Control�relay,�24�V�DC,�SWD
Part�no.
EASY802-DC-SWD
Article�no.
152901
Delivery�programme
Product range
Control relays easyRelay
Basic function
easy800 with SmartWire-DT
Product range
SmartWire-DT control relay easy800
Description
Combines the functionality of an easy800 with direct connection to
switchgear communication system for SmartWire-DT
Up to 99 SmartWire-DT modules with a total of up to 166 inputs/outputs
can be connected via a SmartWire-DT line
Inputs
83
83
SmartWire-DT
Outputs
SmartWire-DT
Additional features
Display
without display, without keypad
Expansions
SmartWire-DT
Supply voltage
24 V DC
Software
EASY-SOFT-PRO
Notes
Depending on the hardware, such as high-speed counter, PWM output, integrated analog input/output are not supported
Approbationen
NA Certification
General
Request filed for UL and CSA
Standards
EN 55011, EN 55022, IEC/EN 61000-4, IEC 60068-2-6, IEC 60068-2-27
Dimensions (W x H x D)
mm
35 x 110 x 125.5 (2 PE)
Weight
kg
0.16
Mounting
Top-hat rail IEC/EN 60715, 35 mm or screw fixing using fixing brackets
ZB4-101-GF1 (accessories)
Solid
mm
Flexible with ferrule
Operating ambient temperature
Terminal�capacities
2
0.2/1.5 (AWG 24 - 16)
mm
2
°C
In accordance with IEC 60068-2-1, -25 - +55
Condensation
Take appropriate measures to prevent condensation
LCD display (clearly legible)
°C
0 - 55
Storage
°C
In accordance with IEC 60068-2-1, -2, -14
-40 - +70
Climatic�environmental�conditions
05/14/2012
HPL-ED2012 V1.0 EN
1/4
relative humidity
nach IEC 60068-2-30, IEC 600068-2-78
5 - 95
Air pressure (operation)
hPa
795 - 1080
Protection type (IEC/EN 60529, EN50178, VBG 4)
IP20
Vibrations
Hz
nach IEC 60068-2-6
konstante Amplitude 0.15 mm: 10 - 57
konstante Beschleunigung 2 g: 57 - 150
Mechanical shock resistance (IEC/EN 60068-2-27) semi-sinusoidal 15
g/11 ms
Impacts 18
Drop to IEC/EN 60068-2-31
Drop
height
mm
50
Free fall, packaged (IEC/EN 60068-2-32)
m
0.3
Mounting position
Vertical or horizontal
Overvoltage category/pollution degree
III/2
Electrostatic discharge (ESD)
applied standard
according to IEC EN 61000-4-2
Air discharge
kV
8
Contact discharge
Ambient�conditions,�mechanical
Electromagnetic�compatibility�(EMC)
kV
6
Electromagnetic fields (RFI), to IEC EN 61000-4-3
V/m
0.8 - 1.0 GHz: 10
1.4 - 2 GHz: 3
2.0 - 2.7 GHz: 1
Radio interference suppression
EN 55011 Class B
Burst
according to IEC/EN 61000-4-4
Supply cables: 2
Signal cables: 2
SWD lines: 2
power pulses (Surge)
according to IEC/EN 61000-4-5
1 kV (supply cables, symmetrical)
Immunity to line-conducted interference to (IEC/EN 61000-4-6)
V
10
Clearance in air and creepage distances
EN 50178, UL 508, CSA C22.2, No. 142
Insulation resistance
EN 50178
Back-up of real-time clock
Insulation�resistance
Back-up�of�real-time�clock
Backup time (hours) with fully charged double layer capacitor
Service life (years)
Accuracy of real-time clock to inputs
s/
day
typ. ± 2 (± 0.2 h⁄Year)
depending on ambient air temperature fluctuations of up to ± 5 s/day (±
0.5 h⁄year) are possible
Accuracy of timing relays (of values)
± 0.02
Resolution
Repetition�accuracy�of�timing�relays
Range “S”
ms
5
Range “M:S”
s
1
Range “H:M”
min
1
10 (read⁄write cycles)
Rated operational voltage
Ue
V
24 DC (-15/+20%)
Permissible range
20.4 - 28.8 V DC
Residual ripple
Siemens MPI, (optional)
yes
Input current
normally 500 mA at Ue
Einschaltstrom- und dauer
A
12.5 für 6 ms
Voltage dips
ms
≤In accordance with IEC 61131-2
≤ 10
Retentive�memory
Write cycles of the retentive memory
Power�supply
05/14/2012
HPL-ED2012 V1.0 EN
14
5
2/4
Fuse
A
V
24 V DC (-15/+20%)
Permissible range
20.4 - 28.8 V DC
Output voltage SWD-OUT
Ue - 0.3 V
yes
Residual ripple on the input voltage
Max. current
Imax
A
3 (IEC)
2 (UL)
Short-circuit rating
no
Heat dissipation
W
Normally 1 W at 24 V DC
Potential isolation
from power supply POW: yes
to COM interface: yes
to SmartWire-DT: yes
Rated operating voltage
Ue
V
14.5 ± 3 %
max. current
Imax
A
0.4
Yes
Potential isolation
from power supply POW: no
to AUX: yes
Station type
Master
Number of SmartWire-DT slaves
Max.99
Baud Rates
kBd
125/250
Address allocation
Automatically (via Configuration button)
Status indication
LED
SWD-LED: orange/green/red
Config. LED: green/red
Connections
Plug, 8-pole
Plug connectors
Blade terminal SWD4-8MF2
Bus termination
Integrated in the device
SmartWire-DT line end with SWD4-RC8-10
Data transfer rate/distance
1000 KBit/s, 6 m
500 KBit/s, 25 m
250 Kbit/s, 40 m
125 Kbit/s, 300 m
50 KBit/s, 300 m
20 KBit/s, 700 m
10 KBit/s, 1000 m
Lengths from 40 m can be obtained only with cables with reinforced
cross-section and terminal adapter.
Potential isolation
From the inputs: yes
from the outputs: yes
to AUX: yes
Bus termination (first and last station)
ja
Anschlusstechnik
RJ45, 8-polig
Supply�voltage�UAux
SmartWire-DT�supply�voltage
SmartWire-DT�network
Netzwerk�easyNet
3 A (T) (e.g FAZ C3)
5
Dimensions
05/14/2012
HPL-ED2012 V1.0 EN
3/4
Additional�product�information�(links)
IL05013041Z�easy800-SWD
IL05013041Z easy800-SWD
ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL05013041Z2011_08.pdf
MN04902001Z-EN�(AWB2528-1423)�easy800�Control�Relay
MN04902001Z-DE (AWB2528-1423)
Steuerrelais easy800 - Deutsch
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN04902001Z_DE.pdf
MN04902001Z-EN (AWB2528-1423)
easy800 Control Relay - English
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN04902001Z_EN.pdf
BR05013001Z-EN, easy Family
http://www.moeller.net/binary/w_brochures/br05013001Z-en.pdf
Labeleditor
ftp://ftp.moeller.net/MFD/EASY-SOFT-PRO/labeleditor_206.exe
05/14/2012
Eaton Industries GmbH
http://www.moeller.net/en
© 04/2012 by Eaton Industries GmbH
HPL-ED2012 V1.0 EN
4/4
很抱歉,暂时无法提供与“EASY802-DC-SWD”相匹配的价格&库存,您可以联系我们找货
