BK/MDA-V-30-R
BK/MDA-V-30-R
    EATON(伊顿)
    插件,D6.76xL32.82mm
    一次性保险丝(熔断) 30A 125V
BK/MDA-V-30-R 数据手册
/4˝ x 1 1/4˝ Ceramic Tube Fuses MDA Series, Time-Delay 1 Description • Time-delay • Optional axial leads available • 1/4˝ x 1-1/4˝ (6.35 x 31.75mm) physical size • Ceramic tube, nickel-plated brass endcap construction • UL Listed product meets standard 248-14 Rated Current 1/4 - 30A Electrical Characteristics Amp Rating Opening Time 100% None 135% 60 Minutes Max. 200% 120 Seconds Max. Agency Information • UL Listed Card: MDA 2/10 - 20A (Guide JDYX, File E19180) • UL Recognized Card: MDA 25 - 30A (Guide JDYX2, File E19180) • CSA Certification Card: MDA 2/10 - 20 (Class No. 1422-01) • CSA Component Acceptance: MDA 25-30A (Class No. 1422-30) Environmental Data • Shock: 1/100A and 8/10A – MIL-STD-202, Method 213, Test Condition I; 1A thru 30A – MIL-STD-202, Method 213, Test Condition J • Vibration: 1/100A and 8/10A – MIL-STD-202, Method 201; 1/4A thru 30A – MIL-STD-202, Method 204, Test Condition C (Except 5g, 500HZ) Dimensions - mm (in) Drawing Not to Scale 32.82 (1.292) 38.10 (1.500) 38.10 (1.500) 6.76 (0.266) DIA. OF LEADS 0.81 (0.032) 20–30 AMP: 1.02 (0.040) 0–15 AMP: 31.75 (1.250) 6.35 (0.250) Ordering • Specify packaging, product, and option code SPECIFICATIONS Part Number MDA-1/4-R MDA-1/2-R MDA-3/4-R MDA-1-R MDA-1-1/2-R MDA-2-R MDA-2-1/2-R MDA-3-R MDA-4-R MDA-5-R MDA-6-R MDA-7-R MDA-8-R MDA-10-R MDA-12-R MDA-15-R MDA-20-R MDA-25A-R MDA-30A-R * ** † ‡ Voltage Rating Vac Vdc 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 250 125 250 125 AC Interrupting Rating* (amps) 250V 125V 35 10000 35 10000 35 10000 35 10000 100 10000 100 10000 200 10000 200 10000 200 10000 200 10000 200 10000 200 10000 200 10000 200 10000 750 10000 750 10000 1500 10000 1500 10000 1500 10000 DC Interrupting Rating (amps) 125V 10000 10000 10000 Typical DC Cold Resistance** Ω) (Ω 9.325 1.925 0.8555 0.560 0.2585 0.170 0.06685 0.05350 0.03625 0.02610 0.02120 0.01690 0.01350 0.00948 0.00725 0.00553 0.00400 0.00305 0.00243 Typical Melting I2t† AC 0.748 2.53 8.58 12.21 27.5 70.4 31.79 44.99 147.4 380.49 587.73 638.33 1038.4 1620.43 125.18 336.82 483.45 734.69 1096.7 Typical Voltage Drop‡ 4.00 1.42 1.31 1.03 0.691 0.623 0.213 0.182 0.162 0.145 0.141 0.137 0.134 0.135 0.128 0.107 0.095 0.105 0.110 Interrupting Ratings (Measured at 70% - 80% power factor on AC. The interrupting ratings for 25Amp, 30Amp were measured at 90% - 100% power factor on AC) DC Cold Resistance (Measured at ≤10% of rated current) Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage) Typical Voltage Drop (Voltage drop was measured at 25°C ambient temperature at rated current) 0709 SB-BU09312 Page 1 of 2 Data Sheet 2002 Time-Current Curve 10 12 15 20 25 30 3-2/10 4 5 6-1/4 2 1 1/2 TIME IN SECONDS TIME IN SECONDS 1/4 CURRENT IN AMPS CURRENT IN AMPS Packaging Code Packaging Code BK BK1 BK8 Description 100 fuses packed into a cardboard carton 1,000 fuses packed into a cardboard carton 8,000 fuses packed into a cardboard carton Option Code Option Code B V Description Sealed to withstand aqueous cleaning (Board Washable) Axial leads - copper tinned wire with nickel plated brass overcaps The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 0709 SB-BU09312 Page 2 of 2 Data Sheet 2002
BK/MDA-V-30-R 价格&库存
很抱歉,暂时无法提供与“BK/MDA-V-30-R”相匹配的价格&库存,您可以联系我们找货
