BK/MDL-3-1/2-R
BK/MDL-3-1/2-R
    EATON(伊顿)
    3AB,3AG,1/4" x 1-1/4"
    FUSE GLASS 3.5A 250VAC 3AB 3AG
BK/MDL-3-1/2-R 数据手册
Electronic – PCB and small dimension fuses 4 Contents Description Page 5 x 15mm fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-2 5 x 20mm IEC fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-3 5 x 20mm UL fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4-5 1/4˝ x 5/8˝ to 1˝ fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-6 1/4˝ x 1 1/4˝ fast-acting fuses . . . . . . . . . . . . . . . . . . . . . . . 4-7 1/4˝ x 1 1/4˝ time-delay fuses . . . . . . . . . . . . . . . . . . . . . . . 4-8 PCB mount fuse holders . . . . . . . . . . . . . . . . . . . . . . . . . . 4-9 PCB fuseclips for 5mm dia. fuses . . . . . . . . . . . . . . . . . . . 4-11 PCB fuseclips for 1/4˝ dia. fuses . . . . . . . . . . . . . . . . . . . . 4-12 PCB fuseclips for 9/32˝, 13/32˝ and 9/16˝ dia. fuses . . . . . . 4-14 Electronic fuses BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 4-1 4 Electronic – PCB and small dimension fuses 5 x 15mm fuses C515 (axial leads) C518 (axial leads) C517 (axial leads) C519 C520 Specifications Description: Time-delay fuse. Dimensions: 5 x 15mm (0.197” X 0.591”). Construction: Glass tube. Ratings: Volts — 125Vac (3.57A) — 250Vac (125mA-3A) — 32Vdc (self certified) Amps — 125mA-7A IR — 25A (350mA @ 600Vac) — 35A (125mA-1A @ 250Vac) — 100A (1.25-3A @ 250Vac) — 400A (3.5-7A @ 125Vac) — 10kA (125mA-3A @ 125Vac) Agency information: CE, UL Listed File E19180, Guide JDYX 125mA-250mA and 375mA-3A, UL Recognized, File E19180, Guide JDYX2, 350mA and 3.5A-7A, CSA Certification File 53787, Class 1422-01, 125mA-250mA and 375mA-3A. Specifications Description: Fast-acting fuse. Dimensions: 5 x 15mm (0.197” X 0.591”). Construction: Glass tube. Ratings: Volts — 250Vac — 32Vdc (self certified) Amps — 100mA-5A IR — 35A (100mA-750mA @ 250Vac) — 10kA (100mA-5A @ 125Vac) — 100A (1.5-3.5A @ 250Vac) — 200A (4-5A @ 250Vac) Agency information: CE, UL Recognized File E19180, Guide JDYX2CSA Certification File 53787, Class 1422-01. Specifications Description: Fast-acting fuse. Features and benefits • Time-delay for closer sizing on inductive circuits. Typical application • Electronic circuits • Printed circuit boards Data Sheet: 2006 (C515) and 2007 (C519) 4-2 Agency information: CE, UL Listing File E19180, Guide JDYX, CSA Certification File 53787, Class 1422-01, UL Recognized, File E19180, Guide JDYX2. • Small footprint saves space in equipment. • Fast-acting for maximum component protection. • 350Vac rating for 277V ballast circuit protection. *350Vac/100A IR is UL Recognized Typical applications • Electronic circuits • Printed circuit boards • Electronic ballast protection Catalog number (amps) With axial leads C517-3-R Typical applications • Electronic circuits • Printed circuit boards Catalog numbers (amps) Catalog numbers (amps) With axial leads C515-125-R C515-800-R C515-250-R C515-1-R C515-350-R C515-1.25-R C515-375-R C515-1.5-R C515-500-R C515-1.6-R C515-600-R C515-2-R C515-750-R C515-2.25-R Without axial leads C519-125-R C519-750-R C519-250-R C519-1-R C519-350-R C519-1.25-R C519-375-R C519-1.5-R C519-500-R C519-1.6-R C519-600-R C519-2-R Features and benefits • Small footprint saves space in equipment. • Fast-acting for maximum component protection. • Available in ferrule and axial leaded configurations Construction: Glass tube. Ratings: Volts — 350Vac* — 32Vdc (self certified) Amps — 3A IR — 100A @ 350Vac — 100A @ 250Vac — 10kA @ 125Vac C515-2.5-R C515-3-R C515-3.5-R C515-4-R C515-5-R C515-6-R C515-7-R C519-2.25-R C519-2.5-R C519-3-R C519-3.5-R C519-4-R C519-5-R With axial leads C518-100-R C518-750-R C518-125-R C518-2-R C518-250-R C518-2.5-R C518-375-R C518-3-R C518-500-R C518-3.5-R Without axial leads C520-100-R C520-750-R C520-125-R C520-1.5-R C520-250-R C520-2-R C520-375-R C520-2.5-R C520-500-R C520-3-R C518-4-R C518-5-R C520-3.5-R C520-4-R C520-5-R Data Sheet: 2026 (C518) and 2027 (C520) BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries Data Sheet: 2025 Electronic – PCB and small dimension fuses 5 x 20mm IEC fuses S500-V (GDB-V)* (axial leads) S500 (GDB)* Typical applications • Electronic circuits Catalog numbers (amps) S500-32-R S500-40-R S500-50-R S500-63-R S500-80-R S500-100-R S500-125-R S500-160-R S500-200-R S500-250-R S500-315-R S500-400-R S500-500-R S500-630-R S500-800-R S500-1-R S500-1.25-R S500-1.6-R S500-2-R S500-2.5-R S500-3.15-R S500-4-R S500-5-R S500-6.3-R S500-8-R S500-10-R 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 40 50 63 80 100 I2t 0.000047 0.00011 0.00020 0.00057 0.0012 0.003 0.005 0.008 0.016 0.028 0.058 0.018 0.018 0.035 0.067 0.60 0.84 1.6 4.2 6.1 13 22 42 69 —- Max voltage drop (mV) 3200 2500 2400 2000 1200 1100 1000 2000 1700 1400 1300 1100 220 220 190 200 200 190 150 150 130 130 120 120 120 120 Options Axial leads, put “V” in P/N, *When