DEL-E65-SMPR3-HLD
DEL-E65-SMPR3-HLD
    EATON(伊顿)
    EATON CUTLER HAMMER - DEL-E65-SMPR3-HLD - PHOTO SWITCH, REFLEX, 3M, NPN/PNP
DEL-E65-SMPR3-HLD 数据手册
Photoelectric sensors Test the Best Photoelectric Sensors: SM Series The SM Series exhibits superior excess gain. This means that in equal environments, with equal levels of contamination, the SM Series will perform more reliably over time, with less false trips. SM Series Sensor TargetLock: Taking the Guesswork Out of Alignment The performance of a sensor matters little if its misaligned in the first place. Even if you’ve never touched a sensor before, TargetLock helps you setup with the speed and accuracy of an expert. Compact, with industry-standard 18mm threaded barrel mounting. Understanding the Benefits of Excess Gain The SM Series redefines optical performance among compact photoeyes. When compared to the competition, Eaton sensors operate more releably in the presence of dust, humidity and debris. Higher reliability means less downtime, less maintenance, and more money in your pocket. If a sensor on your machine goes down, it can take your line with it. But what if there was a sensor smart enough to notify you of failure before it happens? The SM Series, with TargetLock™ marginal gain indication, does just that. As the sensor detects that its optical power is diminishing—either due to contamination or misalignment—the TargetLock indicator warns of an impending failure. The intelligence of TargetLock, combined with best-in-class sensing power, make the SM Series a compact photoelectric sensor you can depend on, day in and day out. Excess gain is a measurement of how much sensing power a photoelectric sensor has available beyond the power required to detect an object. An excess gain of 1.00 at a given range means there is just enough sensing power to detect an object under perfect conditions. In the real world, there is contamination—dust, dirt, oils, and debris—that can settle in the air or the lens and reduce light transmission. As the level of contamination gets worse, more excess gain is needed to push through contamination in the environment. The SM Series provides the highest excess gain in its operating class. In the chart below, the SM Series is compared to competitive units in its class. Range (m) 0.03 50 0.3 3.0 9.1 Throughout the alignment process, an internal microprocessor constantly measures the signal strength received, and communicates this through an orange LED on the top of the unit. This LED changes from off, to short flash, to long flash, to solid-on as you approach optimum alignment with the reflector. It acts in a similar fashion with diffuse sensors to help you position the target at the optimum range for its size and reflectivity. Optimizing performance provides a larger buffer against reliability problems due to dirty lenses or misalignment that can occur with impact or vibration over time. When problems occur, TargetLock alerts you to necessary maintenance—before your machine goes down. Test the Best 10 1 0.1 1 10 Range (feet) Note: Competitive performance information obtained from publicly available literature. Models compared: Eaton E65-SMPR3-HL; Banner QS18VN6LP; A-B 42EF-P2MPB-A2; SICK EL3-N2415. 30 Want to learn more about the E58 Series or the rest of Eaton’s line of rugged sensors? Visit us online and complete the Test the Best form. We’re so confident in our sensors, we’re willing to let you try one out—absolutely free. Learn more at: www.eaton.com/sensors Product Description The SM Series from Eaton provides the highest optical performance found in the compact photoelectric sensor class. The included TargetLock technology visually confirms the sensor is positioned to operate with the highest possible reliability and also provides diagnostic information during use to inform you of impending problems, before they result in equipment downtime. Beyond TargetLock, the SM Series includes a number of features that simplify use. Visible sensing beams on all models show you exactly where the sensor is pointing. The durable housing features multiple mounting options to easily fit on your equipment, even in the tightest