. PS .50..
45.30
44.20
31.77
13.85
2.65
35.85
40.15
24.40
23.05 36.89 3.70
22
851 01 T 22.. PS .50..
851 01 RT 22.. PS .50..
45.30
44.20
34.95
13.85
2.65
38.20
42.24
27.50
25.55 40.00 3.70
24
851 01 T 24.. PS .50..
851 01 RT 24.. PS .50..
44.00
42.60
38.12
14.70
2.65
41.30
46.44
30.60
28.65 43.29 3.70
P
S
P
S
Connector
B
Cable connecting receptacle with removable straight backshell for screen termination
L
ØD
ØA
ØG
P
M
B
Shell
size
Part numbers
solder contacts
8
851 01 T 8.. PS .50
10
851 01 T 10..
P
S
P
S
L max
crimp contacts
38
42
ØF
C
38
42
crimp
A
B
max
C
max
D
max
F
max
G
max
M
max
P
max
51.60
12.03
10.60
2.10
18.25
24.24
7.45
3.70
20.99
.50
38
42
51.60
15.01
10.60
2.10
20.25
27.44
9.00
3.70
24.19
851 01 RT 12..
P
S
.50
38
42
51.60
19.07
10.60
2.10
24.75
29.79
13.30
3.70
26.54
851 01 RT 14..
P
S
.50
38
42
51.60
22.25
10.60
2.10
27.75
32.10
16.50
3.70
28.89
16
851 01 T 16..
38
42
851 01 RT 16..
P
S
.50
38
42
51.60
25.42
10.60
2.10
30.05
34.59
18.50
3.70
31.29
18
851 01 T 18.. PS .50 38
42
851 01 RT 18..
P
S
.50
38
42
52.00
28.60
10.60
2.10
34.15
36.94
21.90
3.70
33.69
851 01 T 20..
38
42
851 01 RT 20..
P
S
.50
38
42
55.10
31.77
13.85
2.65
37.25
40.15
25.10
3.70
36.89
22
851 01 T 22.. PS .50 38
42
851 01 RT 22..
P
S
.50
38
42
55.10
34.95
13.85
2.65
40.45
42.24
28.20
3.70
40.00
24
851 01 T 24..
851 01 RT 24..
P
S
.50
38
42
55.10
38.12
14.70
2.65
43.65
46.44
31.40
3.70
43.29
.50
38
42
.50
851 01 RT 8.. PS .50
solder
851 01 RT 10..
P
S
12
851 01 T 12..
38
42
14
851 01 T 14.. PS .50 38
42
P
S
P
S
P
S
.50
.50
.50
38
42
29
Square flange receptacle not accepting backshell
L
Cross reference
E
HE 301 B 02 E
02 E
F
ØA
VG 95328 H
ØD
MS 3112 E
HE 301 B 02 R
02 R
MS 3122 E
B
VG 95328 C
Shell
size
Part numbers
solder contacts
8
851 02 E 8..
10
ØJ
C
L max
crimp contacts
solder
crimp
A
B
max
C
max
D
max
E
F
max
J
. 50..
851 02 R 8..
. 50 ..
25.18
32.35
12.03
11.70
1.32
10.84
15.09
20.99
3.13
851 02 E 10..
P
S
. 50..
851 02 R 10..
P
S
. 50..
25.10
32.35
15.01
11.70
1.32
13.99
18.26
24.19
3.13
12
851 02 E 12..
P
S
. 50..
851 02 R 12..
P
S
. 50..
25.10
32.35
19.07
11.70
1.32
17.37
20.62
26.54
3.13
14
851 02 E 14..
P
S
. 50..
851 02 R 14..
P
S
. 50..
25.10
32.35
22.25
11.70
1.32
20.57
23.00
28.89
3.13
16
851 02 E 16..
P
S
. 50..
851 02 R 16..
P
S
. 50..
25.10
32.35
25.42
11.70
1.32
23.72
24.61
31.29
3.13
18
851 02 E 18..
P
S
. 50..
851 02 R 18..
P
S
. 50..
25.10
32.35
28.60
11.70
1.32
26.69
26.97
33.69
3.13
851 02 E 20..
P
S
. 50..
851 02 R 20..
P
S
. 50..
26.67
33.95
31.77
14.35
2.15
29.89
29.36
36.89
3.13
22
851 02 E 22..
P
S
. 50..
851 02 R 22..
P
S
. 50..
26.67
33.95
34.95
14.35
2.15
33.04
31.75
39.99
3.13
24
851 02 E 24..
P
S
. 50..
851 02 R 24..
P
S
. 50..
26.67
33.95
38.12
15.20
2.15
36.24
34.92
43.15
3.81
P
S
P
S
Jam nut receptacle not accepting backshell
L
P
HE 301 B 07 A
S
07 A
ØA
Cross reference
B
Shell
size
Part numbers
solder contacts
8
851 07 A 8..
. 50..
L max
crimp contacts
solder
crimp
25.18
A
B
max
C
max
F
max
P
max
S
max
12.03
17.90
2.64
26.94
19.29
23.94
10
851 07 A 10..
P
S
12
851 07 A 12..
P
S
14
851 07 A 14..
P
S
. 50..
25.10
22.25
17.90
2.64
38.04
30.33
34.94
16
851 07 A 16..
P
S
. 50..
25.10
25.42
17.90
2.64
41.24
33.48
38.24
18
851 07 A 18..
P
S
. 50..
25.10
28.60
17.90
2.64
44.44
36.68
41.34
. 50..
25.10
15.01
17.90
2.64
30.14
22.38
26.94
. 50..
25.10
19.07
17.90
2.64
34.94
27.13
31.74
851 07 A 20..
P
S
. 50..
26.67
31.77
22.45
3.44
49.14
39.83
46.04
22
851 07 A 22..
P
S
. 50..
26.67
34.95
22.45
3.44
52.24
43.03
49.24
24
851 07 A 24..
P
S
. 50..
26.67
38.12
23.30
3.44
55.54
46.18
52.74
30
P
S
ØF
C
Jam nut receptacle with straight cable clamp
Cross reference
L
P
HE 301 B 07 EC
07 EC
S
ØD
ØA
HE 301 B 07 AC
ØG
MS 3114 F
07 AC
HE 301 B 07 RC
MS 3124 F
VG 95328 E
Shell
size
B
Part numbers
solder contacts
8
851 07 EC
AC 8..
10
851 07
12
L max
crimp contacts
. 50..
851 07 RC 8..
10..
P
S
. 50..
851 07 EC
AC 12..
P
S
. 50..
EC
AC
P
S
solder
crimp
ØF
C
A
B
max
C
max
D
max
F
max
G
P
max
S
max
. 50 ..
49.31
49.10
12.03
17.90
2.64
19.90
26.94
3.50
19.29
23.94
851 07 RC 10..
P
S
. 50..
49.31
49.10
15.01
17.90
2.64
21.50
30.14
5.00
22.38
26.94
851 07 RC 12..
P
S
. 50..
49.17
49.10
19.07
17.90
2.64
25.00
34.94
8.20
27.13
31.74
P
S
14
851 07
14..
P
S
. 50..
851 07 RC 14..
P
S
. 50..
49.17
49.10
22.25
17.90
2.64
27.80
38.04
10.00
30.33
34.94
16
851 07 EC
AC 16..
P
S
. 50..
851 07 RC 16..
P
S
. 50..
52.34
52.20
25.42
17.90
2.64
29.40
41.24
13.00
33.48
38.24
EC
AC
18
851 07
18..
P
S
. 50..
851 07 RC 18..
P
S
. 50..
53.22
53.10
28.60
17.90
2.64
35.30
44.44
16.00
36.68
41.34
851 07 EC
AC 20..
P
S
. 50..
851 07 RC 20..
P
S
. 50..
58.10
58.00
31.77
22.45
3.44
35.30
49.14
16.00
39.83
46.04
. 50..
851 07 RC 22..
P
S
. 50..
58.10
58.00
34.95
22.45
3.44
41.10
52.24
19.30
43.03
49.24
. 50..
851 07 RC 24..
P
S
. 50..
58.10
58.00
38.12
23.30
3.44
42.40
55.54
20.60
46.18
52.74
EC
AC
EC
AC
22
851 07
22..
P
S
24
851 07 EC
AC 24..
P
S
Connector
07 RC
Jam nut receptacle with backnut
L
Cross reference
HE 301 B 07 R
07 R
MS 3124 E
VG 95328 D
Shell
size
S
MS 3114 E
ØD
HE 301 B 07 E
ØA
07 E
P
B
Part numbers
solder contacts
L max
crimp contacts
solder
crimp
. 50 ..
ØF
C
A
B
max
C
max
D
max
F
max
P
max
S
max
8
851 07 E 8..
34.10
33.50
12.03
17.90
2.64
18.50
26.94
19.29
23.94
10
851 07 E 10..
P
S
. 50..
851 07 R 10..
P
S
. 50..
34.10
33.50
15.01
17.90
2.64
21.70
30.14
22.38
26.94
12
851 07 E 12..
P
S
. 50..
851 07 R 12..
P
S
. 50..
34.10
33.50
19.07
17.90
2.64
24.90
34.94
27.13
31.74
14
851 07 E 14..
P
S
. 50..
851 07 R 14..
P
S
. 50..
34.10
33.50
22.25
17.90
2.64
28.10
38.04
30.33
34.94
16
851 07 E 16..
P
S
. 50..
851 07 R 16..
P
S
. 50..
34.10
33.50
25.42
17.90
2.64
31.20
41.24
33.48
38.24
18
851 07 E 18..
P
S
. 50..
851 07 R 18..
P
S
. 50..
34.10
33.50
28.60
17.90
2.64
34.40
44.44
36.68
41.34
851 07 E 20..
P
S
. 50..
851 07 R 20..
P
S
. 50..
39.30
37.90
31.77
22.45
3.44
38.30
49.14
39.83
46.04
22
851 07 E 22..
P
S
. 50..
851 07 R 22..
P
S
. 50..
39.30
37.90
34.95
22.45
3.44
41.50
52.24
43.03
49.24
24
851 07 E 24..
P
S
. 50..
851 07 R 24..
P
S
. 50..
39.30
37.90
38.12
22.30
3.44
44.70
55.54
46.18
52.74
P
S
. 50..
851 07 R 8..
P
S
31
Jam nut receptacle with removable straight backshell for screen termination
L
P
B
Shell
size
Part numbers
solder contacts
8
851 07 G 8..
10
C
L max
crimp contacts
solder
crimp
S
VG 95328 T
ØD
ØA
07 G
07 RG
ØG
Cross reference
M
ØF
A
B
max
C
max
D
max
F
max
G
max
M
max
P
max
S
max
. 50
851 07 RG 8..
. 50
62.20
12.03
17.90
2.64
16.30
26.94
7.45
3.60
19.29 23.94
851 07 G 10..
P
S
. 50
851 07 RG 10..
