E57P-30SPN15-Q
E57P-30SPN15-Q
    EATON(伊顿)
    EATON CUTLER HAMMER - E57P-30SPN15-Q - SENSOR, INDUCTIVE, 15MM, 10-48VDC, PNP
E57P-30SPN15-Q 数据手册
3.2 3 Inductive Proximity Sensors E57P Performance Series Sensors Contents E57P Performance Series Sensors Description 3 Page E57P Performance Series Sensors Product Selection E57P Performance Sensors . . . . . . . . . . . . Compatible Connector Cables . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 3 3 3 V8-T3-19 V8-T3-20 V8-T3-20 V8-T3-21 V8-T3-22 V8-T3-23 3 3 3 3 3 E57P Performance Series Sensors 3 Product Description Features For sensing applications requiring more demanding specifications, the new E57P Performance series incorporates premium features without the premium price. With its stainless steel tubular body, IP69K rating, wide temperature range (down to –40 °C), fast switching speed and laser-etched markings, the E57P series provides value at a low price point. ● 3 3 3 3 3 3 ● ● ● ● ● ● ● 360° LED indicator Stainless steel tube 10–48 Vdc operating voltage Short-circuit protection –40 to 70 °C temperature range IP69K environmental rating Durable laser-engraved label Available in cable and micro-connector styles Standards and Certifications ● ● cULus Listed CE 3 3 3 DANGER THIS SENSOR IS NOT A SAFETY DEVICE AND IS NOT INTENDED TO BE USED AS A SAFETY DEVICE. This sensor is designed only to detect and read certain data in an electronic manner and perform no use apart from that, specifically no safetyrelated use. This sensor product does not include self-checking redundant circuitry, and the failure of this sensor product could cause either an energized or de-energized output condition, which could result in death, serious bodily injury, or property damage. 3 3 3 3 3 3 3 3 3 For the most current information on this product, visit our Web site: www.eaton.com V8-T3-18 For Customer Service in the U.S. call 1-877-ETN CARE (386-2273), in Canada call 1-800-268-3578. For Application Assistance in the U.S. and Canada call 1-800-426-9184. Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com 3.2 Inductive Proximity Sensors E57P Performance Series Sensors Product Selection 3 E57P Performance Sensors 3 Three-Wire Sensors Operating Voltage 12 mm Sensing Range (Sn) Connection Type 1 NO Output Catalog Number NC Output Catalog Number Shielded (PNP) 2-meter cable E57P-12SPN2-C2 E57P-12SPC2-C2 4-pin micro DC connector E57P-12SPN2-Q E57P-12SPC2-Q Shielded (NPN) 2-meter cable E57P-12SNN2-C2 E57P-12SNC2-C2 4-pin micro DC connector E57P-12SNN2-Q E57P-12SNC2-Q Unshielded (PNP) 2-meter cable E57P-12UPN4-C2 E57P-12UPC4-C2 4-pin micro DC connector E57P-12UPN4-Q E57P-12UPC4-Q Unshielded (NPN) 2-meter cable E57P-12UNN4-C2 E57P-12UNC4-C2 4-pin micro DC connector E57P-12UNN4-Q E57P-12UNC4-Q Shielded (PNP) 2-meter cable E57P-12SPN4-C2 E57P-12SPC4-C2 4-pin micro DC connector E57P-12SPN4-Q E57P-12SPC4-Q Shielded (NPN) 2-meter cable E57P-12SNN4-C2 E57P-12SNC4-C2 4-pin micro DC connector E57P-12SNN4-Q E57P-12SNC4-Q Unshielded (PNP) 2-meter cable E57P-12UPN8-C2 E57P-12UPC8-C2 4-pin micro DC connector E57P-12UPN8-Q E57P-12UPC8-Q Unshielded (NPN) 2-meter cable E57P-12UNN8-C2 E57P-12UNC8-C2 4-pin micro DC connector E57P-12UNN8-Q E57P-12UNC8-Q 3 Shielded (PNP) 2-meter cable E57P-18SPN5-C2 E57P-18SPC5-C2 3 4-pin micro DC connector E57P-18SPN5-Q E57P-18SPC5-Q Shielded (NPN) 2-meter cable E57P-18SNN5-C2 E57P-18SNC5-C2 4-pin micro DC connector E57P-18SNN5-Q E57P-18SNC5-Q Unshielded (PNP) 2-meter cable E57P-18UPN8-C2 E57P-18UPC8-C2 4-pin micro DC connector E57P-18UPN8-Q E57P-18UPC8-Q Unshielded (NPN) 2-meter cable E57P-18UNN8-C2 E57P-18UNC8-C2 4-pin micro DC connector E57P-18UNN8-Q E57P-18UNC8-Q Shielded (PNP) 2-meter cable E57P-18SPN8-C2 E57P-18SPC8-C2 4-pin micro DC connector E57P-18SPN8-Q E57P-18SPC8-Q Shielded (NPN) 2-meter cable E57P-18SNN8-C2 E57P-18SNC8-C2 4-pin micro DC connector E57P-18SNN8-Q E57P-18SNC8-Q Unshielded (PNP) 2-meter cable E57P-18UPN12-C2 E57P-18UPC12-C2 4-pin micro DC connector E57P-18UPN12-Q E57P-18UPC12-Q Unshielded (NPN) 2-meter cable E57P-18UNN12-C2 E57P-18UNC12-C2 4-pin micro DC connector E57P-18UNN12-Q E57P-18UNC12-Q 3 12 mm Diameter End Sensing 10–48 Vdc 2 mm (standard range) 4 mm (standard range) 4 mm (extended range) 8 mm (extended range) 18 mm 3 Shielding 3 3 3 3 3 3 3 3 18 mm Diameter End Sensing 10–48 Vdc 5 mm (standard range) 8 mm (standard range) 8 mm (extended range) 12 mm (extended range) 3 3 3 3 3 3 3 3 3 Notes See listing of compatible connector cables on Page V8-T3-20. 