FP1008R5-R220-R
FP1008R5-R220-R
    EATON(伊顿)
    SMD,10.8x8mm
    220 nH 屏蔽 电感器 79 A 0.17 毫欧 非标准
FP1008R5-R220-R 数据手册
Technical Data 10520 Effective April 2017 FP1008R5 and FP1008R6 High frequency, high current power inductors Applications Product features • High current carrying capacity • Low core loss • Magnetically shielded • Tight tolerance DCR for sensing circuits • Inductance Range from 100 nH to 300 nH • Current range from 36 A to 103 A • 10.8 mm x 8.0 mm footprint surface mount package in an 8.0 mm height • Moisture Sensitivity Level: 1 • Ferrite core material • Multi-phase and Vcore regulators • Voltage Regulator Modules (VRMs) and high power density VRMs • Server and desktop • Central processing unit (CPU) • Graphics processing unit (GPU) • Application specific integrated circuit (ASIC) • Data networking and storage systems • Graphics cards and battery power systems • Point-of-Loadmodules (POL) • DCR sensing circuits Environmental data • Storage temperature range (Component): -40 °C to +125 °C • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant • Halogen free, lead free, RoHS compliant HALOGEN Pb HF FREE FP1008R5 and FP1008R6 High frequency, high current power inductors  Technical Data 10520 Effective April 2017 Product specifications OCL1 (nH) ±10% FLL2 (nH) minimum Irms3 (A) Isat14 (A) Isat25 (A) Isat36 (A) DCR (mΩ) ±5% @ 20 °C K-factor7 FP1008R5-R120-R 120 86 79 103 90 84 0.170 342 FP1008R5-R150-R 150 108 79 85 68 64 0.170 342 FP1008R5-R180-R 180 130 79 70 56 53 0.170 342 FP1008R5-R220-R 220 158 79 58 44 42 0.170 342 FP1008R5-R270-R 270 194 79 44 34 32 0.170 342 FP1008R5-R300-R 300 216 79 36 28 26 0.170 342 FP1008R6-R100-R 100 72 74 103 86 81 0.180 342 FP1008R6-R120-R 120 86 74 103 90 84 0.180 342 FP1008R6-R150-R 150 108 74 85 68 64 0.180 342 Part Number8 R5 version R6 version FP1008R6-R180-R 180 130 74 70 56 53 0.180 342 FP1008R6-R220-R 220 158 74 58 44 42 0.180 342 FP1008R6-R270-R 270 194 74 44 34 32 0.180 342 FP1008R6-R300-R 300 216 74 36 28 26 0.180 342 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C 2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C 3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating conditions verified in the end application. 4. Isat1: Peak current for approximately 20% rolloff @ +25 °C 5. Isat2: Peak current for approximately 20% rolloff @ +100 °C 6. Isat3: Peak current for approximately 20% rolloff @ +125 °C 7. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table), L: (Inductance in nH), ∆I (Peak to peak ripple current in Amps). 8. Part Number Definition: FP1008Rx-Rxxx-R FP1008R= Product code and size x= Version indicator -Rxxx= Inductance value in uH, R= decimal point -R suffix = RoHS compliant Dimensions (mm) Part marking: FP1008Rx (x = Version), Rxxx= Inductance value in uH (R= decimal point) xxxx = Lot code Tolerances are ±0.15 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise All soldering surfaces to be coplanar within 0.1 millimeter DCR measured from point “A” to point “B” Do not route traces or vias underneath the inductor 2 www.eaton.com/electronics FP1008R5 and FP1008R6 High frequency, high current power inductors Technical