ECMT1V1714H-1R0-R
ECMT1V1714H-1R0-R
    EATON(伊顿)
    垂直式,4 PC 引脚
    1 mH @ 1 kHz 2 线路共模扼流圈 通孔 1A DCR 100 毫欧
ECMT1V1714H-1R0-R 数据手册
Technical Data ELX1092 Effective September 2021 ECMT1V17 Common mode choke, through-hole Applications Product features • Closed magnetic path reduces conductive EMI emission • High impedance and inductance values • Robust construction • High voltage isolation • Independent winding sections • Rated voltage: 250 Vac • Industrial IoT equipment • Motion controls • Power supplies • Battery backup • Renewable energy products • Smart meters • Solar/wind generators, inverters, charger controllers • Medical equipment • High tech consumer products • Appliances Environmental compliance and general specifications • Storage temperature range (Component): -40 °C to +85 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Wave solder temperature: +260 °C maximum HALOGEN Pb HF FREE ECMT1V17 Common mode choke, through-hole  Technical Data ELX1092 Effective September 2021 Product specifications Part number7 OCL1 (mH) minimum (1-2), (4-3) DCR2 (Ω) maximum (1-2), (4-3) @ +25 °C Irms3 (A) (1-4) short 2,3 SRF (kHz) minimum Hi-pot4 (Vac) Hi-pot5 (Vac) Insulation resistance6 (MΩ) minimum ECMT1V1717S-1R0-R 1.0 0.1 1.0 792 1500 1000 100 ECMT1V1714H-1R0-R 1.0 0.1 1.0 792 1500 1000 100 ECMT1V1717S-2R0-R 2.0 0.3 1.4 896 1500 1000 100 ECMT1V1714H-2R0-R 2.0 0.3 1.4 896 1500 1000 100 ECMT1V1717S-5R0-R 5.0 0.3 1.4 712 1500 1000 100 ECMT1V1714H-5R0-R 5.0 0.3 1.4 712 1500 1000 100 ECMT1V1717S-8R0-R 8.0 1.0 0.8 456 1500 1000 100 ECMT1V1714H-8R0-R 8.0 1.0 0.8 456 1500 1000 100 ECMT1V1717S-100-R 10 0.6 1.2 423 1500 1000 100 ECMT1V1714H-100-R 10 0.6 1.2 423 1500 1000 100 ECMT1V1717S-150-R 15 0.6 1.0 408 1500 1000 100 ECMT1V1714H-150-R 15 0.6 1.0 408 1500 1000 100 ECMT1V1717S-200-R 20 1.0 0.8 295 1500 1000 100 ECMT1V1714H-200-R 20 1.0 0.8 295 1500 1000 100 ECMT1V1717S-300-R 30 1.6 0.6 276 1500 1000 100 ECMT1V1714H-300-R 30 1.6 0.6 276 1500 1000 100 ECMT1V1717S-330-R 33 2.7 0.5 240 1500 1000 100 ECMT1V1714H-330-R 33 2.7 0.5 240 1500 1000 100 ECMT1V1717S-350-R 35 2.0 0.5 312 1500 1000 100 ECMT1V1714H-350-R 35 2.0 0.5 312 1500 1000 100 ECMT1V1717S-400-R 40 2.0 0.5 216 1500 1000 100 ECMT1V1714H-400-R 40 2.0 0.5 216 1500 1000 100 ECMT1V1717S-470-R 47 2.0 0.5 192 1500 1000 100 ECMT1V1714H-470-R 47 2.0 0.5 192 1500 1000 100 ECMT1V1717S-500-R 50 2.0 0.5 176 1500 1000 100 ECMT1V1714H-500-R 50 2.0 0.5 176 1500 1000 100 ECMT1V1717S-600-R 60 3.3 0.4 144 1500 1000 100 ECMT1V1714H-600-R 60 3.3 0.4 144 1500 1000 100 ECMT1V1717S-850-R 85 5.7 0.3 85 1500 1000 100 ECMT1V1714H-850-R 85 5.7 0.3 85 1500 1000 100 1. Open circuit inductance (OCL) Test parameters: 1 kHz, 0.25 Vrms, 0.0 Adc, +25 °C 2. DCR Test parameters: 4-wire method measured from the root of base, +25 °C 3. Irms: Maximum DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 2 www.eaton.com/electronics 4. Hi-pot: Coil-Coil, 2 seconds, 5 mA 5. Hi-pot: Coil-Core, 2 seconds, 5 mA 6. Insulation Resistance: Coil-Coil and Coil-Core, at 500 Vdc 7. Part Number Definition: ECMT1Vxxxxy-zzz-R ECMT1V = Product code xxxx= Size indicator y= Orientation H= horizontal, S= vertical zzz=Inductance value in mH, R= decimal point, If no R is present last