spaces. Bright LED status indicators are visible from all angles. Comprehensive electrical protections—overvoltage, reverse polarity, short circuit—reduce the change of damage. Features • • Sensing Range 50 ft. (15m) • Available in AC/DC (18-264V AC, 18-50V DC) or DC-only (10-30V DC) • Visible red sensing beams on all models • Compact size to fit into tight spaces Multiple mounting options including industry-standard 18mm threads Thru-Beam Component Light Operate Dark Operate 10 in. @ 10 ft. (254mm @ 3m) Source E65-SMTS15-HA E65-SMTS15-HA Detector E65-SMTD15-HL E65-SMTD15-HD — E65-SMPR3-HL E65-SMPR3-HD — E65-SMSD200-HL E65-SMSD200-HD Polarized Reflex, 10-30 VDC Models  with 2m Cable  10 ft. (3m) 0.1-5 ft. — (30mm-1.5m) 1 in. @ 50 in. (25mm @ 1.3m) Diffuse Reflective, 10-30 VDC Models  with 2m Cable  8 in. (200mm) 0.25-5 in. (6-127mm) — 2 in. @ 5 in. (50mm @ 127mm) Perfect Prox® Background Rejection, 10-30 VDC Models  with 2m Cable  2 in. (50mm) 0.4-1.8 in. (10-45mm) 2.3 in. (58mm) 0.25 in. @ 2.25 in. (6mm @ 57mm) — E65-SMPP050-HL E65-SMPP050-HD 4 in. (100mm) 0.5-3.0 in. (13-76mm) 5.0 in. (127mm) 0.35 in. @ 5.0 in. (9mm @ 127mm) — E65-SMPP10-HL E65-SMPP100-HD  Sensor will ignore a 90% reflectance white card at—and beyond—this range.  This family is also available in AC/DC (18-264V AC, 18-50V DC) configuration. To specify an AC/DC model, simply substitute the H in the model num- ber with a G (for example, E65-SMPR3-HL would become E65-SMPR3-GL). For a complete model selection table, see the Sensing Solutions Catalog (CA08100010E) available online at www.eaton.com/sensors and orderable from Eaton’s Literature Fulfillment Center at 800-957-7050.  This family is also available with 4-pin micro connectors. To specify an micro connector model, simply add a D to the end of the model number (for exam- ple, E65-SMPR3-HL would become E65-SMPR3-HLD). For a complete model selection table, see the Sensing Solutions Catalog (CA08100010E) available online at www.eaton.com/sensors and orderable from Eaton’s Literature Fulfillment Center at 800-957-7050. TargetLock simplifies setup and ensures optimum sensor performance Available Perfect Prox models sense different colored targets at the same range, ignoring background objects Cutoff Range  Field of View 0.1-25 ft. — (30mm-7.5m) 4-Wire Sensors • Optimum Range Thru-Beam, 10-30 VDC Models with 2m Cable  Wiring Diagrams Full family includes thru-beam, polarized reflex, diffuse and Perfect Prox® models • Catalog Number SM Series Highly visible LED indicators for power, output and TargetLock • • Model Selection Table Operating Voltage Mounting Cable Models 10-30V DC  BN WH BK BU Load Micro Connector Models L2 or +V L1 or (-) No Connection L2 or +V Load No Connection L1 or (-)  This family is also available in AC/DC (18-264V AC, 18-50V DC) configuration. For a complete model selection table, see the Sensing Solutions Catalog (CA08100010E) available online at www.eaton.com/sensors and orderable from Eaton’s Literature Fulfillment Center at 800-957-7050. Dimensions Mounting Sensor Using #6 Hardware Approximate dimensions in inches (mm). 1.29 ( 33 ) M18 x 1.0 0.3 5 (9) 1.51 ( 3 8) 1.70 (43 ) ø 0.16 (4) 2 places The SM Series features two mounting holes in the rectangular section of the body for mounting to a surface with #6 or smaller hardware. The threaded barrel and jam nut allow mounting into any 0.75 in. (19mm) hole. Additionally, a selection of accessory mounting brackets are available from Eaton (see Sensing Solutions Catalog for full model selection). 0.8 3 1.02 (21) (26) Cable Models 0.75 (19) Connector Models 0.41 (10) 2.17 (55) AC/DC Models Only 1.6 3 (41) 0.58 (15) 1.05 (27) 1.47 (37) 0.10 (2.5) Mounting Sensor Using Jam Nut C-UL Listed, CE Approved Eaton Corporation Electrical Sector 1111 Superior Ave. Cleveland, OH 44114 United States 877-ETN-CARE (877-386-2273) Eaton.com © 2011 Eaton Corporation All Rights Reserved Printed in USA Publication No. PA05305004E / RG August 2011 Eaton is a registered trademark of Eaton Corporation. All other trademarks are property of their respective owners.
DEL-E65-SMPR3-HLD 价格&库存
很抱歉,暂时无法提供与“DEL-E65-SMPR3-HLD”相匹配的价格&库存,您可以联系我们找货