P
S
. 50
62.20
15.01
17.90
2.64
18.30
30.14
10.30
3.60
22.38 26.94
12
851 07 G 12..
P
S
. 50
851 07 RG 12..
P
S
. 50
62.20
19.07
17.90
2.64
22.30
34.94
13.20
3.60
27.13 31.74
14
851 07 G 14..
P
S
. 50
851 07 RG 14..
P
S
. 50
62.40
22.25
17.90
2.64
25.30
38.04
16.50
3.60
30.33 34.94
16
851 07 G 16..
P
S
. 50
851 07 RG 16..
P
S
. 50
62.40
25.42
17.90
2.64
28.30
41.24
19.35
3.60
33.48 38.24
18
851 07 G 18..
P
S
. 50
851 07 RG 18..
P
S
. 50
62.40
28.60
17.90
2.64
32.30
44.44
21.60
3.60
36.68 41.34
851 07 G 20..
P
S
. 50
851 07 RG 20..
P
S
. 50
67.50
31.77
22.45
3.44
34.30
49.14
24.80
3.60
39.83 46.04
22
851 07 G 22..
P
S
. 50
851 07 RG 22..
P
S
. 50
67.50
34.95
22.45
3.44
38.30
52.24
27.90
3.60
43.03 49.24
24
851 07 G 24..
P
S
. 50
851 07 RG 24..
P
S
. 50
67.50
38.12
23.30
3.44
41.30
55.54
31.00
3.60
46.18 52.74
P
S
P
S
Jam nut receptacle with straight backshell for potting
L
P
Cross reference
HE 301 B 07 RP
07 RP
MS 3124 P
B
Shell
size
Part numbers
solder contacts
8
851 07 P 8..
10
851 07 P 10..
12
L max
crimp contacts
solder
crimp
ØF
C
A
B
max
C
max
D
max
F
max
G
max
P
max
S
max
. 50..
851 07 RP 8..
P
S
. 50..
851 07 RP 10..
P
S
851 07 P 12..
P
S
. 50..
851 07 RP 12..
P
S
. 50..
34.30
39.80
19.07
17.90
2.64
21.69
34.94
13.96
27.13
31.74
14
851 07 P 14..
P
S
. 50..
851 07 RP 14..
P
S
. 50..
34.30
39.80
22.25
17.90
2.64
23.90
38.04
17.42
30.33
34.94
16
851 07 P 16..
P
S
. 50..
851 07 RP 16..
P
S
. 50..
34.30
39.80
25.42
17.90
2.64
27.00
41.24
20.56
33.48
38.24
18
851 07 P 18..
P
S
. 50..
851 07 RP 18..
P
S
. 50..
34.10
41.80
28.60
17.90
2.64
30.50
44.44
23.66
36.68
41.34
851 07 P 20..
P
S
. 50..
851 07 RP 20..
P
S
. 50..
42.25
49.92
31.77
22.45
3.44
33.65
49.14
23.92
39.83
46.04
22
851 07 P 22..
P
S
. 50..
851 07 RP 22..
P
S
. 50..
42.25
49.92
34.95
22.45
3.44
37.10
52.24
25.52
43.03
49.24
24
851 07 P 24..
P
S
. 50..
851 07 RP 24..
P
S
. 50..
43.26
51.30
38.12
23.30
3.44
40.00
55.54
32.00
46.18
52.74
32
S
MS 3114 P
ØD
ØA
ØG
HE 301 B 07 P
07 P
P
S
P
S
. 50 ..
34.30
39.80
12.03
17.90
2.64
15.34
26.94
10.46
19.29
23.94
. 50..
34.30
39.80
15.01
17.90
2.64
17.70
30.14
13.55
22.38
26.94
Jam nut receptacle with straight backshell for heatshrink sleeving
P
L
07 RT
VG 95328 S
M
Part numbers
solder contacts
8
851 07 T 8..
P
S
L max
crimp contacts
. 50..
851 07 RT 8..
. 50 ..
P
S
solder
crimp
42.60
41.50
ØF
C
B
max
A
C
max
D
max
G max
F
max Solder Crimp
12.03 17.90 2.64 15.35 26.94 7.20
M
max
P
max
S
max
6.70
3.70 19.29 23.94
41.50
15.01 17.90 2.64 18.15 30.14 10.20 9.40
3.70 22.38 26.94
41.50
19.07 17.90 2.64 23.45 34.94 13.20 11.95 3.70 27.13 31.74
10
851 07 T 10..
P
S
. 50..
851 07 RT 10..
P
S
12
851 07 T 12..
P
S
. 50..
851 07 RT 12..
P
S
14
851 07 T 14..
P
S
. 50..
851 07 RT 14..
P
S
. 50..
42.60
41.50
22.25 17.90 2.64 24.25 38.04 16.10 15.15 3.70 30.33 34.94
16
851 07 T 16..
P
S
. 50..
851 07 RT 16..
P
S
. 50..
44.40
43.80
25.42 17.90 2.64 29.55 41.24 19.25 18.05 3.70 33.48 38.24
18
851 07 T 18..
P
S
. 50..
851 07 RT 18..
P
S
. 50..
44.40
43.80
28.60 17.90 2.64 31.75 44.44 21.30 19.95 3.70 36.68 41.24
851 07 T 20..
P
S
. 50..
851 07 RT 20..
P
S
. 50..
50.90
49.80
31.77 22.45 3.44 35.85 49.14 24.40 23.05 3.70 39.83 46.04
22
851 07 T 22..
P
S
. 50..
851 07 RT 22..
P
S
. 50..
50.90
49.80
34.95 22.45 3.44 38.20 52.24 27.50 25.55 3.70 43.03 49.24
24
851 07 T 24..
P
S
. 50..
851 07 RT 24..
P
S
. 50..
49.90
48.50
38.12 23.30 3.44 41.30 55.54 30.60 28.65 3.70 46.18 52.74
. 50..
42.60
. 50..
42.60
Connector
B
Shell
size
S
ØD
ØA
07 T
ØG
Cross reference
P
M
B
Shell
size
851 07 T 8..
10
851 07 T 10..
P
S
12
14
. 50 42
P
S
L max
crimp contacts
38
8
851 07 RT 8..
ØF
C
Part numbers
solder contacts
solder
38
crimp
A
B
max
C
max
D
max
F
max
G
max
M
max
P
max
S
max
60.00
12.03
17.90
2.64
18.25
26.94
7.45
3.70
19.29 23.94
851 07 RT 10..
P
S
. 50 42
38
60.00
15.01
17.90
2.64
20.25
30.14
9.00
3.70
22.38 26.94
. 50
38
42
P
S
. 50 42
S
ØD
ØA
ØG
L
. 50
38
42
851 07 T 12..
P
S
. 50
38
42
851 07 RT 12..
P
S
60.00
19.07
17.90
2.64
24.75
34.94
13.30
3.70
27.13 31.74
851 07 T 14..
P
S
. 50 38
42
851 07 RT 14..
P
S
. 50 38
42
60.00
22.25
17.90
2.64
27.75
38.04
16.50
3.70
30.33 34.94
16
851 07 T 16..
P
S
. 50
38
42
851 07 RT 16..
P
S
. 50
38
42
60.00
25.42
17.90
2.64
30.05
41.24
18.50
3.70
33.48 38.24
18
851 07 T 18..
P
S
. 50 38
42
851 07 RT 18..
P
S
. 50 38
42
60.40
28.60
17.90
2.64
34.15
44.44
21.90
3.70
36.68 41.34
851 07 T 20..
P
S
. 50
38
42
851 07 RT 20..
P
S
. 50
38
42
63.40
31.77
22.45
3.44
37.25
49.14
25.10
3.70
39.83 46.04
22
851 07 T 22..
P
S
. 50 38
42
851 07 RT 22..
P
S
. 50 38
42
63.40
34.95
22.45
3.44
40.45
52.24
28.20
3.70
43.03 49.24
24
851 07 T 24..
P
S
. 50
851 07 RT 24..
P
S
. 50
63.40
38.12
23.30
3.44
43.65
55.54
31.40
3.70
46.18 52.74
38
42
38
42
33
Plug with straight adaptor
L
ØA
Shell
size
Part numbers
solder contacts
8
851 06 A 8 ..
P
S
L max
crimp contacts
. 50..
851 06 RA 8 ..
. 50 ..
P
S
solder
crimp
A
max
41.00
41.00
19.05
D
HE 301 B 06 A
HE 301 B 06 RA
ØK
06 A
06 RA
ØG
Cross reference
D
max
G
max
F
threading
UNEF 2A
14.50
9.10
1/2 28
10
851 06 A 10 ..
P
S
. 50..
851 06 RA 10 ..
P
S
12
851 06 A 12 ..
P
S
. 50..
851 06 RA 12 ..
P
S
14
851 06 A 14 ..
P
S
. 50..
851 06 RA 14 ..
P
S
. 50..
41.00
41.00
29.35
25.10
18.15
7/8 20
16
851 06 A 16 ..
P
S
. 50..
851 06 RA 16 ..
P
S
. 50..
41.00
41.00
32.50
28.13
21.32
1-20
18
851 06 A 18 ..
P
S
. 50..
851 06 RA 18 ..
P
S
. 50..
41.00
41.00
35.30
31.38
24.32
1-3/16 18
851 06 A 20 ..
P
S
. 50..
851 06 RA 20 ..
P
S
. 50..
44.00
43.30
38.85
34.30
26.73
1-3/16 18
22
851 06 A 22 ..
P
S
. 50..
851 06 RA 22 ..
P
S
. 50..
44.00
43.30
42.05
37.60
30.67
1-7/16 18
24
851 06 A 24 ..
P
S
. 50..
851 06 RA 24 ..
P
S
. 50..
44.00
43.50
45.10
40.70
33.08
1-7/16 18
. 50..
41.00
41.00
21.80
18.70
12.08
5/8 24
. 50..
41.00
41.00
26.15
21.70
15.25
3/4 20
Plug with straight cable clamp
Cross reference
L
HE 301 B 06 EC
06 EC
ØA
MS 3116 F
06 AC
HE 301 B 06 AC
06 RC
D
ØG
HE 301 B 06 RC
MS 3126 F
VG 95328 K
Shell
size
Part numbers
solder contacts
8
851 06 EC
AC 8 ..
10
851 06
12
solder
crimp
A
max
D
max
G
. 50..
851 06 RC 8 ..
P
S
. 50..
851 06 RC 10 ..
851 06 EC
AC 12 ..
P
S
. 50..
851 06 RC 12 ..
P
S
. 50..
48.00
47.30
26.15
25.00
8.20
14
851 06
14 ..
P
S
. 50..
851 06 RC 14 ..
P
S
. 50..
48.00
47.30
29.35
27.80
10.00
16
851 06 EC
AC 16 ..
P
S
. 50..
851 06 RC 16 ..
P
S
. 50..
