BK/5678-04
BK/5678-04
    EATON(伊顿)
BK/5678-04 数据手册
Fuse Clips with Mounting Holes 5000 Series For 1/4”, 9/32”, 13/32”, and 9/16” Diameter Fuses Dimensional Data • Clips are made of a spring bronze of distinctly superior quality. This metal gives clips great gripping strength and ability to retain fuses under adverse conditions. B C C • Beryllium copper is by far the most satisfactory metal yet discovered for use in fuse clips. It has the ability to retain spring pressure better than any other metal under high current and high ambient conditions. It also has exceedingly high electrical conductivity. D D E E Figure 2 Figure 1 1/4˝ Diameter Fuses Catalog Number End Clip Stop Mat.** B (To Finish 5681-01 BeCu No 5681-08 No Spg. Br. Nickel 5681-15 Spg. Br. Bright Tin 5682-01 BeCu Silver BeCu Yes BeCu 5682-11 Yes Silver 5682-02 13/32˝ Diameter Fuses C Dimensions (Inches) D E End Stop) (Contact) Hole Fig. (Height) (Width) Dia. Ref. † 0.41 Silver 0.265 0.32 0.132 2 0.108 Bright Tin 0.131 0.262 0.41 0.32 0.132 1 Catalog Number End Clip Stop Mat.** Finish B (To C Dimensions (Inches) D E End Stop) (Contact) (Height) (Width) Hole Fig. Dia. Ref. 0.172 2 5956-16 No Spg. Br. Bright Tin † 5960-07 BeCu Silver 0.168 5960-09 BeCu Silver 0.20 0.172 5960-44 Spg. Br. Nickel 0.20 0.197 5960-51 Yes 5960-53 Yes Spg. Br. Bright Dip* 0.20 0.172 Spg. Br. Bright Dip* 0.168 0.312 0.71 0.47 0.196 0.387 0.71 0.47 0.196 1 5682-41 Spg. Br. Bright Tin 0.106 5960-61 Spg. Br. Bright Tin 0.168 0.196 5682-44 Spg. Br. Bright Tin 0.132 5960-62 Spg. Br. Bright Tin 0.168 0.132 5960-63 Spg. Br. Bright Tin 0.20 0.172 5960-64 Spr. Br. Bright Tin 0.20 0.128 9/32˝ Diameter Fuses Catalog Number End Clip Stop Mat.** 9/16˝ Diameter Fuses B (To Finish End Stop) (Contact) 5672-11 No Spg. Br. Bright Tin † 5674-01 BeCu Yes BeCu 5674-10 Yes 5674-41 C Dimensions (Inches) D E 0.362 Hole Fig. (Height) (Width) Dia. Ref. Catalog Number 0.52 5591-42 0.38 0.172 2 Silver Bright Tin 0.168 0.356 Spg. Br. Bright Tin 0.52 0.38 0.172 1 Dimensions (Inches) D E Hole Fig. End Stop) (Contact) (Height) (Width) Dia. Ref. End Clip Stop Mat.** Finish Yes Spg. Br. Bright Dip* 5591-52 Spg. Br. Bright Tin 5592-01 BeCu No 5592-11 No Spg. Br. Silver 5592-33 Spg. Br. Bright Dip B (To C 0.26 0.51 0.89 0.60 0.172 1 0.252 0.56 0.875 0.60 0.20 2 Silver 0.20 0.172 * Bright Dip is actually treated bare metal with no plating. ** Spg. Br. — Spring Bronze; BeCu — Beryllium Copper. † Hole in center of both clip and contact area. The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 02-09 BU-SB08760 Page 1 of 1 Data Sheet 2132
BK/5678-04 价格&库存
很抱歉,暂时无法提供与“BK/5678-04”相匹配的价格&库存,您可以联系我们找货