ordering GDB version, do not add “-R” suffix to part number. Data Sheet: 2052 (S500), 2015 (GDB) S505-V (axial leads) S505 Specifications Description: Timedelay, high-breaking capacity fuse. Construction: Ceramic tube, silverplated brass endcaps. Ratings: Volts — 250Vac (or less) — 32Vdc (self certified) Amps — 500mA-12A IR — 1500A @ 250Vac Agency information: UL, CSA, SEMKO, VDE, BSI, IMQ, PSE/JET, CCC, EK, FIMKO. See data sheet for complete agency information. Not all approvals apply to all ratings. Specifications Description: Fastacting, high-breaking capacity fuse. Construction: Ceramic tube, nickel-plated brass endcaps (silverplated endcaps 50mA-400mA). Ratings: Volts — 250Vac (or less) — 32Vdc (self certified) Amps — 50mA-10A** IR — 1500A @ 250Vac Agency information: CE, cURus, SEMKO, VDE, IMQ, CCC, CSA, BSI. See data sheet for complete agency information. Not all approvals apply to all ratings. Features and benefits • Fast-acting for maximum protection. • High break capacity for use in higher fault energy electronic circuitry. • Conforming to IEC standards. Features and benefits • Time-delay performance ideal for inductive circuits. • Conforming to IEC standards. Typical applications • Electronic circuits Catalog numbers (amps) Typical applications • Electronic circuits Catalog numbers (amps) Catalog numbers S501-50-R S501-63-R S501-80-R S501-100-R S501-125-R S501-160-R S501-200-R S501-250-R S501-315-R S501-400-R S501-500-R S501-630-R S501-800-R S501-1-R S501-1.25-R S501-1.6-R S501-2-R S501-2.5-R S501-3.15-R S501-4-R S501-5-R S501-6.3-R S501-8-R S501-10-R I2t Typical voltage drop (mV) 0.0017 0.0005 0.0011 0.0018 0.0037 0.008 0.020 0.027 0.010 0.018 0.038 0.064 0.097 0.146 0.313 0.748 2.0 3.9 8.1 14 25 48 N/A N/A 9000 3300 2600 2300 1900 1600 1350 1300 1400 1200 1050 1200 490 330 297 239 205 190 160 160 155 150 N/A N/A Catalog numbers Typical I2t Max voltage drop (mV) S505-500-R 0.188* 295 S505-800-R 0.632* 189 S505-1-R 1.28 152.5 S505-1.25-R 2.22 150 S505-1.6-R 6.78 125 S505-2-R 9.60 118.5 S505-2.5-R 16.60 115 S505-3.15-R 36.60 102.5 S505-4-R 38.45* 86.5 S505-5-R 71.30* 77.5 S505-6.3-R 197 75 S505-8-R 311 75 S505-10-R 397 72 S505-12-R 713.7* 77 *The typical I2t value was measured at 10 times of rated current under DC. Options Axial leads, put “V” in P/N. Options Axial leads, put “V” in P/N. *When ordering GDA version, do not add “-R” suffix to part number. **GDA is not available above 6.3A. Data Sheet: 2051 (S501), 2014 (GDA) BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Data Sheet: 2037 Eaton.com/bussmannseries 4-3 Electronic fuses Features and benefits • Fast-acting for maximum protection, conforms to IEC 60127-2 (160mA-10A). IR (amps) (axial leads) S501 (GDA)* Specifications Description: Fastacting, low-breaking capacity fuse. Construction: Glass tube, nickelplated brass endcaps (silver-plated endcaps, 32-125mA). Ratings: Volts — 250Vac (or less) — 32Vdc (self certified) Amps — 32mA-10A IR — See catalog table Agency information: CE, cURus, SEMKO, VDE, BSI, IMQ, CCC. See data sheet for complete agency information. Not all approvals apply to all ratings. Catalog numbers S501-V (GDA-V)* 4 Electronic – PCB and small dimension fuses 4 5 x 20mm IEC fuses S505H (S505H-V)* S506-V (GDC-V)* (axial leads) S506 (GDC)* Specifications Description: Timedelay, high-breaking capacity fuse. Construction: Ceramic tube, nickelplated brass endcaps. Ratings: Volts — 600Vac/400Vdc — 500mA-5A — 6.3A-10A — 500Vac/400Vdc Amps — 500mm-10A IR — 35A @ 250Vac Agency information: cURus, CCC, CQC, TUV, PSE/JET. See data sheet for complete agency information. Not all approvals apply to all ratings. Specifications Description: Timedelay, low-breaking capacity fuse. Construction: Glass tube, nickel-plated brass endcaps. Ratings: Volts — 250Vac (or less) — 32Vdc (self certified) Amps — 32mA-15A** IR — 35A @ 250Vac Agency information: UR, CSA, cURus, SEMKO, VDE, BSI, IMQ, PSE/JET, CCC. See data sheet for complete agency information. Not all approvals apply to all ratings. Features and benefits • Time-delay, high breaking capacity • Conforming to IEC standards Typical applications • Power supplies - adapters • Desktops/notebooks Catalog numbers (amps) Catalog numbers S505H-500-R S505H-800-R S505H-1-R S505H-1.25-R S505H-1.6-R S505H-2-R S505H-2.5-R S505H-3.15-R S505H-4-R S505H-5-R S505H-6.3-R S505H-8-R S505H-10-R Typical I2t (A2s)1 0.188 0.632 1.28 2.22 6.78 11.44 24.23 43.55 38.45 71.3 111.4 228.2 349.5 295 189 153 150 125 128 126 121 90 89 80 76 72 1. Typical Pre-Arc I2t: Measured at 10In DC. 2. - Breaking Capacity of 250VAC/1500A is tested by all agency approvals, test condition is 250Vac, PF: 0.7-0.8. - Breaking Capacity of Max. voltage is tested by UL, PF:1. - Breaking Capacity Test of DC is tested by UL under Capacitor Bank 4800mF (for 400V, 1500A) 2400mF (for 400V, 500A). 