Technical Data ELX1192
Effective June 2022
ECSTA1V1308
Automotive grade SMT current sense transformer
Applications
Product features
AEC-Q200 qualified
EE8.3 SMT package
(13 mm x 11 mm x 7.8 mm)
Very low DC resistance
Wide selection of turns ratios
Sensed current – primary rated for 15 A
Frequency range: 50 kHz to 1 MHz
Moisture sensitivity level (MSL): 1
Motor drive
On-board chargers
DC/DC converters
Wireless chargers
Battery management systems (BMS)
EV charging
Feedback control
Overload sensing
Environmental compliance and general
specifications
Storage temperature (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb
HALOGEN
HF
FREE
ECSTA1V1308
Effective June 2022
Product specifications
Part number3
Turns ratio
sec :pri
Secondary
inductance (mH)
@ 100 kHz 0.1 V
minimum
DCR sec (Ω)
maximum
DCR pri (mΩ)
reference
Hi-pot pri to sec
@ 3 mA 3 seconds
50 Hz
Sensed
current1 (A)
maximum
ECSTA1V1308-1020-R
20:1
0.22
0.21
3.9
500 Vac
15
ECSTA1V1308-1030-R
30:1
0.5
0.32
3.9
500 Vac
15
ECSTA1V1308-1040-R
40:1
0.88
0.5
3.9
500 Vac
15
ECSTA1V1308-1050-R
50:1
1.4
0.65
3.9
500 Vac
15
ECSTA1V1308-1060-R
60:1
2
0.81
3.9
500 Vac
15
ECSTA1V1308-1070-R
70:1
2.7
1
3.9
500 Vac
15
ECSTA1V1308-1080-R
80:1
3.5
1.3
3.9
500 Vac
15
ECSTA1V1308-1100-R
100:1
5.6
2
3.9
500 Vac
15
ECSTA1V1308-1125-R
125:1
8.7
5.2
3.9
500 Vac
15
ECSTA1V1308-1150-R
150:1
12.6
6.5
3.9
500 Vac
15
ECSTA1V1308-1200-R
200:1
22
8
3.9
500 Vac
15
1. Primary current of 15 A causes less than 40°C temperature rise @ +2 5°C ambient. Higher current causes a greater
temperature rise
2. Electrical specifications at +25 °C
3. Part Number Definition: ECSTA1V1308-1xxx-R
ECSTA1V1308 = Product code and size
1xxx= Turns ratio sec:pri 1=pri, xxx=sec; 1020= 20:1
-R suffix = RoHS compliant
Mechanical parameters, schematic, pad layout (mm)
Recommended PCB Layout
Schematic
Dimension
Value
A
11.00 maximum
B
13.00 maximum
C
7.80 maximum
E
0.7
F
0.25
G
0.8 ±0.2
H
2.5 ±0.3
Part marking: White dot, Pin 1 indicator
All soldering surfaces to be coplanar within 0.15 millimeters
Tolerances are ±0.1 millimeters unless stated otherwise
Traces or vias underneath the inductor is not recommended
2
www.eaton.com/electronics
ECSTA1V1308
Effective June 2022
Temperature rise vs current
3
Effective June 2022
ECSTA1V1308
Packaging information (mm)
Supplied in tape and reel packaging, 13” diameter reel (EIA-481 compliant)
350 parts per reel
4
Dimension
Value
W
24.0 ±0.3
P1
20.0 ±0.1
E1
1.75 ±0.1
F
11.5 ±0.05
P2
2.0 ±0.05
D0
1.5 +0.1/-0
D1
1.5 +0.1/-0
B0
11.7 ±0.1
A0
13.3 ±0.1
K0
8.2 ±0.1
P0
4.0 ±0.1
T
0.40 ±0.05
Dimension
Value
A
330 ±3.0
B
2.6 ±0.3
N
100 ±1.0
C
13+0.5/-0.2
D
21.5 ±0.5
W1
16.4+2.0/-0.0
W2
30.4 max
W3
na
ECSTA1V1308
Effective June 2022
Solder reflow profile
Table 1 - Standard SnPb solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“ECSTA1V1308-1100-R”相匹配的价格&库存,您可以联系我们找货
