Bussmann®
Buss High Voltage Fuses
HV
Series
1000 - 10,000 Volts
HVA (1000 Volts)
Amps
1/16
1/8
1/4
1/10
2/10
3/10
3/8
1/2
CATALOG SYMBOL: HVA, HVB, HVJ, HVL, HVR, HVT, HVU,
HVW, AND HVX
NON-TIME DELAY
1000 TO 10,000 VOLTS
• Non-Time Delay fuses for high voltage instruments and circuits.
• Physical size varies with electical rating of fuse to prevent
over-fusing.
• Use HVA, HVB, HVJ an d HVL for circuits up to 20kw dc or
30 KVA ac. For higher interrupting capacity, use HVR, HVT,
HVU, HVW and HVX.
mm
*Wt./100
Lbs.
Kg
0.41”
3”
76.1
2
0.91
1/2
3/4
1
1-1/2
2
3
0.41”
4.5”
114.2
3
1.36
0.81”
5”
126.9
9
4.08
0.81”
10”
253.8
15
6.80
76.1
3
1.36
114.2
4
1.81
126.9
19
8.62
57.1
2
0.91
36
16.33
HVJ (5000 Volts)
1-1/2
2
4
6
10
HVL (10,000 Volts)
1/16
1/8
1/4
1/2
1
1-1/2
2
3
HVR (1000 Volts) (max. S.C. KVA-500)
1/2
1
2
3
4
5
0.41”
3”
HVT (2500 Volts) (max. S.C. KVA-1250)
Test Spectifications
Catalog
Number
HVA
HVB
HVJ
HVL
HVR
HVT
HVU
HVW
HVX
Length
In.
HVB (2500 Volts)
1/16
1/8
1/4
1/2
3/4
1
13/32” and 13/16” x Length
(10.3mm and 20.6mm x Length)
For High Voltage Circuits
3/4
1
1-1/2
2
3
4
6
10
Dia.
Load
Opening Time
110%
135%
4 Hours (min.)
1 Hour (max.)
100%
150%
4 Hours (min.)
1 Hour (max.)
1/2
1
2
3
5
0.41”
4.5”
HVU (5000 Volts) (max. S.C. KVA-2500)
1/2
1
2
3
4
5
0.81”
5”
HVW (1200 Volts) (max. S.C. KVA-5000)
1/2
1
2
3
4
5
0.41”
2.25”
8
HVX (10,000 Volts) (max. S.C. KVA-12,000)
1/2
3
1
5
*Shipping.
Carton quantity: 10.
12-21-98
SB98107
Rev. A
0.41”
10.0”
253.8
Form No. HV Series
Page 1 of 2
BIF Doc #6003
Bussmann®
HV
Series
1000 - 10,000 Volts
3
2
1/2
3/4
1
AMPERE
RATING
1/4
300
1/16
Time-Current Characteristic Curves—Average Melt
100
CATALOG SYMBOL: 4528, 4529, 4530, AND 2960
FUSE BLOCKS
10
TIME IN SECONDS
For BUSS High Voltage Fuses
(1000 to 10,000 Volts)
• Bakelite base.
• Alloy plated terminals.
Dimensional Data
1
B
.1
C
HVA
HVR
HVB
HVT
HVJ
HVU
HVL
HVX
4528
4529
4530
2960
C
Base
Width
3.75”
1.125”
0.38”
1.0”
(95.3)
(28.6)
(9.5)
(25.4)
5.25”
1.125”
0.38”
1.0”
(133.4)
(28.6)
(9.5)
(25.4)
6.5”
1.66”
0.5”
1.38”
(165.1)
(42.1)
(12.7)
(34.9)
11.44”
1.45”
0.75”
1.38”
(290.5)
(48.4)
(19.1)
(34.9)
.01
B
10
A
1
*Dimensions
Inches/(mm’s)
.1
Bock
Cat.
No.
.02
For
Fuse
Sym.
A
CURRENT IN AMPERES
*Two mounting holes:
Use #8 screws on blocks 4528 and 4529.
Use #10 screws on blocks 4530 and 2960.
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to
clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any
products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
12-21-98
SB98107
Rev. A
Form No. HV Series
Page 2 of 2
BIF Doc #6003
很抱歉,暂时无法提供与“HVJ-1/8”相匹配的价格&库存,您可以联系我们找货