3. Typical Voltage Drop: Voltage drop is measured under ambient 20°C with rated current. Options Axial leads, put “V” in P/N. Features and benefits • Time-delay compatibility for inductive circuits • Conforming to IEC standards Typical applications • Electronic circuits Catalog numbers (amps) Catalog numbers Max voltage drop (mV)3 (axial leads) Typical I2t S506-32-R S506-40-R S506-50-R S506-63-R S506-80-R S506-100-R S506-125-R S506-160-R S506-200-R S506-250-R S506-315-R S506-400-R S506-500-R S506-630-R S506-800-R S506-1-R S506-1.25-R S506-1.6-R S506-2-R S506-2.5-R S506-3.15-R S506-4-R S506-5-R S506-6.3-R S506-8-R S506-10-R S506-12.5-R S506-15-R 0.0051 0.0072 0.0095 0.021 0.038 0.045 0.063 0.093 0.114 0.265 0.621 0.872 0.827 1.33 2.78 6.45 10.05 21.7 31.6 59.4 96.4 71.8 142.5 237.6 255.8 450 1019.5 1091.7 Max voltage drop (mV) 1050 920 800 760 580 490 390 320 340 270 250 210 140 150 75 87.5 86 82 77 72.5 68.5 67 60.5 54 55 54 45 65.5 Options Axial leads, put “V” in P/N. *When ordering GDC version, do not add “-R” suffix to part number. **GDC series is not available above 6.3A. Data Sheet: 4406 4-4 Data Sheet: 2016 (GDC), 4332 (S506) BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries Electronic – PCB and small dimension fuses 4 5 x 20mm UL fuses GMC-V (axial leads) GMA GMC Specifications Description: Fast-acting fuse. Dimensions: 5 x 20mm (0.197” x 0.788”). Construction: Glass tube, nickel-plated brass endcaps. Ratings: Volts — 250Vac (63mA-2.5A) — 125Vac (3.15-15A) — 32Vdc (self certified) Amps — 63mA-15A IR — 35A (63mA- 1A @ 250Vac, p.f. = 0.7-0.8) — 10kA (63mA-6A @ 125Vac, p.f. = 0.7-0.8) — 100A (1.25-2.5A @ 250Vac, p.f. = 0.7-0.8) — 200A (7-8A @ 125Vac, p.f. = 1.0) — 150A (10-15A @ 125Vac, p.f. = 1.0) Agency information: CE, Std. 248-14 UL Listed Guide JDYX, File E19180, 0-6A, UL Recognized, Guide JDYX2, File E19180, 7-15A, CSA Certified, Class 1422-01,File 53787, 0-6. Specifications Description: Medium time-delay fuse. Dimensions: 5 x 20mm (0.197” x 0.788”). Construction: Glass tube, nickel-plated brass endcaps. Ratings: Volts — 250Vac (63mA3.15A) — 125Vac (3.5-10A) — 32Vdc (self certified) Amps — 63mA-10A IR — 35A (63mA- 1A @ 250Vac, p.f. = 0.7-0.8) — 10kA (63mA-6A @ 125Vac, p.f. = 0.7-0.8) — 100A (1.25-3.15A @ 250Vac, p.f. = 0.7-0.8) — 200A (6.3-10A @ 125Vac, p.f. = 1.0) Agency information: CE, Std. 248-14, UL Listed Guide JDYX, File E19180, 0-6.3A, UL Recognized, Guide JDYX2, File E19180, 7-8A, CSA Certified, Class 1422-01, File 53787, 0-6.3A. Features and benefits • Fast-acting for maximum protection. Typical applications • Electronic circuits Data Sheet: 2017 GMC-10A Features and benefits • Conforming to UL standards. Typical applications • Electronic circuits Catalog numbers (amps) Catalog numbers (amps) With axial leads GMA-V-63-R GMA-V-800-R GMA-V-100-R GMA-V-1-R GMA-V-125-R GMA-V-1.25-R GMA-V-200-R GMA-V-1.5-R GMA-V-250-R GMA-V-1.6-R GMA-V-300-R GMA-V-2-R GMA-V-500-R GMA-V-2.5-R GMA-V-600-R GMA-V-3.15-R GMA-V-750-R GMA-V-3.5-R Without axial leads GMA-63-R GMA-800-R GMA-100-R GMA-1-R GMA-125-R GMA-1.25-R GMA-200-R GMA-1.5-R GMA-250-R GMA-1.6-R GMA-300-R GMA-2-R GMA-500-R GMA-2.5-R GMA-600-R GMA-3.15-R GMA-750-R GMA-3.5-R GMD-V (axial leads) GMA-V-4-R GMA-V-5-R GMA-V-6-R GMA-V-7-R GMA-V-8-R GMA-V-10-R GMA-V-15-R GMA-4-R GMA-5-R GMA-6-R GMA-7-R GMA-8-R GMA-10-R GMA-15-R With axial leads GMC-V-63-R GMC-V-500-R GMC-V-80-R GMC-V-600-R GMC-V-100-R GMC-V-630-R GMC-V-125-R GMC-V-750-R GMC-V-150-R GMC-V-800-R GMC-V-200-R GMC-V-1-R GMC-V-250-R GMC-V-1.25-R GMC-V-300-R GMC-V-1.5-R GMC-V-315-R GMC-V-1.6-R GMC-V-400-R GMC-V-2-R Without axial leads GMC-63-R GMC-500-R GMC-80-R GMC-600-R GMC-100-R GMC-630-R GMC-125-R GMC-750-R GMC-150-R GMC-800-R GMC-200-R GMC-1-R GMC-250-R GMC-1.25-R GMC-300-R GMC-1.5-R GMC-315-R GMC-1.6-R GMC-400-R GMC-2-R GMC-V-2.5-R GMC-V-3.15-R GMC-V-3.5-R GMC-V-4-R GMC-V-5-R GMC-V-6-R GMC-V-6.3-R GMC-V-7-R GMC-V-8-R GMC-V-10-R GMC-2.5-R GMC-3.15-R GMC-3.5-R GMC-4-R GMC-5-R GMC-6-R GMC-6.3-R GMC-7-R GMC-8-R GMC-10-R Data Sheet: 4395 BUSSMANN SERIES FULL LINE CATALOG GMD GMD Specifications Description: Timedelay fuse. Dimensions: 5 x 20mm (0.197” x 0.788”). Construction: Glass tube, nickelplated brass endcaps. Ratings: Volts — 250Vac — 32Vdc (self certified) Amps — 125mA-4A IR — 10kA (125mA-3A @ 125Vac, p.f. = 0.7-0.8) — 10kA (4A @ 125Vac, p.f. = 1.0) — 35A (125mA-1A @ 250Vac, p.f. = 0.7-0.8) — 100A (1.2A-3.A @ 250Vac, p.f. = 0.7-0.8) — 200A (4A @ 250Vac, p.f. = 1.0) Agency information: CE, UL Listed Guide JDYX, File E19180, 125mA-3A, UL Recognized, Guide JDYX2, File E19180, 4A, CSA Certified, Class 1422-01, File 53787, 0-4A, PSE/JET. File 1641-31003-1001, 1.2A-4A. Features and benefits • Time-delay compatibility for inductive circuits. • Conforming to UL standards. Typical applications • Electronic circuits Catalog numbers (amps) With axial leads GMD-V-125-R GMD-V-500-R GMD-V-150-R GMD-V-600-R GMD-V-200-R GMD-V-630-R GMD-V-250-R GMD-V-750-R GMD-V-300-R