51.00
50.50
32.50
29.40
13.00
18
851 06
18 ..
P
S
. 50..
851 06 RC 18 ..
P
S
. 50..
51.00
50.50
35.30
35.30
16.00
851 06 EC
AC 20 ..
P
S
. 50..
851 06 RC 20 ..
P
S
. 50..
52.00
50.20
38.85
35.30
16.00
22
851 06
22 ..
P
S
. 50..
851 06 RC 22 ..
P
S
. 50..
52.00
50.20
42.05
41.10
19.30
24
851 06 EC
AC 24 ..
P
S
. 50..
851 06 RC 24 ..
P
S
. 50..
52.00
50.20
45.10
42.40
20.60
EC
AC
EC
AC
EC
AC
EC
AC
34
L max
crimp contacts
10 ..
P
S
P
S
P
S
. 50 ..
48.00
47.30
19.05
19.90
3.50
. 50..
48.00
47.30
21.80
21.50
5.00
Plug with backnut
L
Cross reference
Shell
size
MS 3116 E
HE 301 B 06 R
MS 3126 E
Part numbers
solder contacts
8
851 06 E 8 ..
P
S
L max
crimp contacts
. 50..
851 06 R 8 ..
. 50 ..
P
S
solder
crimp
A
max
D
max
32.54
32.00
19.05
13.50
10
851 06 E 10 ..
P
S
. 50..
851 06 R 10 ..
P
S
12
851 06 E 12 ..
P
S
. 50..
851 06 R 12 ..
P
S
14
851 06 E 14 ..
P
S
. 50..
851 06 R 14 ..
P
S
. 50..
32.54
32.00
29.35
23.40
16
851 06 E 16 ..
P
S
. 50..
851 06 R 16 ..
P
S
. 50..
32.54
32.00
32.50
26.60
18
851 06 E 18 ..
P
S
. 50..
851 06 R 18 ..
P
S
. 50..
32.54
32.00
35.30
29.60
851 06 E 20 ..
P
S
. 50..
851 06 R 20 ..
P
S
. 50..
33.30
32.10
38.85
32.70
22
851 06 E 22 ..
P
S
. 50..
851 06 R 22 ..
P
S
. 50..
33.30
32.10
42.05
36.00
24
851 06 E 24 ..
P
S
. 50..
851 06 R 24 ..
P
S
. 50..
33.30
32.10
45.10
39.10
. 50..
32.54
32.00
21.80
16.70
. 50..
32.54
32.00
26.15
19.90
Connector
06 R
HE 301 B 06 E
D
06 E
ØA
Plug with straight sealing gland backshell
L
ØA
Shell
size
ØG
HE 301 B 06 J
Part numbers
solder contacts
L max
crimp contacts
ØD
Cross reference
06 J
G max
solder
crimp
A
max
D
max
min
max
8
851 06 J 8 ..
. 50..
47.60
19.05
14.40
5.02
5.84
10
851 06 J 10 ..
P
S
. 50..
47.60
21.80
17.60
5.94
6.76
12
851 06 J 12 ..
P
S
. 50..
49.20
26.15
21.10
9.34
10.16
14
851 06 J 14 .. PS . 50..
54.00
29.35
24.40
11.32
12.14
16
18
P
S
851 06 J 16 ..
P
S
. 50..
59.60
32.50
27.60
14.73
15.55
851 06 J 18 ..
P
S
. 50..
65.60
35.30
30.80
16.00
16.80
851 06 J 20 ..
P
S
. 50..
78.00
38.85
34.10
16.89
17.71
22
851 06 J 22 ..
P
S
. 50..
79.50
42.05
37.30
17.78
18.60
24
851 06 J 24 ..
P
S
. 50..
90.00
45.10
40.50
20.34
21.16
35
Plug with straight sealing gland and cable clamp backshells
L
ØA
06 JC
Shell
size
ØG
MS 3116 J
Part numbers
L max
ØD
Cross reference
crimp contacts
solder
crimp
min
max
8
851 06 JC 8 ..
. 50..
57.68
19.05
19.90
5.02
5.84
10
851 06 JC 10 .. PS . 50..
57.68
21.80
21.50
5.94
6.76
12
851 06 JC 12 .. PS . 50..
61.24
26.15
25.00
9.34
10.16
14
851 06 JC 14 .. PS . 50..
66.01
29.35
27.80
11.32
12.14
16
851 06 JC 16 .. PS . 50..
74.75
32.50
29.40
14.73
15.50
18
851 06 JC 18 ..
. 50..
80.57
35.30
35.30
16.00
16.82
851 06 JC 20 .. PS . 50..
91.69
38.85
35.30
16.89
17.71
22
851 06 JC 22 ..
. 50..
95.66
42.05
41.10
17.78
18.60
24
851 06 JC 24 .. PS . 50..
101.22
45.10
42.40
20.34
21.16
solder contacts
P
S
P
S
P
S
D
max
G max
A
max
Plug with long metallic adaptor and plastic cable gland
E
D
ØG
ØC
Shell
size
Part numbers
solder contacts
E
maxi
ØC
maxi
mini
maxi
8
851 06L 8
57.00
81.00
19.30
4.00
5.00
10
851 06L 10
P
S
57.00
84.00
22.00
4.00
6.00
12
851 06L 12
P
S
57.00
86.00
26.30
4.00
7.00
14
851 06L 14
P
S
57.00
87.00
29.50
4.00
9.00
16
851 06L 16
P
S
57.00
90.00
32.70
6.00
12.00
P
S
Black anodized* See page 12 "obligatory specification". Example: 85106L123P54
36
ØG
D
maxi
Plug with removable straight backshell for heatshrink sleeving
ØA
ØD
ØG
L
Shell
size
Part numbers
solder contacts
8
851 06 M 8 ..
P
S
L max
crimp contacts
. 50..
851 06 RM 8 ..
. 50 ..
P
S
solder
crimp
50.00
A
max
D
max
G
max
M
max
19.05
13.55
7.05
3.50
10
851 06 M 10 ..
P
S
. 50..
851 06 RM 10 ..
P
S
12
851 06 M 12 ..
P
S
. 50..
851 06 RM 12 ..
P
S
14
851 06 M 14 ..
P
S
. 50..
851 06 RM 14 ..
P
S
. 50..
50.00
29.35
21.30
15.90
3.50
16
851 06 M 16 ..
P
S
. 50..
851 06 RM 16 ..
P
S
. 50..
50.00
32.50
24.50
18.95
3.50
18
851 06 M 18 ..
P
S
. 50..
851 06 RM 18 ..
P
S
. 50..
50.00
35.30
26.45
20.90
3.50
851 06 M 20 ..
P
S
. 50..
851 06 RM 20 ..
P
S
. 50..
52.00
38.85
30.73
23.70
3.50
22
851 06 M 22 ..
P
S
. 50..
851 06 RM 22 ..
P
S
. 50..
52.00
42.05
34.24
26.60
3.50
24
851 06 M 24 ..
P
S
. 50..
851 06 RM 24 ..
P
S
. 50..
52.00
45.10
36.47
29.30
3.50
. 50..
50.00
21.80
15.35
9.90
3.50
. 50..
50.00
26.15
19.48
12.60
3.50
Connector
M
Plug with short metallic adaptor and plastic cable gland with spiral protector
B
ØC
ØG
A
Shell
size
Part numbers
solder contacts
8
851 06NS 8
10
12
P
S
A
maxi
B
maxi
ØC
maxi
ØG
mini
maxi
37.00
91.00
19.30
4.00
6.50
37.00
101.00
22.00
4.00
7.00
37.00
114.00
26.30
4.00
7.00
851 06NS 10
P
S
851 06NS 12
P
S
14
851 06NS 14
P
S
37.00
125.00
29.50
4.00
7.00
16
851 06NS 16
P
S
42.00
144.00
32.70
6.00
11.0
Black anodized* See page 12 "obligatory specification". Example: 85106NS123P54
37
Plug with long metallic adaptor and plastic cable gland with spiral protector
B
ØC
ØG
A
Shell
size
Part numbers
solder contacts
D
maxi
E
maxi
ØC
maxi
ØG
mini
maxi
8
851 06NL 8
10
851 06NL 10
P
S
12
851 06NL 12
P
S
57.00
134.00
26.30
4.00
7.00
14
851 06NL 14
P
S
57.00
145.00
29.50
4.00
7.00
16
851 06NL 16
P
S
57.00
159.00
32.70
6.00
11.0
P
S
57.00
111.00
19.30
4.00
6.50
57.00
121.00
22.00
4.00
7.00
Black anodized* See page 12 "obligatory specification". Example: 85106NL123P54
Plug with straight backshell for potting
L
Cross reference
HE 301 B 06 RP
06 RP
MS 3126 P
Part numbers
solder contacts
L max
crimp contacts
solder
crimp
A
max
D
max
G
8
851 06 P 8 ..
. 50 ..
36.20
42.10
19.05
15.34
10.46
10
851 06 P 10 ..
P
S
. 50..
851 06 RP 10 ..
P
S
. 50..
36.20
42.10
21.80
17.70
13.55
12
851 06 P 12 ..
P
S
. 50..
851 06 RP 12 ..
P
S
. 50..
36.20
42.10
26.15
21.69
13.96
14
851 06 P 14 .. PS . 50..
851 06 RP 14 ..
P
S
. 50..
36.20
42.10
29.35
23.90
17.42
16
18
P
S
. 50..
851 06 RP 8 ..
P
S
851 06 P 16 ..
P
S
. 50..
851 06 RP 16 ..
P
S
. 50..
36.20
42.10
32.50
27.00
20.56
851 06 P 18 ..
P
S
. 50..
851 06 RP 18 ..
P
S
. 50..
37.70
45.40
35.30
30.50
23.66
851 06 P 20 ..
P
S
. 50..
851 06 RP 20 ..
P
S
. 50..
42.40
50.00
38.85
33.65
23.92
22
851 06 P 22 ..
P
S
. 50..
851 06 RP 22 ..
P
S
. 50..
42.40
50.00
42.05
37.10
25.52
24
851 06 P 24 ..
P
S
. 50..
851 06 RP 24 ..
P
S
. 50..
42.85
50.00
45.10
40.00
32.00
38
ØG
MS 3116 P
ØD
HE 301 B 06 P
06 P
Shell
size
ØA
B
A
ØG
ØC
Part numbers
solder contacts
8
851 06S 8
10
12
P
S
ØG
A
maxi
B
maxi
ØC
maxi
mini
maxi
37.00
61.00
19.30
4.00
5.00
851 06S 10
P
S
37.00
64.00
22.00
4.00
6.00
851 06S 12
P
S
37.00
66.00
26.30
4.00
7.00
14
851 06S 14
P
S
37.00
67.00
29.50
4.00
9.00
16
851 06S 16
P
S
42.00
75.00
32.70
6.00
12.00
Connector
Shell
size
Black anodized* See page 12 "obligatory specification". Example: 85106S123P54
Plug with straight backshell for heatshrink sleeving
L
ØA
ØG
06 T
06 RT
VG 95328 J
D
Cross reference
M
Shell
size
Part numbers
solder contacts
8
851 06 T 8..
