Technical Data ELX1020
Effective February 2021
HTJ
1/4” panel mount fuse holder family
Agency information
Environmental compliance
Ordering part number
BK1-HTJ-602I
Packaging prefix
Product features
For 1/4” fuses
Panel mount fuse holder
250 Vac rating and up to 15 A
Family name
Type
Packaging prefix
BK1- (1000 parts per case pack)
BK2- (2000 parts per case pack)
BK16- (1600 parts per carton)
HTJ
Specifications
Part number
BK16-HTJ-601I
BK1-HTJ-602I
BK1-HTJ-605I
BK1-HTJ-606I
BK2-HTJ-608I
Voltage rating
(Vac)
250
Current rating
(A)
10
250
10
250
10
250
10
250
15
Body material
Contact/clip material
Agency
Bakelite, UL 94V-0, black
Clip: copper alloy, nickel plated
Terminals: brass, nickel plated
Spring: steel
cURus, CE
Spring: steel
CE
Clip: brass, nickel plated
Spring: steel
cURus, CE
Clip: brass, tin plated
Terminals: brass, tin plated
Spring: steel
cURus, CE
Spring: steel
cURus, CE
Dimensions- mm
HTJ-601I
HTJ-602I
10.5
M15
(Length 53±1.0mm With Fuse Installed)
0.55±0.05
43.5±0.5
3
3
13.0
1.8
13.2±0.5
18±0.3
Recommended mounting hole
0.3±0.05
1.8
M15X1.0
15.2 -0.2
4.2±0.1
5.4±0.1
0.5±0.05
13.4±0.1
11.5±0.3
Recommend mounting hole
50.5±1.0
(After inserting the fuse 54.0±2.0)
HTJ-605I
HTJ-606I
4.25±0.1
R3-14
US
0.8±0.05
C
12.2+0/-0.2
12.4±0.15
250V 10A
13.2+0/-0.2
43.9
M13XP1.0
11±0.3
19.6
15±0.2
7.3
9.0
20.5
11.0
59.8±1
18.0±0.15
C
Mounting hole
2
10±0.3
US
14±0.2
www.eaton.com/electronics
0.4
9.5
6.3±0.1
4.7±0.1
16.7
17.5
1.8±0.2
HTJ
Dimensions- mm
HTJ-608I
Mounting hole
11.3±0.2
13.0±0.3
19.3±0.3
12.3±0.3
9.6±0.2
15.0±0.3
4.0±0.2
25.0±0.3
R3-9
15A250V AC
43.6±1
C
US
13.1±0.3
0.5±0.05
4.7±0.2
4.8±0.1
5.5±0.3
16.3±0.5
10.0±0.3
11.3±0.3
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. ELX1020 BU-ELX21021
February 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK2-HTJ-608I”相匹配的价格&库存,您可以联系我们找货
