ECMS1V0704-701-R
ECMS1V0704-701-R
    EATON(伊顿)
    水平式,4 PC 板
    2 线路共模扼流圈 表面贴装型 700 Ohms @ 100 MHz 4A DCR 15 毫欧
ECMS1V0704-701-R 数据手册
Technical Data ELX1112 Effective December 2021 ECMS1V0704 Common mode choke, surface mount Applications Product features • High frequency filter • Square type closed magnetic core • Current rating up to 15 A • 8.0 mm x 6.5 mm surface mount package in a 3.8 mm height • Moisture sensitivity level (MSL): 1 • Battery backup • Renewable energy products • High tech consumer products • Appliances • LED lighting • Smart meters • Industrial IoT equipment • Motion controls • Power supplies • Medical equipment Environmental compliance and general specifications • Storage temperature (component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ECMS1V0704 Common mode choke, surface mount  Technical Data ELX1112 Effective December 2021 Product specifications Impedance1 (Ω) mimimum Impedance1 (Ω ) typical DCR2 (mΩ) @ +25 °C maximum Rated current3 (A) maximum Rated voltage (Vdc) maximum Insulation resistance4 @ (MΩ) minimum ECMS1V0704-700-R 40 70 5 15 80 10 ECMS1V0704-141-R 100 140 10 9 80 10 ECMS1V0704-301-R 225 300 10 5 80 10 ECMS1V0704-451-R 275 450 10 5 80 10 ECMS1V0704-701-R 500 700 15 4 80 10 ECMS1V0704-102-R 800 1020 17 3 80 10 ECMS1V0704-132-R 910 1300 21 2.5 80 10 ECMS1V0704-272-R 2000 2700 63 1 80 10 ECMS1V0704-302-R 2500 3000 75 0.9 80 10 Part number 5 1. Impedance test parameters: 100 MHz, 0.1 Vrms, parallel connection (1,2 - 4,3), +25 °C 2. DCR test parameters: parallel connection (1,2 - 4,3), 4-wire method measured at +25°C 3. Rated current: DC current for an approximate temperature rise of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 4. Insulation resistance: Coil to coil 5. Part Number Definition: ECMS1Vxxxx-yyy-R ECMS1V = Product code xxxx= Size indicator yyy= Typical impedance value in ohms. R= decimal point, if no R is present then last digit indicates the number of zeros -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended PCB Layout Schematic Dimension Value A 7.0 ±0.5 A1 7.5 ±0.5 B 6.0 ±0.5 C 3.8 maximum D 1.5 typical E 1.7 typical F 3.5 typical Part marking: xxx= Typical impedance value in ohms All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.5 millimeters unless stated otherwise Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics ECMS1V0704 Common mode choke, surface mount Technical Data ELX1112 Effective December 2021  Packaging information (mm) Supplied in tape and reel packaging, 13” diameter reel (EIA-481 compliant) 1500 parts per reel Dimension Value W 16 ±0.3 F 7.5 ±0.1 E1 1.75 ±0.1 E2 na P0 4.0 ±0.1 P1 12 ±0.1 P2 2.0 ±0.1 D0 1.5 +0.1/-0 D1 1.5 +0.1/-0 A0 7.5 ±0.1 B0 7.2 ±0.1 K0 4.2 ±0.1 T 0.4 ±0.05 www.eaton.com/electronics 3 Technical Data ELX1112 Effective December 2021 Impedance vs frequency 4 www.eaton.com/electronics ECMS1V0704 Common mode choke, surface mount  ECMS1V0704 Common mode choke, surface mount Technical Data ELX1112 Effective December 2021  Impedance vs frequency www.eaton.com/electronics 5 Technical Data ELX1112 ECMS1V0704 Common mode choke, surface mount  Effective December 2021 Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
ECMS1V0704-701-R 价格&库存
很抱歉,暂时无法提供与“ECMS1V0704-701-R”相匹配的价格&库存,您可以联系我们找货
ECMS1V0704-701-R
    • 1+1.19880
    • 200+0.46397
    • 500+0.44766
    • 1500+0.43956
    ECMS1V0704-701-R
    • 1500+4.628301500+0.60067
    • 3000+4.364733000+0.56647
    • 4500+4.217744500+0.54739
    • 7500+4.039757500+0.52429
    • 10500+3.9267710500+0.50963
    • 15000+3.8105815000+0.49455
    库存:1920
    ECMS1V0704-701-R
      ECMS1V0704-701-R
        ECMS1V0704-701-R
        • 1+7.690651+0.99811
        • 10+6.3634310+0.82586
        • 25+5.8862225+0.76393
        • 50+5.5485650+0.72011
        • 100+5.23135100+0.67894
        • 250+4.83940250+0.62807
        • 500+4.56311500+0.59221
        库存:1920
