Effective December 2015
Supersedes April 2014
Technical Data 2028
BUSSMANN
SERIES
FNM 13⁄32˝ x 1-1⁄2˝ 250Vac time-delay
supplemental fuses
Catalog symbol / color code:
Dimensions - in (mm):
FNM
• Green (250Vac max)
Description:
0.41"
(10.3)
Time-delay supplemental fuse.
For superior protection, Eaton recommends
upgrading to Bussmann series Low-Peak™
Class CC fuses. See data sheet No. 1023.
Specifications:
Ratings
250Vac
1/10 to 30A
1.5"
(38.1)
Features
Color coded green for 250Vac maximum
voltage rating
Melamine tube construction
Nickel-plated endcaps
Fuse
amp
range
Interrupting rating at
system voltage
Agency
information
Typical applications
250Vac
125Vac
UL®
CSA®
1/10 to 1
35A
10kA
X
X
Circuits with high inrush currents
(motor/transformer loads)
1-1/8 to 3-1/2
100A
10kA
X
X
4 to 10
200A
10kA
X
X
Supplemental protection for inductive
circuits up to 250Vac.
12 to 30
10kA
X
X
Agency information
Recommended fuse blocks/fuse holders
Catalog
Description
CE
symbol
Blocks
UL Listed, Std. 248-14, Guide JDYX;
File E19180
BMM
CSA Certified, Class 1422-01, File 53787
1-, 2- and 3-pole
modular blocks with
optional covers
DIN-Rail holders / switches
RoHS compliant
CCP-_-30M
Catalog numbers (amps)
Data sheet
No.
10235
1-, 2- and 3-pole
switch
1157
CHM
1-, 2- and 3-pole
3185
Optima NG
3-pole protection
module
1109
FNM-1⁄10
FNM-8⁄10
FNM-2-1⁄2
FNM-6-1⁄4
FNM-1⁄8
FNM-1
FNM-2-8⁄10
FNM-7
Optima
3-pole holder
1102
FNM-15⁄100
FNM-1-1⁄8
FNM-3
FNM-8
Optima
1103
FNM-2⁄10
FNM-1-1⁄4
FNM-3-2⁄10
FNM-9
3-pole holder +
switch
FNM-1⁄4
FNM-1-4⁄10
FNM-3-1⁄2
FNM-10
FNM-3⁄10
FNM-1-1⁄2
FNM-4
FNM-12
FNM-4⁄10
FNM-1-6⁄10
FNM-4-1⁄2
FNM-15
FNM-1⁄2
FNM-1-8⁄10
FNM-5
FNM-20
FNM-6⁄10
FNM-2
FNM-5-6⁄10
FNM-25
FNM-3⁄4
FNM-2-1⁄4
FNM-6
FNM-30
Carton quantity
Amps
1/10 to 30
Panel mount holders
HPM and HPM-D
1-pole holder
2112
HPC-D
1-pole holder
2109
HPS2
2-pole holder
2140
HPF, HPF-C and
HPF-WT
1-pole holder
2114
HPS
1-pole holder
2113
HPG and HPD
1-pole holder
2108
In-line holders
Qty.
10
HEB
1-pole holder
2127
HEX
2-pole holder
2126
PCB fuseclips
2132
Fuseclips
1A3400, 5956
and 5960
Fuse covers
CVR(I)-CCM(-QC)
Finger-safe fuse
cover
10235
FNM
250Vac time-delay supplemental fuses
Technical Data 2028
Time-current characteristic curves – total clearing:
10A
5A
Time in seconds
Time in Seconds
2A
Amp
Rating
Amp
rating
Current
in amps
Current
in Amps
2
Eaton.com/bussmannseries
FNM
Technical Data 2028
Time-current characteristic curves – average melt:
Time in Seconds
12A
15A
20A
25A
30A
Amp
AmpRating
rating
Current in amps
Current in Amps
The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this
document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical
information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction
of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible
applications.
Eaton
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com
Bussmann Division
114 Old State Road
Ellisville, MO 63021
United States
© 2015 Eaton
All Rights Reserved
Printed in USA
Publication No. 2028 – BU-SB14291
December 2015
For Eaton’s Bussmann series
product information,
call 1-855-287-7626 or visit:
Eaton, Bussmann and Low-Peak are
valuable trademarks of Eaton in the US
and other countries. You are not permitted
to use the Eaton trademarks without prior
written consent of Eaton.
CSA is a registered trademark of the
Canadian Standards Group.
UL is a registered trademark of the
Underwriters Laboratories, Inc.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“FNM-30”相匹配的价格&库存,您可以联系我们找货