10
851 06 T 10..
12
14
L max
crimp contacts
solder
crimp
A
max
D
max
G max
Solder
Crimp
M
max
. 50..
851 06 RT 8..
. 50 ..
36.70
36.00
19.05
15.35
7.20
6.70
3.70
P
S
. 50..
851 06 RT 10..
P
S
. 50..
36.70
36.00
21.80
18.15
10.20
9.40
3.70
851 06 T 12..
P
S
. 50..
851 06 RT 12..
P
S
. 50..
36.70
36.00
26.15
23.45
13.20
11.95
3.70
851 06 T 14..
P
S
. 50..
851 06 RT 14..
P
S
. 50..
36.70
36.00
29.35
24.25
16.10
15.15
3.70
16
851 06 T 16..
P
S
. 50..
851 06 RT 16..
P
S
. 50..
39.00
38.30
32.50
29.55
19.25
18.05
3.70
18
851 06 T 18..
P
S
. 50..
851 06 RT 18..
P
S
. 50..
39.00
38.30
35.30
31.75
21.30
19.95
3.70
851 06 T 20..
P
S
. 50..
851 06 RT 20..
P
S
. 50..
44.00
42.90
38.85
35.85
24.40
23.05
3.70
22
851 06 T 22..
P
S
. 50..
851 06 RT 22..
P
S
. 50..
44.00
42.90
42.05
38.20
27.50
25.55
3.70
24
851 06 T 24..
P
S
. 50..
851 06 RT 24..
P
S
. 50..
42.70
41.60
45.10
41.30
30.60
28.65
3.70
P
S
P
S
39
Plug with straight adaptor for electrical pitch access
ØA
D
The Z type special adaptor which equips crimp
plug 851 06 RZ fits following accessories.
- Packing gland collet backshell
- Backshell for polyflex sleeving
- Backshell for C.N.O.M.O. tube
ØC
L
B
Part numbers
L max
Shell
size
solder contacts
crimp contacts
8
10
12
851 06 Z 12 ..
14
solder
crimp
B
max
C
max
D
threading
PE
43.00
26.15
9.10
24.80
11
P
S
. 50..
851 06 RZ 12 ..
851 06 Z14 ..
P
S
. 50..
851 06 RZ 14 ..
P
S
. 50..
45.00
29.35
11.00
28.80
16
16
851 06 Z 16 ..
P
S
. 50..
851 06 RZ 16 ..
P
S
. 50..
45.00
32.50
11.00
30.80
16
18
851 06 Z 18 ..
P
S
. 50..
851 06 RZ 18 ..
P
S
. 50..
46.00
35.30
12.00
40.80
21
851 06 Z 20 ..
P
S
. 50..
851 06 RZ 20 ..
P
S
. 50..
46.50
38.85
12.00
40.80
21
22
851 06 Z 22 ..
P
S
. 50..
851 06 RZ 22 ..
P
S
. 50..
46.50
42.05
12.00
40.80
21
24
851 06 Z24 ..
P
S
. 50..
851 06 RZ 24 ..
P
S
. 50..
65.50
45.10
31.40
45.00
29
P
S
. 50..
A
max
Plug with elbow cable clamp backshell
L
ØA
08 EC
HE 301 B 08 EC
08 RC
HE 301 B 08 RC
R
Cross reference
ØG
Shell
size
Part numbers
solder contacts
8
851 08 EC 8 ..
10
851 08 EC 10 ..
12
14
solder
crimp
A
max
D
max
G
R
max
. 50..
851 08 RC 8 ..
. 50..
50.10
19.05
19.70
3.50
16.00
P
S
. 50..
851 08 RC 10 ..
P
S
. 50..
52.60
21.80
21.20
5.00
18.00
851 08 EC 12 ..
P
S
. 50..
851 08 RC 12 ..
P
S
. 50..
54.90
26.15
24.20
8.20
19.50
851 08 EC 14 ..
P
S
. 50..
851 08 RC 14 ..
P
S
. 50..
58.50
29.35
27.50
10.00
22.00
. 50..
60.80
32.50
29.10
13.00
23.50
. 50..
65.00
35.30
35.70
16.00
25.00
P
S
P
S
16
851 08 EC 16 ..
P
S
. 50..
851 08 RC 16 ..
P
S
18
851 08 EC 18 ..
P
S
. 50..
851 08 RC 18 ..
P
S
851 08 EC 20 ..
P
S
. 50..
851 08 RC 20 ..
P
S
. 50..
69.10
38.85
35.70
16.00
26.50
22
851 08 EC 22 ..
P
S
. 50..
851 08 RC 22 ..
P
S
. 50..
71.00
42.05
39.70
19.30
28.00
24
851 08 EC 24 ..
P
S
. 50..
851 08 EC 24 ..
P
S
. 50..
75.50
45.10
43.50
20.60
31.00
40
L max
crimp contacts
D
Plug with elbow backshell for potting
L
ØA
HE 301 B 08 P
HE 301 B 08 RP
S
G
Shell
size
Part numbers
solder contacts
8
851 08 P 8 ..
P
S
L max
crimp contacts
. 50..
851 08 RP 8 ..
solder
. 50..
P
S
A
max
G
max
R
max
S
max
19.05
8.10
11.70
11.30
crimp
40.70
10
851 08 P 10 ..
P
S
. 50..
851 08 RP 10 ..
P
S
12
851 08 P 12 ..
P
S
. 50..
851 08 RP 12 ..
P
S
. 50..
49.20
29.35
16.10
16.30
20.10
. 50..
50.60
32.50
16.90
19.30
22.80
. 50..
44.90
21.80
11.30
14.35
14.50
. 50..
46.90
26.15
13.30
15.90
17.70
14
851 08 P 14 ..
P
S
. 50..
851 08 RP 14 ..
P
S
16
851 08 P 16 ..
P
S
. 50..
851 08 RP 16 ..
P
S
. 50..
51.80
35.30
18.10
20.60
25.60
. 50..
53.70
38.85
19.70
21.90
28.80
18
851 08 P 18 ..
P
S
. 50..
851 08 RP 18 ..
P
S
851 08 P 20 ..
P
S
. 50..
851 08 RP 20 ..
P
S
22
851 08 P 22 ..
P
S
. 50..
851 08 RP 22 ..
P
S
. 50..
54.80
42.05
20.80
23.50
31.60
24
851 08 P 24 ..
P
S
. 50..
851 08 RP 24 ..
P
S
. 50..
58.20
45.10
24.20
30.15
35.20
Connector
08 P
08 RP
R
Cross reference
Shielded plug with straight adaptor
L
ØA
Cross reference
Shell
size
Part numbers
solder contacts
L max
crimp contacts
solder
crimp
D
VG 95328 N
ØK
36 RA
ØG
36 A
A
max
D
max
G
max
F
threading
UNEF 2A
8
851 36 A 8 ..
. 50..
851 36 RA 8 ..
10
851 36 A 10 ..
P
S
. 50..
851 36 RA 10 ..
P
S
12
851 36 A 12 ..
P
S
. 50..
851 36 RA 12 ..
P
S
. 50..
41.00
26.15
21.70
15.25
3/4 20
14
851 36 A 14 ..
P
S
. 50..
851 36 RA 14 ..
P
S
. 50..
41.00
29.35
25.10
18.15
7/8 20
16
851 36 A 16 ..
P
S
. 50..
851 36 RA 16 ..
P
S
. 50..
41.00
32.50
28.13
21.32
1-20
18
851 36 A 18 ..
P
S
. 50..
851 36 RA 18 ..
P
S
. 50..
41.00
35.30
31.38
24.32
1-3/16 18
851 36 A 20 ..
P
S
. 50..
851 36 RA 20 ..
P
S
. 50..
43.30
38.85
34.30
26.73
1-3/16 18
22
851 36 A 22 ..
P
S
. 50..
851 36 RA 22 ..
P
S
. 50..
43.30
42.05
37.60
30.67
1-7/16 18
24
851 36 A 24 ..
P
S
. 50..
851 36 RA 24 ..
P
S
. 50..
43.50
45.10
40.70
33.08
1-7/16 18
P
S
P
S
. 50..
41.00
19.05
14.50
9.10
1/2 28
. 50..
41.00
21.80
18.70
12.08
5/8 24
41
Shielded plug with removable straight backshell for
screen termination and heatshrink sleeving
L
ØA
ØG
36 G
36 RG
VG 95328 M
ØD
Cross reference
M
Shell
size
Part numbers
solder contacts
8
851 36 G 8 ..
P
S
L max
crimp contacts
. 50..
851 36 RG 8 .. PS . 50..
solder
A
max
D
max
G
max
M
max
19.05
16.30
7.45
3.60
crimp
54.00
10
851 36 G10 ..
P
S
. 50..
851 36 RG 10 ..
P
S
12
851 36 G 12 ..
P
S
. 50..
851 36 RG 12 ..
P
S
14
851 36 G 14 ..
P
S
. 50..
851 36 RG 14 ..
P
S
. 50..
54.00
29.35
25.30
16.50
3.60
16
851 36 G 16 ..
P
S
. 50..
851 36 RG 16 ..
P
S
. 50..
54.00
32.50
28.30
19.35
3.60
18
851 36 G 18 ..
P
S
. 50..
851 36 RG 18 ..
P
S
. 50..
54.00
35.30
32.30
21.60
3.60
851 36 G 20 ..
P
S
. 50..
851 36 RG 20 ..
P
S
. 50..
58.00
38.85
34.30
24.80
3.60
22
851 36 G 22 ..
P
S
. 50..
851 36 RG 22 ..
P
S
. 50..
58.00
42.05
38.30
27.90
3.60
24
851 36 G 24 ..
P
S
. 50..
851 36 RG 24 ..
P
S
. 50..
58.00
45.10
41.30
31.00
3.60
. 50..
54.00
21.80
18.30
10.30
3.60
. 50..
54.00
26.15
22.30
13.20
3.60
Shielded plug with removable straight backshell for screen termination
ØA
ØD
ØG
L
M
Shell
size
Part numbers
solder contacts
8
851 36 T 8 ..
10
851 36 T 10 ..
12
. 50..
38
42
851 36 RT 8 ..
P
S
solder
crimp
A
max
D
max
G
max
M
max
. 50..
51.60
19.05
18.25
7.45
3.70
. 50..
51.60
21.80
20.25
9.00
3.70
. 50..
38
42
851 36 RT 10 ..
P
S
. 50..
38
42
851 36 RT 12 ..
P
S
. 50..
51.60
26.15
24.75
13.30
3.70
851 36 T 14 ..
P
S
. 50..
38
42
851 36 RT 14 ..
