86-5359-4
86-5359-4
    EATON(伊顿)
86-5359-4 数据手册
NEMA Contactors & Starters Freedom, Full Voltage — Enclosed 33-127 February 2008 Product Family Overview Cover Control Item: 86-5359-4 Non-reversing Flange Control Kits 33 For on-the-job conversion of Type 1, 3R, 4X and 12 enclosed starters. Knockouts are provided on the Type 1 flange. Type 3R, 4X and 12 have prepunched holes with removable hole plugs. Factory Installed Pilot Devices Figure 33-50. Figure 33-51. To order factory installed pilot devices, change the 9th character of the Catalog Number to the alpha shown in the table below. Example: to order an ECN0514CAA with START/STOP pushbuttons and a red pilot light, change the A to a C, i.e. ECN0514CCA. Table 33-185. Non-reversing Pilot Devices Description Factory Installed Flange Control Position Non-combination See Figure 33-50 9 Alpha Code Adder U.S. $ Combination (NEMA only) See Figure 33-51 Adder U.S. $ No Cover Mounted Pilot Devices A START/STOP Pushbuttons B with Red RUN Pilot Light C with Red RUN/Green OFF Lights D ON/OFF Pushbuttons E with Red RUN Pilot Light F with Red RUN/Green OFF Lights G HAND/OFF/AUTO Selector Switch H with Red RUN Pilot Light J with Red RUN/Green OFF Lights K START Pushbutton L ON Pushbutton M OFF Pushbutton N Red RUN Pilot Light P Green OFF Q Red RUN/Green OFF Pilot Lights R START/STOP Selector Switch S with Red RUN Pilot Light T with Red RUN/Green OFF Lights U ON/OFF Selector Switch V with Red RUN Pilot Light W with Red RUN/Green OFF Lights X Type 1, NEMA Sizes 00 – 4/IEC Frames A – M Non-combination ONLY. Type 1, NEMA Sizes 5 – 9/IEC Frames N – V Non-combination PLUS all Type 3R, 4X, 12 Non-combination PLUS all Combination — NEMA Sizes only. For IEC Combination Cover Control, see Page 33-152. Add Code Letter from the table below to Catalog Number for voltage — Kits only. Example: C400T9B. Rating Code Letter Rating Code Letter Rating Code Letter 120V 60 Hz 208V 60 Hz A E 240V 60 Hz 380V 50 Hz B L 480V 60 Hz 600V 60 Hz Field Installation Kits Non-combination See Figure 33-50 Catalog Number Price U.S. $ C400GK0 C400GK1 C400GK12 C400GK16 — — — C400GK3 C400GK32 C400GK36 — — — C400GK42 C400GK41 C400GK46 — — — — — — Combination (NEMA only) See Figure 33-51 Catalog Price Number U.S. $ — C400T1 — — C400T2 — — C400T12 — — C400T3 C400T4 C400T5 C400T9 C400T10 C400T11 C400T13 — — C400T14 — — C D Discount Symbol . . . . . . . . . . . . . . . . . . . . . 1CD1C CA08102001E For more information visit: www.eaton.com NEMA Contactors & Starters Freedom, Full Voltage — Enclosed 33-128 February 2008 Product Family Overview Reversing Flange Control Kits 33 For on-the-job conversion of Type 1, 3R, 4X and 12 enclosed starters. Knockouts are provided on the Type 1 flange. Type 3R, 4X and 12 have prepunched holes with removable hole plugs. Figure 33-52. Factory Installed Pilot Devices Figure 33-53. To order factory installed pilot devices, change the 9th character of the Catalog Number to the alpha shown in the table below. Example: to order an ECN0614CAA with FOR/REV/STOP pushbuttons and 2 red pilot lights, change the A to a C, i.e. ECN0614CCA. Table 33-186. Reversing Pilot Devices Description Factory Installed Flange Control Position Non-combination See Figure 33-52 9 Alpha Code No Cover Mounted Pilot Devices FOR/REV/STOP Pushbuttons with 2 Red Pilot Lights with 2 Red/1 Green Pilot Lights UP/STOP/DOWN Pushbuttons with 2 Red Pilot Lights FOR/OFF/REV Selector Switch with 2 Red Pilot Lights with 2 Red/1 Green Pilot Lights Two Red Pilot Lights One Green Pilot Light Two Red/One Green Pilot Lights OPEN/OFF/CLOSE Selector Switch with 2 Red Pilot Lights with 2 Red/1 Green Pilot Lights A B C D E F H J K P Q R V W X Field Installation Kits Non-combination See Figure 33-52 Catalog Number Price U.S. $ C400GK0 C400GR1 C400GR14 — C400GR2 C400GR24 — — — C400GK44 C400GK41 — — — — Combination (NEMA only) See Figure 33-53 Catalog Price Number U.S. $ — C400T6 — — — — C400T15 — — C400T10 — C400T16 — — Type 1, NEMA Sizes 00 – 4/IEC Frames A – M Non-combination ONLY. Type 1, NEMA Sizes 5 – 9/IEC Frames N – V Non-combination PLUS all Type 3R, 4X, 12 Non-combination PLUS all Combination — NEMA Sizes only. For IEC Combination Cover Control, see Page 33-152. Add Code Letter from the table below to Catalog Number for voltage — Kits only. Example: C400T10B. Rating Code Letter Rating Code Letter Rating Code Letter 120V 60 Hz 208V 60 Hz Adder U.S. $ Combination (NEMA only) See Figure 33-53 Adder U.S. $ A E 240V 60 Hz 380V 50 Hz B L 480V 60 Hz 600V 60 Hz C D Order Quantity (2) of C400T10. Discount Symbol . . . . . . . . . . . . . . . . . . . . . . 1CD1C For more information visit: www.eaton.com CA08102001E
86-5359-4 价格&库存
很抱歉,暂时无法提供与“86-5359-4”相匹配的价格&库存,您可以联系我们找货