Data 10520 Effective April 2017  Packaging information (mm) Supplied in tape-and-reel packaging, 500 parts on a 13” diameter reel. Temperature rise vs total loss FP1008R6 60 60 50 50 Temperature Rise (°C) Temperature Rise (°C) FP1008R5 40 30 20 30 20 10 10 0 40 0.0 0.2 0.4 0.6 0.8 Total Loss (W) 1.0 1.2 1.4 1.6 0 0.0 0.2 0.4 0.6 0.8 Total Loss (W) 1.0 1.2 www.eaton.com/electronics 1.4 1.6 3 FP1008R5 and FP1008R6 High frequency, high current power inductors  Technical Data 10520 Effective April 2017 Core loss vs. Bp-p FP1008R5 1 0.1 Core Loss (W) Core Loss (W) 0.1 0.01 0.001 0.0001 FP1008R6 1 0.01 0.001 100 1000 0.0001 10000 Bp-p (Gauss) 100 1000 10000 Bp-p (Gauss) Inductance characteristics FP1008R5-R120-R 140 140 120 120 Inductance (nH) Inductance (nH) 100 80 60 -40 °C 40 +25 °C 4 20 40 80 60 -40 °C +25 °C +100 °C 20 +125 °C 0 100 40 +100 °C 20 0 FP1008R5-R150-R 160 60 www.eaton.com/electronics Idc (A) 80 100 120 140 0 +125 °C 0 20 40 60 Idc (A) 80 100 120 FP1008R5 and FP1008R6 High frequency, high current power inductors Technical Data 10520 Effective April 2017  Inductance characteristics FP1008R5-R180-R 200 FP1008R5-R220-R 240 180 200 160 Inductance (nH) Inductance (nH) 140 120 100 80 80 +25 °C +100 °C 20 40 +100 °C +125 °C 0 10 20 +125 °C 30 40 50 Idc (A) 60 70 80 90 0 100 FP1008R5-R270-R 320 0 10 20 40 Idc (A) 50 60 70 80 FP1008R5-R300-R 300 240 250 Inductance (nH) 200 160 120 -40 °C 80 200 150 -40 °C 100 +25 °C +100 °C 40 +25 °C +100 °C 50 +125 °C +125 °C 0 10 20 30 Idc (A) 40 50 60 0 70 FP1008R6-R100-R 120.0 0 10 20 30 Idc (A) 40 50 60 FP1008R6-R120-R 140 120 100.0 Inductance (nH) 100 Inductance (nH) 80.0 60.0 40.0 80 60 -40 °C 40 -40 °C +25 °C +25 °C 20.0 +100 °C 20 +100 °C +125 °C +125 °C 0.0 30 350 280 Inductance (nH) -40 °C +25 °C 40 0 120 -40 °C 60 0 160 0 20 40 60 80 Idc (A) 100 120 140 160 0 0 20 40 60 Idc (A) 80 100 120 www.eaton.com/electronics 140 5 FP1008R5 and FP1008R6 High frequency, high current power inductors  Technical Data 10520 Effective April 2017 Inductance characteristics FP1008R6-R150-R 160 FP1008R6-R180-R 200 180 140 160 Inductance (nH) Inductance (nH) 120 100 80 60 40 120 100 60 +25 °C 40 20 40 60 80 Idc (A) 100 0 120 FP1008R6-R220-R 240 -40 °C +25 °C +100 °C 20 +125 °C 0 80 -40 °C +100 °C 20 0 140 +125 °C 0 10 20 30 40 50 Idc (A) 60 70 80 90 100 FP1008R6-R270-R 320 280 200 160 Inductance (nH) Inductance (nH) 240 120 80 +100 °C 0 10 20 30 40 Idc (A) 50 60 70 80 FP1008R6-R300-R 250 200 150 -40 °C 100 +25 °C +100 °C 50 +125 °C 0 10 20 www.eaton.com/electronics +25 °C +100 °C +125 °C 300 Inductance (nH) -40 °C 40 +125 °C 350 6 120 80 +25 °C 0 160 -40 °C 40 0 200 30 Idc (A) 40 50 60 0 0 10 20 30 Idc (A) 40 50 60 70 FP1008R5 and FP1008R6 High frequency, high current power inductors Technical Data 10520 Effective April 2017  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
FP1008R5-R220-R 价格&库存
很抱歉,暂时无法提供与“FP1008R5-R220-R”相匹配的价格&库存,您可以联系我们找货
FP1008R5-R220-R
  • 500+11.18150500+1.45116
  • 1000+10.544761000+1.36852
  • 1500+10.189681500+1.32244
  • 2500+9.759732500+1.26664
  • 3500+9.486813500+1.23122
  • 5000+9.206095000+1.19479
库存:16075
FP1008R5-R220-R
    FP1008R5-R220-R