P
S
. 50..
51.60
29.35
27.75
16.50
3.70
16
851 36 T 16 ..
P
S
. 50..
38
42
851 36 RT 16 ..
P
S
. 50..
51.60
32.50
30.05
18.50
3.70
18
851 36 T 18 ..
P
S
. 50..
38
42
851 36 RT 18 ..
P
S
. 50..
52.00
35.30
34.15
21.90
3.70
851 36 T 20 ..
P
S
. 50..
38
42
851 36 RT 20 ..
P
S
. 50..
53.90
38.85
37.25
25.10
3.70
22
851 36 T 22 ..
P
S
. 50..
38
42
851 36 RT 22 ..
P
S
. 50..
53.90
42.05
40.45
28.20
3.70
24
851 36 T 24 ..
P
S
. 50..
38
42
851 36 RT 24 ..
P
S
. 50..
53.90
45.10
43.65
31.40
3.70
P
S
851 36 T 12 ..
14
42
P
S
L max
crimp contacts
P
S
Hermetic connectors
B
F
J
C
Cross reference
ØE
H
ØL
D
Shell
size
Part numbers
A
max
B
C
D
E
F
max
H
max
J
L
8
851 02 H 8 .. PS . 50..
12.03
13.84
11.24
1.55
14.27
7.5
21.03
15.09
3.15
10
851 02 H 10 .. . 50..
15.01
13.84
11.24
1.55
17.07
7.5
24.23
18.26
3.15
12
851 02 H 12 .. PS . 50..
19.07
13.84
11.24
1.55
19.84
7.5
26.59
20.62
3.15
14
851 02 H 14 .. . 50..
22.25
13.84
11.24
1.55
23.01
7.5
28.98
23.00
3.15
16
851 02 H 16 .. PS . 50..
25.42
13.84
11.24
1.55
26.19
7.5
31.34
24.61
3.15
18
851 02 H 18 .. . 50..
28.60
13.84
11.24
1.55
29.36
7.5
33.73
26.97
3.15
851 02 H 20 .. PS . 50..
31.77
15.42
12.00
2.36
31.75
7.5
36.91
29.36
3.15
22
8851 02 H 22 .. . 50..
34.95
16.23
12.00
2.36
34.92
7.5
40.10
31.75
3.15
24
851 02 H 24 .. PS . 50..
38.12
17.04
12.81
2.36
38.10
6.7
43.27
34.92
3.82
P
S
P
S
P
S
P
S
Connector
HE 301 B 02 H
ØA
02 H
Jam nut receptacle
B
E
Cross reference
F
MS 3114 H
ØA
07 H
ØG
HE 301 B 07 H
VG 95328 F
ØD
C
Shell
size
Part numbers
A
max
B
max
C
D
max
E
max
F
G
max
8
851 07 H 8 .. PS . 50..
12.03
20.60
17.93
27.37
24.07
13.33
14.26
10
851 07 H 10 .. PS . 50..
15.01
20.60
17.93
30.57
27.22
16.51
17.43
12
851 07 H 12 .. . 50..
19.07
20.60
17.93
35.32
32.00
20.63
22.19
14
851 07 H 14 .. PS . 50..
22.25
20.60
17.93
38.50
35.17
23.78
25.36
16
851 07 H 16 .. . 50..
25.42
20.60
17.93
41.67
38.35
26.93
28.54
18
851 07 H 18 .. PS . 50..
28.60
20.60
17.93
44.85
41.52
30.10
31.71
851 07 H 20 .. . 50..
31.77
26.15
22.70
49.62
46.27
33.28
34.89
22
8851 07 H 22 ..PS . 50..
34.95
26.15
22.70
52.77
49.47
36.45
38.06
24
851 07 H 24 .. . 50..
38.12
26.98
23.54
55.97
52.62
39.63
41.24
P
S
P
S
P
S
P
S
43
Hermetic connectors
Solder fixing receptacle
B
ØG
C
Cross reference
MS 3113 H
ØE
ØA
HE 301 B 1H
IH
VG 95328 G
D
Shell
size
Part numbers
A
max
B
C
D
E
F
max
G
max
8
851 IH 8 .. PS . 50..
12.03
13.84
10.70
0.80
14.27
8.60
16.40
10
851 IH 10 .. . 50..
15.01
13.84
10.70
0.80
17.07
8.60
19.40
12
851 IH 12 .. PS . 50..
19.07
13.84
10.70
0.80
19.84
8.60
21.80
14
851 IH 14 .. . 50..
22.25
13.84
10.70
0.80
23.01
8.60
25.00
16
851 IH 16 .. PS . 50..
25.42
13.84
10.70
0.80
26.19
8.60
28.10
18
851 IH 18 .. . 50..
28.60
13.84
10.70
0.80
29.36
8.60
31.30
851 IH 20 .. PS . 50..
31.77
15.42
12.70
0.80
31.75
8.60
33.70
22
8851 IH 22 .. . 50..
34.95
16.23
12.70
0.80
34.92
8.60
36.90
24
851 IH 24 .. PS . 50..
38.12
17.04
13.10
0.80
38.10
7.80
40.10
P
S
P
S
P
S
P
S
44
PC Tail connectors
L
A
B
max
C
max
ØD
max
E
F
max
J
L
max
T
+1.25
851 02 E 8..
P
S
.50.. 16
40
12.03
11.70
1.32
10.84
15.09
20.99
3.13
20.50
9.46
10
851 02 E 10.. .50..
16
40
15.01
11.70
1.32
13.99
18.26
24.19
3.13
20.50
9.46
12
851 02 E 12.. PS .50.. 16
40
19.07
11.70
1.32
17.37
20.62
26.54
3.13
20.50
9.46
14
851 02 E 14.. PS .50.. 16
40
22.25
11.70
1.32
20.57
23.00
28.89
3.13
20.50
9.46
16
851 02 E 16.. PS .50.. 16
40
25.42
11.70
1.32
23.62
24.61
31.29
3.13
20.50
9.46
18
851 02 E 18.. PS .50.. 16
40
28.60
11.70
1.32
26.69
26.97
33.69
3.13
20.50
9.46
851 02 E 20.. PS .50.. 16
40
31.77
14.35
2.15
29.89
29.36
36.89
3.13
23.80
7.76
22
851 02 E 22.. PS .50.. 16
40
34.95
14.35
2.15
33.04
31.75
39.99
3.13
23.80
7.76
24
851 02 E 24.. PS .50.. 16
40
38.12
15.20
2.15
36.24
34.92
43.15
3.81
23.80
7.76
P
S
Connector
C
Part numbers
8
F
ØD
ØA
B
Shell
size
E
T
Jam nut receptacle
L
P
S
ØA
T
B
Shell
size
Part numbers
ØF
C
A
B
max
C
max
F
max
L
max
P
max
S
max
T
+1.25
851 07 A 8..
16
40
12.03
17.90
2.64
26.94
20.64
19.29
23.94
9.46
10
851 07 A 10.. PS .50.. 16
40
15.01
17.90
2.64
30.14
20.64
22.38
26.95
9.46
12
851 07 A 12.. PS .50.. 16
40
19.07
17.90
2.64
34.94
20.64
27.13
31.74
9.46
14
851 07 A 14.. PS .50.. 16
40
22.25
17.90
2.64
38.04
20.64
30.33
34.94
9.46
16
851 07 A 16.. PS .50.. 16
40
25.42
17.90
2.64
41.26
20.64
33.48
38.24
9.46
18
851 07 A 18.. PS .50.. 16
40
28.60
17.90
2.64
44.44
20.64
36.68
41.34
9.46
851 07 A 20.. PS .50.. 16
40
31.77
22.45
3.44
49.14
25.99
39.83
46.04
8.49
22
851 07 A 22.. PS .50.. 16
40
34.95
22.45
3.44
52.24
25.99
43.03
49.24
8.49
24
851 07 A 24.. PS .50.. 16
40
38.12
23.30
3.44
55.54
26.84
46.18
52.74
7.79
P
S
.50..
