Technical Data 11207
Effective November 2020
15KPE
15000 W Transient voltage suppressor
Applications
Product features
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
Low incremental surge resistance
Excellent clamping capability
15,000 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 2 μA above 30 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow and wave soldering
Plastic package meets UL 94 V-0 flammability
rating
Terminal: Solder plated leads,
solderable per J-STD-02
Family name
VR voltage
UL 497B recognized.
File No. : E198449 Guide QVGQ2
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
PIN configuration
HALOGEN
Pb HF
FREE
Ordering part number
15KPE 280 C A
15KPE
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +175
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
8.0
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
15,000
W
Peak forward surge current, 8.3 ms single half
sine-wave for unidirectional only
IFSM
400
A
Typical thermal resistance junction to lead
R
JL
8.0
°C/W
Typical thermal resistance junction to ambient
R
JA
40
°C/W
Storage operating junction temperature range
Mechanical parameters- mm
Millimeters
Dimension Minimum
A
Part marking
Cathode band
(Uni-polar only)
15KPExxA
Packaging information (mm)
300 parts per box.
2
www.eaton.com/electronics
15KPExxCA
Inches
Maximum
25.40
Minimum
1.000
B
8.60
9.40
0.339
0.370
C
1.20
1.40
0.047
0.055
D
8.60
9.10
0.339
0.358
15KPE
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
15KPE17A
15KPE17CA
17
5000
18.9
20.9
50
29.3
515.4
15KPE18A
15KPE18CA
18
5000
50
30.9
488.7
15KPE20A
15KPE20CA
22.2
24.5
440.2
15KPE22A
15KPE22CA
22
500
24.4
26.9
10
37.1
407
15KPE24A
15KPE24CA
24
150
26.7
29.5
5
40.7
371
15KPE26A
15KPE26CA
26
50
28.9
31.9
5
44
343.2
15KPE28A
15KPE28CA
28
25
31.1
34.4
5
47.5
317.9
15KPE30A
15KPE30CA
30
15
33.3
36.8
5
50.7
297.8
15KPE33A
15KPE33CA
33
2
36.7
40.6
5
54.7
276.1
15KPE36A
15KPE36CA
36
2
40
44.2
5
59.8
252.5
15KPE40A
15KPE40CA
40
2
44.4
49.1
5
65.8
229.5
15KPE43A
15KPE43CA
43
2
47.8
52.8
5
69.8
216.3
15KPE45A
15KPE45CA
45
2
50
55.3
5
72.8
207.4
15KPE48A
15KPE48CA
48
2
53.3
58.9
5
77.7
194.3
15KPE51A
15KPE51CA
51
2
56.7
62.7
5
82.9
182.1
15KPE54A
15KPE54CA
54
2
60
66.3
5
87.7
172.2
15KPE58A
15KPE58CA
58
2
64.4
71.2
5
93.8
161
15KPE60A
15KPE60CA
60
2
66.7
73.7
5
97.4
155
15KPE64A
15KPE64CA
64
2
71.1
78.6
5
104.2
144.9
15KPE70A
15KPE70CA
70
2
77.8
86
5
113.6
132.9
15KPE75A
15KPE75CA
75
2
83.3
92.1
5
122
123.8
15KPE78A
15KPE78CA
78
2
86.7
95.8
5
126.1
119.7
15KPE85A
15KPE85CA
85
2
94.4
104
5
137.6
109.7
15KPE90A
15KPE90CA
90
2
100
111
5
145.6
103.7
15KPE100A
15KPE100CA
100
2
111
123
5
161.3
93.6
15KPE110A
15KPE110CA
110
2
122
135
5
178.6
84.5
15KPE120A
15KPE120CA
120
2
133
147
5
192.3
78.5
15KPE130A
15KPE130CA
130
2
144
159
5
208.3
72.5
15KPE150A
15KPE150CA
150
2
167
185
5
241.9
62.4
15KPE160A
15KPE160CA
160
2
178
197
5
258.6
58.4
15KPE170A
15KPE170CA
170
2
189
209
5
272.7
55.4
15KPE180A
15KPE180CA
180
2
201
222
5
288.5
52.3
15KPE200A
15KPE200CA
200
2
224
247
5
319.1
47.3
15KPE220A
15KPE220CA
220
2
246
272
5
352.5
42.8
15KPE240A
15KPE240CA
240
2
268
292
5
384.6
39.3
15KPE260A
15KPE260CA
260
2
289
317
5
416.7
36.2
15KPE280A
15KPE280CA
280
2
311
341
5
454.5
33.2
3
15KPE
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage
VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current
IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse derating curve
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse waveform
Peak value
Half value
50
td
2.0
3.0
4.0
t (ms)
1000
Ppp (kW)
15000 W at 10/1000 µs +25 °C
100
10
0.01
0.1
td-Pulse width (ms)
4
80
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
Peak pulse power dissipation vs. pulse width
1.0
0.001
100
1.0
10
175
15KPE
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“15KPE28CA”相匹配的价格&库存,您可以联系我们找货