digit indicates number of zeros -R= RoHS compliant Technical Data ELX1092 ECMT1V17  Common mode choke, through-hole Effective September 2021  Mechanical parameters, schematic, pad layout (mm) ECMT1V1717S-xxx-R Recommended PCB layout Schematic ECMT1V1714H-xxx-R Recommended PCB layout Schematic Part number A B C D E F G ECMT1V1717S-xxx-R 12.0 max. 17.0 max. 17.0 max. 3.5 ± 0.5 7.0 ± 0.5 8.0 ± 0.5 0.6 ± 0.1 ECMT1V1714H-xxx-R 17.0 max. 16.0 max. 14.0 max. 3.5 ± 0.5 7.0 ± 0.5 8.0 ± 0.5 0.6 ± 0.1 Part marking: xxx-wwyy, xxx =inductance value in mH, wwyy= lot code Trace or vias underneath the inductor is not recommended www.eaton.com/electronics 3 Technical Data ELX1092 Effective September 2021 ECMT1V17 Common mode choke, through-hole  Packaging information (mm) ECMT1V1717S-xxx-R Supplied in tray, 14 trays per carton. (88 parts per tray x 14 trays per box = 1232 parts per carton) (Tray height 17 mm) ECMT1V1714H-xxx-R Supplied in tray, 12 trays per carton. (88 parts per tray x 12 trays per box = 1056 parts per carton) (Tray height 19 mm) 4 www.eaton.com/electronics ECMT1V17  Common mode choke, through-hole Technical Data ELX1092 Effective September 2021  Impedance vs frequency www.eaton.com/electronics 5 Technical Data ELX1092 Effective September 2021 Impedance vs frequency 6 www.eaton.com/electronics ECMT1V17 Common mode choke, through-hole  ECMT1V17  Common mode choke, through-hole Technical Data ELX1092 Effective September 2021  Impedance vs frequency Measurement method www.eaton.com/electronics 7 Technical Data ELX1092 Effective September 2021 Inductance vs frequency 8 www.eaton.com/electronics ECMT1V17 Common mode choke, through-hole  ECMT1V17  Common mode choke, through-hole Technical Data ELX1092 Effective September 2021  Inductance vs frequency www.eaton.com/electronics 9 Technical Data ELX1092 Effective September 2021 Inductance vs frequency 10 www.eaton.com/electronics ECMT1V17 Common mode choke, through-hole  ECMT1V17  Common mode choke, through-hole Technical Data ELX1092 Effective September 2021  Wave solder profile Reference EN 61760-1:2006 Profile feature Preheat Standard SnPb solder Lead (Pb) free solder • Temperature min. (Tsmin) 100 °C 100 °C • Temperature typ. (Tstyp) 120 °C 120 °C • Temperature max. (Tsmax) 130 °C 130 °C • Time (Tsmin to Tsmax) (ts) 70 seconds 70 seconds D preheat to max Temperature 150 °C max. 150 °C max. Peak temperature (TP)* 235 °C – 260 °C 250 °C – 260 °C Time at peak temperature (tp) 10 seconds max 5 seconds max each wave 10 seconds max 5 seconds max each wave Ramp-down rate ~ 2 K/s min ~3.5 K/s typ ~5 K/s max ~ 2 K/s min ~3.5 K/s typ ~5 K/s max Time 25 °C to 25 °C 4 minutes 4 minutes Manual solder +350 °C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2021 Eaton All Rights Reserved Printed in USA Publication No. ELX1092 BU-ELX21102 September 2021 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
ECMT1V1714H-1R0-R 价格&库存
很抱歉,暂时无法提供与“ECMT1V1714H-1R0-R”相匹配的价格&库存,您可以联系我们找货
ECMT1V1714H-1R0-R
  • 1+16.182091+2.07568
  • 10+13.2883210+1.70450
  • 25+12.2902825+1.57648
  • 50+11.5883450+1.48644
  • 100+10.92579100+1.40146
  • 250+10.10856250+1.29663
  • 500+9.53170500+1.22264
  • 1056+8.947271056+1.14767
  • 3168+8.154373168+1.04596
库存:2396
