DILM32-XHI22
DILM32-XHI22
    EATON(伊顿)
DILM32-XHI22 数据手册
Auxiliary�contact�module,�2N/O+2N/C Delivery�programme Part�no. Article�no. Catalog�No. DILM32-XHI22 277377 XTCEXFCC22 Product range Accessories Description Function Pole Connection technique Rated operational current AC-3 Conventional free air thermal current, 3 pole, 50 - 60 Hz Open at 60 °C AC-15 220 V 230 V 240 V 380 V 400 V 415 V Contacts N/O = Normally open N/C = Normally closed Mounting type Contact sequence                                     Accessories Auxiliary contact modules with interlocked opposing contacts for standard applications 4 pole Screw terminals         Ith =Ie   Ie Ie             A   A A             16   4 4   2 N/O 2 NC Front fixing For use with     Instructions     DILM(C)7-10… DILM(C)9-10… DILM(C)12-10… DILM(C)15-10… DILM(C)17-10… DILM(C)25-10… DILM(C)32-10… DILM38-10… DILMP20… DILMP32-10… DILMP45-10… DILL… Interlocked opposing contacts according to IEC/EN 60947-5-1 appendix L, inside the auxiliary contact modules, also for the integrated auxiliary contacts of the DILM 7 DILM32 Auxiliary contacts used as mirror contacts according to IEC/EN 60947-4-1 Appendix F (not N/C late open) Approvals Product Standards UL File No. UL Category Control No. CSA File No. CSA Class No. North America Certification Specially designed for North America IEC/EN 60947-4-1; UL 508; CSA-C22.2 No. 14-05; CE marking E29184 NKCR 012528 3211-03 UL listed, CSA certified No Electrical�specifications�for�standard�auxiliary�contacts Interlocked opposing contacts within an auxiliary contact module (to IEC 60947-5-1 Annex L) N/C contact (not late-break contact) suitable as a mirror contact (to IEC/ EN 60947-4-1 Annex F) Rated impulse withstand voltage     Yes     DILM7 - DILM38 Uimp 6000 Overvoltage category/pollution degree V AC     III/3 Ui 690 Rated operational voltage V AC Ue 500 Safe isolation to EN 61140 V AC         V AC 400   V AC 400   A   Rated insulation voltage between coil and auxiliary contacts between the auxiliary contacts Rated operational current 03/26/2014 HPL-ED2014 V2.13 EN 1/5 Conventional free air thermal current, 3 pole, 50 - 60 Hz Open at 60 °C AC-15 220 V 230 V 240 V 380 V 400 V 415 V 500 V DC current DC L/R 24 V 15 ms 60 V 110 V 220 V DC-13 (6xP) Contacts in series: 3 3 3 3 Control circuit reliability Component lifespan at Ue = 230 V, AC-15, 3 A Short-circuit rating without welding max. fuse             Ith =Ie A 16       Ie A 4 Ie A 4 Ie A 1.5             Ie A 10 Ie A 6 Ie A 3 Ie A 1         A   24 V A 2.5 60 V A 1 110 V A 0.5 220 V A 0.25 Failure rate λ
DILM32-XHI22 价格&库存
很抱歉,暂时无法提供与“DILM32-XHI22”相匹配的价格&库存,您可以联系我们找货
DILM32-XHI22
    • 1+342.64390
    • 2+324.00265
    • 10+211.26748
    库存:116