GMD-V-800-R GMD-V-315-R GMD-V-1-R GMD-V-375-R GMD-V-1.2-R GMD-V-400-R GMD-V-1.25-R Without axial leads GMD-125-R GMD-500-R GMD-150-R GMD-600-R GMD-200-R GMD-630-R GMD-250-R GMD-750-R GMD-300-R GMD-800-R GMD-315-R GMD-1-R GMD-375-R GMD-1.2-R GMD-400-R GMD-1.25-R GMD-V-1.5-R GMD-V-1.6-R GMD-V-2-R GMD-V-2.5-R GMD-V-3-R GMD-V-4-R GMD-1.5-R GMD-1.6-R GMD-2-R GMD-2.5-R GMD-3-R GMD-4-R Data Sheet:2019 1007—July 2015 Eaton.com/bussmannseries 4-5 Electronic fuses GMA-V (axial leads) Electronic – PCB and small dimension fuses 4 1/4˝ x 5/8˝ to 1˝ fuses AGA AGW AGX Specifications Description: Fast-acting fuse. Dimensions: 1 ⁄4˝ x 5⁄8˝ (6.4 x 15.9mm). Construction: Glass tube. Ratings: Volts — 125Vac (or less) — 32Vdc (self certified) Amps — 1-30A IR — 10kA (1-11⁄2A @ 125Vac) — 200A (2-5A @ 125Vac) — 1000A (6-30A @ 32Vac) Agency information: CE, Std. 24814, UL File E19180, UL Listed, Guide JDYX 0-31⁄2A UL Recognized, Guide JDYX2 12-30A. Specifications Description: Fast-acting fuse. Dimensions: 1⁄4˝ x 7⁄8˝ (6.4 x 22.2mm). Construction: Glass tube. Ratings: Volts — 32Vac — 32Vdc (self certified) Amps — 1-30A Specifications Description: Fast-acting fuse. Dimensions: 1⁄4˝ x 1˝ (6.4 x 25.4mm). Construction: Glass tube. Ratings: Volts — 250Vac (1⁄16-20A) — 125Vac (25-30A) — 32Vdc (1⁄16-30A) Amps — 1⁄16-30A IR — 35A (1⁄16-1A @ 250Vac) — 10kA (1⁄16-10A @ 125Vac) — 200A (15-20A @ 125Vac) — 100A (25-30A @ 125Vac) — 1000A (8-30A @ 32Vac) Agency information: cULus: AGX 0-10A (Guide JDYX, File E 19180 and Guide JDYX7, File E19180), UL Recognized Card: AGX 15-30A (Guide JDYX2, File E19180), CSA Component Acceptance Card : AGX 15-30A (Class No. 1422-01, File 53787) Features and benefits • Fast-acting for maximum protection. • Size rejects insertion of other fuse types. Features and benefits • Fast-acting for maximum protection. Typical applications • Electronic circuits Catalog numbers (amps) AGW-1 AGW-4 AGW-15 AGW-1- 1⁄2 AGW-5 AGW-20 AGW-2 AGW-6 AGW-25 AGW-2- 1⁄2 AGW-7-1⁄2 AGW-30 AGW-3 AGW-10 Typical applications • Electronic circuits Features and benefits • Size rejects insertion of other fuse types. Catalog numbers (amps) AGA-1 AGA-5 AGA-15 AGA-1-1⁄2 AGA-6 AGA-20 AGA-2 AGA-7 AGA-25 Typical applications • Electronic circuits AGA-2-1⁄2 AGA-7-1⁄2 AGA-30 Catalog numbers (amps) AGA-3 AGA-10 Data Sheet: 2039 4-6 Data Sheet: 2040 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 AGX-1⁄4 AGX-1-1⁄2 AGX-3⁄10 AGX-2 AGX-10 AGX-3⁄8 AGX-2-1⁄2 AGX-15 AGX-4⁄10 AGX-3 AGX-20 AGX-1⁄2 AGX-4 AGX-25 AGX-3⁄4 AGX-5 AGX-30 AGX-1 AGX-6 AGX-1-1⁄4 AGX-7 Data Sheet: 2041 Eaton.com/bussmannseries AGX-8 Electronic – PCB and small dimension fuses 4 1/4˝ x 1 1/4˝ fast-acting fuses ABC (ABC-V axial leads) GBB (GBB-V axial leads) Specifications Description: Fast-acting fuse. Dimensions: 1⁄4˝ x 1 1⁄4˝ (6.4 x 31.7mm). Specifications Description: Fast-acting fuse. Dimensions: 1 ⁄4˝ x 1 1⁄4˝ (6.4 x 31.7mm). Specifications Description: Very fast-acting fuse. Dimensions: 1 ⁄4˝ x 1 1⁄4˝ (6.4 x 31.7mm). Construction: Ceramic cartridge with nickel-plated brass endcaps. Ratings: Volts — 250Vac/125Vdc Amps — 1-30A IR — 200A @ 250Vac — 200A (20-30A @ 125Vac/dc) — 10,000A (1A -15A @ 125Vac/dc) Agency information: CE, Std. 248-14, UL Recognized, 1-30,125Vdc/250Vac, File E56412, Guide JFHR2, CSA Accepted, 1-30, 125Vdc/250Vac, File 53787, Class 1422-30. Construction: Ceramic tube with nickel-plated brass endcaps. Ratings: Volts — 250Vac/125Vdc (1⁄4-15A, 20-30A)* — 250Vac (18A) — 32Vdc (self certified) Amps — 1⁄4-30A IR** — 35A (1⁄4-1A @ 250Vac) — 100A (11⁄2-3A @ 250Vac) — 200A (4-10A @ 250Vac) — 750A (12-15A @ 250Vac) — 400A (18-20A @ 250Vac) — 10kA (1⁄4-15A @ 125Vac) — 1kA (18-30A @ 125Vac) — 10kA (1⁄4-15, 20A @ 125Vdc) — 400A (25-30A @ 125Vdc) — 200A (25-30A @ 250Vac) Construction: Glass tube with nickel-plated brass endcaps. Ratings: Volts — 250Vac (1⁄20-10A) — 32Vac (12-40A) — 32Vdc (self certified) Amps — 1⁄20-40A IR — 35A (1⁄20-1A @ 250Vac) — 100A (11⁄4-3A @ 250Vac) — 200A (4-10A @ 250Vac) — 10kA (1⁄20-10A @ 125Vac) — 1000A (12-40A @ 32Vac) Agency information: CE, UL Listed, Guide JDYX, File E19180, 0-10A UL Recognized, Guide JDYX2, File E19180, 12-30A CSA Certification, Class 1422-01, File 053787, 1⁄20-30A. Features and benefits • Original electronic glass tube fuse. • Fast-acting for maximum protection. • Wide amp/volt ratings allow versatility of protecting electronic circuits. Typical applications • Electronic circuits Catalog numbers (amps) With axial leads AGC-V-1⁄20-R AGC-V-1⁄10-R AGC-V-1⁄8-R AGC-V-3⁄16-R AGC-V-2⁄10-R AGC-V-1⁄4-R AGC-V-3⁄10-R AGC-V-3⁄8-R AGC-V-1⁄2-R AGC-V-3⁄4-R AGC-V-1-R AGC-V-1- 1⁄4-R AGC-V-1- 1⁄2-R AGC-V-2-R AGC-V-2- 1⁄4-R AGC-V-2- 1⁄2-R AGC-V-3-R AGC-V-4-R AGC-V-5-R AGC-V-6-R AGC-V-7-R AGC-V-7- 1⁄2-R AGC- ⁄20-R AGC-1⁄10-R AGC-1⁄8-R AGC-3⁄16-R AGC-2⁄10-R AGC-1⁄4-R AGC-3⁄10-R AGC-3⁄8-R AGC-1⁄2-R AGC-3⁄4-R AGC-1-R AGC-1- ⁄4-R AGC-1- 1⁄2-R AGC-2-R AGC-2- 1⁄4-R