ACE1V3225-201-R
ACE1V3225-201-R
    EATON(伊顿)
    水平式,4 PC 板
    200 µH @ 100 kHz 2 线路共模扼流圈 表面贴装型 70mA DCR 4.8 欧姆
ACE1V3225-201-R 数据手册
Technical Data 10985 Effective November 2019 ACE1V3225 Automotive grade common-mode chip inductor Applications Product features • AEC-Q200 qualified • 1210 (3225 metric) package • Impedance range from 500 ohms to 15000 ohms • Inductance range from 11 uH to 200 uH • Moisture sensitivity level (MSL): 1 • Controller area network (CAN) • Ethernet architectures • Automotive signal line filter • Advanced driver assistance systems (ADAS) • Infotainment, safety cameras, sensors, xEV, Powertrain • Engine control unit (ECU) • Electric power steering system (EPS) • Battery management systems (BMS) Environmental data • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ACE1V3225 Automotive grade common-mode chip inductor  Technical Data 10985 Effective November 2019 Product specifications Common-mode impedance Z (Ω) at 10 MHz Part number Common-mode inductance (μH) at 100 kHz DCR (Ω) @ +25 ° maximum Idc (mA) maximum Rated voltage (Vdc) typical Insulation resistance (MΩ) minimum ACE1V3225-110-R 300 minimum 500 typical 11+50%/-30% 0.40 300 80 10 ACE1V3225-220-R 500 minimum 1000 typical 22+50%/-30% 0.50 250 80 10 ACE1V3225-510-R 1000 minimum 2600 typical 51+50%/-30% 0.70 200 80 10 ACE1V3225-101-R 2200 minimum 5100 typical 100+50%/-30% 1.50 150 80 10 ACE1V3225-201-R NA 200+30%/-20% 4.80 70 80 10 1. Part Number Definition: ACE1V3225-xxn-R ACE1V3225 = Product code and size xx= inductance value in uH, n= multiplication factor: 10^n (i.e. 110 = 11 * 10^0 = 11 uH) -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout B A Epoxy C D Terminations Wires E E F F Equivalent circuit 1 4 2 3 No polarity Part Number A B C D E F L H G1 G2 ACE1V3225-xxn-R 3.2±0.2 2.5±0.2 2.5 max 0.2±0.1 0.9 typ 08 typ 3.7 typ 2.8 typ 2.4 typ 1.2 typ All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics Technical Data 10985 ACE1V3225  Automotive grade common-mode chip inductor Effective November 2019  Packaging information (mm) Supplied in tape and reel packaging, 1000 parts per 7” diameter reel Ao 2.80±0.10 Bo 3.60±0.10 Ko 2.20±0.10 W 8.00±0.20 E 1.75±0.10 F 3.50±0.05 Po 4.0±0.05 P1 4.0±0.10 Do 1.0±0.1 www.eaton.com/electronics 3 ACE1V3225 Automotive grade common-mode chip inductor  Technical Data 10985 Effective November 2019 Performance curves ACE1V3225-220-R Impedance (Ω) Impedance (Ω) ACE1V3225-110-R Frequency (MHz) Frequency (MHz) ACE1V3225-101-R Impedance (Ω) Impedance (Ω) ACE1V3225-510-R Frequency (MHz) Frequency (MHz) Common mode measurement method: Impedance (Ω) ACE1V3225-201-R Differential mode measurement method: Frequency (MHz) 4 www.eaton.com/electronics Technical Data 10985 ACE1V3225  Automotive grade common-mode chip inductor Effective November 2019  Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package Thickness Volume mm3
ACE1V3225-201-R 价格&库存
很抱歉,暂时无法提供与“ACE1V3225-201-R”相匹配的价格&库存,您可以联系我们找货
ACE1V3225-201-R
    ACE1V3225-201-R
      ACE1V3225-201-R
        ACE1V3225-201-R
        • 1000+4.334481000+0.56183
        • 2000+4.087322000+0.52980
        • 3000+3.949513000+0.51194
        • 5000+3.782665000+0.49031
        • 7000+3.676757000+0.47658
        • 10000+3.5677710000+0.46245
        库存:1652
        ACE1V3225-201-R
        • 1+7.605231+0.98579
        • 10+6.2897610+0.81528
        • 25+5.8161925+0.75389
        • 50+5.4838650+0.71082
        • 100+5.16943100+0.67006
        • 250+4.78252250+0.61991
        • 500+4.50918500+0.58448
        库存:1652
        ACE1V3225-201-R
        • 1000+2.68421
        • 4000+2.10384
        库存:55000