3 1 3 For cable lengths longer than 2 meters, add the number of the desired length in meters to the end of the listed catalog number (for catalog numbers ending with a number, add an S and then the length). Examples for a 5-meter cable: E57-18LE12-A becomes E57-18LE12-A5; E57LAL12A2 becomes E57LAL12A2S5. 3 3 3 3 3 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com V8-T3-19 3.2 E57P Performance Series Sensors Three-Wire Sensors, continued 3 3 Inductive Proximity Sensors Operating Voltage 30 mm 3 Sensing Range (Sn) Shielding Connection Type 1 NO Output Catalog Number Shielded (PNP) 2-meter cable E57P-30SPN10-C2 E57P-30SPC10-C2 4-pin micro DC connector E57P-30SPN10-Q E57P-30SPC10-Q Shielded (NPN) 2-meter cable E57P-30SNN10-C2 E57P-30SNC10-C2 4-pin micro DC connector E57P-30SNN10-Q E57P-30SNC10-Q Unshielded (PNP) 2-meter cable E57P-30UPN15-C2 E57P-30UPC15-C2 4-pin micro DC connector E57P-30UPN15-Q E57P-30UPC15-Q Unshielded (NPN) 2-meter cable E57P-30UNN15-C2 E57P-30UNC15-C2 4-pin micro DC connector E57P-30UNN15-Q E57P-30UNC15-Q Shielded (PNP) 2-meter cable E57P-30SPN15-C2 E57P-30SPC15-C2 4-pin micro DC connector E57P-30SPN15-Q E57P-30SPC15-Q Shielded (NPN) 2-meter cable E57P-30SNN15-C2 E57P-30SNC15-C2 4-pin micro DC connector E57P-30SNN15-Q E57P-30SNC15-Q Unshielded (PNP) 2-meter cable E57P-30UPN22-C2 E57P-30UPC22-C2 4-pin micro DC connector E57P-30UPN22-Q E57P-30UPC22-Q Unshielded (NPN) 2-meter cable E57P-30UNN22-C2 E57P-30UNC22-C2 4-pin micro DC connector E57P-30UNN22-Q E57P-30UNC22-Q 30 mm Diameter End Sensing 10–48 Vdc 10 mm (standard range) 3 3 15 mm (standard range) 3 3 15 mm (extended range) 3 3 3 22 mm (extended range) 3 3 3 Compatible Connector Cables 3 Standard Cables 1 Current Rating Voltage at 600 V Style 3 3 NC Output Catalog Number Micro-Style Straight Female Number of Pins Gauge Length 22 AWG 6.0 ft (2m) Pin Configuration/Wire Colors (Face View Female Shown) PVC Jacket Catalog Number PUR Jacket Catalog Number CSDS4A4CY2202 CSDS4A4RY2202 Micro-Style, Straight Female — DC 3 4-pin, 4-wire 1-Brown 2-White 3-Blue 4-Black 3 3 3 Accessories E57P Performance Sensors 3 3 3 3 Description Reference Mounting brackets See Tab 8, section 8.2 Replacement mounting nuts and other accessories See Tab 8, section 8.3 Connector cables See Tab 10, section 10.1 Notes See listing of compatible connector cables on Page V8-T3-20. 3 1 3 2 For cable lengths longer than 2 meters, add the number of the desired length in meters to the end of the listed catalog number (for catalog numbers ending with a number, add an S and then the length). Examples for a 5-meter cable: E57-18LE12-A becomes E57-18LE12-A5; E57LAL12A2 becomes E57LAL12A2S5. For a full selection of connector cables, see Tab 10, section 10.1. 3 3 3 3 V8-T3-20 Volume 8—Sensing Solutions CA08100010E—December 2014 www.eaton.com Inductive Proximity Sensors E57P Performance Series Sensors 3.2 Technical Data and Specifications 3 E57P Performance Sensors Description 3 Performance Three-Wire DC Sensors 3 Operating voltage 10–48 Vdc Output current (continuous) 300 mA Switching frequency [Hz] Standard range: 12 mm—Shielded: 2000; Unshielded: 2000 18 mm—Shielded: 1200; Unshielded: 1200 30 mm—Shielded: 600; Unshielded: 500 Extended range: 12 mm—Shielded: 1200; Unshielded: 500 18 mm—Shielded: 300; Unshielded: 300 30 mm—Shielded: 400; Unshielded: 200 Leakage current
E57P-30SPN15-Q 价格&库存
很抱歉,暂时无法提供与“E57P-30SPN15-Q”相匹配的价格&库存,您可以联系我们找货