AGC-2- 1⁄2-R AGC-3-R AGC-4-R AGC-5-R AGC-6-R AGC-7-R AGC-7- 1⁄2-R Without axial leads 1 Data Sheet: 2543 1 AGC-V-8-R AGC-V-9-R AGC-V-10-R AGC-V-12-R AGC-V-14-R AGC-V-15-R AGC-V-20-R AGC-V-25-R AGC-V-30-R AGC-V-35-R AGC-V-40-R AGC-8-R AGC-9-R AGC-10-R AGC-12-R AGC-14-R AGC-15-R AGC-20-R AGC-25-R AGC-30-R AGC-35-R AGC-40-R Features and benefits • Very fast-acting performance allows protection of highly sensitive electronic circuitry. *CSA approvals for 25A and 30A are at 125Vac – IR 1000A and Vdc – IR 400A (IR 1000A at 75Vdc) **Interrupting ratings measured at 70% – 80% power factor on AC. The interrupting ratings for 18A and 20A were measured at 85%-95% power factor on AC. The interrupting ratings for 25A and 30A were measured at 89% power factor on AC. Agency information: CE, Std. 248-14 UL Listed, Guide JDYX File E19180, 1 ⁄4-15A; UL Recognized, Guide JDYX2, File E19180, 18-30A; CSA Certification, Class 1422-01 & 1422-30, File 53787, 1 ⁄4-30A. Typical applications • Electronic circuits Catalog numbers (amps) With axial leads GBB-V-1-R GBB-V-1-1⁄4-R GBB-V-2-R GBB-V-3-R GBB-V-4-R GBB-V-5-R Features and benefits • Ceramic body allows for higher amp/volt rating combinations. Without axial leads GBB-1-R GBB-6-R GBB-1-1⁄4-R GBB-7-R GBB-2-R GBB-8-R GBB-3-R GBB-9-R GBB-4-R GBB-10-R GBB-5-R GBB-12-R Typical applications • Electronic circuits Catalog numbers (amps) With axial leads ABC-V- 1⁄4-R ABC-V- 1⁄2-R ABC-V- 3⁄4-R ABC-V-1-R ABC-V-1- 1⁄2-R ABC-V-2-R ABC-V-2- 1⁄2-R ABC-V-3-R ABC-V-4-R ABC-V-5-R ABC-V-6-R ABC-V-7-R ABC-V-8-R ABC-V-10-R ABC-V-12-R ABC-V-15-R ABC-V-18-R ABC-V-20-R ABC-V-25-R ABC-V-30-R ABC- 1⁄4-R ABC- 1⁄2-R ABC- 3⁄4-R ABC-1-R ABC-1- 1⁄2-R ABC-2-R ABC-2- 1⁄2-R ABC-3-R ABC-4-R ABC-5-R ABC-6-R ABC-7-R ABC-8-R ABC-10-R ABC-12-R ABC-15-R ABC-18-R ABC-20-R ABC-25-R ABC-30-R Without axial leads Data Sheet: 2000 BUSSMANN SERIES FULL LINE CATALOG GBB-V-6-R GBB-V-7-R GBB-V-8-R GBB-V-9-R GBB-V-10-R GBB-V-12-R GBB-V-15-R GBB-V-20-R GBB-V-25-R GBB-V-30-R GBB-15-R GBB-20-R GBB-25-R GBB-30-R Data Sheet: 2013 1007—July 2015 Eaton.com/bussmannseries 4-7 Electronic fuses AGC (AGC-V axial leads) Electronic – PCB and small dimension fuses 4 1/4˝ x 1 1/4˝ time-delay fuses MDL-V (axial leads) MDL Specifications Description: Time-delay fuse. Dimensions: 1⁄4˝ x 1 1⁄4˝ (6.4 x 31.7mm). Construction: Glasstube with nickel-plated brass endcaps. Ratings: Volts — 250Vac (1⁄16-8A) — 32Vac (9-30A) — 32Vdc (Self Certified) Amps — 1⁄16-30A IR* — 35A (1⁄16-1A @ 250Vac) — 100A (11⁄4-3A @ 250Vac) — 200A (4-8A @ 250Vac) — 10000A (1⁄16-8A @ 125Vac) — 1000A (9-30A @ 32Vac) *Interrupting ratings were measured at 70% – 80% power factor on AC, and at a time constant described in UL 198L. Agency information: CE, UL Listed, Guide JDYX, File E19180, 1⁄16-8A; CSA Certification Class 1422-01, 1⁄16-8A; UL Recognized, Guide JDYX2, File E19180, 9-30A; CSA Component Acceptance, Class 142230, 9-30A. Features and benefits • Time-delay allows close sizing on inductive circuits. Typical applications • Electronic circuits MDA-V (axial leads) MDQ MDA Specifications Description: Dual-element, time-delay fuse. Dimensions: 1⁄4˝ x 1 1⁄4˝ (6.4 x 31.7mm). Specifications Description: Time-delay fuse. Dimensions: 1⁄4˝ x 1 1⁄4˝ (6.35 x 31.75mm). Construction: Ceramic tube with nickel-plated brass endcaps. Ratings: Volts — 250Vac (or less) — 125Vdc (20A- 30A) — 32Vdc (Self certified) Amps — 1⁄4-30A IR** — 35A (1⁄4-1A @ 250Vac) — 100A (11⁄2-2A @ 250Vac) — 200A (21⁄2-10A @ 250Vac) — 750A (12-15A @ 250Vac) — 1500A (20-30A @ 250Vac) — 10kA (1⁄4-30A @ 125Vac) — 10kA (20-30A @ 125Vdc) Construction: Glass tube with nickel-plated brass endcaps. Ratings: Volts — 250Vac (1⁄100-7A) — 32Vac (71⁄2-15A) — 32Vdc (Self Certified) Amps — 1⁄100-15A IR — 35A (1⁄100-1A @ 250Vac) — 100A (11⁄4-3A @ 250Vac) — 200A (4-7A @ 250Vac) — 1000A (71⁄2-12A @ 32Vac) Agency information: Std. 248-14, UL Listed, File E19180; Guide JDYX, 1 ⁄16-7A CSA Certification, File 47233, Class 1422-01, 1⁄16 -7A, UL Recognized, Guide JDYX2, File E19180, 7.1-30A. Features and benefits • Dual-element design allows closer sizing to inductive circuits than any other fuses. Typical applications • Electronic relay and control circuits Catalog numbers (amps) Catalog numbers (amps) With axial leads MDL-V- 1⁄16-R MDL-V- 1⁄10-R MDL-V- 1⁄8-R MDL-V- 2⁄10-R MDL-V- 3⁄16-R MDL-V- 1⁄4-R MDL-V- 3⁄10-R MDL-V- 3⁄8-R MDL-V- 1⁄2-R MDL-V- 3⁄4-R MDL-V-1-R MDL-V-1- 1 ⁄4-R MDL-V-1- 1⁄2-R MDL-V-2-R MDL-V-2- 1⁄4-R MDL-V-2- 1⁄2-R MDL-V-3-R MDL-V-3- 2⁄10-R MDL-V-4-R MDL-V-5-R MDL-V-6-R MDL-V-7-R MDL-V-8-R MDL-V-9-R MDL-V-10-R MDL-V-12-R MDL-V-15-R MDL-V-20-R MDL-V-25* MDL-V-30* MDL- 1⁄16-R MDL- 1⁄10-R MDL- 1⁄8-R MDL- 2⁄10-R MDL- 3⁄16-R MDL- 1⁄4-R MDL- 3⁄10-R MDL- 3⁄8-R MDL- 1⁄2-R MDL- 3⁄4-R MDL-1-R MDL-1- 1⁄4-R MDL-1- 1⁄2-R MDL-2-R MDL-2- 1⁄4-R MDL-2- 1⁄2-R MDL-3-R MDL-3- 2⁄10-R MDL-4-R MDL-5-R MDL-6-R MDL-7-R MDL-8-R MDL-9-R MDL-10-R MDL-12-R MDL-15-R