45
Panel cut out
Receptacle
Shell
size
A±0.1
B±0.1
C±0.1
E±0.15
J±0.15
8
15.55
14.60
14.70
15.10
10
18.80
17.75
17.50
12
22.15
22.50
14
25.30
25.70
16
28.45
18
31.65
24
N
P±0.1
X
min
3.17
13.75
2.90
1.57
3.17
16.95
2.90
3.15
1.57
3.17
21.50
2.90
3.15
1.57
3.17
24.20
2.90
24.60
3.15
1.57
3.17
27.35
2.90
26.97
3.15
1.57
3.17
30.55
2.90
32.10
29.36
3.15
1.57
6.35
33.70
5.50
35.30
31.75
3.15
1.57
6.35
36.90
5.50
38.40
34.92
3.82
1.57
6.35
40.05
5.50
min
max
3.15
1.57
18.26
3.15
20.20
20.62
23.40
23.00
28.85
26.60
32.05
29.80
34.80
35.20
38.00
38.40
41.20
41.55
46
Jam nut receptacle
Backshell / Ordering information
Shell size
Backnut
Straight cable
clamp
Straight
backshell
for potting
(nut+potting)
Straight
adaptor
Straight
backshell for
heatshrink
sleeving
Removable
straight
backshell for
heatshrink
sleeving
Removable
termination
& heatshrink
sleeving
Straight
sealing gland
backshell
Straight
sealing gland
& cable clamp
backshell
Short backshell
for screen
termination
& heatshrink
sleeving
Straight
adaptor for
electrical pitch
access
E
R
EC
or
AC
RC
Plating*
Std
29 31
44
Std
29 31
44
8
10
12
14
16
18
24
8500-5882 LP
8500-5883 LP
8500-5884 LP
8500-5885 LP
8500-5886 LP
8500-5887 LP
8500-5888 LP
8500-5889 LP
8500-5890 LP
8500-5882 110
8500-5883 110
8500-5884 110
8500-5885 110
8500-5886 110
8500-5887 110
8500-5888 110
8500-5889 110
8500-5890 110
8500-5882 202
8500-5883 202
8500-5884 202
8500-5885 202
8500-5886 202
8500-5887 202
8500-5888 202
8500-5889 202
8500-5890 202
8500-2469 900
8500-2470 900
8500-2471 900
8500-2472 900
8500-2473 900
8500-2474 900
8500-2475 900
8500-2476 900
8500-2477 900
8500-2469 902
8500-2470 902
8500-2471 902
8500-2472 902
8500-2473 902
8500-2474 902
8500-2475 902
8500-2476 902
8500-2477 902
8500-2469 903
8500-2470 903
8500-2471 903
8500-2472 903
8500-2473 903
8500-2474 903
8500-2475 903
8500-2476 903
8500-2477 903
Nut
P
RP
Std
8500-1559 LP
8500-1560 LP
8500-1561 LP
8500-1562 LP
8500-1563 LP
8500-1564 LP
8500-1565 LP
8500-1566 LP
8500-1567 LP
P
RP
8500-466
8500-467
8500-468
8500-469
8500-470
8500-471
8500-472
8500-473
8500-474
8500-682
8500-683
8500-684
8500-685
8500-686
8500-687
8500-688
8500-689
8500-690
A
RA
Std
8500-448 LP
8500-449 LP
8500-450 LP
8500-451 LP
8500-452 LP
8500-453 LP
8500-3185 LP
8500-3186 LP
8500-456 LP
Std
8500-4021 LP
8500-4022 LP
8500-4023 LP
8500-4024 LP
8500-4025 LP
8500-4026 LP
8500-4027 LP
8500-4028 LP
8500-4029 LP
T
RT
29 31
8500-4021 110
8500-4022 110
8500-4023 110
8500-4024 110
8500-4025 110
8500-4026 110
8500-4027 110
8500-4028 110
8500-4029 110
Std
8500-4045 900
8500-4046 900
8500-4047 900
8500-4048 900
8500-4049 900
8500-4050 900
8500-4051 900
8500-4052 900
8500-4053 900
Std
8501-0188 900
8500-8977 900
8501-0189 900
8500-8978 900
8501-0190 900
8500-8979 900
8500-8980 900
8500-8981 900
8500-8982 900
44
8501-0188 903
8500-8977 903
8501-0189 903
8500-8978 903
8501-0190 903
8500-8979 903
8500-8980 903
8500-8981 903
8500-8982 903
38
851 T 08-38
851 T 10-38
851 T 12-38
851 T 14-38
851 T 16-38
851 T 18-38
851 T 20-38
851 T 22-38
851 T 24-38
42
851 T 08-42
851 T 10-42
851 T 12-42
851 T 14-42
851 T 16-42
851 T 18-42
851 T 20-42
851 T 22-42
851 T 24-42
Sealing gland
8500-5873
8500-5874
8500-5875
8500-5876
8500-5877
8500-5878
8500-5879
8500-5880
8500-5881
Nut
Std
8500-5900 LP
8500-5901 LP
8500-5902 LP
8500-5903 LP
8500-5904 LP
8500-5905 LP
8500-5906 LP
8500-5907 LP
8500-5908 LP
Sealing gland
8500-5873
8500-5874
8500-5875
8500-5876
8500-5877
8500-5878
8500-5879
8500-5880
8500-5881
Nut
Std
8500-5989 900
8500-5990 900
8500-5991 900
8500-5992 900
8500-5993 900
8500-5994 900
8500-5995 900
8500-5996 900
8500-5997 900
Potting
M
RM
G
RG
T
RT
U
RU
Std
8500-8474 900
8500-8475 900
8500-8476 900
Z
RZ
Std
8500-8185 LP
8500-8186 LP
8500-8187 LP
8500-8188 LP
8500-8189 LP
8500-8190 LP
8500-8191A LP
47
Connector
Designation
Contact type
Solder
Crimp
Straight backshells for Receptacle 07 / Ordering information
Shell size
Designation
Contact type
Solder
Crimp
8
10
12
14
16
18
24
Std
29 31
44
8500-8347 LP
8500-374 LP
8500-375 LP
8500-376 LP
8500-377 LP
8500-378 LP
8500-379 LP
8500-380 LP
8500-381 LP
8500-8347 110
8500-374 110
8500-375 110
8500-376 110
8500-377 110
8500-378 110
8500-379 110
8500-380 110
8500-381 110
8500-8347 202
8500-374 202
8500-375 202
8500-376 202
8500-377 202
8500-378 202
8500-379 202
8500-380 202
8500-381 202
Backnut
E
Straight cable
clamp
EC
or
AC
RC
Std
8500-8351 900
8500-1790 900
8500-1791 900
8500-1792 900
8500-1793 900
8500-1794 900
8500-1795 900
8500-1796 900
8500-1797 900
P
8500-466
8500-467
8500-468
8500-469
8500-470
8500-471
8500-472
8500-473
8500-474
RP
8500-682
8500-683
8500-684
8500-685
8500-686
8500-687
8500-688
8500-689
8500-690
Std
8500-4776 LP
8500-4777 LP
8500-4778 LP
8500-4779 LP
8500-4780 LP
8500-4781 LP
8500-4782 LP
8500-4783 LP
8500-4784 LP
T
RT
29 31
8500-4776 110
8500-4777 110
8500-4778 110
8500-4779 110
8500-4780 110
8500-4781 110
8500-4782 110
8500-4783 110
8500-4784 110
Straight
backshell
for potting
Straight
backshell for
heatshrink
sleeving
R
Plating*
Elbow backshells / Ordering information
Shell size
Designation
Elbow cable
clamp
backshell
Contact type
Solder
Crimp
EC
RC
Plating*
8
10
12
14
16
18
24
Std
8500-791 900
8500-792 900
8500-793 900
8500-794 900
8500-795 900
8500-796 900
8500-3224 900
8500-3225 900
8500-799 900
29 31
8500-791 902
8500-792 902
8500-793 902
8500-794 902
8500-794 902
8500-795 902
8500-796 902
8500-3224 902
8500-799 902
*Plating:
Std olive green cadmium plating
29 black anodised (solder version)
031 black anodised (crimp version)
44 nickel plating
38 nickel plating for backshell for screen termination
42 olive green cadmium plating
48
General characteristics
• Locking: by pushing on the coupling nut
• Unlocking: by pulling a lanyard
• Mounted: on all 851 receptacles
• Layouts and crimp solder contacts: (see pages 14 & 15)
• cable gainé noir longueur déroulée 106 mm (for other length, consult us)
• Other characteristics: (see page 16)
Basic Series
856
00
E
8
3A
P
50
Shell type:
06 plug for use with straight backshell
08 plug for use with 90° backshell
Connector
Backshell type:
Solder Crimp
E
R backnut
EC
RC
A
RA
straight adaptor
P
RP
T
RT
M
RM
straight removable backshell for heatshrink sleeving
EC
RC
90° cable clamp
Shell size:
8 - 10 - 12 - 14 - 16 - 18 - 20 - 22 - 24
Contacts layout:
see pages 14 & 15
Contact type:
P male
S female
Orientation:
Normal (not included in part number). For others note: W, X, Y, Z - see table page 76
Obligatory suffix
50
Specification
07 olive-green cadmium plating (solder version)
08 olive green cadmium plating (crimp version)
09 white cadmium plating (crimp and solder version)
49
Shell size
Backshell
type
Dimension
8
10
12
14
16
18
24
All
A
19.50
22.80
27.30
30.80
34.00
37.00
41.00
44.50
49.20
All
B
24.95
28.25
32.55
36.05
39.05
42.05
45.80
49.20
53.45
06 R
E
32.00
32.00
32.00
32.00
32.00
32.00
31.80
31.80
31.80
06 RC
E
47.30
47.30
47.30
47.30
50.50
50.50
49.90
49.90
49.90
06 RP
E
42.10
42.10
42.10
42.10
42.10
45.40
49.80
49.80
49.80
06 RA
E
41.00
41.00
41.00
41.00
41.00
41.00
43.00
43.00
43.20
06 RM
E
50.00
50.00
50.00
50.00
50.00
50.00
51.70
51.70
51.70
06 RT
spécifications
38 or 42
E
50.00
50.00
50.00
50.00
50.00
50.00
51.70
51.70
51.70
E
50.10
52.60
54.90
58.50
60.80
65.00
68.80
71.20
76.20
D
max
16.00
18.00
19.50
22.00
23.50
25.00
26.50
28.00
31.00
08RC
Note : For backshells dimensioning, refer to values given in preceding pages
50
851 Series | Connector
8F51 filter connectors
General information
They are intermountable and intermateable
with standard connectors.
Different types of filters may be fitted in these
connectors to eliminate RFI/EMI in different
frequency ranges.
Using built-in High Performance EMI filters
offers the following advantages :
• Efficient filtering on interferences at electronic equipment input or output,
• Case screen-shielding efficiency is maintained,
• Cost and volume saving as compared with
the use of discrete filters wired down the
line,
• 4 types of standard filters are available Please consult us for other capacitance and
filter types,
• Combinations of mixed filter in the same
layout: filtered, non-filtered and grounded
contacts available.
• Max. current rating per contact: 7.5 A (#20),
13 A (#16)
• Max. operating voltage: 200 Vdc, 120 Vac
• Standard filter types: C, Pi
• Capacitance range: typically 500 pF - 200 nF
• Filter performance: up to -60dB / -80dB
For this product, consult our FILTER
CONNECTOR department.
An adaptor version is also a simple technique
to equip existing systems which do not incorporate filters.
Connector
These connectors are derived from standard
specifications
MIL-DTL-26482 G series 1 - NFC 93422 (HE
301 B) - VG 95328.
Electrical characteristics
51
SNC specific connectors and connection accessories
General information
specifications
301 B) - VG 95328.
frequency ranges.
maintained
the use of discrete filters wired down the line
• 4 types of standard filters are available.
filter types
contacts available.
7.5 A (#20),13 A (#16)
200 Vdc, 120 Vac
C, Pi
up to -60dB / -80dB
Designations
Part numbers
Square flange through bulkhead, pins, sockets
Shell sizes 8 to 24: layouts 8.03 / 10.06 / 12.10 / 14.19 / 16.26 / 18.32 / 20.41 / 22.55 / 24.61
Insert rotations: N & W
Plating: 085 green cadmium / 112 black anodized
EC 52 B
Short profile 90° backshell with cable clamp for 08 RC plug
Shell sizes 12, 14, 16, 18 and 22
SN 556
Plug and receptacle connector
Shell size 24 : contact layout = 3 contacts # 16, 7 contacts # 20, 1 coaxial contact 50 Ω (for KX15 cable)
SN 775 P
SN 775 S
Shunt plug
SN 901
Straight two-piece backshell with sealing gland and cable strap
Shell sizes 8, 10 and 16
SN 946
Plug with flanged coupling nut
Shell sizes 20, 22 and 24
SN 1167
Cable in line receptacle test connector, pins, sockets
Shell sizes 8 to 24, arrangements with size contacts # 20
SN 1206
Ring with lugs with cone-pointed grub screws fitting 851 plug
Shell sizes 8 to 24
SN 1277
Elbow backshell with closing sleeve for shield termination by magnaforming
Shell sizes 8 to 24
SN 1533
Jam nut receptacle with front release straight PC tails
Layouts: 14.19 (N) / 16.26 (N) / 18.32 (N, X) / 20.41 (N, W, X, Y) / 22.55 (N, W, X, Y, Z) / 24.61 (N)
Plating: passivated green cadmium
SN 0378
Other layouts, please consult us
52
Connector
Notes
53
851 SERIES
© 2016 SOURIAU - SOURIAU is a registered trademark
851 Series
Contacts & Accessories
Crimp contacts ................................................................................................................. 56
Caps / Ordering information ............................................................................................ 57
Plastic protective caps ...................................................................................................... 59
Filler plugs ........................................................................................................................ 59
Dummy receptacle ........................................................................................................... 60
Gaskets ............................................................................................................................. 60
55
851 Series | Contacts & Accessories
Crimp contacts
Standard version
Contact
size
#20
Ø1 mm
Wire size
Specification
AWG
mm²
For layouts
8-2, 8-3, 8-4 &
12-14
24-18
0.21-0.93
For further
contact layout
24-18
0.21-0.93
Reducing
sleeve
30-24
0.06-0.21
18-14
0.93-1.91
Reducing
sleeve
Part number
insulator Ø
Male
Female
8500-9573*
8500-9213 900*
8500-697
8500-1758A 900
8500-781 B1
8500-1300
#16
Ø1.6
mm
8500-9331 900
8500-1985 B1
min.
max.
