BBS-4/10
BBS-4/10
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE CRTRDGE 4MA 600VAC NON STD
BBS-4/10 数据手册
Bussmann® Fast-Acting Ferrule Fuses BBS 13/32” x 1-3/8” 3 5 6 7 2 100 3/4 1 Time-Current Characteristic Curves–Average Melt 4/10 Dimensional Data AMPERE RATING 1.38" (±0.031) 10 TIME IN SECONDS 0.41" (±0.004) Catalog Symbol: BBS Fast-Acting 1/10 TO 30A Interrupting Rating: 10 KA UL Listed, STD. 248-14 0-5A/600Vac OR LESS, 6-10A/250Vac (GUIDE #JDYX, FILE #E19180) CSA CERTIFIED, C22.2 NO. 248.14 0-5A/600V, 6-10A/250Vac (CLASS #1422-01, FILE #53787) 1 .1 Electrical Ratings (Catalog Symbol and Amperes) BBS-2/10 BBS-1-1/2 BBS-7 BBS-15 BBS-1/4 BBS-1-6/10 BBS-8 BBS-20 BBS-4/10 BBS-1-8/10 BBS-10 BBS-25 BBS-1/2 BBS-2 — BBS-30 BBS-6/10 BBS-3 — — BBS-3/4 BBS-4 — — BBS-8/10 BBS-5 — — CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. .01 200 BBS-12 100 BBS-6 10 48Vac BBS-1 1 250Vac BBS-1/10 .4 600Vac CURRENT IN AMPERES • For control circuits, gaseous vapor fixture, HID ballasts; electronic circuits and hand-held meters. • Fibre Tube. • Nickel Plated Brass Endcaps. Recommended fuseblocks/fuseholders for 13/32” x 1-1/2” fuses See Data Sheets listed below • Open fuseblocks - 1104, 2104 • Finger-safe fuseholders - 1109, 1102, 1103, 1151 • Panel-mount fuseholders - 2114, 2113, 2108, 2112, 2109, 2140 • In-line fuseholders - 2127, 2126 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this Data Sheeti are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 10-2-02 SB02295 Form No. BBS Page 1 of 1 Data Sheet: 2010
BBS-4/10 价格&库存
很抱歉,暂时无法提供与“BBS-4/10”相匹配的价格&库存,您可以联系我们找货