MDL-20-R MDL-25* MDL-30* Without axial leads MDQ-V (axial leads) With axial leads MDQ-V-1⁄100 MDQ-V-3⁄10 MDQ-V-1⁄32 MDQ-V-3⁄8 MDQ-V-1⁄16 MDQ-V-4⁄10 MDQ-V-1⁄10 MDQ-V-1⁄2 MDQ-V-1⁄8 MDQ-V-6⁄10 MDQ-V-15⁄100 MDQ-V-3⁄4 MDQ-V-175⁄1000 MDQ-V-8⁄10 MDQ-V-3⁄16 MDQ-V-1 MDQ-V-2⁄10 MDQ-V-1-2⁄10 MDQ-V-1⁄4 MDQ-V-1-1⁄4 Without axial leads MDQ-1⁄100 MDQ-3⁄10 MDQ-1⁄32 MDQ-3⁄8 MDQ-1⁄16 MDQ-4⁄10 MDQ-1⁄10 MDQ-1⁄2 MDQ-1⁄8 MDQ-6⁄10 MDQ-15⁄100 MDQ-3⁄4 MDQ-175⁄1000 MDQ-8⁄10 MDQ-3⁄16 MDQ-1 MDQ-2⁄10 MDQ-1-2⁄10 MDQ-1⁄4 MDQ-1-1⁄4 MDQ-V-1-1⁄2 MDQ-V-1-6⁄10 MDQ-V-1-8⁄10 MDQ-V-2 MDQ-V-2-1⁄4 MDQ-V-2-1⁄2 MDQ-V-2-8⁄10 MDQ-V-3 MDQ-V-3-2⁄10 MDQ-V-4 MDQ-V-5 MDQ-V-6 MDQ-V-6-1⁄4 MDQ-V-7 MDQ-V-7-1⁄2 MDQ-V-8 MDQ-V-9 MDQ-V-10 MDQ-V-12 MDQ-15 MDQ-1-1⁄2 MDQ-1-6⁄10 MDQ-1-8⁄10 MDQ-2 MDQ-2-1⁄4 MDQ-2-1⁄2 MDQ-2-8⁄10 MDQ-3 MDQ-3-2⁄10 MDQ-4 MDQ-5 MDQ-6 MDQ-6-1⁄4 MDQ-7 MDQ-7-1⁄2 MDQ-8 MDQ-9 MDQ-10 MDQ-12 MDQ-15 *MDL-25 & MDL-30 are not available in RoHS compliant construction. Data Sheet: 2004 4-8 Data Sheet: 2044 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 **Interrupting ratings were measured at 70% – 80% power factor on AC, and at a time constant described in UL 248. Agency information: CE, Std. 248-14, UL Listed, Guide JDYX, File E19180, 0-20A CSA Certification, Class 1422-01, File 53787, 0-20A. UL Recognized, Guide JDYX2, File E19180, 25-30A, CSA Component Acceptance, Class 1422-30, 25-30A Features and benefits • Ceramic body allows for higher amp/volt rating combinations. • Inventory consolidation by replacing MDL fuses allows for reduced SKU investment and minimizing potential for misapplying fuse. Typical applications • Electronic circuits Catalog numbers (amps) With axial leads MDA-V-1⁄4-R MDA-V-1⁄2-R MDA-V-3⁄4-R MDA-V-1-R MDA-V-1-1⁄2-R MDA-V-2-R MDA-V-2-1⁄2-R MDA-V-3-R MDA-V-4-R MDA-V-5-R MDA-V-6-R MDA-V-7-R MDA-V-8-R MDA-V-10-R Without axial leads MDA-1⁄4-R MDA-3-R MDA-1⁄2-R MDA-4-R MDA-3⁄4-R MDA-5-R MDA-1-R MDA-6-R MDA-1-1 ⁄2-R MDA-7-R MDA-2-R MDA-8-R MDA-2-1⁄2-R MDA-10-R Data Sheet: 2002 Eaton.com/bussmannseries MDA-V-12-R MDA-V-15-R MDA-V-20-R MDA-V-25A-R MDA-V-30A-R MDA-12-R MDA-15-R MDA-20-R MDA-25A-R MDA-30A-R Electronic – PCB and small dimension fuses 4 PC board mount fuse holders HTC-45M HTC-50M HTC-60M PCB horizontal mount PCB stand-off mount PCB vertical mount Specifications Description: PCB vertical mount bayonet cap and fuse holder. Dimensions: See dimensions illustration. Ratings: See specifications table. Agency information: See specifications table notes 1, 2, 5. 1.303" Mounting Holes (33.1mm) Dimensions - in (mm) 1.303" (33.1mm) Printed Circuit Board Specifications Description: Four-leg PCB stand-off fuse holder. Dimensions: See dimensions illustration. Ratings: Volts: — 250V Amps: — 6.3A Agency information: See specifications table notes 1, 4. Dimensions - in (mm) HTC-65M (4-Leg) Mounting Holes _ 0.002" Dia. (Typ.) 0.051" + ( 1.30 _+ 0.05mm) 0.394" .886" (3.5mm) (10.0mm) Printed Circuit Board 0.512" (3.5mm) 0.512" 4 (13.0mm) S FU E .591" mm) S FU E (15.0mm) . 0.461" .102" Dia. Hole (2.6mm) .051" Dia. Hole 0.461" (11.7mm) Data Sheet 2110 .102 .138" (13.0mm) (11.7mm) (9.0mm) .551" 0.394" _ 0.002" Dia. (Typ.) 0.051" + ( 1.30 _+ 0.05mm) .354" (22.5mm) (10.0mm) Data Sheet 2110 Specifications Terminals — Tin-plated brass with 3mm (HTC-35M, -55M) and 4.8mm (HTC-70M). Molded materials — High temperature thermoplastic that meets the flammability ratings of UL 94VO; Glow Wire Test: 960°C per IEC 695-2-1. Solderability — In accordance with IEC 68-2-20. Electrical — Contact resistance: 10MW; _ dielectric strength >2000Vac. _ Ratings — 250V, 10A, UL (1.3mm) . Data Sheet 2110 Shock safety — PC2 (fuse holders). Agency information: 1) 2) 3) 4) 5) cURus: Guide 1ZLT2 & IZLT8, File E14853 VDE: 40004457 VDE: 40004458 VDE: 40004459 VDE: 40004463 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 4-9 Electronic fuses Dimensions - in (mm) Specifications Description: PCB horizontal mount bayonet cap and fuse holder. Dimensions: See dimensions illustration. Ratings: See specifications table. Agency information: See specifications table notes 1, 2. Electronic – PCB and small dimension fuses 4 HBH-I PC board mount fuse holders HBV-I (for 1⁄4˝ x 1 1⁄4˝ fuses) HBH-M HBV-M (for 5 x 20mm fuses) HBW-I (for 1⁄4˝ x 1 1⁄4˝ fuses) (for 1⁄4˝ x 1 1⁄4˝ fuses) HBW-M (for 5 x 20mm fuses) (for 5 x 20mm fuses) PCB horizontal PCB vertical mount PCB vertical mount mount with stability pins without stability Specifications Description: PCB horizontal mount fuse holder. Dimensions: See dimensions illustration. Ratings: See specifications table. Specifications Description: PCB vertical mount fuse holder with stability pins. Dimensions: See dimensions illustration. Ratings: See specifications table. pins Dimensions - in (mm) Dimensions - in (mm) Specifications Description: PCB vertical mount fuse holder without stability pins. Dimensions: See dimensions illustration. 