1.20
2.11
1.20
2.11
1.60
2.80
Thermocouple version
Contact
size
Wire size
Specification
AWG
mm²
Chromel
24-18
0.21-0.93
Alumel
24-18
0.21-0.93
Chromel
18-14
0.93-1.91
Alumel
#20
Ø1 mm
#16
Ø1.6
mm
Note: all dimensions are in mm
56
Part number
insulator Ø
Male
Female
8500-809 A
8500-2054 900
8500-812 A
8500-2055 900
8500-1053
8500-1054 900
8500-812 A
8500-1059 900
min.
max.
1.20
2.11
1.20
2.11
1.60
2.80
1.60
2.80
Basic Series
Shell type:
Part numbers for receptacle
Part numbers for plug
8
02
10
10
03
11
12
04
12
14
05
13
16
27
28
18
06
14
8500
05
22
08
16
24
09
17
15
Specifications:
For cap & plating, see table below
Type and plating
Plug cap
Olive
White
Black
green
cadmium anodised
cadmium
Cap type
Nickel
Olive
White
Black
green
cadmium anodised
cadmium
Nickel
Cap with chain and ring
D
02 D
29 D
44 D
D
02 D
29 D
44 D
Cap with nylon cord and ring
B
02 B
29 B
44 B
B
02 B
29 B
44 B
Cap with nylon cord and washer (shell 10, 12 , 14, 16 & 18)
E
H
44 H
Cap with chain and washer
J
JQ7
M
M
Cap 500hr salt spray
Cap without chain
Receptacle cap
Caps for plugs
D
B&M
E
Shell size
ØA
max
B
max
C+60
D+20
E
ØF
8
16.80
19.84
132
128
consult us
consult us
10
19.80
19.84
132
128
132
14.00
12
23.90
19.84
148
140
148
17.60
14
27.00
19.84
148
140
148
20.80
16
30.20
19.84
148
140
148
25.60
18
33.40
19.84
148
140
148
28.70
21.44
168
153
consult us
consult us
22
39.80
21.44
168
153
consult us
consult us
24
42.90
22.22
168
153
consult us
consult us
57
Caps
Caps for receptacles
D
B&M
J & JQ7
H
Shell size
ØA
max
B
max
C+60
D+20
J
max
H+20
K+60
8
19.00
21.44
84
77
14.80
80
84
10
21.80
21.44
84
77
17.90
80
84
12
26.10
21.44
100
89
22.70
90
100
14
29.30
21.44
100
89
25.90
90
100
16
32.50
21.44
100
89
29.00
90
100
18
35.30
21.44
100
89
32.20
90
100
21.44
116
102
35.40
110
116
22
42.00
21.44
116
102
38.60
110
116
24
45.10
22.22
116
102
41.70
110
116
58
Accessories
Shell size
Caps for plugs
8
8500-5585 A
8500-5594
10
8500-5586 A
8500-5595
12
8500-5587 A
8500-5596
14
8500-5588 A
8500-5597
16
8500-5589 A
8500-5598
18
8500-5590 A
8500-5599
8500-5591 A
8500-5600
22
8500-5592 A
8500-5601
24
8500-5593 A
8500-5602
Plastic protective caps for receptacles and plugs
Filler plugs
Contact size
Part number
8500-4144
#20
Ø1 mm
Color
grey
8500-4144 A (MS 3187 A 20)
red
8500-479
#16
Ø1.6 mm
8500-4267 (MS 3187-16)
blue
59
Accessories
Dummy receptacles
F
ØA
E
M
ØJ
N
Shell size
Part numbers
A
C
max
E
J
M
max
N
max
8
8500-18
12.03
20.99
15.09
3.13
11.70
1.32
10
8500-19
15.01
24.19
18.26
3.13
11.70
1.32
12
8500-20
19.07
26.54
20.62
3.13
11.70
1.32
14
8500-21
22.25
28.89
23.00
3.13
11.70
1.32
16
8500-26
25.42
31.29
24.61
3.13
11.70
1.32
18
8500-22
28.60
33.69
26.97
3.13
11.70
1.32
31.77
36.89
29.36
3.13
14.35
2.15
22
8500-24
34.95
39.99
31.75
3.13
14.35
2.15
24
8500-25
38.12
43.15
34.92
3.81
15.20
2.15
Gaskets
Shell size
Fairprène
Gaskets for jam nut receptacle
Néoprène
Vitton
8
8500-275
8500-4164
3330102
3330675
10
8500-276
8500-4165
3330103
3330670
12
8500-277
8500-4166
3330104
3330671
14
8500-278
8500-4167
3330105
3330672
16
8500-283
8500-4168
3330106
3331048
18
8500-279
8500-4169
3330107
3331049
8500-4170
3330108
3331050
22
8500-281
8500-4171
3330109
3331051
24
8500-282
8500-4172
3330110
3331052
60
Gaskets for square flange receptacle
Néoprène
Notes
61
851 SERIES
851 Series
Technical Information
Tooling .............................................................................................................................. 64
Stripping instruction ......................................................................................................... 66
Crimping instruction ......................................................................................................... 66
Crimp contact insertion .................................................................................................... 67
Crimp contact extraction .................................................................................................. 67
Cross reference list ........................................................................................................... 68
Drilling pattern ................................................................................................................. 70
Discrimination / Keying methods ..................................................................................... 76
63
851 Series | Technical Information
Tooling
Crimp tooling - Contact #20 & 16
Locator - Contact #20 & 16
Part number
Part number
8365
(M 22520/1-01)
8365-02
(M 22520/1-02)
Part number
Part number
8476-01
(M 22520/2-01)
8476-02
(M 22520/2-02)
Insertion tools - Crimp contact
Part number
8500-29B*
* Except 8-2, 8-3, 8-4, 12-14 contact layouts : insertion tool 8500-93B
64
Tooling
Strap backshell
Part number #20
Part number #16
Part number
8500-38A
8500-36A
8490-04
Extraction tools - Crimp contact
65
Stripping instructions
• This operation should be carried out with great care. Use stripping pliers which are in good condition and which are designed for use with the size of
wire being stripped.
• In order to maintain the connector’s excellent sealing characteristics and, at the same time, meet the highest cabling standards the wires should have
the following external sheath dimensions :
Ø over sheath
Contacts
size
min.
max.
2.11
16
1.60
2.80
• Recommended loading:
- 050 % with max. diam. wires
- 050 % with min. diam. wires
- 100 % with medium size wires.
• Size 20 contacts for cables:
- when Ø over insulation ≤ 2 mm strip to a 4.5 mm length
- when Ø over insulation > 2 mm strip to a 7 mm length.
• Size 16 contacts, strip the cable to a length of 6 mm.
4.5 mm
7 mm
6 mm
Cable-contact assembly
• Insert the wire into the crimp barrel and ensure that it has penetrated correctly by checking that it may be seen through the lateral hole in the barrel.
Reducing sleeve
• If a wire with a cross sectional area of less than 0.21 mm2 is used with a size 20 contact, it will be necessary to use a reducing sleeve: ref. 8500-781.
• Wires of cross sectional area of 0.6 mm2 may be used with size 16 contacts by using a reducing sleeve, ref. 8500-1985.
contact
sleeve
cable
Crimping instructions
• With crimping pliers MS 22520/1-01 Souriau part number 8365 and turret MS 22520/1-02 8365-02:
- «red» position for size 20 contacts
- «blue» position for size 16 contacts.
• With crimping pliers MS 22520/2-01 Souriau part number 8476-01 and locator MS 22520/2-02 8476-02:
- for size 20 contacts only.
Note : not be used with reducing sleeve.
Squeeze pliers firmly until a click is heard, the pliers should spring open when the ratched mechanism is released.
• Hold indentor side up-insert the wire-contact assembly or mire-reducing sleeve-contact assembly between the four indentors, ensuring that the
contact bottoms in the locator.
• Fully close the jaws, once the contact is crimped the pliers must spring open remove wire + crimped contact, check crimp aspect.
66
First disassemble and slide connector rear accessory over cables.
Insertion tools
• Pliers 8500-29B.
• Except 8-2, 8-3, 8-4, 12-14 contact layouts: tool 8500-93B
Use of insertion tools
Manually insert the contact into the desired insert cavity.
• Insert the wire between the pliers jaws, the tip
of the jaws butting the contact shoulder.
Introduce contacts one by one in insert cavities pushing
straight in until the contact snaps into position and
the clip ensures contact retention.
Filler plugs
Where certain contacts are unwired and where it is necessary to fully maintain the connector’s sealing characteristics, a filler plug must be used.
Note that the contact must be inserted before the filler plug.
8500-36A
All contacts for use in insulators with clips are extracted using a semi-automatic tool:
• size 20 contacts: tool type 8500-36A
• size 16 contacts: tool type 8500-38A.
8500-38A
First dissassemble and slide connector rear accessory over cables.
• Do not operate the tool slide button.
• Bring the tool tip over the male or female contact to be removed from connector front (mating face) as far as the first mark for male contacts
and the second mark for female contacts.
First mark
Second mark
• This operation, should be carried out delicately in a direction parallel to the contact centre line with a light turning action.
• Extract contact pushing the slide button fully forward, carefully remove tool and pull wire to release the wire-contact assembly.
Note : tools have an adjustable spring system (rear knurled knob) also for automatic contact disengagement.
67
851 version with crimp contacts (olive green cadmium plating)
Connector with backshells
SOURIAU
NCF 93422
(modèle HE 301B)
MIL-DTL-26482G série 1
VG 95328
851 00 R .. .. .. 50 ..
HE 301 B 00 R .. .. .. 1A
* MS 3120 E .. .. ..
VG 95328 A .. .. ..
VG 95328 B .. .. ..
851 00 RC .. .. .. 50 ..
HE 301 B 00 RC .. .. .. 1A
* MS 3120 F .. .. ..
851 00 RP .. .. .. 50 ..
HE 301 B 00 RP .. .. .. 1A
* MS 3120 P .. .. ..
851 00 RG .. .. .. 50 ..
