7805K13
7805K13
    EATON(伊顿)
7805K13 数据手册
XT Series Toggles Vehicle Controls • Commercial and industrial equipment • Household appliances • Industrial machinery and automation • Medical equipment • Military communications and surveillance • Rail systems • Signaling and communications • Test and lab equipment • Telecommunications, cable and broadcasting Accessories Keyway 16.0 ± 0.3 28.6 ± 0.3 ø6.0 ± 0.3 16.5 ± 1.0 11.9 ± 0.3 17.2 ± 0.5 11.5 ± 0.5 15/32-32 NS-2A 1 Eaton’s new competitively priced ac rated XT Series Toggles offer a standard high rating for both single- and double-pole applications. The new XT Series Toggle line offers a wide range of switching circuits, functions and accessories. Ratings for single- and double-pole include 20 A at 125 Vac and 10 A at 277 Vac to handle more severe inductive, motor and lamp loads. In addition, XT Series Toggles have a high standard horsepower rating of 1-½ hp from 125 – 250 Vac for double-pole applications. The easy-to-install toggles also have an industry standard .480-inch diameter mounting hole. For added convenience and delivery support, select industry standard switch circuit part numbers are available from stock. With so many features, XT Series can be used in a variety of applications! 2 Applications 3 Introduction Single-Pole Dimensions in mm For more information on relevant accessories, see publication number TD07002001E. Keyway Mounting Hole 19.0 ± 0.5 ø12.0+0.1 -0 33.0 ± 0.5 16.5 ± 1.0 ø6.0 ± 0.2 1.6 ± 0.1 11.0 ± 0.1 11.9 ± 0.3 18.8 ± 0.5 11.5 ± 0.5 15/32-32 NS-2A 3 2 1 3 4 6 6 1 5 4 Double-Pole Dimensions in mm Specifications Summary Single-Pole Rating 20 A, 125 Vac; 10 A, 277 Vac; 3/4 hp 125 – 250 Vac Double-Pole Rating 20 A, 125 Vac; 10 A, 277 Vac; 1-1/2 hp 125 – 250 Vac Available Circuits 1PST, 1PDT, 2PST, 2PDT Terminal Types Brass Screw, Brass Solder Lugs, Brass Nickel-Plated .250” Spade Hardware Included Zinc Nickel-Plated Knurl Nut, Zinc Nickel-Plated Hex Nut Mounting Means Threaded Bushing 12.0 +.1, -0 mm; 16.5 +1, -1 mm Keyway 1.8 mm Located in Down Position Base Material Thermoset Molding Material Finish Bright Nickel-Plated Toggle Lever and Bushing Contact Mechanism Slow-make/Slow-break Butt Contact Contact Resistance 50 Ohm Maximum Dielectric Strength AC 1500 V, 1 Minute Operating Temperature 0 – 65°C Insulation Resistance DC 500 V 100M Ohm Minute Seal Level Rating IP40 Approval UL姞 Recognized component for Canada (cUR marked): File E2702; RoHS Compliant Packaging Sealed in Polybag Labeled with Part Number 1 Furnished bulk packaged. Single-Pole — Rating 20 A at 125 Vac; 10 A at 277 Vac; 3/4 hp, 125 – 250 Vac; Recommended up to 15 A at 28 Vdc Circuit with Toggle In Terminal Type — Catalog Number Poles and Throw UP Position CENTER Position DOWN Position 2 .250 Spade Screw Solder Lugs 1 PST ON NONE OFF XTD1A1A2 XTD1A2A2 XTD1A3A2 1 PST ON 3 NONE OFF XTD1F1A2 XTD1F2A2 XTD1F3A2 1 PDT ON OFF ON XTD2B1A XTD2B2A XTD2B3A 1 PDT ON NONE ON XTD2C1A XTD2C2A XTD2C3A 1 PDT ON NONE ON 3 XTD2D1A XTD2D2A XTD2D3A 1 PDT ON 3 OFF ON 3 XTD2E1A XTD2E2A XTD2E3A 1 PDT ON OFF ON 3 XTD2G1A XTD2G2A XTD2G3A 2 Keyway position. 3 Indicates momentary position. Double-Pole — Rating 20 A at 125 Vac; 10 A at 277 Vac; 1-1/2 hp at 125 – 250 Vac; Recommended up to 15 A at 28 Vdc Circuit with Toggle In Terminal Type — Catalog Number Poles and Throw UP Position CENTER Position DOWN Position 4 .250 Spade Screw Solder Lugs 2 PST ON NONE OFF XTD3A1A2 XTD3A2A2 XTD3A3A2 2 PST ON 5 NONE OFF XTD3F1A2 XTD3F2A2 XTD3F3A2 2 PDT ON OFF ON XTD4B1A XTD4B2A XTD4B3A 2 PDT ON NONE ON XTD4C1A XTD4C2A XTD4C3A 2 PDT ON NONE ON 5 XTD4D1A XTD4D2A XTD4D3A 2 PDT ON 5 OFF ON 5 XTD4E1A XTD4E2A XTD4E3A 2 PDT ON OFF ON 5 XTD4G1A XTD4G2A XTD4G3A 4 Keyway position. 5 Indicates momentary position. Eaton Corporation Electrical Group 1000 Cherrington Parkway Moon Township, PA 15108 United States 877-ETN-CARE (877-386-2273) Eaton.com © 2008 Eaton Corporation All Rights Reserved Printed in USA Publication No. PA07002001E / Z7847 October 2008 PowerChain Management is a registered trademark of Eaton Corporation. All other trademarks are property of their respective owners.
7805K13 价格&库存
很抱歉,暂时无法提供与“7805K13”相匹配的价格&库存,您可以联系我们找货