0 Ratings: See specifications table. 0 Dimensions - in (mm) (13.5mm) 0.531" (5.0mm) 0.200" HBV 0.510" 0.100" Dia. 4 Holes (2.54mm) (13.0mm) 0.510" (5.0mm) 0.200" (13.5mm) 0.531" (47.0mm) (47.0mm) 1.855" (10.0mm) 0.400" 1.855" (1.3mm) 0.050" Dia. 2 Holes Panel PC Board Data Sheet: 2118 (10.0mm) 0.400" PC Board 0.040" 0.040" 0.580" Panel Dia. 2 Holes (1.3mm) (1.05mm) (1.05mm) (14.9mm) 0.050" HBW (13.0mm) (14.9mm) 0.580" P Data Sheet: 2118 FBI Data Sheet: 2118 FBM Fuse holder caps (fit all three shown above) Specifications Electrical ratings: UL — 16A @ 250V; CSA — 12A @ 250V; VDE — 6.3A @ 250V; SEMKO — 10A @ 250V Insulation resistance — 10 megohm at 500Vdc. Contact resistance — less than 0.005 ohms @ 200mV. Dielectric strength — over 200V/mil. Molded material: High dielectric molded phenolic with a UL 94V0 flammability rating. Fuse carrier and knob: Spring-loaded, bayonet-type. Tin plated brass. Screwdriver slotted. Mounting: “Kicked” terminals (all models) and stabilizer pins on HBV and HBW models for increased stability. Temperature Rating (RTI): Body: 150ºC, Knob: 130ºC Agency information: CE, UL Recognized — Guide IZLT2, File EI4853; CSA Certified — Class 6225-01, File 47235 VDE — 4009241 (HBV, HBW) SEMKO — 800444 4-10 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries Electronic – PCB and small dimension fuses 4 PC board fuseclips for 5mm diameter fuses HTC-15M, HTC-140M PCB mounted fuse holder and snap-on cover Voltage rating: 250V, 6.3A, 1.6W HTC-15M (fuse holder), HTC-140M (natural cover), HTC-150M* (transparent cover) Agency information: See specifications table notes 1, 3 on bottom of page 65 *Available in bulk only. Use this format: BK/HTC-150M 0.217 " 1.047" (13.5mm) (9.0mm) HTC-140M Cover 0.571" (14.5mm) (5.5mm) 0.531" 0.345" (26.6mm) Mounting Holes 0.890" (22.60mm) 0.866" (22.0mm) 0.177" (4.5mm) _ 0.002" Dia. (Typ.) 0.059" + + .05mm) (1.50 _ Data Sheet: 2110 0.319" (23.6mm) 0.61" (15.5mm) (0.79mm) 0.012" 0.217" (0.3mm) (5.5mm) 0.50" 0.50" Data Sheet: 2110 (12.7mm) (12.7mm) 4.32mm HTC-210M 2.54mm Data Sheet: 2110 6.22mm 3.91mm 2.85mm 1A3399 PCB fuseclips with end stops and straight leads Catalog numbers Clip material* Finish 1A3399-01 Beryllium copper* Silver 1A3399-04-R Beryllium copper* Bright tin 1A3399-10-R Spring bronze Bright tin 8.73mm 6.26mm 0.062" 0.115" 0.125" (1.6mm) (2.9mm) 0.254" (3.2mm) 0.237" (6.5mm) 0.060" (6.0mm) (1.5mm) *Beryllium copper recommended for amps higher than 15 amps. 2.29mm 2.54mm 1.46mm 2.54mm 0.225" (5.7mm) 0.125" (3.2mm) Electronic fuses PCB mounted fuseclip with end stops 0.157" (3.99mm) 0.929" 0.031" BUSS (12.7mm) BUSS PCB mounted fuseclip Construction: Tin-plated bronze Tape and fan fold packed Ammo Pack (AP/HTC-200M) 1000 pieces per box 0.50" (8.1mm) 0.177" (4.5mm) BUSS HTC-200M 0.030" (1.6mm) 0.188" (4.8mm) Data Sheet: 2131 0.180" 1A5018 0.440" (4.57mm) PCB high profile fuseclips with end Catalog numbers Clip material* 1A5018-07 Spring bronze 1A5018-10-R Spring bronze stops and straight leads Finish Silver Bright tin 0.230" (5.84mm) *Beryllium copper recommended for amps higher than 15 amps. (11.2mm) 0.140" 0.047" (3.7mm) (1.2mm) 0.180" (4.6mm) Data Sheet: 2131 1A5601 PCB fuseclips (0-7A) Catalog number Clip material 1A5601 Cartridge brass Data Sheet: 2131 0.246" 0.344" + 0.015" (6.3mm) (8.73mm + 0.38mm) Finish Bright tin 0.344" + 0.015" (8.73mm + 0.38mm) 0.141" + 0.015" (3.58mm + 0.38mm) 0.022" + 0.002" 0.060" 0.266" (1.5mm) (6.75mm) 0.032" + 0.002" (0.56mm + 0.05mm) 1A5602 PCB fuseclips (0-7A) Catalog number Clip material 1A5602 Cartridge brass Data Sheet: 2131 0.250" (6.35mm) (0.81mm + 0.05mm) 0.219" (5.57mm) Finish Bright tin 0.500" (6.35mm) 0.140" (3.56mm) 0.093" 0.216" (5.48mm) BUSSMANN SERIES FULL LINE CATALOG 0.250" (12.70mm) 1007—July 2015 (2.36mm) LEGS TO FIT IN 0.052" (1.3mm) DIA. HOLES ON CENTER 0.047" (1.19mm) Eaton.com/bussmannseries 4-11 4 Electronic – PCB and small dimension fuses PC board fuseclips for 1/4˝ diameter fuses (2.6mm) 1A3398 0.250" (7.1mm) (6.35mm) PCB fuseclips without end stops with straight leads Clip material Finish Catalog numbers 1A3398-07-R Cartridge brass Bright tin 0.155" 0.245" (3.94mm) (6.2mm) 0.410" (10.4mm) 0.060" Data Sheet: 2131 0.140" (1.5mm) 0.102" Dia. (2.6mm) " 0.280" (3.6mm) (7.1mm) 0.320" (8.13mm) 1A1907 PCB fuseclips with end stops and straight leads Catalog numbers Clip material* Finish 1A1907-02 Cartridge brass None/bright dipped 1A1907-03-R High performance copper* Bright tin 1A1907-05 High performance copper* Silver 1A1907-06-R Cartridge brass Bright tin *High performance copper recommended for amps higher than 15A. Data Sheet: 2131 0.102" Dia. (2.6mm) 0.255" (6.5mm) 0.280" (7.1mm) 0.155" (3.94mm) 0.245" (6.2mm) 0.410" 0.102" Dia. (10.4mm) 0.060" 0.140" (1.5mm) (2.6mm) (8.13mm) 0.280" 0.245" (6.2mm) *High performance copper recommended for amps higher than 15A. out leads Finish Bright tin Bright tin 0.280" (7.1mm) (3.6mm) (7.1mm) 