Over�current�switch,�5A,�1p,�type�C�characteristic
Part�no.
Article�no.
Catalog�No.
Similar to illustration
FAZ-C5/1
278554
FAZ-C5/1
Delivery�program
Basic function
Miniature circuit-breakers
Number of poles
1 pole
Tripping characteristic
C
Application
Switchgear for industrial and advanced commercial applications
Rated current
In
A
5
Rated switching capacity acc. to IEC/EN 60947-2
kA
15
Product range
FAZ
Standards
IEC/EN 60947‐2
IEC/EN 60898
Rated operational voltage
Ue
V
Ue
V AC
240/415
kA
15
Rated operational current for specified heat dissipation
In
A
5
Heat dissipation per pole, current-dependent
Pvid
W
Equipment heat dissipation, current-dependent
Pvid
W
1.9
Static heat dissipation, non-current-dependent
Pvs
W
Heat dissipation capacity
Pdiss
W
Operating ambient temperature min.
°C
-40
Operating ambient temperature max.
°C
75
linear, per +1 °C, results in a 0.5% reduction of current carrying capacity
10.2 Strength of materials and parts
10.2.2 Corrosion resistance
Meets the product standard's requirements.
10.2.3.1 Verification of thermal stability of enclosures
10.2.3.2 Verification of resistance of insulating materials to normal heat
10.2.3.3 Verification of resistance of insulating materials to abnormal heat
and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
Does not apply, since the entire switchgear needs to be evaluated.
10.2.6 Mechanical impact
10.2.7 Inscriptions
10.3 Degree of protection of ASSEMBLIES
10.4 Clearances and creepage distances
10.5 Protection against electric shock
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
Is the panel builder's responsibility.
10.8 Connections for external conductors
Technical�data
Electrical
Design�verification�as�per�IEC/EN�61439
Technical data for design verification
IEC/EN 61439 design verification
04/12/2017
278554 - HPL-ED2017 V31.0 EN
1/2
10.9 Insulation properties
10.9.2 Power-frequency electric strength
10.9.3 Impulse withstand voltage
10.9.4 Testing of enclosures made of insulating material
10.10 Temperature rise
The panel builder is responsible for the temperature rise calculation. Eaton will
provide heat dissipation data for the devices.
10.11 Short-circuit rating
Is the panel builder's responsibility. The specifications for the switchgear must be
observed.
10.12 Electromagnetic compatibility
observed.
10.13 Mechanical function
The device meets the requirements, provided the information in the instruction
leaflet (IL) is observed.
Technical�data�ETIM�6.0
Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042)
Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB) (ecl@ss8.1-27-14-19-01
[AAB905011])
Release characteristic
C
Number of poles (total)
1
Number of protected poles
1
Nominal rated current
A
5
Nominal rated voltage
V
230
Rated short-circuit breaking capacity Icn EN 60898 at 230 V
kA
10
Rated short-circuit breaking capacity Icn EN 60898 at 400 V
kA
10
Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V
kA
15
Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V
kA
15
Voltage type
AC
Current limiting class
3
Frequency
Hz
50 - 60
Concurrently switching N-neutral
No
Suitable for flush-mounted installation
No
Over voltage category
3
Pollution degree
2
Width in number of modular spacings
1
Built-in depth
mm
70.5
Additional equipment possible
Yes
Degree of protection (IP)
IP20
Product Standards
IEC/EN 60947-2; IEC/EN 60898; UL 1077; CSA-C22.2 No. 235; CE marking
UL File No.
E177451
UL Category Control No.
QVNU2, QVNU8
CSA File No.
204453
CSA Class No.
3215-30
North America Certification
UL recognized, CSA certified
Conditions of Acceptability
Supplementary Protector only
Suitable for
Branch Circuits; not as BCPD
Current Limiting Circuit-Breaker
No
Max. Voltage Rating
277 VAC; 48 VDC
Degree of Protection
IEC: IP20; UL/CSA Type: -
Approvals
04/12/2017
Eaton Industries GmbH
http://www.eaton.eu
© 04/2017 by Eaton Industries GmbH
2/2
很抱歉,暂时无法提供与“FAZ-C5/1-SP”相匹配的价格&库存,您可以联系我们找货