851 00 RA .. .. .. 50 ..
HE 301 B 00 RA .. .. .. 1A
851 01 R .. .. .. 50 ..
HE 301 B 01 R .. .. .. 1A
* MS 3121 E .. .. ..
851 01 RC .. .. .. 50 ..
HE 301 B 01 RC .. .. .. 1A
* MS 3121 F .. .. ..
851 01 RP .. .. .. 50 ..
HE 301 B 01 RP .. .. .. 1A
* MS 3121 P .. .. ..
851 01 RA .. .. .. 50 ..
HE 301 B 01 RA .. .. .. 1A
851 02 R .. .. .. 50 ..
HE 301 B 02 R .. .. .. 1A
* MS 3122 E .. .. ..
VG 95328 C .. .. ..
VG 95328 R .. .. ..
851 06 R .. .. .. 50 ..
HE 301 B 06 R .. .. .. 1A
* MS 3126 E .. .. ..
851 06 RC .. .. .. 50 ..
HE 301 B 06 RC .. .. .. 1A
* MS 3126 F .. .. ..
VG 95328 K .. .. ..
851 06 RP .. .. .. 50 ..
HE 301 B 06 RP .. .. .. 1A
* MS 3126 P .. .. ..
851 06 RT .. .. .. 50 ..
VG 95328 J .. .. ..
851 06 RA .. .. .. 50 ..
HE 301 B 06 RA .. .. .. 1A
851 36 RG .. .. .. 50 ..
VG 95328 M .. .. ..
851 36 RA .. .. .. 50 ..
851 07 R .. .. .. 50 ..
HE 301 B 07 R .. .. .. 1A
* MS 3124 E .. .. ..
VG 95328 D .. .. ..
851 07 RC .. .. .. 50 ..
HE 301 B 07 RC .. .. .. 1A
* MS 3124 F .. .. ..
VG 95328 E .. .. ..
851 07 RP .. .. .. 50 ..
HE 301 B 07 RP .. .. .. 1A
* MS 3124 P .. .. ..
851 07 RT .. .. .. 50 ..
VG 95328 S .. .. ..
851 07 RG .. .. .. 50 ..
VG 95328 T .. .. ..
851 08 RC .. .. .. 50 ..
HE 301 B 08 RC .. .. .. 1A
* Not QPL
851 version with crimp contacts (other plating)
SOURIAU
Plating
68
NFC 93422
(modèle HE 301B)
Solder version
Crimp version
Black anodised
851 .. .. .. .. 5029
851 .. .. .. .. .. 50031
HE 301B .. .. .. .. .. 4A
Nickel
851 .. .. .. .. 5044
851 .. .. .. .. .. 5044
HE 301B .. .. .. .. .. 5A
851 version with solder contacts (olive green cadmium plating)
SOURIAU
NCF 93422
(modèle HE 301B)
VG 95328
851 00 E .. .. .. 50 ..
HE 301 B 00 E .. .. .. 1A
MS 3110 E .. .. ..
851 00 EC .. .. .. 50 ..
HE 301 B 00 EC .. .. .. 1A
MS 3110 F .. .. ..
851 00 AC .. .. .. 50 ..
HE 301 B 00 AC .. .. .. 1A
851 00 P .. .. .. 50 ..
HE 301 B 00 P .. .. .. 1A
MS 3110 P .. .. ..
851 00 A .. .. .. 50 ..
HE 301 B 00 A .. .. .. 1A
851 00 J .. .. .. 50 ..
HE 301 B 00 J .. .. .. 1A
851 00 JC .. .. .. 50 ..
MS 3110 J .. .. ..
851 01 E .. .. .. 50 ..
HE 301 B 01 E .. .. .. 1A
MS 3111 E .. .. ..
851 01 EC .. .. .. 50 ..
HE 301 B 01 EC .. .. .. 1A
MS 3111 F .. .. ..
851 01 AC .. .. .. 50 ..
HE 301 B 01 AC .. .. .. 1A
851 01 P .. .. .. 50 ..
HE 301 B 01 P .. .. .. 1A
MS 3111 P .. .. ..
851 01 A .. .. .. 50 ..
HE 301 B 01 A .. .. .. 1A
851 01 J .. .. .. 50 ..
HE 301 B 01 J .. .. .. 1A
851 01 JC .. .. .. 50 ..
MS 3111 J .. .. ..
851 02 E .. .. .. 50 ..
HE 301 B 02 E .. .. .. 1A
MS 3112 E .. .. ..
VG 95328 H .. .. ..
851 06 E .. .. .. 50 ..
HE 301 B 06 E .. .. .. 1A
MS 3116 E .. .. ..
851 06 EC .. .. .. 50 ..
HE 301 B 06 EC .. .. .. 1A
MS 3116 F .. .. ..
851 06 AC .. .. .. 50 ..
HE 301 B 06 AC .. .. .. 1A
851 06 P .. .. .. 50 ..
HE 301 B 06 P .. .. .. 1A
MS 3116 P .. .. ..
851 06 A .. .. .. 50 ..
HE 301 B 06 A .. .. .. 1A
851 06 J .. .. .. 50 ..
HE 301 B 06 J .. .. .. 1A
851 06 JC .. .. .. 50 ..
MS 3116 J .. .. ..
851 08 EC .. .. .. 50 ..
HE 301 B 08 EC .. .. .. 1A
851 08 P .. .. .. 50 ..
HE 301 B 08 P .. .. .. 1A
851 07 E .. .. .. 50 ..
HE 301 B 07 E .. .. .. 1A
MS 3114 E .. .. ..
851 07 EC .. .. .. 50 ..
HE 301 B 07 EC .. .. .. 1A
MS 3114 F .. .. ..
851 07 AC .. .. .. 50 ..
HE 301 B 07 AC .. .. .. 1A
851 07 P .. .. .. 50 ..
HE 301 B 07 P .. .. .. 1A
MS 3114 P .. .. ..
851 Hermetic version
SOURIAU
NFC 93422
(modèle HE 301B)
851 02 H .. .. P.50
HE 301 B 02 H .. .. P.3A
851 07 H .. .. P.50
851 I H .. .. P.50
VG 95328
HE 301 B 07 H .. .. P.3A
* MS 3114 H .. .. P.
VG 95328 F .. .. ..
HE 301 B 1 H .. .. P.3A
* MS 3113 H .. .. P.
VG 95328 G .. .. .
* Not QPL
69
Drilling pattern - Male rear face
Shell Size
Dimension (mm)
8-2
2 contacts
2xØ1.0 (#20)
8-3
8-3A/8-98
3xØ1.0 (#20)
3xØ1.0 (#20)
3 contacts
8-33
3 contacts
8-4
3 contacts
4 contacts
3xØ1.0 (#20)
4xØ1.0 (#20)
8
10-6
10-98
6 contacts
10-7
6 contacts
6xØ1.0 (#20)
7 contacts
6xØ1.0 (#20)
7xØ1.0 (#20)
10
12-2
12-3
2 contacts
3 contacts
2xØ1.6 (#16)
12
3xØ1.6 (#16)
12-10
10 contacts
10xØ1.0 (#20)
70
12-4
3 contacts
+ground
12
4
4xØ1.6 (#16)
12-14
14 contacts
14xØ1.0 (#20)
12-8
8 contacts
8xØ1.0 (#20)
Dimension (mm)
14-5
12 4
14
5 contacts
5xØ1.6 (#16)
14-15
15 contacts
14xØ1.0 (#20)
1xØ1.6 (#16)
14-7
6 contacts
+ground
147
7xØ1.6 (#16)
14-18
18 contacts
18xØ1.0 (#20)
16-8
14-12
12 contacts
8xØ1.0 (#20)
4xØ1.6 (#16)
14-19
19 contacts
19xØ1.0 (#20)
16-23
8 contacts
23 contacts
8xØ1.6 (#16)
22xØ1.0 (#20)
1xØ1.6 (#16)
Shell Size
16-26
26 contacts
26xØ1.0 (#20)
16
71
Shell Size
Dimension (mm)
18-11
18-30
11 contacts
30 contacts
11xØ1.6 (#16)
29xØ1.0 (#20)
1xØ1.6 (#16)
18-32
32 contacts
32xØ1.6 (#16)
18
20-16
16 contacts
16xØ1.6 (#16)
20-24
24 contacts
24xØ1.0 (#20)
Dimension (mm)
20-25
25 contacts
25xØ1.0 (#20)
39 contacts
37xØ1.0 (#20)
2xØ1.6 (#16)
20-27
27 contacts
27xØ1.0 (#20)
20-41
41 contacts
41xØ1.0 (#20)
Shell Size
22-21
21 contacts
21xØ1.6 (#16)
22
73
Shell Size
Dimension (mm)
22-32
32 contacts
32xØ1.0 (#20)
22-34
34 contacts
34xØ1.0 (#20)
22
22-36
36 contacts
36xØ1.0 (#20)
74
22-55
55 contacts
55xØ1.0 (#20)
Shell Size
Dimension (mm)
24-61
61 contacts
61xØ1.0 (#20)
24
75
Insulator rotated inside metal bod
Viewed from front face of male
insulator (receptacle or plug)
Shells
Angle in degrees
Layouts
W
8
10
X
Y
NFC 93422 HE 301B
Z
Solder
Crimp
MIL-DTL-26482G
serie 1
Solder
Crimp
Service1
1500 Vrms
2
58
122
X
3
60
210
X
3A (98)*
60
210
4
45
33
90
6
90
7*
90
98
90
180
240
270
3
180
Service 2
2300 Vrms
X
X
X
X
X
X
X
X
X
4
12
8
90
112
203
292
10
60
155
270
295
2
14*
45
X
5
40
92
184
273
43
90
15
17
110
155
234
18
15
90
180
270
X
X
7
14
16
18
24
12
X
X
X
19
30
165
315
8
54
152
180
331
23
158
270
X
X
X
26
60
275
338
11
62
119
241
340
32
85
138
222
265
X
X
30
180
193
285
350
16
238
318
333
347
39
63
144
252
333
41
45
126
225
24
70
145
215
290
25
72
144
216
288
27
72
144
216
288
21
16
135
175
349
36
72
144
216
288
X
X
X
X
X
X
X
X
55
30
142
226
314
72
145
215
288
X
34
62
142
218
298
X
61
90
180
270
324
X
X
32
* 8-98 layout, W and X non standard ortientations
10-7 & 12-14 layouts, W non standard orientation
76
X
X
Notes
77
Notes
78
Our contribution to environmental
protection:
This catalog is printed on PEFC
certified paper
Advancement of sustainable
wood cultivation. www.pefc.org
contactindustry@souriau.com (Europe - Asia - Africa)
technicalsupport@souriau.com (North America)
www.souriau-industrial.com
CA851WUSEN01 © Copyright SOURIAU 2016 - SOURIAU is a registered trademark
Your local contact
All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing.
Reliable People, Reliable Solutions