0.320" 1A4533 PCB fuseclips without end stops or angled Catalog numbers Clip material* 1A4533-01-R High performance copper* 1A4533-06-R Cartridge brass 0.280" (7.1mm) 0.155" (3.94mm) 0.102" (2.6mm) 0.410" (10.4mm) 0.255" (6.5mm) 0.060" (1.5mm) Data Sheet: 2131 0.320" 0.150" (3.81mm) 0.228" 0.280" (7.11mm) (5.79mm) 0.323" (8.20mm) 1A4534 0.245" (6.2mm) PCB fuseclips with end stops and angled out leads Catalog numbers Clip material* Finish 1A4534-01-R High performance copper* Bright tin 1A4534-06-R Cartridge brass Bright tin (8.13mm) 0.155" (3.94mm) 0.102" (2.6mm) 0.410" (10.4mm) 0.255" (6.5mm) *High performance copper recommended for amps higher than 15A. 0.060" (1.5mm) Data Sheet: 2131 0.320" 0.150" (3.81mm) 0.228" (8.13mm) (5.79mm) 0.323" (8.20mm) 1A1119 0.132" 0.285" Fuseclips with end stops and angled in leads Catalog numbers Clip material* Finish 1A1119-04-R High performance copper* Bright tin 1A1119-05 High performance copper* Silver 1A1119-10-R Cartridge brass Bright tin (3.4mm) (7.24mm) 0.420" 0.187" (10.67mm) 0.250" (6.5mm) *High performance copper recommended for amps higher than 15A. Data Sheet: 2131 (4.8mm) 0.312" (7.9mm) 0.290" 0.155" 0.080" (2.03mm) 0.280" (7.11mm) (7.4mm) (3.9mm) 0.360" (9.14mm) 1A1120 PCB fuseclips without end stops or angled Catalog numbers Clip material* 1A1120-02 Cartridge brass 1A1120-05 High performance copper* 1A1120-06-R High performance copper* 1A1120-09-R Cartridge brass *High performance copper recommended for amps higher than 15A. in leads Finish None/bright dipped Silver Bright tin Bright tin 0.272” [6.91] 0.250” [6.35] 0.080” [2.03] 0.320” [8.13] Ø 0.130”±.003 [3.3mm±0.08] C L 0.400”±.010 [10.16±0.25] 0.155”±.010 [3.94±0.25] Data Sheet: 2131 4-12 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 0.290”±.010 [7.37±0.25] 0.363”±.003 [9.22±0.08] 0.187” [4.75] 0.312” [7.92] Electronic – PCB and small dimension fuses 4 PC board fuseclips for 1/4˝ diameter fuses 5681 and 5682 PCB fuseclips with mounting holes For 1⁄4˝ diameter fuses Catalog number End stop Clip mat.** 5681-08 No Spg. br. 5681-01 5681-15-R 5682-01 5682-02 5682-11-R 5682-41-R 5682-44-R BeCu Yes Finish C end stop) (Contact) (Height) (Width) Hole dia. Nickel † 0.265 0.41 0.32 0.132 Fig. 2 Silver 0.108 Bright tin 0.131 0.262 0.41 0.32 0.132 Fig. 1 Bright tin 0.132 Silver Spg. br. Bright tin BeCu Silver BeCu BeCu Spg. br. Spg. br. Dimensions (Inches) D E B (To Bright tin 0.106 Ref. B E Figure 1 C C D D E Figure 2 Electronic fuses BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 4-13 Electronic – PCB and small dimension fuses 4 PC board fuseclips for 9/32˝, 13/32˝ and 9/16˝ diameter fuses 5672 and 5674 PCB fuseclips with mounting holes for 9⁄32˝ diameter fuses Catalog number 5672-11 5674-01 5674-10 5674-41 End stop No Yes Clip mat.** Finish BeCu Silver Spg. br. Bright tin BeCu Bright tin Spg. br. Bright tin B (To C Dimensions (Inches) D E end stop) (Contact) † 0.362 (Height) (Width) 0.52 0.38 Hole dia. Ref. 0.168 0.356 0.52 0.38 0.172 Fig. 1 B C 0.172 Fig. 2 D 1A3400*** For 13/32˝ diameter fuses With end stops and straight leads E Dimensional data 0.050" 0.437" Figure 1 (1.27mm) (11.1mm) 0.218" (5.54mm) 0.142" Dia. (3.61mm) 0.470" (11.94mm) 0.710" (18.03mm) Specifications: 0.080" 0.380" (2.03mm) (9.65mm) 0.470" (11.94mm) 1A3400-09 and 1A3400-10 1A3400-12 Catalog number 1A3400-09 1A3400-10 1A3400-12 Clip material Copper-clad steel Copper-clad steel Spring brass Finish Bright tin Silver Bright tin ***For RoHS compliant version add “-R” option code suffix to part number. 5956 and 5960 PCB fuseclips with mounting holes for 13⁄32˝ diameter fuses Catalog number 5956-16 5960-07 End stop No 5960-09 5960-44 5960-51 5960-53 Clip mat.** Finish BeCu Silver Spg. br. BeCu Yes 5960-61-R Spg. br. Spg. br. Spg. br. Spg. br. 5960-62-R Spg. br. 5960-63-R Spg. br. 5960-64-R Spr. br. Bright tin Silver Nickel Bright dip* Bright dip* Bright tin Bright tin Bright tin Bright tin B (To end stop) † 0.168 C Dimensions (inches) D E 0.71 0.47 (Contact) (Height) 0.312 (Width) 0.20 0.20 0.168 0.20 Hole dia. Ref. C 0.172 Fig. 2 0.196 0.172 0.387 0.71 0.47 0.168 0.197 0.196 Fig. 1 0.172 0.196 0.168 D 0.132 0.20 0.172 0.20 0.128 E 5591 and 5592 Figure 2 PCB fuseclips with mounting holes for 9⁄16˝ diameter fuses Catalog number 5591-42 5591-52-R 5592-01 End stop Yes No Clip mat.** Finish Spg. br. Bright tin Spg. br. BeCu Bright dip* Silver Dimensions (inches) C D E Hole B (To end stop) (Contact) (Height) (Width) dia. 0.26 0.252 * Bright dip is actually treated bare metal with no plating. ** Spg. br. — Spring bronze; BeCu — Beryllium copper. † Hole in center of both clip and contact area. 0.51 0.56 0.89 0.875 0.60 0.60 Ref. 0.172 Fig. 1 0.20 Fig. 2 Data Sheet: 2132 4-14 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries Amp rating 20A max. 30A max. 15A max.
BK/MDL-3-1/2-R 价格&库存
很抱歉,暂时无法提供与“BK/MDL-3-1/2-R”相匹配的价格&库存,您可以联系我们找货
